[petsc-dev] [petsc-users] Multigrid with defect correction
Dave May dave.mayhem23 at gmail.com
Tue Feb 28 11:16:44 CST 2017
>    PCMG can actually do this for you if you tell it to use Galerkin so you
> shouldn't need to do this (with both the "standard" PCMG interface and its
> use of DM).
Sure. I realize if there is a DM on the fine grid, and the DM has the
method DMCoarsen(), then galerkin operators can/will be constructed by PCMG
if the galerkin flag is set. However, my understanding is that PCMG will
create Galerkin operators for on ALL levels (except the finest).
I wanted to have control over exactly which levels in the hierarchy defined
Galerkin operators. I also wanted more control over how the mesh hierarchy
was constructed than DMCoarsen() provided, so i found it more convenient to
build the mesh hierarchy myself.
Cheers
  Dave
>    Barry
> > >> I would ask, why just two discretizations?  I've always thought a
> better
> > >> interface would be for Mats (and any other operators/functions) to
> have
> > >> optional approximations or supplementary data attached.  We can do
> this
> > >> with PetscObjectCompose, but that's hard to work with in a structured
> > >> way.  Anyway, I think I would rather just have the Amat with ability
> to
> > >> attach one or more Pmats.
> > >   Understood. I don't like the API as "attach one or more Pmats to a
> > >   Mat" but instead prefer to think of it as a linear operator that has
> > >   one or more "levels of approximation"
> > Should they be "levels" (numbered?) or named approximations?
> > >   that can optionally be indicated; which one you wish to use is up to
> > >   the algorithm using the linear operator. Changing this in PETSc
> > >   would require some conceptional changes and refactoring in
> > >   PETSc. Would simplify things like SNESSetJacobian() because we would
> > >   not need to track mat and pmat. But would not be terribly difficult
> > >   for the PETSc developers or user.
> > >   If we used this model, instead of adding a new DM to the interface
> > >   do we keep the one DM but have a way to "attach" other "lower order"
> > >   DMs to the that one DM that can be accessed?
> > Presumably.  Is a DM a function space, an operator, or both?
> > > DMCreateMatrix(dm,&mat);
> > > pmat = mat;
> > > DMGetLowerDM(dm,&ldm);
> > > if (ldm) {
> > >   DMCreateMatrix(ldm,&pmat);
> > > KSP/SNES/TSSetIJacobian(ts,mat,pmat,...);
> > > more generally DMGetLowerDM(dm,PetscOrderIndicater i,&ldm);
> Similarly MatGetLowerMat(mat,PetscOrderIndicater i,&lmat)?
> > > ----- an aside
> > >   BTW: this introduces a possible "missing" object in PETSc. We have
> > >   as a fundamental object the Mat which is a linear operator, we do
> > >   not have a fundamental object for a "general" operator, instead we
> > >   accept user provided functions directly (SNESSetFunction(),
> > >   TSSetIFunction() etc).  I've resisted the PetscOperator because I
> > >   felt it was overly abstract (and thus confusing to most users) and
> > >   is more difficult to implement cleanly since the operator may depend
> > >   on more than one input vector (TSSetIFunction depends on u and udot;
> > >   would we have a PetscOperator2 that had two input vectors?).
> > DMSNES and DMTS effectively provide this, it's just intimately coupled
> > to the DM.  I advocated before for separating these because function
> > spaces have meaning independent of operators defined on them, but that's
> > more of a performance consideration that assumes DM implementations
> > don't have cheap sharing of common data.
> > > I did try the PF object but it is very limited and rarely
> > > used. Certainly I think for a wide class of users, especially Fortran,
> > > SNESSetFunction() is understandable but
> > > PetscOperatorCreate(&operator)
> > > PetscOperatorSetRawFunction(operator, function())
> > > SNESSetOperator(snes,operator)
> > > becomes gibberish and so we would lose many potential users. Of course
> we could introduce the PetscOperator and maintain the simplicity of the
> current interface by having things like SNESSetFunction() automatically
> handle the conversion to the "operator" interface and have a new
> SNESSetOperator() for the general case. I hate having this kind of
> "wrapper" code because it usually bit decays over time and I don't like
> have multiple equivalent interfaces for the same effect (how do you
> document them, how does the user decide which one to use? I hate perl :-),
> there should be one way to do each thing).
> > SNESSetFunction calls DMSNESSetFunction.
> > > Or does one every need "lower order operation evaluation"? Is lower
> > > order linearization enough?
> > No, dual-order discretizations are possibly more important for nonlinear
> > problems.
> > > Currently with mat and pmat we only support lower order linearization,
> > > we don't for example allow passing a higher order and lower order
> > > nonlinear function both to SNESSetFunction. If the lower order
> > > operator is never needed, only the lower order linearization then
> > > PetscOperator (which would allow managing several orders of general
> > > operator) would not be needed so API for users is simpler. Or we could
> > > introduce lower order linear operators now and not worry about lower
> > > order function evaluations for years?  --- end of the aside
> > One common application of lower order discretizations is in in the
> > function provided to SNESSetNGS.
> > > I also don't disagree with Matt, should we just "complete" support for
> two levels of approximation by having proper two DMs for TS/KSP/SNES, see
> how that goes rather than jumping directly from a (far from perfect since
> users need to manually do ugly stuff since we only have one DM) two level
> support (as we currently have) to multilevel support? I won't change the
> current interface to do this instead I would just add TS/SNES/KSPSetDMs()
> > Yup.
> > > Imagine poor Ed's book if we suddenly change stuff like this in PETSc
> :-(  So the question is what should/could we do now to improve flexibility
> without requiring Ed to start all over again? That is, how gradually we
> need to introduce this kind of overhaul, and with how much backward
> compatibility?
> > I would say quite gradual and with at least a full release cycle of
> > backward compatibility.  And although I think it is ultimately better
> > for extensibility, I'm not 100% convinced it is worth the cost to users
> > to overhaul.  One nice thing about the current interface is that it
> > forces people to acknowledge that those two arguments could be
> > different, so they may read or find examples.  If we switch so our
> > operators have a basket of approximations, lots of users may never learn
> > about that basket.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170228/75e37b3e/attachment.html>
