[petsc-dev] reading gmsh into DMPlex
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Mon Jan 16 21:15:35 CST 2017
hi Matt
On 17/01/17 15:52, Matthew Knepley wrote:
> Its a DOS file and has no newline at the end. Thus, when I read
> $EndElements, it has no termination and you
> can something weird. I put a newline on that line and its fine.
I don't think it is a DOS file- it was created on a Linux machine, emacs
doesn't identify it as DOS, and I tried running dos2unix on it to make
sure, but that made no difference.
What does make a difference is manually adding a newline on the end.
However, that isn't super convenient when these files are being created
automatically via scripts.
Would it be possible to make DMPlexCreateGmsh() a bit more robust about
the line ending at the end of the file? Gmsh itself isn't bothered by it.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170117/89f84f1b/attachment.html>
