[petsc-dev] Provide access to the block interpolation for HYPRE
Delyan Kalchev
delyank at gmail.com
Thu Jan 12 14:36:28 CST 2017
Hello,
I would like to suggest a small modification in petsc / src / ksp / pc /
impls / hypre / hypre.c
Namely, the lines
static const char *HYPREBoomerAMGInterpType[] = {"classical", "", "",
"direct", "multipass", "multipass-wts", "ext+i",
"ext+i-cc", "standard", "standard-wts", "",
"", "FF", "FF1"};
to be modified to (something like)
"block", "block-wtd", "FF", "FF1"};
This gives access to block interpolation available in HYPRE. It is
beneficial with nodal AMG for systems.
Without this option it seems that only the "coarse mesh" can be
constructed in a nodal fashion but not the interpolation.
A full nodal would need an interpolation between the nodes (which
appear as blocks in the matrix)
Thank you!
Delyan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170112/216086bc/attachment.html>
