[petsc-dev] download problem p4est on Cori at NERSC
Tobin Isaac
tisaac at uchicago.edu
Thu Feb 16 21:20:34 CST 2017
On Thu, Feb 16, 2017 at 05:48:57PM -0600, Barry Smith wrote:
> > On Feb 16, 2017, at 5:01 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> > The bootstrap script predates/supercedes autoreconf to get the necessary m4 scripts and write configure. The tarballs have the m4 scripts and configure, so they should be treated as standard gnu configure && make && make install scripts. I think that's what I accomplished in p4est.py. I'm on my phone, when I'm at a computer I'll look at this thread's history to see if I can figure out what's going on.
> You are confusing two errors. One is the issue you mention above, we don't care about that. The only error we care about is that p4est ./configure needs to run a compiled program to gather some information about the machine. On systems with cross-compiling this doesn't work since after ./configure compiles the program it cannot run it because it is not compatible with the hardware. So the question is: is there an easy way to hack the p4est configure so that we can provide the needed information directly and not have ./configure try to run an executable?
Okay, I get it now. There should be `config.log` in
externalpackags/git.p4est that would let me know what particular check
it was working on when cross-compilation errors cropped up, and I
could try to help come up with a solution.
> Barry
> Note that this problem is common for many autoconf based build systems, its solution depends on the details of how the particular system is using using executables to gather information.
> > On February 16, 2017 4:34:35 PM CST, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> The best long term fix is to find out what things p4est needs to
> >> determine by a running a program and providing them some other way.
> >> Toby
> >> So what things is p4est trying to determine by running a program?
> >> Barry
> >>> On Feb 16, 2017, at 3:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> I don't understand autoconf well enough for cross compiling. Some
> >>> packages appear to require this - but others don't.
> >> https://www.gnu.org/software/autoconf/manual/autoconf-2.69/html_node/Hosts-and-Cross_002dCompilation.html
> >>> So one would run 'config.guess' script on the compute node - and use
> >> this value on the compile node with configure?
> >>> I don't know how we could automate that..
> >>> Satish
> >>> On Wed, 15 Feb 2017, Mark Adams wrote:
> >>>> OK, that did not work. It says something about --host now.
> >>>> On Wed, Feb 15, 2017 at 5:06 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >>>>> I think this will work because I have git when I configure on a
> >> login node
> >>>>> (Haswell). I build KNL by submitting a batch script (it takes to
> >> long to
> >>>>> fit in 30 minutes of an interactive session). That fails because
> >> git is not
> >>>>> available (can I just load the module ...) on a KNL compute node.
> >> It is
> >>>>> reconfiguring now, I'll let you know if it fails.
> >>>>> Thanks,
> >>>>> On Wed, Feb 15, 2017 at 4:59 PM, Satish Balay <balay at mcs.anl.gov>
> >> wrote:
> >>>>>> Sorry - this won't work - as p4est appears to require git
> >> [submodules?]..
> >>>>>>>>>>>>>>>>>> p4est.py <<<<<<<<<<<<<
> >>>>>> def updateGitDir(self):
> >>>>>> config.package.GNUPackage.updateGitDir(self)
> >>>>>> Dir = self.getDir()
> >>>>>> try:
> >>>>>> libsc = self.libsc
> >>>>>> except AttributeError:
> >>>>>> try:
> >>>>>> self.executeShellCommand([self.sourceControl.git,
> >> 'submodule',
> >>>>>> 'update', '--init'], cwd=Dir, log=self.log)
> >>>>>> import os
> >>>>>> if os.path.isfile(os.path.join(Dir,'sc','README')):
> >>>>>> self.libsc = os.path.join(Dir,'sc')
> >>>>>> else:
> >>>>>> raise RuntimeError
> >>>>>> except RuntimeError:
> >>>>>> raise RuntimeError('Could not initialize sc submodule
> >> needed by
> >>>>>> p4est')
> >>>>>> return
> >>>>>> Satish
> >>>>>> On Wed, 15 Feb 2017, Satish Balay wrote:
> >>>>>>> batch won't help here. its git vs tarball - and p4est curently
> >> doesn't
> >>>>>> have a taball.
> >>>>>>> The following should give you a tarball - if you don't have git.
> >>>>>>> diff --git a/config/BuildSystem/config/packages/p4est.py
> >>>>>> b/config/BuildSystem/config/packages/p4est.py
> >>>>>>> index 4735ff4..1f9507c 100644
> >>>>>>> --- a/config/BuildSystem/config/packages/p4est.py
> >>>>>>> +++ b/config/BuildSystem/config/packages/p4est.py
> >>>>>>> @@ -4,7 +4,7 @@ class Configure(config.package.GNUPackage):
> >>>>>>> def __init__(self, framework):
> >>>>>>> config.package.GNUPackage.__init__(self, framework)
> >>>>>>> self.gitcommit = 'v2.0'
> >>>>>>> - self.download = ['git://https://github.com/cbu
> >>>>>> rstedde/p4est']
> >>>>>>> + self.download = ['git://https://github.com/cbu
> >>>>>> rstedde/p4est','https://github.com/cburstedde/p4est/archive/
> >>>>>> '+self.gitcommit+'.tar.gz']
> >>>>>>> self.functions = ['p4est_init']
> >>>>>>> self.includes = ['p4est_bits.h']
> >>>>>>> self.liblist = [['libp4est.a', 'libsc.a']]
> >>>>>>> I can push this to master.
> >>>>>>> Satish
> >>>>>>>> Oh, this is because git does not work on KNL. Maybe I should do
> >>>>>>>> with-batch=1,
> >>>>>>>> On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov>
> >> wrote:
> >>>>>>>>> I get this error on the KNL partition at NERSC. P4est works on
> >> the
> >>>>>>>>> Haswell partition and other downloads seem to work on the KNL
> >>>>>> partition.
> >>>>>>>>> Any ideas?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170216/ad988ce2/attachment.sig>
