[petsc-dev] every test example runs in a new directory with new test harness
Barry Smith
bsmith at mcs.anl.gov
Sun Feb 5 21:32:33 CST 2017
test:
suffix: restart_0
requires: hdf5
args: -run_type test -refinement_limit 0.0 -bc_type dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append
test:
suffix: restart_1
requires: hdf5
args: -run_type test -refinement_limit 0.0 -bc_type dirichlet -interpolate 1 -petscspace_order 1 -f sol.h5 -restart
See a problem?
Should the same run of the example view the files and then load them back in? versus trying to read in a data file from another run that may not even have been created before and even if it was, the file was definitely created in a different directory?
I think that if you want to do this kind of test the same example must first write the file and then read it back in. Cannot assume any relationship between different runs of tests with parallel scheduling.
Barry
