[petsc-dev] Curse CMake to the Depths of Hell
Satish Balay
balay at mcs.anl.gov
Wed Jan 18 14:18:02 CST 2017
On Wed, 18 Jan 2017, Matthew Knepley wrote:
> On Wed, Jan 18, 2017 at 10:42 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > Yep, I am fixing that too.
> Okay, I fixed the -lrt and commit, but the stuff to fix the shared link did
> not work.
> I pushed knepley/fix-configure-pragmatic. Could you look at it?
Looking at superlu (instead of superlu_dist) - and discarding the
previous change - the following appears to work.
Satish
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 4b42eb9..9d63ab4 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -128,8 +128,9 @@ if (NOT ENABLE_LIBMESHB OR NOT LIBMESHB_FOUND)
message(STATUS "Configured without libMeshb support.")
endif()
+# Make sure libpragmatic.dylib works properly from the prefix location
+set(CMAKE_INSTALL_RPATH_USE_LINK_PATH TRUE)
+set(CMAKE_INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}/lib")
# ADD_EXECUTABLE( ${PROJECT_NAME} main.cpp )
# TARGET_LINK_LIBRARIES( ${PROJECT_NAME} ${PRAgMaTIc_LIBS} )
