[petsc-dev] Introducing new "test harness" to PETSc
Wed Jan 18 13:56:45 CST 2017
On Wed, Jan 18, 2017 at 1:54 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jan 18, 2017, at 1:46 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Jan 17, 2017 at 8:25 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Tue, Jan 17, 2017 at 8:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Jan 17, 2017, at 8:13 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Tue, Jan 17, 2017 at 7:59 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > Use ${DATAFILESPATH} like we do in all the legacy tests.
> > > Not working
> >   Why do you even listen to Jed, when you can listen to me. In this case
> the data files is in the PETSc share directory so you should use the
> ${PETSC_DIR} to point to it. Only files in the DATAFILESPATH directory
> should use $DATAFILESPATH
> > Okay, that worked. I have one test converted.
> > Gripes:
> > From the answers to these, it sounds like I will end up writing a piece
> of Python around this that
> > does largely what my existing Python script does. I wanted to avoid this.
>    What exactly would this "piece of Python around this" consist of? The
> intention is that default test harness has what you need so anything you
> think you need to put into a ""piece of Python around this" should be part
> of the test harness.
Right now, I am running stuff through 'make'. The % matching does not work,
but searchin does. Moreover, in order to replace
output, I need to type DIFF=<crazy script>, so I would just do that by
using Python with a short option, dumping that script,
calling it, and then deleting. Also, I want to be able to toss in
arguments, since this makes it much simpler to debug tests. It
seems I will need a wrapper to the make.
  Matt
>    Barry
> >   Matt
> >   1) How do I run an individual test run?
> > I use
> >   make -f gmakefile test searchin=plex
> > to run plex tests, and I think
> >   make -f gmakefile test searchin=plex*ex1
> > will work. However, how do I select ex1_2?
> >   2) How do I replace the output which exists with the output of the
> current test run?
> > This is amazingly useful after changes.
> >   3) How do I give extra arguments with the make interface, rather than
> test_harness?
> > Once I have all the functionality of my Python stuff,  I will throw it
> away.
> >   Thanks,
> >      Matt
> > > arch-c-exodus-master/tests/src/dm/impls/plex/examples/tests/runex1_gmsh_3.sh
> -v
> > > not ok dm_impls_plex_tests-ex1_gmsh_3 /PETSc3/petsc/petsc-dev/arch-c-exodus-master/bin/mpiexec
> -n 3 ../ex1 -filename /meshes/square.msh -interpolate 1 -dm_view >
> ex1_gmsh_3.tmp 2> runex1_gmsh_3.err
> > > when I have
> > >   test:
> > >     suffix: gmsh_3
> > >     nsize: 3
> > >     args: -filename ${DATAFILESPATH}/meshes/square.msh -interpolate 1
> -dm_view
> > >    Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/d7adab5a/attachment.html>
