[petsc-dev] [petsc-users] Multigrid with defect correction
Dave May
dave.mayhem23 at gmail.com
Tue Feb 28 04:03:31 CST 2017
On 26 February 2017 at 05:30, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >>> Do you think this is a reasonable approach or am I missing
> >>> something fundamental? I am assuming generally for the "higher
> >>> order" DM the Mat it returns is a MATSHELL or a new matrix class
> >>> built on "tensor contractions" and that kind of nonsense. I don't
> >>> want to do all the coding and then have it turn out that it is
> >>> totally useless for CEED etc.
> >> Well, this is exactly what we do in pTatin.
> > So why didn't you fix it in PETSc at that time?
> I didn't know it "didn't work" because what we were doing did work. (I
> think we used PCMG interfaces directly; we were mixing unassembled and
> assembled representations, plus Galerkin on coarser levels.)
I can confirm that Jed's recollection is correct.
The configuration used in ptatin was performed in the context of a
non-linear problem. Essentially all the MG setup has conducted during my
method for computeJacobian(). The setup / config for the different
operators was a little delicate, but the standard PCMG API permitted mixing
matrix-free, assembled and Galerkin coarse operators. For the Galerkin
case, I performed the call to MatPtAP myself in my computeJacobian()
function and would stuff the result into the appropriate KSP defining the
smoother.
> >> I would ask, why just two discretizations? I've always thought a better
> >> interface would be for Mats (and any other operators/functions) to have
> >> optional approximations or supplementary data attached. We can do this
> >> with PetscObjectCompose, but that's hard to work with in a structured
> >> way. Anyway, I think I would rather just have the Amat with ability to
> >> attach one or more Pmats.
> > Understood. I don't like the API as "attach one or more Pmats to a
> > Mat" but instead prefer to think of it as a linear operator that has
> > one or more "levels of approximation"
> Should they be "levels" (numbered?) or named approximations?
> > that can optionally be indicated; which one you wish to use is up to
> > the algorithm using the linear operator. Changing this in PETSc
> > would require some conceptional changes and refactoring in
> > PETSc. Would simplify things like SNESSetJacobian() because we would
> > not need to track mat and pmat. But would not be terribly difficult
> > for the PETSc developers or user.
> > If we used this model, instead of adding a new DM to the interface
> > do we keep the one DM but have a way to "attach" other "lower order"
> > DMs to the that one DM that can be accessed?
> Presumably. Is a DM a function space, an operator, or both?
> > DMCreateMatrix(dm,&mat);
> > pmat = mat;
> > DMGetLowerDM(dm,&ldm);
> > if (ldm) {
> > DMCreateMatrix(ldm,&pmat);
> > KSP/SNES/TSSetIJacobian(ts,mat,pmat,...);
> > more generally DMGetLowerDM(dm,PetscOrderIndicater i,&ldm); Similarly
> MatGetLowerMat(mat,PetscOrderIndicater i,&lmat)?
> > ----- an aside
> > BTW: this introduces a possible "missing" object in PETSc. We have
> > as a fundamental object the Mat which is a linear operator, we do
> > not have a fundamental object for a "general" operator, instead we
> > accept user provided functions directly (SNESSetFunction(),
> > TSSetIFunction() etc). I've resisted the PetscOperator because I
> > felt it was overly abstract (and thus confusing to most users) and
> > is more difficult to implement cleanly since the operator may depend
> > on more than one input vector (TSSetIFunction depends on u and udot;
> > would we have a PetscOperator2 that had two input vectors?).
> DMSNES and DMTS effectively provide this, it's just intimately coupled
> to the DM. I advocated before for separating these because function
> spaces have meaning independent of operators defined on them, but that's
> more of a performance consideration that assumes DM implementations
> don't have cheap sharing of common data.
> > I did try the PF object but it is very limited and rarely
> > used. Certainly I think for a wide class of users, especially Fortran,
> > SNESSetFunction() is understandable but
> > PetscOperatorCreate(&operator)
> > PetscOperatorSetRawFunction(operator, function())
> > SNESSetOperator(snes,operator)
> > becomes gibberish and so we would lose many potential users. Of course
> we could introduce the PetscOperator and maintain the simplicity of the
> current interface by having things like SNESSetFunction() automatically
> handle the conversion to the "operator" interface and have a new
> SNESSetOperator() for the general case. I hate having this kind of
> "wrapper" code because it usually bit decays over time and I don't like
> have multiple equivalent interfaces for the same effect (how do you
> document them, how does the user decide which one to use? I hate perl :-),
> there should be one way to do each thing).
> SNESSetFunction calls DMSNESSetFunction.
> > Or does one every need "lower order operation evaluation"? Is lower
> > order linearization enough?
> No, dual-order discretizations are possibly more important for nonlinear
> problems.
> > Currently with mat and pmat we only support lower order linearization,
> > we don't for example allow passing a higher order and lower order
> > nonlinear function both to SNESSetFunction. If the lower order
> > operator is never needed, only the lower order linearization then
> > PetscOperator (which would allow managing several orders of general
> > operator) would not be needed so API for users is simpler. Or we could
> > introduce lower order linear operators now and not worry about lower
> > order function evaluations for years? --- end of the aside
> One common application of lower order discretizations is in in the
> function provided to SNESSetNGS.
> > I also don't disagree with Matt, should we just "complete" support for
> two levels of approximation by having proper two DMs for TS/KSP/SNES, see
> how that goes rather than jumping directly from a (far from perfect since
> users need to manually do ugly stuff since we only have one DM) two level
> support (as we currently have) to multilevel support? I won't change the
> current interface to do this instead I would just add TS/SNES/KSPSetDMs()
> Yup.
> > Imagine poor Ed's book if we suddenly change stuff like this in PETSc
> :-( So the question is what should/could we do now to improve flexibility
> without requiring Ed to start all over again? That is, how gradually we
> need to introduce this kind of overhaul, and with how much backward
> compatibility?
> I would say quite gradual and with at least a full release cycle of
> backward compatibility. And although I think it is ultimately better
> for extensibility, I'm not 100% convinced it is worth the cost to users
> to overhaul. One nice thing about the current interface is that it
> forces people to acknowledge that those two arguments could be
> different, so they may read or find examples. If we switch so our
> operators have a basket of approximations, lots of users may never learn
> about that basket.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170228/9ac8cd53/attachment.html>
