[petsc-dev] Curse CMake to the Depths of Hell
    Matthew Knepley
    knepley at gmail.com
    Wed Jan 18 10:42:33 CST 2017
Yep, I am fixing that too.
   Matt
On Wed, Jan 18, 2017 at 10:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mac - with prgmatic 'master' - I get:
> /usr/local/Cellar/cmake/3.7.1/bin/cmake -E cmake_link_script
> CMakeFiles/jpeg2mesh.dir/link.txt --verbose=1
> /usr/bin/g++   -fstack-protector -g -std=c++11 -Wno-literal-suffix
> -Wno-deprecated -DEIGEN_NO_DEBUG -Wl,-search_paths_first
> -Wl,-headerpad_max_install_names  CMakeFiles/jpeg2mesh.dir/tools/jpeg2mesh.cpp.o
> CMakeFiles/jpeg2mesh.dir/src/mpi_tools.cpp.o CMakeFiles/jpeg2mesh.dir/src/ticker.cpp.o
> -o bin/jpeg2mesh  -lrt
> [ 92%] Linking CXX executable bin/coarsen_mesh_3d
> CMakeFiles/coarsen_mesh_3d.dir/link.txt --verbose=1
> -Wl,-headerpad_max_install_names  CMakeFiles/coarsen_mesh_3d.
> dir/tools/coarsen_mesh_3d.cpp.o CMakeFiles/coarsen_mesh_3d.
> dir/src/generate_Steiner_ellipse_3d.cpp.o CMakeFiles/coarsen_mesh_3d.dir/src/mpi_tools.cpp.o
> CMakeFiles/coarsen_mesh_3d.dir/src/ticker.cpp.o  -o bin/coarsen_mesh_3d
> -lrt
> [100%] Linking CXX shared library lib/libpragmatic.dylib
> <snip>
> ld: library not found for -lrt
> clang: error: linker command failed with exit code 1 (use -v to see
> invocation)
> Satish
> On Wed, 18 Jan 2017, Matthew Knepley wrote:
> > Yep, I am updating that (since it pointed to a branch that got munged),
> and
> > in doing so I wanted o fix this aswell.
> >    Matt
> > On Wed, Jan 18, 2017 at 10:32 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > BTW: wrong self.gitcommit in pragmatic.py?
> > > Satish
> > > balay at asterix /home/balay/petsc (master=)
> > > $ ./configure --with-mpi=0  --download-metis --download-eigen
> > > --download-pragmatic PETSC_ARCH=arch-pragmatic
> > >              Configuring PETSc to compile on your system
> > >                  Trying to download hg://https://bitbucket.org/
> > > eigen/eigen/ for EIGEN
> > >                  Configuring EIGEN with cmake, this may take several
> > > minutes
> > >                  Compiling and installing EIGEN; this may take several
> > > minutes
> > >                  Trying to download git://https://bitbucket.org/
> > > petsc/pkg-metis.git for METIS
> > >                  Configuring METIS with cmake, this may take several
> > > minutes
> > >                  Compiling and installing METIS; this may take several
> > > minutes
> > >                  Trying to download git://https://github.com/
> > > meshadaptation/pragmatic.git for PRAGMATIC
> > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for
> > > details):
> > > Unable to checkout commit: 2efa91b32a3b9954083ddf96f2ee81889906543c in
> > > repository: /home/balay/petsc/arch-pragmatic/externalpackages/
> > > git.pragmatic.
> > > Perhaps its a git error!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/a8039f78/attachment.html>
