[petsc-dev] Scatter a single local value to multiple global values
Chris Eldred
chris.eldred at gmail.com
Wed Feb 22 12:11:43 CST 2017
Ok, it is apparent I will have to think about this some more. Thanks
for the help!
-Chris
On Wed, Feb 22, 2017 at 6:36 PM, Jed Brown <jed at jedbrown.org> wrote:
> Chris Eldred <chris.eldred at gmail.com> writes:
>> Hey Jed,
>> That makes sense now, thanks! It sounds like the correct way to do things is:
>> For matrices:
>> 1) for each set of coupled dofs, select 1 to be the master and modify
>> the local to global maps such that all the local indices that
>> previously pointed to the slave dofs now point to the master dof
>> -> assembly doesn't produce anything for the slave rows
>> 2) fill the rows for the slave dofs with a -1 in the master column and
>> 1 in the slave column (since we are just enforcing slave = master).
> It's better to not store slave dofs in the global matrix. Just use the
> local-to-global mapping so that you get it in your local spaces. What
> you describe makes the matrix nonsymmetric and possibly ill-conditioned
> (depends on scaling of the other dofs).
>> For residuals, just do 1) and then set slave dofs equal to the master dof.
> What you describe above with +1 and -1 requires a right-hand side of 0.
Chris Eldred
https://www.math.univ-paris13.fr/~eldred/
Postdoctoral Fellow, LAGA, University of Paris 13
PhD, Atmospheric Science, Colorado State University, 2015
DOE Computational Science Graduate Fellow (Alumni)
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
