[petsc-dev] build on cygwin for cygwin
Marco Atzeri marco.atzeri at gmail.com
Mon Feb 27 11:17:17 CST 2017
Dear developers,
from documentation
https://www.mcs.anl.gov/petsc/documentation/installation.html
seems that a build with cygwin compiler is possible, however
the results seems puzzling.
I tried with opemmpi compilers on x86_64 platform
--with-cc=mpicc --with-cxx=mpic++ --with-fc=mpifort --prefix=/usr/local
PETSC_ARCH=arch-mswin-gnu
and I see that the shared libraries have incorrect names
./arch-mswin-gnu/lib/libpetsc.dll
./arch-mswin-gnu/lib/libpetsc.so.3.7
./arch-mswin-gnu/lib/libpetsc.so.3.7.5
the right one should be cygpetsc-SONAME.dll;
The dependencies are correct
$ cygcheck arch-mswin-gnu/lib/libpetsc.so.3.7.5 |grep "^  E"
   E:\cygwin64\bin\cyggcc_s-seh-1.dll
   E:\cygwin64\bin\cyggfortran-3.dll
   E:\cygwin64\bin\cygblas-0.dll
   E:\cygwin64\bin\cygcrypto-1.0.0.dll
   E:\cygwin64\lib\lapack\cyglapack-0.dll
   E:\cygwin64\bin\cygmpi-12.dll
   E:\cygwin64\bin\cygmpi_mpifh-12.dll
   E:\cygwin64\bin\cygssl-1.0.0.dll
   E:\cygwin64\bin\cygX11-6.dll
there is no trace of import library ( *.a or *.lib)
Almost all tests fails.
$ make PETSC_DIR=/usr/local PETSC_ARCH="" test
Running test examples to verify correct installation
Using PETSC_DIR=/usr/local and PETSC_ARCH=
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
MPI process
C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
MPI processes
Possible error running Fortran example src/snes/examples/tutorials/ex5f
with 1 MPI process
See http://www.mcs.anl.gov/petsc/documentation/faq.html
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Cannot set ownership ranges before setting number of procs
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
[0]PETSC ERROR: ./ex5f on a arch-mswin-gnu named GE-MATZERI-EU by 0356EU
Mon Feb 27 18:10:42 2017
[0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpic++
--with-fc=mpifort --prefix=/usr/local PETSC_ARCH=arch-mswin-gnu
[0]PETSC ERROR: #1 DMDASetOwnershipRanges() line 617 in
/cygdrive/e/cyg_pub/devel/petsc/prova4/petsc-3.7.5/src/dm/impls/da/da.c
[0]PETSC ERROR: #2 DMDACreate2d() line 863 in
/cygdrive/e/cyg_pub/devel/petsc/prova4/petsc-3.7.5/src/dm/impls/da/da2.c
I also tried a build without mpi --with-mpi=0
but the tests seem to call mpi anyway:
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
process
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
that is at least curious.
Question:
- have some recently built successfully on cygwin for cygwin ?
Looking at build scripts on config directory I have the impression
that cygwin is only used as platform to build for Windows and not for
cygwin itself.
Thanks in advance
Marco
