[petsc-dev] need c++ expert help
Matthew Knepley
knepley at gmail.com
Sun Dec 31 13:53:58 CST 2017
On Sun, Dec 31, 2017 at 2:35 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Sun, Dec 31, 2017 at 1:55 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> These look like linker errors and that build uses
> >> --with-cxxlib-autodetect=0. We either need a rule to *link* C++ using
> >> CXX (i.e., mpicxx) or add LIBS=-lstdc++.
> > I thought we were doing this (linking C++ mains with CXX).
> After compiling to the object file (ex3.o) we don't know what language
> main was written in, and this doesn't solve the actual problem that C++
> linking is required if any object (not just main) depends on C++.
My thinking here was the following:
1) No C++ is allowed in PETSc, unless --with-clanguage=cxx, in which case
the linker is C++
2) If C++ is in an external library, then that configure requires the C++
library
3) The executable itself could be C++, in which case I proposed using the
C++ linker explicitly
About not knowing which objects come with C++ main: I thought we did. Don't
they go into a separate set?
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171231/2892d129/attachment.html>
