[petsc-dev] [SPAM?] Re: [SPAM *****] Re: Issue with Lapack names
Karl Rupp
rupp at iue.tuwien.ac.at
Mon Dec 18 15:34:09 CST 2017
> > > This is related to a message I sent 2 years ago to petsc-maint
> "Inconsistent naming of one Lapack subroutine", where I advocated
> renaming LAPACKungqr_ --> LAPACKorgqr_. But that thread did not end
> up in any modification...
> > > I can't find the thread. I also do not understand the problem.
> Are you saying that the check succeeds but the routines is still
> missing?
> > No, the opposite. The routines are there, but since configure
> decided (wrongly) that they are missing, the check would fail at run
> time complaining that the routines are missing.
> > Ah. Why does the check fail? It does succeed for a number of them.
> I don't know the exact reason, but it has to do with the names of
> real/complex subroutines. I guess the test is checking for dungqr,
> which does not exist - it should check for either dorgqr or zungqr.
> Before that commit, there were only checks for "real" names, but
> after the commit there are a mix of real and complex subroutines.
> Now I really want to punch one of the LAPACK guys in the face. Which one...
> Karl, I think it is enough right now to change the complex names, like
> ungqr to orgqr as Jose suggests. Will this work for you?
works for me, yes.
If possible, I'd like to preserve the auto-generated nature of this
list. If 'dungqr' is the only exception, then please adjust the list of
tests accordingly *and* add a comment to BlasLapack.py saying why
'dungqr' is special.
Best regards,
Karli
> > Thanks,
> > Matt
> > Jose
> > > Thanks,
> > > Matt
> > > Jose
> > > What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any results to
> which their experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> <https://www.cse.buffalo.edu/~knepley/>
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
