[petsc-dev] How to pass user data to a registered PC (PCRegister) ?
Franck Houssen
franck.houssen at inria.fr
Sun Dec 31 08:01:43 CST 2017
Using PCSHELL means calling:
- PCShellSetSetUp, PCShellSetApply, PCShellSetDestroy to set callbacks.
- PCShellSetContext/PCShellGetContext to get/set context in callbacks.
To go from PCSHELL to PCRegister, one need to:
- #include <petsc/private/pcimpl.h> // Access to PC data/struct.
- Set callbacks with pc->ops->...
- NO more use ANY shell methods (context, name), but, use pc->data instead.
- call PCRegister.
Correct ? Did I miss something ?
Seems I get things to work (without compose function).
The last problem I have is in the options: options are passed to PetscInitialize but not found in the database (I mimic'ed the jacobi example). Is there specific related to this ?
----- Mail original -----
> De: "Franck Houssen" <franck.houssen at inria.fr>
> À: "Barry F. Smith" <bsmith at mcs.anl.gov>
> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Envoyé: Samedi 30 Décembre 2017 17:12:09
> Objet: Re: [petsc-dev] How to pass user data to a registered PC (PCRegister) ?
> Don't get the link. I'll try first with independent function (no compose) and
> see if this can work at least for a start.
> Franck
> > De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> > À: "Franck Houssen" <franck.houssen at inria.fr>
> > Envoyé: Vendredi 29 Décembre 2017 17:55:30
> > (PCRegister) ?
> > > On Dec 29, 2017, at 9:03 AM, Franck Houssen <franck.houssen at inria.fr>
> > > wrote:
> > > OK, on the highway now (bad ssh !), I'll try to check this out.
> > >> Envoyé: Jeudi 28 Décembre 2017 18:21:48
> > >> (PCRegister) ?
> > >>> On Dec 28, 2017, at 10:34 AM, Franck Houssen <franck.houssen at inria.fr>
> > >>>> Envoyé: Jeudi 28 Décembre 2017 16:43:16
> > >>>> (PCRegister) ?
> > >>>> The register is for a new type of PC of which can have many
> > >>>> instantiations
> > >>>> at the same time.
> > >>> OK, I didn't get that that way ! I was looking for a way to plug "my"
> > >>> pc
> > >>> at
> > >>> the command line this way: -pc_type my_pc.
> > >>> I already call PCSetType(pc, PCSHELL) and PCShellSetName(pc, "my_pc"):
> > >>> maybe this already enables "-pc_type shell" or "-pc_type my_pc"... And
> > >>> I
> > >>> didn't know it ! :D I'll try that.
> > >>> I was looking for a way to integrate "my" (external) pc as any other
> > >>> regular/existing petsc pc (bjacobi, ...) like a kind of plugin but
> > >>> still
> > >>> integrated to the cmd line: I believed PCRegister was meant for that.
> > >> Indeed it is exactly what it is meant for. Please try to follow my
> > >> recipe
> > >> and let us know when you get stuck.
> > >>> Not sure if this is actually possible/enabled by the API.
> > >>>> For example
> > >>>> PCRegister("mypctype",mypc_create);
> > >>>> KSPCreate(&ksp1);
> > >>>> KSPCreate(&ksp2);
> > >>>> KSPGetPC(ksp1,&pc1);
> > >>>> KSPGetPC(ksp2,&pc2);
> > >>>> You don't want pc1 and pc2 to have the same dof multiplicities,
> > >>>> domain
> > >>>> intersections etc since they are associated with completely
> > >>>> different
> > >>>> linear systems and presumably meshes etc.
> > >>>> Presumably you want each of pc1, pc2, to have their own version of
> > >>>> the
> > >>>> data so you need to stick it directly in the PC, for example
> > >>>> PCMypcSetDOFMultiplicities(pc1,stuff);
> > >>>> PCMypcSetDOFMultiplicities(pc2,otherstuff);
> > > OK, I must provide/implement PCMypcSetDOFMultiplicities (add data to pc
> > > context) besides mypc_create: sounds logical.
> > > Is this OK if PCMypcSetDOFMultiplicities is independent from mypc_create
> > > I guess yes.
> > > From what I remember/understand, I got lost here: from the jacobi
> > > example,
> > > mypc_create looks to be supposed (?) to call some kind of
> > > Petsc*ComposeFunction to associate PCMypcSetDOFMultiplicities to the pc
> > > (correct ?)... But, in the jacobi example, PCJacobiGetUseAbs_Jacobi is
> > > associated to PCJacobiGetUseAbs_C...
> > the _C name is a string name that is used by PETSc to "find" the correct
> > function pointer which is PCJacobiGetUseAbs_Jacobi. There is no
> > _C function.
> > > Which turns out not to be implemented according to git grep ?! Got lost
> > > here (and looked for a way to pass user data directly to PCRegister): is
> > > PCMypcSetDOFMultiplicities supposed to be "attached/composed" or
> > > independent from the pc ?
> > composed.
> > >>> git grep PCJacobiGetUseAbs_C
> > > src/ksp/pc/impls/jacobi/jacobi.c: ierr =
> > > PetscObjectComposeFunction((PetscObject)pc,"PCJacobiGetUseAbs_C",PCJacobiGetUseAbs_Jacobi);CHKERRQ(ierr);
> > > PetscUseMethod(pc,"PCJacobiGetUseAbs_C",(PC,PetscBool*),(pc,flg));CHKERRQ(ierr);
> > > Sorry, for the short answer. Hope I succeeded to be clear enough.
> > Just copy jacobi.c and start converting it over to your names and needs
> > and you'll see it is actually really straightforward and not as
> > complicated as you think it is.
> > Barry
> > >>>> You write as many of these Set() functions as you need for your
> > >>>> PCtype.
> > >>>> You
> > >>>> store the data inside the PC_Mypc data structure you create with
> > >>>> mypc_create(). Look at PCCreate_Jacobi() and PCJacobiSetType for the
> > >>>> pattern.
> > >>>> Barry
> > >>>>> On Dec 28, 2017, at 9:34 AM, Franck Houssen <franck.houssen at inria.fr>
> > >>>>> At first, I expected the signature would be "PetscErrorCode
> > >>>>> PCRegister(const char sname[],PetscErrorCode (*function)(PC, void
> > >>>>> but
> > >>>>> it turns out to be "PetscErrorCode PCRegister(const char
> > >>>>> sname[],PetscErrorCode (*function)(PC))"
> > >>>>> I try to integrate a PC that needs A but also other informations (dof
> > >>>>> multiplicities, domain intersections that the user must provide). I
> > >>>>> guess
> > >>>>> I can get A with PCGetOperators in the setup callback of the PC. But
> > >>>>> still
> > >>>>> not sure how to pass the other informations if I get to use
> > >>>>> PCRegister.
> > >>>>> I
> > >>>>> looked a few examples in the bitbucket (jacobi:
> > >>>>> src/ksp/ksp/examples/tutorials/ex12.c and
> > >>>>> + SOR: src/ksp/pc/impls/sor/sor.c)... But didn't get any real
> > >>>>> relevant
> > >>>>> answer and feel a bit lost among the numerous pc !...
> > >>>>> The idea is: for now I use PCSetType(pc, PCSHELL) and
> > >>>>> PCShellSetContext
> > >>>>> with a context who knows the extra needed informations which is "not
> > >>>>> so
> > >>>>> handy" (that's OK as for now I am both the user and the PC provider).
> > >>>>> I'd
> > >>>>> like to package this in a more convenient way (a unique and "simple"
> > >>>>> call
> > >>>>> to PCRegister) to decouple the user from the PC machinery.
> > >>>>> Franck
