[petsc-dev] install petsc on windows 10 with mpi
Satish Balay
balay at mcs.anl.gov
Sun Feb 5 22:58:35 CST 2017
Try to figureout path without spaces.
cygpath -u `cygpath -s -m PATH`
Make sure you can do "ls" on this path.
And use it with petsc configure.
balay at ps4 ~
$ cygpath -u `cygpath -s -m /cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include`
/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include
balay at ps4 ~
$ ls /cygdrive/c/PROGRA~2/MICROS~2/MPI/Include
mpi.f90 mpi.h mpif.h mpio.h mspms.h pmidbg.h x64 x86
balay at ps4 ~
For ex: - I use:
$ cat config/examples/arch-mswin-intel.py
#!/usr/bin/python
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--download-fblaslapack=1',
'--with-cc=win32fe icl',
'--with-cxx=win32fe icl',
'--with-fc=win32fe ifort',
'--with-mpi-include=[/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include/,/cygdrive/c/PROGRA~2/MICROS~2/MPI/Include/x64]',
'--with-mpi-lib=[/cygdrive/c/PROGRA~2/MICROS~2/MPI/lib/x64/msmpifec.lib,/cygdrive/c/PROGRA~2/MICROS~2/MPI/lib/x64/msmpi.lib]',
'--with-mpiexec=/cygdrive/c/PROGRA~1/MICROS~2/Bin/mpiexec',
'--with-shared-libraries=0',
'DATAFILESPATH=c:/cygwin64/home/petsc/datafiles',
configure.petsc_configure(configure_options)
if you still have issues - send us configure.log for the failure.
Satish
On Sun, 5 Feb 2017, Mohammad S Dodaran wrote:
> Dear Petsc developers,
> I am trying to install Petsc on windows 10 but I have a problem. I installed MS-MPI v8<http://go.microsoft.com/FWLink/p/?LinkID=389556> separately and in the configure options I use
> --with-mpi-include="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include" --with-mpi-lib="/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Lib/x64/msmpi.lib"
> But it gives error which says:
> ERROR in COMMAND LINE ARGUMENT to ./configure
> Invalid directory: [/cygdrive/c/Program\ Files\ \(x86\)/Microsoft\ SDKs/MPI/Include for key with-mpi-include
> How should I solve it?
> Mohammad
