[petsc-dev] download problem p4est on Cori at NERSC
Tobin Isaac
tisaac at uchicago.edu
Thu Feb 16 17:01:32 CST 2017
The bootstrap script predates/supercedes autoreconf to get the necessary m4 scripts and write configure. The tarballs have the m4 scripts and configure, so they should be treated as standard gnu configure && make && make install scripts. I think that's what I accomplished in p4est.py. I'm on my phone, when I'm at a computer I'll look at this thread's history to see if I can figure out what's going on.
On February 16, 2017 4:34:35 PM CST, Barry Smith <bsmith at mcs.anl.gov> wrote:
>The best long term fix is to find out what things p4est needs to
>determine by a running a program and providing them some other way.
> Toby
> So what things is p4est trying to determine by running a program?
> Barry
>> On Feb 16, 2017, at 3:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> I don't understand autoconf well enough for cross compiling. Some
>> packages appear to require this - but others don't.
>https://www.gnu.org/software/autoconf/manual/autoconf-2.69/html_node/Hosts-and-Cross_002dCompilation.html
>> So one would run 'config.guess' script on the compute node - and use
>this value on the compile node with configure?
>> I don't know how we could automate that..
>> Satish
>> On Wed, 15 Feb 2017, Mark Adams wrote:
>>> OK, that did not work. It says something about --host now.
>>> On Wed, Feb 15, 2017 at 5:06 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> I think this will work because I have git when I configure on a
>login node
>>>> (Haswell). I build KNL by submitting a batch script (it takes to
>long to
>>>> fit in 30 minutes of an interactive session). That fails because
>git is not
>>>> available (can I just load the module ...) on a KNL compute node.
>It is
>>>> reconfiguring now, I'll let you know if it fails.
>>>> Thanks,
>>>> On Wed, Feb 15, 2017 at 4:59 PM, Satish Balay <balay at mcs.anl.gov>
>wrote:
>>>>> Sorry - this won't work - as p4est appears to require git
>[submodules?]..
>>>>>>>>>>>>>>>>> p4est.py <<<<<<<<<<<<<
>>>>> def updateGitDir(self):
>>>>> config.package.GNUPackage.updateGitDir(self)
>>>>> Dir = self.getDir()
>>>>> try:
>>>>> libsc = self.libsc
>>>>> except AttributeError:
>>>>> try:
>>>>> self.executeShellCommand([self.sourceControl.git,
>'submodule',
>>>>> 'update', '--init'], cwd=Dir, log=self.log)
>>>>> import os
>>>>> if os.path.isfile(os.path.join(Dir,'sc','README')):
>>>>> self.libsc = os.path.join(Dir,'sc')
>>>>> else:
>>>>> raise RuntimeError
>>>>> except RuntimeError:
>>>>> raise RuntimeError('Could not initialize sc submodule
>needed by
>>>>> p4est')
>>>>> return
>>>>> Satish
>>>>> On Wed, 15 Feb 2017, Satish Balay wrote:
>>>>>> batch won't help here. its git vs tarball - and p4est curently
>doesn't
>>>>> have a taball.
>>>>>> The following should give you a tarball - if you don't have git.
>>>>>> diff --git a/config/BuildSystem/config/packages/p4est.py
>>>>> b/config/BuildSystem/config/packages/p4est.py
>>>>>> index 4735ff4..1f9507c 100644
>>>>>> --- a/config/BuildSystem/config/packages/p4est.py
>>>>>> +++ b/config/BuildSystem/config/packages/p4est.py
>>>>>> @@ -4,7 +4,7 @@ class Configure(config.package.GNUPackage):
>>>>>> def __init__(self, framework):
>>>>>> config.package.GNUPackage.__init__(self, framework)
>>>>>> self.gitcommit = 'v2.0'
>>>>>> - self.download = ['git://https://github.com/cbu
>>>>> rstedde/p4est']
>>>>>> + self.download = ['git://https://github.com/cbu
>>>>> rstedde/p4est','https://github.com/cburstedde/p4est/archive/
>>>>> '+self.gitcommit+'.tar.gz']
>>>>>> self.functions = ['p4est_init']
>>>>>> self.includes = ['p4est_bits.h']
>>>>>> self.liblist = [['libp4est.a', 'libsc.a']]
>>>>>> I can push this to master.
>>>>>> Satish
>>>>>>> Oh, this is because git does not work on KNL. Maybe I should do
>>>>>>> with-batch=1,
>>>>>>> On Wed, Feb 15, 2017 at 4:36 PM, Mark Adams <mfadams at lbl.gov>
>wrote:
>>>>>>>> I get this error on the KNL partition at NERSC. P4est works on
>the
>>>>>>>> Haswell partition and other downloads seem to work on the KNL
>>>>> partition.
>>>>>>>> Any ideas?
