[petsc-dev] Golub-Kahan bidiagonalization
Karin&NiKo
niko.karin at gmail.com
Mon Dec 18 06:42:35 CST 2017
Dear PETSc team,
I would like to implement and possibly commit to PETSc the Golub-Kahan
bidiagonalization algorithm (GK) describe in Arioli's paper :
http://epubs.siam.org/doi/pdf/10.1137/120866543.
In this work, Mario Arioli uses GK to solve saddle point problems, of the
form A=[A00, A01; A10, A11]. There is an outer-loop which treats the
constraints and an inner-loop, with its own KSP, to solve the linear
systems with A00 as operator. We have evaluated this algorithm on different
problems and have found that it exhibits very nice convergence of the
outer-loop (independant of the problem size).
In order to developp a source that could be commited to PETSc, I would like
to have your opinion on how to implement it. Since the algorithm treats
saddle point problems, it seems to me that it should be implemented in the
fieldsplit framework. Should we add for instance a new -pc_fieldsplit_type,
say gk? Have you other ideas?
I look forward to hearing your opinion on the best design for implementing
this algorithm in PETSc.
Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171218/080c0629/attachment.html>
