[petsc-dev] & or &&?
Pierre Jolivet
pierre.jolivet at enseeiht.fr
Sat Dec 23 08:23:11 CST 2017
Hello,
Are you sure that a bitwise AND is the right operator here https://bitbucket.org/petsc/petsc/src/d209cd380f7aba331915877696c8ffe10e8df5ea/src/vec/vec/utils/vpscat.h?at=master&fileviewer=file-view-default#vpscat.h-66 <https://bitbucket.org/petsc/petsc/src/d209cd380f7aba331915877696c8ffe10e8df5ea/src/vec/vec/utils/vpscat.h?at=master&fileviewer=file-view-default#vpscat.h-66> and there https://bitbucket.org/petsc/petsc/src/d209cd380f7aba331915877696c8ffe10e8df5ea/src/vec/vec/utils/vpscat_mpi1.h?at=master&fileviewer=file-view-default#vpscat_mpi1.h-66 <https://bitbucket.org/petsc/petsc/src/d209cd380f7aba331915877696c8ffe10e8df5ea/src/vec/vec/utils/vpscat_mpi1.h?at=master&fileviewer=file-view-default#vpscat_mpi1.h-66> ?
Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171223/4845351d/attachment.html>
