[petsc-dev] Bug introduced in MatGetSubmatrices()
Hong hzhang at mcs.anl.gov
Fri Jan 20 10:49:22 CST 2017
Matt,
By default, the flag C->submat_singleis = false.
In PCSetUp_ASM(), we set it as 'true' to
use MatGetSubMatrices_MPIAIJ_SingleIS().
Can you check the value of this flag in your case?
Hong
> It comes from here:
>>   https://bitbucket.org/petsc/petsc/commits/c10200c1442b553b
>> 7ad65c70101560db4fa22e78
>> If we ask for more than 1 matrix, it dispatches to
>> but then fails here
>>   https://bitbucket.org/petsc/petsc/annotate/2e559809f9aee9c
>> 95ee79eb0939630cfe5502c8d/src/mat/impls/aij/mpi/mpiov.c?at=
>> master&fileviewer=file-view-default#mpiov.c-1306
>> because ismax > 1. I think the ismax check needs to move up to here
>> master&fileviewer=file-view-default#mpiov.c-2012
>> but I don't know for sure. Please fix this since it is breaking PyLith.
>>   Matt
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170120/6755b934/attachment.html>
