[petsc-dev] Segmentation fault GAMG + MatView
Pierre Jolivet pierre.jolivet at enseeiht.fr
Thu Feb 9 16:00:44 CST 2017
Oh my, this example also segfaults (at least on my Mac) when running:
mpirun -np 1 ./ex1 -pc_type gamg -mat_view
[0]PETSC ERROR: [0] MatView_SeqAIJ_ASCII line 560 /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: [0] MatView_SeqAIJ line 915 /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: [0] MatView line 920 /Volumes/Data/Repositories/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] PetscObjectView line 92 /Volumes/Data/Repositories/petsc/src/sys/objects/destroy.c
[0]PETSC ERROR: [0] PetscObjectViewFromOptions line 2702 /Volumes/Data/Repositories/petsc/src/sys/objects/options.c
[0]PETSC ERROR: [0] MatAssemblyEnd line 5151 /Volumes/Data/Repositories/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] MatCreateSeqAIJWithArrays line 4137 /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: [0] MatTransposeMatMultSymbolic_SeqAIJ_SeqAIJ line 1012 /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/matmatmult.c
[0]PETSC ERROR: [0] MatTransposeMatMult_SeqAIJ_SeqAIJ line 994 /Volumes/Data/Repositories/petsc/src/mat/impls/aij/seq/matmatmult.c
[0]PETSC ERROR: [0] MatTransposeMatMult line 9607 /Volumes/Data/Repositories/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] PCGAMGCoarsen_AGG line 914 /Volumes/Data/Repositories/petsc/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: [0] PCSetUp_GAMG line 425 /Volumes/Data/Repositories/petsc/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: [0] PCSetUp line 886 /Volumes/Data/Repositories/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPSetUp line 291 /Volumes/Data/Repositories/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.5-3046-gde967d2  GIT Date: 2017-02-09 18:59:37 +0000
[0]PETSC ERROR: Configure options --LDFLAGS=-L/opt/intel/lib --download-hypre --download-metis --download-mumps --download-parmetis --download-pastix --download-ptscotch --with-blacs-include=/opt/intel/mkl/include --with-blacs-lib=/opt/intel/mkl/lib/libmkl_blacs_mpich_lp64.so --with-blaslapack-dir=/opt/intel/mkl --with-chtml=0 --with-mkl_pardiso-include=/opt/intel/mkl/include --with-mkl_pardiso=1 --with-scalapack-include=/opt/intel/mkl/include --with-scalapack-lib="[/opt/intel/mkl/lib/libmkl_scalapack_lp64.so,/opt/intel/mkl/lib/libmkl_blacs_mpich_lp64.so]" --with-shared-libraries=1 --with-x=1 PETSC_ARCH=arch-darwin-c-debug
> On Feb 9, 2017, at 10:52 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
> There, attached.
> Thanks.
> PS: here is the patch also, just in case
> diff --git a/src/ksp/ksp/examples/tutorials/ex1.c b/src/ksp/ksp/examples/tutorials/ex1.c
> index 6382c09..d9dc69a 100644
> --- a/src/ksp/ksp/examples/tutorials/ex1.c
> +++ b/src/ksp/ksp/examples/tutorials/ex1.c
> @@ -123,6 +123,11 @@ int main(int argc,char **args)
>      routines.
>    ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> +  ierr = KSPSetUp(ksp);CHKERRQ(ierr);
> +  char right_options[] = "-ksp_norm_type unpreconditioned -ksp_pc_side right";
> +  PetscOptionsInsertString(NULL,right_options);
> +  ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>    if (nonzeroguess) {
>      PetscScalar p = .5;
> <ex1.c>
>> On Feb 9, 2017, at 2:56 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Thu, Feb 9, 2017 at 7:48 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>>> On Feb 9, 2017, at 2:31 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Thu, Feb 9, 2017 at 7:29 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>>>> On Feb 9, 2017, at 2:17 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> On Thu, Feb 9, 2017 at 7:06 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>>>>> On Feb 9, 2017, at 1:37 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>> On Thu, Feb 9, 2017 at 4:56 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr <mailto:pierre.jolivet at enseeiht.fr>> wrote:
>>>>> Hello,
>>>>> I _might_ be doing something wrong when calling KSPSetFromOptions/KSPSetUp, but still, am I supposed to get this kind of error?
>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>> [0]PETSC ERROR: KSP gmres does not support PRECONDITIONED with RIGHT
>>>>> If not, I’ll try to send a MWE (it basically depends on where I set the option -ksp_pc_side right).
>>>>> I believe its telling you that it cannot display the preconditioned residual with right preconditioning, which is true.
>>>>> Are you requesting both?
>>>> No, I’m just using -ksp_view and -ksp_pc_side right. In the “standard” case, it obviously work.
>>>> However, the error is triggered if I set -ksp_pc_side right after a first call to KSPSetOperators()/KSPSetUp() without destroying the KSP.
>>>> Should I destroy my KSP before changing from left- (default) to right-preconditioning if KSPSetOperators()/KSPSetUp has already been called?
>>>> Its likely you have to use
>>>>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetNormType.html <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetNormType.html>
>>>> or
>>> If I use this after my first call to KSPSetUp, I now end up with:
>>> [0]PETSC ERROR: KSP gmres does not support UNPRECONDITIONED with LEFT
>>> Yes, you would need to use it at the same time that you change the preconditioning side.
>> Yes, I’m using PetscOptionsInsert, and whether I let PETSc parse "-ksp_pc_side right -ksp_norm_type unpreconditioned” or "-ksp_norm_type unpreconditioned -ksp_pc_side right” I end up with the same error afterwards.
>> Can you make an example do it (SNES ex5)? Or can you send a small example that does it?
>>   Thanks,
>>     Matt
>> Thanks.
>>>   Thanks,
>>>      Matt
>>>> since we would not have a chance to change it since its been set already.
>>>>   Thanks,
>>>>      Matt
>>>> Thanks.
>>>>>   Thanks,
>>>>>      Matt
>>>>> Thanks,
>>>>> Pierre
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>> -- Norbert Wiener
>>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170209/701c8950/attachment.html>
