[petsc-dev] Unable to access to MatSeqSBAIJGetArray_SeqSBAIJ from "outside" PETSc
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Fri Jan 6 15:18:29 CST 2017
Thanks!!! :)
Eric
On 06/01/17 04:14 PM, Barry Smith wrote:
> Run ./configure with the additional option --with-visibility=0
> We'll add a MatSeqSBAIJGetArray()
> Barry
>> On Jan 6, 2017, at 2:46 PM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
>> Hi,
>> we are trying to add a "petsc" developpement into our code but we need to call MatSeqSBAIJGetArray_SeqSBAIJ for it.
>> Unlike MatSeqAIJGetArray_SeqAIJ which is accessible with either
>> MatSeqAIJGetArray
>> or
>> ierr = PetscUseMethod(A,"MatSeqAIJGetArray_C",(Mat,PetscScalar**),(A,array));CHKERRQ(ierr);
>> there is no MatSeqSBAIJGetArray and we can't call it with
>> ierr = PetscUseMethod(A,"MatSeqSBAIJGetArray_C",(Mat,PetscScalar**),(A,array));CHKERRQ(ierr);
>> since it isn't registered in MatCreate_SeqSBAIJ.
>> is it normal?
>> We can call MatSeqSBAIJGetArray_SeqSBAIJ directly, but the linker complains about unresolved symbol because it is not exported global but only local in our shared library:
>> nm /opt/petsc-3.7.2_debug_matmatmult_mpi/lib/libpetsc.so |grep MatSeqSBAIJGetArray
>> 00000000007f7b74 t MatSeqSBAIJGetArray_SeqSBAIJ
>> Is there any (nasty) way to override the shared library global/local symbols attribute?
>> Thanks,
>> Eric
