[petsc-dev] need c++ expert help
Jed Brown
jed at jedbrown.org
Sun Dec 31 17:58:35 CST 2017
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> On Dec 31, 2017, at 2:14 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Matthew Knepley <knepley at gmail.com> writes:
>>>>> On Sun, Dec 31, 2017 at 1:55 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>>> These look like linker errors and that build uses
>>>>>> --with-cxxlib-autodetect=0. We either need a rule to *link* C++ using
>>>>>> CXX (i.e., mpicxx) or add LIBS=-lstdc++.
>>>>> I thought we were doing this (linking C++ mains with CXX).
>>>> After compiling to the object file (ex3.o) we don't know what language
>>>> main was written in, and this doesn't solve the actual problem that C++
>>>> linking is required if any object (not just main) depends on C++.
>>> My thinking here was the following:
>>> 1) No C++ is allowed in PETSc, unless --with-clanguage=cxx, in which case
>>> the linker is C++
>>> 2) If C++ is in an external library, then that configure requires the C++
>>> library
>>> 3) The executable itself could be C++, in which case I proposed using the
>>> C++ linker explicitly
>>> About not knowing which objects come with C++ main: I thought we did. Don't
>>> they go into a separate set?
>> Right, we do have that information for tests. Note that a single test
>> executable can depend on multiple source files, and the one containing
>> main might not be C++ while another is. I don't know if there are any
>> such instances in PETSc.
>> I can change the build rules for tests with C++ sources later today.
> Jed, are you indicating that you will resolve the original problem I reported? Where will you resolve it? The problem may come up in one of my branches.
I was going to put it in a new branch from 'master'. There is
disgusting duplication in 'maint' that has since been fixed so I'd
rather not do it there.
Under what conditions is PCC_LINKER different from CC (or CXX when
clanguage=C++)? I need to find a C++ linker and would prefer to use
$(CXX) rather than adding a new configure test. I feel like the
generated petscvariables has an inordinate amount of duplication all
with non-standard names and no documentation.
The cheap way to fix your issue is to add LIBS=-lstdc++ to your
configure.
