[petsc-dev] install petsc on windows 10 with mpi
Wed Feb 8 09:46:02 CST 2017
Richard,
The current issue is with MS compiler build - with MS-MPI. WSL doesn't
help for this case. [assuming 'abaqus' requirement requires a native
build with MS compilers]
Wrt WSL/PETSc - yeah build goes through fine - but 'make alltests'
give random hangs/errors in MPI calls for me..
Satish
On Wed, 8 Feb 2017, Richard Mills wrote:
> Hi Mohammad,
> Have you considered not using Cygwin and instead using the beta "Windows
> Subsystem for Linux" that provides a layer for running ELF binaries and
> using Ubuntu packages?  I've not tried building PETSc with it yet, but I've
> been impressed at how well it works when I have tried other things.  Quick
> Google search comes up with this page that briefly talks about it and how
> to enable it:
>   http://www.zdnet.com/article/ubuntu-and-bash-arrive-on-windows-10/
> Best regards,
> Richard
> On Sun, Feb 5, 2017 at 8:51 PM, Mohammad S Dodaran <mdodar1 at lsu.edu> wrote:
> > Dear Petsc developers,
> > I am trying to install Petsc on windows 10 but I have a problem. I
> > installed  MS-MPI v8 <http://go.microsoft.com/FWLink/p/?LinkID=389556> separately
> > and in the configure options I use
> > --with-mpi-include="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\
> > SDKs/MPI/Include" --with-mpi-lib="/cygdrive/c/Program\ Files\
> > \(x86\)/Microsoft\ SDKs/MPI/Lib/x64/msmpi.lib"
> > But it gives error which says:
> >                 ERROR in COMMAND LINE ARGUMENT to ./configure
> > Invalid directory: [/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\
> > SDKs/MPI/Include for key with-mpi-include
> > How should I solve it?
> > Mohammad
