[petsc-dev] segfaults with mpich 3.2 and clang (Apple LLVM 8.0.0, clang 800.0.42.1)
    Jeff Hammond
    jeff.science at gmail.com
    Fri Feb 10 14:33:41 CST 2017
See https://github.com/elemental/Elemental/issues/200.
Jeff
On Fri, Feb 10, 2017 at 12:05 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   I am using MPICH 3.2 with 8.2.1 and typically run the entire PETSc test
> suite. Have not observed problems. Maybe upgrade Xcode first?
> > On Feb 10, 2017, at 1:59 PM, Brad Aagaard <baagaard at usgs.gov> wrote:
> > Are there any known issues with mpich3.2 and clang (Apple LLVM 8.0.0,
> clang 800.0.42.1)? I am getting segfaults in MPI routines within PETSc.
> > The error is: write_line error; fd=-1 buf=:cmd=abort exitcode=59, which
> appears to be similar to the recent DMPlexCreateExodusFromFile() does not
> work on macOS Sierra thread
> > https://lists.mcs.anl.gov/mailman/htdig/petsc-users/
> 2017-January/031463.html
> > However, I am not using any Darwin packaging system like homebrew. I am
> building PETSc via the PyLith installer which builds mpich, NetCDF, HDF5,
> etc from scratch using the Apple's clang. If I swap mpich3.2 for
> mpich3.1.3, these segfaults go away, so I am inclined to blame mpich3.2.
> > If this is a unknown or undiagnosed issue, I will try a standalone PETSc
> install to try to reproduce it.
> > Thanks,
> > Brad
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170210/90449599/attachment.html>
