[petsc-dev] Introducing new "test harness" to PETSc
Matthew Knepley
knepley at gmail.com
Tue Jan 17 20:25:14 CST 2017
On Tue, Jan 17, 2017 at 8:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jan 17, 2017, at 8:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Jan 17, 2017 at 7:59 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Use ${DATAFILESPATH} like we do in all the legacy tests.
> > Not working
> Why do you even listen to Jed, when you can listen to me. In this case
> the data files is in the PETSc share directory so you should use the
> ${PETSC_DIR} to point to it. Only files in the DATAFILESPATH directory
> should use $DATAFILESPATH
Okay, that worked. I have one test converted.
Gripes:
1) How do I run an individual test run?
I use
make -f gmakefile test searchin=plex
to run plex tests, and I think
make -f gmakefile test searchin=plex*ex1
will work. However, how do I select ex1_2?
2) How do I replace the output which exists with the output of the
current test run?
This is amazingly useful after changes.
3) How do I give extra arguments with the make interface, rather than
test_harness?
Once I have all the functionality of my Python stuff, I will throw it away.
Matt
> > arch-c-exodus-master/tests/src/dm/impls/plex/examples/tests/runex1_gmsh_3.sh
> -v
> > not ok dm_impls_plex_tests-ex1_gmsh_3 /PETSc3/petsc/petsc-dev/arch-c-exodus-master/bin/mpiexec
> -n 3 ../ex1 -filename /meshes/square.msh -interpolate 1 -dm_view >
> ex1_gmsh_3.tmp 2> runex1_gmsh_3.err
> > when I have
> > test:
> > suffix: gmsh_3
> > nsize: 3
> > args: -filename ${DATAFILESPATH}/meshes/square.msh -interpolate 1
> -dm_view
> > Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170117/e5d01ae3/attachment.html>
