[petsc-dev] every test example runs in a new directory with new test harness
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Feb  5 21:50:10 CST 2017
  Does the test harness support this? If so it sounds like an ok solution
> On Feb 5, 2017, at 9:41 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Perhaps the following could be converted into a single run script with
> 2 mpiexec commands.
>  test:
>    suffix: restart_0
>    requires: hdf5
>    args: -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append
>    args: -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 1 -petscspace_order 1 -f sol.h5 -restart
> Satish
> On Sun, 5 Feb 2017, Barry Smith wrote:
>>  test:
>>    suffix: restart_0
>>    requires: hdf5
>>  test:
>>    suffix: restart_1
>>    requires: hdf5
>> See a problem?
>> Should the same run of the example view the files and then load them back in? versus trying to read in a data file from another run that may not even have been created before and even if it was, the file was definitely created  in a different directory?
>> I think that if you want to do this kind of test the same example must first write the file and then read it back in. Cannot assume any relationship between different runs of tests with parallel scheduling.
>>  Barry
