[petsc-dev] YAML options support in PETSc issue
Jed Brown jed at jedbrown.org
Tue Jan 10 01:44:35 CST 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Is this suppose to work?  What should be done with the example?
This file has lists/sequences and references.  Neither are implemented.
I don't know what it means to convert a YAML list into PETSc options.
(Nested dicts are defined, but not lists.)  References would be a nice
feature to support, but that isn't even stubbed out yet.  Seems to me we
can disable the example (it wasn't tested prior to the new testing
system).
> #	[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> #	[0]PETSC ERROR: No support for this operation for this object type
> #	[0]PETSC ERROR: Unable to open YAML option file: sequences not supported
> #	[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> #	[0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2087-g869b4d0136  GIT Date: 2017-01-09 12:37:55 -0600
> #	[0]PETSC ERROR: ../ex23 on a arch-mpich named visitor096-130.wl.anl-external.org by barrysmith Mon Jan  9 15:51:52 2017
> #	[0]PETSC ERROR: Configure options --download-metis --download-mpich --download-parmetis --download-superlu_dist PETSC_ARCH=arch-mpich --download-saws --download-yaml
> #	[0]PETSC ERROR: #1 PetscParseLayerYAML() line 37 in /Users/barrysmith/Src/petsc/src/sys/yaml/yamlimpls.c
> #	[0]PETSC ERROR: #2 PetscParseLayerYAML() line 50 in /Users/barrysmith/Src/petsc/src/sys/yaml/yamlimpls.c
> #	[0]PETSC ERROR: #3 PetscOptionsInsertFileYAML() line 136 in /Users/barrysmith/Src/petsc/src/sys/yaml/yamlimpls.c
> #	[0]PETSC ERROR: #4 PetscOptionsInsert() line 771 in /Users/barrysmith/Src/petsc/src/sys/objects/options.c
> #	[0]PETSC ERROR: #5 PetscInitialize() line 875 in /Users/barrysmith/Src/petsc/src/sys/objects/pinit.c
> #	[0]PETSC ERROR: #6 main() line 15 in /Users/barrysmith/Src/petsc/src/sys/examples/tests/ex23.c
> #	[0]PETSC ERROR: PETSc Option Table entries:
> #	[0]PETSC ERROR: -malloc_test
> #	[0]PETSC ERROR: -options_file_yaml ex23options
> #	[0]PETSC ERROR: -saws_port_auto_select
> #	[0]PETSC ERROR: -saws_port_auto_select_silent
> #	[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> #	application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> not ok diff-sys_tests-ex23
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170110/63effd3a/attachment.sig>
