[petsc-dev] every test example runs in a new directory with new test harness
Matthew Knepley
knepley at gmail.com
Mon Feb 6 08:10:28 CST 2017
On Mon, Feb 6, 2017 at 1:05 AM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> > test:
> > suffix: restart_0
> > requires: hdf5
> > args: -run_type test -refinement_limit 0.0 -bc_type dirichlet
> -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view
> hdf5:sol.h5::append
> > test:
> > suffix: restart_1
> > requires: hdf5
> -interpolate 1 -petscspace_order 1 -f sol.h5 -restart
> > See a problem?
> > Should the same run of the example view the files and then load them
> back in? versus trying to read in a data file from another run that may not
> even have been created before and even if it was, the file was definitely
> created in a different directory?
> So if write only is broken, do you want both to fail? I think it's
> better to read and write separately, with comparison using h5diff, since
> that independently tests read vs write and establishes backward
> compatibility, which you'd really like the test system to make you deal
> with explicitly.
I know the test is broken, but I did already mail the list about this and
was waiting for an answer
to be worked out.
I agree with Satish that running two commands would be great. I could
rewrite the example to
both write and load it, but it would complicate it. Also, I am trying to
get the pattern I expect the
user to follow for checkpointing.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170206/5097dce9/attachment.html>
