[petsc-dev] telescope does not work with TS
    Dave May
    dave.mayhem23 at gmail.com
    Mon Feb 13 14:34:32 CST 2017
Okay - sorry Barry, I should have looked at the stack trace more carefully.
I see now that the error is coming from a DMDA example.
Here is a possible way forward.
In telescope, I could actually check if the computeoperators method was in
fact KSPComputeOperators_SNES(). If it is, then I could set things up
differently, e.g. call computeoperators on the parent comm, then if the
result mat is an assembled matrix, move it onto the sub-comm.
What do you think? Just another hack??
Cheers
  Dave
> > On Feb 13, 2017, at 10:01 AM, Zhang, Hong <hongzhang at anl.gov> wrote:
> > Hi Barry,
> > When using telescope, I get an error complaining about missing Jacobian.
> But apparently I have a Jacobian set by TSSetIJacobian().
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Must call SNESSetJacobian(), DMSNESSetJacobian(),
> DMDASNESSetJacobianLocal(), etc
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2764-g0ff3c95
> GIT Date: 2017-01-10 15:40:21 -0600
> > [0]PETSC ERROR: ./ex5adj_ell on a arch-memalign-mkl-avx512-opt named
> isdp001.cels.anl.gov by hongzh Mon Feb 13 09:56:48 2017
> > [0]PETSC ERROR: Configure options --COPTFLAGS="-g -O3 -xMIC-AVX512"
> --CXXOPTFLAGS="-g -O3 -xMIC-AVX512" --FOPTFLAGS="-g -O3 -xMIC-AVX512"
> --PETSC_ARCH=arch-memalign-mkl-avx512-opt --PETSC_DIR=/homes/hongzh/Projects/petsc
> --download-cmake --download-revolve=1 --with-blaslapack-dir=/opt/int
> el/2017-initial/compilers_and_libraries_2017/linux/mkl/lib/intel64
> --with-cc=mpiicc --with-cxx=mpiicpc --with-debugging=no --with-fc=mpiifort
> --with-memalign=64 --with-mpiexec=mpirun
> > [0]PETSC ERROR: #1 SNESComputeJacobian() line 2242 in
> /home/hongzh/Projects/petsc/src/snes/interface/snes.c
> > [0]PETSC ERROR: #2 KSPComputeOperators_SNES() line 569 in
> > [0]PETSC ERROR: #3 KSPSetUp() line 327 in /home/hongzh/Projects/petsc/sr
> c/ksp/ksp/interface/itfunc.c
> > [0]PETSC ERROR: #4 KSPSolve() line 599 in /home/hongzh/Projects/petsc/sr
> > [0]PETSC ERROR: #5 PCApply_Telescope_dmda() line 952 in
> /home/hongzh/Projects/petsc/src/ksp/pc/impls/telescope/telescope_dmda.c
> > [0]PETSC ERROR: #6 PCApply() line 458 in /home/hongzh/Projects/petsc/sr
> c/ksp/pc/interface/precon.c
> > [0]PETSC ERROR: #7 KSP_PCApply() line 251 in
> /homes/hongzh/Projects/petsc/include/petsc/private/kspimpl.h
> > [0]PETSC ERROR: #8 KSPSolve_PREONLY() line 22 in
> /home/hongzh/Projects/petsc/src/ksp/ksp/impls/preonly/preonly.c
> > [0]PETSC ERROR: #9 KSPSolve() line 656 in /home/hongzh/Projects/petsc/sr
> > [0]PETSC ERROR: #10 PCMGMCycle_Private() line 19 in
> /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> > [0]PETSC ERROR: #11 PCMGMCycle_Private() line 53 in
> > [0]PETSC ERROR: #12 PCMGMCycle_Private() line 53 in
> > [0]PETSC ERROR: #13 PCMGMCycle_Private() line 53 in
> > [0]PETSC ERROR: #14 PCMGMCycle_Private() line 53 in
> > [0]PETSC ERROR: #15 PCApply_MG() line 331 in
> > [0]PETSC ERROR: #16 PCApply() line 458 in /home/hongzh/Projects/petsc/sr
> > [0]PETSC ERROR: #17 KSP_PCApply() line 251 in
> > [0]PETSC ERROR: #18 KSPInitialResidual() line 67 in
> /home/hongzh/Projects/petsc/src/ksp/ksp/interface/itres.c
> > [0]PETSC ERROR: #19 KSPSolve_GMRES() line 233 in
> /home/hongzh/Projects/petsc/src/ksp/ksp/impls/gmres/gmres.c
> > [0]PETSC ERROR: #20 KSPSolve() line 656 in /home/hongzh/Projects/petsc/sr
> > [0]PETSC ERROR: #21 SNESSolve_NEWTONLS() line 224 in
> /home/hongzh/Projects/petsc/src/snes/impls/ls/ls.c
> > [0]PETSC ERROR: #22 SNESSolve() line 3967 in
> > [0]PETSC ERROR: #23 TS_SNESSolve() line 171 in
> /home/hongzh/Projects/petsc/src/ts/impls/implicit/theta/theta.c
> > [0]PETSC ERROR: #24 TSStep_Theta() line 211 in
> > [0]PETSC ERROR: #25 TSStep() line 3808 in /home/hongzh/Projects/petsc/sr
> c/ts/interface/ts.c
> > [0]PETSC ERROR: #26 TSSolve() line 4053 in /home/hongzh/Projects/petsc/sr
> c/ts/interface/ts.c
> > [0]PETSC ERROR: #27 main() line 171 in /homes/hongzh/Projects/petsc/s
> rc/ts/examples/tutorials/advection-diffusion-reaction/ex5adj_ell.c
> > [0]PETSC ERROR: PETSc Option Table entries:
> > [0]PETSC ERROR: -da_refine 4
> > [0]PETSC ERROR: -dm_mat_type aij
> > [0]PETSC ERROR: -forwardonly
> > [0]PETSC ERROR: -ksp_converged_reason
> > [0]PETSC ERROR: -ksp_view
> > [0]PETSC ERROR: -mg_coarse_pc_telescope_reduction_factor 2
> > [0]PETSC ERROR: -mg_coarse_pc_type telescope
> > [0]PETSC ERROR: -mg_coarse_telescope_pc_type lu
> > [0]PETSC ERROR: -mg_levels_pc_type jacobi
> > [0]PETSC ERROR: -pc_type mg
> > [0]PETSC ERROR: -ts_dt 1
> > [0]PETSC ERROR: -ts_max_steps 1
> > [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> > Thanks,
> > Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170213/9eb167eb/attachment.html>
