[petsc-dev] Fwd: no petsc on Edison
Kong, Fande fande.kong at inl.gov
Tue Jan 10 15:02:18 CST 2017
On Tue, Jan 10, 2017 at 1:47 PM, Mark Adams <mfadams at lbl.gov> wrote:
> We have a code that is failing on large scale runs on Edison at NERSC. We
> ran with a debug version and we got this error message that I assume is
> from a check that is done in debug. Is this a false positive? This is a 64
> bit integer build.
> Thanks,
> Mark
> [5]PETSC ERROR: --------------------- Error Message
> [5]PETSC ERROR: Argument out of range
> [5]PETSC ERROR: A really huge hash is being requested.. cannot process:
> 4294967296
Satish,
The number "4294967296" is larger than the maximum number (2147321881) you
put in the lookup.
I guess your fixes do not help this one.
Fande,
> [5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.mcs.anl.gov_petsc_documentation_faq.html&d=DQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=Jd9TVPRE-Ts5OmoJe38KFIo29VVtsFIoN1ABdechuuE&s=BdTH9phOP3ipZiM21mw_gZrxPjWTeVcpXw9n-y7GECo&e=>
> for trouble shooting.
> [5]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2584-g7175242 GIT
> Date: 2016-12-21 13:19:16 -0600
> [5]PETSC ERROR: /tmp/targetExec on a arch-xc30-dbg64-intel named nid00008
> by u6338 Sat Jan  7 16:39:16 2017
> [5]PETSC ERROR: Configure options --COPTFLAGS="-O0 -g -no-ipo"
> --CXXOPTFLAGS="-O0 -g -no-ipo" --FOPTFLAGS="-O0 -g -ipo"
> --download-parmetis --download-metis --download-hypre --with-ssl=0
> --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC
> --with-cxxlib-autodetect=0 --with-debugging=1 --with-fc=ftn
> --with-fortranlib-autodetect=0 --with-shared-libraries=0 --with-x=0
> --with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices
> --prefix=/global/homes/m/madams/petsc_install/petscv3.7-x[16527]PETSC
> ERROR: ----
> using:
> PETSC_DIR=/global/homes/m/madams/petsc_install/petscv3.7-xc30-dbg64-intel/
> maybe go back to opt version?
> On 12/22/2016 03:22 PM, Mark Adams wrote:
>> You configure with the size of an integer explicitly, ie,
>> --with-64-bit-integers. I can't imagine there is anything bigger, but it
>> would not be hard to do.
>> On Thu, Dec 22, 2016 at 6:06 PM, David Trebotich <treb at hpcrdm.lbl.gov>
>> wrote:
>> i just committed changes to SPMD that Brian needed for signed long long.
>>> Evidently petsc is now handling bigger matrices?
>>> On 12/22/2016 2:57 PM, Mark Adams wrote:
>>> There are a few hits on stack exchange, google:
>>> "error: expression must have class type"
>>> I think intputT is a templated type and it is templated with a PetscInt.
>>> You are calling the linearSize() method on a primitive type. That is my
>>> best guess.
>>> On Thu, Dec 22, 2016 at 3:33 PM, David Trebotich <treb at hpcrd.lbl.gov>
>>> wrote:
>>> building with dbg looks same:
>>>> ../../../Chombo/lib/src/BaseTools/SPMDI.H(23): error: expression must
>>>> have class type
>>>>     return inputT.linearSize();
>>>>           detected during:
>>>>             instantiation of "int linearSize(const T &) [with
>>>> T=PetscInt={PetscInt64={long long}}]" at line 128 of
>>>> "../../../Chombo/lib/src/EBTools/MiniIVFABI.H"
>>>>             instantiation of "int MiniIVFAB<T>::size(const Box &, const
>>>> Interval &) const [with T=PetscInt={PetscInt64={long long}}]" at line
>>>> 155
>>>> of "../../../Chombo/lib/src/EBTools/BaseEBCellFABI.H"
>>>>             instantiation of "int BaseEBCellFAB<T>::size(const Box &,
>>>> const Interval &) const [with T=PetscInt={PetscInt64={long long}}]" at
>>>> line
>>>> 149 of "../../../Chombo/lib/src/BoxTools/BoxLayoutData.H"
>>>>             instantiation of "int LDOperator<T>::size(const T &, const
>>>> Box &, const Interval &) const [with T=BaseEBCellFAB<PetscInt={Pets
>>>> cInt64={long
>>>> long}}>]" at line 114 of "../../../Chombo/lib/src/BoxTools/LevelData.H"
>>>>             implicit generation of "LDOperator<T>::LDOperator() [with
>>>> T=BaseEBCellFAB<PetscInt={PetscInt64={long long}}>]" at line 114 of
>>>>             instantiation of class "LDOperator<T> [with
>>>>             instantiation of "void LevelData<T>::copyTo(const Interval
>>>> BoxLayoutData<T> &, const Interval &, const Copier &, const
>>>> LDOperator<T>
>>>> &) const [with T=BaseEBCellFAB<PetscInt={PetscInt64={long long}}>]" at
>>>> line 213 of "../../../Chombo/lib/src/BoxTools/LevelDataI.H"
>>>> BoxLayoutData<T> &, const Interval &) const [with
>>>> T=BaseEBCellFAB<PetscInt={PetscInt64={long long}}>]" at line 32 of
>>>>             instantiation of "LevelData<T>::LevelData() [with
>>>> T=BaseEBCellFAB<PetscInt={PetscInt64={long long}}>]" at line 41 of
>>>> "../srcLib/EBPetscSolver.cpp"
>>>> ../../../Chombo/lib/src/BaseTools/SPMDI.H(35): error: expression must
>>>> have class type
>>>>     inputT.linearOut(a_outBuf);
>>>>           detected during:
>>>>             instantiation of "void linearOut(void *, const T &) [with
>>>> T=PetscInt={PetscInt64={long long}}]" at line 155 of
>>>>             instantiation of "void MiniIVFAB<T>::linearOut(void *, const
>>>> Box &, const Interval &) const [with T=PetscInt={PetscInt64={long
>>>> long}}]"
>>>> at line 169 of "../../../Chombo/lib/src/EBTools/BaseEBCellFABI.H"
>>>>             instantiation of "void BaseEBCellFAB<T>::linearOut(void *,
>>>> const Box &, const Interval &) const [with T=PetscInt={PetscInt64={long
>>>> long}}]" at line 154 of "../../../Chombo/lib/src/BoxTo
>>>>             instantiation of "void LDOperator<T>::linearOut(const T &,
>>>> void *, const Box &, const Interval &) const [with
>>>> LDOperator<T>
>>>> ../../../Chombo/lib/src/BaseTools/SPMDI.H(29): error: expression must
>>>> have class type
>>>>     a_outputT.linearIn(inBuf);
>>>>           detected during:
>>>>             instantiation of "void linearIn(T &, const void *) [with
>>>> T=PetscInt={PetscInt64={long long}}]" at line 181 of
>>>>             instantiation of "void MiniIVFAB<T>::linearIn(void *, const
>>>> Box &, const Interval &) [with T=PetscInt={PetscInt64={long long}}]" at
>>>> line 181 of "../../../Chombo/lib/src/EBTools/BaseEBCellFABI.H"
>>>>             instantiation of "void BaseEBCellFAB<T>::linearIn(void *,
>>>> const Box &, const Interval &) [with T=PetscInt={PetscInt64={long
>>>> long}}]"
>>>> at line 159 of "../../../Chombo/lib/src/BoxTools/BoxLayoutData.H"
>>>>             instantiation of "void LDOperator<T>::linearIn(T &, void *,
>>>> LDOperator<T>
>>>> compilation aborted for ../srcLib/EBPetscSolver.cpp (code 2)
>>>> gmake[1]: *** [o/3d.Linux.64.CC.ftn.DEBUG.MP
>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__3d.Linux.64.CC.ftn.DEBUG.MP&d=DQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=Jd9TVPRE-Ts5OmoJe38KFIo29VVtsFIoN1ABdechuuE&s=HAhvWGeoB7HMK7Clyrfh_x-R465qxP-CNXK4zqhrCuE&e=>
>>>> I.PETSC/EBPetscSolver.o]
>>>> Error 2
>>>> On 12/22/2016 09:42 AM, Mark Adams wrote:
>>>> I have build a debug version (opt64 --> dbg64). You might try that.
>>>>> On Wed, Dec 21, 2016 at 9:46 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> On Wed, Dec 21, 2016 at 2:25 PM, David Trebotich <treb at hpcrd.lbl.gov>
>>>>>> wrote:
>>>>>> This wasn't happening until after you rebuilt petsc.  So I am
>>>>>> wondering
>>>>>>> if you upgraded or changed something??
>>>>>> Humm, let me rebuild. This is on Edison I assume.
>>>>>> Try PETSC_DIR=/global/homes/m/madams/petsc_install/petscv3.7-xc3
>>>>>> 0-opt64-intel
>>>>>> (again)
>>>>>> This is a new build. I would also do a deep clean on your end, of
>>>>>> course.
>>>>>> I see a DCH_USE_COMPLEX ...
>>>>>> Also, I would try a debug build just to get some data. This is some
>>>>>> strange problem of something is out of synch.
>>>>>> On 12/19/2016 05:05 PM, Mark Adams wrote:
>>>>>>> On Mon, Dec 19, 2016 at 6:35 PM, David Trebotich <treb at hpcrd.lbl.gov
>>>>>>>> wrote:
>>>>>>>> I am sorry, you mean I need to add that to environment variables?
>>>>>>>> The PETSC_ARCH is hardwired for the size of integers so you would
>>>>>>>> use
>>>>>>>> PETSC_ARCH=arch-xc30-opt-intel to get 32 bit ints (I don't know of
>>>>>>>> this
>>>>>>>> installation ever being used). But now that I think about it you
>>>>>>>> always
>>>>>>>> use
>>>>>>>> 64 bit ints and you need to.
>>>>>>>> So what is going on here ... it looks like an object has been
>>>>>>>> templated
>>>>>>>> on
>>>>>>>> a PetscInt and is getting mixed up. I don't think you ever use 32
>>>>>>>> bit
>>>>>>>> ints
>>>>>>>> in PETSc so it looks like you regressed here... I don't have a lot
>>>>>>>> of
>>>>>>>> experience with templates. I'd ask Brian or Dan.
>>>>>>>> On 12/19/2016 03:34 PM, Mark Adams wrote:
>>>>>>>>> There is a: arch-xc30-opt-intel
>>>>>>>>>> On Mon, Dec 19, 2016 at 6:25 PM, David Trebotich <
>>>>>>>>>> wrote:
>>>>>>>>>> Hey Mark-
>>>>>>>>>> We have had this issue recently and am wondering if you know what
>>>>>>>>>>> the
>>>>>>>>>>> problem is.  Maybe an int vs. PetscInt vs. PetscInt64 kind of
>>>>>>>>>>> thing?
>>>>>>>>>>> CC  -O2 -fast -no-ipo -std=c++11 -O3 -m64
>>>>>>>>>>> -qopt-multi-version-aggressive
>>>>>>>>>>> -restrict -m64 -std=c++11 -Wno-unknown-pragmas -diag-disable 3180
>>>>>>>>>>> -DCH_SPACEDIM=3 -DCH_Linux   -DNDEBUG  -DCH_MPI
>>>>>>>>>>> -DMPICH_SKIP_MPICXX
>>>>>>>>>>> -ULAM_WANT_MPI2CPP -DMPI_NO_CPPBIND     -DCH_USE_COMPLEX
>>>>>>>>>>>  -DCH_USE_EB
>>>>>>>>>>> -DCH_USE_MEMORY_TRACKING  -DCH_USE_64 -DCH_USE_DOUBLE
>>>>>>>>>>> -DCH_USE_HDF5
>>>>>>>>>>> -I/opt/cray/hdf5-parallel/1.8.16/INTEL/15.0/include    -I.
>>>>>>>>>>> -I../srcBCG
>>>>>>>>>>> -I../srcLib -I../srcAdvectDiffuseCrunch_BCG
>>>>>>>>>>> -I../srcCrunchFlow_BCG
>>>>>>>>>>> -I../srcCrunchFlow_BCG/modules    -DCH_USE_PETSC
>>>>>>>>>>> -I/global/homes/m/madams/petsc_install/petscv3.6-xc30-opt64-
>>>>>>>>>>> intel/include
>>>>>>>>>>> intel/include
>>>>>>>>>>> intel/include
>>>>>>>>>>> -DCH_FORT_UNDERSCORE -I../../../Chombo/lib/src/EBAM
>>>>>>>>>>> RTimeDependent
>>>>>>>>>>> -I../../../Chombo/lib/src/EBAMRElliptic
>>>>>>>>>>> RTools
>>>>>>>>>>> -I../../../Chombo/lib/src/Workshop
>>>>>>>>>>> -I../../../Chombo/lib/src/EBTo
>>>>>>>>>>> ols
>>>>>>>>>>> -I../../../Chombo/lib/src/AMRTimeDependent
>>>>>>>>>>> -I../../../Chombo/lib/src/AMRElliptic
>>>>>>>>>>> -I../../../Chombo/lib/src/AMRTools
>>>>>>>>>>> -I../../../Chombo/lib/src/BoxT
>>>>>>>>>>> ools
>>>>>>>>>>> -I../../../Chombo/lib/src/BaseTools  -DCH_LANG_CC -c
>>>>>>>>>>> ../srcLib/EBPetscSolver.cpp -o o/3d.Linux.64.CC.ftn.OPTHIGH.M
>>>>>>>>>>> PI.PETSC/EBPetscSolver.o
>>>>>>>>>>> must
>>>>>>>>>>> have class type
>>>>>>>>>>>           detected during:
>>>>>>>>>>> const
>>>>>>>>>>> line
>>>>>>>>>>> 155
>>>>>>>>>>> Box
>>>>>>>>>>> long}}]" at
>>>>>>>>>>> line
>>>>>>>>>>> const
>>>>>>>>>>> Box
>>>>>>>>>>> cInt64={long
>>>>>>>>>>> ols/LevelData.H"
>>>>>>>>>>> [with
>>>>>>>>>>> of
>>>>>>>>>>> of
>>>>>>>>>>> Interval &,
>>>>>>>>>>> LDOperator<T>
>>>>>>>>>>> long}}>]"
>>>>>>>>>>> at
>>>>>>>>>>> Interval &,
>>>>>>>>>>> of
>>>>>>>>>>> of
>>>>>>>>>>> must
>>>>>>>>>>> have class type
>>>>>>>>>>>           detected during:
>>>>>>>>>>> [with
>>>>>>>>>>> const
>>>>>>>>>>> long}}]"
>>>>>>>>>>> id
>>>>>>>>>>> T &,
>>>>>>>>>>> of
>>>>>>>>>>> [with
>>>>>>>>>>> of
>>>>>>>>>>> of
>>>>>>>>>>> Interval &,
>>>>>>>>>>> LDOperator<T>
>>>>>>>>>>> long}}>]"
>>>>>>>>>>> at
>>>>>>>>>>> Interval &,
>>>>>>>>>>> of
>>>>>>>>>>> of
>>>>>>>>>>> must
>>>>>>>>>>> have class type
>>>>>>>>>>>           detected during:
>>>>>>>>>>> [with
>>>>>>>>>>> const
>>>>>>>>>>> long}}]"
>>>>>>>>>>> at
>>>>>>>>>>> d
>>>>>>>>>>> long}}]"
>>>>>>>>>>> void
>>>>>>>>>>> cInt64={long
>>>>>>>>>>> ols/LevelData.H"
>>>>>>>>>>> [with
>>>>>>>>>>> of
>>>>>>>>>>> of
>>>>>>>>>>> Interval &,
>>>>>>>>>>> LDOperator<T>
>>>>>>>>>>> long}}>]"
>>>>>>>>>>> at
>>>>>>>>>>> Interval &,
>>>>>>>>>>> of
>>>>>>>>>>> of
>>>>>>>>>>> gmake[1]: *** [o/3d.Linux.64.CC.ftn.OPTHIGH.
>>>>>>>>>>> MPI.PETSC/EBPetscSolver.o]
>>>>>>>>>>> Error 2
>>>>>>>>>>> make: *** [all-example] Error 2
>>>>>>>>>>> On 12/19/2016 03:09 PM, Mark Adams wrote:
>>>>>>>>>>> Sorry cleaning up. insert "petsc_install" in the path:
>>>>>>>>>>> "...madams/
>>>>>>>>>>> petsc_install/petscv3.6..."
>>>>>>>>>>>> On Mon, Dec 19, 2016 at 5:43 PM, David Trebotich <
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>> Hey Mark-
>>>>>>>>>>>> I seem to have lost contact with petsc over the weekend:
>>>>>>>>>>>>> /global/homes/m/madams/petscv3.6-xc30-opt64-intel//lib/
>>>>>>>>>>>>> petsc/conf/variables:
>>>>>>>>>>>>> No such file or directory
>>>>>>>>>>>>> Last chance .ex rule for target /global/homes/m/madams/petscv3
>>>>>>>>>>>>> .6-xc30-opt64-intel//lib/petsc/conf/variables
>>>>>>>>>>>>> setenv | grep petsc:
>>>>>>>>>>>>> PE_PETSC_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/petsc/3.
>>>>>>>>>>>>> 7.2.0/real/@PRGENV@/@PE_PETSC_DEFAULT_GENCOMPS@/@PE_PETSC_
>>>>>>>>>>>>> DEFAULT_TARGET@/lib/pkgconfig
>>>>>>>>>>>>> PETSC_DIR=/global/homes/m/madams/petscv3.6-xc30-opt64-intel/
>>>>>>>>>>>>> Currently Loaded Modulefiles:
>>>>>>>>>>>>>   1) modules/3.2.10.4
>>>>>>>>>>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__3.2.10.4&d=DQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=Jd9TVPRE-Ts5OmoJe38KFIo29VVtsFIoN1ABdechuuE&s=UN73DjcLzn6LGQKK_kwoLCLWgyM5YEeKwwHYYCHe1nw&e=>
>>>>>>>>>>>>>                      8) intel/15.0.1.133
>>>>>>>>>>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__15.0.1.133&d=DQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=Jd9TVPRE-Ts5OmoJe38KFIo29VVtsFIoN1ABdechuuE&s=Gix6rgPxH5UFQeKmDN6zAXMAmFezfJ1qY-723XuYrUE&e=>
>>>>>>>>>>>>>     15) xpmem/0.1-2.0502.57015.1.15.ar
>>>>>>>>>>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__0.1-2D2.0502.57015.1.15.ar&d=DQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=Jd9TVPRE-Ts5OmoJe38KFIo29VVtsFIoN1ABdechuuE&s=DcDHbf2qyi7t-rquIoqAdDx5HPEa3BXjxxWGpgLVhBU&e=>i
>>>>>>>>>>>>>      22)
>>>>>>>>>>>>> cray-mpich/7.4.1
>>>>>>>>>>>>>   2) nsg/1.2.0                              9)
>>>>>>>>>>>>> cray-libsci/16.07.1
>>>>>>>>>>>>>       16) dvs/2.5_0.9.0-1.0502.1958.2.55.ari    23)
>>>>>>>>>>>>> slurm/edison
>>>>>>>>>>>>>   3) eswrap/1.3.3-1.020200.1278.0          10)
>>>>>>>>>>>>> udreg/2.3.2-1.0502.9889.2.20.ari      17)
>>>>>>>>>>>>> alps/5.2.3-2.0502.9295.14.14.a
>>>>>>>>>>>>> ri
>>>>>>>>>>>>>     24) altd/2.0
>>>>>>>>>>>>>   4) switch/1.0-1.0502.57058.1.58.ari      11)
>>>>>>>>>>>>> ugni/6.0-1.0502.10245.9.9.ari         18) rca/
>>>>>>>>>>>>> 1.0.0-2.0502.57212.2.56.ar
>>>>>>>>>>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__1.0.0-2D2.0502.57212.2.56.ar&d=DQMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=Jd9TVPRE-Ts5OmoJe38KFIo29VVtsFIoN1ABdechuuE&s=KaOFCQYgi4MV721r1zVhLb666-2L2dmTfExdbRrrB1s&e=>
>>>>>>>>>>>>> i
>>>>>>>>>>>>>      25) darshan/2.3.1
>>>>>>>>>>>>>   5) craype-ivybridge                      12) pmi/
>>>>>>>>>>>>> 5.0.10-1.0000.11050.0.0.ari       19) atp/2.0.2        26)
>>>>>>>>>>>>> emacs/24.2
>>>>>>>>>>>>>   6) craype-network-aries                  13)
>>>>>>>>>>>>> dmapp/7.0.1-1.0502.10246.8.47.ari     20) PrgEnv-intel/5.2.56
>>>>>>>>>>>>> 27)
>>>>>>>>>>>>> cray-hdf5-parallel/1.8.16
>>>>>>>>>>>>>   7) craype/2.4.2                          14)
>>>>>>>>>>>>> gni-headers/4.0-1.0502.10317.9.2.ari  21) cray-shmem/7.4.1
>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>> treb
>>>>>>>>>>>>> David Trebotich
>>>>>>>>>>>>> Applied Numerical Algorithms Group
>>>>>>>>>>>>> Lawrence Berkeley National Laboratory
>>>>>>>>>>>>> (510) 486-5984 <%28510%29%20486-5984> office
>>>>>>>>>>>>> (510) 384-6868 <%28510%29%20384-6868> mobile
>>>>>>>>>>>> David Trebotich
>>>>>>>>>> David Trebotich
>>>>>>> David Trebotich
>>>> David Trebotich
>>>> (510) 486-5984 office
>>>> (510) 384-6868 mobile
>>> David Trebotich
>>> Computational Research Division
>>> Lawrence Berkeley National Laboratory(510) 486-5984 office(510) 384-6868
>>> mobile
> David Trebotich
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170110/06cad2ed/attachment.html>
