[petsc-dev] Segmentation fault GAMG + MatView
    Hong
    hzhang at mcs.anl.gov
    Tue Feb 14 10:15:19 CST 2017
Pierre :
The bug is fixed and pushed to petsc-maint
https://bitbucket.org/petsc/petsc/branch/maint
Thanks for reporting it.
Hong
Oh my, this example also segfaults (at least on my Mac) when running:
> mpirun -np 1 ./ex1 -pc_type gamg -mat_view
> [0]PETSC ERROR: [0] MatView_SeqAIJ_ASCII line 560
> /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: [0] MatView_SeqAIJ line 915 /Volumes/Data/Repositories/
> [0]PETSC ERROR: [0] MatView line 920 /Volumes/Data/Repositories/
> petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PetscObjectView line 92 /Volumes/Data/Repositories/
> petsc/src/sys/objects/destroy.c
> [0]PETSC ERROR: [0] PetscObjectViewFromOptions line 2702
> /Volumes/Data/Repositories/petsc/src/sys/objects/options.c
> [0]PETSC ERROR: [0] MatAssemblyEnd line 5151 /Volumes/Data/Repositories/
> [0]PETSC ERROR: [0] MatCreateSeqAIJWithArrays line 4137
> [0]PETSC ERROR: [0] MatTransposeMatMultSymbolic_SeqAIJ_SeqAIJ line 1012
> /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/matmatmult.c
> [0]PETSC ERROR: [0] MatTransposeMatMult_SeqAIJ_SeqAIJ line 994
> [0]PETSC ERROR: [0] MatTransposeMatMult line 9607
> /Volumes/Data/Repositories/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PCGAMGCoarsen_AGG line 914 /Volumes/Data/Repositories/
> petsc/src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: [0] PCSetUp_GAMG line 425 /Volumes/Data/Repositories/
> petsc/src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: [0] PCSetUp line 886 /Volumes/Data/Repositories/
> petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 291 /Volumes/Data/Repositories/
> petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3046-gde967d2  GIT
> Date: 2017-02-09 18:59:37 +0000
> [0]PETSC ERROR: Configure options --LDFLAGS=-L/opt/intel/lib
> --download-hypre --download-metis --download-mumps --download-parmetis
> --download-pastix --download-ptscotch --with-blacs-include=/opt/intel/mkl/include
> --with-blacs-lib=/opt/intel/mkl/lib/libmkl_blacs_mpich_lp64.so
> --with-blaslapack-dir=/opt/intel/mkl --with-chtml=0
> --with-mkl_pardiso-include=/opt/intel/mkl/include --with-mkl_pardiso=1
> --with-scalapack-include=/opt/intel/mkl/include
> --with-scalapack-lib="[/opt/intel/mkl/lib/libmkl_
> scalapack_lp64.so,/opt/intel/mkl/lib/libmkl_blacs_mpich_lp64.so]"
> --with-shared-libraries=1 --with-x=1 PETSC_ARCH=arch-darwin-c-debug
> On Feb 9, 2017, at 10:52 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> wrote:
> There, attached.
> Thanks.
> PS: here is the patch also, just in case
> diff --git a/src/ksp/ksp/examples/tutorials/ex1.c b/src/ksp/ksp/examples/
> tutorials/ex1.c
> index 6382c09..d9dc69a 100644
> --- a/src/ksp/ksp/examples/tutorials/ex1.c
> +++ b/src/ksp/ksp/examples/tutorials/ex1.c
> @@ -123,6 +123,11 @@ int main(int argc,char **args)
>      routines.
>    ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> +  ierr = KSPSetUp(ksp);CHKERRQ(ierr);
> +  char right_options[] = "-ksp_norm_type unpreconditioned -ksp_pc_side
> right";
> +  PetscOptionsInsertString(NULL,right_options);
> +  ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>    if (nonzeroguess) {
>      PetscScalar p = .5;
> <ex1.c>
> On Feb 9, 2017, at 2:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 9, 2017 at 7:48 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr
> > wrote:
>> On Feb 9, 2017, at 2:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Feb 9, 2017 at 7:29 AM, Pierre Jolivet <pierre.jolivet at enseei
>> ht.fr> wrote:
>>> On Feb 9, 2017, at 2:17 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Feb 9, 2017 at 7:06 AM, Pierre Jolivet <pierre.jolivet at enseei
>>> ht.fr> wrote:
>>>> On Feb 9, 2017, at 1:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Feb 9, 2017 at 4:56 AM, Pierre Jolivet <pierre.jolivet at enseei
>>>> ht.fr> wrote:
>>>>> Hello,
>>>>> I _might_ be doing something wrong when calling
>>>>> KSPSetFromOptions/KSPSetUp, but still, am I supposed to get this kind of
>>>>> error?
>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>> [0]PETSC ERROR: KSP gmres does not support PRECONDITIONED with RIGHT
>>>>> If not, I’ll try to send a MWE (it basically depends on where I set
>>>>> the option -ksp_pc_side right).
>>>> I believe its telling you that it cannot display the preconditioned
>>>> residual with right preconditioning, which is true.
>>>> Are you requesting both?
>>>> No, I’m just using -ksp_view and -ksp_pc_side right. In the “standard”
>>>> case, it obviously work.
>>>> However, the error is triggered if I set -ksp_pc_side right after a
>>>> first call to KSPSetOperators()/KSPSetUp() without destroying the KSP.
>>>> Should I destroy my KSP before changing from left- (default) to
>>>> right-preconditioning if KSPSetOperators()/KSPSetUp has already been called?
>>> Its likely you have to use
>>>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpage
>>> s/KSP/KSPSetNormType.html
>>> or
>>>   *-ksp_norm_type unpreconditioned*
>>> If I use this after my first call to KSPSetUp, I now end up with:
>>> [0]PETSC ERROR: KSP gmres does not support UNPRECONDITIONED with LEFT
>> Yes, you would need to use it at the same time that you change the
>> preconditioning side.
>> Yes, I’m using PetscOptionsInsert, and whether I let PETSc parse
>> "-ksp_pc_side right -ksp_norm_type unpreconditioned” or "-ksp_norm_type
>> unpreconditioned -ksp_pc_side right” I end up with the same error
>> afterwards.
> Can you make an example do it (SNES ex5)? Or can you send a small example
> that does it?
>   Thanks,
>     Matt
>> Thanks.
>>   Thanks,
>>      Matt
>>> since we would not have a chance to change it since its been set already.
>>>   Thanks,
>>>      Matt
>>> Thanks.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Pierre
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170214/df86dd5f/attachment.html>
