[petsc-dev] Introducing new "test harness" to PETSc
Matthew Knepley
knepley at gmail.com
Wed Jan 18 13:46:09 CST 2017
On Tue, Jan 17, 2017 at 8:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 17, 2017 at 8:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > On Jan 17, 2017, at 8:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Tue, Jan 17, 2017 at 7:59 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > Use ${DATAFILESPATH} like we do in all the legacy tests.
>> > Not working
>> Why do you even listen to Jed, when you can listen to me. In this case
>> the data files is in the PETSc share directory so you should use the
>> ${PETSC_DIR} to point to it. Only files in the DATAFILESPATH directory
>> should use $DATAFILESPATH
> Okay, that worked. I have one test converted.
> Gripes:
>From the answers to these, it sounds like I will end up writing a piece of
Python around this that
does largely what my existing Python script does. I wanted to avoid this.
Matt
> 1) How do I run an individual test run?
> I use
> make -f gmakefile test searchin=plex
> to run plex tests, and I think
> make -f gmakefile test searchin=plex*ex1
> will work. However, how do I select ex1_2?
> 2) How do I replace the output which exists with the output of the
> current test run?
> This is amazingly useful after changes.
> 3) How do I give extra arguments with the make interface, rather than
> test_harness?
> Once I have all the functionality of my Python stuff, I will throw it
> away.
> Thanks,
> Matt
>> > arch-c-exodus-master/tests/src/dm/impls/plex/examples/tests/runex1_gmsh_3.sh
>> -v
>> > not ok dm_impls_plex_tests-ex1_gmsh_3 /PETSc3/petsc/petsc-dev/arch-c-exodus-master/bin/mpiexec
>> -n 3 ../ex1 -filename /meshes/square.msh -interpolate 1 -dm_view >
>> ex1_gmsh_3.tmp 2> runex1_gmsh_3.err
>> > when I have
>> > test:
>> > suffix: gmsh_3
>> > nsize: 3
>> > args: -filename ${DATAFILESPATH}/meshes/square.msh -interpolate 1
>> -dm_view
>> > Matt
>> > What most experimenters take for granted before they begin their
>> experiments lead.
>> > -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/832e8a80/attachment.html>
