[petsc-dev] more next-tmp
    Satish Balay
    balay at mcs.anl.gov
    Tue Dec  5 21:12:14 CST 2017
PETSc developers,
I'm switching the nightlybuilds to next-tmp to test fewer branches
that are likely to produce clean builds. [next hasn't been clean for
some time]
Tonights builds are with the following branches:
$ git fetch -p && comm -12 <(git branch -r --merged origin/next-tmp | sort) <(git branch -r --no-merged origin/master | sort) |grep -v ' origin/next-tmp'
  origin/barry/fix-matcreatenest-lawrencemitchell
  origin/hongzh/remove-bitarray-ell
  origin/jed/pc-composite-nozero
  origin/pr803/acroucher/acroucher/fix-IS-global-to-local-mapping-block/master
  origin/rmills/fix-mpisell-matconvert
  origin/stefano_zampini/example-bddc-3levels
  origin/stefano_zampini/optimize-tsadjointstep-rk
Current outstanding branches in next:
2017-11-20T11:22:53+13:00	  origin/pr803/acroucher/acroucher/fix-IS-global-to-local-mapping-block/master
2017-11-20T21:03:04-07:00	  origin/jed/pc-composite-nozero
2017-11-23T08:10:36-08:00	  origin/barry/fix-matcreatenest-lawrencemitchell
2017-11-25T05:28:01-08:00	  origin/barry/pccomposite-only-propagate-if-not-set
2017-11-26T18:53:44+03:00	  origin/stefano_zampini/example-bddc-3levels
2017-11-29T14:09:27-05:00	  origin/knepley/fix-l2-projection-submesh
2017-11-30T14:56:41-05:00	  origin/knepley/fix-plex-proj-ds
2017-11-30T17:43:06-08:00	  origin/hongzh/remove-bitarray-ell
2017-11-30T19:56:29-06:00	  origin/barry/fix-kspcgls
2017-12-01T11:53:29-05:00	  origin/knepley/fix-plex-multifield-eval
2017-12-02T11:53:52-06:00	  origin/barry/vec-to-test-harness
2017-12-04T08:37:31-05:00	  origin/knepley/feature-adaptor-plex
2017-12-04T10:58:39-05:00	  origin/knepley/fix-plex-fvm-adjacency
2017-12-05T14:53:20-06:00	  origin/barry/ssisc-spectral-adjoint
2017-12-05T15:24:40-06:00	  origin/barry/move-to-new-test-harness
2017-12-05T16:46:12-06:00	  origin/hzhang/fix-Matdup_ptap/maint
2017-12-05T17:44:29+03:00	  origin/rmills/fix-mpisell-matconvert
2017-12-05T19:40:29-05:00	  origin/knepley/fix-plex-spectral-incomplete
Satish
