[petsc-dev] Introducing new "test harness" to PETSc
Matthew Knepley
knepley at gmail.com
Tue Jan 17 20:13:17 CST 2017
On Tue, Jan 17, 2017 at 7:59 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > However, none of my localrunfiles are working. I have them defined this
> way
> > test:
> > suffix: cgns_0
> > requires: cgns
> > args: -filename tut21.cgns -interpolate 1 -dm_view
> > localrunfiles: ../../../../../../share/petsc/
> datafiles/meshes/tut21.cgns
> > which works when gmakegentest.py is run, but not when executing the
> script
> > arch-c-exodus-master/tests/src/dm/impls/plex/examples/
> tests/runex1_cgns_0.sh
> > -v
> > cp: ../../../../../../share/petsc/datafiles/meshes/tut21.cgns: No such
> file
> > or directory
> Use ${DATAFILESPATH} like we do in all the legacy tests.
Not working
arch-c-exodus-master/tests/src/dm/impls/plex/examples/tests/runex1_gmsh_3.sh
-v
not ok dm_impls_plex_tests-ex1_gmsh_3
/PETSc3/petsc/petsc-dev/arch-c-exodus-master/bin/mpiexec -n 3 ../ex1
-filename /meshes/square.msh -interpolate 1 -dm_view > ex1_gmsh_3.tmp 2>
runex1_gmsh_3.err
when I have
test:
suffix: gmsh_3
nsize: 3
args: -filename ${DATAFILESPATH}/meshes/square.msh -interpolate 1
-dm_view
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170117/be73bce5/attachment.html>
