[petsc-dev] Fwd: [Bitbucket] Pipeline for master failed on c3c607c (petsc/petsc)
Barry Smith
bsmith at mcs.anl.gov
Sun Jan 22 14:42:42 CST 2017
Once something bugs you with irrelevant things you pretty soon start to ignore it and then it becomes useless.
> On Jan 22, 2017, at 3:09 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 21 January 2017 at 20:27, Barry Smith <bsmith at mcs.anl.gov> wrote:
> It appears the step that failed is just initializing the virtual machine, it hasn't gotten anywhere near PETSc? If it fails in this situation it should not send me any email, why should I get spammed with email about things I can't do anything about? It should only send me email if it is an error in the truly "PETSc" part of the process.
> Well, Barry, I'm not sure. These kind of VM issues are not frequent. This way you know there was a problem and your commit was not tested, then you can click the link and hit "Rerun" to try again. Of course, I agree the message is suboptimal, maybe it should mention that the build did not pass the setup.
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
