[petsc-dev] Introducing new "test harness" to PETSc
Wed Jan 18 14:47:46 CST 2017
wPETSC_DIR is one of the petscconf variables.
Perhaps we should start a branch origin/scott/testharness-update2 or
something to push all new changes..
[and change wPETSC_DIR to W_PETSC_DIR everywhere? There is still some
inconsistancy wrt lowercase/uppercase in these 2 scripts]
Satish
diff --git a/config/example_template.py b/config/example_template.py
index 6296f46..2f9050e 100755
--- a/config/example_template.py
+++ b/config/example_template.py
@@ -9,6 +9,7 @@ exec=@EXEC@
 testname='@TESTNAME@'
 label=@LABEL@
 runfiles=@LOCALRUNFILES@
+wPETSC_DIR=@WPETSC_DIR@
 petsc_dir=@PETSC_DIR@
 . ${petsc_dir}/config/petsc_harness.sh
diff --git a/config/gmakegentest.py b/config/gmakegentest.py
index 79894e7..fe449a8 100755
--- a/config/gmakegentest.py
+++ b/config/gmakegentest.py
@@ -244,6 +244,7 @@ class generateExamples(Petsc):
     subst['rm']=self.conf['RM']
     subst['grep']=self.conf['GREP']
     subst['petsc_lib_dir']=self.conf['PETSC_LIB_DIR']
+    subst['wpetsc_dir']=self.conf['wPETSC_DIR']
     return subst
On Wed, 18 Jan 2017, Scott Kruger wrote:
> In the current version of the new test system, there is support for 'requires:
> DATAFILESPATH' which then keys off what is configured,
> similar to any other requirement on how PETSc is configured.
> How would I get wPETSC_DIR?
> Scott
> On 1/18/17 8:09 AM, Satish Balay wrote:
> > On Tue, 17 Jan 2017, Barry Smith wrote:
> > > In this case the data files is in the PETSc share directory so you should
> > > use the ${PETSC_DIR} to point to it. Only files in the DATAFILESPATH
> > > directory should use $DATAFILESPATH
> > Hm - we use wPETSC_DIR so that the path is  valid for windows binaries
> > aswell. Perhaps
> > the test harness will need a fix for this..
> > $ git grep wPETSC_DIR |grep makefile |head -3
> > src/ksp/ksp/examples/tutorials/makefile:	-@${MPIEXEC} -n 2 ./ex10 -f0
> > ${wPETSC_DIR}/share/petsc/datafiles/matrices/spd-real-int${PETSC_INDEX_SIZE}-float${PETSC_SCALAR_SIZE}
> > > ex10_1.tmp 2>&1; \
> > -pc_type asm -pc_asm_sub_mat_type aijviennacl -f0
> > > ex10_asm_viennacl.tmp 2>&1; \
> > src/ksp/ksp/examples/tutorials/makefile:	-@${MPIEXEC} -n 1 ./ex63
> > --filedir=${wPETSC_DIR}/share/petsc/datafiles/matrices/
> > --filename=amesos2_test_mat0.mtx --solver=SuperLU --print-residual=true
> > -ksp_monitor -pc_type lu -pc_factor_mat_solver_package superlu -ksp_view
> > -ksp_converged_reason  > ex63_1.tmp 2>&1;	  \
> > Satish
