[petsc-dev] Interface for supporting MKL sparse inspector-executor model?
Barry Smith
bsmith at mcs.anl.gov
Tue Feb 14 18:04:23 CST 2017
PetscObjectSetOptionsPrefix()
> On Feb 14, 2017, at 5:52 PM, Richard Mills <richardtmills at gmail.com> wrote:
> On Mon, Feb 13, 2017 at 8:11 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> > Richard,
> > My gut feeling is that the "hint" based system should be used by default, who uses linear stuff only once (only people not doing real problems :-)). So you could just provide a single flag to say don't use hints, useful for numerical comparisons. (This is all experimental, stuff anyways and will evolve).
> You could process the hints using command-line options and not make a
> programmatic API at this time. If there is no good default, we can talk
> about whether the important MKL hints are really MKL-specific or
> something that other PETSc classes might be able to use. (There are
> uses cases for implicit conversion to ELL or a compressed
> representation.) But let's not make a programmatic hints API just yet.
> Thanks for the suggestion, Jed -- I think that's the way I should go. I'm probably going to need to do a decent amount of experimentation, and command-line options are the easiest way to do that.
> I'd like to tie these into the PETSc option handling system properly so that I can specify options for different matrices using prefixes (e.g., "-flow_" and "-transport_" in PFLOTRAN), but I don't remember how to do this. Can someone point me to where I should look to refresh my memory?
> --Richard
