[petsc-dev] every test example runs in a new directory with new test harness
Jed Brown
jed at jedbrown.org
Thu Feb 9 19:06:22 CST 2017
Matthew Knepley <knepley at gmail.com> writes:
> So I need to check in this checkpoint file in order to test reading it in,
> and also the diffing? I am not sure I like that better.
> Shouldn't we design our test system to do this simple thing, rather than
> clutter our repository for all time?
Shouldn't we do the stronger test that guarantees the file format does
not silently change?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170210/3d39db22/attachment.sig>
