[petsc-dev] MatIS export
Franck Houssen
franck.houssen at inria.fr
Mon Dec 11 10:39:40 CST 2017
Reporting a small bug related to MatIS export (or is this not meant to be supported ?).
Franck
>> rm -f matExport.log matExport.mat matExport.bin; mpirun -n 2 ./matExport.exe is ; more matExport.log matExport.mat matExport.bin
mat type is is
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[1]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> rm -f matExport.log matExport.mat matExport.bin; mpirun -n 2 ./matExport.exe mpiaij ; more matExport.log matExport.mat matExport.bin
mat type is mpiaij
matExport.log
Mat Object: 2 MPI processes
type: mpiaij
row 0: (0, 2.)
row 1: (1, 4.)
row 2: (2, 6.)
row 3: (3, 8.)
row 4: (4, 10.)
row 5: (5, 12.)
row 6: (6, 14.)
row 7: (7, 16.)
row 8: (8, 18.)
row 9: (9, 20.)
matExport.mat
%Mat Object: 2 MPI processes
% type: mpiaij
% Size = 10 10
% Nonzeros = 10
zzz = zeros(10,3);
zzz = [
1 1 2.0000000000000000e+00
2 2 4.0000000000000000e+00
3 3 6.0000000000000000e+00
4 4 8.0000000000000000e+00
5 5 1.0000000000000000e+01
6 6 1.2000000000000000e+01
7 7 1.4000000000000000e+01
8 8 1.6000000000000000e+01
9 9 1.8000000000000000e+01
10 10 2.0000000000000000e+01
Mat_0x557ffe276ba0_0 = spconvert(zzz);
matExport.bin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171211/1e084daa/attachment.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171211/1e084daa/attachment.bin>
