[petsc-dev] install petsc on windows 10 with mpi
    Mohammad S Dodaran
    mdodar1 at lsu.edu
    Tue Feb  7 16:31:24 CST 2017
i did
make clean
make V=1 MAKE_NP=1
and i attached  the make.log
when I try to make the error that  appears on the screen is like this:
Using C/C++ compile: /home/petsc-3.6.4/bin/win32fe/win32fe cl -c -MT -wd4996 -O2   -I/home/petsc-3.6.4/include -I/home/petsc-3.6.4/first/include -I/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include -I/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include/x64
Using Fortran compile: /home/petsc-3.6.4/bin/win32fe/win32fe ifort -c -MT -O3 -fpp   -I/home/petsc-3.6.4/include -I/home/petsc-3.6.4/first/include -I/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include -I/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include/x64
Using C/C++ linker: /home/petsc-3.6.4/bin/win32fe/win32fe cl
Using C/C++ flags: -MT -wd4996 -O2
Using Fortran linker: /home/petsc-3.6.4/bin/win32fe/win32fe ifort
Using Fortran flags: -MT -O3 -fpp
Using libraries: -L/home/petsc-3.6.4/first/lib  -lpetsc -lflapack -lfblas /cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpi.lib /cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpifec.lib Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
Using mpiexec: mpiexec
Building PETSc using GNU Make with 1 build threads
make[2]: Entering directory '/home/petsc-3.6.4'
/usr/bin/python ./config/gmakegen.py --petsc-arch=first
/home/petsc-3.6.4/bin/win32fe/win32fe cl -c -MT -wd4996 -O2   -I/home/petsc-3.6.4/include -I/home/petsc-3.6.4/first/include -I/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include -I/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include/x64     /home/petsc-3.6.4/src/sys/info/verboseinfo.c -o first/obj/src/sys/info/verboseinfo.o
make[2]: *** [gmakefile:161: first/obj/src/sys/info/verboseinfo.o] Error 188
make[2]: Leaving directory '/home/petsc-3.6.4'
make[1]: *** [/home/petsc-3.6.4/lib/petsc/conf/rules:107: gnumake] Error 2
make[1]: Leaving directory '/home/petsc-3.6.4'
**************************ERROR*************************************
  Error during compile, check first/lib/petsc/conf/make.log
  Send it and first/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov
make: *** [makefile:30: all] Error 1
MIE-HERA1+instadm at mie-hera1 /home/petsc-3.6.4
Sent: Tuesday, February 7, 2017 3:44:01 PM
To: Mohammad S Dodaran
Cc: petsc-dev
Subject: Re: [petsc-dev] install petsc on windows 10 with mpi
On Tue, 7 Feb 2017, Mohammad S Dodaran wrote:
> okay
> i patched the file you send
> $ patch -Np1 < mpich-ver-test.patch
> (Stripping trailing CRs from patch; use --binary to disable.)
> patching file config/BuildSystem/config/packages/MPI.py
wrt this patch - you would run configure again. But the error messages below are weird.
Can you do:
make clean
make V=1 MAKE_NP=1
and resend logs.
Satish
> the tried to make
> it failed
> Building PETSc using GNU Make with 4 build threads
> Use "/usr/bin/make V=1" to see the verbose compile lines.
>           CC first/obj/src/sys/info/verboseinfo.o
>           CC first/obj/src/sys/info/ftn-custom/zverboseinfof.o
>           CC first/obj/src/sys/info/ftn-auto/verboseinfof.o
>           CC first/obj/src/sys/ftn-custom/zsys.o
> make[2]: *** [gmakefile:161: first/obj/src/sys/info/ftn-custom/zverboseinfof.o]        Error 188
> make[2]: *** Waiting for unfinished jobs....
> make[2]: *** [gmakefile:161: first/obj/src/sys/info/ftn-auto/verboseinfof.o] Err        or 188
> make[2]: *** [gmakefile:161: first/obj/src/sys/ftn-custom/zsys.o] Error 188
> i have attached the make.log
> ________________________________
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Tuesday, February 7, 2017 3:25:52 PM
> Cc: petsc-dev
> nope.
> satish
> > do you want me to remove the env and configure it once again and send you the log files?
> > From: Mohammad S Dodaran
> > Sent: Tuesday, February 7, 2017 3:13:55 PM
> > To: petsc-dev
> > sorry for responding late. something came up and i couldn't start working on this earlier.
> > env is still there, and i removed those three line
> > then: tried to make
> > i attached the configure and make log files
> > i tried to patch the file that you send but the patch command does not work in cygwin
> > MIE-HERA1+instadm at mie-hera1 ~
> > $ cd /home/petsc-3.6.4
> > bash: patch: command not found
> > am i missing something?
> > Sent: Tuesday, February 7, 2017 12:09:38 AM
> > To: petsc-dev
> > Cc: Mohammad S Dodaran
> > Please try the attached patch - and see if it works [without removing IntelMPI from env]
> > you can apply it with 'patch' command from cygwin
> > Satish
> > On Mon, 6 Feb 2017, Satish Balay wrote:
> > > Thinking about this - configure should not fail with MSMPI even if Intel-MPI is in the default path.
> > > A workarround is [after successful configure] - edit PETSC_ARCH/include/petscconf.h and remove the lines:
> > > #ifndef PETSC_HAVE_MPICH_NUMVERSION
> > > #define PETSC_HAVE_MPICH_NUMVERSION 30200300
> > > #endif
> > > And then run 'make all'
> > > Will have to check on the fix..
> > > Satish
> > > On Mon, 6 Feb 2017, Mohammad S Dodaran wrote:
> > > > I will remove intel mpi env tomorrow first thing in the morning and then i will send you the log files.
> > > > Mohammad
> > > > Get Outlook for Android<https://aka.ms/ghei36>
> > > > Sent: Monday, February 6, 2017 11:34:00 PM
> > > > To: petsc-dev
> > > > BTW: Why not use petsc-3.7?
> > > > Satish
> > > > > Please send the logs for the case that is supporsed to work - but failed.
> > > > > without the relavent logs - I have no idea what failed.
> > > > > Satish
> > > > > > As i stated in my previous email.
> > > > > > " i tried to make with and without intel-mpi ENV . in both cases the error had been changed." And the error didnt have any thing to do with intel_mpi ENV. Do you still want me to remove the intel_ mpi env and send you the log file?
> > > > > > Sent: Monday, February 6, 2017 11:15:19 PM
> > > > > > To: petsc-dev
> > > > > > never mind.
> > > > > > #line 2416 "c:\\program files (x86)\\intelswtools\\compilers_and_libraries_2017.1.143\\windows\\mpi\\intel64\\include\\mpi.h"^M
> > > > > > ^M
> > > > > > #line 2418 "c:\\program files (x86)\\intelswtools\\compilers_and_libraries_2017.1.143\\windows\\mpi\\intel64\\include\\mpi.h"^M
> > > > > > ^M
> > > > > > #line 4 "C:\\cygwin64\\tmp\\PE5639~1\\CONFIG~1.MPI\\conftest.c"^M
> > > > > > int mpich_ver = 30200300;
> > > > > >                   Defined "HAVE_MPICH_NUMVERSION" to "30200300"
> > > > > >               Checking for functions [MPI_Alltoallw] in library ['/cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpi.lib', '/cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/ms\
> > > > > > mpifec.lib'] []
> > > > > >                 Pushing language C
> > > > > > Its still picking up mpi.h from intel MPI
> > > > > > INCLUDE=C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\compiler\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\compiler\include\intel64;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\INCLUDE;C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\ATLMFC\INCLUDE;C:\Program Files (x86)\Windows Kits\8.1\include\shared;C:\Program Files (x86)\Windows Kits\8.1\include\um;C:\Program Files (x86)\Windows Kits\8.1\include\winrt;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\mpi\intel64\bin\..\..\intel64\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\ipp\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\mkl\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\tbb\bin\..\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\daal\include;C:\Program Files (x86)\IntelSWTools\itac_2017\include;C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\mpi\intel64\bin\..\..\intel64\include;
> > > > > > The env has "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.1.143\windows\mpi\intel64\bin\..\..\intel64\include" from where mpi.h is getting picked up.
> > > > > > If you can't remove it  perhaps you can try using it instead of MSMPI
> > > > > > Satish
> > > > > > > can you also send make.log?
> > > > > > > Satish
> > > > > > > > i was trying to repair my parallel_studio_xe_2017. then i configure it once again and then i tried to make with and without intel-mpi ENV . in both cases the error had been changed. i have attached the configure.log
> > > > > > > > Sent: Monday, February 6, 2017 10:10:43 PM
> > > > > > > > Cc: petsc-dev
> > > > > > > > Them Intel-MPI was not removed. You can resend configure.log to confirm..
> > > > > > > > Satish
> > > > > > > > > I removed the INTEL-MPI from the environmental variables and I still have the same problem. When I configure it looks like it  accepts the mpi_include and mpi_lib but when I want to build , it says the configure was with mpi but in build it appears to  compile is using a non-mpich.
> > > > > > > > > Mohammad
> > > > > > > > > Sent: Monday, February 6, 2017 6:13:04 PM
> > > > > > > > > Cc: petsc-dev
> > > > > > > > > 1. configure.log is a cygwin simlink - so native mail app is unable to
> > > > > > > > > attach correctly.  The actual file is in
> > > > > > > > > PETSC_DIR/PETSC_ARCH/lib/petsc/conf
> > > > > > > > > 2. Suggest doing the build without fftw and hdf5 packages [once the
> > > > > > > > > basic build succeeds - you can look at adding these pacakges.]
> > > > > > > > > 3. remove INTEL-MPI from your env - before running configure.  [you
> > > > > > > > > might be able to use intel-mpi instead of ms-mpi - but we don't have
> > > > > > > > > any experience with it]
> > > > > > > > > Satish
> > > > > > > > > > now I'm trying to configure petsc 3.7
> > > > > > > > > > i used the format you showd in your previous email for the directories of fftw and hdf5 as below
> > > > > > > > > > --with-fftw-dir=/cygdrive/c/cygwin64/home/fftw --with-hdf5-dir=/cygdrive/c/cygwin64/home/hdf5
> > > > > > > > > > the result is the following
> > > > > > > > > > TESTING: alternateConfigureLibrary from config.packages.glut(config/BuildSystem/config/package.py:742)                  TESTING: alternateConfigureLibrary from config.packages.giflib(config/BuildSystem/config/package.py:742)                TESTING: alternateConfigureLibrary from config.packages.scientificpython(config/BuildSystem/config/package.py:742)      TESTING: alternateConfigureLibrary from config.packages.fiat(config/BuildSystem/config/package.py:742)                  TESTING: configureLibrary from config.packages.fftw(config/BuildSystem/config/package.py:679)                           *******************************************************************************
> > > > > > > > > >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > > > > > > > > > --with-fftw-dir=/cygdrive/c/cygwin64/home/fftw did not work
> > > > > > > > > > i also attached the configure.log
> > > > > > > > > > Sent: Monday, February 6, 2017 4:28:09 PM
> > > > > > > > > > Cc: Matthew Knepley; petsc-dev
> > > > > > > > > > Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc="win32fe cl" --with-fc="win32fe ifort" --with-cxx="win32fe cl" --with-mpi-include="[/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include,/cygdrive/c/PROGRA~2/MICROS~4/MPI/Include/x64]" --with-mpi-lib="[/cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpi.lib,/cygdrive/c/PROGRA~2/MICROS~4/MPI/Lib/x64/msmpifec.lib]" --with-fftw-dir="[/cygdrive/c/cygwin64/home/fftw]" --with-hdf5-dir="[/cygdrive/c/cygwin64/home/hdf5]" --download-fblaslapack=1 --with-c2html=0 --with-debugging=0 --with-ssl=0 --with-x=0 PETSC_ARCH= PETSC_DIR=/home/petsc-3.6.4
> > > > > > > > > > > 'PETSC_ARCH='
> > > > > > > > > > Can you rerun with a non-empty PETSC_ARCH string - or let configure choost default..
> > > > > > > > > > I don't think I've built these packages with MS compilers
> > > > > > > > > > before. Somehow they are not picked up anyway. For one - the format
> > > > > > > > > > here should be the following [but I don't know if that will make
> > > > > > > > > > configure check for them]:
> > > > > > > > > > Also - please use latest petsc-3.7 release.
> > > > > > > > > > > C:\cygwin64\home\PETSC-~1.4\include\petscsys.h(122) : fatal error C1189: #error :  "PETSc was configured with MPICH but
> > > > > > > > > > > now appears to be compiling using a non-MPICH mpi.h"
> > > > > > > > > > Hm - configure is picking up Intel-MPI from your 'INCLUDE' env
> > > > > > > > > > variable - but not 'make' - not sure whats hapenning - but I think its
> > > > > > > > > > best to start a clean build with petsc-3.7 [unless you need 3.6 for a
> > > > > > > > > > specific need]
> > > > > > > > > > Satish
> > > > > > > > > > > hello
> > > > > > > > > > > i configured petsc and i was trying to make then this error appeared
> > > > > > > > > > > /usr/bin/python ./config/gmakegen.py --petsc-arch=../petsc-3.6.4
> > > > > > > > > > >           CC ../petsc-3.6.4/obj/src/sys/info/verboseinfo.o
> > > > > > > > > > >           CC ../petsc-3.6.4/obj/src/sys/info/ftn-auto/verboseinfof.o
> > > > > > > > > > >           CC ../petsc-3.6.4/obj/src/sys/info/ftn-custom/zverboseinfof.o
> > > > > > > > > > >           CC ../petsc-3.6.4/obj/src/sys/ftn-custom/zsys.o
> > > > > > > > > > > verboseinfo.c
> > > > > > > > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/info/verboseinfo.o] Error 2
> > > > > > > > > > > verboseinfof.c
> > > > > > > > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/info/ftn-auto/verboseinfof.o] Error 2
> > > > > > > > > > > zverboseinfof.c
> > > > > > > > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/info/ftn-custom/zverboseinfof.o] Error 2
> > > > > > > > > > > zsys.c
> > > > > > > > > > > make[2]: *** [gmakefile:161: ../petsc-3.6.4/obj/src/sys/ftn-custom/zsys.o] Error 2
> > > > > > > > > > >   Error during compile, check ../petsc-3.6.4/lib/petsc/conf/make.log
> > > > > > > > > > >   Send it and ../petsc-3.6.4/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov
> > > > > > > > > > > i have also attached the configure.log and make.log
> > > > > > > > > > > regards
> > > > > > > > > > > Mohammad
> > > > > > > > > > > From: Matthew Knepley <knepley at gmail.com>
> > > > > > > > > > > Sent: Monday, February 6, 2017 8:07:41 AM
> > > > > > > > > > > Cc: petsc-dev
> > > > > > > > > > > On Sun, Feb 5, 2017 at 11:26 PM, Mohammad S Dodaran <mdodar1 at lsu.edu<mailto:mdodar1 at lsu.edu>> wrote:
> > > > > > > > > > > Satish,
> > > > > > > > > > > Thanks for your quick response. as you see I can ls to the directory:
> > > > > > > > > > >  ls /cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include/
> > > > > > > > > > > Yes, but as Satish said, there are spaces in the path above. We do not allow spaces in the path.
> > > > > > > > > > > You cannot give a path to configure with spaces.
> > > > > > > > > > > You can remove the spaces using the cygpath command that Satish showed. Please use that command.
> > > > > > > > > > > Remove the spaces from this path and give the spaceless path to configure.
> > > > > > > > > > >   Thanks,
> > > > > > > > > > >      Matt
> > > > > > > > > > > mpi.f90   mpi.h     mpif.h    mpio.h    mspms.h   pmidbg.h  x64/      x86/
> > > > > > > > > > > but I do not know why still it has the same problem. and my configure file looks strange.
> > > > > > > > > > > Best,
> > > > > > > > > > > Mohammad
> > > > > > > > > > > From: Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>
> > > > > > > > > > > Sent: Sunday, February 5, 2017 10:58:35 PM
> > > > > > > > > > > Cc: petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>
> > > > > > > > > > > Try to figureout path without spaces.
> > > > > > > > > > > cygpath -u `cygpath -s -m PATH`
> > > > > > > > > > > Make sure you can do "ls" on this path.
> > > > > > > > > > > And use it with petsc configure.
> > > > > > > > > > > balay at ps4 ~
> > > > > > > > > > > $ cygpath -u `cygpath -s -m /cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include`
> > > > > > > > > > > /cygdrive/c/PROGRA~2/MICROS~2/MPI/Include
> > > > > > > > > > > balay at ps4 ~
> > > > > > > > > > > $ ls /cygdrive/c/PROGRA~2/MICROS~2/MPI/Include
> > > > > > > > > > > mpi.f90  mpi.h  mpif.h  mpio.h  mspms.h  pmidbg.h  x64  x86
> > > > > > > > > > > balay at ps4 ~
> > > > > > > > > > > For ex: - I use:
> > > > > > > > > > > $ cat config/examples/arch-mswin-intel.py
> > > > > > > > > > > #!/usr/bin/python
> > > > > > > > > > > if __name__ == '__main__':
> > > > > > > > > > >   import sys
> > > > > > > > > > >   import os
> > > > > > > > > > >   sys.path.insert(0, os.path.abspath('config'))
> > > > > > > > > > >   import configure
> > > > > > > > > > >   configure_options = [
> > > > > > > > > > >     '--download-fblaslapack=1',
> > > > > > > > > > >     '--with-cc=win32fe icl',
> > > > > > > > > > >     '--with-cxx=win32fe icl',
> > > > > > > > > > >     '--with-fc=win32fe ifort',
> > > > > > > > > > >     '--with-mpi-include=[/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include/,/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include/x64]',
> > > > > > > > > > >     '--with-mpi-lib=[/cygdrive/c/PROGRA~2/MICROS~2/MPI/lib/x64/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~2/MPI/lib/x64/msmpi.lib]',
> > > > > > > > > > >     '--with-mpiexec=/cygdrive/c/PROGRA~1/MICROS~2/Bin/mpiexec',
> > > > > > > > > > >     '--with-shared-libraries=0',
> > > > > > > > > > >     'DATAFILESPATH=c:/cygwin64/home/petsc/datafiles',
> > > > > > > > > > >   configure.petsc_configure(configure_options)
> > > > > > > > > > > if you still have issues - send us configure.log for the failure.
> > > > > > > > > > > Satish
> > > > > > > > > > > On Sun, 5 Feb 2017, Mohammad S Dodaran wrote:
> > > > > > > > > > > > Dear Petsc developers,
> > > > > > > > > > > > I am trying to install Petsc on windows 10 but I have a problem. I installed  MS-MPI v8<http://go.microsoft.com/FWLink/p/?LinkID=389556> separately and in the configure options I use
> > > > > > > > > > > > --with-mpi-include="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include" --with-mpi-lib="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Lib/x64/msmpi.lib"
> > > > > > > > > > > > But it gives error which says:
> > > > > > > > > > > >                 ERROR in COMMAND LINE ARGUMENT to ./configure
> > > > > > > > > > > > Invalid directory: [/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include for key with-mpi-include
> > > > > > > > > > > > How should I solve it?
> > > > > > > > > > > > Mohammad
> > > > > > > > > > > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > > > > > > > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170207/9540bc04/attachment.html>
Desc: make.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170207/9540bc04/attachment.obj>
