[petsc-dev] Fluent test
Sat Feb 11 13:59:27 CST 2017
  Matt,
    I see the following
249b02ff src/dm/impls/plex/examples/tests/ex1.c    (Matthew Knepley 2017-01-19 14:34:09 -0600 386)     requires: broken
so it looks like you previously thought it was broken and hence marked it this way.
I added
7f662ca5 src/dm/impls/plex/examples/tests/ex1.c    (Barry Smith     2017-02-09 14:38:55 -0600 387)     requires: !complex
which apparently broke the previous broken requires and hence triggered the "error" you could not fix.
I have put both requires on the same line and the test harness now correctly does not run this example since it requires broken.
> On Feb 11, 2017, at 9:10 AM, Matthew Knepley <knepley at gmail.com> wrote:
> This test
>   dm_impls_plex_tests-runex1_fluent_3
> mysteriously stopped working when I pulled. I stepped through and a read() call returns
> EOF when its clearly not at the end. I have no idea how to debug. Did someone just change
> something connected with binary reading, file opening, Fluent?
>    Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
