[petsc-dev] download problem p4est on Cori at NERSC
    Tobin Isaac
    tisaac at uchicago.edu
    Fri Feb 17 11:43:35 CST 2017
The configure.log doesn't really tell me why it is failing.  Did you
start with a clean git.p4est after trying to use the tarball?
On Fri, Feb 17, 2017 at 12:21:50PM -0500, Mark Adams wrote:
> It turns out that Cori-KNL does have git, it is just not loaded by default.
> It still does not work, but the error looks different.
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Could not initialize sc submodule needed by p4est
> On Thu, Feb 16, 2017 at 10:20 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> > On Thu, Feb 16, 2017 at 05:48:57PM -0600, Barry Smith wrote:
> > > > On Feb 16, 2017, at 5:01 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> > > > The bootstrap script predates/supercedes  autoreconf to get the
> > necessary m4 scripts and write configure.  The tarballs have the m4 scripts
> > and configure, so they should be treated as standard gnu configure && make
> > && make install scripts.  I think that's what I accomplished in p4est.py.
> > I'm on my phone, when I'm at a computer I'll look at this thread's history
> > to see if I can figure out what's going on.
> > >    You are confusing two errors. One is the issue you mention above, we
> > don't care about that. The only error we care about is that p4est
> > ./configure needs to run a compiled program to gather some information
> > about the machine. On systems with cross-compiling this doesn't work since
> > after ./configure compiles the program it cannot run it because it is not
> > compatible with the hardware. So the question is: is there an easy way to
> > hack the p4est configure so that we can provide the needed information
> > directly and not have ./configure try to run an executable?
> > Okay, I get it now.  There should be `config.log` in
> > externalpackags/git.p4est that would let me know what particular check
> > it was working on when cross-compilation errors cropped up, and I
> > could try to help come up with a solution.
> > >    Barry
> > > Note that this problem is common for many autoconf based build systems,
> > its solution depends on the details of how the particular system is using
> > using executables to gather information.
> > > > On February 16, 2017 4:34:35 PM CST, Barry Smith <bsmith at mcs.anl.gov>
> > wrote:
> > > >> The best long term fix is to find out what things p4est needs to
> > > >> determine by a running a program and providing them some other way.
> > > >> Toby
> > > >>  So what things is p4est trying to determine by running a program?
> > > >> Barry
> > > >>> On Feb 16, 2017, at 3:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > >>> I don't understand autoconf well enough for cross compiling. Some
> > > >>> packages appear to require this - but others don't.
> > > >> https://www.gnu.org/software/autoconf/manual/autoconf-2.69/
> > html_node/Hosts-and-Cross_002dCompilation.html
> > > >>> So one would run 'config.guess' script on the compute node - and use
> > > >> this value on the compile node with configure?
> > > >>> I don't know how we could automate that..
> > > >>> Satish
> > > >>> On Wed, 15 Feb 2017, Mark Adams wrote:
> > > >>>> OK, that did not work. It says something about --host now.
> > > >>>> On Wed, Feb 15, 2017 at 5:06 PM, Mark Adams <mfadams at lbl.gov>
> > wrote:
> > > >>>>> I think this will work because I have git when I configure on a
> > > >> login node
> > > >>>>> (Haswell). I build KNL by submitting a batch script (it takes to
> > > >> long to
> > > >>>>> fit in 30 minutes of an interactive session). That fails because
> > > >> git is not
> > > >>>>> available (can I just load the module ...) on a KNL compute node.
> > > >> It is
> > > >>>>> reconfiguring now, I'll let you know if it fails.
> > > >>>>> Thanks,
> > > >>>>> On Wed, Feb 15, 2017 at 4:59 PM, Satish Balay <balay at mcs.anl.gov>
> > > >> wrote:
> > > >>>>>> Sorry - this won't work - as p4est appears to require git
> > > >> [submodules?]..
> > > >>>>>>>>>>>>>>>>>> p4est.py <<<<<<<<<<<<<
> > > >>>>>> def updateGitDir(self):
> > > >>>>>>   config.package.GNUPackage.updateGitDir(self)
> > > >>>>>>   Dir = self.getDir()
> > > >>>>>>   try:
> > > >>>>>>     libsc = self.libsc
> > > >>>>>>   except AttributeError:
> > > >>>>>>     try:
> > > >>>>>>       self.executeShellCommand([self.sourceControl.git,
> > > >> 'submodule',
> > > >>>>>> 'update', '--init'], cwd=Dir, log=self.log)
> > > >>>>>>       import os
> > > >>>>>>       if os.path.isfile(os.path.join(Dir,'sc','README')):
> > > >>>>>>         self.libsc = os.path.join(Dir,'sc')
> > > >>>>>>       else:
> > > >>>>>>         raise RuntimeError
> > > >>>>>>     except RuntimeError:
> > > >>>>>>       raise RuntimeError('Could not initialize sc submodule
> > > >> needed by
> > > >>>>>> p4est')
> > > >>>>>>   return
> > > >>>>>> Satish
> > > >>>>>> On Wed, 15 Feb 2017, Satish Balay wrote:
> > > >>>>>>> batch won't help here. its git vs tarball - and p4est curently
> > > >> doesn't
> > > >>>>>> have a taball.
> > > >>>>>>> The following should give you a tarball - if you don't have git.
> > > >>>>>>> diff --git a/config/BuildSystem/config/packages/p4est.py
> > > >>>>>> b/config/BuildSystem/config/packages/p4est.py
> > > >>>>>>> index 4735ff4..1f9507c 100644
> > > >>>>>>> --- a/config/BuildSystem/config/packages/p4est.py
> > > >>>>>>> +++ b/config/BuildSystem/config/packages/p4est.py
> > > >>>>>>> @@ -4,7 +4,7 @@ class Configure(config.package.GNUPackage):
> > > >>>>>>>  def __init__(self, framework):
> > > >>>>>>>    config.package.GNUPackage.__init__(self, framework)
> > > >>>>>>>    self.gitcommit         = 'v2.0'
> > > >>>>>>> -    self.download          = ['git://https://github.com/cbu
> > > >>>>>> rstedde/p4est']
> > > >>>>>>> +    self.download          = ['git://https://github.com/cbu
> > > >>>>>> rstedde/p4est','https://github.com/cburstedde/p4est/archive/
> > > >>>>>> '+self.gitcommit+'.tar.gz']
> > > >>>>>>>    self.functions         = ['p4est_init']
> > > >>>>>>>    self.includes          = ['p4est_bits.h']
> > > >>>>>>>    self.liblist           = [['libp4est.a', 'libsc.a']]
> > > >>>>>>> I  can push this to master.
> > > >>>>>>> Satish
> > > >>>>>>>> Oh, this is because git does not work on KNL. Maybe I should do
> > > >>>>>>>> with-batch=1,
> > > >>>>>>>> On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov>
> > > >> wrote:
> > > >>>>>>>>> I get this error on the KNL partition at NERSC.  P4est works on
> > > >> the
> > > >>>>>>>>> Haswell partition and other downloads seem to work on the KNL
> > > >>>>>> partition.
> > > >>>>>>>>> Any ideas?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170217/bbefd267/attachment.sig>
