[petsc-dev] telescope does not work with TS
Barry Smith
bsmith at mcs.anl.gov
Mon Feb 13 13:41:52 CST 2017
From the manual page: KSPSetComputeOperators() is not propagated to the sub KSP.
Yet there is some code
sred->ignore_kspcomputeoperators = PETSC_FALSE;
if (sred->ignore_kspcomputeoperators) {
ierr = PetscViewerASCIIPrintf(subviewer," Telescope: ignoring KSPComputeOperators\n");CHKERRQ(ierr);
ierr = PetscOptionsBool("-pc_telescope_ignore_kspcomputeoperators","Ignore method used to compute A","PCTelescopeSetIgnoreKSPComputeOperators",sred->ignore_kspcomputeoperators,&sred->ignore_kspcomputeoperators,0);CHKERRQ(ierr);
etc
that seems to indicate that Dave May intended to have support for KSPComputeOperator ... but didn't complete it.
In this case it is using KSPComputeOperators_SNES(KSP ksp,Mat A,Mat B,void *ctx); which needs a couple of things changed to get it to work:
1) KSPComputeOperators_SNES() needs to work when the subdm is on a smaller set of processes so the call to SNESComputeJacobian() has to handle running on a subset of process (which of course it cannot do normally because the SNES has its full communicator while the DM only lives on a subset of processes).
2) The DMRestrictHook_SNESVecSol() has to handle switching to a DM on a smaller set of processes and remapping the "solution" vector to that smaller set.
Dave and Jed,
All and all looks awfully complex and fragile to get this working. What do you think?
Barry
Curse whoever designed PETSc originally and didn't take into account in its basic design the need to subcom PETSc objects to smaller communicators :-(
> On Feb 13, 2017, at 10:01 AM, Zhang, Hong <hongzhang at anl.gov> wrote:
> Hi Barry,
> When using telescope, I get an error complaining about missing Jacobian. But apparently I have a Jacobian set by TSSetIJacobian().
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR:
> [0]PETSC ERROR: Must call SNESSetJacobian(), DMSNESSetJacobian(), DMDASNESSetJacobianLocal(), etc
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.4-2764-g0ff3c95 GIT Date: 2017-01-10 15:40:21 -0600
> [0]PETSC ERROR: ./ex5adj_ell on a arch-memalign-mkl-avx512-opt named isdp001.cels.anl.gov by hongzh Mon Feb 13 09:56:48 2017
> [0]PETSC ERROR: Configure options --COPTFLAGS="-g -O3 -xMIC-AVX512" --CXXOPTFLAGS="-g -O3 -xMIC-AVX512" --FOPTFLAGS="-g -O3 -xMIC-AVX512" --PETSC_ARCH=arch-memalign-mkl-avx512-opt --PETSC_DIR=/homes/hongzh/Projects/petsc --download-cmake --download-revolve=1 --with-blaslapack-dir=/opt/intel/2017-initial/compilers_and_libraries_2017/linux/mkl/lib/intel64 --with-cc=mpiicc --with-cxx=mpiicpc --with-debugging=no --with-fc=mpiifort --with-memalign=64 --with-mpiexec=mpirun
> [0]PETSC ERROR: #1 SNESComputeJacobian() line 2242 in /home/hongzh/Projects/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #2 KSPComputeOperators_SNES() line 569 in /home/hongzh/Projects/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #3 KSPSetUp() line 327 in /home/hongzh/Projects/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #4 KSPSolve() line 599 in /home/hongzh/Projects/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #5 PCApply_Telescope_dmda() line 952 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/telescope/telescope_dmda.c
> [0]PETSC ERROR: #6 PCApply() line 458 in /home/hongzh/Projects/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #7 KSP_PCApply() line 251 in /homes/hongzh/Projects/petsc/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #8 KSPSolve_PREONLY() line 22 in /home/hongzh/Projects/petsc/src/ksp/ksp/impls/preonly/preonly.c
> [0]PETSC ERROR: #9 KSPSolve() line 656 in /home/hongzh/Projects/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #10 PCMGMCycle_Private() line 19 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #11 PCMGMCycle_Private() line 53 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #12 PCMGMCycle_Private() line 53 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #13 PCMGMCycle_Private() line 53 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #14 PCMGMCycle_Private() line 53 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #15 PCApply_MG() line 331 in /home/hongzh/Projects/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #16 PCApply() line 458 in /home/hongzh/Projects/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #17 KSP_PCApply() line 251 in /homes/hongzh/Projects/petsc/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #18 KSPInitialResidual() line 67 in /home/hongzh/Projects/petsc/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #19 KSPSolve_GMRES() line 233 in /home/hongzh/Projects/petsc/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #20 KSPSolve() line 656 in /home/hongzh/Projects/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #21 SNESSolve_NEWTONLS() line 224 in /home/hongzh/Projects/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #22 SNESSolve() line 3967 in /home/hongzh/Projects/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #23 TS_SNESSolve() line 171 in /home/hongzh/Projects/petsc/src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: #24 TSStep_Theta() line 211 in /home/hongzh/Projects/petsc/src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: #25 TSStep() line 3808 in /home/hongzh/Projects/petsc/src/ts/interface/ts.c
> [0]PETSC ERROR: #26 TSSolve() line 4053 in /home/hongzh/Projects/petsc/src/ts/interface/ts.c
> [0]PETSC ERROR: #27 main() line 171 in /homes/hongzh/Projects/petsc/src/ts/examples/tutorials/advection-diffusion-reaction/ex5adj_ell.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -da_refine 4
> [0]PETSC ERROR: -dm_mat_type aij
> [0]PETSC ERROR: -forwardonly
> [0]PETSC ERROR: -ksp_converged_reason
> [0]PETSC ERROR: -ksp_view
> [0]PETSC ERROR: -mg_coarse_pc_telescope_reduction_factor 2
> [0]PETSC ERROR: -mg_coarse_pc_type telescope
> [0]PETSC ERROR: -mg_coarse_telescope_pc_type lu
> [0]PETSC ERROR: -mg_levels_pc_type jacobi
> [0]PETSC ERROR: -pc_type mg
> [0]PETSC ERROR: -ts_dt 1
> [0]PETSC ERROR: -ts_max_steps 1
> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> Thanks,
> Hong
