[petsc-dev] IMPORTANT nightly builds are down do not add to next
Jeff Hammond jeff.science at gmail.com
Sat Dec 30 22:57:42 CST 2017
On Sat, Dec 30, 2017 at 3:34 PM Jed Brown <jed at jedbrown.org> wrote:
> Jeff Hammond <jeff.science at gmail.com> writes:
> > On Sat, Dec 30, 2017 at 12:04 PM Jed Brown <jed at jedbrown.org> wrote:
> >> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >> >> On Dec 30, 2017, at 3:53 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> >> On Fri, Dec 29, 2017 at 5:35 PM, Smith, Barry F. <bsmith at mcs.anl.gov
> >> wrote:
> >> >> > On Dec 29, 2017, at 3:52 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> >> > On Fri, Dec 29, 2017 at 2:11 PM, Smith, Barry F. <
> >> wrote:
> >> >> >    The nightly builds are down (out-dated data at the website) and
> >> Satish is in India and cannot fix it.
> >> >> >     Please do not put anything into next until you are notified
> that
> >> the nightly tests are working again.
> >> >> > Cool.
> >> >> > This should tell us that we need to make more of an effort to
> >> automate this part, and employ failsafe measures.
> >> >>   Indeed. Note that this is largely just bad timing, this happens
> very
> >> rarely and it is just bad luck Satish is out.
> >> >> I agree completely. However, right now we are all too indispensible.
> We
> >> usually focus on transmitting developer knowledge,
> >> >> but I think we need more focus on transmitting process knowledge.
> Could
> >> another group of people pick up and run
> >> >> the maintenance process for PETSc?
> >> >    No because they would use jenkins or some similar worthless shit;
> >> >    we need to keep control of the processes but need more more help in
> >> >    running the processes.
> >> It shouldn't be this labor-intensive.  As I understand it, we could use
> >> free hosted CI except for proprietary compilers/unsupported
> >> environments.  Most of those CI systems want to sell their products with
> >> enterprise pricing for custom environments, but I think it's supposed to
> >> be easy to use the gitlab-ci runner on a custom machine.
> > You can use ICC and PGI in Travis CI, which is free if you use Github
> with
> > a public repo. ICC requires a friend at Intel to help with license
> issues.
> > PGI has community edition you should be able to use. Travis CI doesn’t
> > support Bitbucket but I recall you mirror Petsc there. Examples of both
> are
> > easily found with an obvious google search.
> Good to know.
> > Travis CI is great for covering generic Mac/Homebrew and Ubuntu
> platforms.
> > You can get almost all compiler versions and MPI libraries in both, with
> > reasonable effort.
> > I can do an initial implementation if you aren’t inclined to do it
> > yourselves.
> Lisandro set up Travis-CI last year, though we aren't currently doing
> pull requests there.
> https://travis-ci.org/petsc/petsc/branches
> Our "weird" configurations are OpenSolaris, FreeBSD, and MS Windows.  I
> see some murmurs online about running QEMU inside Travis-CI, but it
> isn't supported.  It's perhaps a bit hokey, but a Travis-CI build could
> launch an EC2 Windows instance (or connect to a Windows machine at
> Argonne) and stream the results back.
Travis CI can be run locally. It’s just a Yaml (?) script generator or
something like that. They document it. I’ve considered trying to cron it at
NERSC but am not sufficiently motivated. From the local setup, you can
potentially do almost anything.
Jeff
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171231/d548677a/attachment.html>
