[petsc-dev] Curse CMake to the Depths of Hell
    Matthew Knepley
    knepley at gmail.com
    Wed Jan 18 09:55:43 CST 2017
I want to use Pragmatic, and it seems that the CMakeLists.txt is
constructed correctly, but the dynamic library has no path in it, so after
the link, I still need DYLD_LIBRARY_PATH. For some reason, the CMake
install is screwing up.
Jed, do you know how to fix this? If not, I will just explicitly set this
in our code.
   Matt
master *$:/PETSc3/petsc/petsc-dev/src/dm/impls/plex/examples/tests$ otool
-L
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/externalpackages/git.pragmatic/build/lib/libpragmatic.dylib
otool -L
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/externalpackages/git.pragmatic/build/lib/libpragmatic.dylib:
(compatibility version 0.0.0, current version 0.0.0)
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libmetis.dylib
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libmpichcxx.10.dylib
(compatibility version 11.0.0, current version 11.4.0)
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libpmpich.10.dylib
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libmpich.10.dylib
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libopa.1.dylib
(compatibility version 2.0.0, current version 2.0.0)
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libmpl.1.dylib
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version
1197.1.1)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version
120.0.0)
-L /PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libpragmatic.dylib
otool -L /PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libpragmatic.dylib
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/lib/libpragmatic.dylib:
libpragmatic.dylib (compatibility version 0.0.0, current version 0.0.0)
1197.1.1)
120.0.0)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170118/7973b772/attachment.html>
