[petsc-dev] using valgrind with new test harness
Wed Feb 8 22:04:07 CST 2017
Namespacing avoids this issue of conflict. You already have PETSCDIFF
for the diff. So I changed MPIEXEC to PETSCMPIEXEC
Pushed to scott/test-harness-valgrind-v2 and merged to next.
Satish
On Wed, 8 Feb 2017, Satish Balay wrote:
> The old system was just makefile with runtargets using shell.
> So we had:
> - default 'VAR=foo' in petscvariables (i.e make variable)
> - and we could change the value on command line: 'make VAR=new'
> We avoided 'make -e' early-on [due to buggy make?] and continued to do
> so - to avoid picking up user env that could have conflicting stuff
> With the new system we have 'makefile -> gmakefile -> runex.sh' - and
> we can run tests at all 3 leves. I think its best if all 3 modes
> behave the same way (or pretty close).
> runex.sh will get default values from petsvariables via
> ./config/gmakegentest.py - so this case works fine.
> With the default usage of 'make' [i.e without -e] - things can become
> inconsistant between make and the script - when user env variables
> exist. For ex:
> $ cat makefile
> FOO=default_val_make
> all:
> 	@echo makevar: ${FOO}
> 	@echo scriptvar: `./script.sh`
> $ cat script.sh
> #!/bin/sh
> FOO=${FOO:-"default_val_script"}
> echo $FOO
> 1. Env variable FOO is not set [and we see the expected behavior. - we would have default_val_make and default_val_script be the same]
> $ ./script.sh
> default_val_script
> $ make
> makevar: default_val_make
> scriptvar: default_val_script
> 2. With 'FOO' specified to make (via command line) This is fine aswell. (no equivalent stuff for script)
> $ make FOO=cmd_var
> makevar: cmd_var
> scriptvar: cmd_var
> 3. Use env variable. (env var is ignored by make as expected - but
> script_var gets changed to make_var? I don't understand this - however
> it won't affect our usage as both should be same).
> But now script.sh is picking up this user env variable - which I don't
> think we would want to happen.
> $ export FOO=env_var
> $ make
> scriptvar: default_val_make
> $ ./script.sh
> env_var
> There is also one more thing to worry about:
> the usage is: 'makefile -> gmakefile -> runex.sh' -> "bin/*.sh" and
> the scripts in bin can rely on env variables [PETSC_ARCH/PETSC_DIR]
> for defaults. So I fixed petscdiff for defaults but I'm avoiding
> petscmpiexec and using petsc_mpiexec_valgrind() in petsc_harness.sh
> instead.
> [petscdiff currently lets us override defaults with env variables -
> perhaps it will also have the same issue as above - so should be fixed
> - or we add petsc_diff() in petsc_harness.sh.]
> Satish
> On Wed, 8 Feb 2017, Scott Kruger wrote:
> > I have no strong objection, but a couple of comments.
> > Barry said that the old test system could take env variables from the
> > command-line.  Didn't the old system pull in petscvariables?  If so,
> > how could it be overwritten.
> > I think only documenting (and yes, I will need to update the
> > documentation when things have settled down) VALGRIND=1 but
> > allow the secret -e method would probably be OK.  Users that
> > know about make -e should be smart enough (?) to know the danger.
> > Scott
> > On 2/8/17 3:47 PM, Satish Balay wrote:
> > > Scott & Barry,
> > > I'd like to remove the 'env' variable change. We don't want this to be
> > > overwritten as it can be fragile [as users env can have incompatible
> > > stuff here]
> > > And petscmpiexec relies on env variables - so I'm not using it in the test
> > > harness.
> > > So I have a branch scott/test-harness-valgrind-v2 (with commits
> > > collapsed/fixed)
> > > So the following would be the way to use it.
> > > make -f gmakefile test VALGRIND=1
> > > Do you have any objections to this?
> > > If we want them to be overwritted - then I guess we'll have to namespace
> > > them properly.
> > > Satish
> > > > Actually Jed's discussion of using env for DIFF had me consider another
> > > > solution than the one I had originally came up with.  I have both mpiexec
> > > > and
> > > > diff using this new method to give what Barry
> > > > wants more directly:
> > > >     https://bitbucket.org/petsc/petsc/pull-requests/631/
> > > > Both of these now work at the makefile level:
> > > >     MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind" make -e -f
> > > > gmakefile test
> > > > Note that I am passing the -e flag to make which has
> > > > the environment variable override the value in
> > > > ${PETSC_ARCH}/lib/conf/petscvariables
> > > > This can be dangerous depending on how clean your environment is
> > > > because it'll override ALL variables.
> > > > And from the shell script level:
> > > >     runex1.sh -V
> > > >     MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind" runex1.sh
> > > > On 2/7/17 4:42 PM, Barry Smith wrote:
> > > > > > On Feb 7, 2017, at 5:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > > > We cannot override stuff via env variables in the new test harness.
> > > > > > For
> > > > > > nightlybuilds
> > > > > > I added support to check if PETSC_ARCH has 'valgrind' string in it -
> > > > > > and
> > > > > > if so - use
> > > > > > valgrind.
> > > > > > 26646c0bcc29652ef239540b066d00d1c8fc99c7
> > > > > > Perhaps we can force this to use valgrind with:
> > > > > > ./config/gmakegentest.py --valgrind=1
> > > > >   I can't decide at the time I run the tests, but need to decide when I
> > > > >   do
> > > > >   the gmakegentest.py
> > > > > > Ok - perhaps the attached patch.
> > > > >    That is one heck of a patch, talk about code duplication resulting in
> > > > >    endless bugs.
> > > > > > But then - sometimes gmakefile runs ./config/gmakegentest.py directly
> > > > > > [without valgrind]
> > > > >   Fix it properly somehow; currently it is impossible and that is
> > > > >   insanely
> > > > >   horrible.
> > > > > > Satish
> > > > > > On Tue, 7 Feb 2017, Barry Smith wrote:
> > > > > > > Both
> > > > > > > -valgrind "
> > > > > > > and
> > > > > > > MPIEXEC="/sandbox/bsmith/petsc/bin/petscmpiexec -valgrind " make -f
> > > > > > > gmakefile test
> > > > > > > do not appear to use valgrind in the test harness (the old system
> > > > > > > did).
> > > > > > > How do I run all tests under valgrind automatically?
> > > > > > > not ok dm_impls_plex_tests-ex18_1
> > > > > > > #       [0]PETSC ERROR: PetscTrFreeDefault() called from
> > > > > > > VecDestroy_MPI() line 18 in /sandbox/bsmith/petsc/src/vec\
> > > > > > > /vec/impls/mpi/pdvec.c
> > > > > > > #       [0]PETSC ERROR: Block [id=0(32)] at address 0xb54240 is
> > > > > > > #       corrupted (probably write past end of array)
> > > > > > > #       [0]PETSC ERROR: Block allocated in VecCreate_MPI_Private()
> > > > > > > #       line
> > > > > > > #       497 in /sandbox/bsmith/petsc/src/vec/vec/i\
> > > > > > > mpls/mpi/pbvec.c
> > > > > > > #       [0]PETSC ERROR: --------------------- Error Message
> > > > > > > #       [0]PETSC ERROR: Memory corruption:
> > > > > > > #       http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
> > > > > > > #       [0]PETSC ERROR: Corrupted memory
> > > > > > > #       [0]PETSC ERROR: See
> > > > > > > #       http://www.mcs.anl.gov/petsc/documentation/faq.html for
> > > > > > > #       trouble
> > > > > > > #       shooting.
> > > > > > > #       [0]PETSC ERROR: Petsc Development GIT revision:
> > > > > > > #       v3.7.5-3057-g2d11e0f  GIT Date: 2017-02-07 15:39:04 -0600
> > > > > > > #       [0]PETSC ERROR: ../ex18 on a arch-single named es by bsmith
> > > > > > > #       Tue
> > > > > > > #       Feb  7 15:46:25 2017
> > > > > > > #       [0]PETSC ERROR: Configure options --download-ctetgen
> > > > > > > #       --download-exodusii --download-hdf5 --download-mpich \
> > > > > > > --download-netcdf PETSC_ARCH=arch-single --with-precision=single
> > > > > > > #       [0]PETSC ERROR: #1 PetscTrFreeDefault() line 287 in
> > > > > > > #       /sandbox/bsmith/petsc/src/sys/memory/mtr.c
> > > > > > > #       [0]PETSC ERROR: #2 VecDestroy_MPI() line 18 in
> > > > > > > #       /sandbox/bsmith/petsc/src/vec/vec/impls/mpi/pdvec.c
> > > > > > > #       [0]PETSC ERROR: #3 VecDestroy() line 406 in
> > > > > > > #       /sandbox/bsmith/petsc/src/vec/vec/interface/vector.c
> > > > > > > #       [0]PETSC ERROR: #4 DMDestroy() line 681 in
> > > > > > > #       /sandbox/bsmith/petsc/src/dm/interface/dm.c
> > > > > > > #       [0]PETSC ERROR: #5 main() line 473 in
> > > > > > > #       /sandbox/bsmith/petsc/src/dm/impls/plex/examples/tests/ex18.c
> > > > > > > #       [0]PETSC ERROR: PETSc Option Table entries:
> > > > > > > #       [0]PETSC ERROR: -dm_view ascii::ascii_info_detail
> > > > > > > #       [0]PETSC ERROR: -interpolate
> > > > > > <val.patch>
