[petsc-dev] problem in PETSc.pc file
Jed Brown
jed at jedbrown.org
Sat Aug 26 10:44:43 CDT 2017
Stefano Zampini <stefano.zampini at gmail.com> writes:
> configure log is attached
I'm afraid I don't have any answers. I added this
diff --git i/config/PETSc/Configure.py w/config/PETSc/Configure.py
index 9d1072caef..a19fb98fc7 100644
--- i/config/PETSc/Configure.py
+++ w/config/PETSc/Configure.py
@@ -199,6 +199,7 @@ class Configure(config.base.Configure):
# pkg-config --variable=ldflag_rpath and pkg-config --libs-only-L
lflags = self.packagelibs+self.libraries.math+self.compilers.flibs+self.compilers.cxxlibs+self.compilers.LIBS.split()
fd.write('Libs.private: '+self.libraries.toStringNoDupes([f for f in lflags if not f.startswith(self.setCompilers.CSharedLinkerFlag)], with_rpath=False)+'\n')
+ import ipdb; ipdb.set_trace()
fd.close()
return
then ran configure and substituted in your library list (taken from
PETSC_EXTERNAL_LIB_BASIC in your configure.log).
ipdb> zlflags = ['-Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib', '-L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib', '-Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64', '-L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64', '-L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/', '-L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/', '-lcmumps', '-ldmumps', '-lsmumps', '-lzmumps', '-lmumps_common', '-lpord', '-lscalapack', '-lumfpack', '-lklu', '-lcholmod', '-lbtf', '-lccolamd', '-lcolamd', '-lcamd', '-lamd', '-lsuitesparseconfig', '-lHYPRE', '-lmkl_intel_lp64', '-lmkl_core', '-lmkl_sequential', '-lmkl_core', '-lmkl_sequential', '-lmkl_core', '-lparmetis', '-lmetis', '-lptesmumps', '-lptscotch', '-lptscotcherr', '-lscotch', '-lscotcherr', '-lrt', '-lm', '-lpthread', '-lz', '-ldl', '-lmkl_core', '-lmkl_sequential', '-lmkl_core', '-lmkl_sequential', '-lmkl_core', '-lirc', '-liomp5', '-lsvml', '-limf', '-lifcore', '-lirng', '-lifport', '-lirc', '-ldl']
ipdb> print self.libraries.toStringNoDupes([f for f in zlflags if not f.startswith(self.setCompilers.CSharedLinkerFlag)], with_rpath=False)
-L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lHYPRE -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -lparmetis -lmetis -lptesmumps -lptscotch -lptscotcherr -lscotch -lscotcherr -lrt -lm -lpthread -lz -ldl -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
This is the ordering that you say works. Are you sure you're looking at
the PETSc.pc produced by the same configure? Can you add a debugging
statement in this Python to try to figure out why you're producing
something different using the same code?
> 2017-08-26 17:30 GMT+03:00 Jed Brown <jed at jedbrown.org>:
>> Stefano, can you send configure.log? This is the relevant code for
>> defining PETSC_EXTERNAL_LIB_BASIC.
>> self.packagelibs = libs
>> self.PETSC_EXTERNAL_LIB_BASIC = self.libraries.
>> toStringNoDupes(libs+self.libraries.math+self.compilers.
>> flibs+self.compilers.cxxlibs+self.compilers.LIBS.split())
>> if self.framework.argDB['prefix'] and self.setCompilers.CSharedLinkerFlag
>> not in ['-L']:
>> lib_basic = self.PETSC_EXTERNAL_LIB_BASIC.replace(self.setCompilers.
>> CSharedLinkerFlag+os.path.join(self.petscdir.dir,self.
>> arch.arch,'lib'),self.setCompilers.CSharedLinkerFlag+os.path.
>> join(self.installdir.dir,'lib'))
>> else:
>> self.addMakeMacro('PETSC_EXTERNAL_LIB_BASIC',lib_basic)
>> This is run subsequently to write PETSc.pc Libs.private:
>> So the difference is that the latter removes rpath-related flags, but
>> there shouldn't be other differences.
>> > I have recently noticed a regression with using Libs.private of PETSc.pc
>> > (used by MFEM configure). For some reason, the mumps and mkl linking
>> lines
>> > are scrambled up. At the bottom of the message you can see the undefined
>> > references I'm getting, coming from having libdmumps before libscalapack,
>> > and libmkl_intel_lp64 before libdmumps and libcholmod. This configuration
>> > (static build with gnu compilers and MKL on a Cray XC40.... yes, I know,
>> > life could be easier....) was working before, but I cannot say when got
>> > broken.
>> > This is the line in PETSc.pc that corresponds to Libs.private and that
>> > makes the executable linking to fail.
>> > -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lcmumps
>> -lscalapack
>> > -lumfpack -lHYPRE -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64
>> > -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lparmetis -lmetis
>> > -lptesmumps
>> > -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -ldmumps
>> -lsmumps
>> > -lzmumps -lmumps_common -lpord -lklu -lcholmod -lbtf -lccolamd -lcolamd
>> > -lcamd -lamd -lsuitesparseconfig -lptscotch -lptscotcherr -lscotch
>> -lifcore
>> > Instead, this is PETSC_EXTERNAL_LIB_BASIC from petscvariables, that leads
>> > (with the current master) to a successful linking
>> -ldmumps
>> -lHYPRE
>> -lscotch
>> -lifcore
>> > /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/
>> libdmumps.a(dana_driver.o):
>> > In function `dmumps_ana_driver_':
>> externalpackages/git.mumps/src/dana_driver.F:1944:
>> > undefined reference to `numroc_'
>> externalpackages/git.mumps/src/dana_driver.F:1948:
>> libdmumps.a(dfac_driver.o):
>> > In function `dmumps_fac_driver_':
>> externalpackages/git.mumps/src/dfac_driver.F:1605:
>> externalpackages/git.mumps/src/dfac_driver.F:1609:
>> libdmumps.a(dend_driver.o):
>> > In function `dmumps_end_driver_':
>> externalpackages/git.mumps/src/dend_driver.F:44:
>> > undefined reference to `blacs_gridexit_'
>> libdmumps.a(dana_aux_ELT.o):
>> > In function `dmumps_ana_f_elt_':
>> externalpackages/git.mumps/src/dana_aux_ELT.F:257:
>> > undefined reference to `metis_setdefaultoptions_'
>> libdmumps.a(dana_aux.o):
>> > In function `dmumps_ana_f_':
>> externalpackages/git.mumps/src/dana_aux.F:564:
>> libdmumps.a(darrowheads.o):
>> > In function `dmumps_facto_send_arrowheads_':
>> externalpackages/git.mumps/src/darrowheads.F:254:
>> externalpackages/git.mumps/src/darrowheads.F:257:
>> > In function `dmumps_facto_recv_arrowhd2_':
>> externalpackages/git.mumps/src/darrowheads.F:688:
>> externalpackages/git.mumps/src/darrowheads.F:691:
>> libdmumps.a(dfac_distrib_distentry.o):
>> > In function `dmumps_redistribution_':
>> externalpackages/git.mumps/src/dfac_distrib_distentry.F:264:
>> libdmumps.a(dfac_distrib_distentry.o):/home/zampins/
>> src/petsc/haswell_debug_gnu_mkl/externalpackages/git.
>> mumps/src/dfac_distrib_distentry.F:267:
>> > more undefined references to `numroc_' follow
>> > /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dsol_root_
>> parallel.o):
>> > In function `dmumps_solve_2d_bcyclic_':
>> externalpackages/git.mumps/src/dsol_root_parallel.F:76:
>> > undefined reference to `descinit_'
>> externalpackages/git.mumps/src/dsol_root_parallel.F:84:
>> > undefined reference to `pdgetrs_'
>> externalpackages/git.mumps/src/dsol_root_parallel.F:87:
>> externalpackages/git.mumps/src/dsol_root_parallel.F:91:
>> > undefined reference to `pdpotrs_'
>> parallel.o):
>> > In function `dmumps_root_solve_':
>> externalpackages/git.mumps/src/dsol_root_parallel.F:33:
>> > undefined reference to `blacs_gridinfo_'
>> externalpackages/git.mumps/src/dsol_root_parallel.F:34:
>> libdmumps.a(dtype3_root.o):
>> > In function `dmumps_root_alloc_static_':
>> externalpackages/git.mumps/src/dtype3_root.F:1085:
>> externalpackages/git.mumps/src/dtype3_root.F:1088:
>> externalpackages/git.mumps/src/dtype3_root.F:1091:
>> > In function `dmumps_init_root_ana_':
>> externalpackages/git.mumps/src/dtype3_root.F:783:
>> externalpackages/git.mumps/src/dtype3_root.F:788:
>> > undefined reference to `blacs_gridinit_'
>> externalpackages/git.mumps/src/dtype3_root.F:792:
>> libdmumps.a(dfac_par_m.o):
>> > In function `__dmumps_fac_par_m_MOD_dmumps_fac_par':
>> externalpackages/git.mumps/src/dfac_par_m.F:744:
>> > /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_root_
>> parallel.o):
>> > In function `dmumps_facto_root_':
>> externalpackages/git.mumps/src/dfac_root_parallel.F:77:
>> externalpackages/git.mumps/src/dfac_root_parallel.F:100:
>> > undefined reference to `pdgetrf_'
>> externalpackages/git.mumps/src/dfac_root_parallel.F:107:
>> > undefined reference to `pdpotrf_'
>> externalpackages/git.mumps/src/dfac_root_parallel.F:155:
>> libdmumps.a(dmumps_iXamax.o):
>> > In function `dmumps_ixamax_':
>> externalpackages/git.mumps/src/dmumps_iXamax.F:17:
>> > undefined reference to `idamax_'
>> libdmumps.a(dfac_lr.o):
>> > In function `__dmumps_fac_lr_MOD_dmumps_compress_panel':
>> externalpackages/git.mumps/src/dfac_lr.F:873:
>> > undefined reference to `dormqr_'
>> > /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dlr_core_
>> subroutine.o):
>> > In function `dmumps_truncated_rrqr_':
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:69:
>> > undefined reference to `ilaenv_'
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:78:
>> > undefined reference to `dnrm2_'
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:83:
>> > undefined reference to `dlamch_'
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:92:
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:121:
>> > undefined reference to `dlarfg_'
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:123:
>> externalpackages/git.mumps/src/dlr_core_subroutine.F:189:
>> > /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmumps_common.a(ana_
>> orderings_wrappers_m.o):
>> > In function `__mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto64':
>> externalpackages/git.mumps/src/ana_orderings_wrappers_m.F:225:
>> > undefined reference to `metis_nodend_'
>> externalpackages/git.mumps/src/ana_orderings_wrappers_m.F:246:
>> > In function `__mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32':
>> externalpackages/git.mumps/src/ana_orderings_wrappers_m.F:115:
>> libmumps_common.a(mumps_metis.o):
>> > In function `mumps_parmetis_':
>> externalpackages/git.mumps/src/mumps_metis.c:43:
>> > undefined reference to `ParMETIS_V3_NodeND'
>> libmumps_common.a(mumps_scotch.o):
>> > In function `mumps_scotch_':
>> externalpackages/git.mumps/src/mumps_scotch.c:31:
>> > undefined reference to `esmumps'
>> libmumps_common.a(mumps_scotch64.o):
>> > In function `mumps_scotch_64_':
>> externalpackages/git.mumps/src/mumps_scotch64.c:30:
>> libcholmod.a(cholmod_super_numeric.o):
>> > In function `c_cholmod_super_numeric':
>> externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_
>> cholmod_super_numeric.c:692:
>> > undefined reference to `zherk_'
>> cholmod_super_numeric.c:722:
>> > undefined reference to `zgemm_'
>> cholmod_super_numeric.c:872:
>> > undefined reference to `zpotrf_'
>> cholmod_super_numeric.c:1007:
>> > undefined reference to `ztrsm_'
>> > In function `z_cholmod_super_numeric':
>> libcholmod.a(cholmod_super_solve.o):
>> > In function `c_cholmod_super_lsolve':
>> cholmod_super_solve.c:110:
>> > undefined reference to `ztrsv_'
>> cholmod_super_solve.c:116:
>> > undefined reference to `zgemv_'
>> cholmod_super_solve.c:189:
>> cholmod_super_solve.c:198:
>> > In function `c_cholmod_super_ltsolve':
>> cholmod_super_solve.c:318:
>> cholmod_super_solve.c:328:
>> cholmod_super_solve.c:393:
>> cholmod_super_solve.c:404:
>> > Stefano
> Stefano
> Pushing language C
> Popping language C
> Pushing language CUDA
> Popping language CUDA
> Pushing language Cxx
> Popping language Cxx
> Pushing language FC
> Popping language FC
> Starting Configure Run at Mon Aug 21 14:31:37 2017
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --CFLAGS="-g -O0 " --CXXFLAGS="-g -O0 " --FFLAGS="-g -O0 " --LIBS="-L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl" --PETSC_ARCH=haswell_debug_gnu_mkl --download-hypre=1 --download-metis=1 --download-mumps=1 --download-parmetis=1 --download-ptscotch=1 --download-scalapack --download-suitesparse=1 --known-bits-per-byte=8 --known-has-attribute-aligned=1 --known-level1-dcache-assoc=8 --known-level1-dcache-linesize=64 --known-level1-dcache-size=32768 --known-memcmp-ok=1 --known-mpi-c-double-complex=1 --known-mpi-int64_t=1 --known-mpi-long-double=1 --known-mpi-shared-libraries=0 --known-sdot-returns-double=0 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1 --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4 --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2 --known-sizeof-size_t=8 --known-sizeof-void-p=8 --known-snrm2-returns-double=0 --with-ar=ar --with-batch=1 --with-blaslapack-lib="[/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a]" --with-cc=/opt/cray/craype/2.4.2/bin/cc --with-clib-autodetect=0 --with-cxx=/opt/cray/craype/2.4.2/bin/CC --with-cxxlib-autodetect=0 --with-debugging=1 --with-dependencies=0 --with-etags=0 --with-fc=/opt/cray/craype/2.4.2/bin/ftn --with-fortran-datatypes=0 --with-fortran-interfaces=0 --with-fortranlib-autodetect=0 --with-mkl_pardiso-include=/opt/intel/composer_xe_2015.1.133/mkl/include --with-mkl_pardiso-lib="[/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a]" --with-pthread=0 --with-ranlib=ranlib --with-scalar-type=real --with-shared-ld=ar
> Working directory: /home/zampins/src/petsc
> Machine platform:
> ('Linux', 'cdl2', '3.0.101-0.47.102-default', '#1 SMP Tue Jun 6 10:51:55 UTC 2017 (ca3a20f)', 'x86_64', 'x86_64')
> Python version:
> 2.7.9 |Anaconda 2.2.0 (64-bit)| (default, Apr 14 2015, 12:54:25)
> [GCC 4.4.7 20120313 (Red Hat 4.4.7-1)]
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> TEST configureExternalPackagesDir from config.framework(/home/zampins/src/petsc/config/BuildSystem/config/framework.py:841)
> TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:841)
> TEST configureDebuggers from config.utilities.debuggers(/home/zampins/src/petsc/config/BuildSystem/config/utilities/debuggers.py:22)
> TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
> Find a default debugger and determine its arguments
> Checking for program /home/zampins/local/fenics-tools/bin/gdb...not found
> Checking for program /home/zampins/local/bin/gdb...not found
> Checking for program /home/zampins/local/anaconda/bin/gdb...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/gdb...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/gdb...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/gdb...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/gdb...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/gdb...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/gdb...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/gdb...not found
> Checking for program /opt/gcc/5.1.0/bin/gdb...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/gdb...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/gdb...not found
> Checking for program /opt/slurm/default/bin/gdb...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/gdb...not found
> Checking for program /opt/cray/craype/2.4.2/bin/gdb...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/gdb...not found
> Checking for program /opt/modules/3.2.10.5/bin/gdb...not found
> Checking for program /home/zampins/bin/gdb...not found
> Checking for program /usr/local/bin/gdb...not found
> Checking for program /usr/bin/gdb...found
> Defined make macro "GDB" to "/usr/bin/gdb"
> Checking for program /home/zampins/local/fenics-tools/bin/dbx...not found
> Checking for program /home/zampins/local/bin/dbx...not found
> Checking for program /home/zampins/local/anaconda/bin/dbx...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/dbx...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/dbx...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/dbx...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/dbx...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/dbx...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/dbx...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/dbx...not found
> Checking for program /opt/gcc/5.1.0/bin/dbx...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/dbx...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/dbx...not found
> Checking for program /opt/slurm/default/bin/dbx...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/dbx...not found
> Checking for program /opt/cray/craype/2.4.2/bin/dbx...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/dbx...not found
> Checking for program /opt/modules/3.2.10.5/bin/dbx...not found
> Checking for program /home/zampins/bin/dbx...not found
> Checking for program /usr/local/bin/dbx...not found
> Checking for program /usr/bin/dbx...not found
> Checking for program /bin/dbx...not found
> Checking for program /usr/bin/X11/dbx...not found
> Checking for program /usr/X11R6/bin/dbx...not found
> Checking for program /usr/games/dbx...not found
> Checking for program /sbin/dbx...not found
> Checking for program /usr/sbin/dbx...not found
> Checking for program /usr/lib/mit/bin/dbx...not found
> Checking for program /usr/lib/mit/sbin/dbx...not found
> Checking for program ./dbx...not found
> Checking for program /usr/lib/qt3/bin/dbx...not found
> Checking for program /opt/cray/bin/dbx...not found
> Checking for program /home/zampins/dbx...not found
> Checking for program /home/zampins/local/fenics-tools/bin/xdb...not found
> Checking for program /home/zampins/local/bin/xdb...not found
> Checking for program /home/zampins/local/anaconda/bin/xdb...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/xdb...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/xdb...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/xdb...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/xdb...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/xdb...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/xdb...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/xdb...not found
> Checking for program /opt/gcc/5.1.0/bin/xdb...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/xdb...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/xdb...not found
> Checking for program /opt/slurm/default/bin/xdb...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/xdb...not found
> Checking for program /opt/cray/craype/2.4.2/bin/xdb...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/xdb...not found
> Checking for program /opt/modules/3.2.10.5/bin/xdb...not found
> Checking for program /home/zampins/bin/xdb...not found
> Checking for program /usr/local/bin/xdb...not found
> Checking for program /usr/bin/xdb...not found
> Checking for program /bin/xdb...not found
> Checking for program /usr/bin/X11/xdb...not found
> Checking for program /usr/X11R6/bin/xdb...not found
> Checking for program /usr/games/xdb...not found
> Checking for program /sbin/xdb...not found
> Checking for program /usr/sbin/xdb...not found
> Checking for program /usr/lib/mit/bin/xdb...not found
> Checking for program /usr/lib/mit/sbin/xdb...not found
> Checking for program ./xdb...not found
> Checking for program /usr/lib/qt3/bin/xdb...not found
> Checking for program /opt/cray/bin/xdb...not found
> Checking for program /home/zampins/xdb...not found
> Checking for program /home/zampins/local/fenics-tools/bin/dsymutil...not found
> Checking for program /home/zampins/local/bin/dsymutil...not found
> Checking for program /home/zampins/local/anaconda/bin/dsymutil...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/dsymutil...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/dsymutil...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/dsymutil...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/dsymutil...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/dsymutil...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/dsymutil...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/dsymutil...not found
> Checking for program /opt/gcc/5.1.0/bin/dsymutil...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/dsymutil...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/dsymutil...not found
> Checking for program /opt/slurm/default/bin/dsymutil...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/dsymutil...not found
> Checking for program /opt/cray/craype/2.4.2/bin/dsymutil...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/dsymutil...not found
> Checking for program /opt/modules/3.2.10.5/bin/dsymutil...not found
> Checking for program /home/zampins/bin/dsymutil...not found
> Checking for program /usr/local/bin/dsymutil...not found
> Checking for program /usr/bin/dsymutil...not found
> Checking for program /bin/dsymutil...not found
> Checking for program /usr/bin/X11/dsymutil...not found
> Checking for program /usr/X11R6/bin/dsymutil...not found
> Checking for program /usr/games/dsymutil...not found
> Checking for program /sbin/dsymutil...not found
> Checking for program /usr/sbin/dsymutil...not found
> Checking for program /usr/lib/mit/bin/dsymutil...not found
> Checking for program /usr/lib/mit/sbin/dsymutil...not found
> Checking for program ./dsymutil...not found
> Checking for program /usr/lib/qt3/bin/dsymutil...not found
> Checking for program /opt/cray/bin/dsymutil...not found
> Checking for program /home/zampins/dsymutil...not found
> Defined make macro "DSYMUTIL" to "true"
> Defined "USE_GDB_DEBUGGER" to "1"
> TEST configureGit from config.sourceControl(/home/zampins/src/petsc/config/BuildSystem/config/sourceControl.py:24)
> TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
> Find the Git executable
> Checking for program /home/zampins/local/fenics-tools/bin/git...not found
> Checking for program /home/zampins/local/bin/git...not found
> Checking for program /home/zampins/local/anaconda/bin/git...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/git...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/git...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/git...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/git...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/git...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/git...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/git...not found
> Checking for program /opt/gcc/5.1.0/bin/git...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/git...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/git...not found
> Checking for program /opt/slurm/default/bin/git...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/git...not found
> Checking for program /opt/cray/craype/2.4.2/bin/git...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/git...not found
> Checking for program /opt/modules/3.2.10.5/bin/git...not found
> Checking for program /home/zampins/bin/git...not found
> Checking for program /usr/local/bin/git...not found
> Checking for program /usr/bin/git...found
> Defined make macro "GIT" to "git"
> Executing: git --version
> stdout: git version 1.7.12.4
> TEST configureMercurial from config.sourceControl(/home/zampins/src/petsc/config/BuildSystem/config/sourceControl.py:35)
> TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
> Find the Mercurial executable
> Checking for program /home/zampins/local/fenics-tools/bin/hg...not found
> Checking for program /home/zampins/local/bin/hg...not found
> Checking for program /home/zampins/local/anaconda/bin/hg...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/hg...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/hg...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/hg...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/hg...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/hg...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/hg...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/hg...not found
> Checking for program /opt/gcc/5.1.0/bin/hg...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/hg...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/hg...not found
> Checking for program /opt/slurm/default/bin/hg...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/hg...not found
> Checking for program /opt/cray/craype/2.4.2/bin/hg...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/hg...not found
> Checking for program /opt/modules/3.2.10.5/bin/hg...not found
> Checking for program /home/zampins/bin/hg...not found
> Checking for program /usr/local/bin/hg...not found
> Checking for program /usr/bin/hg...found
> Defined make macro "HG" to "hg"
> Executing: hg version -q
> stdout: Mercurial Distributed SCM (version 2.3.2)
> TEST configureCLanguage from PETSc.options.languages(/home/zampins/src/petsc/config/PETSc/options/languages.py:27)
> TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
> Choose whether to compile the PETSc library using a C or C++ compiler
> C language is C
> Defined "CLANGUAGE_C" to "1"
> TEST configureDirectories from PETSc.options.petscdir(/home/zampins/src/petsc/config/PETSc/options/petscdir.py:23)
> TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
> Checks PETSC_DIR and sets if not set
> Version Information:
> #define PETSC_VERSION_RELEASE 0
> #define PETSC_VERSION_MAJOR 3
> #define PETSC_VERSION_MINOR 7
> #define PETSC_VERSION_SUBMINOR 6
> #define PETSC_VERSION_PATCH 0
> #define PETSC_VERSION_DATE "unknown"
> #define PETSC_VERSION_GIT "unknown"
> #define PETSC_VERSION_DATE_GIT "unknown"
> #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_ PETSC_VERSION_EQ
> #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
> #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
> Defined make macro "DIR" to "/home/zampins/src/petsc"
> TEST getDatafilespath from PETSc.options.dataFilesPath(/home/zampins/src/petsc/config/PETSc/options/dataFilesPath.py:29)
> TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
> Checks what DATAFILESPATH should be
> TEST configureInstallationMethod from PETSc.options.petscclone(/home/zampins/src/petsc/config/PETSc/options/petscclone.py:20)
> TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
> bin/maint exists. This appears to be a repository clone
> .git directory exists
> Executing: cd /home/zampins/src/petsc && git describe --match "v*"
> stdout: v3.7.6-4967-gb31f67c
> Executing: cd /home/zampins/src/petsc && git log -1 --pretty=format:%H
> stdout: b31f67cfb4c7be76d31008842d469cfb00db9b2c
> Executing: cd /home/zampins/src/petsc && git log -1 --pretty=format:%ci
> stdout: 2017-08-19 14:20:51 -0700
> Executing: cd /home/zampins/src/petsc && git branch
> stdout:
> * master
> next
> stefano_zampini/enhancements-fetidp-saddlepoint
> stefano_zampini/feature-pcbddc-saddlepoint
> stefano_zampini/feature-usehyprematmatops
> stefano_zampini/integration-mfem
> stefano_zampini/pcbddc-adaptive-selection
> Defined "VERSION_GIT" to ""v3.7.6-4967-gb31f67c""
> Defined "VERSION_DATE_GIT" to ""2017-08-19 14:20:51 -0700""
> Defined "VERSION_BRANCH_GIT" to ""master""
> TEST configureArchitecture from PETSc.options.arch(/home/zampins/src/petsc/config/PETSc/options/arch.py:36)
> TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:36)
> Checks PETSC_ARCH and sets if not set
> Defined "ARCH" to ""haswell_debug_gnu_mkl""
> TEST setInstallDir from PETSc.options.installDir(/home/zampins/src/petsc/config/PETSc/options/installDir.py:35)
> TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
> setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
> TEST saveReconfigure from PETSc.options.installDir(/home/zampins/src/petsc/config/PETSc/options/installDir.py:75)
> TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:75)
> TEST cleanInstallDir from PETSc.options.installDir(/home/zampins/src/petsc/config/PETSc/options/installDir.py:68)
> TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:68)
> TEST configureInstallDir from PETSc.options.installDir(/home/zampins/src/petsc/config/PETSc/options/installDir.py:52)
> TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:52)
> Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
> Changed persistence directory to /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/petsc/conf
> TEST restoreReconfigure from PETSc.options.installDir(/home/zampins/src/petsc/config/PETSc/options/installDir.py:88)
> TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:88)
> TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/zampins/src/petsc/config/PETSc/options/externalpackagesdir.py:15)
> TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
> TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/zampins/src/petsc/config/PETSc/options/externalpackagesdir.py:22)
> TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
> TEST printEnvVariables from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1612)
> TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1612)
> **** printenv ****
> CRAY_MPICH_BASEDIR=/opt/cray/mpt/7.2.6/gni
> PE_LIBSCI_DEFAULT_VOLATILE_PRGENV=CRAY GNU INTEL
> PE_PAPI_DEFAULT_ACCEL_LIBS=
> PKG_CONFIG_PATH_DEFAULT=/opt/cray/papi/5.4.1.2/lib64/pkgconfig
> PYTHONPATH=/home/zampins/local/fenics-tools/lib/python2.7/site-packages/:
> LESS=-M -I
> PE_PETSC_DEFAULT_GENCOMPILERS_INTEL_haswell=14.0
> PE_TPSL_DEFAULT_GENCOMPILERS_GNU_interlagos=5.1 4.9
> PETIGA_DIR=/home/zampins/src/petiga-master
> PE_PKGCONFIG_LIBS=AtpSigHandler:cray-rca:darshan-runtime:mpich
> PE_TPSL_64_DEFAULT_GENCOMPILERS_CRAY_x86_64=8.3
> PE_LIBSCI_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/libsci/13.2.0/@PRGENV@/@PE_LIBSCI_DEFAULT_GENCOMPS@/@PE_LIBSCI_DEFAULT_TARGET@/lib/pkgconfig
> G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-15,CP1252
> PE_TRILINOS_DEFAULT_GENCOMPILERS_CRAY_x86_64=8.3
> PE_FFTW_DEFAULT_TARGET_sandybridge=sandybridge
> PE_PETSC_DEFAULT_GENCOMPS_INTEL_interlagos=140
> XCURSOR_THEME=crystalwhite
> USERMODULES=/opt/modules/3.2.10.5/init/.usermodules:acml:alps:apprentice:apprentice2:atp:blcr:cce:chapel:cray-ccdb:cray-fftw:cray-ga:cray-hdf5:cray-hdf5-parallel:cray-lgdb:cray-libsci:cray-libsci_acc:cray-mpich:cray-mpich2:cray-mpich-compat:cray-netcdf:cray-netcdf-hdf5parallel:cray-parallel-netcdf:craypat:craype:cray-petsc:cray-petsc-complex:craypkg-gen:cray-shmem:cray-snplauncher:cray-tpsl:cray-trilinos:cudatoolkit:ddt:fftw:ga:gcc:hdf5:hdf5-parallel:intel:iobuf:java:lgdb:libfast:libsci_acc:mpich1:netcdf:netcdf-hdf5parallel:netcdf-nofsync:netcdf-nofsync-hdf5parallel:ntk:onesided:papi:parallel-netcdf:pathscale:perftools:perftools-lite:petsc:petsc-complex:pgi:pmi:PrgEnv-cray:PrgEnv-gnu:PrgEnv-intel:PrgEnv-pathscale:PrgEnv-pgi:stat:totalview:tpsl:trilinos:xt-asyncpe:xt-craypat:xt-lgdb:xt-libsci:xt-mpich2:xt-mpt:xt-papi:xt-shmem:xt-totalview:/etc/opt/cray/modules/site_usermodules
> PE_TPSL_64_DEFAULT_GENCOMPILERS_GNU_sandybridge=5.1 4.9
> GCC_PATH=/opt/gcc/5.1.0
> PE_HDF5_DEFAULT_GENCOMPS_GNU=51 49 48
> XKEYSYMDB=/usr/share/X11/XKeysymDB
> PE_PETSC_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/petsc/3.6.1.0/real/@PRGENV@/@PE_PETSC_DEFAULT_GENCOMPS@/@PE_PETSC_DEFAULT_TARGET@/lib/pkgconfig
> PE_TPSL_DEFAULT_GENCOMPILERS_INTEL_x86_64=14.0
> CRAYPE_DIR=/opt/cray/craype/2.4.2
> SHELL=/bin/bash
> PE_TPSL_DEFAULT_GENCOMPILERS_CRAY_sandybridge=8.3
> PE_HDF5_PARALLEL_DEFAULT_VOLATILE_PRGENV=GNU
> PE_PAPI_DEFAULT_TARGET_VAR_nvidia35=,-lcupti,-lcudart,-lcuda
> XDG_DATA_DIRS=/usr/local/share:/usr/share:/etc/opt/kde3/share:/opt/kde3/share
> LESSCLOSE=lessclose.sh %s %s
> CPU=x86_64
> HISTSIZE=1000
> PE_TPSL_64_DEFAULT_GENCOMPS_INTEL_x86_64=140
> PE_MPICH_TARGET_VAR_nvidia35=-lcudart
> SQUEUE_FORMAT=%.11i %.8u %.7a %.14j %.3t %9r %19S %.10M %.10L %.5D
> PE_PETSC_DEFAULT_VOLATILE_PRGENV=CRAY CRAY64 GNU GNU64 INTEL INTEL64
> CRAYPE_VERSION=2.4.2
> PE_MPICH_MODULE_NAME=cray-mpich
> PE_HDF5_DEFAULT_VOLATILE_PRGENV=GNU
> XMODIFIERS=@im=ibus
> PETSC_DIR=/home/zampins/src/petsc
> PE_TPSL_DEFAULT_GENCOMPILERS_GNU_x86_64=5.1 4.9
> PE_PETSC_DEFAULT_GENCOMPILERS_CRAY_haswell=8.3
> PROFILEREAD=true
> PE_PETSC_DEFAULT_GENCOMPS_GNU_sandybridge=51 49
> PE_PKGCONFIG_PRODUCTS=PE_MPICH
> PE_TPSL_DEFAULT_GENCOMPILERS_CRAY_interlagos=8.3
> DMAPP_ABORT_ON_ERROR=1
> CRAY_UGNI_INCLUDE_OPTS=-I/opt/cray/ugni/6.0-1.0502.10863.8.29.ari/include
> PE_MPICH_PKGCONFIG_VARIABLES=PE_MPICH_NV_LIBS_ at accelerator@:PE_MPICH_MULTITHREADED_LIBS_ at multithreaded@
> PE_NETCDF_HDF5PARALLEL_DEFAULT_REQUIRED_PRODUCTS=PE_HDF5_PARALLEL:PE_MPICH
> PE_FFTW_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH
> PE_TPSL_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH:PE_LIBSCI
> DVS_VERSION=0.9.0
> PE_TPSL_64_DEFAULT_GENCOMPS_GNU_interlagos=51 49
> FPATH=:/opt/modules/3.2.10.5/init/sh_funcs/no_redirect:/opt/modules/3.2.10.5/init/sh_funcs/no_redirect:/opt/modules/3.2.10.5/init/sh_funcs/no_redirect:/opt/modules/3.2.10.5/init/sh_funcs/no_redirect
> PE_NETCDF_HDF5PARALLEL_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/netcdf-hdf5parallel/4.3.3.1/@PRGENV@/@PE_NETCDF_HDF5PARALLEL_DEFAULT_GENCOMPS@/lib/pkgconfig
> PELOCAL_PRGENV=true
> MPICH_ABORT_ON_ERROR=1
> PE_PETSC_DEFAULT_GENCOMPILERS_GNU_interlagos=5.1 4.9
> PE_ENV=GNU
> PE_PRODUCT_LIST=CRAY_RCA:CRAY_ALPS:DVS:CRAY_XPMEM:CRAY_DMAPP:CRAY_PMI:CRAY_UGNI:CRAY_UDREG:GNU:GCC:CRAYPE:CRAYPE_HASWELL
> PE_MPICH_VOLATILE_PRGENV=CRAY GNU
> PE_HDF5_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/hdf5/1.8.14/@PRGENV@/@PE_HDF5_DEFAULT_GENCOMPS@/lib/pkgconfig
> PE_PETSC_DEFAULT_GENCOMPS_CRAY_x86_64=83
> PE_PETSC_DEFAULT_GENCOMPS_GNU_interlagos=51 49
> PE_PETSC_DEFAULT_GENCOMPS_GNU_haswell=51 49
> PE_TPSL_DEFAULT_GENCOMPS_INTEL_x86_64=140
> PE_TRILINOS_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/trilinos/11.12.1.5/@PRGENV@/@PE_TRILINOS_DEFAULT_GENCOMPS@/@PE_TRILINOS_DEFAULT_TARGET@/lib/pkgconfig
> PE_FFTW_DEFAULT_TARGET_haswell=haswell
> SSH_CONNECTION=10.68.58.70 49396 10.66.87.2 22
> HOSTNAME=cdl2
> PE_INTEL_DEFAULT_FIXED_PKGCONFIG_PATH=/opt/cray/mpt/7.2.6/gni/mpich-intel/14.0/lib/pkgconfig:/opt/cray/ga/5.3.0.4/INTEL/14.0/lib/pkgconfig:/opt/cray/netcdf/4.3.3.1/INTEL/14.0/lib/pkgconfig:/opt/cray/parallel-netcdf/1.6.1/INTEL/14.0/lib/pkgconfig:/opt/cray/hdf5-parallel/1.8.14/INTEL/14.0/lib/pkgconfig:/opt/cray/hdf5/1.8.14/INTEL/14.0/lib/pkgconfig:/opt/cray/netcdf-hdf5parallel/4.3.3.1/INTEL/14.0/lib/pkgconfig
> CRAY_DMAPP_POST_LINK_OPTS=-L/opt/cray/dmapp/7.0.1-1.0502.11080.8.76.ari/lib64
> SSH_SENDS_LOCALE=yes
> PE_MPICH_GENCOMPILERS_CRAY=8.3
> BASH_FUNC_mc()=() { . /usr/share/mc/bin/mc-wrapper.sh
> CRAY_RCA_POST_LINK_OPTS=-L/opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/lib64 -lrca
> PE_SMA_DEFAULT_DIR_PGI_DEFAULT64=64
> PE_MPICH_TARGET_VAR_nvidia20=-lcudart
> ATP_IGNORE_SIGTERM=1
> MAIL=/var/mail/zampins
> PE_TPSL_DEFAULT_GENCOMPS_INTEL_sandybridge=140
> LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
> KSH_AUTOLOAD=1
> TOOLMODULES=/opt/modules/3.2.10.5/init/.toolmodules:apprentice:apprentice2:atp:chapel:cray-lgdb:craypat:craypkg-gen:cray-snplauncher:ddt:gdb:iobuf:papi:perftools:perftools-lite:stat:totalview:xt-craypat:xt-lgdb:xt-papi:xt-totalview:/etc/opt/cray/modules/site_toolmodules
> CRAYOS_VERSION=5.2.82
> PE_LIBSCI_DEFAULT_GENCOMPILERS_GNU_x86_64=5.1 4.9
> PE_SMA_DEFAULT_COMPFLAG=
> PE_TPSL_DEFAULT_GENCOMPILERS_INTEL_interlagos=14.0
> PE_NETCDF_HDF5PARALLEL_DEFAULT_FIXED_PRGENV=CRAY INTEL
> PE_TPSL_DEFAULT_GENCOMPS_CRAY_interlagos=83
> JAVA_ROOT=/usr/lib64/jvm/java
> CRAY_MPICH_DIR=/opt/cray/mpt/7.2.6/gni/mpich-gnu/51
> PE_MPICH_DIR_CRAY_DEFAULT64=64
> MINICOM=-c on
> LESSOPEN=lessopen.sh %s
> CSHEDIT=emacs
> PE_TRILINOS_DEFAULT_GENCOMPILERS_INTEL_x86_64=14.0
> MACHTYPE=x86_64-suse-linux
> PE_TPSL_DEFAULT_GENCOMPS_CRAY_sandybridge=83
> PE_MPICH_NV_LIBS=
> CRAY_UDREG_INCLUDE_OPTS=-I/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/include
> USER=zampins
> PE_TPSL_DEFAULT_GENCOMPILERS_GNU_haswell=5.1 4.9
> PE_TRILINOS_DEFAULT_GENCOMPILERS_GNU_x86_64=5.1 4.9
> ATP_POST_LINK_OPTS=-Wl,-L/opt/cray/atp/1.8.3/libApp/
> PETIGAM_DIR=/home/zampins/src/petiga-ds
> PE_MPICH_PKGCONFIG_LIBS=mpich
> PE_LIBSCI_DEFAULT_GENCOMPS_INTEL_x86_64=140
> PE_TPSL_64_DEFAULT_GENCOMPILERS_GNU_x86_64=5.1 4.9
> PE_TPSL_DEFAULT_GENCOMPILERS_INTEL_sandybridge=14.0
> PE_LIBSCI_DEFAULT_GENCOMPS_CRAY_x86_64=83
> JDK_HOME=/usr/lib64/jvm/java
> PKGCONFIG_ENABLED=1
> SHLVL=2
> PE_MPICH_NV_LIBS_nvidia20=-lcudart
> PE_TPSL_64_DEFAULT_GENCOMPS_GNU_haswell=51 49
> PE_PARALLEL_NETCDF_DEFAULT_GENCOMPS_GNU=51 49 48
> PE_MPICH_DEFAULT_DIR_CRAY_DEFAULT64=64
> PE_MPICH_GENCOMPS_CRAY=83
> PE_NETCDF_HDF5PARALLEL_DEFAULT_GENCOMPILERS_GNU=5.1 4.9 4.8
> LD_LIBRARY_PATH=/home/zampins/local/lib:/opt/gcc/5.1.0/snos/lib64:/sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/lib
> PE_PKGCONFIG_DEFAULT_PRODUCTS=PE_PETSC:PE_FFTW:PE_MPICH:PE_GA:PE_TRILINOS:PE_TPSL_64:PE_TPSL:PE_LIBSCI:PE_NETCDF:PE_PARALLEL_NETCDF:PE_HDF5_PARALLEL:PE_HDF5:PE_NETCDF_HDF5PARALLEL
> CRAY_XPMEM_POST_LINK_OPTS=-L/opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/lib64
> PE_TRILINOS_DEFAULT_GENCOMPS_GNU_x86_64=51 49
> SQUEUE_SORT=-t,e,S
> PE_TPSL_64_DEFAULT_GENCOMPILERS_INTEL_x86_64=14.0
> PE_MPICH_FORTRAN_PKGCONFIG_LIBS=mpichf90
> PE_HDF5_PARALLEL_DEFAULT_GENCOMPILERS_GNU=5.1 4.9 4.8
> LIBRARYMODULES=/opt/modules/3.2.10.5/init/.librarymodules:acml:alps:cray-dwarf:cray-fftw:cray-ga:cray-hdf5:cray-hdf5-parallel:cray-libsci:cray-libsci_acc:cray-mpich:cray-mpich2:cray-mpich-abi:cray-netcdf:cray-netcdf-hdf5parallel:cray-parallel-netcdf:cray-petsc:cray-petsc-complex:cray-shmem:cray-tpsl:cray-trilinos:cudatoolkit:fftw:ga:hdf5:hdf5-parallel:iobuf:libfast:netcdf:netcdf-hdf5parallel:ntk:onesided:papi:petsc:petsc-complex:pmi:tpsl:trilinos:xt-libsci:xt-mpich2:xt-mpt:xt-papi:/etc/opt/cray/modules/site_librarymodules
> MODULESHOME=/opt/modules/3.2.10.5
> PE_PETSC_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH:PE_LIBSCI:PE_TPSL
> PE_LIBSCI_DEFAULT_GENCOMPILERS_CRAY_x86_64=8.3
> JAVA_BINDIR=/usr/lib64/jvm/java/bin
> PE_TPSL_64_DEFAULT_GENCOMPILERS_INTEL_haswell=14.0
> PE_TPSL_64_DEFAULT_GENCOMPS_CRAY_interlagos=83
> MFLAGS=
> PE_LIBSCI_DEFAULT_OMP_REQUIRES=
> PE_NETCDF_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/netcdf/4.3.3.1/@PRGENV@/@PE_NETCDF_DEFAULT_GENCOMPS@/lib/pkgconfig
> PE_TPSL_DEFAULT_GENCOMPS_CRAY_haswell=83
> XTPE_NETWORK_TARGET=aries
> PE_TPSL_64_DEFAULT_GENCOMPS_GNU_sandybridge=51 49
> GCC_VERSION=5.1.0
> PE_TPSL_DEFAULT_GENCOMPS_CRAY_x86_64=83
> PE_MPICH_DEFAULT_FIXED_PRGENV=INTEL
> PE_PETSC_DEFAULT_GENCOMPS_CRAY_haswell=83
> PE_HDF5_PARALLEL_DEFAULT_FIXED_PRGENV=CRAY INTEL
> CRAY_MPICH_ROOTDIR=/opt/cray/mpt/7.2.6
> XNLSPATH=/usr/share/X11/nls
> _=/home/zampins/local/anaconda/bin/python
> MODULEPATH=/opt/cray/ari/modulefiles:/opt/cray/craype/2.4.2/modulefiles:/usr/local/modulefiles:/cm/local/modulefiles:/opt/modulefiles:/opt/cray/modulefiles:/sw/xc40/modulefiles
> PE_PKGCONFIG_PRODUCTS_DEFAULT=PE_PAPI
> PERL5LIB=/opt/slurm/default//lib/perl5/site_perl/5.10.0/x86_64-linux-thread-multi
> PE_MPICH_CXX_PKGCONFIG_LIBS=mpichcxx
> PE_PARALLEL_NETCDF_DEFAULT_FIXED_PRGENV=CRAY INTEL
> XDG_CONFIG_DIRS=/etc/xdg
> PE_HDF5_DEFAULT_GENCOMPILERS_GNU=5.1 4.9 4.8
> CRAY_ALPS_INCLUDE_OPTS=-I/opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/include
> PE_TPSL_DEFAULT_GENCOMPILERS_CRAY_haswell=8.3
> PE_NETCDF_DEFAULT_GENCOMPILERS_GNU=5.1 4.9 4.8
> PE_LIBSCI_DEFAULT_OMP_REQUIRES_openmp=_mp
> WINDOWMANAGER=
> PE_TPSL_DEFAULT_GENCOMPS_GNU_haswell=51 49
> PE_NETCDF_DEFAULT_GENCOMPS_GNU=51 49 48
> PE_TRILINOS_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH:PE_HDF5_PARALLEL:PE_NETCDF_HDF5PARALLEL:PE_LIBSCI:PE_TPSL
> PE_INTEL_FIXED_PKGCONFIG_PATH=/opt/cray/mpt/7.2.6/gni/mpich-intel/14.0/lib/pkgconfig
> PE_TPSL_64_DEFAULT_GENCOMPS_INTEL_sandybridge=140
> PE_HDF5_PARALLEL_DEFAULT_GENCOMPS_GNU=51 49 48
> CRAY_DMAPP_INCLUDE_OPTS=-I/opt/cray/dmapp/7.0.1-1.0502.11080.8.76.ari/include -I/opt/cray/gni-headers/4.0-1.0502.10859.7.8.ari/include
> PAGER=less
> PE_TPSL_64_DEFAULT_GENCOMPS_INTEL_interlagos=140
> PE_TPSL_64_DEFAULT_GENCOMPILERS_INTEL_sandybridge=14.0
> MODULE_VERSION=3.2.10.5
> PE_GA_DEFAULT_GENCOMPS_GNU=51 49
> ENV=/etc/bash.bashrc
> G_BROKEN_FILENAMES=1
> PE_PETSC_DEFAULT_GENCOMPS_INTEL_x86_64=140
> CRAY_PMI_POST_LINK_OPTS=-L/opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/lib64
> CRAY_RCA_INCLUDE_OPTS=-I/opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/include -I/opt/cray/krca/1.0.0-2.0502.63139.4.31.ari/include -I/opt/cray-hss-devel/7.2.0/include
> QT_SYSTEM_DIR=/usr/share/desktop-data
> OPENSSL_NO_DEFAULT_ZLIB=yes
> ATP_MRNET_COMM_PATH=/opt/cray/atp/1.8.3/libexec/atp_mrnet_commnode_wrapper
> PE_FFTW_DEFAULT_TARGET_interlagos=interlagos
> CRAY_MPICH2_VER=7.2.6
> SHMEM_ABORT_ON_ERROR=1
> RCLOCAL_PRGENV=true
> PE_MPICH_DEFAULT_GENCOMPS_GNU=51 49
> QTDIR=/usr/lib/qt3
> PE_MPICH_GENCOMPILERS_GNU=5.1 4.9
> PE_TPSL_64_DEFAULT_GENCOMPILERS_GNU_interlagos=5.1 4.9
> PE_MPICH_DEFAULT_GENCOMPS_CRAY=83
> PE_PETSC_DEFAULT_GENCOMPS_CRAY_sandybridge=83
> COLORTERM=1
> LANG=en_US.UTF-8
> PE_NETCDF_DEFAULT_FIXED_PRGENV=CRAY INTEL
> CRAY_ALPS_POST_LINK_OPTS=-L/opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/lib64
> INFOPATH=/opt/gcc/5.1.0/snos/share/info:/usr/local/info:/usr/share/info:/usr/info
> LS_OPTIONS=-N --color=none -T 0
> PE_TPSL_64_DEFAULT_GENCOMPS_CRAY_sandybridge=83
> PE_TPSL_DEFAULT_GENCOMPS_INTEL_haswell=140
> PE_MPICH_DEFAULT_GENCOMPILERS_CRAY=8.3
> PE_GA_DEFAULT_FIXED_PRGENV=CRAY INTEL
> PE_TPSL_DEFAULT_GENCOMPS_GNU_interlagos=51 49
> PE_GA_DEFAULT_GENCOMPILERS_GNU=5.1 4.9
> PE_MPICH_NV_LIBS_nvidia35=-lcudart
> PE_LIBSCI_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH
> PE_FORTRAN_PKGCONFIG_LIBS=mpichf90
> PE_TPSL_DEFAULT_GENCOMPILERS_INTEL_haswell=14.0
> LESS_ADVANCED_PREPROCESSOR=no
> ATP_HOME=/opt/cray/atp/1.8.3
> PE_PAPI_DEFAULT_ACCEL_LIBS_nvidia35=,-lcupti,-lcudart,-lcuda
> PE_NETCDF_DEFAULT_REQUIRED_PRODUCTS=PE_HDF5_PARALLEL:PE_MPICH
> DARSHAN_LOGPATH=/project/logs/darshan/
> PE_PETSC_DEFAULT_GENCOMPILERS_GNU_haswell=5.1 4.9
> PE_NETCDF_HDF5PARALLEL_DEFAULT_GENCOMPS_GNU=51 49 48
> MANPATH=/home/zampins/local/fenics-tools/share/man/:/opt/cray/atp/1.8.3/man:/opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/man:/opt/gcc/5.1.0/snos/share/man:/opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/man:/opt/slurm/default/share/man:/opt/cray/mpt/7.2.6/gni/man/mpich:/opt/cray/craype/2.4.2/man:/opt/modules/3.2.10.5/share/man:/opt/cray/share/man:/usr/local/man:/usr/local/share/man:/usr/share/man:/opt/cray/share/man:/cm/local/apps/environment-modules/current/share/man:/opt/cray/man
> PE_PETSC_DEFAULT_GENCOMPILERS_GNU_x86_64=5.1 4.9
> PE_TRILINOS_DEFAULT_GENCOMPS_INTEL_x86_64=140
> NNTPSERVER=news
> PE_PETSC_DEFAULT_GENCOMPILERS_INTEL_interlagos=14.0
> CRAY_CPU_TARGET=haswell
> PE_SMA_DEFAULT_DIR_CRAY_DEFAULT64=64
> PE_TPSL_DEFAULT_GENCOMPS_GNU_sandybridge=51 49
> OSTYPE=linux
> HOST=cdl2
> PE_NETCDF_HDF5PARALLEL_DEFAULT_VOLATILE_PRGENV=GNU
> PE_MPICH_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/mpt/7.2.6/gni/mpich- at PRGENV@@PE_MPICH_DEFAULT_DIR_DEFAULT64@/@PE_MPICH_DEFAULT_GENCOMPS@/lib/pkgconfig
> _LMFILES_=/opt/modulefiles/modules/3.2.10.5:/opt/cray/ari/modulefiles/switch/1.0-1.0502.60522.1.61.ari:/opt/modulefiles/gcc/5.1.0:/opt/cray/craype/2.4.2/modulefiles/craype-network-aries:/opt/cray/craype/2.4.2/modulefiles/craype-haswell:/opt/cray/modulefiles/craype/2.4.2:/opt/cray/modulefiles/cray-mpich/7.2.6:/opt/modulefiles/slurm/slurm:/opt/modulefiles/eswrap/1.3.3-1.020200.1278.0:/usr/local/modulefiles/ksl/ksl:/usr/local/modulefiles/darshan/2.3.1:/opt/cray/ari/modulefiles/udreg/2.3.2-1.0502.10518.2.17.ari:/opt/cray/ari/modulefiles/ugni/6.0-1.0502.10863.8.29.ari:/opt/cray/ari/modulefiles/pmi/5.0.10-1.0000.11050.0.0.ari:/opt/cray/ari/modulefiles/dmapp/7.0.1-1.0502.11080.8.76.ari:/opt/cray/ari/modulefiles/gni-headers/4.0-1.0502.10859.7.8.ari:/opt/cray/ari/modulefiles/xpmem/0.1-2.0502.64982.5.3.ari:/opt/cray/ari/modulefiles/dvs/2.5_0.9.0-1.0502.2188.1.116.ari:/opt/cray/ari/modulefiles/alps/5.2.4-2.0502.9774.31.11.ari:/opt/cray/ari/modulefiles/rca/1.0.0-2.0502.60530.1.62.ari:/opt/cray/modulefiles/atp/1.8.3:/opt/cray/modulefiles/PrgEnv-gnu/5.2.82
> BASH_FUNC_module()=() { eval `/opt/modules/3.2.10.5/bin/modulecmd bash $*`
> PE_MPICH_DEFAULT_GENCOMPILERS_GNU=5.1 4.9
> PE_TPSL_64_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH:PE_LIBSCI
> CRAY_PMI_INCLUDE_OPTS=-I/opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/include
> PE_MPICH_GENCOMPS_GNU=51 49
> PE_PARALLEL_NETCDF_DEFAULT_VOLATILE_PRGENV=GNU
> FROM_HEADER=
> PE_CXX_PKGCONFIG_LIBS=mpichcxx
> PE_MPICH_VOLATILE_PKGCONFIG_PATH=/opt/cray/mpt/7.2.6/gni/mpich- at PRGENV@@PE_MPICH_DIR_DEFAULT64@/@PE_MPICH_GENCOMPS@/lib/pkgconfig
> SSH_TTY=/dev/pts/69
> PE_TPSL_DEFAULT_GENCOMPILERS_GNU_sandybridge=5.1 4.9
> ESWRAP_LOGIN=gateway2
> PE_FFTW_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/fftw/3.3.4.5/@PE_FFTW_DEFAULT_TARGET@/lib/pkgconfig
> PE_PETSC_DEFAULT_GENCOMPS_INTEL_haswell=140
> PE_TPSL_DEFAULT_GENCOMPILERS_CRAY_x86_64=8.3
> MAKELEVEL=1
> CVS_RSH=ssh
> PE_TPSL_64_DEFAULT_GENCOMPILERS_CRAY_interlagos=8.3
> PE_PARALLEL_NETCDF_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/parallel-netcdf/1.6.1/@PRGENV@/@PE_PARALLEL_NETCDF_DEFAULT_GENCOMPS@/lib/pkgconfig
> PE_PETSC_DEFAULT_GENCOMPILERS_INTEL_x86_64=14.0
> currentgw=gateway2
> JRE_HOME=/usr/lib64/jvm/java/jre
> PE_TRILINOS_DEFAULT_GENCOMPS_CRAY_x86_64=83
> PE_TPSL_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/tpsl/1.5.2/@PRGENV@/@PE_TPSL_DEFAULT_GENCOMPS@/@PE_TPSL_DEFAULT_TARGET@/lib/pkgconfig
> PE_TPSL_64_DEFAULT_GENCOMPILERS_GNU_haswell=5.1 4.9
> PE_TPSL_DEFAULT_GENCOMPS_INTEL_interlagos=140
> MORE=-sl
> PE_PETSC_DEFAULT_GENCOMPILERS_CRAY_interlagos=8.3
> PE_GA_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/ga/5.3.0.4/@PRGENV@/@PE_GA_DEFAULT_GENCOMPS@/lib/pkgconfig
> PE_TPSL_64_DEFAULT_GENCOMPS_CRAY_haswell=83
> INPUTRC=/home/zampins/.inputrc
> GNU_VERSION=5.1.0
> PE_HDF5_DEFAULT_FIXED_PRGENV=CRAY INTEL
> PE_PETSC_DEFAULT_GENCOMPS_GNU_x86_64=51 49
> HOSTTYPE=x86_64
> PE_LIBSCI_DEFAULT_GENCOMPS_GNU_x86_64=51 49
> PE_TPSL_DEFAULT_GENCOMPS_GNU_x86_64=51 49
> SSH_CLIENT=10.68.58.70 49396 22
> LOGNAME=zampins
> PATH=/home/zampins/local/fenics-tools/bin:/home/zampins/local/bin:/home/zampins/local/anaconda/bin:/opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin:/opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin:/opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin:/opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin:/opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin:/opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin:/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin:/opt/gcc/5.1.0/bin:/sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin:/opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin:/opt/slurm/default/bin:/opt/cray/mpt/7.2.6/gni/bin:/opt/cray/craype/2.4.2/bin:/opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin:/opt/modules/3.2.10.5/bin:/home/zampins/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/sbin:/usr/sbin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin
> CRAY_PRGENVGNU=loaded
> PE_SMA_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/mpt/7.2.6/gni/sma at PE_SMA_DEFAULT_DIR_DEFAULT64@/lib64/pkgconfig
> PE_TPSL_64_DEFAULT_GENCOMPILERS_INTEL_interlagos=14.0
> PROJECT_DIR=/project/k1011
> MAKEFLAGS=
> DVS_INCLUDE_OPTS=-I/opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/include
> PE_PETSC_DEFAULT_GENCOMPS_CRAY_interlagos=83
> TERM=xterm-256color
> PE_PARALLEL_NETCDF_DEFAULT_GENCOMPILERS_GNU=5.1 4.9 4.8
> PE_TPSL_64_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/tpsl/1.5.2/@PRGENV at 64/@PE_TPSL_64_DEFAULT_GENCOMPS@/@PE_TPSL_64_DEFAULT_TARGET@/lib/pkgconfig
> CRAYPE_NETWORK_TARGET=aries
> PE_TPSL_64_DEFAULT_GENCOMPS_INTEL_haswell=140
> PE_PETSC_DEFAULT_GENCOMPILERS_INTEL_sandybridge=14.0
> CRAY_XPMEM_INCLUDE_OPTS=-I/opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/include
> PE_MPICH_DEFAULT_VOLATILE_PRGENV=CRAY GNU
> PE_HDF5_PARALLEL_DEFAULT_REQUIRED_PRODUCTS=PE_MPICH
> PWD=/home/zampins/src/petsc
> SINFO_FORMAT=%11P %5a %8s %.10l %.6c %.6z %.7D %10T
> CRAY_PRE_COMPILE_OPTS=-hnetwork=aries
> JAVA_HOME=/usr/lib64/jvm/java
> CRAY_MPICH2_DIR=/opt/cray/mpt/7.2.6/gni/mpich-gnu/51
> PE_NETCDF_DEFAULT_VOLATILE_PRGENV=GNU
> PE_MPICH_MULTITHREADED_LIBS_multithreaded=_mt
> HOME=/home/zampins
> CRAY_GNI_HEADERS_INCLUDE_OPTS=-I/opt/cray/gni-headers/4.0-1.0502.10859.7.8.ari/include
> PE_PETSC_DEFAULT_GENCOMPILERS_CRAY_sandybridge=8.3
> PE_TPSL_DEFAULT_VOLATILE_PRGENV=CRAY CRAY64 GNU GNU64 INTEL INTEL64
> PE_TPSL_64_DEFAULT_VOLATILE_PRGENV=CRAY CRAY64 GNU GNU64 INTEL INTEL64
> PE_LIBSCI_DEFAULT_GENCOMPILERS_INTEL_x86_64=14.0
> MODULE_VERSION_STACK=3.2.10.5
> PE_PKG_CONFIG_PATH=/opt/cray/cti/1.0.1/lib/pkgconfig
> INFODIR=/usr/local/info:/usr/share/info:/usr/info
> PRGENVMODULES=/opt/modules/3.2.10.5/init/.prgenvmodules:PrgEnv-cray:PrgEnv-gnu:PrgEnv-intel:PrgEnv-pathscale:PrgEnv-pgi
> PE_CRAY_DEFAULT_FIXED_PKGCONFIG_PATH=/opt/cray/ga/5.3.0.4/CRAY/8.3/lib/pkgconfig:/opt/cray/netcdf/4.3.3.1/CRAY/8.3/lib/pkgconfig:/opt/cray/parallel-netcdf/1.6.1/CRAY/8.3/lib/pkgconfig:/opt/cray/hdf5-parallel/1.8.14/CRAY/8.3/lib/pkgconfig:/opt/cray/hdf5/1.8.14/CRAY/8.3/lib/pkgconfig:/opt/cray/netcdf-hdf5parallel/4.3.3.1/CRAY/8.3/lib/pkgconfig
> PKG_CONFIG_PATH=/opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/lib64/pkgconfig:/opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/lib64/pkgconfig:/opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/lib64/pkgconfig:/opt/cray/gni-headers/4.0-1.0502.10859.7.8.ari/lib64/pkgconfig:/opt/cray/dmapp/7.0.1-1.0502.11080.8.76.ari/lib64/pkgconfig:/opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/lib64/pkgconfig:/opt/cray/ugni/6.0-1.0502.10863.8.29.ari/lib64/pkgconfig:/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/lib64/pkgconfig:/sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/lib/pkgconfig:/opt/slurm/default/lib/pkgconfig:/opt/cray/craype/2.4.2/pkg-config:/opt/cray/iobuf/2.0.6/lib/pkgconfig:/opt/cray/switch/1.0-1.0502.60522.1.61.ari/lib64/pkgconfig:/opt/cray/atp/1.8.3/lib/pkgconfig
> PE_FFTW_DEFAULT_TARGET_x86_64=x86_64
> KRB5CCNAME=FILE:/tmp/krb5cc_127606_OSZMQZqSDD
> PE_TPSL_64_DEFAULT_GENCOMPILERS_CRAY_sandybridge=8.3
> CRAY_SITE_LIST_DIR=/etc/opt/cray/modules
> LESSKEY=/etc/lesskey.bin
> PE_HDF5_PARALLEL_DEFAULT_VOLATILE_PKGCONFIG_PATH=/opt/cray/hdf5-parallel/1.8.14/@PRGENV@/@PE_HDF5_PARALLEL_DEFAULT_GENCOMPS@/lib/pkgconfig
> PE_PETSC_DEFAULT_GENCOMPILERS_GNU_sandybridge=5.1 4.9
> TARGETMODULES=/opt/modules/3.2.10.5/init/.targetmodules:craype-abudhabi:craype-abudhabi-cu:craype-accel-host:craype-accel-nvidia20:craype-accel-nvidia30:craype-accel-nvidia35:craype-barcelona:craype-broadwell:craype-haswell:craype-hugepages128K:craype-hugepages128M:craype-hugepages16M:craype-hugepages256M:craype-hugepages2M:craype-hugepages32M:craype-hugepages4M:craype-hugepages512K:craype-hugepages512M:craype-hugepages64M:craype-hugepages8M:craype-intel-knc:craype-interlagos:craype-interlagos-cu:craype-istanbul:craype-ivybridge:craype-mc12:craype-mc8:craype-mic-knl:craype-network-aries:craype-network-gemini:craype-network-infiniband:craype-network-none:craype-network-seastar:craype-sandybridge:craype-shanghai:craype-target-compute_node:craype-target-local_host:craype-target-native:craype-xeon:xtpe-barcelona:xtpe-interlagos:xtpe-interlagos-cu:xtpe-istanbul:xtpe-mc12:xtpe-mc8:xtpe-network-gemini:xtpe-network-seastar:xtpe-shanghai:xtpe-target-native:xtpe-xeon:/etc/opt/cray/modules/site_targetmodules
> CRAY_LD_LIBRARY_PATH=/opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/lib64:/opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/lib64:/opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/lib64:/opt/cray/dmapp/7.0.1-1.0502.11080.8.76.ari/lib64:/opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/lib64:/opt/cray/ugni/6.0-1.0502.10863.8.29.ari/lib64:/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/lib64:/opt/cray/mpt/7.2.6/gni/mpich-gnu/51/lib
> BOOST_ROOT=/home/zampins/localpe
> CRAY_UGNI_POST_LINK_OPTS=-L/opt/cray/ugni/6.0-1.0502.10863.8.29.ari/lib64
> XTOS_VERSION=5.2.82
> PE_MPICH_FIXED_PRGENV=INTEL
> PE_GA_DEFAULT_VOLATILE_PRGENV=GNU
> PYTHONSTARTUP=/etc/pythonstart
> PE_TPSL_64_DEFAULT_GENCOMPS_CRAY_x86_64=83
> PE_TPSL_64_DEFAULT_GENCOMPS_GNU_x86_64=51 49
> LOADEDMODULES=modules/3.2.10.5:switch/1.0-1.0502.60522.1.61.ari:gcc/5.1.0:craype-network-aries:craype-haswell:craype/2.4.2:cray-mpich/7.2.6:slurm/slurm:eswrap/1.3.3-1.020200.1278.0:ksl/ksl:darshan/2.3.1:udreg/2.3.2-1.0502.10518.2.17.ari:ugni/6.0-1.0502.10863.8.29.ari:pmi/5.0.10-1.0000.11050.0.0.ari:dmapp/7.0.1-1.0502.11080.8.76.ari:gni-headers/4.0-1.0502.10859.7.8.ari:xpmem/0.1-2.0502.64982.5.3.ari:dvs/2.5_0.9.0-1.0502.2188.1.116.ari:alps/5.2.4-2.0502.9774.31.11.ari:rca/1.0.0-2.0502.60530.1.62.ari:atp/1.8.3:PrgEnv-gnu/5.2.82
> PE_LIBSCI_DEFAULT_PKGCONFIG_VARIABLES=PE_LIBSCI_DEFAULT_OMP_REQUIRES_ at openmp@
> PE_PETSC_DEFAULT_GENCOMPILERS_CRAY_x86_64=8.3
> PE_PETSC_DEFAULT_GENCOMPS_INTEL_sandybridge=140
> PE_SMA_DEFAULT_PKGCONFIG_VARIABLES=PE_SMA_COMPFLAG_ at prgenv@
> PE_PAPI_DEFAULT_PKGCONFIG_VARIABLES=PE_PAPI_ACCEL_LIBS_ at accelerator@
> CRAY_UDREG_POST_LINK_OPTS=-L/opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/lib64
> PE_TPSL_64_DEFAULT_GENCOMPILERS_CRAY_haswell=8.3
> PE_TRILINOS_DEFAULT_VOLATILE_PRGENV=CRAY GNU INTEL
> SDK_HOME=/usr/lib64/jvm/java
> PE_SMA_DEFAULT_COMPFLAG_GNU=-fcray-pointer
> TEST resetEnvCompilers from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1619)
> TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1619)
> ***** WARNING: MAKEFLAGS (set to ) found in environment variables - ignoring
> use ./configure MAKEFLAGS=$MAKEFLAGS if you really want to use that value ******
> TEST checkEnvCompilers from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1649)
> TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1649)
> TEST checkMPICompilerOverride from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1584)
> TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1584)
> Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
> This usually prevents mpi compilers from being used - so issue a warning
> TEST requireMpiLdPath from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1603)
> TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1603)
> OpenMPI wrappers require LD_LIBRARY_PATH set
> TEST checkVendor from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:426)
> TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:426)
> Determine the compiler vendor
> Compiler vendor is ""
> TEST checkInitialFlags from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:436)
> TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:436)
> Initialize the compiler and linker flags
> Pushing language C
> Initialized CFLAGS to -g -O0
> Initialized LDFLAGS to
> Popping language C
> Initialized CUDAFLAGS to
> Initialized CXXFLAGS to -g -O0
> Initialized CXX_CXXFLAGS to
> Pushing language FC
> Initialized FFLAGS to -g -O0
> Popping language FC
> Initialized CPPFLAGS to
> Initialized CUDAPPFLAGS to
> Initialized CXXCPPFLAGS to
> Initialized CC_LINKER_FLAGS to []
> Initialized CXX_LINKER_FLAGS to []
> Initialized FC_LINKER_FLAGS to []
> Initialized CUDAC_LINKER_FLAGS to []
> Initialized sharedLibraryFlags to []
> Initialized dynamicLibraryFlags to []
> TEST checkCCompiler from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:566)
> TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:566)
> Locate a functional C compiler
> Checking for program /opt/cray/craype/2.4.2/bin/cc...found
> Defined make macro "CC" to "/opt/cray/craype/2.4.2/bin/cc"
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.setCompilers
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
> Possible ERROR while running linker: exit code 256
> stderr:
> /usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
> collect2: error: ld returned 1 exit status
> Popping language C
> TEST checkCPreprocessor from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:599)
> TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:599)
> Locate a functional C preprocessor
> Defined make macro "CPP" to "/opt/cray/craype/2.4.2/bin/cc -E"
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.setCompilers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.setCompilers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.setCompilers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.setCompilers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.setCompilers/conftest.c" 2
> # 1 "/usr/include/stdlib.h" 1 3 4
> # 25 "/usr/include/stdlib.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 26 "/usr/include/stdlib.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 328 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef int wchar_t;
> # 34 "/usr/include/stdlib.h" 2 3 4
> # 96 "/usr/include/stdlib.h" 3 4
> typedef struct
> int quot;
> int rem;
> } div_t;
> typedef struct
> long int quot;
> long int rem;
> } ldiv_t;
> __extension__ typedef struct
> long long int quot;
> long long int rem;
> } lldiv_t;
> # 140 "/usr/include/stdlib.h" 3 4
> extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__)) ;
> extern double atof (__const char *__nptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
> extern int atoi (__const char *__nptr)
> extern long int atol (__const char *__nptr)
> __extension__ extern long long int atoll (__const char *__nptr)
> extern double strtod (__const char *__restrict __nptr,
> char **__restrict __endptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern float strtof (__const char *__restrict __nptr,
> char **__restrict __endptr) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern long double strtold (__const char *__restrict __nptr,
> extern long int strtol (__const char *__restrict __nptr,
> char **__restrict __endptr, int __base)
> extern unsigned long int strtoul (__const char *__restrict __nptr,
> __extension__
> extern long long int strtoq (__const char *__restrict __nptr,
> __extension__
> extern unsigned long long int strtouq (__const char *__restrict __nptr,
> __extension__
> extern long long int strtoll (__const char *__restrict __nptr,
> __extension__
> extern unsigned long long int strtoull (__const char *__restrict __nptr,
> # 311 "/usr/include/stdlib.h" 3 4
> extern char *l64a (long int __n) __attribute__ ((__nothrow__)) ;
> extern long int a64l (__const char *__s)
> # 1 "/usr/include/sys/types.h" 1 3 4
> # 29 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/types.h" 1 3 4
> # 28 "/usr/include/bits/types.h" 3 4
> # 29 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned char __u_char;
> typedef unsigned short int __u_short;
> typedef unsigned int __u_int;
> typedef unsigned long int __u_long;
> typedef signed char __int8_t;
> typedef unsigned char __uint8_t;
> typedef signed short int __int16_t;
> typedef unsigned short int __uint16_t;
> typedef signed int __int32_t;
> typedef unsigned int __uint32_t;
> typedef signed long int __int64_t;
> typedef unsigned long int __uint64_t;
> typedef long int __quad_t;
> typedef unsigned long int __u_quad_t;
> # 131 "/usr/include/bits/types.h" 3 4
> # 1 "/usr/include/bits/typesizes.h" 1 3 4
> # 132 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned long int __dev_t;
> typedef unsigned int __uid_t;
> typedef unsigned int __gid_t;
> typedef unsigned long int __ino_t;
> typedef unsigned long int __ino64_t;
> typedef unsigned int __mode_t;
> typedef unsigned long int __nlink_t;
> typedef long int __off_t;
> typedef long int __off64_t;
> typedef int __pid_t;
> typedef struct { int __val[2]; } __fsid_t;
> typedef long int __clock_t;
> typedef unsigned long int __rlim_t;
> typedef unsigned long int __rlim64_t;
> typedef unsigned int __id_t;
> typedef long int __time_t;
> typedef unsigned int __useconds_t;
> typedef long int __suseconds_t;
> typedef int __daddr_t;
> typedef long int __swblk_t;
> typedef int __key_t;
> typedef int __clockid_t;
> typedef void * __timer_t;
> typedef long int __blksize_t;
> typedef long int __blkcnt_t;
> typedef long int __blkcnt64_t;
> typedef unsigned long int __fsblkcnt_t;
> typedef unsigned long int __fsblkcnt64_t;
> typedef unsigned long int __fsfilcnt_t;
> typedef unsigned long int __fsfilcnt64_t;
> typedef long int __ssize_t;
> typedef __off64_t __loff_t;
> typedef __quad_t *__qaddr_t;
> typedef char *__caddr_t;
> typedef long int __intptr_t;
> typedef unsigned int __socklen_t;
> # 32 "/usr/include/sys/types.h" 2 3 4
> typedef __u_char u_char;
> typedef __u_short u_short;
> typedef __u_int u_int;
> typedef __u_long u_long;
> typedef __quad_t quad_t;
> typedef __u_quad_t u_quad_t;
> typedef __fsid_t fsid_t;
> typedef __loff_t loff_t;
> typedef __ino_t ino_t;
> # 62 "/usr/include/sys/types.h" 3 4
> typedef __dev_t dev_t;
> typedef __gid_t gid_t;
> typedef __mode_t mode_t;
> typedef __nlink_t nlink_t;
> typedef __uid_t uid_t;
> typedef __off_t off_t;
> # 100 "/usr/include/sys/types.h" 3 4
> typedef __pid_t pid_t;
> typedef __id_t id_t;
> typedef __ssize_t ssize_t;
> typedef __daddr_t daddr_t;
> typedef __caddr_t caddr_t;
> typedef __key_t key_t;
> # 133 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/time.h" 1 3 4
> # 74 "/usr/include/time.h" 3 4
> typedef __time_t time_t;
> # 92 "/usr/include/time.h" 3 4
> typedef __clockid_t clockid_t;
> # 104 "/usr/include/time.h" 3 4
> typedef __timer_t timer_t;
> # 134 "/usr/include/sys/types.h" 2 3 4
> # 147 "/usr/include/sys/types.h" 3 4
> # 148 "/usr/include/sys/types.h" 2 3 4
> typedef unsigned long int ulong;
> typedef unsigned short int ushort;
> typedef unsigned int uint;
> # 195 "/usr/include/sys/types.h" 3 4
> typedef int int8_t __attribute__ ((__mode__ (__QI__)));
> typedef int int16_t __attribute__ ((__mode__ (__HI__)));
> typedef int int32_t __attribute__ ((__mode__ (__SI__)));
> typedef int int64_t __attribute__ ((__mode__ (__DI__)));
> typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
> typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
> typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
> typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
> typedef int register_t __attribute__ ((__mode__ (__word__)));
> # 217 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/endian.h" 1 3 4
> # 37 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/endian.h" 1 3 4
> # 38 "/usr/include/endian.h" 2 3 4
> # 61 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/byteswap.h" 1 3 4
> # 28 "/usr/include/bits/byteswap.h" 3 4
> # 29 "/usr/include/bits/byteswap.h" 2 3 4
> # 62 "/usr/include/endian.h" 2 3 4
> # 218 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/select.h" 1 3 4
> # 31 "/usr/include/sys/select.h" 3 4
> # 1 "/usr/include/bits/select.h" 1 3 4
> # 23 "/usr/include/bits/select.h" 3 4
> # 24 "/usr/include/bits/select.h" 2 3 4
> # 32 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/sigset.h" 1 3 4
> # 24 "/usr/include/bits/sigset.h" 3 4
> typedef int __sig_atomic_t;
> typedef struct
> unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
> } __sigset_t;
> # 35 "/usr/include/sys/select.h" 2 3 4
> typedef __sigset_t sigset_t;
> # 120 "/usr/include/time.h" 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 45 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/time.h" 1 3 4
> # 69 "/usr/include/bits/time.h" 3 4
> struct timeval
> __time_t tv_sec;
> __suseconds_t tv_usec;
> # 47 "/usr/include/sys/select.h" 2 3 4
> typedef __suseconds_t suseconds_t;
> typedef long int __fd_mask;
> # 67 "/usr/include/sys/select.h" 3 4
> typedef struct
> __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
> } fd_set;
> typedef __fd_mask fd_mask;
> # 99 "/usr/include/sys/select.h" 3 4
> # 109 "/usr/include/sys/select.h" 3 4
> extern int select (int __nfds, fd_set *__restrict __readfds,
> fd_set *__restrict __writefds,
> fd_set *__restrict __exceptfds,
> struct timeval *__restrict __timeout);
> # 121 "/usr/include/sys/select.h" 3 4
> extern int pselect (int __nfds, fd_set *__restrict __readfds,
> const struct timespec *__restrict __timeout,
> const __sigset_t *__restrict __sigmask);
> # 221 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/sysmacros.h" 1 3 4
> # 30 "/usr/include/sys/sysmacros.h" 3 4
> __extension__
> extern unsigned int gnu_dev_major (unsigned long long int __dev)
> __attribute__ ((__nothrow__));
> __extension__
> extern unsigned int gnu_dev_minor (unsigned long long int __dev)
> __extension__
> extern unsigned long long int gnu_dev_makedev (unsigned int __major,
> unsigned int __minor)
> # 224 "/usr/include/sys/types.h" 2 3 4
> # 235 "/usr/include/sys/types.h" 3 4
> typedef __blkcnt_t blkcnt_t;
> typedef __fsblkcnt_t fsblkcnt_t;
> typedef __fsfilcnt_t fsfilcnt_t;
> # 270 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
> # 23 "/usr/include/bits/pthreadtypes.h" 3 4
> # 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
> # 50 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef unsigned long int pthread_t;
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> typedef struct __pthread_internal_list
> struct __pthread_internal_list *__prev;
> struct __pthread_internal_list *__next;
> } __pthread_list_t;
> # 76 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef union
> struct __pthread_mutex_s
> int __lock;
> unsigned int __count;
> int __owner;
> unsigned int __nusers;
> int __kind;
> int __spins;
> __pthread_list_t __list;
> # 101 "/usr/include/bits/pthreadtypes.h" 3 4
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_mutexattr_t;
> typedef union
> struct
> int __lock;
> unsigned int __futex;
> __extension__ unsigned long long int __total_seq;
> __extension__ unsigned long long int __wakeup_seq;
> __extension__ unsigned long long int __woken_seq;
> void *__mutex;
> unsigned int __nwaiters;
> unsigned int __broadcast_seq;
> } __data;
> char __size[48];
> __extension__ long long int __align;
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_condattr_t;
> typedef unsigned int pthread_key_t;
> typedef int pthread_once_t;
> typedef union
> struct
> int __lock;
> unsigned int __nr_readers;
> unsigned int __readers_wakeup;
> unsigned int __writer_wakeup;
> unsigned int __nr_readers_queued;
> unsigned int __nr_writers_queued;
> int __writer;
> int __shared;
> unsigned long int __pad1;
> unsigned long int __pad2;
> unsigned int __flags;
> } __data;
> # 187 "/usr/include/bits/pthreadtypes.h" 3 4
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> } pthread_rwlockattr_t;
> typedef volatile int pthread_spinlock_t;
> typedef union
> char __size[32];
> long int __align;
> } pthread_barrier_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_barrierattr_t;
> # 271 "/usr/include/sys/types.h" 2 3 4
> # 321 "/usr/include/stdlib.h" 2 3 4
> extern long int random (void) __attribute__ ((__nothrow__));
> extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__));
> extern char *initstate (unsigned int __seed, char *__statebuf,
> size_t __statelen) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> struct random_data
> int32_t *fptr;
> int32_t *rptr;
> int32_t *state;
> int rand_type;
> int rand_deg;
> int rand_sep;
> int32_t *end_ptr;
> extern int random_r (struct random_data *__restrict __buf,
> int32_t *__restrict __result) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int srandom_r (unsigned int __seed, struct random_data *__buf)
> extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
> size_t __statelen,
> struct random_data *__restrict __buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 4)));
> extern int setstate_r (char *__restrict __statebuf,
> extern int rand (void) __attribute__ ((__nothrow__));
> extern void srand (unsigned int __seed) __attribute__ ((__nothrow__));
> extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__));
> extern double drand48 (void) __attribute__ ((__nothrow__));
> extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern long int lrand48 (void) __attribute__ ((__nothrow__));
> extern long int nrand48 (unsigned short int __xsubi[3])
> extern long int mrand48 (void) __attribute__ ((__nothrow__));
> extern long int jrand48 (unsigned short int __xsubi[3])
> extern void srand48 (long int __seedval) __attribute__ ((__nothrow__));
> extern unsigned short int *seed48 (unsigned short int __seed16v[3])
> extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> struct drand48_data
> unsigned short int __x[3];
> unsigned short int __old_x[3];
> unsigned short int __c;
> unsigned short int __init;
> unsigned long long int __a;
> extern int drand48_r (struct drand48_data *__restrict __buffer,
> double *__restrict __result) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int erand48_r (unsigned short int __xsubi[3],
> extern int lrand48_r (struct drand48_data *__restrict __buffer,
> long int *__restrict __result)
> extern int nrand48_r (unsigned short int __xsubi[3],
> extern int mrand48_r (struct drand48_data *__restrict __buffer,
> extern int jrand48_r (unsigned short int __xsubi[3],
> extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
> extern int seed48_r (unsigned short int __seed16v[3],
> struct drand48_data *__buffer) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int lcong48_r (unsigned short int __param[7],
> extern void *malloc (size_t __size) __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern void *calloc (size_t __nmemb, size_t __size)
> extern void *realloc (void *__ptr, size_t __size)
> __attribute__ ((__nothrow__)) __attribute__ ((__warn_unused_result__));
> extern void free (void *__ptr) __attribute__ ((__nothrow__));
> extern void cfree (void *__ptr) __attribute__ ((__nothrow__));
> # 1 "/usr/include/alloca.h" 1 3 4
> # 25 "/usr/include/alloca.h" 3 4
> # 26 "/usr/include/alloca.h" 2 3 4
> extern void *alloca (size_t __size) __attribute__ ((__nothrow__));
> # 498 "/usr/include/stdlib.h" 2 3 4
> extern void *valloc (size_t __size) __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
> extern void abort (void) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> # 530 "/usr/include/stdlib.h" 3 4
> extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
> extern void exit (int __status) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> # 553 "/usr/include/stdlib.h" 3 4
> extern void _Exit (int __status) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> extern char *getenv (__const char *__name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern char *__secure_getenv (__const char *__name)
> extern int putenv (char *__string) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int setenv (__const char *__name, __const char *__value, int __replace)
> extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__));
> extern int clearenv (void) __attribute__ ((__nothrow__));
> # 604 "/usr/include/stdlib.h" 3 4
> extern char *mktemp (char *__template) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 615 "/usr/include/stdlib.h" 3 4
> extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
> # 637 "/usr/include/stdlib.h" 3 4
> extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
> # 658 "/usr/include/stdlib.h" 3 4
> extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 707 "/usr/include/stdlib.h" 3 4
> extern int system (__const char *__command) ;
> # 729 "/usr/include/stdlib.h" 3 4
> extern char *realpath (__const char *__restrict __name,
> char *__restrict __resolved) __attribute__ ((__nothrow__)) ;
> typedef int (*__compar_fn_t) (__const void *, __const void *);
> # 747 "/usr/include/stdlib.h" 3 4
> extern void *bsearch (__const void *__key, __const void *__base,
> size_t __nmemb, size_t __size, __compar_fn_t __compar)
> __attribute__ ((__nonnull__ (1, 2, 5))) ;
> extern void qsort (void *__base, size_t __nmemb, size_t __size,
> __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
> # 766 "/usr/include/stdlib.h" 3 4
> extern int abs (int __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)) ;
> extern long int labs (long int __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)) ;
> __extension__ extern long long int llabs (long long int __x)
> extern div_t div (int __numer, int __denom)
> extern ldiv_t ldiv (long int __numer, long int __denom)
> __extension__ extern lldiv_t lldiv (long long int __numer,
> long long int __denom)
> # 802 "/usr/include/stdlib.h" 3 4
> extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
> int *__restrict __sign) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4))) ;
> extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
> extern char *gcvt (double __value, int __ndigit, char *__buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3))) ;
> extern char *qecvt (long double __value, int __ndigit,
> int *__restrict __decpt, int *__restrict __sign)
> extern char *qfcvt (long double __value, int __ndigit,
> extern char *qgcvt (long double __value, int __ndigit, char *__buf)
> extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
> int *__restrict __sign, char *__restrict __buf,
> size_t __len) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4, 5)));
> extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
> extern int qecvt_r (long double __value, int __ndigit,
> int *__restrict __decpt, int *__restrict __sign,
> char *__restrict __buf, size_t __len)
> extern int qfcvt_r (long double __value, int __ndigit,
> extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__)) ;
> extern int mbtowc (wchar_t *__restrict __pwc,
> __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__)) ;
> extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__)) ;
> extern size_t mbstowcs (wchar_t *__restrict __pwcs,
> __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__));
> extern size_t wcstombs (char *__restrict __s,
> __const wchar_t *__restrict __pwcs, size_t __n)
> extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 907 "/usr/include/stdlib.h" 3 4
> extern int posix_openpt (int __oflag) ;
> # 942 "/usr/include/stdlib.h" 3 4
> extern int getloadavg (double __loadavg[], int __nelem)
> # 958 "/usr/include/stdlib.h" 3 4
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Popping language C
> TEST checkCUDACompiler from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:640)
> TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:640)
> Locate a functional CUDA compiler
> TEST checkCUDAPreprocessor from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:680)
> TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:680)
> Locate a functional CUDA preprocessor
> TEST checkCxxCompiler from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:792)
> TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:792)
> Locate a functional Cxx compiler
> Checking for program /opt/cray/craype/2.4.2/bin/CC...found
> Defined make macro "CXX" to "/opt/cray/craype/2.4.2/bin/CC"
> Pushing language Cxx
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Pushing language CUDA
> Popping language CUDA
> Popping language Cxx
> Pushing language FC
> Popping language FC
> Pushing language CXX
> Popping language CXX
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Successful compile:
> Source:
> int main() {
> return 0;
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
> stderr:
> TEST checkCxxPreprocessor from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:830)
> TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:830)
> Locate a functional Cxx preprocessor
> Defined make macro "CXXCPP" to "/opt/cray/craype/2.4.2/bin/CC -E"
> Executing: /opt/cray/craype/2.4.2/bin/CC -E -I/tmp/petsc-uoFdrH/config.setCompilers /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.setCompilers/conftest.cc"
> # 1 "<built-in>"
> # 2 "/tmp/petsc-uoFdrH/config.setCompilers/conftest.cc" 2
> extern "C" {
> # 3 "/tmp/petsc-uoFdrH/config.setCompilers/conftest.cc" 2
> # 1 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 1 3
> # 39 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> # 40 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> # 1 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/c++config.h" 1 3
> # 194 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/c++config.h" 3
> namespace std
> typedef long int ptrdiff_t;
> # 216 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/c++config.h" 3
> namespace std
> inline namespace __cxx11 __attribute__((__abi_tag__ ("cxx11"))) { }
> namespace __gnu_cxx
> # 482 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/c++config.h" 3
> # 1 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/os_defines.h" 1 3
> # 39 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/os_defines.h" 3
> # 40 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/os_defines.h" 2 3
> # 483 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/c++config.h" 2 3
> # 1 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/cpu_defines.h" 1 3
> # 486 "/opt/gcc/5.1.0/snos/include/g++/x86_64-suse-linux/bits/c++config.h" 2 3
> # 42 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 2 3
> # 72 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> # 33 "/usr/include/stdlib.h" 3 4
> extern "C" {
> # 1 "/usr/include/bits/waitflags.h" 1 3 4
> # 43 "/usr/include/stdlib.h" 2 3 4
> # 1 "/usr/include/bits/waitstatus.h" 1 3 4
> # 65 "/usr/include/bits/waitstatus.h" 3 4
> # 66 "/usr/include/bits/waitstatus.h" 2 3 4
> union wait
> int w_status;
> struct
> unsigned int __w_termsig:7;
> unsigned int __w_coredump:1;
> unsigned int __w_retcode:8;
> unsigned int:16;
> } __wait_terminated;
> struct
> unsigned int __w_stopval:8;
> unsigned int __w_stopsig:8;
> unsigned int:16;
> } __wait_stopped;
> # 44 "/usr/include/stdlib.h" 2 3 4
> typedef struct
> int quot;
> int rem;
> } div_t;
> typedef struct
> long int quot;
> long int rem;
> } ldiv_t;
> long long int quot;
> long long int rem;
> } lldiv_t;
> extern size_t __ctype_get_mb_cur_max (void) throw () ;
> throw () __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
> throw () __attribute__ ((__nonnull__ (1))) ;
> char **__restrict __endptr) throw () __attribute__ ((__nonnull__ (1))) ;
> __extension__
> __extension__
> __extension__
> __extension__
> # 236 "/usr/include/stdlib.h" 3 4
> # 1 "/usr/include/xlocale.h" 1 3 4
> # 28 "/usr/include/xlocale.h" 3 4
> typedef struct __locale_struct
> struct locale_data *__locales[13];
> const unsigned short int *__ctype_b;
> const int *__ctype_tolower;
> const int *__ctype_toupper;
> const char *__names[13];
> } *__locale_t;
> typedef __locale_t locale_t;
> # 237 "/usr/include/stdlib.h" 2 3 4
> extern long int strtol_l (__const char *__restrict __nptr,
> char **__restrict __endptr, int __base,
> __locale_t __loc) throw () __attribute__ ((__nonnull__ (1, 4))) ;
> extern unsigned long int strtoul_l (__const char *__restrict __nptr,
> int __base, __locale_t __loc)
> __extension__
> extern long long int strtoll_l (__const char *__restrict __nptr,
> __locale_t __loc)
> __extension__
> extern unsigned long long int strtoull_l (__const char *__restrict __nptr,
> extern double strtod_l (__const char *__restrict __nptr,
> char **__restrict __endptr, __locale_t __loc)
> throw () __attribute__ ((__nonnull__ (1, 3))) ;
> extern float strtof_l (__const char *__restrict __nptr,
> extern long double strtold_l (__const char *__restrict __nptr,
> __locale_t __loc)
> extern char *l64a (long int __n) throw () ;
> extern "C" {
> typedef __ino64_t ino64_t;
> typedef __off64_t off64_t;
> # 58 "/usr/include/time.h" 3 4
> typedef __clock_t clock_t;
> typedef __useconds_t useconds_t;
> # 220 "/usr/include/sys/types.h" 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> # 55 "/usr/include/sys/select.h" 3 4
> typedef struct
> __fd_mask fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
> } fd_set;
> extern "C" {
> __extension__
> throw ();
> __extension__
> throw ();
> __extension__
> throw ();
> typedef __blksize_t blksize_t;
> # 262 "/usr/include/sys/types.h" 3 4
> typedef __blkcnt64_t blkcnt64_t;
> typedef __fsblkcnt64_t fsblkcnt64_t;
> typedef __fsfilcnt64_t fsfilcnt64_t;
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> extern long int random (void) throw ();
> extern void srandom (unsigned int __seed) throw ();
> size_t __statelen) throw () __attribute__ ((__nonnull__ (2)));
> extern char *setstate (char *__statebuf) throw () __attribute__ ((__nonnull__ (1)));
> struct random_data
> int32_t *fptr;
> int32_t *rptr;
> int32_t *state;
> int rand_type;
> int rand_deg;
> int rand_sep;
> int32_t *end_ptr;
> int32_t *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
> size_t __statelen,
> throw () __attribute__ ((__nonnull__ (2, 4)));
> extern int rand (void) throw ();
> extern void srand (unsigned int __seed) throw ();
> extern int rand_r (unsigned int *__seed) throw ();
> extern double drand48 (void) throw ();
> extern double erand48 (unsigned short int __xsubi[3]) throw () __attribute__ ((__nonnull__ (1)));
> extern long int lrand48 (void) throw ();
> extern long int mrand48 (void) throw ();
> extern void srand48 (long int __seedval) throw ();
> extern void lcong48 (unsigned short int __param[7]) throw () __attribute__ ((__nonnull__ (1)));
> struct drand48_data
> double *__restrict __result) throw () __attribute__ ((__nonnull__ (1, 2)));
> struct drand48_data *__buffer) throw () __attribute__ ((__nonnull__ (1, 2)));
> extern void *malloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
> throw () __attribute__ ((__warn_unused_result__));
> extern void free (void *__ptr) throw ();
> extern void cfree (void *__ptr) throw ();
> extern "C" {
> extern void *alloca (size_t __size) throw ();
> extern void *valloc (size_t __size) throw () __attribute__ ((__malloc__)) ;
> extern void abort (void) throw () __attribute__ ((__noreturn__));
> extern int atexit (void (*__func) (void)) throw () __attribute__ ((__nonnull__ (1)));
> extern "C++" int at_quick_exit (void (*__func) (void))
> throw () __asm ("at_quick_exit") __attribute__ ((__nonnull__ (1)));
> extern void exit (int __status) throw () __attribute__ ((__noreturn__));
> extern void quick_exit (int __status) throw () __attribute__ ((__noreturn__));
> extern void _Exit (int __status) throw () __attribute__ ((__noreturn__));
> extern char *getenv (__const char *__name) throw () __attribute__ ((__nonnull__ (1))) ;
> extern int putenv (char *__string) throw () __attribute__ ((__nonnull__ (1)));
> extern int unsetenv (__const char *__name) throw ();
> extern int clearenv (void) throw ();
> extern char *mktemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
> # 625 "/usr/include/stdlib.h" 3 4
> extern int mkstemp64 (char *__template) __attribute__ ((__nonnull__ (1))) ;
> # 647 "/usr/include/stdlib.h" 3 4
> extern int mkstemps64 (char *__template, int __suffixlen)
> extern char *mkdtemp (char *__template) throw () __attribute__ ((__nonnull__ (1))) ;
> # 669 "/usr/include/stdlib.h" 3 4
> extern int mkostemp (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
> # 679 "/usr/include/stdlib.h" 3 4
> extern int mkostemp64 (char *__template, int __flags) __attribute__ ((__nonnull__ (1))) ;
> # 689 "/usr/include/stdlib.h" 3 4
> extern int mkostemps (char *__template, int __suffixlen, int __flags)
> # 701 "/usr/include/stdlib.h" 3 4
> extern int mkostemps64 (char *__template, int __suffixlen, int __flags)
> extern char *canonicalize_file_name (__const char *__name)
> char *__restrict __resolved) throw () ;
> typedef __compar_fn_t comparison_fn_t;
> typedef int (*__compar_d_fn_t) (__const void *, __const void *, void *);
> extern void qsort_r (void *__base, size_t __nmemb, size_t __size,
> __compar_d_fn_t __compar, void *__arg)
> extern int abs (int __x) throw () __attribute__ ((__const__)) ;
> extern long int labs (long int __x) throw () __attribute__ ((__const__)) ;
> int *__restrict __sign) throw () __attribute__ ((__nonnull__ (3, 4))) ;
> throw () __attribute__ ((__nonnull__ (3))) ;
> size_t __len) throw () __attribute__ ((__nonnull__ (3, 4, 5)));
> extern int mblen (__const char *__s, size_t __n) throw () ;
> __const char *__restrict __s, size_t __n) throw () ;
> extern int wctomb (char *__s, wchar_t __wchar) throw () ;
> __const char *__restrict __s, size_t __n) throw ();
> throw ();
> extern int rpmatch (__const char *__response) throw () __attribute__ ((__nonnull__ (1))) ;
> # 890 "/usr/include/stdlib.h" 3 4
> extern int getsubopt (char **__restrict __optionp,
> char *__const *__restrict __tokens,
> char **__restrict __valuep)
> throw () __attribute__ ((__nonnull__ (1, 2, 3))) ;
> extern void setkey (__const char *__key) throw () __attribute__ ((__nonnull__ (1)));
> extern int grantpt (int __fd) throw ();
> extern int unlockpt (int __fd) throw ();
> extern char *ptsname (int __fd) throw () ;
> extern int ptsname_r (int __fd, char *__buf, size_t __buflen)
> extern int getpt (void);
> # 73 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 2 3
> # 114 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> namespace std __attribute__ ((__visibility__ ("default")))
> using ::div_t;
> using ::ldiv_t;
> using ::abort;
> using ::abs;
> using ::atexit;
> using ::atof;
> using ::atoi;
> using ::atol;
> using ::bsearch;
> using ::calloc;
> using ::div;
> using ::exit;
> using ::free;
> using ::getenv;
> using ::labs;
> using ::ldiv;
> using ::malloc;
> using ::mblen;
> using ::mbstowcs;
> using ::mbtowc;
> using ::qsort;
> using ::rand;
> using ::realloc;
> using ::srand;
> using ::strtod;
> using ::strtol;
> using ::strtoul;
> using ::system;
> using ::wcstombs;
> using ::wctomb;
> inline long
> abs(long __i) { return __builtin_labs(__i); }
> inline ldiv_t
> div(long __i, long __j) { return ldiv(__i, __j); }
> inline long long
> abs(long long __x) { return __builtin_llabs (__x); }
> inline __int128
> abs(__int128 __x) { return __x >= 0 ? __x : -__x; }
> # 195 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> # 209 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> namespace __gnu_cxx __attribute__ ((__visibility__ ("default")))
> using ::lldiv_t;
> using ::_Exit;
> using ::llabs;
> inline lldiv_t
> div(long long __n, long long __d)
> { lldiv_t __q; __q.quot = __n / __d; __q.rem = __n % __d; return __q; }
> using ::lldiv;
> # 241 "/opt/gcc/5.1.0/snos/include/g++/cstdlib" 3
> using ::atoll;
> using ::strtoll;
> using ::strtoull;
> using ::strtof;
> using ::strtold;
> namespace std
> using ::__gnu_cxx::lldiv_t;
> using ::__gnu_cxx::_Exit;
> using ::__gnu_cxx::llabs;
> using ::__gnu_cxx::div;
> using ::__gnu_cxx::lldiv;
> using ::__gnu_cxx::atoll;
> using ::__gnu_cxx::strtof;
> using ::__gnu_cxx::strtoll;
> using ::__gnu_cxx::strtoull;
> using ::__gnu_cxx::strtold;
> TEST checkFortranCompiler from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:947)
> TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:947)
> Locate a functional Fortran compiler
> Checking for program /opt/cray/craype/2.4.2/bin/ftn...found
> Defined make macro "FC" to "/opt/cray/craype/2.4.2/bin/ftn"
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.F90
> Successful compile:
> Source:
> program main
> end
> Successful compile:
> Source:
> program main
> end
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Successful compile:
> Source:
> program main
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
> stderr:
> Popping language FC
> TEST checkFortranComments from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:968)
> TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:968)
> Make sure fortran comment "!" works
> Pushing language FC
> Successful compile:
> Source:
> ! comment
> program main
> end
> Fortran comments can use ! in column 1
> Popping language FC
> TEST checkLargeFileIO from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1085)
> TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1085)
> TEST checkArchiver from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1184)
> TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1184)
> Check that the archiver exists and can make a library usable by the compiler
> Pushing language C
> Executing: ar -V
> stdout:
> GNU ar (GNU Binutils; SUSE Linux Enterprise 11) 2.23.1
> Copyright 2012 Free Software Foundation, Inc.
> This program is free software; you may redistribute it under the terms of
> the GNU General Public License version 3 or (at your option) any later version.
> This program has absolutely no warranty.
> Executing: ar -V
> stdout:
> Defined make macro "FAST_AR_FLAGS" to "Scq"
> Successful compile:
> Source:
> int foo(int a) {
> return a+1;
> Checking for program /home/zampins/local/fenics-tools/bin/ar...not found
> Checking for program /home/zampins/local/bin/ar...not found
> Checking for program /home/zampins/local/anaconda/bin/ar...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/ar...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/ar...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/ar...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/ar...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/ar...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/ar...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/ar...not found
> Checking for program /opt/gcc/5.1.0/bin/ar...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/ar...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/ar...not found
> Checking for program /opt/slurm/default/bin/ar...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/ar...not found
> Checking for program /opt/cray/craype/2.4.2/bin/ar...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/ar...not found
> Checking for program /opt/modules/3.2.10.5/bin/ar...not found
> Checking for program /home/zampins/bin/ar...not found
> Checking for program /usr/local/bin/ar...not found
> Checking for program /usr/bin/ar...found
> Defined make macro "AR" to "/usr/bin/ar"
> Checking for program /home/zampins/local/fenics-tools/bin/ranlib...not found
> Checking for program /home/zampins/local/bin/ranlib...not found
> Checking for program /home/zampins/local/anaconda/bin/ranlib...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/ranlib...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/ranlib...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/ranlib...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/ranlib...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/ranlib...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/ranlib...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/ranlib...not found
> Checking for program /opt/gcc/5.1.0/bin/ranlib...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/ranlib...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/ranlib...not found
> Checking for program /opt/slurm/default/bin/ranlib...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/ranlib...not found
> Checking for program /opt/cray/craype/2.4.2/bin/ranlib...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/ranlib...not found
> Checking for program /opt/modules/3.2.10.5/bin/ranlib...not found
> Checking for program /home/zampins/bin/ranlib...not found
> Checking for program /usr/local/bin/ranlib...not found
> Checking for program /usr/bin/ranlib...found
> Defined make macro "RANLIB" to "/usr/bin/ranlib"
> Executing: /usr/bin/ar cr /tmp/petsc-uoFdrH/config.setCompilers/libconf1.a /tmp/petsc-uoFdrH/config.setCompilers/conf1.o
> Executing: /usr/bin/ranlib /tmp/petsc-uoFdrH/config.setCompilers/libconf1.a
> Successful compile:
> Source:
> extern int foo(int);
> int main() {
> int b = foo(1); if (b);
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/tmp/petsc-uoFdrH/config.setCompilers -lconf1 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined make macro "AR_FLAGS" to "cr"
> Defined make macro "AR_LIB_SUFFIX" to "a"
> Popping language C
> TEST checkSharedLinker from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1298)
> TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1298)
> Check that the linker can produce shared libraries
> Checking shared linker ar using flags []
> Defined make macro "LD_SHARED" to "ar"
> Trying C compiler flag
> Successful compile:
> Source:
> int main() {
> return 0;
> Added C compiler flag
> Successful compile:
> Source:
> #include <stdio.h>
> int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
> void foo(void){
> fprintf_ptr(stdout,"hello");
> return;
> void bar(void){foo();}
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> Pushing language C
> Popping language C
> Executing: ar -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> ar: invalid option -- 'L'
> Usage: ar [emulation options] [-]{dmpqrstx}[abcDfilMNoPsSTuvV] [--plugin <name>] [member-name] [count] archive-file file...
> ar -M [<mri-script]
> commands:
> d - delete file(s) from the archive
> m[ab] - move file(s) in the archive
> p - print file(s) found in the archive
> q[f] - quick append file(s) to the archive
> r[ab][f][u] - replace existing or insert new file(s) into the archive
> s - act as ranlib
> t - display contents of archive
> x[o] - extract file(s) from the archive
> command specific modifiers:
> [a] - put file(s) after [member-name]
> [b] - put file(s) before [member-name] (same as [i])
> [D] - use zero for timestamps and uids/gids
> [U] - use actual timestamps and uids/gids (default)
> [N] - use instance [count] of name
> [f] - truncate inserted file names
> [P] - use full path names when matching
> [o] - preserve original dates
> [u] - only replace files that are newer than current archive contents
> generic modifiers:
> [c] - do not warn if the library had to be created
> [s] - create an archive index (cf. ranlib)
> [S] - do not build a symbol table
> [T] - make a thin archive
> [v] - be verbose
> [V] - display the version number
> @<file> - read options from <file>
> --target=BFDNAME - specify the target object format as BFDNAME
> optional:
> --plugin <p> - load the specified plugin
> emulation options:
> No emulation specific options
> ar: supported targets: elf64-x86-64 elf32-i386 elf32-x86-64 a.out-i386-linux pei-i386 pei-x86-64 elf64-l1om elf64-k1om elf64-little elf64-big elf32-little elf32-big elf64-littleaarch64 elf64-bigaarch64 elf32-littlearm elf32-bigarm elf64-alpha ecoff-littlealpha elf32-hppa-linux elf32-hppa elf64-hppa-linux elf64-hppa elf64-ia64-little elf64-ia64-big pei-ia64 elf32-m68k a.out-m68k-linux elf32-tradbigmips elf32-tradlittlemips ecoff-bigmips ecoff-littlemips elf32-ntradbigmips elf64-tradbigmips elf32-ntradlittlemips elf64-tradlittlemips elf32-powerpc aixcoff-rs6000 elf32-powerpcle ppcboot elf64-powerpc elf64-powerpcle aixcoff64-rs6000 aix5coff64-rs6000 elf32-s390 elf64-s390 elf32-sh-linux elf32-shbig-linux elf32-sparc a.out-sparc-linux elf64-sparc a.out-sunos-big xcoff-powermac mach-o-be mach-o-le mach-o-fat pef pef-xlib sym elf32-spu pe-x86-64 pe-i386 plugin srec symbolsrec verilog tekhex binary ihex
> Rejected C compiler flag because it was not compatible with shared linker ar using flags []
> Executing: /opt/cray/craype/2.4.2/bin/cc --help
> stdout:
> Usage: cc [options] file...
> Options:
> -[no]-add-rpath Controls whether or not '-Wl,-rpath' options
> are added for all pkg-config generated
> '-L' options. This can be useful to 'lock in'
> specific versions of libraries at runtime for
> dynamically linked applications.
> (Off by default.)
> -[no-]as-needed Controls whether or not '-l' options
> provided by the driver will be wrapped
> with '-Wl,--as-needed' and '-Wl,--no-as-needed'
> when possible to minimize unnecessary
> dependencies when linking dynamically.
> (On by default.)
> --cray-bypass-pkgconfig Disable linking PE libraries via pkg-config.
> --cray-print-opts[=option] Print the results generated by pkg-config.
> options:
> all print include and library information.
> cflags print include information.
> cray_ld_library_path print a dynamically generated
> CRAY_LD_LIBRARY_PATH.
> libs Print library information.
> pcfiles Print the pcfiles that pkg-config
> will be called with.
> pkg_config_path Print PKG_CONFIG_PATH used.
> variables Print the variables definitions that
> pkg-config will be called with.
> -craype-verbose Print the command which is forwarded
> to compiler invocation.
> -default64
> PGI: Passes the -i8 and -r8 options to the
> compiler. The -i8 option directs the compiler to
> use 64 bits for the data sizeof default integer
> and logical operations. The -r8 option directs
> the compiler to use 64 bits for the data size of
> default real variables.
> CCE:Passes the -sdefault64 option to the
> compiler. For CCE, the ftn command will also
> recognize the -sdefault64 option and perform the
> same functionality as the -default64 option.
> The -default64 option also arranges that
> appropriate 64-bit versions of the MPI & SHMEM
> libraries are used.
> -dynamic Directs the compiler driver to link dynamic
> libraries at runtime, rather than linking static
> libraries in at compile time. The linker stores
> the internal name of the dynamic library in the
> executable file. The actual library that is
> loaded at runtime must have the same internal
> name but, may differ from the filename of the
> library found at link time. This option is used
> to create dynamically linked executable files
> and may not be used with the -static or -shared
> options.
> -[no]-gcc-rpath Controls whether or not
> '-Wl,-rpath=/opt/cray/gcc-libs' is added to the
> link line when dynamically linking using gcc.
> This enables a user to run such an application
> without setting LD_LIBRARY_PATH or loading a
> gcc module.
> (On by default.)
> -help Print a description of the options understood
> by the craype driver.
> -shared Creates a library which may be dynamically
> linked at runtime.
> -static Directs the linker to use the static version
> of the libraries, not the dynamic version of
> the libraries, to create an executable file.
> (This is the default.)
> -target-accel=[ACCELERATOR] Set the desired accelerator target.
> -target-cpu=[CPU] Set the desired cpu optimization.
> The appropriate optimization flag will be passed
> to the compiler, and matching libraries will be
> linked in.
> -target-network=[NETWORK] Set the desired network target.
> OpenMP support:
> -homp Enables OpenMP and links in OpenMP libraries when
> possible using CCE.
> -hnoomp Disables OpenMP and links in non-OpenMP libraries
> when using CCE.
> -fopenmp Enables OpenMP and links in OpenMP libraries when
> possible using GNU.
> -openmp Enables OpenMP and links in OpenMP libraries when
> possible when using Intel.
> -mp Enables OpenMP and links in OpenMP libraries when
> possible using PGI.
> -Mnoopenmp Disables OpenMP and links in non-OpenMP libraries
> when using PGI.
> Trying C compiler flag -PIC
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 -PIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Possible ERROR while running compiler: exit code 256
> stderr:
> gcc: error: unrecognized command line option '-PIC'
> Source:
> int main() {
> return 0;
> Rejecting compiler flag -PIC due to nonzero status from link
> PETSc Error: No output file produced
> Rejected C compiler flag -PIC because it was not compatible with shared linker ar using flags []
> Trying C compiler flag -fPIC
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Successful compile:
> Source:
> int main() {
> return 0;
> Added C compiler flag -fPIC
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> stderr:
> ar -M [<mri-script]
> commands:
> s - act as ranlib
> generic modifiers:
> [v] - be verbose
> optional:
> emulation options:
> Rejected C compiler flag -fPIC because it was not compatible with shared linker ar using flags []
> Trying C compiler flag -KPIC
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 -KPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> stderr:
> gcc: error: unrecognized command line option '-KPIC'
> Source:
> int main() {
> return 0;
> Rejecting compiler flag -KPIC due to nonzero status from link
> Rejected C compiler flag -KPIC because it was not compatible with shared linker ar using flags []
> Trying C compiler flag -qpic
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 -qpic /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> stderr:
> gcc: error: unrecognized command line option '-qpic'
> Source:
> int main() {
> return 0;
> Rejecting compiler flag -qpic due to nonzero status from link
> Rejected C compiler flag -qpic because it was not compatible with shared linker ar using flags []
> Deleting "LD_SHARED"
> Executing: uname -s
> stdout: Linux
> Checking shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> Defined make macro "LD_SHARED" to "/opt/cray/craype/2.4.2/bin/cc"
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -shared -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Valid C linker flag -shared
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -shared -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /usr/bin/ld: /tmp/petsc-uoFdrH/config.setCompilers/conftest.o: relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.o: could not read symbols: Bad value
> Rejected C compiler flag because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -PIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -shared -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -shared -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Successful compile:
> Source:
> int foo(void);
> int main() {
> int ret = foo();
> if (ret) {}
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl -L/tmp/petsc-uoFdrH/config.setCompilers -lconftest
> stderr:
> /usr/bin/ld: cannot find -lconftest
> Rejected C compiler flag -fPIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -KPIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -qpic because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> Checking shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-dynamic']
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -dynamic -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /usr/bin/ld: warning: libintlc.so.5, needed by /opt/intel/composer_xe_2015.1.133/compiler/lib/intel64//libsvml.so, not found (try using -rpath or -rpath-link)
> Valid C linker flag -dynamic
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -dynamic -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /usr/lib/../lib64/crt1.o: In function `_start':
> /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:109: undefined reference to `main'
> Rejected C compiler flag because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-dynamic']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -PIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-dynamic']
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -dynamic -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -dynamic -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Rejected C compiler flag -fPIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-dynamic']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -KPIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-dynamic']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -qpic because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-dynamic']
> Checking shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-qmkshrobj']
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -qmkshrobj -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> gcc: error: unrecognized command line option '-qmkshrobj'
> Rejecting linker flag -qmkshrobj due to nonzero status from link
> Rejecting C linker flag -qmkshrobj due to
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /opt/intel/composer_xe_2015.1.133/compiler/lib/intel64//libifcore.a(for_main.o): In function `main':
> for_main.c:(.text+0x3e): undefined reference to `MAIN__'
> Rejected C compiler flag because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-qmkshrobj']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -PIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-qmkshrobj']
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -qmkshrobj -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -g -O0 -fPIC /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Rejected C compiler flag -fPIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-qmkshrobj']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -KPIC because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-qmkshrobj']
> stderr:
> Source:
> int main() {
> return 0;
> Rejected C compiler flag -qpic because it was not compatible with shared linker /opt/cray/craype/2.4.2/bin/cc using flags ['-qmkshrobj']
> Checking for program /opt/cray/craype/2.4.2/bin/cc...found
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.c: In function '__declspec':
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.c:5:29: error: expected declaration specifiers before 'foo'
> void __declspec(dllexport) foo(void){
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.c:9:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.c:5:6: warning: type of 'dllexport' defaults to 'int' [-Wimplicit-int]
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.c:9:15: error: expected '{' at end of input
> Source:
> #include <stdio.h>
> return;
> Compile failed inside link
> stderr:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Source:
> #include <stdio.h>
> return;
> stderr:
> Source:
> int main() {
> return 0;
> stderr:
> Source:
> int main() {
> return 0;
> Executing: uname -s
> stdout: Linux
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> Checking shared linker /usr/bin/ar using flags []
> Defined make macro "LD_SHARED" to "/usr/bin/ar"
> Successful compile:
> Source:
> int main() {
> return 0;
> Successful compile:
> Source:
> #include <stdio.h>
> void foo(void){
> return;
> Pushing language C
> Popping language C
> Executing: /usr/bin/ar cr /tmp/petsc-uoFdrH/config.setCompilers/libconftest.a /tmp/petsc-uoFdrH/config.setCompilers/conftest.o ; /usr/bin/ranlib /tmp/petsc-uoFdrH/config.setCompilers/libconftest.a
> Successful compile:
> Source:
> int foo(void);
> int main() {
> int ret = foo();
> if (ret) {}
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl -L/tmp/petsc-uoFdrH/config.setCompilers -lconftest
> Using shared linker /usr/bin/ar with flags [] and library extension a
> Executing: uname -s
> stdout: Linux
> TEST checkPIC from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1044)
> TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1044)
> Determine the PIC option for each compiler
> Skip checking PIC options on user request
> TEST checkSharedLinkerPaths from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1392)
> TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1392)
> Determine the shared linker path options
> - IRIX: -rpath
> - Linux, OSF: -Wl,-rpath,
> - Solaris: -R
> - FreeBSD: -Wl,-R,
> Pushing language C
> Executing: uname -s
> stdout: Linux
> Executing: /opt/cray/craype/2.4.2/bin/cc -V
> Trying C linker flag -Wl,-rpath,
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -Wl,-rpath,/home/zampins/src/petsc -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Valid C linker flag -Wl,-rpath,/home/zampins/src/petsc
> Popping language C
> Executing: uname -s
> stdout: Linux
> Trying Cxx linker flag -Wl,-rpath,
> Successful compile:
> Source:
> int main() {
> return 0;
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -Wl,-rpath,/home/zampins/src/petsc -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Valid Cxx linker flag -Wl,-rpath,/home/zampins/src/petsc
> Pushing language FC
> Executing: uname -s
> stdout: Linux
> Trying FC linker flag -Wl,-rpath,
> Successful compile:
> Source:
> program main
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -Wl,-rpath,/home/zampins/src/petsc -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Valid FC linker flag -Wl,-rpath,/home/zampins/src/petsc
> Popping language FC
> TEST checkLibC from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1427)
> TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1427)
> Test whether we need to explicitly include libc in shared linking
> - Mac OSX requires an explicit reference to libc for shared linking
> TEST checkDynamicLinker from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1476)
> TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1476)
> Check that the linker can dynamicaly load shared libraries
> Checking for header: dlfcn.h
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.headers
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/usr/include/dlfcn.h" 1 3 4
> # 23 "/usr/include/dlfcn.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 24 "/usr/include/dlfcn.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 26 "/usr/include/dlfcn.h" 2 3 4
> # 1 "/usr/include/bits/dlfcn.h" 1 3 4
> # 29 "/usr/include/dlfcn.h" 2 3 4
> # 53 "/usr/include/dlfcn.h" 3 4
> extern void *dlopen (__const char *__file, int __mode) __attribute__ ((__nothrow__));
> extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern void *dlsym (void *__restrict __handle,
> __const char *__restrict __name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> # 83 "/usr/include/dlfcn.h" 3 4
> extern char *dlerror (void) __attribute__ ((__nothrow__));
> # 189 "/usr/include/dlfcn.h" 3 4
> Defined "HAVE_DLFCN_H" to "1"
> Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.libraries
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> /* Override any gcc2 internal prototype to avoid an error. */
> char dlopen();
> static void _check_dlopen() { dlopen(); }
> char dlsym();
> static void _check_dlsym() { dlsym(); }
> char dlclose();
> static void _check_dlclose() { dlclose(); }
> int main() {
> _check_dlopen();
> _check_dlsym();
> _check_dlclose();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Possible ERROR while running linker:
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_dlopen':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Defined "HAVE_LIBDL" to "1"
> Popping language C
> Adding ['dl'] to LIBS
> Executing: uname -s
> stdout: Linux
> Checking dynamic linker /usr/bin/ar using flags []
> Defined make macro "DYNAMICLINKER" to "/usr/bin/ar"
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Successful compile:
> Source:
> #include <stdio.h>
> int foo(void) {printf("test");return 0;}
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> Pushing language C
> Popping language C
> Executing: /usr/bin/ar -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Possible ERROR while running linker: exit code 256
> stderr:
> /usr/bin/ar: invalid option -- 'L'
> Usage: /usr/bin/ar [emulation options] [-]{dmpqrstx}[abcDfilMNoPsSTuvV] [--plugin <name>] [member-name] [count] archive-file file...
> /usr/bin/ar -M [<mri-script]
> commands:
> s - act as ranlib
> generic modifiers:
> [v] - be verbose
> optional:
> emulation options:
> /usr/bin/ar: supported targets: elf64-x86-64 elf32-i386 elf32-x86-64 a.out-i386-linux pei-i386 pei-x86-64 elf64-l1om elf64-k1om elf64-little elf64-big elf32-little elf32-big elf64-littleaarch64 elf64-bigaarch64 elf32-littlearm elf32-bigarm elf64-alpha ecoff-littlealpha elf32-hppa-linux elf32-hppa elf64-hppa-linux elf64-hppa elf64-ia64-little elf64-ia64-big pei-ia64 elf32-m68k a.out-m68k-linux elf32-tradbigmips elf32-tradlittlemips ecoff-bigmips ecoff-littlemips elf32-ntradbigmips elf64-tradbigmips elf32-ntradlittlemips elf64-tradlittlemips elf32-powerpc aixcoff-rs6000 elf32-powerpcle ppcboot elf64-powerpc elf64-powerpcle aixcoff64-rs6000 aix5coff64-rs6000 elf32-s390 elf64-s390 elf32-sh-linux elf32-shbig-linux elf32-sparc a.out-sparc-linux elf64-sparc a.out-sunos-big xcoff-powermac mach-o-be mach-o-le mach-o-fat pef pef-xlib sym elf32-spu pe-x86-64 pe-i386 plugin srec symbolsrec verilog tekhex binary ihex
> Checking dynamic linker /opt/cray/craype/2.4.2/bin/cc using flags ['-shared']
> Defined make macro "DYNAMICLINKER" to "/opt/cray/craype/2.4.2/bin/cc"
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/conftest -shared -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Successful compile:
> Source:
> #include <stdio.h>
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.setCompilers/libconftest.so -shared -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> collect2: error: ld returned 1 exit status
> Unable to find working dynamic linker
> TEST output from config.setCompilers(/home/zampins/src/petsc/config/BuildSystem/config/setCompilers.py:1528)
> TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1528)
> Output module data as defines and substitutions
> Substituting "CC" with "/opt/cray/craype/2.4.2/bin/cc"
> Substituting "CFLAGS" with "-g -O0 "
> Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
> Substituting "CPP" with "/opt/cray/craype/2.4.2/bin/cc -E"
> Substituting "CPPFLAGS" with ""
> Substituting "CXX" with "/opt/cray/craype/2.4.2/bin/CC"
> Substituting "CXX_CXXFLAGS" with ""
> Substituting "CXXFLAGS" with "-g -O0"
> Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
> Substituting "CXXCPP" with "/opt/cray/craype/2.4.2/bin/CC -E"
> Substituting "CXXCPPFLAGS" with ""
> Substituting "FC" with "/opt/cray/craype/2.4.2/bin/ftn"
> Substituting "FFLAGS" with "-g -O0"
> Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
> Substituting "LDFLAGS" with ""
> Substituting "LIBS" with "-ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl"
> Substituting "SHARED_LIBRARY_FLAG" with ""
> TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/home/zampins/src/petsc/config/PETSc/options/sharedLibraries.py:37)
> TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
> TEST configureSharedLibraries from PETSc.options.sharedLibraries(/home/zampins/src/petsc/config/PETSc/options/sharedLibraries.py:53)
> TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
> Checks whether shared libraries should be used, for which you must
> - Specify --with-shared-libraries
> - Have found a working shared linker
> Defines PETSC_USE_SHARED_LIBRARIES if they are used
> Defined make rule "shared_arch" with dependencies "" and code []
> Defined make macro "BUILDSHAREDLIB" to "no"
> Defined "HAVE_SHARED_LIBRARIES" to "1"
> Shared libraries - disabled
> TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/home/zampins/src/petsc/config/PETSc/options/sharedLibraries.py:99)
> TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:99)
> Checks whether dynamic loading is available (with dlfcn.h and libdl)
> TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/home/zampins/src/petsc/config/PETSc/options/sharedLibraries.py:105)
> TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:105)
> Defines PETSC_SERIALIZE_FUNCTIONS if they are used
> Requires shared libraries
> TEST configureIndexSize from PETSc.options.indexTypes(/home/zampins/src/petsc/config/PETSc/options/indexTypes.py:31)
> TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
> Defined make macro "PETSC_INDEX_SIZE" to "32"
> TEST configureCompilerFlags from config.compilerFlags(/home/zampins/src/petsc/config/BuildSystem/config/compilerFlags.py:72)
> TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:72)
> Get the default compiler flags
> Ignoring default options which were overridden using --CFLAGS -g -O0
> Optimization options found in CFLAGS. Skipping setting defaults
> Ignoring default options which were overridden using --CXXFLAGS -g -O0
> Optimization options found in CXXFLAGS. Skipping setting defaults
> Ignoring default options which were overridden using --FFLAGS -g -O0
> Optimization options found in FFLAGS. Skipping setting defaults
> Pushing language C
> Popping language C
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/cc --version
> stdout:
> gcc (GCC) 5.1.0 20150422 (Cray Inc.)
> Copyright (C) 2015 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> getCompilerVersion: /opt/cray/craype/2.4.2/bin/cc gcc (GCC) 5.1.0 20150422 (Cray Inc.)
> Executing: /opt/cray/craype/2.4.2/bin/CC --version
> stdout:
> g++ (GCC) 5.1.0 20150422 (Cray Inc.)
> getCompilerVersion: /opt/cray/craype/2.4.2/bin/CC g++ (GCC) 5.1.0 20150422 (Cray Inc.)
> Executing: /opt/cray/craype/2.4.2/bin/ftn --version
> stdout:
> GNU Fortran (GCC) 5.1.0 20150422 (Cray Inc.)
> GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
> You may redistribute copies of GNU Fortran
> under the terms of the GNU General Public License.
> For more information about these matters, see the file named COPYING
> getCompilerVersion: /opt/cray/craype/2.4.2/bin/ftn GNU Fortran (GCC) 5.1.0 20150422 (Cray Inc.)
> TEST configureDebugging from PETSc.options.debugging(/home/zampins/src/petsc/config/PETSc/options/debugging.py:25)
> TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
> Defined "USE_ERRORCHECKING" to "1"
> TEST checkRestrict from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:137)
> TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:137)
> Check for the C/CXX restrict keyword
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.compilers
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.c
> Successful compile:
> Source:
> int main() {
> float * __restrict x;;
> return 0;
> compilers: Set C restrict keyword to __restrict
> Defined "C_RESTRICT" to "__restrict"
> Popping language C
> TEST checkCFormatting from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:322)
> TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:322)
> Activate format string checking if using the GNU compilers
> TEST checkCStaticInline from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:108)
> TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:108)
> Check for C keyword: static inline
> Pushing language C
> Successful compile:
> Source:
> static inline int foo(int a) {return a;}
> int main() {
> foo(1);;
> return 0;
> compilers: Set C StaticInline keyword to static inline
> Popping language C
> Defined "C_STATIC_INLINE" to "static inline"
> TEST checkDynamicLoadFlag from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:333)
> TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:333)
> Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
> TEST checkDependencyGenerationFlag from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1389)
> TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1389)
> Check if -MMD works for dependency generation, and add it if it does
> Skip checking dependency compiler options on user request
> TEST checkC99Flag from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1435)
> TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1435)
> Check for -std=c99 or equivalent flag
> Accepted C99 compile flag:
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Successful compile:
> Source:
> #include <float.h>
> int main() {
> float x[2],y;
> y = FLT_ROUNDS;
> // c++ comment
> int j = 2;
> for (int i=0; i<2; i++){
> x[i] = i*j*y;
> return 0;
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/CC --help
> stdout:
> Usage: CC [options] file...
> Options:
> (Off by default.)
> (On by default.)
> options:
> -default64
> libraries are used.
> options.
> gcc module.
> (On by default.)
> linked at runtime.
> linked in.
> OpenMP support:
> possible using CCE.
> when using CCE.
> possible using GNU.
> possible using PGI.
> when using PGI.
> Pushing language Cxx
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.cc
> Successful compile:
> Source:
> int main() {
> return 0;
> compilers: Set Cxx restrict keyword to __restrict
> Defined "CXX_RESTRICT" to "__restrict"
> Popping language Cxx
> TEST checkCxxNamespace from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:373)
> TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:373)
> Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
> Successful compile:
> Source:
> namespace petsc {int dummy;}
> int main() {
> return 0;
> Successful compile:
> Source:
> template <class dummy> struct a {};
> namespace trouble{
> template <class dummy> struct a : public ::a<dummy> {};
> trouble::a<int> uugh;
> int main() {
> return 0;
> compilers: C++ has namespaces
> Defined "HAVE_CXX_NAMESPACE" to "1"
> TEST checkCxxOptionalExtensions from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:346)
> TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:346)
> Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.c
> Successful compile:
> Source:
> int main() {
> class somename { int i; };;
> return 0;
> Added Cxx compiler flag
> TEST checkCxxStaticInline from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:122)
> TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:122)
> Check for C++ keyword: static inline
> Successful compile:
> Source:
> int main() {
> foo(1);;
> return 0;
> compilers: Set Cxx StaticInline keyword to static inline
> Defined "CXX_STATIC_INLINE" to "static inline"
> TEST checkCxx11 from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:388)
> TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:388)
> Determine the option needed to support the C++11 dialect
> We auto-detect C++11 if the compiler supports it without options,
> otherwise we require with-cxx-dialect=C++11 to try adding flags to
> support it.
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc
> stderr:
> In file included from /opt/gcc/5.1.0/snos/include/g++/random:35:0,
> from /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:4:
> /opt/gcc/5.1.0/snos/include/g++/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
> #error This file requires compiler and library support for the \
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:5:32: error: 'constexpr' does not name a type
> template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:5:32: note: C++11 'constexpr' only available with -std=c++11 or -std=gnu++11
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc: In function 'int main()':
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:10:11: error: 'random_device' is not a member of 'std'
> std::random_device rd;
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:11:11: error: 'mt19937' is not a member of 'std'
> std::mt19937 mt(rd());
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:12:11: error: 'normal_distribution' is not a member of 'std'
> std::normal_distribution<double> dist(0,1);
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:12:36: error: expected primary-expression before 'double'
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:13:33: error: 'mt' was not declared in this scope
> const double x = dist(mt);
> /tmp/petsc-uoFdrH/config.setCompilers/conftest.cc:13:35: error: 'dist' was not declared in this scope
> Source:
> #include <random>
> int main() {
> return 0;
> Rejecting compiler flag due to nonzero status from link
> TEST checkFortranTypeSizes from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:594)
> TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:594)
> Check whether real*8 is supported and suggest flags which will allow support
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.F90
> Successful compile:
> Source:
> program main
> real*8 variable
> end
> Popping language FC
> TEST checkFortranNameMangling from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:653)
> TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:653)
> Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
> Testing Fortran mangling type underscore with code void d1chk_(void){return;}
> Pushing language C
> Successful compile:
> Source:
> Popping language C
> Pushing language FC
> Successful compile:
> Source:
> program main
> call d1chk()
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.compilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.o /tmp/petsc-uoFdrH/config.compilers/confc.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language FC
> compilers: Fortran name mangling is underscore
> Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
> TEST checkFortranNameManglingDouble from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:690)
> TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:690)
> Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
> Pushing language C
> Successful compile:
> Source:
> void d1_chk__(void){return;}
> Popping language C
> Pushing language FC
> Successful compile:
> Source:
> program main
> call d1_chk()
> end
> Pushing language FC
> Popping language FC
> stderr:
> /tmp/petsc-uoFdrH/config.compilers/conftest.o: In function `MAIN__':
> /tmp/petsc-uoFdrH/config.compilers/conftest.F90:2: undefined reference to `d1_chk_'
> Popping language FC
> TEST checkFortranPreprocessor from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:700)
> TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:700)
> Determine if Fortran handles preprocessing properly
> compilers: Fortran uses CPP preprocessor
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.setCompilers/conftest.F90
> Successful compile:
> Source:
> program main
> #define dummy
> dummy
> #ifndef dummy
> fooey
> #endif
> end
> Added FC compiler flag
> Popping language FC
> TEST checkFortranDefineCompilerOption from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:724)
> TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:724)
> Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
> Defined make macro "FC_DEFINE_FLAG" to "-D"
> compilers: Fortran uses -D for defining macro
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.setCompilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -g -O0 -DTesting /tmp/petsc-uoFdrH/config.setCompilers/conftest.F90
> Successful compile:
> Source:
> program main
> #define dummy
> dummy
> #ifndef Testing
> fooey
> #endif
> end
> Popping language FC
> TEST checkFortranLinkingCxx from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1095)
> TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1095)
> Check that Fortran can be linked against C++
> Successful compile:
> Source:
> extern "C" void d1chk_(void);
> void foo(void){d1chk_();}
> Successful compile:
> Source:
> Pushing language FC
> Successful compile:
> Source:
> program main
> call d1chk()
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.compilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.o /tmp/petsc-uoFdrH/config.compilers/cxxobj.o /tmp/petsc-uoFdrH/config.compilers/confc.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language FC
> compilers: Fortran can link C++ functions
> TEST checkFortran90 from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1130)
> TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1130)
> Determine whether the Fortran compiler handles F90
> Pushing language FC
> Successful compile:
> Source:
> program main
> INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
> INTEGER (KIND=int) :: ierr
> ierr = 1
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.compilers/conftest -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "USING_F90" to "1"
> Fortran compiler supports F90
> Popping language FC
> TEST checkFortran90FreeForm from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1143)
> TESTING: checkFortran90FreeForm from config.compilers(config/BuildSystem/config/compilers.py:1143)
> Determine whether the Fortran compiler handles F90FreeForm
> We also require that the compiler handles lines longer than 132 characters
> Pushing language FC
> stderr:
> /tmp/petsc-uoFdrH/config.compilers/conftest.F90:2:132:
> INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8); INTEGER (KIND=int) :: ierr; ierr = 1
> 1
> Error: Line truncated at (1) [-Werror=line-truncation]
> /tmp/petsc-uoFdrH/config.compilers/conftest.F90:2:110:
> 1
> Error: Unclassifiable statement at (1)
> f951: some warnings being treated as errors
> Source:
> program main
> end
> Fortran compiler does not support F90FreeForm
> Popping language FC
> TEST checkFortran2003 from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1157)
> TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1157)
> Determine whether the Fortran compiler handles F2003
> Pushing language FC
> Successful compile:
> Source:
> module Base_module
> type, public :: base_type
> integer :: A
> contains
> procedure, public :: Print => BasePrint
> end type base_type
> contains
> subroutine BasePrint(this)
> class(base_type) :: this
> end subroutine BasePrint
> end module Base_module
> program main
> use,intrinsic :: iso_c_binding
> Type(C_Ptr),Dimension(:),Pointer :: CArray
> character(kind=c_char),pointer :: nullc => null()
> character(kind=c_char,len=5),dimension(:),pointer::list1
> allocate(list1(5))
> CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
> end
> Pushing language FC
> Popping language FC
> Defined "USING_F2003" to "1"
> Fortran compiler supports F2003
> Popping language FC
> TEST checkFortran90Array from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1191)
> TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1191)
> Check for F90 array interfaces
> Executing: /opt/cray/craype/2.4.2/bin/ftn -V
> compilers: Using --with-batch, so guess that F90 uses a single argument for array pointers
> TEST checkFortranModuleInclude from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1278)
> TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1278)
> Figures out what flag is used to specify the include path for Fortran modules
> Pushing language FC
> Successful compile:
> Source:
> module configtest
> integer testint
> parameter (testint = 42)
> end module configtest
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.compilers/confdir -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.F90
> Successful compile:
> Source:
> program main
> use configtest
> write(*,*) testint
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.compilers/conftest -I/tmp/petsc-uoFdrH/config.compilers/confdir -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.o /tmp/petsc-uoFdrH/config.compilers/configtest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> compilers: Fortran module include flag -I found
> Popping language FC
> TEST checkFortranModuleOutput from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1344)
> TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1344)
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -module /tmp/petsc-uoFdrH/config.compilers/confdir -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.F90
> stderr:
> gfortran: error: unrecognized command line option '-module'
> Source:
> module configtest
> integer testint
> compilers: Fortran module output flag -module compile failed
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -module:/tmp/petsc-uoFdrH/config.compilers/confdir -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.F90
> stderr:
> gfortran: error: unrecognized command line option '-module:/tmp/petsc-uoFdrH/config.compilers/confdir'
> Source:
> module configtest
> integer testint
> compilers: Fortran module output flag -module: compile failed
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -fmod=/tmp/petsc-uoFdrH/config.compilers/confdir -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.F90
> stderr:
> gfortran: error: unrecognized command line option '-fmod=/tmp/petsc-uoFdrH/config.compilers/confdir'
> Source:
> module configtest
> integer testint
> compilers: Fortran module output flag -fmod= compile failed
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.compilers/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -J/tmp/petsc-uoFdrH/config.compilers/confdir -g -O0 /tmp/petsc-uoFdrH/config.compilers/conftest.F90
> Successful compile:
> Source:
> module configtest
> integer testint
> compilers: Fortran module output flag -J found
> Popping language FC
> TEST setupFrameworkCompilers from config.compilers(/home/zampins/src/petsc/config/BuildSystem/config/compilers.py:1503)
> TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1503)
> TEST configureClosure from config.utilities.closure(/home/zampins/src/petsc/config/BuildSystem/config/utilities/closure.py:18)
> TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
> Determine if Apple ^close syntax is supported in C
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.utilities.closure
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.utilities.closure/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.utilities.closure -g -O0 /tmp/petsc-uoFdrH/config.utilities.closure/conftest.c
> stderr:
> /tmp/petsc-uoFdrH/config.utilities.closure/conftest.c: In function 'main':
> /tmp/petsc-uoFdrH/config.utilities.closure/conftest.c:6:6: error: expected identifier or '(' before '^' token
> int (^closure)(int);;
> Source:
> #include <stdio.h>
> int main() {
> return 0;
> TEST configureFortranCPP from PETSc.options.fortranCPP(/home/zampins/src/petsc/config/PETSc/options/fortranCPP.py:21)
> TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:21)
> Handle case where Fortran cannot preprocess properly
> Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
> Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
> Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
> Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
> TEST checkStdC from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:105)
> TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.headers/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.headers -g -O0 /tmp/petsc-uoFdrH/config.headers/conftest.c
> Successful compile:
> Source:
> #include <stdlib.h>
> #include <stdarg.h>
> #include <string.h>
> #include <float.h>
> int main() {
> return 0;
> Source:
> #include <string.h>
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/string.h" 1 3 4
> # 26 "/usr/include/string.h" 3 4
> # 27 "/usr/include/string.h" 2 3 4
> # 34 "/usr/include/string.h" 2 3 4
> extern void *memcpy (void *__restrict __dest,
> __const void *__restrict __src, size_t __n)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern void *memmove (void *__dest, __const void *__src, size_t __n)
> extern void *memccpy (void *__restrict __dest, __const void *__restrict __src,
> int __c, size_t __n)
> extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int memcmp (__const void *__s1, __const void *__s2, size_t __n)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
> # 94 "/usr/include/string.h" 3 4
> extern void *memchr (__const void *__s, int __c, size_t __n)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
> # 125 "/usr/include/string.h" 3 4
> extern char *strcpy (char *__restrict __dest, __const char *__restrict __src)
> extern char *strncpy (char *__restrict __dest,
> __const char *__restrict __src, size_t __n)
> extern char *strcat (char *__restrict __dest, __const char *__restrict __src)
> extern char *strncat (char *__restrict __dest, __const char *__restrict __src,
> size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int strcmp (__const char *__s1, __const char *__s2)
> extern int strncmp (__const char *__s1, __const char *__s2, size_t __n)
> extern int strcoll (__const char *__s1, __const char *__s2)
> extern size_t strxfrm (char *__restrict __dest,
> # 1 "/usr/include/xlocale.h" 1 3 4
> # 28 "/usr/include/xlocale.h" 3 4
> typedef struct __locale_struct
> struct locale_data *__locales[13];
> const unsigned short int *__ctype_b;
> const int *__ctype_tolower;
> const int *__ctype_toupper;
> const char *__names[13];
> } *__locale_t;
> typedef __locale_t locale_t;
> # 162 "/usr/include/string.h" 2 3 4
> extern int strcoll_l (__const char *__s1, __const char *__s2, __locale_t __l)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
> extern size_t strxfrm_l (char *__dest, __const char *__src, size_t __n,
> __locale_t __l) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 4)));
> extern char *strdup (__const char *__s)
> __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
> extern char *strndup (__const char *__string, size_t __n)
> # 208 "/usr/include/string.h" 3 4
> # 233 "/usr/include/string.h" 3 4
> extern char *strchr (__const char *__s, int __c)
> # 260 "/usr/include/string.h" 3 4
> extern char *strrchr (__const char *__s, int __c)
> # 279 "/usr/include/string.h" 3 4
> extern size_t strcspn (__const char *__s, __const char *__reject)
> extern size_t strspn (__const char *__s, __const char *__accept)
> # 312 "/usr/include/string.h" 3 4
> extern char *strpbrk (__const char *__s, __const char *__accept)
> # 340 "/usr/include/string.h" 3 4
> extern char *strstr (__const char *__haystack, __const char *__needle)
> extern char *strtok (char *__restrict __s, __const char *__restrict __delim)
> extern char *__strtok_r (char *__restrict __s,
> __const char *__restrict __delim,
> char **__restrict __save_ptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 3)));
> extern char *strtok_r (char *__restrict __s, __const char *__restrict __delim,
> # 395 "/usr/include/string.h" 3 4
> extern size_t strlen (__const char *__s)
> extern size_t strnlen (__const char *__string, size_t __maxlen)
> extern char *strerror (int __errnum) __attribute__ ((__nothrow__));
> # 425 "/usr/include/string.h" 3 4
> extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__))
> # 443 "/usr/include/string.h" 3 4
> extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__));
> extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern void bcopy (__const void *__src, void *__dest, size_t __n)
> extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int bcmp (__const void *__s1, __const void *__s2, size_t __n)
> # 487 "/usr/include/string.h" 3 4
> extern char *index (__const char *__s, int __c)
> # 515 "/usr/include/string.h" 3 4
> extern char *rindex (__const char *__s, int __c)
> extern int ffs (int __i) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> # 534 "/usr/include/string.h" 3 4
> extern int strcasecmp (__const char *__s1, __const char *__s2)
> extern int strncasecmp (__const char *__s1, __const char *__s2, size_t __n)
> # 557 "/usr/include/string.h" 3 4
> extern char *strsep (char **__restrict __stringp,
> extern char *strsignal (int __sig) __attribute__ ((__nothrow__));
> extern char *__stpcpy (char *__restrict __dest, __const char *__restrict __src)
> extern char *stpcpy (char *__restrict __dest, __const char *__restrict __src)
> extern char *__stpncpy (char *__restrict __dest,
> extern char *stpncpy (char *__restrict __dest,
> # 644 "/usr/include/string.h" 3 4
> Source:
> #include <stdlib.h>
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/stdlib.h" 1 3 4
> # 25 "/usr/include/stdlib.h" 3 4
> # 26 "/usr/include/stdlib.h" 2 3 4
> # 328 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef int wchar_t;
> # 34 "/usr/include/stdlib.h" 2 3 4
> # 96 "/usr/include/stdlib.h" 3 4
> typedef struct
> int quot;
> int rem;
> } div_t;
> typedef struct
> long int quot;
> long int rem;
> } ldiv_t;
> __extension__ typedef struct
> long long int quot;
> long long int rem;
> } lldiv_t;
> # 140 "/usr/include/stdlib.h" 3 4
> extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__)) ;
> extern double atof (__const char *__nptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
> extern int atoi (__const char *__nptr)
> extern long int atol (__const char *__nptr)
> __extension__ extern long long int atoll (__const char *__nptr)
> extern double strtod (__const char *__restrict __nptr,
> char **__restrict __endptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern float strtof (__const char *__restrict __nptr,
> char **__restrict __endptr) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern long double strtold (__const char *__restrict __nptr,
> extern long int strtol (__const char *__restrict __nptr,
> char **__restrict __endptr, int __base)
> extern unsigned long int strtoul (__const char *__restrict __nptr,
> __extension__
> extern long long int strtoq (__const char *__restrict __nptr,
> __extension__
> extern unsigned long long int strtouq (__const char *__restrict __nptr,
> __extension__
> extern long long int strtoll (__const char *__restrict __nptr,
> __extension__
> extern unsigned long long int strtoull (__const char *__restrict __nptr,
> # 311 "/usr/include/stdlib.h" 3 4
> extern char *l64a (long int __n) __attribute__ ((__nothrow__)) ;
> extern long int a64l (__const char *__s)
> # 1 "/usr/include/sys/types.h" 1 3 4
> # 29 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/types.h" 1 3 4
> # 28 "/usr/include/bits/types.h" 3 4
> # 29 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned char __u_char;
> typedef unsigned short int __u_short;
> typedef unsigned int __u_int;
> typedef unsigned long int __u_long;
> typedef signed char __int8_t;
> typedef unsigned char __uint8_t;
> typedef signed short int __int16_t;
> typedef unsigned short int __uint16_t;
> typedef signed int __int32_t;
> typedef unsigned int __uint32_t;
> typedef signed long int __int64_t;
> typedef unsigned long int __uint64_t;
> typedef long int __quad_t;
> typedef unsigned long int __u_quad_t;
> # 131 "/usr/include/bits/types.h" 3 4
> # 1 "/usr/include/bits/typesizes.h" 1 3 4
> # 132 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned long int __dev_t;
> typedef unsigned int __uid_t;
> typedef unsigned int __gid_t;
> typedef unsigned long int __ino_t;
> typedef unsigned long int __ino64_t;
> typedef unsigned int __mode_t;
> typedef unsigned long int __nlink_t;
> typedef long int __off_t;
> typedef long int __off64_t;
> typedef int __pid_t;
> typedef struct { int __val[2]; } __fsid_t;
> typedef long int __clock_t;
> typedef unsigned long int __rlim_t;
> typedef unsigned long int __rlim64_t;
> typedef unsigned int __id_t;
> typedef long int __time_t;
> typedef unsigned int __useconds_t;
> typedef long int __suseconds_t;
> typedef int __daddr_t;
> typedef long int __swblk_t;
> typedef int __key_t;
> typedef int __clockid_t;
> typedef void * __timer_t;
> typedef long int __blksize_t;
> typedef long int __blkcnt_t;
> typedef long int __blkcnt64_t;
> typedef unsigned long int __fsblkcnt_t;
> typedef unsigned long int __fsblkcnt64_t;
> typedef unsigned long int __fsfilcnt_t;
> typedef unsigned long int __fsfilcnt64_t;
> typedef long int __ssize_t;
> typedef __off64_t __loff_t;
> typedef __quad_t *__qaddr_t;
> typedef char *__caddr_t;
> typedef long int __intptr_t;
> typedef unsigned int __socklen_t;
> # 32 "/usr/include/sys/types.h" 2 3 4
> typedef __u_char u_char;
> typedef __u_short u_short;
> typedef __u_int u_int;
> typedef __u_long u_long;
> typedef __quad_t quad_t;
> typedef __u_quad_t u_quad_t;
> typedef __fsid_t fsid_t;
> typedef __loff_t loff_t;
> typedef __ino_t ino_t;
> # 62 "/usr/include/sys/types.h" 3 4
> typedef __dev_t dev_t;
> typedef __gid_t gid_t;
> typedef __mode_t mode_t;
> typedef __nlink_t nlink_t;
> typedef __uid_t uid_t;
> typedef __off_t off_t;
> # 100 "/usr/include/sys/types.h" 3 4
> typedef __pid_t pid_t;
> typedef __id_t id_t;
> typedef __ssize_t ssize_t;
> typedef __daddr_t daddr_t;
> typedef __caddr_t caddr_t;
> typedef __key_t key_t;
> # 133 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/time.h" 1 3 4
> # 74 "/usr/include/time.h" 3 4
> typedef __time_t time_t;
> # 92 "/usr/include/time.h" 3 4
> typedef __clockid_t clockid_t;
> # 104 "/usr/include/time.h" 3 4
> typedef __timer_t timer_t;
> # 134 "/usr/include/sys/types.h" 2 3 4
> # 147 "/usr/include/sys/types.h" 3 4
> # 148 "/usr/include/sys/types.h" 2 3 4
> typedef unsigned long int ulong;
> typedef unsigned short int ushort;
> typedef unsigned int uint;
> # 195 "/usr/include/sys/types.h" 3 4
> typedef int int8_t __attribute__ ((__mode__ (__QI__)));
> typedef int int16_t __attribute__ ((__mode__ (__HI__)));
> typedef int int32_t __attribute__ ((__mode__ (__SI__)));
> typedef int int64_t __attribute__ ((__mode__ (__DI__)));
> typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
> typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
> typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
> typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
> typedef int register_t __attribute__ ((__mode__ (__word__)));
> # 217 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/endian.h" 1 3 4
> # 37 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/endian.h" 1 3 4
> # 38 "/usr/include/endian.h" 2 3 4
> # 61 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/byteswap.h" 1 3 4
> # 28 "/usr/include/bits/byteswap.h" 3 4
> # 29 "/usr/include/bits/byteswap.h" 2 3 4
> # 62 "/usr/include/endian.h" 2 3 4
> # 218 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/select.h" 1 3 4
> # 31 "/usr/include/sys/select.h" 3 4
> # 1 "/usr/include/bits/select.h" 1 3 4
> # 23 "/usr/include/bits/select.h" 3 4
> # 24 "/usr/include/bits/select.h" 2 3 4
> # 32 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/sigset.h" 1 3 4
> # 24 "/usr/include/bits/sigset.h" 3 4
> typedef int __sig_atomic_t;
> typedef struct
> unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
> } __sigset_t;
> # 35 "/usr/include/sys/select.h" 2 3 4
> typedef __sigset_t sigset_t;
> # 120 "/usr/include/time.h" 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 45 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/time.h" 1 3 4
> # 69 "/usr/include/bits/time.h" 3 4
> struct timeval
> __time_t tv_sec;
> __suseconds_t tv_usec;
> # 47 "/usr/include/sys/select.h" 2 3 4
> typedef __suseconds_t suseconds_t;
> typedef long int __fd_mask;
> # 67 "/usr/include/sys/select.h" 3 4
> typedef struct
> __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
> } fd_set;
> typedef __fd_mask fd_mask;
> # 99 "/usr/include/sys/select.h" 3 4
> # 109 "/usr/include/sys/select.h" 3 4
> extern int select (int __nfds, fd_set *__restrict __readfds,
> fd_set *__restrict __writefds,
> fd_set *__restrict __exceptfds,
> struct timeval *__restrict __timeout);
> # 121 "/usr/include/sys/select.h" 3 4
> extern int pselect (int __nfds, fd_set *__restrict __readfds,
> const struct timespec *__restrict __timeout,
> const __sigset_t *__restrict __sigmask);
> # 221 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/sysmacros.h" 1 3 4
> # 30 "/usr/include/sys/sysmacros.h" 3 4
> __extension__
> extern unsigned int gnu_dev_major (unsigned long long int __dev)
> __extension__
> extern unsigned int gnu_dev_minor (unsigned long long int __dev)
> __extension__
> extern unsigned long long int gnu_dev_makedev (unsigned int __major,
> unsigned int __minor)
> # 224 "/usr/include/sys/types.h" 2 3 4
> # 235 "/usr/include/sys/types.h" 3 4
> typedef __blkcnt_t blkcnt_t;
> typedef __fsblkcnt_t fsblkcnt_t;
> typedef __fsfilcnt_t fsfilcnt_t;
> # 270 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
> # 23 "/usr/include/bits/pthreadtypes.h" 3 4
> # 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
> # 50 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef unsigned long int pthread_t;
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> typedef struct __pthread_internal_list
> struct __pthread_internal_list *__prev;
> struct __pthread_internal_list *__next;
> } __pthread_list_t;
> # 76 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef union
> struct __pthread_mutex_s
> int __lock;
> unsigned int __count;
> int __owner;
> unsigned int __nusers;
> int __kind;
> int __spins;
> __pthread_list_t __list;
> # 101 "/usr/include/bits/pthreadtypes.h" 3 4
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_mutexattr_t;
> typedef union
> struct
> int __lock;
> unsigned int __futex;
> __extension__ unsigned long long int __total_seq;
> __extension__ unsigned long long int __wakeup_seq;
> __extension__ unsigned long long int __woken_seq;
> void *__mutex;
> unsigned int __nwaiters;
> unsigned int __broadcast_seq;
> } __data;
> char __size[48];
> __extension__ long long int __align;
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_condattr_t;
> typedef unsigned int pthread_key_t;
> typedef int pthread_once_t;
> typedef union
> struct
> int __lock;
> unsigned int __nr_readers;
> unsigned int __readers_wakeup;
> unsigned int __writer_wakeup;
> unsigned int __nr_readers_queued;
> unsigned int __nr_writers_queued;
> int __writer;
> int __shared;
> unsigned long int __pad1;
> unsigned long int __pad2;
> unsigned int __flags;
> } __data;
> # 187 "/usr/include/bits/pthreadtypes.h" 3 4
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> } pthread_rwlockattr_t;
> typedef volatile int pthread_spinlock_t;
> typedef union
> char __size[32];
> long int __align;
> } pthread_barrier_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_barrierattr_t;
> # 271 "/usr/include/sys/types.h" 2 3 4
> # 321 "/usr/include/stdlib.h" 2 3 4
> extern long int random (void) __attribute__ ((__nothrow__));
> extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__));
> extern char *initstate (unsigned int __seed, char *__statebuf,
> size_t __statelen) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> struct random_data
> int32_t *fptr;
> int32_t *rptr;
> int32_t *state;
> int rand_type;
> int rand_deg;
> int rand_sep;
> int32_t *end_ptr;
> extern int random_r (struct random_data *__restrict __buf,
> int32_t *__restrict __result) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int srandom_r (unsigned int __seed, struct random_data *__buf)
> extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
> size_t __statelen,
> struct random_data *__restrict __buf)
> extern int setstate_r (char *__restrict __statebuf,
> extern int rand (void) __attribute__ ((__nothrow__));
> extern void srand (unsigned int __seed) __attribute__ ((__nothrow__));
> extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__));
> extern double drand48 (void) __attribute__ ((__nothrow__));
> extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern long int lrand48 (void) __attribute__ ((__nothrow__));
> extern long int nrand48 (unsigned short int __xsubi[3])
> extern long int mrand48 (void) __attribute__ ((__nothrow__));
> extern long int jrand48 (unsigned short int __xsubi[3])
> extern void srand48 (long int __seedval) __attribute__ ((__nothrow__));
> extern unsigned short int *seed48 (unsigned short int __seed16v[3])
> extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> struct drand48_data
> unsigned short int __x[3];
> unsigned short int __old_x[3];
> unsigned short int __c;
> unsigned short int __init;
> unsigned long long int __a;
> extern int drand48_r (struct drand48_data *__restrict __buffer,
> double *__restrict __result) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int erand48_r (unsigned short int __xsubi[3],
> extern int lrand48_r (struct drand48_data *__restrict __buffer,
> long int *__restrict __result)
> extern int nrand48_r (unsigned short int __xsubi[3],
> extern int mrand48_r (struct drand48_data *__restrict __buffer,
> extern int jrand48_r (unsigned short int __xsubi[3],
> extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
> extern int seed48_r (unsigned short int __seed16v[3],
> struct drand48_data *__buffer) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int lcong48_r (unsigned short int __param[7],
> extern void *malloc (size_t __size) __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern void *calloc (size_t __nmemb, size_t __size)
> extern void *realloc (void *__ptr, size_t __size)
> __attribute__ ((__nothrow__)) __attribute__ ((__warn_unused_result__));
> extern void free (void *__ptr) __attribute__ ((__nothrow__));
> extern void cfree (void *__ptr) __attribute__ ((__nothrow__));
> # 1 "/usr/include/alloca.h" 1 3 4
> # 25 "/usr/include/alloca.h" 3 4
> # 26 "/usr/include/alloca.h" 2 3 4
> extern void *alloca (size_t __size) __attribute__ ((__nothrow__));
> # 498 "/usr/include/stdlib.h" 2 3 4
> extern void *valloc (size_t __size) __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
> extern void abort (void) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> # 530 "/usr/include/stdlib.h" 3 4
> extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
> extern void exit (int __status) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> # 553 "/usr/include/stdlib.h" 3 4
> extern void _Exit (int __status) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> extern char *getenv (__const char *__name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern char *__secure_getenv (__const char *__name)
> extern int putenv (char *__string) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int setenv (__const char *__name, __const char *__value, int __replace)
> extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__));
> extern int clearenv (void) __attribute__ ((__nothrow__));
> # 604 "/usr/include/stdlib.h" 3 4
> extern char *mktemp (char *__template) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 615 "/usr/include/stdlib.h" 3 4
> extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
> # 637 "/usr/include/stdlib.h" 3 4
> extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
> # 658 "/usr/include/stdlib.h" 3 4
> extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 707 "/usr/include/stdlib.h" 3 4
> extern int system (__const char *__command) ;
> # 729 "/usr/include/stdlib.h" 3 4
> extern char *realpath (__const char *__restrict __name,
> char *__restrict __resolved) __attribute__ ((__nothrow__)) ;
> typedef int (*__compar_fn_t) (__const void *, __const void *);
> # 747 "/usr/include/stdlib.h" 3 4
> extern void *bsearch (__const void *__key, __const void *__base,
> size_t __nmemb, size_t __size, __compar_fn_t __compar)
> __attribute__ ((__nonnull__ (1, 2, 5))) ;
> extern void qsort (void *__base, size_t __nmemb, size_t __size,
> __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
> # 766 "/usr/include/stdlib.h" 3 4
> extern int abs (int __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)) ;
> extern long int labs (long int __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)) ;
> __extension__ extern long long int llabs (long long int __x)
> extern div_t div (int __numer, int __denom)
> extern ldiv_t ldiv (long int __numer, long int __denom)
> __extension__ extern lldiv_t lldiv (long long int __numer,
> long long int __denom)
> # 802 "/usr/include/stdlib.h" 3 4
> extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
> int *__restrict __sign) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4))) ;
> extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
> extern char *gcvt (double __value, int __ndigit, char *__buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3))) ;
> extern char *qecvt (long double __value, int __ndigit,
> int *__restrict __decpt, int *__restrict __sign)
> extern char *qfcvt (long double __value, int __ndigit,
> extern char *qgcvt (long double __value, int __ndigit, char *__buf)
> extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
> int *__restrict __sign, char *__restrict __buf,
> size_t __len) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4, 5)));
> extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
> extern int qecvt_r (long double __value, int __ndigit,
> int *__restrict __decpt, int *__restrict __sign,
> char *__restrict __buf, size_t __len)
> extern int qfcvt_r (long double __value, int __ndigit,
> extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__)) ;
> extern int mbtowc (wchar_t *__restrict __pwc,
> __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__)) ;
> extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__)) ;
> extern size_t mbstowcs (wchar_t *__restrict __pwcs,
> __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__));
> extern size_t wcstombs (char *__restrict __s,
> __const wchar_t *__restrict __pwcs, size_t __n)
> extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 907 "/usr/include/stdlib.h" 3 4
> extern int posix_openpt (int __oflag) ;
> # 942 "/usr/include/stdlib.h" 3 4
> extern int getloadavg (double __loadavg[], int __nelem)
> # 958 "/usr/include/stdlib.h" 3 4
> Defined "STDC_HEADERS" to "1"
> TEST checkStat from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:138)
> TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
> Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> #include <sys/types.h>
> #include <sys/stat.h>
> #if defined(S_ISBLK) && defined(S_IFDIR)
> # if S_ISBLK (S_IFDIR)
> You lose.
> # endif
> #endif
> #if defined(S_ISBLK) && defined(S_IFCHR)
> # if S_ISBLK (S_IFCHR)
> You lose.
> # endif
> #endif
> #if defined(S_ISLNK) && defined(S_IFREG)
> # if S_ISLNK (S_IFREG)
> You lose.
> # endif
> #endif
> #if defined(S_ISSOCK) && defined(S_IFREG)
> # if S_ISSOCK (S_IFREG)
> You lose.
> # endif
> #endif
> stdout:
> # 1 "<built-in>"
> # 27 "/usr/include/sys/types.h" 3 4
> # 28 "/usr/include/sys/types.h" 2 3 4
> # 31 "/usr/include/bits/types.h" 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> typedef struct
> } fd_set;
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 5 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/usr/include/sys/stat.h" 1 3 4
> # 39 "/usr/include/sys/stat.h" 3 4
> # 40 "/usr/include/sys/stat.h" 2 3 4
> # 105 "/usr/include/sys/stat.h" 3 4
> # 1 "/usr/include/bits/stat.h" 1 3 4
> # 43 "/usr/include/bits/stat.h" 3 4
> struct stat
> __dev_t st_dev;
> __ino_t st_ino;
> __nlink_t st_nlink;
> __mode_t st_mode;
> __uid_t st_uid;
> __gid_t st_gid;
> int __pad0;
> __dev_t st_rdev;
> __off_t st_size;
> __blksize_t st_blksize;
> __blkcnt_t st_blocks;
> # 88 "/usr/include/bits/stat.h" 3 4
> struct timespec st_atim;
> struct timespec st_mtim;
> struct timespec st_ctim;
> # 103 "/usr/include/bits/stat.h" 3 4
> long int __unused[3];
> # 112 "/usr/include/bits/stat.h" 3 4
> # 108 "/usr/include/sys/stat.h" 2 3 4
> # 209 "/usr/include/sys/stat.h" 3 4
> extern int stat (__const char *__restrict __file,
> struct stat *__restrict __buf) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int fstat (int __fd, struct stat *__buf) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> # 238 "/usr/include/sys/stat.h" 3 4
> extern int fstatat (int __fd, __const char *__restrict __file,
> struct stat *__restrict __buf, int __flag)
> # 263 "/usr/include/sys/stat.h" 3 4
> extern int lstat (__const char *__restrict __file,
> # 284 "/usr/include/sys/stat.h" 3 4
> extern int chmod (__const char *__file, __mode_t __mode)
> extern int lchmod (__const char *__file, __mode_t __mode)
> extern int fchmod (int __fd, __mode_t __mode) __attribute__ ((__nothrow__));
> extern int fchmodat (int __fd, __const char *__file, __mode_t __mode,
> int __flag)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2))) ;
> extern __mode_t umask (__mode_t __mask) __attribute__ ((__nothrow__));
> # 321 "/usr/include/sys/stat.h" 3 4
> extern int mkdir (__const char *__path, __mode_t __mode)
> extern int mkdirat (int __fd, __const char *__path, __mode_t __mode)
> extern int mknod (__const char *__path, __mode_t __mode, __dev_t __dev)
> extern int mknodat (int __fd, __const char *__path, __mode_t __mode,
> __dev_t __dev) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> extern int mkfifo (__const char *__path, __mode_t __mode)
> extern int mkfifoat (int __fd, __const char *__path, __mode_t __mode)
> extern int utimensat (int __fd, __const char *__path,
> __const struct timespec __times[2],
> int __flags)
> extern int futimens (int __fd, __const struct timespec __times[2]) __attribute__ ((__nothrow__));
> # 399 "/usr/include/sys/stat.h" 3 4
> extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3)));
> extern int __xstat (int __ver, __const char *__filename,
> struct stat *__stat_buf) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 3)));
> extern int __lxstat (int __ver, __const char *__filename,
> extern int __fxstatat (int __ver, int __fildes, __const char *__filename,
> struct stat *__stat_buf, int __flag)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4)));
> # 442 "/usr/include/sys/stat.h" 3 4
> extern int __xmknod (int __ver, __const char *__path, __mode_t __mode,
> __dev_t *__dev) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 4)));
> extern int __xmknodat (int __ver, int __fd, __const char *__path,
> __mode_t __mode, __dev_t *__dev)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 5)));
> # 534 "/usr/include/sys/stat.h" 3 4
> # 6 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> TEST checkSysWait from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:173)
> TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
> Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
> Successful compile:
> Source:
> #include <sys/wait.h>
> #ifndef WEXITSTATUS
> #define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
> #endif
> #ifndef WIFEXITED
> #define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
> #endif
> int main() {
> int s;
> wait (&s);
> s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
> return 0;
> Defined "HAVE_SYS_WAIT_H" to "1"
> TEST checkTime from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:195)
> TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
> Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
> Checking for header: time.h
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 28 "/usr/include/time.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 29 "/usr/include/time.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 39 "/usr/include/time.h" 2 3 4
> # 43 "/usr/include/time.h" 2 3 4
> # 56 "/usr/include/time.h" 3 4
> # 57 "/usr/include/time.h" 2 3 4
> typedef __clock_t clock_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct tm
> int tm_sec;
> int tm_min;
> int tm_hour;
> int tm_mday;
> int tm_mon;
> int tm_year;
> int tm_wday;
> int tm_yday;
> int tm_isdst;
> long int tm_gmtoff;
> __const char *tm_zone;
> struct itimerspec
> struct timespec it_interval;
> struct timespec it_value;
> struct sigevent;
> extern clock_t clock (void) __attribute__ ((__nothrow__));
> extern time_t time (time_t *__timer) __attribute__ ((__nothrow__));
> extern double difftime (time_t __time1, time_t __time0)
> extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__));
> extern size_t strftime (char *__restrict __s, size_t __maxsize,
> __const char *__restrict __format,
> __const struct tm *__restrict __tp) __attribute__ ((__nothrow__));
> # 215 "/usr/include/time.h" 3 4
> } *__locale_t;
> # 216 "/usr/include/time.h" 2 3 4
> extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
> __const struct tm *__restrict __tp,
> __locale_t __loc) __attribute__ ((__nothrow__));
> # 230 "/usr/include/time.h" 3 4
> extern struct tm *gmtime (__const time_t *__timer) __attribute__ ((__nothrow__));
> extern struct tm *localtime (__const time_t *__timer) __attribute__ ((__nothrow__));
> extern struct tm *gmtime_r (__const time_t *__restrict __timer,
> extern struct tm *localtime_r (__const time_t *__restrict __timer,
> extern char *asctime (__const struct tm *__tp) __attribute__ ((__nothrow__));
> extern char *ctime (__const time_t *__timer) __attribute__ ((__nothrow__));
> extern char *asctime_r (__const struct tm *__restrict __tp,
> char *__restrict __buf) __attribute__ ((__nothrow__));
> extern char *ctime_r (__const time_t *__restrict __timer,
> extern char *__tzname[2];
> extern int __daylight;
> extern long int __timezone;
> extern char *tzname[2];
> extern void tzset (void) __attribute__ ((__nothrow__));
> extern int daylight;
> extern long int timezone;
> extern int stime (__const time_t *__when) __attribute__ ((__nothrow__));
> # 313 "/usr/include/time.h" 3 4
> extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__));
> extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__));
> extern int dysize (int __year) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> # 328 "/usr/include/time.h" 3 4
> extern int nanosleep (__const struct timespec *__requested_time,
> struct timespec *__remaining);
> extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__));
> extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__));
> extern int clock_settime (clockid_t __clock_id, __const struct timespec *__tp)
> extern int clock_nanosleep (clockid_t __clock_id, int __flags,
> __const struct timespec *__req,
> struct timespec *__rem);
> extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__));
> extern int timer_create (clockid_t __clock_id,
> struct sigevent *__restrict __evp,
> timer_t *__restrict __timerid) __attribute__ ((__nothrow__));
> extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__));
> extern int timer_settime (timer_t __timerid, int __flags,
> __const struct itimerspec *__restrict __value,
> struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__));
> extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
> extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__));
> # 417 "/usr/include/time.h" 3 4
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Defined "HAVE_TIME_H" to "1"
> Checking for header: sys/time.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/time.h" 1 3 4
> # 23 "/usr/include/sys/time.h" 3 4
> # 24 "/usr/include/sys/time.h" 2 3 4
> # 26 "/usr/include/sys/time.h" 2 3 4
> # 28 "/usr/include/sys/time.h" 2 3 4
> struct timeval
> __time_t tv_sec;
> # 30 "/usr/include/sys/time.h" 2 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> typedef struct
> } fd_set;
> # 32 "/usr/include/sys/time.h" 2 3 4
> # 57 "/usr/include/sys/time.h" 3 4
> struct timezone
> int tz_minuteswest;
> int tz_dsttime;
> typedef struct timezone *__restrict __timezone_ptr_t;
> # 73 "/usr/include/sys/time.h" 3 4
> extern int gettimeofday (struct timeval *__restrict __tv,
> __timezone_ptr_t __tz) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int settimeofday (__const struct timeval *__tv,
> __const struct timezone *__tz)
> extern int adjtime (__const struct timeval *__delta,
> struct timeval *__olddelta) __attribute__ ((__nothrow__));
> enum __itimer_which
> ITIMER_REAL = 0,
> ITIMER_VIRTUAL = 1,
> ITIMER_PROF = 2
> struct itimerval
> struct timeval it_interval;
> struct timeval it_value;
> typedef int __itimer_which_t;
> extern int getitimer (__itimer_which_t __which,
> struct itimerval *__value) __attribute__ ((__nothrow__));
> extern int setitimer (__itimer_which_t __which,
> __const struct itimerval *__restrict __new,
> struct itimerval *__restrict __old) __attribute__ ((__nothrow__));
> extern int utimes (__const char *__file, __const struct timeval __tvp[2])
> extern int lutimes (__const char *__file, __const struct timeval __tvp[2])
> extern int futimes (int __fd, __const struct timeval __tvp[2]) __attribute__ ((__nothrow__));
> # 191 "/usr/include/sys/time.h" 3 4
> Defined "HAVE_SYS_TIME_H" to "1"
> Successful compile:
> Source:
> #include <sys/time.h>
> #include <time.h>
> int main() {
> struct tm *tp = 0;
> if (tp);
> return 0;
> Defined "TIME_WITH_SYS_TIME" to "1"
> TEST checkMath from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:203)
> TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
> Checks for the math headers and defines
> Checking for header: math.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/math.h" 1 3 4
> # 28 "/usr/include/math.h" 3 4
> # 29 "/usr/include/math.h" 2 3 4
> # 1 "/usr/include/bits/huge_val.h" 1 3 4
> # 35 "/usr/include/math.h" 2 3 4
> # 1 "/usr/include/bits/huge_valf.h" 1 3 4
> # 37 "/usr/include/math.h" 2 3 4
> # 1 "/usr/include/bits/huge_vall.h" 1 3 4
> # 38 "/usr/include/math.h" 2 3 4
> # 1 "/usr/include/bits/inf.h" 1 3 4
> # 41 "/usr/include/math.h" 2 3 4
> # 1 "/usr/include/bits/nan.h" 1 3 4
> # 44 "/usr/include/math.h" 2 3 4
> # 1 "/usr/include/bits/mathdef.h" 1 3 4
> # 26 "/usr/include/bits/mathdef.h" 3 4
> # 27 "/usr/include/bits/mathdef.h" 2 3 4
> # 31 "/usr/include/bits/mathdef.h" 3 4
> typedef float float_t;
> typedef double double_t;
> # 48 "/usr/include/math.h" 2 3 4
> # 71 "/usr/include/math.h" 3 4
> # 1 "/usr/include/bits/mathcalls.h" 1 3 4
> # 53 "/usr/include/bits/mathcalls.h" 3 4
> extern double acos (double __x) __attribute__ ((__nothrow__)); extern double __acos (double __x) __attribute__ ((__nothrow__));
> extern double asin (double __x) __attribute__ ((__nothrow__)); extern double __asin (double __x) __attribute__ ((__nothrow__));
> extern double atan (double __x) __attribute__ ((__nothrow__)); extern double __atan (double __x) __attribute__ ((__nothrow__));
> extern double atan2 (double __y, double __x) __attribute__ ((__nothrow__)); extern double __atan2 (double __y, double __x) __attribute__ ((__nothrow__));
> extern double cos (double __x) __attribute__ ((__nothrow__)); extern double __cos (double __x) __attribute__ ((__nothrow__));
> extern double sin (double __x) __attribute__ ((__nothrow__)); extern double __sin (double __x) __attribute__ ((__nothrow__));
> extern double tan (double __x) __attribute__ ((__nothrow__)); extern double __tan (double __x) __attribute__ ((__nothrow__));
> extern double cosh (double __x) __attribute__ ((__nothrow__)); extern double __cosh (double __x) __attribute__ ((__nothrow__));
> extern double sinh (double __x) __attribute__ ((__nothrow__)); extern double __sinh (double __x) __attribute__ ((__nothrow__));
> extern double tanh (double __x) __attribute__ ((__nothrow__)); extern double __tanh (double __x) __attribute__ ((__nothrow__));
> # 87 "/usr/include/bits/mathcalls.h" 3 4
> extern double acosh (double __x) __attribute__ ((__nothrow__)); extern double __acosh (double __x) __attribute__ ((__nothrow__));
> extern double asinh (double __x) __attribute__ ((__nothrow__)); extern double __asinh (double __x) __attribute__ ((__nothrow__));
> extern double atanh (double __x) __attribute__ ((__nothrow__)); extern double __atanh (double __x) __attribute__ ((__nothrow__));
> extern double exp (double __x) __attribute__ ((__nothrow__)); extern double __exp (double __x) __attribute__ ((__nothrow__));
> extern double frexp (double __x, int *__exponent) __attribute__ ((__nothrow__)); extern double __frexp (double __x, int *__exponent) __attribute__ ((__nothrow__));
> extern double ldexp (double __x, int __exponent) __attribute__ ((__nothrow__)); extern double __ldexp (double __x, int __exponent) __attribute__ ((__nothrow__));
> extern double log (double __x) __attribute__ ((__nothrow__)); extern double __log (double __x) __attribute__ ((__nothrow__));
> extern double log10 (double __x) __attribute__ ((__nothrow__)); extern double __log10 (double __x) __attribute__ ((__nothrow__));
> extern double modf (double __x, double *__iptr) __attribute__ ((__nothrow__)); extern double __modf (double __x, double *__iptr) __attribute__ ((__nothrow__));
> # 127 "/usr/include/bits/mathcalls.h" 3 4
> extern double expm1 (double __x) __attribute__ ((__nothrow__)); extern double __expm1 (double __x) __attribute__ ((__nothrow__));
> extern double log1p (double __x) __attribute__ ((__nothrow__)); extern double __log1p (double __x) __attribute__ ((__nothrow__));
> extern double logb (double __x) __attribute__ ((__nothrow__)); extern double __logb (double __x) __attribute__ ((__nothrow__));
> extern double exp2 (double __x) __attribute__ ((__nothrow__)); extern double __exp2 (double __x) __attribute__ ((__nothrow__));
> extern double log2 (double __x) __attribute__ ((__nothrow__)); extern double __log2 (double __x) __attribute__ ((__nothrow__));
> extern double pow (double __x, double __y) __attribute__ ((__nothrow__)); extern double __pow (double __x, double __y) __attribute__ ((__nothrow__));
> extern double sqrt (double __x) __attribute__ ((__nothrow__)); extern double __sqrt (double __x) __attribute__ ((__nothrow__));
> extern double hypot (double __x, double __y) __attribute__ ((__nothrow__)); extern double __hypot (double __x, double __y) __attribute__ ((__nothrow__));
> extern double cbrt (double __x) __attribute__ ((__nothrow__)); extern double __cbrt (double __x) __attribute__ ((__nothrow__));
> extern double ceil (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __ceil (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double fabs (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __fabs (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double floor (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __floor (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double fmod (double __x, double __y) __attribute__ ((__nothrow__)); extern double __fmod (double __x, double __y) __attribute__ ((__nothrow__));
> extern int __isinf (double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int __finite (double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int isinf (double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int finite (double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double drem (double __x, double __y) __attribute__ ((__nothrow__)); extern double __drem (double __x, double __y) __attribute__ ((__nothrow__));
> extern double significand (double __x) __attribute__ ((__nothrow__)); extern double __significand (double __x) __attribute__ ((__nothrow__));
> extern double copysign (double __x, double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __copysign (double __x, double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double nan (__const char *__tagb) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __nan (__const char *__tagb) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int __isnan (double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int isnan (double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double j0 (double) __attribute__ ((__nothrow__)); extern double __j0 (double) __attribute__ ((__nothrow__));
> extern double j1 (double) __attribute__ ((__nothrow__)); extern double __j1 (double) __attribute__ ((__nothrow__));
> extern double jn (int, double) __attribute__ ((__nothrow__)); extern double __jn (int, double) __attribute__ ((__nothrow__));
> extern double y0 (double) __attribute__ ((__nothrow__)); extern double __y0 (double) __attribute__ ((__nothrow__));
> extern double y1 (double) __attribute__ ((__nothrow__)); extern double __y1 (double) __attribute__ ((__nothrow__));
> extern double yn (int, double) __attribute__ ((__nothrow__)); extern double __yn (int, double) __attribute__ ((__nothrow__));
> extern double erf (double) __attribute__ ((__nothrow__)); extern double __erf (double) __attribute__ ((__nothrow__));
> extern double erfc (double) __attribute__ ((__nothrow__)); extern double __erfc (double) __attribute__ ((__nothrow__));
> extern double lgamma (double) __attribute__ ((__nothrow__)); extern double __lgamma (double) __attribute__ ((__nothrow__));
> extern double tgamma (double) __attribute__ ((__nothrow__)); extern double __tgamma (double) __attribute__ ((__nothrow__));
> extern double gamma (double) __attribute__ ((__nothrow__)); extern double __gamma (double) __attribute__ ((__nothrow__));
> extern double lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__)); extern double __lgamma_r (double, int *__signgamp) __attribute__ ((__nothrow__));
> extern double rint (double __x) __attribute__ ((__nothrow__)); extern double __rint (double __x) __attribute__ ((__nothrow__));
> extern double nextafter (double __x, double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __nextafter (double __x, double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double nexttoward (double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __nexttoward (double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double remainder (double __x, double __y) __attribute__ ((__nothrow__)); extern double __remainder (double __x, double __y) __attribute__ ((__nothrow__));
> extern double scalbn (double __x, int __n) __attribute__ ((__nothrow__)); extern double __scalbn (double __x, int __n) __attribute__ ((__nothrow__));
> extern int ilogb (double __x) __attribute__ ((__nothrow__)); extern int __ilogb (double __x) __attribute__ ((__nothrow__));
> extern double scalbln (double __x, long int __n) __attribute__ ((__nothrow__)); extern double __scalbln (double __x, long int __n) __attribute__ ((__nothrow__));
> extern double nearbyint (double __x) __attribute__ ((__nothrow__)); extern double __nearbyint (double __x) __attribute__ ((__nothrow__));
> extern double round (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __round (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double trunc (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern double __trunc (double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern double remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__)); extern double __remquo (double __x, double __y, int *__quo) __attribute__ ((__nothrow__));
> extern long int lrint (double __x) __attribute__ ((__nothrow__)); extern long int __lrint (double __x) __attribute__ ((__nothrow__));
> extern long long int llrint (double __x) __attribute__ ((__nothrow__)); extern long long int __llrint (double __x) __attribute__ ((__nothrow__));
> extern long int lround (double __x) __attribute__ ((__nothrow__)); extern long int __lround (double __x) __attribute__ ((__nothrow__));
> extern long long int llround (double __x) __attribute__ ((__nothrow__)); extern long long int __llround (double __x) __attribute__ ((__nothrow__));
> extern double fdim (double __x, double __y) __attribute__ ((__nothrow__)); extern double __fdim (double __x, double __y) __attribute__ ((__nothrow__));
> extern double fmax (double __x, double __y) __attribute__ ((__nothrow__)); extern double __fmax (double __x, double __y) __attribute__ ((__nothrow__));
> extern double fmin (double __x, double __y) __attribute__ ((__nothrow__)); extern double __fmin (double __x, double __y) __attribute__ ((__nothrow__));
> extern int __fpclassify (double __value) __attribute__ ((__nothrow__))
> extern int __signbit (double __value) __attribute__ ((__nothrow__))
> extern double fma (double __x, double __y, double __z) __attribute__ ((__nothrow__)); extern double __fma (double __x, double __y, double __z) __attribute__ ((__nothrow__));
> extern double scalb (double __x, double __n) __attribute__ ((__nothrow__)); extern double __scalb (double __x, double __n) __attribute__ ((__nothrow__));
> # 72 "/usr/include/math.h" 2 3 4
> # 94 "/usr/include/math.h" 3 4
> extern float acosf (float __x) __attribute__ ((__nothrow__)); extern float __acosf (float __x) __attribute__ ((__nothrow__));
> extern float asinf (float __x) __attribute__ ((__nothrow__)); extern float __asinf (float __x) __attribute__ ((__nothrow__));
> extern float atanf (float __x) __attribute__ ((__nothrow__)); extern float __atanf (float __x) __attribute__ ((__nothrow__));
> extern float atan2f (float __y, float __x) __attribute__ ((__nothrow__)); extern float __atan2f (float __y, float __x) __attribute__ ((__nothrow__));
> extern float cosf (float __x) __attribute__ ((__nothrow__)); extern float __cosf (float __x) __attribute__ ((__nothrow__));
> extern float sinf (float __x) __attribute__ ((__nothrow__)); extern float __sinf (float __x) __attribute__ ((__nothrow__));
> extern float tanf (float __x) __attribute__ ((__nothrow__)); extern float __tanf (float __x) __attribute__ ((__nothrow__));
> extern float coshf (float __x) __attribute__ ((__nothrow__)); extern float __coshf (float __x) __attribute__ ((__nothrow__));
> extern float sinhf (float __x) __attribute__ ((__nothrow__)); extern float __sinhf (float __x) __attribute__ ((__nothrow__));
> extern float tanhf (float __x) __attribute__ ((__nothrow__)); extern float __tanhf (float __x) __attribute__ ((__nothrow__));
> extern float acoshf (float __x) __attribute__ ((__nothrow__)); extern float __acoshf (float __x) __attribute__ ((__nothrow__));
> extern float asinhf (float __x) __attribute__ ((__nothrow__)); extern float __asinhf (float __x) __attribute__ ((__nothrow__));
> extern float atanhf (float __x) __attribute__ ((__nothrow__)); extern float __atanhf (float __x) __attribute__ ((__nothrow__));
> extern float expf (float __x) __attribute__ ((__nothrow__)); extern float __expf (float __x) __attribute__ ((__nothrow__));
> extern float frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__)); extern float __frexpf (float __x, int *__exponent) __attribute__ ((__nothrow__));
> extern float ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__)); extern float __ldexpf (float __x, int __exponent) __attribute__ ((__nothrow__));
> extern float logf (float __x) __attribute__ ((__nothrow__)); extern float __logf (float __x) __attribute__ ((__nothrow__));
> extern float log10f (float __x) __attribute__ ((__nothrow__)); extern float __log10f (float __x) __attribute__ ((__nothrow__));
> extern float modff (float __x, float *__iptr) __attribute__ ((__nothrow__)); extern float __modff (float __x, float *__iptr) __attribute__ ((__nothrow__));
> extern float expm1f (float __x) __attribute__ ((__nothrow__)); extern float __expm1f (float __x) __attribute__ ((__nothrow__));
> extern float log1pf (float __x) __attribute__ ((__nothrow__)); extern float __log1pf (float __x) __attribute__ ((__nothrow__));
> extern float logbf (float __x) __attribute__ ((__nothrow__)); extern float __logbf (float __x) __attribute__ ((__nothrow__));
> extern float exp2f (float __x) __attribute__ ((__nothrow__)); extern float __exp2f (float __x) __attribute__ ((__nothrow__));
> extern float log2f (float __x) __attribute__ ((__nothrow__)); extern float __log2f (float __x) __attribute__ ((__nothrow__));
> extern float powf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __powf (float __x, float __y) __attribute__ ((__nothrow__));
> extern float sqrtf (float __x) __attribute__ ((__nothrow__)); extern float __sqrtf (float __x) __attribute__ ((__nothrow__));
> extern float hypotf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __hypotf (float __x, float __y) __attribute__ ((__nothrow__));
> extern float cbrtf (float __x) __attribute__ ((__nothrow__)); extern float __cbrtf (float __x) __attribute__ ((__nothrow__));
> extern float ceilf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __ceilf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float fabsf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __fabsf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float floorf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __floorf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float fmodf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __fmodf (float __x, float __y) __attribute__ ((__nothrow__));
> extern int __isinff (float __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int __finitef (float __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int isinff (float __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int finitef (float __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float dremf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __dremf (float __x, float __y) __attribute__ ((__nothrow__));
> extern float significandf (float __x) __attribute__ ((__nothrow__)); extern float __significandf (float __x) __attribute__ ((__nothrow__));
> extern float copysignf (float __x, float __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __copysignf (float __x, float __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float nanf (__const char *__tagb) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __nanf (__const char *__tagb) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int __isnanf (float __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int isnanf (float __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float j0f (float) __attribute__ ((__nothrow__)); extern float __j0f (float) __attribute__ ((__nothrow__));
> extern float j1f (float) __attribute__ ((__nothrow__)); extern float __j1f (float) __attribute__ ((__nothrow__));
> extern float jnf (int, float) __attribute__ ((__nothrow__)); extern float __jnf (int, float) __attribute__ ((__nothrow__));
> extern float y0f (float) __attribute__ ((__nothrow__)); extern float __y0f (float) __attribute__ ((__nothrow__));
> extern float y1f (float) __attribute__ ((__nothrow__)); extern float __y1f (float) __attribute__ ((__nothrow__));
> extern float ynf (int, float) __attribute__ ((__nothrow__)); extern float __ynf (int, float) __attribute__ ((__nothrow__));
> extern float erff (float) __attribute__ ((__nothrow__)); extern float __erff (float) __attribute__ ((__nothrow__));
> extern float erfcf (float) __attribute__ ((__nothrow__)); extern float __erfcf (float) __attribute__ ((__nothrow__));
> extern float lgammaf (float) __attribute__ ((__nothrow__)); extern float __lgammaf (float) __attribute__ ((__nothrow__));
> extern float tgammaf (float) __attribute__ ((__nothrow__)); extern float __tgammaf (float) __attribute__ ((__nothrow__));
> extern float gammaf (float) __attribute__ ((__nothrow__)); extern float __gammaf (float) __attribute__ ((__nothrow__));
> extern float lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__)); extern float __lgammaf_r (float, int *__signgamp) __attribute__ ((__nothrow__));
> extern float rintf (float __x) __attribute__ ((__nothrow__)); extern float __rintf (float __x) __attribute__ ((__nothrow__));
> extern float nextafterf (float __x, float __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __nextafterf (float __x, float __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __nexttowardf (float __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float remainderf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __remainderf (float __x, float __y) __attribute__ ((__nothrow__));
> extern float scalbnf (float __x, int __n) __attribute__ ((__nothrow__)); extern float __scalbnf (float __x, int __n) __attribute__ ((__nothrow__));
> extern int ilogbf (float __x) __attribute__ ((__nothrow__)); extern int __ilogbf (float __x) __attribute__ ((__nothrow__));
> extern float scalblnf (float __x, long int __n) __attribute__ ((__nothrow__)); extern float __scalblnf (float __x, long int __n) __attribute__ ((__nothrow__));
> extern float nearbyintf (float __x) __attribute__ ((__nothrow__)); extern float __nearbyintf (float __x) __attribute__ ((__nothrow__));
> extern float roundf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __roundf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float truncf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern float __truncf (float __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern float remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__)); extern float __remquof (float __x, float __y, int *__quo) __attribute__ ((__nothrow__));
> extern long int lrintf (float __x) __attribute__ ((__nothrow__)); extern long int __lrintf (float __x) __attribute__ ((__nothrow__));
> extern long long int llrintf (float __x) __attribute__ ((__nothrow__)); extern long long int __llrintf (float __x) __attribute__ ((__nothrow__));
> extern long int lroundf (float __x) __attribute__ ((__nothrow__)); extern long int __lroundf (float __x) __attribute__ ((__nothrow__));
> extern long long int llroundf (float __x) __attribute__ ((__nothrow__)); extern long long int __llroundf (float __x) __attribute__ ((__nothrow__));
> extern float fdimf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __fdimf (float __x, float __y) __attribute__ ((__nothrow__));
> extern float fmaxf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __fmaxf (float __x, float __y) __attribute__ ((__nothrow__));
> extern float fminf (float __x, float __y) __attribute__ ((__nothrow__)); extern float __fminf (float __x, float __y) __attribute__ ((__nothrow__));
> extern int __fpclassifyf (float __value) __attribute__ ((__nothrow__))
> extern int __signbitf (float __value) __attribute__ ((__nothrow__))
> extern float fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__)); extern float __fmaf (float __x, float __y, float __z) __attribute__ ((__nothrow__));
> extern float scalbf (float __x, float __n) __attribute__ ((__nothrow__)); extern float __scalbf (float __x, float __n) __attribute__ ((__nothrow__));
> # 95 "/usr/include/math.h" 2 3 4
> # 141 "/usr/include/math.h" 3 4
> extern long double acosl (long double __x) __attribute__ ((__nothrow__)); extern long double __acosl (long double __x) __attribute__ ((__nothrow__));
> extern long double asinl (long double __x) __attribute__ ((__nothrow__)); extern long double __asinl (long double __x) __attribute__ ((__nothrow__));
> extern long double atanl (long double __x) __attribute__ ((__nothrow__)); extern long double __atanl (long double __x) __attribute__ ((__nothrow__));
> extern long double atan2l (long double __y, long double __x) __attribute__ ((__nothrow__)); extern long double __atan2l (long double __y, long double __x) __attribute__ ((__nothrow__));
> extern long double cosl (long double __x) __attribute__ ((__nothrow__)); extern long double __cosl (long double __x) __attribute__ ((__nothrow__));
> extern long double sinl (long double __x) __attribute__ ((__nothrow__)); extern long double __sinl (long double __x) __attribute__ ((__nothrow__));
> extern long double tanl (long double __x) __attribute__ ((__nothrow__)); extern long double __tanl (long double __x) __attribute__ ((__nothrow__));
> extern long double coshl (long double __x) __attribute__ ((__nothrow__)); extern long double __coshl (long double __x) __attribute__ ((__nothrow__));
> extern long double sinhl (long double __x) __attribute__ ((__nothrow__)); extern long double __sinhl (long double __x) __attribute__ ((__nothrow__));
> extern long double tanhl (long double __x) __attribute__ ((__nothrow__)); extern long double __tanhl (long double __x) __attribute__ ((__nothrow__));
> extern long double acoshl (long double __x) __attribute__ ((__nothrow__)); extern long double __acoshl (long double __x) __attribute__ ((__nothrow__));
> extern long double asinhl (long double __x) __attribute__ ((__nothrow__)); extern long double __asinhl (long double __x) __attribute__ ((__nothrow__));
> extern long double atanhl (long double __x) __attribute__ ((__nothrow__)); extern long double __atanhl (long double __x) __attribute__ ((__nothrow__));
> extern long double expl (long double __x) __attribute__ ((__nothrow__)); extern long double __expl (long double __x) __attribute__ ((__nothrow__));
> extern long double frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__)); extern long double __frexpl (long double __x, int *__exponent) __attribute__ ((__nothrow__));
> extern long double ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__)); extern long double __ldexpl (long double __x, int __exponent) __attribute__ ((__nothrow__));
> extern long double logl (long double __x) __attribute__ ((__nothrow__)); extern long double __logl (long double __x) __attribute__ ((__nothrow__));
> extern long double log10l (long double __x) __attribute__ ((__nothrow__)); extern long double __log10l (long double __x) __attribute__ ((__nothrow__));
> extern long double modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__)); extern long double __modfl (long double __x, long double *__iptr) __attribute__ ((__nothrow__));
> extern long double expm1l (long double __x) __attribute__ ((__nothrow__)); extern long double __expm1l (long double __x) __attribute__ ((__nothrow__));
> extern long double log1pl (long double __x) __attribute__ ((__nothrow__)); extern long double __log1pl (long double __x) __attribute__ ((__nothrow__));
> extern long double logbl (long double __x) __attribute__ ((__nothrow__)); extern long double __logbl (long double __x) __attribute__ ((__nothrow__));
> extern long double exp2l (long double __x) __attribute__ ((__nothrow__)); extern long double __exp2l (long double __x) __attribute__ ((__nothrow__));
> extern long double log2l (long double __x) __attribute__ ((__nothrow__)); extern long double __log2l (long double __x) __attribute__ ((__nothrow__));
> extern long double powl (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __powl (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern long double sqrtl (long double __x) __attribute__ ((__nothrow__)); extern long double __sqrtl (long double __x) __attribute__ ((__nothrow__));
> extern long double hypotl (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __hypotl (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern long double cbrtl (long double __x) __attribute__ ((__nothrow__)); extern long double __cbrtl (long double __x) __attribute__ ((__nothrow__));
> extern long double ceill (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __ceill (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double fabsl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __fabsl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double floorl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __floorl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double fmodl (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __fmodl (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern int __isinfl (long double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int __finitel (long double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int isinfl (long double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int finitel (long double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double dreml (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __dreml (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern long double significandl (long double __x) __attribute__ ((__nothrow__)); extern long double __significandl (long double __x) __attribute__ ((__nothrow__));
> extern long double copysignl (long double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __copysignl (long double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double nanl (__const char *__tagb) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __nanl (__const char *__tagb) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int __isnanl (long double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int isnanl (long double __value) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double j0l (long double) __attribute__ ((__nothrow__)); extern long double __j0l (long double) __attribute__ ((__nothrow__));
> extern long double j1l (long double) __attribute__ ((__nothrow__)); extern long double __j1l (long double) __attribute__ ((__nothrow__));
> extern long double jnl (int, long double) __attribute__ ((__nothrow__)); extern long double __jnl (int, long double) __attribute__ ((__nothrow__));
> extern long double y0l (long double) __attribute__ ((__nothrow__)); extern long double __y0l (long double) __attribute__ ((__nothrow__));
> extern long double y1l (long double) __attribute__ ((__nothrow__)); extern long double __y1l (long double) __attribute__ ((__nothrow__));
> extern long double ynl (int, long double) __attribute__ ((__nothrow__)); extern long double __ynl (int, long double) __attribute__ ((__nothrow__));
> extern long double erfl (long double) __attribute__ ((__nothrow__)); extern long double __erfl (long double) __attribute__ ((__nothrow__));
> extern long double erfcl (long double) __attribute__ ((__nothrow__)); extern long double __erfcl (long double) __attribute__ ((__nothrow__));
> extern long double lgammal (long double) __attribute__ ((__nothrow__)); extern long double __lgammal (long double) __attribute__ ((__nothrow__));
> extern long double tgammal (long double) __attribute__ ((__nothrow__)); extern long double __tgammal (long double) __attribute__ ((__nothrow__));
> extern long double gammal (long double) __attribute__ ((__nothrow__)); extern long double __gammal (long double) __attribute__ ((__nothrow__));
> extern long double lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__)); extern long double __lgammal_r (long double, int *__signgamp) __attribute__ ((__nothrow__));
> extern long double rintl (long double __x) __attribute__ ((__nothrow__)); extern long double __rintl (long double __x) __attribute__ ((__nothrow__));
> extern long double nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __nextafterl (long double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __nexttowardl (long double __x, long double __y) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double remainderl (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __remainderl (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern long double scalbnl (long double __x, int __n) __attribute__ ((__nothrow__)); extern long double __scalbnl (long double __x, int __n) __attribute__ ((__nothrow__));
> extern int ilogbl (long double __x) __attribute__ ((__nothrow__)); extern int __ilogbl (long double __x) __attribute__ ((__nothrow__));
> extern long double scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__)); extern long double __scalblnl (long double __x, long int __n) __attribute__ ((__nothrow__));
> extern long double nearbyintl (long double __x) __attribute__ ((__nothrow__)); extern long double __nearbyintl (long double __x) __attribute__ ((__nothrow__));
> extern long double roundl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __roundl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double truncl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)); extern long double __truncl (long double __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern long double remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__)); extern long double __remquol (long double __x, long double __y, int *__quo) __attribute__ ((__nothrow__));
> extern long int lrintl (long double __x) __attribute__ ((__nothrow__)); extern long int __lrintl (long double __x) __attribute__ ((__nothrow__));
> extern long long int llrintl (long double __x) __attribute__ ((__nothrow__)); extern long long int __llrintl (long double __x) __attribute__ ((__nothrow__));
> extern long int lroundl (long double __x) __attribute__ ((__nothrow__)); extern long int __lroundl (long double __x) __attribute__ ((__nothrow__));
> extern long long int llroundl (long double __x) __attribute__ ((__nothrow__)); extern long long int __llroundl (long double __x) __attribute__ ((__nothrow__));
> extern long double fdiml (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __fdiml (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern long double fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __fmaxl (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern long double fminl (long double __x, long double __y) __attribute__ ((__nothrow__)); extern long double __fminl (long double __x, long double __y) __attribute__ ((__nothrow__));
> extern int __fpclassifyl (long double __value) __attribute__ ((__nothrow__))
> extern int __signbitl (long double __value) __attribute__ ((__nothrow__))
> extern long double fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__)); extern long double __fmal (long double __x, long double __y, long double __z) __attribute__ ((__nothrow__));
> extern long double scalbl (long double __x, long double __n) __attribute__ ((__nothrow__)); extern long double __scalbl (long double __x, long double __n) __attribute__ ((__nothrow__));
> # 142 "/usr/include/math.h" 2 3 4
> # 157 "/usr/include/math.h" 3 4
> extern int signgam;
> # 198 "/usr/include/math.h" 3 4
> enum
> FP_NAN,
> FP_INFINITE,
> FP_ZERO,
> FP_SUBNORMAL,
> FP_NORMAL
> # 291 "/usr/include/math.h" 3 4
> typedef enum
> _IEEE_ = -1,
> _SVID_,
> _XOPEN_,
> _POSIX_,
> _ISOC_
> } _LIB_VERSION_TYPE;
> extern _LIB_VERSION_TYPE _LIB_VERSION;
> # 316 "/usr/include/math.h" 3 4
> struct exception
> int type;
> char *name;
> double arg1;
> double arg2;
> double retval;
> extern int matherr (struct exception *__exc);
> # 472 "/usr/include/math.h" 3 4
> Defined "HAVE_MATH_H" to "1"
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.headers/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.headers -g -O0 /tmp/petsc-uoFdrH/config.headers/conftest.c
> Successful compile:
> Source:
> #include <math.h>
> int main() {
> double pi = M_PI;
> if (pi);
> return 0;
> Found math #defines, like M_PI
> TEST check from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:77)
> TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
> Checks for "header", and defines HAVE_"header" if found
> Checking for header: sys/socket.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/socket.h" 1 3 4
> # 24 "/usr/include/sys/socket.h" 3 4
> # 25 "/usr/include/sys/socket.h" 2 3 4
> # 1 "/usr/include/sys/uio.h" 1 3 4
> # 24 "/usr/include/sys/uio.h" 3 4
> # 1 "/usr/include/sys/types.h" 1 3 4
> # 29 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/types.h" 1 3 4
> # 28 "/usr/include/bits/types.h" 3 4
> # 29 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned char __u_char;
> typedef unsigned short int __u_short;
> typedef unsigned int __u_int;
> typedef unsigned long int __u_long;
> typedef signed char __int8_t;
> typedef unsigned char __uint8_t;
> typedef signed short int __int16_t;
> typedef unsigned short int __uint16_t;
> typedef signed int __int32_t;
> typedef unsigned int __uint32_t;
> typedef signed long int __int64_t;
> typedef unsigned long int __uint64_t;
> typedef long int __quad_t;
> typedef unsigned long int __u_quad_t;
> # 131 "/usr/include/bits/types.h" 3 4
> # 1 "/usr/include/bits/typesizes.h" 1 3 4
> # 132 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned long int __dev_t;
> typedef unsigned int __uid_t;
> typedef unsigned int __gid_t;
> typedef unsigned long int __ino_t;
> typedef unsigned long int __ino64_t;
> typedef unsigned int __mode_t;
> typedef unsigned long int __nlink_t;
> typedef long int __off_t;
> typedef long int __off64_t;
> typedef int __pid_t;
> typedef struct { int __val[2]; } __fsid_t;
> typedef long int __clock_t;
> typedef unsigned long int __rlim_t;
> typedef unsigned long int __rlim64_t;
> typedef unsigned int __id_t;
> typedef long int __time_t;
> typedef unsigned int __useconds_t;
> typedef long int __suseconds_t;
> typedef int __daddr_t;
> typedef long int __swblk_t;
> typedef int __key_t;
> typedef int __clockid_t;
> typedef void * __timer_t;
> typedef long int __blksize_t;
> typedef long int __blkcnt_t;
> typedef long int __blkcnt64_t;
> typedef unsigned long int __fsblkcnt_t;
> typedef unsigned long int __fsblkcnt64_t;
> typedef unsigned long int __fsfilcnt_t;
> typedef unsigned long int __fsfilcnt64_t;
> typedef long int __ssize_t;
> typedef __off64_t __loff_t;
> typedef __quad_t *__qaddr_t;
> typedef char *__caddr_t;
> typedef long int __intptr_t;
> typedef unsigned int __socklen_t;
> # 32 "/usr/include/sys/types.h" 2 3 4
> typedef __u_char u_char;
> typedef __u_short u_short;
> typedef __u_int u_int;
> typedef __u_long u_long;
> typedef __quad_t quad_t;
> typedef __u_quad_t u_quad_t;
> typedef __fsid_t fsid_t;
> typedef __loff_t loff_t;
> typedef __ino_t ino_t;
> # 62 "/usr/include/sys/types.h" 3 4
> typedef __dev_t dev_t;
> typedef __gid_t gid_t;
> typedef __mode_t mode_t;
> typedef __nlink_t nlink_t;
> typedef __uid_t uid_t;
> typedef __off_t off_t;
> # 100 "/usr/include/sys/types.h" 3 4
> typedef __pid_t pid_t;
> typedef __id_t id_t;
> typedef __ssize_t ssize_t;
> typedef __daddr_t daddr_t;
> typedef __caddr_t caddr_t;
> typedef __key_t key_t;
> # 133 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/time.h" 1 3 4
> # 74 "/usr/include/time.h" 3 4
> typedef __time_t time_t;
> # 92 "/usr/include/time.h" 3 4
> typedef __clockid_t clockid_t;
> # 104 "/usr/include/time.h" 3 4
> typedef __timer_t timer_t;
> # 134 "/usr/include/sys/types.h" 2 3 4
> # 147 "/usr/include/sys/types.h" 3 4
> # 148 "/usr/include/sys/types.h" 2 3 4
> typedef unsigned long int ulong;
> typedef unsigned short int ushort;
> typedef unsigned int uint;
> # 195 "/usr/include/sys/types.h" 3 4
> typedef int int8_t __attribute__ ((__mode__ (__QI__)));
> typedef int int16_t __attribute__ ((__mode__ (__HI__)));
> typedef int int32_t __attribute__ ((__mode__ (__SI__)));
> typedef int int64_t __attribute__ ((__mode__ (__DI__)));
> typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
> typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
> typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
> typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
> typedef int register_t __attribute__ ((__mode__ (__word__)));
> # 217 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/endian.h" 1 3 4
> # 37 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/endian.h" 1 3 4
> # 38 "/usr/include/endian.h" 2 3 4
> # 61 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/byteswap.h" 1 3 4
> # 28 "/usr/include/bits/byteswap.h" 3 4
> # 29 "/usr/include/bits/byteswap.h" 2 3 4
> # 62 "/usr/include/endian.h" 2 3 4
> # 218 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/select.h" 1 3 4
> # 31 "/usr/include/sys/select.h" 3 4
> # 1 "/usr/include/bits/select.h" 1 3 4
> # 23 "/usr/include/bits/select.h" 3 4
> # 24 "/usr/include/bits/select.h" 2 3 4
> # 32 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/sigset.h" 1 3 4
> # 24 "/usr/include/bits/sigset.h" 3 4
> typedef int __sig_atomic_t;
> typedef struct
> unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
> } __sigset_t;
> # 35 "/usr/include/sys/select.h" 2 3 4
> typedef __sigset_t sigset_t;
> # 120 "/usr/include/time.h" 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 45 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/time.h" 1 3 4
> # 69 "/usr/include/bits/time.h" 3 4
> struct timeval
> __time_t tv_sec;
> __suseconds_t tv_usec;
> # 47 "/usr/include/sys/select.h" 2 3 4
> typedef __suseconds_t suseconds_t;
> typedef long int __fd_mask;
> # 67 "/usr/include/sys/select.h" 3 4
> typedef struct
> __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
> } fd_set;
> typedef __fd_mask fd_mask;
> # 99 "/usr/include/sys/select.h" 3 4
> # 109 "/usr/include/sys/select.h" 3 4
> extern int select (int __nfds, fd_set *__restrict __readfds,
> fd_set *__restrict __writefds,
> fd_set *__restrict __exceptfds,
> struct timeval *__restrict __timeout);
> # 121 "/usr/include/sys/select.h" 3 4
> extern int pselect (int __nfds, fd_set *__restrict __readfds,
> const struct timespec *__restrict __timeout,
> const __sigset_t *__restrict __sigmask);
> # 221 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/sysmacros.h" 1 3 4
> # 30 "/usr/include/sys/sysmacros.h" 3 4
> __extension__
> extern unsigned int gnu_dev_major (unsigned long long int __dev)
> __extension__
> extern unsigned int gnu_dev_minor (unsigned long long int __dev)
> __extension__
> extern unsigned long long int gnu_dev_makedev (unsigned int __major,
> unsigned int __minor)
> # 224 "/usr/include/sys/types.h" 2 3 4
> # 235 "/usr/include/sys/types.h" 3 4
> typedef __blkcnt_t blkcnt_t;
> typedef __fsblkcnt_t fsblkcnt_t;
> typedef __fsfilcnt_t fsfilcnt_t;
> # 270 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
> # 23 "/usr/include/bits/pthreadtypes.h" 3 4
> # 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
> # 50 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef unsigned long int pthread_t;
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> typedef struct __pthread_internal_list
> struct __pthread_internal_list *__prev;
> struct __pthread_internal_list *__next;
> } __pthread_list_t;
> # 76 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef union
> struct __pthread_mutex_s
> int __lock;
> unsigned int __count;
> int __owner;
> unsigned int __nusers;
> int __kind;
> int __spins;
> __pthread_list_t __list;
> # 101 "/usr/include/bits/pthreadtypes.h" 3 4
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_mutexattr_t;
> typedef union
> struct
> int __lock;
> unsigned int __futex;
> __extension__ unsigned long long int __total_seq;
> __extension__ unsigned long long int __wakeup_seq;
> __extension__ unsigned long long int __woken_seq;
> void *__mutex;
> unsigned int __nwaiters;
> unsigned int __broadcast_seq;
> } __data;
> char __size[48];
> __extension__ long long int __align;
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_condattr_t;
> typedef unsigned int pthread_key_t;
> typedef int pthread_once_t;
> typedef union
> struct
> int __lock;
> unsigned int __nr_readers;
> unsigned int __readers_wakeup;
> unsigned int __writer_wakeup;
> unsigned int __nr_readers_queued;
> unsigned int __nr_writers_queued;
> int __writer;
> int __shared;
> unsigned long int __pad1;
> unsigned long int __pad2;
> unsigned int __flags;
> } __data;
> # 187 "/usr/include/bits/pthreadtypes.h" 3 4
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> } pthread_rwlockattr_t;
> typedef volatile int pthread_spinlock_t;
> typedef union
> char __size[32];
> long int __align;
> } pthread_barrier_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_barrierattr_t;
> # 271 "/usr/include/sys/types.h" 2 3 4
> # 25 "/usr/include/sys/uio.h" 2 3 4
> # 1 "/usr/include/bits/uio.h" 1 3 4
> # 44 "/usr/include/bits/uio.h" 3 4
> struct iovec
> void *iov_base;
> size_t iov_len;
> # 30 "/usr/include/sys/uio.h" 2 3 4
> # 40 "/usr/include/sys/uio.h" 3 4
> extern ssize_t readv (int __fd, __const struct iovec *__iovec, int __count)
> # 51 "/usr/include/sys/uio.h" 3 4
> extern ssize_t writev (int __fd, __const struct iovec *__iovec, int __count)
> # 66 "/usr/include/sys/uio.h" 3 4
> extern ssize_t preadv (int __fd, __const struct iovec *__iovec, int __count,
> __off_t __offset) ;
> # 78 "/usr/include/sys/uio.h" 3 4
> extern ssize_t pwritev (int __fd, __const struct iovec *__iovec, int __count,
> __off_t __offset) ;
> # 121 "/usr/include/sys/uio.h" 3 4
> # 29 "/usr/include/sys/socket.h" 2 3 4
> # 31 "/usr/include/sys/socket.h" 2 3 4
> # 40 "/usr/include/sys/socket.h" 3 4
> # 1 "/usr/include/bits/socket.h" 1 3 4
> # 29 "/usr/include/bits/socket.h" 3 4
> # 30 "/usr/include/bits/socket.h" 2 3 4
> typedef __socklen_t socklen_t;
> enum __socket_type
> SOCK_STREAM = 1,
> SOCK_DGRAM = 2,
> SOCK_RAW = 3,
> SOCK_RDM = 4,
> SOCK_SEQPACKET = 5,
> SOCK_DCCP = 6,
> SOCK_PACKET = 10,
> SOCK_CLOEXEC = 02000000,
> SOCK_NONBLOCK = 04000
> # 175 "/usr/include/bits/socket.h" 3 4
> # 1 "/usr/include/bits/sockaddr.h" 1 3 4
> # 29 "/usr/include/bits/sockaddr.h" 3 4
> typedef unsigned short int sa_family_t;
> # 176 "/usr/include/bits/socket.h" 2 3 4
> struct sockaddr
> sa_family_t sa_family;
> char sa_data[14];
> # 191 "/usr/include/bits/socket.h" 3 4
> struct sockaddr_storage
> sa_family_t ss_family;
> unsigned long int __ss_align;
> char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
> enum
> MSG_OOB = 0x01,
> MSG_PEEK = 0x02,
> MSG_DONTROUTE = 0x04,
> MSG_CTRUNC = 0x08,
> MSG_PROXY = 0x10,
> MSG_TRUNC = 0x20,
> MSG_DONTWAIT = 0x40,
> MSG_EOR = 0x80,
> MSG_WAITALL = 0x100,
> MSG_FIN = 0x200,
> MSG_SYN = 0x400,
> MSG_CONFIRM = 0x800,
> MSG_RST = 0x1000,
> MSG_ERRQUEUE = 0x2000,
> MSG_NOSIGNAL = 0x4000,
> MSG_MORE = 0x8000,
> MSG_CMSG_CLOEXEC = 0x40000000
> struct msghdr
> void *msg_name;
> socklen_t msg_namelen;
> struct iovec *msg_iov;
> size_t msg_iovlen;
> void *msg_control;
> size_t msg_controllen;
> int msg_flags;
> struct cmsghdr
> size_t cmsg_len;
> int cmsg_level;
> int cmsg_type;
> __extension__ unsigned char __cmsg_data [];
> # 297 "/usr/include/bits/socket.h" 3 4
> extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
> struct cmsghdr *__cmsg) __attribute__ ((__nothrow__));
> # 324 "/usr/include/bits/socket.h" 3 4
> enum
> SCM_RIGHTS = 0x01
> # 370 "/usr/include/bits/socket.h" 3 4
> # 1 "/usr/include/asm/socket.h" 1 3 4
> # 1 "/usr/include/asm-generic/socket.h" 1 3 4
> # 1 "/usr/include/asm/sockios.h" 1 3 4
> # 1 "/usr/include/asm-generic/sockios.h" 1 3 4
> # 1 "/usr/include/asm/sockios.h" 2 3 4
> # 5 "/usr/include/asm-generic/socket.h" 2 3 4
> # 1 "/usr/include/asm/socket.h" 2 3 4
> # 371 "/usr/include/bits/socket.h" 2 3 4
> # 404 "/usr/include/bits/socket.h" 3 4
> struct linger
> int l_onoff;
> int l_linger;
> # 41 "/usr/include/sys/socket.h" 2 3 4
> struct osockaddr
> unsigned short int sa_family;
> unsigned char sa_data[14];
> enum
> SHUT_RD = 0,
> SHUT_WR,
> SHUT_RDWR
> # 105 "/usr/include/sys/socket.h" 3 4
> extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__));
> extern int socketpair (int __domain, int __type, int __protocol,
> int __fds[2]) __attribute__ ((__nothrow__));
> extern int bind (int __fd, __const struct sockaddr * __addr, socklen_t __len)
> extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
> socklen_t *__restrict __len) __attribute__ ((__nothrow__));
> # 129 "/usr/include/sys/socket.h" 3 4
> extern int connect (int __fd, __const struct sockaddr * __addr, socklen_t __len);
> extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
> extern ssize_t send (int __fd, __const void *__buf, size_t __n, int __flags);
> extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
> extern ssize_t sendto (int __fd, __const void *__buf, size_t __n,
> int __flags, __const struct sockaddr * __addr,
> socklen_t __addr_len);
> # 166 "/usr/include/sys/socket.h" 3 4
> extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
> int __flags, struct sockaddr *__restrict __addr,
> socklen_t *__restrict __addr_len);
> extern ssize_t sendmsg (int __fd, __const struct msghdr *__message,
> int __flags);
> extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
> extern int getsockopt (int __fd, int __level, int __optname,
> void *__restrict __optval,
> socklen_t *__restrict __optlen) __attribute__ ((__nothrow__));
> extern int setsockopt (int __fd, int __level, int __optname,
> __const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__));
> extern int listen (int __fd, int __n) __attribute__ ((__nothrow__));
> # 214 "/usr/include/sys/socket.h" 3 4
> extern int accept (int __fd, struct sockaddr *__restrict __addr,
> # 232 "/usr/include/sys/socket.h" 3 4
> extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__));
> extern int sockatmark (int __fd) __attribute__ ((__nothrow__));
> extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__));
> # 254 "/usr/include/sys/socket.h" 3 4
> Defined "HAVE_SYS_SOCKET_H" to "1"
> Checking for header: sys/types.h
> stdout:
> # 1 "<built-in>"
> # 27 "/usr/include/sys/types.h" 3 4
> # 28 "/usr/include/sys/types.h" 2 3 4
> # 31 "/usr/include/bits/types.h" 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> typedef struct
> } fd_set;
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> Defined "HAVE_SYS_TYPES_H" to "1"
> Checking for header: malloc.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/malloc.h" 1 3 4
> # 24 "/usr/include/malloc.h" 3 4
> # 25 "/usr/include/malloc.h" 2 3 4
> # 149 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long int ptrdiff_t;
> # 328 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef int wchar_t;
> # 426 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef struct {
> long long __max_align_ll __attribute__((__aligned__(__alignof__(long long))));
> long double __max_align_ld __attribute__((__aligned__(__alignof__(long double))));
> } max_align_t;
> # 26 "/usr/include/malloc.h" 2 3 4
> # 1 "/usr/include/stdio.h" 1 3 4
> # 30 "/usr/include/stdio.h" 3 4
> # 35 "/usr/include/stdio.h" 2 3 4
> # 37 "/usr/include/stdio.h" 2 3 4
> # 45 "/usr/include/stdio.h" 3 4
> struct _IO_FILE;
> typedef struct _IO_FILE FILE;
> # 65 "/usr/include/stdio.h" 3 4
> typedef struct _IO_FILE __FILE;
> # 75 "/usr/include/stdio.h" 3 4
> # 1 "/usr/include/libio.h" 1 3 4
> # 32 "/usr/include/libio.h" 3 4
> # 1 "/usr/include/_G_config.h" 1 3 4
> # 15 "/usr/include/_G_config.h" 3 4
> # 16 "/usr/include/_G_config.h" 2 3 4
> # 1 "/usr/include/wchar.h" 1 3 4
> # 83 "/usr/include/wchar.h" 3 4
> typedef struct
> int __count;
> union
> unsigned int __wch;
> char __wchb[4];
> } __value;
> } __mbstate_t;
> # 21 "/usr/include/_G_config.h" 2 3 4
> typedef struct
> __off_t __pos;
> __mbstate_t __state;
> } _G_fpos_t;
> typedef struct
> __off64_t __pos;
> } _G_fpos64_t;
> # 53 "/usr/include/_G_config.h" 3 4
> typedef int _G_int16_t __attribute__ ((__mode__ (__HI__)));
> typedef int _G_int32_t __attribute__ ((__mode__ (__SI__)));
> typedef unsigned int _G_uint16_t __attribute__ ((__mode__ (__HI__)));
> typedef unsigned int _G_uint32_t __attribute__ ((__mode__ (__SI__)));
> # 33 "/usr/include/libio.h" 2 3 4
> # 53 "/usr/include/libio.h" 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdarg.h" 1 3 4
> # 40 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdarg.h" 3 4
> typedef __builtin_va_list __gnuc_va_list;
> # 54 "/usr/include/libio.h" 2 3 4
> # 170 "/usr/include/libio.h" 3 4
> struct _IO_jump_t; struct _IO_FILE;
> # 180 "/usr/include/libio.h" 3 4
> typedef void _IO_lock_t;
> struct _IO_marker {
> struct _IO_marker *_next;
> struct _IO_FILE *_sbuf;
> int _pos;
> # 203 "/usr/include/libio.h" 3 4
> enum __codecvt_result
> __codecvt_ok,
> __codecvt_partial,
> __codecvt_error,
> __codecvt_noconv
> # 271 "/usr/include/libio.h" 3 4
> struct _IO_FILE {
> int _flags;
> char* _IO_read_ptr;
> char* _IO_read_end;
> char* _IO_read_base;
> char* _IO_write_base;
> char* _IO_write_ptr;
> char* _IO_write_end;
> char* _IO_buf_base;
> char* _IO_buf_end;
> char *_IO_save_base;
> char *_IO_backup_base;
> char *_IO_save_end;
> struct _IO_marker *_markers;
> struct _IO_FILE *_chain;
> int _fileno;
> int _flags2;
> __off_t _old_offset;
> unsigned short _cur_column;
> signed char _vtable_offset;
> char _shortbuf[1];
> _IO_lock_t *_lock;
> # 319 "/usr/include/libio.h" 3 4
> __off64_t _offset;
> # 328 "/usr/include/libio.h" 3 4
> void *__pad1;
> void *__pad2;
> void *__pad3;
> void *__pad4;
> size_t __pad5;
> int _mode;
> char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
> typedef struct _IO_FILE _IO_FILE;
> struct _IO_FILE_plus;
> extern struct _IO_FILE_plus _IO_2_1_stdin_;
> extern struct _IO_FILE_plus _IO_2_1_stdout_;
> extern struct _IO_FILE_plus _IO_2_1_stderr_;
> # 364 "/usr/include/libio.h" 3 4
> typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
> typedef __ssize_t __io_write_fn (void *__cookie, __const char *__buf,
> size_t __n);
> typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
> typedef int __io_close_fn (void *__cookie);
> # 416 "/usr/include/libio.h" 3 4
> extern int __underflow (_IO_FILE *);
> extern int __uflow (_IO_FILE *);
> extern int __overflow (_IO_FILE *, int);
> # 460 "/usr/include/libio.h" 3 4
> extern int _IO_getc (_IO_FILE *__fp);
> extern int _IO_putc (int __c, _IO_FILE *__fp);
> extern int _IO_feof (_IO_FILE *__fp) __attribute__ ((__nothrow__));
> extern int _IO_ferror (_IO_FILE *__fp) __attribute__ ((__nothrow__));
> extern int _IO_peekc_locked (_IO_FILE *__fp);
> extern void _IO_flockfile (_IO_FILE *) __attribute__ ((__nothrow__));
> extern void _IO_funlockfile (_IO_FILE *) __attribute__ ((__nothrow__));
> extern int _IO_ftrylockfile (_IO_FILE *) __attribute__ ((__nothrow__));
> # 490 "/usr/include/libio.h" 3 4
> extern int _IO_vfscanf (_IO_FILE * __restrict, const char * __restrict,
> __gnuc_va_list, int *__restrict);
> extern int _IO_vfprintf (_IO_FILE *__restrict, const char *__restrict,
> __gnuc_va_list);
> extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
> extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
> extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
> extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
> extern void _IO_free_backup_area (_IO_FILE *) __attribute__ ((__nothrow__));
> # 76 "/usr/include/stdio.h" 2 3 4
> # 89 "/usr/include/stdio.h" 3 4
> typedef _G_fpos_t fpos_t;
> # 141 "/usr/include/stdio.h" 3 4
> # 1 "/usr/include/bits/stdio_lim.h" 1 3 4
> # 142 "/usr/include/stdio.h" 2 3 4
> extern struct _IO_FILE *stdin;
> extern struct _IO_FILE *stdout;
> extern struct _IO_FILE *stderr;
> extern int remove (__const char *__filename) __attribute__ ((__nothrow__));
> extern int rename (__const char *__old, __const char *__new) __attribute__ ((__nothrow__));
> extern int renameat (int __oldfd, __const char *__old, int __newfd,
> extern FILE *tmpfile (void) ;
> # 188 "/usr/include/stdio.h" 3 4
> extern char *tmpnam (char *__s) __attribute__ ((__nothrow__)) ;
> extern char *tmpnam_r (char *__s) __attribute__ ((__nothrow__)) ;
> # 206 "/usr/include/stdio.h" 3 4
> extern char *tempnam (__const char *__dir, __const char *__pfx)
> __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern int fclose (FILE *__stream);
> extern int fflush (FILE *__stream);
> # 231 "/usr/include/stdio.h" 3 4
> extern int fflush_unlocked (FILE *__stream);
> # 245 "/usr/include/stdio.h" 3 4
> extern FILE *fopen (__const char *__restrict __filename,
> __const char *__restrict __modes) ;
> extern FILE *freopen (__const char *__restrict __filename,
> __const char *__restrict __modes,
> FILE *__restrict __stream) ;
> # 274 "/usr/include/stdio.h" 3 4
> # 285 "/usr/include/stdio.h" 3 4
> extern FILE *fdopen (int __fd, __const char *__modes) __attribute__ ((__nothrow__)) ;
> # 298 "/usr/include/stdio.h" 3 4
> extern FILE *fmemopen (void *__s, size_t __len, __const char *__modes)
> extern FILE *open_memstream (char **__bufloc, size_t *__sizeloc) __attribute__ ((__nothrow__)) ;
> extern void setbuf (FILE *__restrict __stream, char *__restrict __buf) __attribute__ ((__nothrow__));
> extern int setvbuf (FILE *__restrict __stream, char *__restrict __buf,
> int __modes, size_t __n) __attribute__ ((__nothrow__));
> extern void setbuffer (FILE *__restrict __stream, char *__restrict __buf,
> size_t __size) __attribute__ ((__nothrow__));
> extern void setlinebuf (FILE *__stream) __attribute__ ((__nothrow__));
> extern int fprintf (FILE *__restrict __stream,
> __const char *__restrict __format, ...);
> extern int printf (__const char *__restrict __format, ...);
> extern int sprintf (char *__restrict __s,
> __const char *__restrict __format, ...) __attribute__ ((__nothrow__));
> extern int vfprintf (FILE *__restrict __s, __const char *__restrict __format,
> __gnuc_va_list __arg);
> extern int vprintf (__const char *__restrict __format, __gnuc_va_list __arg);
> extern int vsprintf (char *__restrict __s, __const char *__restrict __format,
> __gnuc_va_list __arg) __attribute__ ((__nothrow__));
> extern int snprintf (char *__restrict __s, size_t __maxlen,
> __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 4)));
> extern int vsnprintf (char *__restrict __s, size_t __maxlen,
> __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__printf__, 3, 0)));
> # 396 "/usr/include/stdio.h" 3 4
> extern int vdprintf (int __fd, __const char *__restrict __fmt,
> __attribute__ ((__format__ (__printf__, 2, 0)));
> extern int dprintf (int __fd, __const char *__restrict __fmt, ...)
> __attribute__ ((__format__ (__printf__, 2, 3)));
> extern int fscanf (FILE *__restrict __stream,
> __const char *__restrict __format, ...) ;
> extern int scanf (__const char *__restrict __format, ...) ;
> extern int sscanf (__const char *__restrict __s,
> # 427 "/usr/include/stdio.h" 3 4
> extern int fscanf (FILE *__restrict __stream, __const char *__restrict __format, ...) __asm__ ("" "__isoc99_fscanf")
> extern int scanf (__const char *__restrict __format, ...) __asm__ ("" "__isoc99_scanf")
> extern int sscanf (__const char *__restrict __s, __const char *__restrict __format, ...) __asm__ ("" "__isoc99_sscanf") __attribute__ ((__nothrow__))
> # 447 "/usr/include/stdio.h" 3 4
> extern int vfscanf (FILE *__restrict __s, __const char *__restrict __format,
> __attribute__ ((__format__ (__scanf__, 2, 0))) ;
> extern int vscanf (__const char *__restrict __format, __gnuc_va_list __arg)
> __attribute__ ((__format__ (__scanf__, 1, 0))) ;
> extern int vsscanf (__const char *__restrict __s,
> __attribute__ ((__nothrow__)) __attribute__ ((__format__ (__scanf__, 2, 0)));
> # 478 "/usr/include/stdio.h" 3 4
> extern int vfscanf (FILE *__restrict __s, __const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vfscanf")
> extern int vscanf (__const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vscanf")
> extern int vsscanf (__const char *__restrict __s, __const char *__restrict __format, __gnuc_va_list __arg) __asm__ ("" "__isoc99_vsscanf") __attribute__ ((__nothrow__))
> # 506 "/usr/include/stdio.h" 3 4
> extern int fgetc (FILE *__stream);
> extern int getc (FILE *__stream);
> extern int getchar (void);
> # 534 "/usr/include/stdio.h" 3 4
> extern int getc_unlocked (FILE *__stream);
> extern int getchar_unlocked (void);
> # 545 "/usr/include/stdio.h" 3 4
> extern int fgetc_unlocked (FILE *__stream);
> extern int fputc (int __c, FILE *__stream);
> extern int putc (int __c, FILE *__stream);
> extern int putchar (int __c);
> # 578 "/usr/include/stdio.h" 3 4
> extern int fputc_unlocked (int __c, FILE *__stream);
> extern int putc_unlocked (int __c, FILE *__stream);
> extern int putchar_unlocked (int __c);
> extern int getw (FILE *__stream);
> extern int putw (int __w, FILE *__stream);
> extern char *fgets (char *__restrict __s, int __n, FILE *__restrict __stream)
> extern char *gets (char *__s) ;
> # 640 "/usr/include/stdio.h" 3 4
> extern __ssize_t __getdelim (char **__restrict __lineptr,
> size_t *__restrict __n, int __delimiter,
> extern __ssize_t getdelim (char **__restrict __lineptr,
> extern __ssize_t getline (char **__restrict __lineptr,
> extern int fputs (__const char *__restrict __s, FILE *__restrict __stream);
> extern int puts (__const char *__s);
> extern int ungetc (int __c, FILE *__stream);
> extern size_t fread (void *__restrict __ptr, size_t __size,
> size_t __n, FILE *__restrict __stream) ;
> extern size_t fwrite (__const void *__restrict __ptr, size_t __size,
> size_t __n, FILE *__restrict __s) ;
> # 712 "/usr/include/stdio.h" 3 4
> extern size_t fread_unlocked (void *__restrict __ptr, size_t __size,
> extern size_t fwrite_unlocked (__const void *__restrict __ptr, size_t __size,
> extern int fseek (FILE *__stream, long int __off, int __whence);
> extern long int ftell (FILE *__stream) ;
> extern void rewind (FILE *__stream);
> # 748 "/usr/include/stdio.h" 3 4
> extern int fseeko (FILE *__stream, __off_t __off, int __whence);
> extern __off_t ftello (FILE *__stream) ;
> # 767 "/usr/include/stdio.h" 3 4
> extern int fgetpos (FILE *__restrict __stream, fpos_t *__restrict __pos);
> extern int fsetpos (FILE *__stream, __const fpos_t *__pos);
> # 790 "/usr/include/stdio.h" 3 4
> # 799 "/usr/include/stdio.h" 3 4
> extern void clearerr (FILE *__stream) __attribute__ ((__nothrow__));
> extern int feof (FILE *__stream) __attribute__ ((__nothrow__)) ;
> extern int ferror (FILE *__stream) __attribute__ ((__nothrow__)) ;
> extern void clearerr_unlocked (FILE *__stream) __attribute__ ((__nothrow__));
> extern int feof_unlocked (FILE *__stream) __attribute__ ((__nothrow__)) ;
> extern int ferror_unlocked (FILE *__stream) __attribute__ ((__nothrow__)) ;
> extern void perror (__const char *__s);
> # 1 "/usr/include/bits/sys_errlist.h" 1 3 4
> # 27 "/usr/include/bits/sys_errlist.h" 3 4
> extern int sys_nerr;
> extern __const char *__const sys_errlist[];
> # 829 "/usr/include/stdio.h" 2 3 4
> extern int fileno (FILE *__stream) __attribute__ ((__nothrow__)) ;
> extern int fileno_unlocked (FILE *__stream) __attribute__ ((__nothrow__)) ;
> # 848 "/usr/include/stdio.h" 3 4
> extern FILE *popen (__const char *__command, __const char *__modes) ;
> extern int pclose (FILE *__stream);
> extern char *ctermid (char *__s) __attribute__ ((__nothrow__));
> # 888 "/usr/include/stdio.h" 3 4
> extern void flockfile (FILE *__stream) __attribute__ ((__nothrow__));
> extern int ftrylockfile (FILE *__stream) __attribute__ ((__nothrow__)) ;
> extern void funlockfile (FILE *__stream) __attribute__ ((__nothrow__));
> # 918 "/usr/include/stdio.h" 3 4
> # 27 "/usr/include/malloc.h" 2 3 4
> # 48 "/usr/include/malloc.h" 3 4
> extern void *malloc (size_t __size) __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern void *calloc (size_t __nmemb, size_t __size) __attribute__ ((__nothrow__))
> extern void *realloc (void *__ptr, size_t __size) __attribute__ ((__nothrow__))
> __attribute__ ((__warn_unused_result__));
> extern void free (void *__ptr) __attribute__ ((__nothrow__));
> extern void cfree (void *__ptr) __attribute__ ((__nothrow__));
> extern void *memalign (size_t __alignment, size_t __size) __attribute__ ((__nothrow__))
> extern void *valloc (size_t __size) __attribute__ ((__nothrow__))
> extern void * pvalloc (size_t __size) __attribute__ ((__nothrow__))
> extern void *(*__morecore) (ptrdiff_t __size);
> extern void *__default_morecore (ptrdiff_t __size) __attribute__ ((__nothrow__))
> __attribute__ ((__malloc__));
> struct mallinfo {
> int arena;
> int ordblks;
> int smblks;
> int hblks;
> int hblkhd;
> int usmblks;
> int fsmblks;
> int uordblks;
> int fordblks;
> int keepcost;
> extern struct mallinfo mallinfo (void) __attribute__ ((__nothrow__));
> # 135 "/usr/include/malloc.h" 3 4
> extern int mallopt (int __param, int __val) __attribute__ ((__nothrow__));
> extern int malloc_trim (size_t __pad) __attribute__ ((__nothrow__));
> extern size_t malloc_usable_size (void *__ptr) __attribute__ ((__nothrow__));
> extern void malloc_stats (void) __attribute__ ((__nothrow__));
> extern int malloc_info (int __options, FILE *__fp);
> extern void *malloc_get_state (void) __attribute__ ((__nothrow__));
> extern int malloc_set_state (void *__ptr) __attribute__ ((__nothrow__));
> extern void (*__malloc_initialize_hook) (void);
> extern void (*__free_hook) (void *__ptr, __const void *)
> extern void *(*__malloc_hook) (size_t __size, __const void *)
> extern void *(*__realloc_hook) (void *__ptr, size_t __size, __const void *)
> extern void *(*__memalign_hook) (size_t __alignment, size_t __size, __const void *)
> extern void (*__after_morecore_hook) (void);
> extern void __malloc_check_init (void) __attribute__ ((__nothrow__));
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Defined "HAVE_MALLOC_H" to "1"
> Checking for header: time.h
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 28 "/usr/include/time.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 29 "/usr/include/time.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 39 "/usr/include/time.h" 2 3 4
> # 43 "/usr/include/time.h" 2 3 4
> # 56 "/usr/include/time.h" 3 4
> # 57 "/usr/include/time.h" 2 3 4
> typedef __clock_t clock_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct tm
> int tm_sec;
> int tm_min;
> int tm_hour;
> int tm_mday;
> int tm_mon;
> int tm_year;
> int tm_wday;
> int tm_yday;
> int tm_isdst;
> long int tm_gmtoff;
> __const char *tm_zone;
> struct itimerspec
> struct timespec it_interval;
> struct timespec it_value;
> struct sigevent;
> extern clock_t clock (void) __attribute__ ((__nothrow__));
> extern time_t time (time_t *__timer) __attribute__ ((__nothrow__));
> extern double difftime (time_t __time1, time_t __time0)
> extern time_t mktime (struct tm *__tp) __attribute__ ((__nothrow__));
> extern size_t strftime (char *__restrict __s, size_t __maxsize,
> __const struct tm *__restrict __tp) __attribute__ ((__nothrow__));
> # 215 "/usr/include/time.h" 3 4
> # 1 "/usr/include/xlocale.h" 1 3 4
> # 28 "/usr/include/xlocale.h" 3 4
> typedef struct __locale_struct
> struct locale_data *__locales[13];
> const unsigned short int *__ctype_b;
> const int *__ctype_tolower;
> const int *__ctype_toupper;
> const char *__names[13];
> } *__locale_t;
> typedef __locale_t locale_t;
> # 216 "/usr/include/time.h" 2 3 4
> extern size_t strftime_l (char *__restrict __s, size_t __maxsize,
> __const struct tm *__restrict __tp,
> __locale_t __loc) __attribute__ ((__nothrow__));
> # 230 "/usr/include/time.h" 3 4
> extern struct tm *gmtime (__const time_t *__timer) __attribute__ ((__nothrow__));
> extern struct tm *localtime (__const time_t *__timer) __attribute__ ((__nothrow__));
> extern struct tm *gmtime_r (__const time_t *__restrict __timer,
> extern struct tm *localtime_r (__const time_t *__restrict __timer,
> extern char *asctime (__const struct tm *__tp) __attribute__ ((__nothrow__));
> extern char *ctime (__const time_t *__timer) __attribute__ ((__nothrow__));
> extern char *asctime_r (__const struct tm *__restrict __tp,
> extern char *ctime_r (__const time_t *__restrict __timer,
> extern char *__tzname[2];
> extern int __daylight;
> extern long int __timezone;
> extern char *tzname[2];
> extern void tzset (void) __attribute__ ((__nothrow__));
> extern int daylight;
> extern long int timezone;
> extern int stime (__const time_t *__when) __attribute__ ((__nothrow__));
> # 313 "/usr/include/time.h" 3 4
> extern time_t timegm (struct tm *__tp) __attribute__ ((__nothrow__));
> extern time_t timelocal (struct tm *__tp) __attribute__ ((__nothrow__));
> extern int dysize (int __year) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> # 328 "/usr/include/time.h" 3 4
> extern int nanosleep (__const struct timespec *__requested_time,
> struct timespec *__remaining);
> extern int clock_getres (clockid_t __clock_id, struct timespec *__res) __attribute__ ((__nothrow__));
> extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) __attribute__ ((__nothrow__));
> extern int clock_settime (clockid_t __clock_id, __const struct timespec *__tp)
> extern int clock_nanosleep (clockid_t __clock_id, int __flags,
> __const struct timespec *__req,
> struct timespec *__rem);
> extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) __attribute__ ((__nothrow__));
> extern int timer_create (clockid_t __clock_id,
> struct sigevent *__restrict __evp,
> timer_t *__restrict __timerid) __attribute__ ((__nothrow__));
> extern int timer_delete (timer_t __timerid) __attribute__ ((__nothrow__));
> extern int timer_settime (timer_t __timerid, int __flags,
> __const struct itimerspec *__restrict __value,
> struct itimerspec *__restrict __ovalue) __attribute__ ((__nothrow__));
> extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
> extern int timer_getoverrun (timer_t __timerid) __attribute__ ((__nothrow__));
> # 417 "/usr/include/time.h" 3 4
> Defined "HAVE_TIME_H" to "1"
> Checking for header: Direct.h
> stdout:
> # 1 "<built-in>"
> Possible ERROR while running preprocessor: exit code 256
> stdout:
> # 1 "<built-in>"
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2stderr:
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
> compilation terminated.
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> #include <Direct.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: Direct.h: No such file or directorycompilation terminated.:
> Checking for header: Ws2tcpip.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
> Source:
> #include <Ws2tcpip.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:22: fatal error: Ws2tcpip.h: No such file or directorycompilation terminated.:
> Checking for header: endian.h
> stdout:
> # 1 "<built-in>"
> # 22 "/usr/include/endian.h" 3 4
> # 23 "/usr/include/endian.h" 2 3 4
> Defined "HAVE_ENDIAN_H" to "1"
> Checking for header: ieeefp.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
> Source:
> #include <ieeefp.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: ieeefp.h: No such file or directorycompilation terminated.:
> Checking for header: strings.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/strings.h" 1 3 4
> # 27 "/usr/include/strings.h" 3 4
> # 28 "/usr/include/strings.h" 2 3 4
> # 30 "/usr/include/strings.h" 2 3 4
> extern int bcmp (__const void *__s1, __const void *__s2, size_t __n)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__));
> extern void bcopy (__const void *__src, void *__dest, size_t __n) __attribute__ ((__nothrow__));
> extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__));
> extern int ffs (int __i) __attribute__ ((__nothrow__)) __attribute__ ((const));
> # 76 "/usr/include/strings.h" 3 4
> extern char *index (__const char *__s, int __c)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
> # 104 "/usr/include/strings.h" 3 4
> extern char *rindex (__const char *__s, int __c)
> extern int strcasecmp (__const char *__s1, __const char *__s2)
> extern int strncasecmp (__const char *__s1, __const char *__s2, size_t __n)
> } *__locale_t;
> # 121 "/usr/include/strings.h" 2 3 4
> extern int strcasecmp_l (__const char *__s1, __const char *__s2,
> __locale_t __loc)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 3)));
> extern int strncasecmp_l (__const char *__s1, __const char *__s2,
> size_t __n, __locale_t __loc)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2, 4)));
> Defined "HAVE_STRINGS_H" to "1"
> Checking for header: inttypes.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/inttypes.h" 1 3 4
> # 26 "/usr/include/inttypes.h" 3 4
> # 27 "/usr/include/inttypes.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 1 3 4
> # 9 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 3 4
> # 1 "/usr/include/stdint.h" 1 3 4
> # 27 "/usr/include/stdint.h" 3 4
> # 1 "/usr/include/bits/wchar.h" 1 3 4
> # 28 "/usr/include/stdint.h" 2 3 4
> # 29 "/usr/include/stdint.h" 2 3 4
> # 37 "/usr/include/stdint.h" 3 4
> typedef signed char int8_t;
> typedef short int int16_t;
> typedef int int32_t;
> typedef long int int64_t;
> typedef unsigned char uint8_t;
> typedef unsigned short int uint16_t;
> typedef unsigned int uint32_t;
> typedef unsigned long int uint64_t;
> # 66 "/usr/include/stdint.h" 3 4
> typedef signed char int_least8_t;
> typedef short int int_least16_t;
> typedef int int_least32_t;
> typedef long int int_least64_t;
> typedef unsigned char uint_least8_t;
> typedef unsigned short int uint_least16_t;
> typedef unsigned int uint_least32_t;
> typedef unsigned long int uint_least64_t;
> # 91 "/usr/include/stdint.h" 3 4
> typedef signed char int_fast8_t;
> typedef long int int_fast16_t;
> typedef long int int_fast32_t;
> typedef long int int_fast64_t;
> # 104 "/usr/include/stdint.h" 3 4
> typedef unsigned char uint_fast8_t;
> typedef unsigned long int uint_fast16_t;
> typedef unsigned long int uint_fast32_t;
> typedef unsigned long int uint_fast64_t;
> # 120 "/usr/include/stdint.h" 3 4
> typedef long int intptr_t;
> typedef unsigned long int uintptr_t;
> # 135 "/usr/include/stdint.h" 3 4
> typedef long int intmax_t;
> typedef unsigned long int uintmax_t;
> # 10 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 2 3 4
> # 29 "/usr/include/inttypes.h" 2 3 4
> typedef int __gwchar_t;
> # 274 "/usr/include/inttypes.h" 3 4
> typedef struct
> long int quot;
> long int rem;
> } imaxdiv_t;
> # 298 "/usr/include/inttypes.h" 3 4
> extern intmax_t imaxabs (intmax_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
> extern intmax_t strtoimax (__const char *__restrict __nptr,
> char **__restrict __endptr, int __base) __attribute__ ((__nothrow__));
> extern uintmax_t strtoumax (__const char *__restrict __nptr,
> char ** __restrict __endptr, int __base) __attribute__ ((__nothrow__));
> extern intmax_t wcstoimax (__const __gwchar_t *__restrict __nptr,
> __gwchar_t **__restrict __endptr, int __base)
> extern uintmax_t wcstoumax (__const __gwchar_t *__restrict __nptr,
> __gwchar_t ** __restrict __endptr, int __base)
> # 442 "/usr/include/inttypes.h" 3 4
> Defined "HAVE_INTTYPES_H" to "1"
> Checking for header: sched.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sched.h" 1 3 4
> # 23 "/usr/include/sched.h" 3 4
> # 24 "/usr/include/sched.h" 2 3 4
> # 27 "/usr/include/sched.h" 2 3 4
> # 30 "/usr/include/sched.h" 2 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 33 "/usr/include/sched.h" 2 3 4
> # 1 "/usr/include/bits/sched.h" 1 3 4
> # 71 "/usr/include/bits/sched.h" 3 4
> struct sched_param
> int __sched_priority;
> extern int clone (int (*__fn) (void *__arg), void *__child_stack,
> int __flags, void *__arg, ...) __attribute__ ((__nothrow__));
> extern int unshare (int __flags) __attribute__ ((__nothrow__));
> extern int sched_getcpu (void) __attribute__ ((__nothrow__));
> struct __sched_param
> # 113 "/usr/include/bits/sched.h" 3 4
> typedef unsigned long int __cpu_mask;
> typedef struct
> __cpu_mask __bits[4096 / (8 * sizeof (__cpu_mask))];
> } cpu_set_t;
> # 196 "/usr/include/bits/sched.h" 3 4
> extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
> extern cpu_set_t *__sched_cpualloc (size_t __count) __attribute__ ((__nothrow__)) ;
> extern void __sched_cpufree (cpu_set_t *__set) __attribute__ ((__nothrow__));
> # 36 "/usr/include/sched.h" 2 3 4
> extern int sched_setparam (__pid_t __pid, __const struct sched_param *__param)
> extern int sched_getparam (__pid_t __pid, struct sched_param *__param) __attribute__ ((__nothrow__));
> extern int sched_setscheduler (__pid_t __pid, int __policy,
> __const struct sched_param *__param) __attribute__ ((__nothrow__));
> extern int sched_getscheduler (__pid_t __pid) __attribute__ ((__nothrow__));
> extern int sched_yield (void) __attribute__ ((__nothrow__));
> extern int sched_get_priority_max (int __algorithm) __attribute__ ((__nothrow__));
> extern int sched_get_priority_min (int __algorithm) __attribute__ ((__nothrow__));
> extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) __attribute__ ((__nothrow__));
> # 118 "/usr/include/sched.h" 3 4
> Defined "HAVE_SCHED_H" to "1"
> Checking for header: cxxabi.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
> Source:
> #include <cxxabi.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: cxxabi.h: No such file or directorycompilation terminated.:
> Checking for header: sys/systeminfo.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
> Source:
> #include <sys/systeminfo.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directorycompilation terminated.:
> Checking for header: dos.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
> Source:
> #include <dos.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:17: fatal error: dos.h: No such file or directorycompilation terminated.:
> Checking for header: WindowsX.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
> Source:
> #include <WindowsX.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:22: fatal error: WindowsX.h: No such file or directorycompilation terminated.:
> Checking for header: sys/sysinfo.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/sysinfo.h" 1 3 4
> # 22 "/usr/include/sys/sysinfo.h" 3 4
> # 23 "/usr/include/sys/sysinfo.h" 2 3 4
> # 1 "/usr/include/linux/kernel.h" 1 3 4
> # 11 "/usr/include/linux/kernel.h" 3 4
> struct sysinfo {
> long uptime;
> unsigned long loads[3];
> unsigned long totalram;
> unsigned long freeram;
> unsigned long sharedram;
> unsigned long bufferram;
> unsigned long totalswap;
> unsigned long freeswap;
> unsigned short procs;
> unsigned short pad;
> unsigned long totalhigh;
> unsigned long freehigh;
> unsigned int mem_unit;
> char _f[20-2*sizeof(long)-sizeof(int)];
> # 26 "/usr/include/sys/sysinfo.h" 2 3 4
> extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__));
> extern int get_nprocs_conf (void) __attribute__ ((__nothrow__));
> extern int get_nprocs (void) __attribute__ ((__nothrow__));
> extern long int get_phys_pages (void) __attribute__ ((__nothrow__));
> extern long int get_avphys_pages (void) __attribute__ ((__nothrow__));
> Defined "HAVE_SYS_SYSINFO_H" to "1"
> Checking for header: sys/wait.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/wait.h" 1 3 4
> # 27 "/usr/include/sys/wait.h" 3 4
> # 28 "/usr/include/sys/wait.h" 2 3 4
> # 1 "/usr/include/signal.h" 1 3 4
> # 31 "/usr/include/signal.h" 3 4
> typedef struct
> } __sigset_t;
> # 104 "/usr/include/bits/sigset.h" 3 4
> extern int __sigismember (__const __sigset_t *, int);
> extern int __sigaddset (__sigset_t *, int);
> extern int __sigdelset (__sigset_t *, int);
> # 34 "/usr/include/signal.h" 2 3 4
> typedef __sig_atomic_t sig_atomic_t;
> # 58 "/usr/include/signal.h" 2 3 4
> # 1 "/usr/include/bits/signum.h" 1 3 4
> # 59 "/usr/include/signal.h" 2 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 77 "/usr/include/signal.h" 2 3 4
> # 1 "/usr/include/bits/siginfo.h" 1 3 4
> # 25 "/usr/include/bits/siginfo.h" 3 4
> # 26 "/usr/include/bits/siginfo.h" 2 3 4
> typedef union sigval
> int sival_int;
> void *sival_ptr;
> } sigval_t;
> # 51 "/usr/include/bits/siginfo.h" 3 4
> typedef struct siginfo
> int si_signo;
> int si_errno;
> int si_code;
> union
> int _pad[((128 / sizeof (int)) - 4)];
> struct
> __pid_t si_pid;
> __uid_t si_uid;
> } _kill;
> struct
> int si_tid;
> int si_overrun;
> sigval_t si_sigval;
> } _timer;
> struct
> __pid_t si_pid;
> __uid_t si_uid;
> sigval_t si_sigval;
> } _rt;
> struct
> __pid_t si_pid;
> __uid_t si_uid;
> int si_status;
> __clock_t si_utime;
> __clock_t si_stime;
> } _sigchld;
> struct
> void *si_addr;
> } _sigfault;
> struct
> long int si_band;
> int si_fd;
> } _sigpoll;
> } _sifields;
> } siginfo_t;
> # 129 "/usr/include/bits/siginfo.h" 3 4
> enum
> SI_ASYNCNL = -60,
> SI_TKILL = -6,
> SI_SIGIO,
> SI_ASYNCIO,
> SI_MESGQ,
> SI_TIMER,
> SI_QUEUE,
> SI_USER,
> SI_KERNEL = 0x80
> enum
> ILL_ILLOPC = 1,
> ILL_ILLOPN,
> ILL_ILLADR,
> ILL_ILLTRP,
> ILL_PRVOPC,
> ILL_PRVREG,
> ILL_COPROC,
> ILL_BADSTK
> enum
> FPE_INTDIV = 1,
> FPE_INTOVF,
> FPE_FLTDIV,
> FPE_FLTOVF,
> FPE_FLTUND,
> FPE_FLTRES,
> FPE_FLTINV,
> FPE_FLTSUB
> enum
> SEGV_MAPERR = 1,
> SEGV_ACCERR
> enum
> BUS_ADRALN = 1,
> BUS_ADRERR,
> BUS_OBJERR
> enum
> TRAP_BRKPT = 1,
> TRAP_TRACE
> enum
> CLD_EXITED = 1,
> CLD_KILLED,
> CLD_DUMPED,
> CLD_TRAPPED,
> CLD_STOPPED,
> CLD_CONTINUED
> enum
> POLL_IN = 1,
> POLL_OUT,
> POLL_MSG,
> POLL_ERR,
> POLL_PRI,
> POLL_HUP
> # 273 "/usr/include/bits/siginfo.h" 3 4
> typedef struct sigevent
> sigval_t sigev_value;
> int sigev_signo;
> int sigev_notify;
> union
> int _pad[((64 / sizeof (int)) - 4)];
> __pid_t _tid;
> struct
> void (*_function) (sigval_t);
> void *_attribute;
> } _sigev_thread;
> } _sigev_un;
> } sigevent_t;
> enum
> SIGEV_SIGNAL = 0,
> SIGEV_NONE,
> SIGEV_THREAD,
> SIGEV_THREAD_ID = 4
> # 80 "/usr/include/signal.h" 2 3 4
> typedef void (*__sighandler_t) (int);
> extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
> # 99 "/usr/include/signal.h" 3 4
> extern __sighandler_t signal (int __sig, __sighandler_t __handler)
> # 113 "/usr/include/signal.h" 3 4
> # 126 "/usr/include/signal.h" 3 4
> extern int kill (__pid_t __pid, int __sig) __attribute__ ((__nothrow__));
> extern int killpg (__pid_t __pgrp, int __sig) __attribute__ ((__nothrow__));
> extern int raise (int __sig) __attribute__ ((__nothrow__));
> extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
> extern int gsignal (int __sig) __attribute__ ((__nothrow__));
> extern void psignal (int __sig, __const char *__s);
> extern void psiginfo (__const siginfo_t *__pinfo, __const char *__s);
> # 168 "/usr/include/signal.h" 3 4
> extern int __sigpause (int __sig_or_mask, int __is_sig);
> # 196 "/usr/include/signal.h" 3 4
> extern int sigblock (int __mask) __attribute__ ((__nothrow__)) __attribute__ ((__deprecated__));
> extern int sigsetmask (int __mask) __attribute__ ((__nothrow__)) __attribute__ ((__deprecated__));
> extern int siggetmask (void) __attribute__ ((__nothrow__)) __attribute__ ((__deprecated__));
> # 216 "/usr/include/signal.h" 3 4
> typedef __sighandler_t sig_t;
> extern int sigemptyset (sigset_t *__set) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int sigfillset (sigset_t *__set) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int sigaddset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int sigdelset (sigset_t *__set, int __signo) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int sigismember (__const sigset_t *__set, int __signo)
> # 252 "/usr/include/signal.h" 3 4
> # 1 "/usr/include/bits/sigaction.h" 1 3 4
> # 25 "/usr/include/bits/sigaction.h" 3 4
> struct sigaction
> union
> __sighandler_t sa_handler;
> void (*sa_sigaction) (int, siginfo_t *, void *);
> __sigaction_handler;
> __sigset_t sa_mask;
> int sa_flags;
> void (*sa_restorer) (void);
> # 253 "/usr/include/signal.h" 2 3 4
> extern int sigprocmask (int __how, __const sigset_t *__restrict __set,
> sigset_t *__restrict __oset) __attribute__ ((__nothrow__));
> extern int sigsuspend (__const sigset_t *__set) __attribute__ ((__nonnull__ (1)));
> extern int sigaction (int __sig, __const struct sigaction *__restrict __act,
> struct sigaction *__restrict __oact) __attribute__ ((__nothrow__));
> extern int sigpending (sigset_t *__set) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int sigwait (__const sigset_t *__restrict __set, int *__restrict __sig)
> __attribute__ ((__nonnull__ (1, 2)));
> extern int sigwaitinfo (__const sigset_t *__restrict __set,
> siginfo_t *__restrict __info) __attribute__ ((__nonnull__ (1)));
> extern int sigtimedwait (__const sigset_t *__restrict __set,
> siginfo_t *__restrict __info,
> __const struct timespec *__restrict __timeout)
> extern int sigqueue (__pid_t __pid, int __sig, __const union sigval __val)
> # 310 "/usr/include/signal.h" 3 4
> extern __const char *__const _sys_siglist[65];
> extern __const char *__const sys_siglist[65];
> struct sigvec
> __sighandler_t sv_handler;
> int sv_mask;
> int sv_flags;
> # 334 "/usr/include/signal.h" 3 4
> extern int sigvec (int __sig, __const struct sigvec *__vec,
> struct sigvec *__ovec) __attribute__ ((__nothrow__));
> # 1 "/usr/include/bits/sigcontext.h" 1 3 4
> # 26 "/usr/include/bits/sigcontext.h" 3 4
> # 27 "/usr/include/bits/sigcontext.h" 2 3 4
> struct _fpreg
> unsigned short significand[4];
> unsigned short exponent;
> struct _fpxreg
> unsigned short padding[3];
> struct _xmmreg
> __uint32_t element[4];
> # 109 "/usr/include/bits/sigcontext.h" 3 4
> struct _fpstate
> __uint16_t cwd;
> __uint16_t swd;
> __uint16_t ftw;
> __uint16_t fop;
> __uint64_t rip;
> __uint64_t rdp;
> __uint32_t mxcsr;
> __uint32_t mxcr_mask;
> struct _fpxreg _st[8];
> struct _xmmreg _xmm[16];
> __uint32_t padding[24];
> struct sigcontext
> unsigned long r8;
> unsigned long r9;
> unsigned long r10;
> unsigned long r11;
> unsigned long r12;
> unsigned long r13;
> unsigned long r14;
> unsigned long r15;
> unsigned long rdi;
> unsigned long rsi;
> unsigned long rbp;
> unsigned long rbx;
> unsigned long rdx;
> unsigned long rax;
> unsigned long rcx;
> unsigned long rsp;
> unsigned long rip;
> unsigned long eflags;
> unsigned short cs;
> unsigned short gs;
> unsigned short fs;
> unsigned short __pad0;
> unsigned long err;
> unsigned long trapno;
> unsigned long oldmask;
> unsigned long cr2;
> struct _fpstate * fpstate;
> unsigned long __reserved1 [8];
> # 340 "/usr/include/signal.h" 2 3 4
> extern int sigreturn (struct sigcontext *__scp) __attribute__ ((__nothrow__));
> # 350 "/usr/include/signal.h" 2 3 4
> extern int siginterrupt (int __sig, int __interrupt) __attribute__ ((__nothrow__));
> # 1 "/usr/include/bits/sigstack.h" 1 3 4
> # 26 "/usr/include/bits/sigstack.h" 3 4
> struct sigstack
> void *ss_sp;
> int ss_onstack;
> enum
> SS_ONSTACK = 1,
> SS_DISABLE
> # 50 "/usr/include/bits/sigstack.h" 3 4
> typedef struct sigaltstack
> void *ss_sp;
> int ss_flags;
> size_t ss_size;
> } stack_t;
> # 357 "/usr/include/signal.h" 2 3 4
> # 365 "/usr/include/signal.h" 3 4
> extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
> extern int sigaltstack (__const struct sigaltstack *__restrict __ss,
> struct sigaltstack *__restrict __oss) __attribute__ ((__nothrow__));
> # 394 "/usr/include/signal.h" 3 4
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 395 "/usr/include/signal.h" 2 3 4
> # 1 "/usr/include/bits/sigthread.h" 1 3 4
> # 31 "/usr/include/bits/sigthread.h" 3 4
> extern int pthread_sigmask (int __how,
> __const __sigset_t *__restrict __newmask,
> __sigset_t *__restrict __oldmask)__attribute__ ((__nothrow__));
> extern int pthread_kill (pthread_t __threadid, int __signo) __attribute__ ((__nothrow__));
> # 396 "/usr/include/signal.h" 2 3 4
> extern int __libc_current_sigrtmin (void) __attribute__ ((__nothrow__));
> extern int __libc_current_sigrtmax (void) __attribute__ ((__nothrow__));
> # 32 "/usr/include/sys/wait.h" 2 3 4
> # 1 "/usr/include/sys/resource.h" 1 3 4
> # 25 "/usr/include/sys/resource.h" 3 4
> # 1 "/usr/include/bits/resource.h" 1 3 4
> # 33 "/usr/include/bits/resource.h" 3 4
> enum __rlimit_resource
> RLIMIT_CPU = 0,
> RLIMIT_FSIZE = 1,
> RLIMIT_DATA = 2,
> RLIMIT_STACK = 3,
> RLIMIT_CORE = 4,
> __RLIMIT_RSS = 5,
> RLIMIT_NOFILE = 7,
> __RLIMIT_OFILE = RLIMIT_NOFILE,
> RLIMIT_AS = 9,
> __RLIMIT_NPROC = 6,
> __RLIMIT_MEMLOCK = 8,
> __RLIMIT_LOCKS = 10,
> __RLIMIT_SIGPENDING = 11,
> __RLIMIT_MSGQUEUE = 12,
> __RLIMIT_NICE = 13,
> __RLIMIT_RTPRIO = 14,
> __RLIMIT_NLIMITS = 15,
> __RLIM_NLIMITS = __RLIMIT_NLIMITS
> # 127 "/usr/include/bits/resource.h" 3 4
> typedef __rlim_t rlim_t;
> struct rlimit
> rlim_t rlim_cur;
> rlim_t rlim_max;
> # 154 "/usr/include/bits/resource.h" 3 4
> enum __rusage_who
> RUSAGE_SELF = 0,
> RUSAGE_CHILDREN = -1
> # 172 "/usr/include/bits/resource.h" 3 4
> struct timeval
> __time_t tv_sec;
> # 176 "/usr/include/bits/resource.h" 2 3 4
> struct rusage
> struct timeval ru_utime;
> struct timeval ru_stime;
> long int ru_maxrss;
> long int ru_ixrss;
> long int ru_idrss;
> long int ru_isrss;
> long int ru_minflt;
> long int ru_majflt;
> long int ru_nswap;
> long int ru_inblock;
> long int ru_oublock;
> long int ru_msgsnd;
> long int ru_msgrcv;
> long int ru_nsignals;
> long int ru_nvcsw;
> long int ru_nivcsw;
> enum __priority_which
> PRIO_PROCESS = 0,
> PRIO_PGRP = 1,
> PRIO_USER = 2
> # 26 "/usr/include/sys/resource.h" 2 3 4
> # 43 "/usr/include/sys/resource.h" 3 4
> typedef int __rlimit_resource_t;
> typedef int __rusage_who_t;
> typedef int __priority_which_t;
> extern int getrlimit (__rlimit_resource_t __resource,
> struct rlimit *__rlimits) __attribute__ ((__nothrow__));
> # 70 "/usr/include/sys/resource.h" 3 4
> extern int setrlimit (__rlimit_resource_t __resource,
> __const struct rlimit *__rlimits) __attribute__ ((__nothrow__));
> # 88 "/usr/include/sys/resource.h" 3 4
> extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__));
> extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__));
> extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
> # 33 "/usr/include/sys/wait.h" 2 3 4
> # 1 "/usr/include/bits/waitflags.h" 1 3 4
> # 39 "/usr/include/sys/wait.h" 2 3 4
> # 63 "/usr/include/sys/wait.h" 3 4
> typedef union
> union wait *__uptr;
> int *__iptr;
> } __WAIT_STATUS __attribute__ ((__transparent_union__));
> # 80 "/usr/include/sys/wait.h" 3 4
> # 1 "/usr/include/bits/waitstatus.h" 1 3 4
> # 65 "/usr/include/bits/waitstatus.h" 3 4
> # 66 "/usr/include/bits/waitstatus.h" 2 3 4
> union wait
> int w_status;
> struct
> unsigned int __w_termsig:7;
> unsigned int __w_coredump:1;
> unsigned int __w_retcode:8;
> unsigned int:16;
> } __wait_terminated;
> struct
> unsigned int __w_stopval:8;
> unsigned int __w_stopsig:8;
> unsigned int:16;
> } __wait_stopped;
> # 81 "/usr/include/sys/wait.h" 2 3 4
> # 102 "/usr/include/sys/wait.h" 3 4
> typedef enum
> P_ALL,
> P_PID,
> P_PGID
> } idtype_t;
> # 116 "/usr/include/sys/wait.h" 3 4
> extern __pid_t wait (__WAIT_STATUS __stat_loc);
> # 139 "/usr/include/sys/wait.h" 3 4
> extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
> # 144 "/usr/include/sys/wait.h" 2 3 4
> # 155 "/usr/include/sys/wait.h" 3 4
> extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
> int __options);
> struct rusage;
> extern __pid_t wait3 (__WAIT_STATUS __stat_loc, int __options,
> struct rusage * __usage) __attribute__ ((__nothrow__));
> extern __pid_t wait4 (__pid_t __pid, __WAIT_STATUS __stat_loc, int __options,
> Defined "HAVE_SYS_WAIT_H" to "1"
> Checking for header: stdlib.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/stdlib.h" 1 3 4
> # 25 "/usr/include/stdlib.h" 3 4
> # 26 "/usr/include/stdlib.h" 2 3 4
> # 34 "/usr/include/stdlib.h" 2 3 4
> # 96 "/usr/include/stdlib.h" 3 4
> typedef struct
> int quot;
> int rem;
> } div_t;
> typedef struct
> long int quot;
> long int rem;
> } ldiv_t;
> __extension__ typedef struct
> long long int quot;
> long long int rem;
> } lldiv_t;
> # 140 "/usr/include/stdlib.h" 3 4
> extern size_t __ctype_get_mb_cur_max (void) __attribute__ ((__nothrow__)) ;
> extern double atof (__const char *__nptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1))) ;
> extern int atoi (__const char *__nptr)
> extern long int atol (__const char *__nptr)
> __extension__ extern long long int atoll (__const char *__nptr)
> extern double strtod (__const char *__restrict __nptr,
> char **__restrict __endptr)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern float strtof (__const char *__restrict __nptr,
> char **__restrict __endptr) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern long double strtold (__const char *__restrict __nptr,
> extern long int strtol (__const char *__restrict __nptr,
> extern unsigned long int strtoul (__const char *__restrict __nptr,
> __extension__
> extern long long int strtoq (__const char *__restrict __nptr,
> __extension__
> extern unsigned long long int strtouq (__const char *__restrict __nptr,
> __extension__
> extern long long int strtoll (__const char *__restrict __nptr,
> __extension__
> extern unsigned long long int strtoull (__const char *__restrict __nptr,
> # 311 "/usr/include/stdlib.h" 3 4
> extern char *l64a (long int __n) __attribute__ ((__nothrow__)) ;
> extern long int a64l (__const char *__s)
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> typedef struct
> } fd_set;
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 321 "/usr/include/stdlib.h" 2 3 4
> extern long int random (void) __attribute__ ((__nothrow__));
> extern void srandom (unsigned int __seed) __attribute__ ((__nothrow__));
> extern char *initstate (unsigned int __seed, char *__statebuf,
> size_t __statelen) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> extern char *setstate (char *__statebuf) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> struct random_data
> int32_t *fptr;
> int32_t *rptr;
> int32_t *state;
> int rand_type;
> int rand_deg;
> int rand_sep;
> int32_t *end_ptr;
> extern int random_r (struct random_data *__restrict __buf,
> int32_t *__restrict __result) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int srandom_r (unsigned int __seed, struct random_data *__buf)
> extern int initstate_r (unsigned int __seed, char *__restrict __statebuf,
> size_t __statelen,
> struct random_data *__restrict __buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 4)));
> extern int setstate_r (char *__restrict __statebuf,
> extern int rand (void) __attribute__ ((__nothrow__));
> extern void srand (unsigned int __seed) __attribute__ ((__nothrow__));
> extern int rand_r (unsigned int *__seed) __attribute__ ((__nothrow__));
> extern double drand48 (void) __attribute__ ((__nothrow__));
> extern double erand48 (unsigned short int __xsubi[3]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern long int lrand48 (void) __attribute__ ((__nothrow__));
> extern long int nrand48 (unsigned short int __xsubi[3])
> extern long int mrand48 (void) __attribute__ ((__nothrow__));
> extern long int jrand48 (unsigned short int __xsubi[3])
> extern void srand48 (long int __seedval) __attribute__ ((__nothrow__));
> extern unsigned short int *seed48 (unsigned short int __seed16v[3])
> extern void lcong48 (unsigned short int __param[7]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> struct drand48_data
> unsigned short int __x[3];
> unsigned short int __old_x[3];
> unsigned short int __c;
> unsigned short int __init;
> unsigned long long int __a;
> extern int drand48_r (struct drand48_data *__restrict __buffer,
> double *__restrict __result) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int erand48_r (unsigned short int __xsubi[3],
> extern int lrand48_r (struct drand48_data *__restrict __buffer,
> long int *__restrict __result)
> extern int nrand48_r (unsigned short int __xsubi[3],
> extern int mrand48_r (struct drand48_data *__restrict __buffer,
> extern int jrand48_r (unsigned short int __xsubi[3],
> extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
> extern int seed48_r (unsigned short int __seed16v[3],
> struct drand48_data *__buffer) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int lcong48_r (unsigned short int __param[7],
> __attribute__ ((__nothrow__)) __attribute__ ((__warn_unused_result__));
> # 1 "/usr/include/alloca.h" 1 3 4
> # 25 "/usr/include/alloca.h" 3 4
> # 26 "/usr/include/alloca.h" 2 3 4
> extern void *alloca (size_t __size) __attribute__ ((__nothrow__));
> # 498 "/usr/include/stdlib.h" 2 3 4
> extern void *valloc (size_t __size) __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) ;
> extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
> extern void abort (void) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> extern int atexit (void (*__func) (void)) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> # 530 "/usr/include/stdlib.h" 3 4
> extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
> extern void exit (int __status) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> # 553 "/usr/include/stdlib.h" 3 4
> extern void _Exit (int __status) __attribute__ ((__nothrow__)) __attribute__ ((__noreturn__));
> extern char *getenv (__const char *__name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern char *__secure_getenv (__const char *__name)
> extern int putenv (char *__string) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int setenv (__const char *__name, __const char *__value, int __replace)
> extern int unsetenv (__const char *__name) __attribute__ ((__nothrow__));
> extern int clearenv (void) __attribute__ ((__nothrow__));
> # 604 "/usr/include/stdlib.h" 3 4
> extern char *mktemp (char *__template) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 615 "/usr/include/stdlib.h" 3 4
> extern int mkstemp (char *__template) __attribute__ ((__nonnull__ (1))) ;
> # 637 "/usr/include/stdlib.h" 3 4
> extern int mkstemps (char *__template, int __suffixlen) __attribute__ ((__nonnull__ (1))) ;
> # 658 "/usr/include/stdlib.h" 3 4
> extern char *mkdtemp (char *__template) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 707 "/usr/include/stdlib.h" 3 4
> extern int system (__const char *__command) ;
> # 729 "/usr/include/stdlib.h" 3 4
> extern char *realpath (__const char *__restrict __name,
> char *__restrict __resolved) __attribute__ ((__nothrow__)) ;
> typedef int (*__compar_fn_t) (__const void *, __const void *);
> # 747 "/usr/include/stdlib.h" 3 4
> extern void *bsearch (__const void *__key, __const void *__base,
> size_t __nmemb, size_t __size, __compar_fn_t __compar)
> __attribute__ ((__nonnull__ (1, 2, 5))) ;
> extern void qsort (void *__base, size_t __nmemb, size_t __size,
> __compar_fn_t __compar) __attribute__ ((__nonnull__ (1, 4)));
> # 766 "/usr/include/stdlib.h" 3 4
> extern int abs (int __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)) ;
> extern long int labs (long int __x) __attribute__ ((__nothrow__)) __attribute__ ((__const__)) ;
> __extension__ extern long long int llabs (long long int __x)
> extern div_t div (int __numer, int __denom)
> extern ldiv_t ldiv (long int __numer, long int __denom)
> __extension__ extern lldiv_t lldiv (long long int __numer,
> long long int __denom)
> # 802 "/usr/include/stdlib.h" 3 4
> extern char *ecvt (double __value, int __ndigit, int *__restrict __decpt,
> int *__restrict __sign) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4))) ;
> extern char *fcvt (double __value, int __ndigit, int *__restrict __decpt,
> extern char *gcvt (double __value, int __ndigit, char *__buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3))) ;
> extern char *qecvt (long double __value, int __ndigit,
> int *__restrict __decpt, int *__restrict __sign)
> extern char *qfcvt (long double __value, int __ndigit,
> extern char *qgcvt (long double __value, int __ndigit, char *__buf)
> extern int ecvt_r (double __value, int __ndigit, int *__restrict __decpt,
> int *__restrict __sign, char *__restrict __buf,
> size_t __len) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3, 4, 5)));
> extern int fcvt_r (double __value, int __ndigit, int *__restrict __decpt,
> extern int qecvt_r (long double __value, int __ndigit,
> int *__restrict __decpt, int *__restrict __sign,
> char *__restrict __buf, size_t __len)
> extern int qfcvt_r (long double __value, int __ndigit,
> extern int mblen (__const char *__s, size_t __n) __attribute__ ((__nothrow__)) ;
> extern int mbtowc (wchar_t *__restrict __pwc,
> __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__)) ;
> extern int wctomb (char *__s, wchar_t __wchar) __attribute__ ((__nothrow__)) ;
> extern size_t mbstowcs (wchar_t *__restrict __pwcs,
> __const char *__restrict __s, size_t __n) __attribute__ ((__nothrow__));
> extern size_t wcstombs (char *__restrict __s,
> __const wchar_t *__restrict __pwcs, size_t __n)
> extern int rpmatch (__const char *__response) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> # 907 "/usr/include/stdlib.h" 3 4
> extern int posix_openpt (int __oflag) ;
> # 942 "/usr/include/stdlib.h" 3 4
> extern int getloadavg (double __loadavg[], int __nelem)
> # 958 "/usr/include/stdlib.h" 3 4
> Defined "HAVE_STDLIB_H" to "1"
> TEST check from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:77)
> TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
> Checks for "header", and defines HAVE_"header" if found
> Checking for header: pthread.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/pthread.h" 1 3 4
> # 23 "/usr/include/pthread.h" 3 4
> # 24 "/usr/include/pthread.h" 2 3 4
> # 1 "/usr/include/endian.h" 1 3 4
> # 37 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/endian.h" 1 3 4
> # 38 "/usr/include/endian.h" 2 3 4
> # 61 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/byteswap.h" 1 3 4
> # 28 "/usr/include/bits/byteswap.h" 3 4
> # 29 "/usr/include/bits/byteswap.h" 2 3 4
> # 62 "/usr/include/endian.h" 2 3 4
> # 25 "/usr/include/pthread.h" 2 3 4
> # 26 "/usr/include/sched.h" 3 4
> # 1 "/usr/include/bits/types.h" 1 3 4
> # 28 "/usr/include/bits/types.h" 3 4
> # 29 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned char __u_char;
> typedef unsigned short int __u_short;
> typedef unsigned int __u_int;
> typedef unsigned long int __u_long;
> typedef signed char __int8_t;
> typedef unsigned char __uint8_t;
> typedef signed short int __int16_t;
> typedef unsigned short int __uint16_t;
> typedef signed int __int32_t;
> typedef unsigned int __uint32_t;
> typedef signed long int __int64_t;
> typedef unsigned long int __uint64_t;
> typedef long int __quad_t;
> typedef unsigned long int __u_quad_t;
> # 131 "/usr/include/bits/types.h" 3 4
> # 1 "/usr/include/bits/typesizes.h" 1 3 4
> # 132 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned long int __dev_t;
> typedef unsigned int __uid_t;
> typedef unsigned int __gid_t;
> typedef unsigned long int __ino_t;
> typedef unsigned long int __ino64_t;
> typedef unsigned int __mode_t;
> typedef unsigned long int __nlink_t;
> typedef long int __off_t;
> typedef long int __off64_t;
> typedef int __pid_t;
> typedef struct { int __val[2]; } __fsid_t;
> typedef long int __clock_t;
> typedef unsigned long int __rlim_t;
> typedef unsigned long int __rlim64_t;
> typedef unsigned int __id_t;
> typedef long int __time_t;
> typedef unsigned int __useconds_t;
> typedef long int __suseconds_t;
> typedef int __daddr_t;
> typedef long int __swblk_t;
> typedef int __key_t;
> typedef int __clockid_t;
> typedef void * __timer_t;
> typedef long int __blksize_t;
> typedef long int __blkcnt_t;
> typedef long int __blkcnt64_t;
> typedef unsigned long int __fsblkcnt_t;
> typedef unsigned long int __fsblkcnt64_t;
> typedef unsigned long int __fsfilcnt_t;
> typedef unsigned long int __fsfilcnt64_t;
> typedef long int __ssize_t;
> typedef __off64_t __loff_t;
> typedef __quad_t *__qaddr_t;
> typedef char *__caddr_t;
> typedef long int __intptr_t;
> typedef unsigned int __socklen_t;
> # 1 "/usr/include/time.h" 1 3 4
> # 120 "/usr/include/time.h" 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct sched_param
> typedef struct
> } cpu_set_t;
> # 26 "/usr/include/pthread.h" 2 3 4
> # 30 "/usr/include/time.h" 3 4
> # 1 "/usr/include/bits/time.h" 1 3 4
> # 58 "/usr/include/time.h" 3 4
> # 74 "/usr/include/time.h" 3 4
> typedef __time_t time_t;
> # 92 "/usr/include/time.h" 3 4
> typedef __clockid_t clockid_t;
> # 104 "/usr/include/time.h" 3 4
> typedef __timer_t timer_t;
> # 131 "/usr/include/time.h" 3 4
> struct tm
> int tm_sec;
> int tm_min;
> int tm_hour;
> int tm_mday;
> int tm_mon;
> int tm_year;
> int tm_wday;
> int tm_yday;
> int tm_isdst;
> long int tm_gmtoff;
> struct itimerspec
> struct sigevent;
> typedef __pid_t pid_t;
> } *__locale_t;
> # 27 "/usr/include/pthread.h" 2 3 4
> # 1 "/usr/include/bits/sigset.h" 1 3 4
> # 24 "/usr/include/bits/sigset.h" 3 4
> typedef int __sig_atomic_t;
> typedef struct
> unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
> } __sigset_t;
> # 50 "/usr/include/signal.h" 3 4
> typedef __sigset_t sigset_t;
> # 408 "/usr/include/signal.h" 3 4
> # 30 "/usr/include/pthread.h" 2 3 4
> # 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
> # 23 "/usr/include/bits/pthreadtypes.h" 3 4
> # 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
> # 50 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef unsigned long int pthread_t;
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> typedef struct __pthread_internal_list
> struct __pthread_internal_list *__prev;
> struct __pthread_internal_list *__next;
> } __pthread_list_t;
> # 76 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef union
> struct __pthread_mutex_s
> int __lock;
> unsigned int __count;
> int __owner;
> unsigned int __nusers;
> int __kind;
> int __spins;
> __pthread_list_t __list;
> # 101 "/usr/include/bits/pthreadtypes.h" 3 4
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_mutexattr_t;
> typedef union
> struct
> int __lock;
> unsigned int __futex;
> __extension__ unsigned long long int __total_seq;
> __extension__ unsigned long long int __wakeup_seq;
> __extension__ unsigned long long int __woken_seq;
> void *__mutex;
> unsigned int __nwaiters;
> unsigned int __broadcast_seq;
> } __data;
> char __size[48];
> __extension__ long long int __align;
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_condattr_t;
> typedef unsigned int pthread_key_t;
> typedef int pthread_once_t;
> typedef union
> struct
> int __lock;
> unsigned int __nr_readers;
> unsigned int __readers_wakeup;
> unsigned int __writer_wakeup;
> unsigned int __nr_readers_queued;
> unsigned int __nr_writers_queued;
> int __writer;
> int __shared;
> unsigned long int __pad1;
> unsigned long int __pad2;
> unsigned int __flags;
> } __data;
> # 187 "/usr/include/bits/pthreadtypes.h" 3 4
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> } pthread_rwlockattr_t;
> typedef volatile int pthread_spinlock_t;
> typedef union
> char __size[32];
> long int __align;
> } pthread_barrier_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_barrierattr_t;
> # 31 "/usr/include/pthread.h" 2 3 4
> # 1 "/usr/include/bits/setjmp.h" 1 3 4
> # 27 "/usr/include/bits/setjmp.h" 3 4
> # 28 "/usr/include/bits/setjmp.h" 2 3 4
> typedef long int __jmp_buf[8];
> # 32 "/usr/include/pthread.h" 2 3 4
> # 33 "/usr/include/pthread.h" 2 3 4
> enum
> PTHREAD_CREATE_JOINABLE,
> PTHREAD_CREATE_DETACHED
> enum
> PTHREAD_MUTEX_TIMED_NP,
> PTHREAD_MUTEX_RECURSIVE_NP,
> PTHREAD_MUTEX_ERRORCHECK_NP,
> PTHREAD_MUTEX_ADAPTIVE_NP
> # 63 "/usr/include/pthread.h" 3 4
> enum
> PTHREAD_MUTEX_STALLED,
> PTHREAD_MUTEX_STALLED_NP = PTHREAD_MUTEX_STALLED,
> PTHREAD_MUTEX_ROBUST,
> PTHREAD_MUTEX_ROBUST_NP = PTHREAD_MUTEX_ROBUST
> # 117 "/usr/include/pthread.h" 3 4
> enum
> PTHREAD_RWLOCK_PREFER_READER_NP,
> PTHREAD_RWLOCK_PREFER_WRITER_NP,
> PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
> PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
> # 149 "/usr/include/pthread.h" 3 4
> enum
> PTHREAD_INHERIT_SCHED,
> PTHREAD_EXPLICIT_SCHED
> enum
> PTHREAD_SCOPE_SYSTEM,
> PTHREAD_SCOPE_PROCESS
> enum
> PTHREAD_PROCESS_PRIVATE,
> PTHREAD_PROCESS_SHARED
> # 184 "/usr/include/pthread.h" 3 4
> struct _pthread_cleanup_buffer
> void (*__routine) (void *);
> void *__arg;
> int __canceltype;
> struct _pthread_cleanup_buffer *__prev;
> enum
> PTHREAD_CANCEL_ENABLE,
> PTHREAD_CANCEL_DISABLE
> enum
> PTHREAD_CANCEL_DEFERRED,
> PTHREAD_CANCEL_ASYNCHRONOUS
> # 222 "/usr/include/pthread.h" 3 4
> extern int pthread_create (pthread_t *__restrict __newthread,
> __const pthread_attr_t *__restrict __attr,
> void *(*__start_routine) (void *),
> void *__restrict __arg) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3)));
> extern void pthread_exit (void *__retval) __attribute__ ((__noreturn__));
> extern int pthread_join (pthread_t __th, void **__thread_return);
> # 265 "/usr/include/pthread.h" 3 4
> extern int pthread_detach (pthread_t __th) __attribute__ ((__nothrow__));
> extern pthread_t pthread_self (void) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int pthread_equal (pthread_t __thread1, pthread_t __thread2) __attribute__ ((__nothrow__));
> extern int pthread_attr_init (pthread_attr_t *__attr) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int pthread_attr_destroy (pthread_attr_t *__attr)
> extern int pthread_attr_getdetachstate (__const pthread_attr_t *__attr,
> int *__detachstate)
> extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
> int __detachstate)
> extern int pthread_attr_getguardsize (__const pthread_attr_t *__attr,
> size_t *__guardsize)
> extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
> size_t __guardsize)
> extern int pthread_attr_getschedparam (__const pthread_attr_t *__restrict
> __attr,
> struct sched_param *__restrict __param)
> extern int pthread_attr_setschedparam (pthread_attr_t *__restrict __attr,
> __const struct sched_param *__restrict
> __param) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int pthread_attr_getschedpolicy (__const pthread_attr_t *__restrict
> __attr, int *__restrict __policy)
> extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
> extern int pthread_attr_getinheritsched (__const pthread_attr_t *__restrict
> __attr, int *__restrict __inherit)
> extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
> int __inherit)
> extern int pthread_attr_getscope (__const pthread_attr_t *__restrict __attr,
> int *__restrict __scope)
> extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
> extern int pthread_attr_getstackaddr (__const pthread_attr_t *__restrict
> __attr, void **__restrict __stackaddr)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2))) __attribute__ ((__deprecated__));
> extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
> void *__stackaddr)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__));
> extern int pthread_attr_getstacksize (__const pthread_attr_t *__restrict
> __attr, size_t *__restrict __stacksize)
> extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
> size_t __stacksize)
> extern int pthread_attr_getstack (__const pthread_attr_t *__restrict __attr,
> void **__restrict __stackaddr,
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2, 3)));
> extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
> size_t __stacksize) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> # 415 "/usr/include/pthread.h" 3 4
> extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (3)));
> extern int pthread_getschedparam (pthread_t __target_thread,
> int *__restrict __policy,
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 3)));
> extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
> # 468 "/usr/include/pthread.h" 3 4
> extern int pthread_once (pthread_once_t *__once_control,
> void (*__init_routine) (void)) __attribute__ ((__nonnull__ (1, 2)));
> # 480 "/usr/include/pthread.h" 3 4
> extern int pthread_setcancelstate (int __state, int *__oldstate);
> extern int pthread_setcanceltype (int __type, int *__oldtype);
> extern int pthread_cancel (pthread_t __th);
> extern void pthread_testcancel (void);
> typedef struct
> struct
> __jmp_buf __cancel_jmp_buf;
> int __mask_was_saved;
> } __cancel_jmp_buf[1];
> void *__pad[4];
> } __pthread_unwind_buf_t __attribute__ ((__aligned__));
> # 514 "/usr/include/pthread.h" 3 4
> struct __pthread_cleanup_frame
> void (*__cancel_routine) (void *);
> void *__cancel_arg;
> int __do_it;
> int __cancel_type;
> # 654 "/usr/include/pthread.h" 3 4
> extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
> # 666 "/usr/include/pthread.h" 3 4
> extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
> # 707 "/usr/include/pthread.h" 3 4
> extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
> __attribute__ ((__weak__))
> struct __jmp_buf_tag;
> extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) __attribute__ ((__nothrow__));
> extern int pthread_mutex_init (pthread_mutex_t *__mutex,
> __const pthread_mutexattr_t *__mutexattr)
> extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
> extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
> extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
> extern int pthread_mutex_timedlock (pthread_mutex_t *__restrict __mutex,
> __abstime) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
> # 769 "/usr/include/pthread.h" 3 4
> extern int pthread_mutex_consistent_np (pthread_mutex_t *__mutex)
> # 782 "/usr/include/pthread.h" 3 4
> extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
> extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
> extern int pthread_mutexattr_getpshared (__const pthread_mutexattr_t *
> __restrict __attr,
> int *__restrict __pshared)
> extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
> int __pshared)
> # 838 "/usr/include/pthread.h" 3 4
> extern int pthread_mutexattr_getrobust (__const pthread_mutexattr_t *__attr,
> int *__robustness)
> extern int pthread_mutexattr_setrobust (pthread_mutexattr_t *__attr,
> int __robustness)
> # 864 "/usr/include/pthread.h" 3 4
> extern int pthread_rwlock_init (pthread_rwlock_t *__restrict __rwlock,
> __const pthread_rwlockattr_t *__restrict
> extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
> extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
> extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
> extern int pthread_rwlock_timedrdlock (pthread_rwlock_t *__restrict __rwlock,
> extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
> extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
> extern int pthread_rwlock_timedwrlock (pthread_rwlock_t *__restrict __rwlock,
> extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
> extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
> extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
> extern int pthread_rwlockattr_getpshared (__const pthread_rwlockattr_t *
> __restrict __attr,
> extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
> int __pshared)
> extern int pthread_rwlockattr_getkind_np (__const pthread_rwlockattr_t *
> __restrict __attr,
> int *__restrict __pref)
> extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
> int __pref) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int pthread_cond_init (pthread_cond_t *__restrict __cond,
> __const pthread_condattr_t *__restrict
> __cond_attr) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int pthread_cond_destroy (pthread_cond_t *__cond)
> extern int pthread_cond_signal (pthread_cond_t *__cond)
> extern int pthread_cond_broadcast (pthread_cond_t *__cond)
> extern int pthread_cond_wait (pthread_cond_t *__restrict __cond,
> pthread_mutex_t *__restrict __mutex)
> # 976 "/usr/include/pthread.h" 3 4
> extern int pthread_cond_timedwait (pthread_cond_t *__restrict __cond,
> __abstime) __attribute__ ((__nonnull__ (1, 2, 3)));
> extern int pthread_condattr_init (pthread_condattr_t *__attr)
> extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
> extern int pthread_condattr_getpshared (__const pthread_condattr_t *
> __restrict __attr,
> extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
> int __pshared) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int pthread_condattr_getclock (__const pthread_condattr_t *
> __restrict __attr,
> __clockid_t *__restrict __clock_id)
> extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
> __clockid_t __clock_id)
> # 1020 "/usr/include/pthread.h" 3 4
> extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
> extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
> extern int pthread_spin_lock (pthread_spinlock_t *__lock)
> extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
> extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
> extern int pthread_barrier_init (pthread_barrier_t *__restrict __barrier,
> __const pthread_barrierattr_t *__restrict
> __attr, unsigned int __count)
> extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
> extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
> extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
> extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
> extern int pthread_barrierattr_getpshared (__const pthread_barrierattr_t *
> __restrict __attr,
> extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
> int __pshared)
> # 1087 "/usr/include/pthread.h" 3 4
> extern int pthread_key_create (pthread_key_t *__key,
> void (*__destr_function) (void *))
> extern int pthread_key_delete (pthread_key_t __key) __attribute__ ((__nothrow__));
> extern void *pthread_getspecific (pthread_key_t __key) __attribute__ ((__nothrow__));
> extern int pthread_setspecific (pthread_key_t __key,
> __const void *__pointer) __attribute__ ((__nothrow__)) ;
> extern int pthread_getcpuclockid (pthread_t __thread_id,
> __clockid_t *__clock_id)
> # 1121 "/usr/include/pthread.h" 3 4
> extern int pthread_atfork (void (*__prepare) (void),
> void (*__parent) (void),
> void (*__child) (void)) __attribute__ ((__nothrow__));
> # 1135 "/usr/include/pthread.h" 3 4
> Defined "HAVE_PTHREAD_H" to "1"
> Checking for header: setjmp.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/setjmp.h" 1 3 4
> # 26 "/usr/include/setjmp.h" 3 4
> # 27 "/usr/include/setjmp.h" 2 3 4
> # 32 "/usr/include/bits/setjmp.h" 3 4
> # 31 "/usr/include/setjmp.h" 2 3 4
> typedef struct
> } __sigset_t;
> # 32 "/usr/include/setjmp.h" 2 3 4
> __jmp_buf __jmpbuf;
> __sigset_t __saved_mask;
> typedef struct __jmp_buf_tag jmp_buf[1];
> extern int setjmp (jmp_buf __env) __attribute__ ((__nothrow__));
> extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) __attribute__ ((__nothrow__));
> extern int _setjmp (struct __jmp_buf_tag __env[1]) __attribute__ ((__nothrow__));
> # 78 "/usr/include/setjmp.h" 3 4
> extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
> extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
> typedef struct __jmp_buf_tag sigjmp_buf[1];
> # 110 "/usr/include/setjmp.h" 3 4
> extern void siglongjmp (sigjmp_buf __env, int __val)
> # 120 "/usr/include/setjmp.h" 3 4
> Defined "HAVE_SETJMP_H" to "1"
> Checking for header: sys/utsname.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/utsname.h" 1 3 4
> # 26 "/usr/include/sys/utsname.h" 3 4
> # 27 "/usr/include/sys/utsname.h" 2 3 4
> # 1 "/usr/include/bits/utsname.h" 1 3 4
> # 31 "/usr/include/sys/utsname.h" 2 3 4
> # 49 "/usr/include/sys/utsname.h" 3 4
> struct utsname
> char sysname[65];
> char nodename[65];
> char release[65];
> char version[65];
> char machine[65];
> char __domainname[65];
> # 82 "/usr/include/sys/utsname.h" 3 4
> extern int uname (struct utsname *__name) __attribute__ ((__nothrow__));
> Defined "HAVE_SYS_UTSNAME_H" to "1"
> Checking for header: machine/endian.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
> Source:
> #include <machine/endian.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: machine/endian.h: No such file or directorycompilation terminated.:
> Checking for header: limits.h
> stdout:
> # 1 "<built-in>"
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/limits.h" 1 3 4
> # 34 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/limits.h" 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/syslimits.h" 1 3 4
> # 168 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/limits.h" 3 4
> # 1 "/usr/include/limits.h" 1 3 4
> # 27 "/usr/include/limits.h" 3 4
> # 28 "/usr/include/limits.h" 2 3 4
> # 145 "/usr/include/limits.h" 3 4
> # 1 "/usr/include/bits/posix1_lim.h" 1 3 4
> # 157 "/usr/include/bits/posix1_lim.h" 3 4
> # 1 "/usr/include/bits/local_lim.h" 1 3 4
> # 39 "/usr/include/bits/local_lim.h" 3 4
> # 1 "/usr/include/linux/limits.h" 1 3 4
> # 40 "/usr/include/bits/local_lim.h" 2 3 4
> # 158 "/usr/include/bits/posix1_lim.h" 2 3 4
> # 146 "/usr/include/limits.h" 2 3 4
> # 1 "/usr/include/bits/posix2_lim.h" 1 3 4
> # 150 "/usr/include/limits.h" 2 3 4
> # 169 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/limits.h" 2 3 4
> # 8 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/syslimits.h" 2 3 4
> # 35 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include-fixed/limits.h" 2 3 4
> Defined "HAVE_LIMITS_H" to "1"
> Checking for header: fcntl.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/fcntl.h" 1 3 4
> # 27 "/usr/include/fcntl.h" 3 4
> # 28 "/usr/include/fcntl.h" 2 3 4
> # 1 "/usr/include/bits/fcntl.h" 1 3 4
> # 24 "/usr/include/bits/fcntl.h" 3 4
> # 1 "/usr/include/sys/types.h" 1 3 4
> # 29 "/usr/include/sys/types.h" 3 4
> # 31 "/usr/include/bits/types.h" 3 4
> # 32 "/usr/include/sys/types.h" 2 3 4
> typedef __u_char u_char;
> typedef __u_short u_short;
> typedef __u_int u_int;
> typedef __u_long u_long;
> typedef __quad_t quad_t;
> typedef __u_quad_t u_quad_t;
> typedef __fsid_t fsid_t;
> typedef __loff_t loff_t;
> typedef __ino_t ino_t;
> # 62 "/usr/include/sys/types.h" 3 4
> typedef __dev_t dev_t;
> typedef __gid_t gid_t;
> typedef __mode_t mode_t;
> typedef __nlink_t nlink_t;
> typedef __uid_t uid_t;
> typedef __off_t off_t;
> # 100 "/usr/include/sys/types.h" 3 4
> typedef __id_t id_t;
> typedef __ssize_t ssize_t;
> typedef __daddr_t daddr_t;
> typedef __caddr_t caddr_t;
> typedef __key_t key_t;
> # 133 "/usr/include/sys/types.h" 3 4
> # 134 "/usr/include/sys/types.h" 2 3 4
> # 147 "/usr/include/sys/types.h" 3 4
> # 148 "/usr/include/sys/types.h" 2 3 4
> typedef unsigned long int ulong;
> typedef unsigned short int ushort;
> typedef unsigned int uint;
> # 195 "/usr/include/sys/types.h" 3 4
> typedef int int8_t __attribute__ ((__mode__ (__QI__)));
> typedef int int16_t __attribute__ ((__mode__ (__HI__)));
> typedef int int32_t __attribute__ ((__mode__ (__SI__)));
> typedef int int64_t __attribute__ ((__mode__ (__DI__)));
> typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
> typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
> typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
> typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
> typedef int register_t __attribute__ ((__mode__ (__word__)));
> # 217 "/usr/include/sys/types.h" 3 4
> # 218 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/select.h" 1 3 4
> # 31 "/usr/include/sys/select.h" 3 4
> # 1 "/usr/include/bits/select.h" 1 3 4
> # 23 "/usr/include/bits/select.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 24 "/usr/include/bits/select.h" 2 3 4
> # 32 "/usr/include/sys/select.h" 2 3 4
> typedef struct
> } __sigset_t;
> # 35 "/usr/include/sys/select.h" 2 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 45 "/usr/include/sys/select.h" 2 3 4
> # 69 "/usr/include/bits/time.h" 3 4
> struct timeval
> __time_t tv_sec;
> __suseconds_t tv_usec;
> # 47 "/usr/include/sys/select.h" 2 3 4
> typedef __suseconds_t suseconds_t;
> typedef long int __fd_mask;
> # 67 "/usr/include/sys/select.h" 3 4
> typedef struct
> __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
> } fd_set;
> typedef __fd_mask fd_mask;
> # 99 "/usr/include/sys/select.h" 3 4
> # 109 "/usr/include/sys/select.h" 3 4
> extern int select (int __nfds, fd_set *__restrict __readfds,
> fd_set *__restrict __writefds,
> fd_set *__restrict __exceptfds,
> struct timeval *__restrict __timeout);
> # 121 "/usr/include/sys/select.h" 3 4
> extern int pselect (int __nfds, fd_set *__restrict __readfds,
> const struct timespec *__restrict __timeout,
> const __sigset_t *__restrict __sigmask);
> # 221 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/sysmacros.h" 1 3 4
> # 30 "/usr/include/sys/sysmacros.h" 3 4
> __extension__
> extern unsigned int gnu_dev_major (unsigned long long int __dev)
> __extension__
> extern unsigned int gnu_dev_minor (unsigned long long int __dev)
> __extension__
> extern unsigned long long int gnu_dev_makedev (unsigned int __major,
> unsigned int __minor)
> # 224 "/usr/include/sys/types.h" 2 3 4
> # 235 "/usr/include/sys/types.h" 3 4
> typedef __blkcnt_t blkcnt_t;
> typedef __fsblkcnt_t fsblkcnt_t;
> typedef __fsfilcnt_t fsfilcnt_t;
> # 270 "/usr/include/sys/types.h" 3 4
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 271 "/usr/include/sys/types.h" 2 3 4
> # 25 "/usr/include/bits/fcntl.h" 2 3 4
> # 26 "/usr/include/bits/fcntl.h" 2 3 4
> # 160 "/usr/include/bits/fcntl.h" 3 4
> struct flock
> short int l_type;
> short int l_whence;
> __off_t l_start;
> __off_t l_len;
> __pid_t l_pid;
> # 244 "/usr/include/bits/fcntl.h" 3 4
> # 289 "/usr/include/bits/fcntl.h" 3 4
> # 35 "/usr/include/fcntl.h" 2 3 4
> # 78 "/usr/include/fcntl.h" 3 4
> extern int fcntl (int __fd, int __cmd, ...);
> # 87 "/usr/include/fcntl.h" 3 4
> extern int open (__const char *__file, int __oflag, ...) __attribute__ ((__nonnull__ (1)));
> # 111 "/usr/include/fcntl.h" 3 4
> extern int openat (int __fd, __const char *__file, int __oflag, ...)
> # 122 "/usr/include/fcntl.h" 3 4
> extern int openat64 (int __fd, __const char *__file, int __oflag, ...)
> # 132 "/usr/include/fcntl.h" 3 4
> extern int creat (__const char *__file, __mode_t __mode) __attribute__ ((__nonnull__ (1)));
> # 161 "/usr/include/fcntl.h" 3 4
> extern int lockf (int __fd, int __cmd, __off_t __len);
> # 178 "/usr/include/fcntl.h" 3 4
> extern int posix_fadvise (int __fd, __off_t __offset, __off_t __len,
> int __advise) __attribute__ ((__nothrow__));
> # 200 "/usr/include/fcntl.h" 3 4
> extern int posix_fallocate (int __fd, __off_t __offset, __off_t __len);
> # 222 "/usr/include/fcntl.h" 3 4
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Defined "HAVE_FCNTL_H" to "1"
> Checking for header: string.h
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 1 "/usr/include/string.h" 1 3 4
> # 26 "/usr/include/string.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 27 "/usr/include/string.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 34 "/usr/include/string.h" 2 3 4
> extern void *memcpy (void *__restrict __dest,
> __const void *__restrict __src, size_t __n)
> extern void *memmove (void *__dest, __const void *__src, size_t __n)
> extern void *memccpy (void *__restrict __dest, __const void *__restrict __src,
> int __c, size_t __n)
> extern void *memset (void *__s, int __c, size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int memcmp (__const void *__s1, __const void *__s2, size_t __n)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1, 2)));
> # 94 "/usr/include/string.h" 3 4
> extern void *memchr (__const void *__s, int __c, size_t __n)
> # 125 "/usr/include/string.h" 3 4
> extern char *strcpy (char *__restrict __dest, __const char *__restrict __src)
> extern char *strncpy (char *__restrict __dest,
> __const char *__restrict __src, size_t __n)
> extern char *strcat (char *__restrict __dest, __const char *__restrict __src)
> extern char *strncat (char *__restrict __dest, __const char *__restrict __src,
> size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2)));
> extern int strcmp (__const char *__s1, __const char *__s2)
> extern int strncmp (__const char *__s1, __const char *__s2, size_t __n)
> extern int strcoll (__const char *__s1, __const char *__s2)
> extern size_t strxfrm (char *__restrict __dest,
> # 1 "/usr/include/xlocale.h" 1 3 4
> # 28 "/usr/include/xlocale.h" 3 4
> typedef struct __locale_struct
> struct locale_data *__locales[13];
> const unsigned short int *__ctype_b;
> const int *__ctype_tolower;
> const int *__ctype_toupper;
> const char *__names[13];
> } *__locale_t;
> typedef __locale_t locale_t;
> # 162 "/usr/include/string.h" 2 3 4
> extern int strcoll_l (__const char *__s1, __const char *__s2, __locale_t __l)
> extern size_t strxfrm_l (char *__dest, __const char *__src, size_t __n,
> __locale_t __l) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 4)));
> extern char *strdup (__const char *__s)
> __attribute__ ((__nothrow__)) __attribute__ ((__malloc__)) __attribute__ ((__nonnull__ (1)));
> extern char *strndup (__const char *__string, size_t __n)
> # 208 "/usr/include/string.h" 3 4
> # 233 "/usr/include/string.h" 3 4
> extern char *strchr (__const char *__s, int __c)
> __attribute__ ((__nothrow__)) __attribute__ ((__pure__)) __attribute__ ((__nonnull__ (1)));
> # 260 "/usr/include/string.h" 3 4
> extern char *strrchr (__const char *__s, int __c)
> # 279 "/usr/include/string.h" 3 4
> extern size_t strcspn (__const char *__s, __const char *__reject)
> extern size_t strspn (__const char *__s, __const char *__accept)
> # 312 "/usr/include/string.h" 3 4
> extern char *strpbrk (__const char *__s, __const char *__accept)
> # 340 "/usr/include/string.h" 3 4
> extern char *strstr (__const char *__haystack, __const char *__needle)
> extern char *strtok (char *__restrict __s, __const char *__restrict __delim)
> extern char *__strtok_r (char *__restrict __s,
> __const char *__restrict __delim,
> char **__restrict __save_ptr)
> extern char *strtok_r (char *__restrict __s, __const char *__restrict __delim,
> # 395 "/usr/include/string.h" 3 4
> extern size_t strlen (__const char *__s)
> extern size_t strnlen (__const char *__string, size_t __maxlen)
> extern char *strerror (int __errnum) __attribute__ ((__nothrow__));
> # 425 "/usr/include/string.h" 3 4
> extern int strerror_r (int __errnum, char *__buf, size_t __buflen) __asm__ ("" "__xpg_strerror_r") __attribute__ ((__nothrow__))
> # 443 "/usr/include/string.h" 3 4
> extern char *strerror_l (int __errnum, __locale_t __l) __attribute__ ((__nothrow__));
> extern void __bzero (void *__s, size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern void bcopy (__const void *__src, void *__dest, size_t __n)
> extern void bzero (void *__s, size_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int bcmp (__const void *__s1, __const void *__s2, size_t __n)
> # 487 "/usr/include/string.h" 3 4
> extern char *index (__const char *__s, int __c)
> # 515 "/usr/include/string.h" 3 4
> extern char *rindex (__const char *__s, int __c)
> extern int ffs (int __i) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> # 534 "/usr/include/string.h" 3 4
> extern int strcasecmp (__const char *__s1, __const char *__s2)
> extern int strncasecmp (__const char *__s1, __const char *__s2, size_t __n)
> # 557 "/usr/include/string.h" 3 4
> extern char *strsep (char **__restrict __stringp,
> extern char *strsignal (int __sig) __attribute__ ((__nothrow__));
> extern char *__stpcpy (char *__restrict __dest, __const char *__restrict __src)
> extern char *stpcpy (char *__restrict __dest, __const char *__restrict __src)
> extern char *__stpncpy (char *__restrict __dest,
> extern char *stpncpy (char *__restrict __dest,
> # 644 "/usr/include/string.h" 3 4
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> Defined "HAVE_STRING_H" to "1"
> Checking for header: sys/times.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/times.h" 1 3 4
> # 26 "/usr/include/sys/times.h" 3 4
> # 27 "/usr/include/sys/times.h" 2 3 4
> # 56 "/usr/include/time.h" 3 4
> # 57 "/usr/include/time.h" 2 3 4
> typedef __clock_t clock_t;
> # 30 "/usr/include/sys/times.h" 2 3 4
> struct tms
> clock_t tms_utime;
> clock_t tms_stime;
> clock_t tms_cutime;
> clock_t tms_cstime;
> extern clock_t times (struct tms *__buffer) __attribute__ ((__nothrow__));
> Defined "HAVE_SYS_TIMES_H" to "1"
> Checking for header: io.h
> stdout:
> # 1 "<built-in>"
> Possible ERROR while running preprocessor: exit code 256
> stdout:
> # 1 "<built-in>"
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2stderr:
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> #include <io.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:16: fatal error: io.h: No such file or directorycompilation terminated.:
> Checking for header: stdint.h
> stdout:
> # 1 "<built-in>"
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 1 3 4
> # 9 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 3 4
> # 1 "/usr/include/stdint.h" 1 3 4
> # 26 "/usr/include/stdint.h" 3 4
> # 27 "/usr/include/stdint.h" 2 3 4
> # 1 "/usr/include/bits/wchar.h" 1 3 4
> # 28 "/usr/include/stdint.h" 2 3 4
> # 29 "/usr/include/stdint.h" 2 3 4
> # 37 "/usr/include/stdint.h" 3 4
> typedef signed char int8_t;
> typedef short int int16_t;
> typedef int int32_t;
> typedef long int int64_t;
> typedef unsigned char uint8_t;
> typedef unsigned short int uint16_t;
> typedef unsigned int uint32_t;
> typedef unsigned long int uint64_t;
> # 66 "/usr/include/stdint.h" 3 4
> typedef signed char int_least8_t;
> typedef short int int_least16_t;
> typedef int int_least32_t;
> typedef long int int_least64_t;
> typedef unsigned char uint_least8_t;
> typedef unsigned short int uint_least16_t;
> typedef unsigned int uint_least32_t;
> typedef unsigned long int uint_least64_t;
> # 91 "/usr/include/stdint.h" 3 4
> typedef signed char int_fast8_t;
> typedef long int int_fast16_t;
> typedef long int int_fast32_t;
> typedef long int int_fast64_t;
> # 104 "/usr/include/stdint.h" 3 4
> typedef unsigned char uint_fast8_t;
> typedef unsigned long int uint_fast16_t;
> typedef unsigned long int uint_fast32_t;
> typedef unsigned long int uint_fast64_t;
> # 120 "/usr/include/stdint.h" 3 4
> typedef long int intptr_t;
> typedef unsigned long int uintptr_t;
> # 135 "/usr/include/stdint.h" 3 4
> typedef long int intmax_t;
> typedef unsigned long int uintmax_t;
> # 10 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 2 3 4
> Defined "HAVE_STDINT_H" to "1"
> Checking for header: pwd.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/pwd.h" 1 3 4
> # 26 "/usr/include/pwd.h" 3 4
> # 27 "/usr/include/pwd.h" 2 3 4
> # 31 "/usr/include/pwd.h" 2 3 4
> # 34 "/usr/include/pwd.h" 2 3 4
> struct passwd
> char *pw_name;
> char *pw_passwd;
> __uid_t pw_uid;
> __gid_t pw_gid;
> char *pw_gecos;
> char *pw_dir;
> char *pw_shell;
> # 1 "/usr/include/stdio.h" 1 3 4
> # 45 "/usr/include/stdio.h" 3 4
> struct _IO_FILE;
> typedef struct _IO_FILE FILE;
> # 65 "/usr/include/pwd.h" 2 3 4
> # 73 "/usr/include/pwd.h" 3 4
> extern void setpwent (void);
> extern void endpwent (void);
> extern struct passwd *getpwent (void);
> # 95 "/usr/include/pwd.h" 3 4
> extern struct passwd *fgetpwent (FILE *__stream);
> extern int putpwent (__const struct passwd *__restrict __p,
> FILE *__restrict __f);
> extern struct passwd *getpwuid (__uid_t __uid);
> extern struct passwd *getpwnam (__const char *__name);
> # 140 "/usr/include/pwd.h" 3 4
> extern int getpwent_r (struct passwd *__restrict __resultbuf,
> char *__restrict __buffer, size_t __buflen,
> struct passwd **__restrict __result);
> extern int getpwuid_r (__uid_t __uid,
> extern int getpwnam_r (__const char *__restrict __name,
> # 164 "/usr/include/pwd.h" 3 4
> extern int fgetpwent_r (FILE *__restrict __stream,
> # 184 "/usr/include/pwd.h" 3 4
> Defined "HAVE_PWD_H" to "1"
> Checking for header: float.h
> stdout:
> # 1 "<built-in>"
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/float.h" 1 3 4
> Defined "HAVE_FLOAT_H" to "1"
> Checking for header: sys/param.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/param.h" 1 3 4
> # 26 "/usr/include/sys/param.h" 3 4
> # 27 "/usr/include/sys/param.h" 2 3 4
> # 1 "/usr/include/linux/param.h" 1 3 4
> # 1 "/usr/include/asm/param.h" 1 3 4
> # 1 "/usr/include/asm-generic/param.h" 1 3 4
> # 1 "/usr/include/asm/param.h" 2 3 4
> # 5 "/usr/include/linux/param.h" 2 3 4
> # 29 "/usr/include/sys/param.h" 2 3 4
> # 52 "/usr/include/sys/param.h" 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> typedef struct
> } fd_set;
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 53 "/usr/include/sys/param.h" 2 3 4
> Defined "HAVE_SYS_PARAM_H" to "1"
> Checking for header: netdb.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/netdb.h" 1 3 4
> # 26 "/usr/include/netdb.h" 3 4
> # 27 "/usr/include/netdb.h" 2 3 4
> # 1 "/usr/include/netinet/in.h" 1 3 4
> # 24 "/usr/include/netinet/in.h" 3 4
> # 27 "/usr/include/stdint.h" 3 4
> # 25 "/usr/include/netinet/in.h" 2 3 4
> # 1 "/usr/include/sys/socket.h" 1 3 4
> # 26 "/usr/include/sys/socket.h" 3 4
> # 1 "/usr/include/sys/uio.h" 1 3 4
> # 24 "/usr/include/sys/uio.h" 3 4
> # 201 "/usr/include/sys/types.h" 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> typedef struct
> } fd_set;
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 25 "/usr/include/sys/uio.h" 2 3 4
> # 1 "/usr/include/bits/uio.h" 1 3 4
> # 44 "/usr/include/bits/uio.h" 3 4
> struct iovec
> void *iov_base;
> size_t iov_len;
> # 30 "/usr/include/sys/uio.h" 2 3 4
> # 40 "/usr/include/sys/uio.h" 3 4
> extern ssize_t readv (int __fd, __const struct iovec *__iovec, int __count)
> # 51 "/usr/include/sys/uio.h" 3 4
> extern ssize_t writev (int __fd, __const struct iovec *__iovec, int __count)
> # 66 "/usr/include/sys/uio.h" 3 4
> extern ssize_t preadv (int __fd, __const struct iovec *__iovec, int __count,
> __off_t __offset) ;
> # 78 "/usr/include/sys/uio.h" 3 4
> extern ssize_t pwritev (int __fd, __const struct iovec *__iovec, int __count,
> __off_t __offset) ;
> # 121 "/usr/include/sys/uio.h" 3 4
> # 29 "/usr/include/sys/socket.h" 2 3 4
> # 31 "/usr/include/sys/socket.h" 2 3 4
> # 40 "/usr/include/sys/socket.h" 3 4
> # 1 "/usr/include/bits/socket.h" 1 3 4
> # 29 "/usr/include/bits/socket.h" 3 4
> # 30 "/usr/include/bits/socket.h" 2 3 4
> typedef __socklen_t socklen_t;
> enum __socket_type
> SOCK_STREAM = 1,
> SOCK_DGRAM = 2,
> SOCK_RAW = 3,
> SOCK_RDM = 4,
> SOCK_SEQPACKET = 5,
> SOCK_DCCP = 6,
> SOCK_PACKET = 10,
> SOCK_CLOEXEC = 02000000,
> SOCK_NONBLOCK = 04000
> # 175 "/usr/include/bits/socket.h" 3 4
> # 1 "/usr/include/bits/sockaddr.h" 1 3 4
> # 29 "/usr/include/bits/sockaddr.h" 3 4
> typedef unsigned short int sa_family_t;
> # 176 "/usr/include/bits/socket.h" 2 3 4
> struct sockaddr
> sa_family_t sa_family;
> char sa_data[14];
> # 191 "/usr/include/bits/socket.h" 3 4
> struct sockaddr_storage
> sa_family_t ss_family;
> unsigned long int __ss_align;
> char __ss_padding[(128 - (2 * sizeof (unsigned long int)))];
> enum
> MSG_OOB = 0x01,
> MSG_PEEK = 0x02,
> MSG_DONTROUTE = 0x04,
> MSG_CTRUNC = 0x08,
> MSG_PROXY = 0x10,
> MSG_TRUNC = 0x20,
> MSG_DONTWAIT = 0x40,
> MSG_EOR = 0x80,
> MSG_WAITALL = 0x100,
> MSG_FIN = 0x200,
> MSG_SYN = 0x400,
> MSG_CONFIRM = 0x800,
> MSG_RST = 0x1000,
> MSG_ERRQUEUE = 0x2000,
> MSG_NOSIGNAL = 0x4000,
> MSG_MORE = 0x8000,
> MSG_CMSG_CLOEXEC = 0x40000000
> struct msghdr
> void *msg_name;
> socklen_t msg_namelen;
> struct iovec *msg_iov;
> size_t msg_iovlen;
> void *msg_control;
> size_t msg_controllen;
> int msg_flags;
> struct cmsghdr
> size_t cmsg_len;
> int cmsg_level;
> int cmsg_type;
> __extension__ unsigned char __cmsg_data [];
> # 297 "/usr/include/bits/socket.h" 3 4
> extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
> struct cmsghdr *__cmsg) __attribute__ ((__nothrow__));
> # 324 "/usr/include/bits/socket.h" 3 4
> enum
> SCM_RIGHTS = 0x01
> # 370 "/usr/include/bits/socket.h" 3 4
> # 1 "/usr/include/asm/socket.h" 1 3 4
> # 1 "/usr/include/asm-generic/socket.h" 1 3 4
> # 1 "/usr/include/asm/sockios.h" 1 3 4
> # 1 "/usr/include/asm-generic/sockios.h" 1 3 4
> # 1 "/usr/include/asm/sockios.h" 2 3 4
> # 5 "/usr/include/asm-generic/socket.h" 2 3 4
> # 1 "/usr/include/asm/socket.h" 2 3 4
> # 371 "/usr/include/bits/socket.h" 2 3 4
> # 404 "/usr/include/bits/socket.h" 3 4
> struct linger
> int l_onoff;
> int l_linger;
> # 41 "/usr/include/sys/socket.h" 2 3 4
> struct osockaddr
> unsigned short int sa_family;
> unsigned char sa_data[14];
> enum
> SHUT_RD = 0,
> SHUT_WR,
> SHUT_RDWR
> # 105 "/usr/include/sys/socket.h" 3 4
> extern int socket (int __domain, int __type, int __protocol) __attribute__ ((__nothrow__));
> extern int socketpair (int __domain, int __type, int __protocol,
> int __fds[2]) __attribute__ ((__nothrow__));
> extern int bind (int __fd, __const struct sockaddr * __addr, socklen_t __len)
> extern int getsockname (int __fd, struct sockaddr *__restrict __addr,
> socklen_t *__restrict __len) __attribute__ ((__nothrow__));
> # 129 "/usr/include/sys/socket.h" 3 4
> extern int connect (int __fd, __const struct sockaddr * __addr, socklen_t __len);
> extern int getpeername (int __fd, struct sockaddr *__restrict __addr,
> extern ssize_t send (int __fd, __const void *__buf, size_t __n, int __flags);
> extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
> extern ssize_t sendto (int __fd, __const void *__buf, size_t __n,
> int __flags, __const struct sockaddr * __addr,
> socklen_t __addr_len);
> # 166 "/usr/include/sys/socket.h" 3 4
> extern ssize_t recvfrom (int __fd, void *__restrict __buf, size_t __n,
> int __flags, struct sockaddr *__restrict __addr,
> socklen_t *__restrict __addr_len);
> extern ssize_t sendmsg (int __fd, __const struct msghdr *__message,
> int __flags);
> extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
> extern int getsockopt (int __fd, int __level, int __optname,
> void *__restrict __optval,
> socklen_t *__restrict __optlen) __attribute__ ((__nothrow__));
> extern int setsockopt (int __fd, int __level, int __optname,
> __const void *__optval, socklen_t __optlen) __attribute__ ((__nothrow__));
> extern int listen (int __fd, int __n) __attribute__ ((__nothrow__));
> # 214 "/usr/include/sys/socket.h" 3 4
> extern int accept (int __fd, struct sockaddr *__restrict __addr,
> # 232 "/usr/include/sys/socket.h" 3 4
> extern int shutdown (int __fd, int __how) __attribute__ ((__nothrow__));
> extern int sockatmark (int __fd) __attribute__ ((__nothrow__));
> extern int isfdtype (int __fd, int __fdtype) __attribute__ ((__nothrow__));
> # 254 "/usr/include/sys/socket.h" 3 4
> # 26 "/usr/include/netinet/in.h" 2 3 4
> enum
> IPPROTO_IP = 0,
> IPPROTO_HOPOPTS = 0,
> IPPROTO_ICMP = 1,
> IPPROTO_IGMP = 2,
> IPPROTO_IPIP = 4,
> IPPROTO_TCP = 6,
> IPPROTO_EGP = 8,
> IPPROTO_PUP = 12,
> IPPROTO_UDP = 17,
> IPPROTO_IDP = 22,
> IPPROTO_TP = 29,
> IPPROTO_DCCP = 33,
> IPPROTO_IPV6 = 41,
> IPPROTO_ROUTING = 43,
> IPPROTO_FRAGMENT = 44,
> IPPROTO_RSVP = 46,
> IPPROTO_GRE = 47,
> IPPROTO_ESP = 50,
> IPPROTO_AH = 51,
> IPPROTO_ICMPV6 = 58,
> IPPROTO_NONE = 59,
> IPPROTO_DSTOPTS = 60,
> IPPROTO_MTP = 92,
> IPPROTO_ENCAP = 98,
> IPPROTO_PIM = 103,
> IPPROTO_COMP = 108,
> IPPROTO_SCTP = 132,
> IPPROTO_UDPLITE = 136,
> IPPROTO_RAW = 255,
> IPPROTO_MAX
> typedef uint16_t in_port_t;
> enum
> IPPORT_ECHO = 7,
> IPPORT_DISCARD = 9,
> IPPORT_SYSTAT = 11,
> IPPORT_DAYTIME = 13,
> IPPORT_NETSTAT = 15,
> IPPORT_FTP = 21,
> IPPORT_TELNET = 23,
> IPPORT_SMTP = 25,
> IPPORT_TIMESERVER = 37,
> IPPORT_NAMESERVER = 42,
> IPPORT_WHOIS = 43,
> IPPORT_MTP = 57,
> IPPORT_TFTP = 69,
> IPPORT_RJE = 77,
> IPPORT_FINGER = 79,
> IPPORT_TTYLINK = 87,
> IPPORT_SUPDUP = 95,
> IPPORT_EXECSERVER = 512,
> IPPORT_LOGINSERVER = 513,
> IPPORT_CMDSERVER = 514,
> IPPORT_EFSSERVER = 520,
> IPPORT_BIFFUDP = 512,
> IPPORT_WHOSERVER = 513,
> IPPORT_ROUTESERVER = 520,
> IPPORT_RESERVED = 1024,
> IPPORT_USERRESERVED = 5000
> typedef uint32_t in_addr_t;
> struct in_addr
> in_addr_t s_addr;
> # 198 "/usr/include/netinet/in.h" 3 4
> struct in6_addr
> union
> uint8_t __u6_addr8[16];
> uint16_t __u6_addr16[8];
> uint32_t __u6_addr32[4];
> } __in6_u;
> extern const struct in6_addr in6addr_any;
> extern const struct in6_addr in6addr_loopback;
> # 225 "/usr/include/netinet/in.h" 3 4
> struct sockaddr_in
> sa_family_t sin_family;
> in_port_t sin_port;
> struct in_addr sin_addr;
> unsigned char sin_zero[sizeof (struct sockaddr) -
> (sizeof (unsigned short int)) -
> sizeof (in_port_t) -
> sizeof (struct in_addr)];
> struct sockaddr_in6
> sa_family_t sin6_family;
> in_port_t sin6_port;
> uint32_t sin6_flowinfo;
> struct in6_addr sin6_addr;
> uint32_t sin6_scope_id;
> struct ip_mreq
> struct in_addr imr_multiaddr;
> struct in_addr imr_interface;
> struct ip_mreq_source
> struct in_addr imr_sourceaddr;
> struct ipv6_mreq
> struct in6_addr ipv6mr_multiaddr;
> unsigned int ipv6mr_interface;
> struct group_req
> uint32_t gr_interface;
> struct sockaddr_storage gr_group;
> struct group_source_req
> uint32_t gsr_interface;
> struct sockaddr_storage gsr_group;
> struct sockaddr_storage gsr_source;
> struct ip_msfilter
> struct in_addr imsf_multiaddr;
> struct in_addr imsf_interface;
> uint32_t imsf_fmode;
> uint32_t imsf_numsrc;
> struct in_addr imsf_slist[1];
> struct group_filter
> uint32_t gf_interface;
> struct sockaddr_storage gf_group;
> uint32_t gf_fmode;
> uint32_t gf_numsrc;
> struct sockaddr_storage gf_slist[1];
> # 356 "/usr/include/netinet/in.h" 3 4
> # 1 "/usr/include/bits/in.h" 1 3 4
> # 86 "/usr/include/bits/in.h" 3 4
> struct ip_opts
> struct in_addr ip_dst;
> char ip_opts[40];
> struct ip_mreqn
> struct in_addr imr_address;
> int imr_ifindex;
> struct in_pktinfo
> int ipi_ifindex;
> struct in_addr ipi_spec_dst;
> struct in_addr ipi_addr;
> # 357 "/usr/include/netinet/in.h" 2 3 4
> # 365 "/usr/include/netinet/in.h" 3 4
> extern uint32_t ntohl (uint32_t __netlong) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern uint16_t ntohs (uint16_t __netshort)
> extern uint32_t htonl (uint32_t __hostlong)
> extern uint16_t htons (uint16_t __hostshort)
> # 377 "/usr/include/netinet/in.h" 2 3 4
> # 440 "/usr/include/netinet/in.h" 3 4
> extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) __attribute__ ((__nothrow__));
> extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
> # 565 "/usr/include/netinet/in.h" 3 4
> # 29 "/usr/include/netdb.h" 2 3 4
> # 1 "/usr/include/rpc/netdb.h" 1 3 4
> # 42 "/usr/include/rpc/netdb.h" 3 4
> # 43 "/usr/include/rpc/netdb.h" 2 3 4
> struct rpcent
> char *r_name;
> char **r_aliases;
> int r_number;
> extern void setrpcent (int __stayopen) __attribute__ ((__nothrow__));
> extern void endrpcent (void) __attribute__ ((__nothrow__));
> extern struct rpcent *getrpcbyname (__const char *__name) __attribute__ ((__nothrow__));
> extern struct rpcent *getrpcbynumber (int __number) __attribute__ ((__nothrow__));
> extern struct rpcent *getrpcent (void) __attribute__ ((__nothrow__));
> extern int getrpcbyname_r (__const char *__name, struct rpcent *__result_buf,
> char *__buffer, size_t __buflen,
> struct rpcent **__result) __attribute__ ((__nothrow__));
> extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
> extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
> size_t __buflen, struct rpcent **__result) __attribute__ ((__nothrow__));
> # 34 "/usr/include/netdb.h" 2 3 4
> # 43 "/usr/include/netdb.h" 3 4
> # 1 "/usr/include/bits/netdb.h" 1 3 4
> # 27 "/usr/include/bits/netdb.h" 3 4
> struct netent
> char *n_name;
> char **n_aliases;
> int n_addrtype;
> uint32_t n_net;
> # 44 "/usr/include/netdb.h" 2 3 4
> # 54 "/usr/include/netdb.h" 3 4
> extern int *__h_errno_location (void) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> # 91 "/usr/include/netdb.h" 3 4
> extern void herror (__const char *__str) __attribute__ ((__nothrow__));
> extern __const char *hstrerror (int __err_num) __attribute__ ((__nothrow__));
> struct hostent
> char *h_name;
> char **h_aliases;
> int h_addrtype;
> int h_length;
> char **h_addr_list;
> extern void sethostent (int __stay_open);
> extern void endhostent (void);
> extern struct hostent *gethostent (void);
> extern struct hostent *gethostbyaddr (__const void *__addr, __socklen_t __len,
> int __type);
> extern struct hostent *gethostbyname (__const char *__name);
> # 154 "/usr/include/netdb.h" 3 4
> extern struct hostent *gethostbyname2 (__const char *__name, int __af);
> # 166 "/usr/include/netdb.h" 3 4
> extern int gethostent_r (struct hostent *__restrict __result_buf,
> char *__restrict __buf, size_t __buflen,
> struct hostent **__restrict __result,
> int *__restrict __h_errnop);
> extern int gethostbyaddr_r (__const void *__restrict __addr, __socklen_t __len,
> int __type,
> extern int gethostbyname_r (__const char *__restrict __name,
> extern int gethostbyname2_r (__const char *__restrict __name, int __af,
> # 197 "/usr/include/netdb.h" 3 4
> extern void setnetent (int __stay_open);
> extern void endnetent (void);
> extern struct netent *getnetent (void);
> extern struct netent *getnetbyaddr (uint32_t __net, int __type);
> extern struct netent *getnetbyname (__const char *__name);
> # 236 "/usr/include/netdb.h" 3 4
> extern int getnetent_r (struct netent *__restrict __result_buf,
> struct netent **__restrict __result,
> extern int getnetbyaddr_r (uint32_t __net, int __type,
> extern int getnetbyname_r (__const char *__restrict __name,
> struct servent
> char *s_name;
> char **s_aliases;
> int s_port;
> char *s_proto;
> extern void setservent (int __stay_open);
> extern void endservent (void);
> extern struct servent *getservent (void);
> extern struct servent *getservbyname (__const char *__name,
> __const char *__proto);
> extern struct servent *getservbyport (int __port, __const char *__proto);
> # 308 "/usr/include/netdb.h" 3 4
> extern int getservent_r (struct servent *__restrict __result_buf,
> struct servent **__restrict __result);
> extern int getservbyname_r (__const char *__restrict __name,
> __const char *__restrict __proto,
> extern int getservbyport_r (int __port, __const char *__restrict __proto,
> struct protoent
> char *p_name;
> char **p_aliases;
> int p_proto;
> extern void setprotoent (int __stay_open);
> extern void endprotoent (void);
> extern struct protoent *getprotoent (void);
> extern struct protoent *getprotobyname (__const char *__name);
> extern struct protoent *getprotobynumber (int __proto);
> # 374 "/usr/include/netdb.h" 3 4
> extern int getprotoent_r (struct protoent *__restrict __result_buf,
> struct protoent **__restrict __result);
> extern int getprotobyname_r (__const char *__restrict __name,
> extern int getprotobynumber_r (int __proto,
> # 395 "/usr/include/netdb.h" 3 4
> extern int setnetgrent (__const char *__netgroup);
> extern void endnetgrent (void);
> # 412 "/usr/include/netdb.h" 3 4
> extern int getnetgrent (char **__restrict __hostp,
> char **__restrict __userp,
> char **__restrict __domainp);
> # 423 "/usr/include/netdb.h" 3 4
> extern int innetgr (__const char *__netgroup, __const char *__host,
> __const char *__user, __const char *__domain);
> extern int getnetgrent_r (char **__restrict __hostp,
> char **__restrict __domainp,
> char *__restrict __buffer, size_t __buflen);
> # 451 "/usr/include/netdb.h" 3 4
> extern int rcmd (char **__restrict __ahost, unsigned short int __rport,
> __const char *__restrict __locuser,
> __const char *__restrict __remuser,
> __const char *__restrict __cmd, int *__restrict __fd2p);
> # 463 "/usr/include/netdb.h" 3 4
> extern int rcmd_af (char **__restrict __ahost, unsigned short int __rport,
> __const char *__restrict __cmd, int *__restrict __fd2p,
> sa_family_t __af);
> # 479 "/usr/include/netdb.h" 3 4
> extern int rexec (char **__restrict __ahost, int __rport,
> __const char *__restrict __pass,
> # 491 "/usr/include/netdb.h" 3 4
> extern int rexec_af (char **__restrict __ahost, int __rport,
> sa_family_t __af);
> # 505 "/usr/include/netdb.h" 3 4
> extern int ruserok (__const char *__rhost, int __suser,
> __const char *__remuser, __const char *__locuser);
> # 515 "/usr/include/netdb.h" 3 4
> extern int ruserok_af (__const char *__rhost, int __suser,
> __const char *__remuser, __const char *__locuser,
> sa_family_t __af);
> # 528 "/usr/include/netdb.h" 3 4
> extern int iruserok (uint32_t __raddr, int __suser,
> # 539 "/usr/include/netdb.h" 3 4
> extern int iruserok_af (__const void *__raddr, int __suser,
> sa_family_t __af);
> # 551 "/usr/include/netdb.h" 3 4
> extern int rresvport (int *__alport);
> # 560 "/usr/include/netdb.h" 3 4
> extern int rresvport_af (int *__alport, sa_family_t __af);
> struct addrinfo
> int ai_flags;
> int ai_family;
> int ai_socktype;
> int ai_protocol;
> socklen_t ai_addrlen;
> struct sockaddr *ai_addr;
> char *ai_canonname;
> struct addrinfo *ai_next;
> # 662 "/usr/include/netdb.h" 3 4
> extern int getaddrinfo (__const char *__restrict __name,
> __const char *__restrict __service,
> __const struct addrinfo *__restrict __req,
> struct addrinfo **__restrict __pai);
> extern void freeaddrinfo (struct addrinfo *__ai) __attribute__ ((__nothrow__));
> extern __const char *gai_strerror (int __ecode) __attribute__ ((__nothrow__));
> extern int getnameinfo (__const struct sockaddr *__restrict __sa,
> socklen_t __salen, char *__restrict __host,
> socklen_t __hostlen, char *__restrict __serv,
> socklen_t __servlen, int __flags);
> # 713 "/usr/include/netdb.h" 3 4
> Defined "HAVE_NETDB_H" to "1"
> Checking for header: search.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/search.h" 1 3 4
> # 23 "/usr/include/search.h" 3 4
> # 24 "/usr/include/search.h" 2 3 4
> # 27 "/usr/include/search.h" 2 3 4
> # 45 "/usr/include/search.h" 3 4
> extern void insque (void *__elem, void *__prev) __attribute__ ((__nothrow__));
> extern void remque (void *__elem) __attribute__ ((__nothrow__));
> typedef enum
> FIND,
> ENTER
> ACTION;
> typedef struct entry
> char *key;
> void *data;
> ENTRY;
> struct _ENTRY;
> # 88 "/usr/include/search.h" 3 4
> extern ENTRY *hsearch (ENTRY __item, ACTION __action) __attribute__ ((__nothrow__));
> extern int hcreate (size_t __nel) __attribute__ ((__nothrow__));
> extern void hdestroy (void) __attribute__ ((__nothrow__));
> # 119 "/usr/include/search.h" 3 4
> typedef enum
> preorder,
> postorder,
> endorder,
> leaf
> VISIT;
> extern void *tsearch (__const void *__key, void **__rootp,
> __compar_fn_t __compar);
> extern void *tfind (__const void *__key, void *__const *__rootp,
> extern void *tdelete (__const void *__restrict __key,
> void **__restrict __rootp,
> typedef void (*__action_fn_t) (__const void *__nodep, VISIT __value,
> int __level);
> extern void twalk (__const void *__root, __action_fn_t __action);
> # 165 "/usr/include/search.h" 3 4
> extern void *lfind (__const void *__key, __const void *__base,
> size_t *__nmemb, size_t __size, __compar_fn_t __compar);
> extern void *lsearch (__const void *__key, void *__base,
> Defined "HAVE_SEARCH_H" to "1"
> Checking for header: mathimf.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
> Source:
> #include <mathimf.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:21: fatal error: mathimf.h: No such file or directorycompilation terminated.:
> Checking for header: sys/procfs.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/procfs.h" 1 3 4
> # 31 "/usr/include/sys/procfs.h" 3 4
> # 32 "/usr/include/sys/procfs.h" 2 3 4
> # 1 "/usr/include/sys/time.h" 1 3 4
> # 25 "/usr/include/sys/time.h" 3 4
> # 26 "/usr/include/sys/time.h" 2 3 4
> # 28 "/usr/include/sys/time.h" 2 3 4
> struct timeval
> __time_t tv_sec;
> # 30 "/usr/include/sys/time.h" 2 3 4
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> typedef struct
> } fd_set;
> # 32 "/usr/include/sys/time.h" 2 3 4
> # 57 "/usr/include/sys/time.h" 3 4
> struct timezone
> int tz_minuteswest;
> int tz_dsttime;
> typedef struct timezone *__restrict __timezone_ptr_t;
> # 73 "/usr/include/sys/time.h" 3 4
> extern int gettimeofday (struct timeval *__restrict __tv,
> __timezone_ptr_t __tz) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int settimeofday (__const struct timeval *__tv,
> __const struct timezone *__tz)
> extern int adjtime (__const struct timeval *__delta,
> struct timeval *__olddelta) __attribute__ ((__nothrow__));
> enum __itimer_which
> ITIMER_REAL = 0,
> ITIMER_VIRTUAL = 1,
> ITIMER_PROF = 2
> struct itimerval
> struct timeval it_interval;
> struct timeval it_value;
> typedef int __itimer_which_t;
> extern int getitimer (__itimer_which_t __which,
> struct itimerval *__value) __attribute__ ((__nothrow__));
> extern int setitimer (__itimer_which_t __which,
> __const struct itimerval *__restrict __new,
> struct itimerval *__restrict __old) __attribute__ ((__nothrow__));
> extern int utimes (__const char *__file, __const struct timeval __tvp[2])
> extern int lutimes (__const char *__file, __const struct timeval __tvp[2])
> extern int futimes (int __fd, __const struct timeval __tvp[2]) __attribute__ ((__nothrow__));
> # 191 "/usr/include/sys/time.h" 3 4
> # 33 "/usr/include/sys/procfs.h" 2 3 4
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> # 34 "/usr/include/sys/procfs.h" 2 3 4
> # 1 "/usr/include/sys/user.h" 1 3 4
> # 26 "/usr/include/sys/user.h" 3 4
> # 27 "/usr/include/sys/user.h" 2 3 4
> struct user_fpregs_struct
> __uint16_t cwd;
> __uint16_t swd;
> __uint16_t ftw;
> __uint16_t fop;
> __uint64_t rip;
> __uint64_t rdp;
> __uint32_t mxcsr;
> __uint32_t mxcr_mask;
> __uint32_t st_space[32];
> __uint32_t xmm_space[64];
> __uint32_t padding[24];
> struct user_regs_struct
> unsigned long r15;
> unsigned long r14;
> unsigned long r13;
> unsigned long r12;
> unsigned long rbp;
> unsigned long rbx;
> unsigned long r11;
> unsigned long r10;
> unsigned long r9;
> unsigned long r8;
> unsigned long rax;
> unsigned long rcx;
> unsigned long rdx;
> unsigned long rsi;
> unsigned long rdi;
> unsigned long orig_rax;
> unsigned long rip;
> unsigned long cs;
> unsigned long eflags;
> unsigned long rsp;
> unsigned long ss;
> unsigned long fs_base;
> unsigned long gs_base;
> unsigned long ds;
> unsigned long es;
> unsigned long fs;
> unsigned long gs;
> struct user
> struct user_regs_struct regs;
> int u_fpvalid;
> struct user_fpregs_struct i387;
> unsigned long int u_tsize;
> unsigned long int u_dsize;
> unsigned long int u_ssize;
> unsigned long start_code;
> unsigned long start_stack;
> long int signal;
> int reserved;
> struct user_regs_struct* u_ar0;
> struct user_fpregs_struct* u_fpstate;
> unsigned long int magic;
> char u_comm [32];
> unsigned long int u_debugreg [8];
> # 35 "/usr/include/sys/procfs.h" 2 3 4
> typedef unsigned long elf_greg_t;
> typedef elf_greg_t elf_gregset_t[(sizeof (struct user_regs_struct) / sizeof(elf_greg_t))];
> # 60 "/usr/include/sys/procfs.h" 3 4
> typedef struct user_fpregs_struct elf_fpregset_t;
> struct elf_siginfo
> int si_signo;
> int si_code;
> int si_errno;
> # 79 "/usr/include/sys/procfs.h" 3 4
> struct elf_prstatus
> struct elf_siginfo pr_info;
> short int pr_cursig;
> unsigned long int pr_sigpend;
> unsigned long int pr_sighold;
> __pid_t pr_pid;
> __pid_t pr_ppid;
> __pid_t pr_pgrp;
> __pid_t pr_sid;
> struct timeval pr_utime;
> struct timeval pr_stime;
> struct timeval pr_cutime;
> struct timeval pr_cstime;
> elf_gregset_t pr_reg;
> int pr_fpvalid;
> struct elf_prpsinfo
> char pr_state;
> char pr_sname;
> char pr_zomb;
> char pr_nice;
> unsigned long int pr_flag;
> unsigned int pr_uid;
> unsigned int pr_gid;
> int pr_pid, pr_ppid, pr_pgrp, pr_sid;
> char pr_fname[16];
> char pr_psargs[(80)];
> typedef void *psaddr_t;
> typedef elf_gregset_t prgregset_t;
> typedef elf_fpregset_t prfpregset_t;
> typedef __pid_t lwpid_t;
> typedef struct elf_prstatus prstatus_t;
> typedef struct elf_prpsinfo prpsinfo_t;
> Defined "HAVE_SYS_PROCFS_H" to "1"
> TEST check from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:77)
> TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
> Checks for "header", and defines HAVE_"header" if found
> Checking for header: sys/resource.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/resource.h" 1 3 4
> # 22 "/usr/include/sys/resource.h" 3 4
> # 23 "/usr/include/sys/resource.h" 2 3 4
> # 1 "/usr/include/bits/resource.h" 1 3 4
> # 25 "/usr/include/bits/resource.h" 3 4
> # 1 "/usr/include/bits/types.h" 1 3 4
> # 28 "/usr/include/bits/types.h" 3 4
> # 29 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned char __u_char;
> typedef unsigned short int __u_short;
> typedef unsigned int __u_int;
> typedef unsigned long int __u_long;
> typedef signed char __int8_t;
> typedef unsigned char __uint8_t;
> typedef signed short int __int16_t;
> typedef unsigned short int __uint16_t;
> typedef signed int __int32_t;
> typedef unsigned int __uint32_t;
> typedef signed long int __int64_t;
> typedef unsigned long int __uint64_t;
> typedef long int __quad_t;
> typedef unsigned long int __u_quad_t;
> # 131 "/usr/include/bits/types.h" 3 4
> # 1 "/usr/include/bits/typesizes.h" 1 3 4
> # 132 "/usr/include/bits/types.h" 2 3 4
> typedef unsigned long int __dev_t;
> typedef unsigned int __uid_t;
> typedef unsigned int __gid_t;
> typedef unsigned long int __ino_t;
> typedef unsigned long int __ino64_t;
> typedef unsigned int __mode_t;
> typedef unsigned long int __nlink_t;
> typedef long int __off_t;
> typedef long int __off64_t;
> typedef int __pid_t;
> typedef struct { int __val[2]; } __fsid_t;
> typedef long int __clock_t;
> typedef unsigned long int __rlim_t;
> typedef unsigned long int __rlim64_t;
> typedef unsigned int __id_t;
> typedef long int __time_t;
> typedef unsigned int __useconds_t;
> typedef long int __suseconds_t;
> typedef int __daddr_t;
> typedef long int __swblk_t;
> typedef int __key_t;
> typedef int __clockid_t;
> typedef void * __timer_t;
> typedef long int __blksize_t;
> typedef long int __blkcnt_t;
> typedef long int __blkcnt64_t;
> typedef unsigned long int __fsblkcnt_t;
> typedef unsigned long int __fsblkcnt64_t;
> typedef unsigned long int __fsfilcnt_t;
> typedef unsigned long int __fsfilcnt64_t;
> typedef long int __ssize_t;
> typedef __off64_t __loff_t;
> typedef __quad_t *__qaddr_t;
> typedef char *__caddr_t;
> typedef long int __intptr_t;
> typedef unsigned int __socklen_t;
> # 26 "/usr/include/bits/resource.h" 2 3 4
> enum __rlimit_resource
> RLIMIT_CPU = 0,
> RLIMIT_FSIZE = 1,
> RLIMIT_DATA = 2,
> RLIMIT_STACK = 3,
> RLIMIT_CORE = 4,
> __RLIMIT_RSS = 5,
> RLIMIT_NOFILE = 7,
> __RLIMIT_OFILE = RLIMIT_NOFILE,
> RLIMIT_AS = 9,
> __RLIMIT_NPROC = 6,
> __RLIMIT_MEMLOCK = 8,
> __RLIMIT_LOCKS = 10,
> __RLIMIT_SIGPENDING = 11,
> __RLIMIT_MSGQUEUE = 12,
> __RLIMIT_NICE = 13,
> __RLIMIT_RTPRIO = 14,
> __RLIMIT_NLIMITS = 15,
> __RLIM_NLIMITS = __RLIMIT_NLIMITS
> # 127 "/usr/include/bits/resource.h" 3 4
> typedef __rlim_t rlim_t;
> struct rlimit
> rlim_t rlim_cur;
> rlim_t rlim_max;
> # 154 "/usr/include/bits/resource.h" 3 4
> enum __rusage_who
> RUSAGE_SELF = 0,
> RUSAGE_CHILDREN = -1
> # 172 "/usr/include/bits/resource.h" 3 4
> # 1 "/usr/include/bits/time.h" 1 3 4
> struct timeval
> __time_t tv_sec;
> # 176 "/usr/include/bits/resource.h" 2 3 4
> struct rusage
> struct timeval ru_utime;
> struct timeval ru_stime;
> long int ru_maxrss;
> long int ru_ixrss;
> long int ru_idrss;
> long int ru_isrss;
> long int ru_minflt;
> long int ru_majflt;
> long int ru_nswap;
> long int ru_inblock;
> long int ru_oublock;
> long int ru_msgsnd;
> long int ru_msgrcv;
> long int ru_nsignals;
> long int ru_nvcsw;
> long int ru_nivcsw;
> enum __priority_which
> PRIO_PROCESS = 0,
> PRIO_PGRP = 1,
> PRIO_USER = 2
> # 26 "/usr/include/sys/resource.h" 2 3 4
> # 43 "/usr/include/sys/resource.h" 3 4
> typedef int __rlimit_resource_t;
> typedef int __rusage_who_t;
> typedef int __priority_which_t;
> extern int getrlimit (__rlimit_resource_t __resource,
> struct rlimit *__rlimits) __attribute__ ((__nothrow__));
> # 70 "/usr/include/sys/resource.h" 3 4
> extern int setrlimit (__rlimit_resource_t __resource,
> __const struct rlimit *__rlimits) __attribute__ ((__nothrow__));
> # 88 "/usr/include/sys/resource.h" 3 4
> extern int getrusage (__rusage_who_t __who, struct rusage *__usage) __attribute__ ((__nothrow__));
> extern int getpriority (__priority_which_t __which, id_t __who) __attribute__ ((__nothrow__));
> extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
> Defined "HAVE_SYS_RESOURCE_H" to "1"
> Checking for header: unistd.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/unistd.h" 1 3 4
> # 26 "/usr/include/unistd.h" 3 4
> # 27 "/usr/include/unistd.h" 2 3 4
> # 203 "/usr/include/unistd.h" 3 4
> # 1 "/usr/include/bits/posix_opt.h" 1 3 4
> # 204 "/usr/include/unistd.h" 2 3 4
> # 218 "/usr/include/unistd.h" 3 4
> # 219 "/usr/include/unistd.h" 2 3 4
> # 228 "/usr/include/unistd.h" 2 3 4
> # 256 "/usr/include/unistd.h" 3 4
> typedef __useconds_t useconds_t;
> typedef __pid_t pid_t;
> typedef __intptr_t intptr_t;
> # 288 "/usr/include/unistd.h" 3 4
> extern int access (__const char *__name, int __type) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> # 305 "/usr/include/unistd.h" 3 4
> extern int faccessat (int __fd, __const char *__file, int __type, int __flag)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2))) ;
> # 331 "/usr/include/unistd.h" 3 4
> extern __off_t lseek (int __fd, __off_t __offset, int __whence) __attribute__ ((__nothrow__));
> # 350 "/usr/include/unistd.h" 3 4
> extern int close (int __fd);
> extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
> extern ssize_t write (int __fd, __const void *__buf, size_t __n) ;
> # 414 "/usr/include/unistd.h" 3 4
> extern int pipe (int __pipedes[2]) __attribute__ ((__nothrow__)) ;
> # 429 "/usr/include/unistd.h" 3 4
> extern unsigned int alarm (unsigned int __seconds) __attribute__ ((__nothrow__));
> # 441 "/usr/include/unistd.h" 3 4
> extern unsigned int sleep (unsigned int __seconds);
> extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
> extern int usleep (__useconds_t __useconds);
> # 465 "/usr/include/unistd.h" 3 4
> extern int pause (void);
> extern int chown (__const char *__file, __uid_t __owner, __gid_t __group)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern int fchown (int __fd, __uid_t __owner, __gid_t __group) __attribute__ ((__nothrow__)) ;
> extern int lchown (__const char *__file, __uid_t __owner, __gid_t __group)
> extern int fchownat (int __fd, __const char *__file, __uid_t __owner,
> __gid_t __group, int __flag)
> extern int chdir (__const char *__path) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern int fchdir (int __fd) __attribute__ ((__nothrow__)) ;
> # 507 "/usr/include/unistd.h" 3 4
> extern char *getcwd (char *__buf, size_t __size) __attribute__ ((__nothrow__)) ;
> # 520 "/usr/include/unistd.h" 3 4
> extern char *getwd (char *__buf)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) __attribute__ ((__deprecated__)) ;
> extern int dup (int __fd) __attribute__ ((__nothrow__)) ;
> extern int dup2 (int __fd, int __fd2) __attribute__ ((__nothrow__));
> # 538 "/usr/include/unistd.h" 3 4
> extern char **__environ;
> extern int execve (__const char *__path, char *__const __argv[],
> char *__const __envp[]) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int fexecve (int __fd, char *__const __argv[], char *__const __envp[])
> extern int execv (__const char *__path, char *__const __argv[])
> extern int execle (__const char *__path, __const char *__arg, ...)
> extern int execl (__const char *__path, __const char *__arg, ...)
> extern int execvp (__const char *__file, char *__const __argv[])
> extern int execlp (__const char *__file, __const char *__arg, ...)
> # 593 "/usr/include/unistd.h" 3 4
> extern int nice (int __inc) __attribute__ ((__nothrow__)) ;
> extern void _exit (int __status) __attribute__ ((__noreturn__));
> # 1 "/usr/include/bits/confname.h" 1 3 4
> # 26 "/usr/include/bits/confname.h" 3 4
> enum
> _PC_LINK_MAX,
> _PC_MAX_CANON,
> _PC_MAX_INPUT,
> _PC_NAME_MAX,
> _PC_PATH_MAX,
> _PC_PIPE_BUF,
> _PC_CHOWN_RESTRICTED,
> _PC_NO_TRUNC,
> _PC_VDISABLE,
> _PC_SYNC_IO,
> _PC_ASYNC_IO,
> _PC_PRIO_IO,
> _PC_SOCK_MAXBUF,
> _PC_FILESIZEBITS,
> _PC_REC_INCR_XFER_SIZE,
> _PC_REC_MAX_XFER_SIZE,
> _PC_REC_MIN_XFER_SIZE,
> _PC_REC_XFER_ALIGN,
> _PC_ALLOC_SIZE_MIN,
> _PC_SYMLINK_MAX,
> _PC_2_SYMLINKS
> enum
> _SC_ARG_MAX,
> _SC_CHILD_MAX,
> _SC_CLK_TCK,
> _SC_NGROUPS_MAX,
> _SC_OPEN_MAX,
> _SC_STREAM_MAX,
> _SC_TZNAME_MAX,
> _SC_JOB_CONTROL,
> _SC_SAVED_IDS,
> _SC_REALTIME_SIGNALS,
> _SC_PRIORITY_SCHEDULING,
> _SC_TIMERS,
> _SC_ASYNCHRONOUS_IO,
> _SC_PRIORITIZED_IO,
> _SC_SYNCHRONIZED_IO,
> _SC_FSYNC,
> _SC_MAPPED_FILES,
> _SC_MEMLOCK,
> _SC_MEMLOCK_RANGE,
> _SC_MEMORY_PROTECTION,
> _SC_MESSAGE_PASSING,
> _SC_SEMAPHORES,
> _SC_SHARED_MEMORY_OBJECTS,
> _SC_AIO_LISTIO_MAX,
> _SC_AIO_MAX,
> _SC_AIO_PRIO_DELTA_MAX,
> _SC_DELAYTIMER_MAX,
> _SC_MQ_OPEN_MAX,
> _SC_MQ_PRIO_MAX,
> _SC_VERSION,
> _SC_PAGESIZE,
> _SC_RTSIG_MAX,
> _SC_SEM_NSEMS_MAX,
> _SC_SEM_VALUE_MAX,
> _SC_SIGQUEUE_MAX,
> _SC_TIMER_MAX,
> _SC_BC_BASE_MAX,
> _SC_BC_DIM_MAX,
> _SC_BC_SCALE_MAX,
> _SC_BC_STRING_MAX,
> _SC_COLL_WEIGHTS_MAX,
> _SC_EQUIV_CLASS_MAX,
> _SC_EXPR_NEST_MAX,
> _SC_LINE_MAX,
> _SC_RE_DUP_MAX,
> _SC_CHARCLASS_NAME_MAX,
> _SC_2_VERSION,
> _SC_2_C_BIND,
> _SC_2_C_DEV,
> _SC_2_FORT_DEV,
> _SC_2_FORT_RUN,
> _SC_2_SW_DEV,
> _SC_2_LOCALEDEF,
> _SC_PII,
> _SC_PII_XTI,
> _SC_PII_SOCKET,
> _SC_PII_INTERNET,
> _SC_PII_OSI,
> _SC_POLL,
> _SC_SELECT,
> _SC_UIO_MAXIOV,
> _SC_IOV_MAX = _SC_UIO_MAXIOV,
> _SC_PII_INTERNET_STREAM,
> _SC_PII_INTERNET_DGRAM,
> _SC_PII_OSI_COTS,
> _SC_PII_OSI_CLTS,
> _SC_PII_OSI_M,
> _SC_T_IOV_MAX,
> _SC_THREADS,
> _SC_THREAD_SAFE_FUNCTIONS,
> _SC_GETGR_R_SIZE_MAX,
> _SC_GETPW_R_SIZE_MAX,
> _SC_LOGIN_NAME_MAX,
> _SC_TTY_NAME_MAX,
> _SC_THREAD_DESTRUCTOR_ITERATIONS,
> _SC_THREAD_KEYS_MAX,
> _SC_THREAD_STACK_MIN,
> _SC_THREAD_THREADS_MAX,
> _SC_THREAD_ATTR_STACKADDR,
> _SC_THREAD_ATTR_STACKSIZE,
> _SC_THREAD_PRIORITY_SCHEDULING,
> _SC_THREAD_PRIO_INHERIT,
> _SC_THREAD_PRIO_PROTECT,
> _SC_THREAD_PROCESS_SHARED,
> _SC_NPROCESSORS_CONF,
> _SC_NPROCESSORS_ONLN,
> _SC_PHYS_PAGES,
> _SC_AVPHYS_PAGES,
> _SC_ATEXIT_MAX,
> _SC_PASS_MAX,
> _SC_XOPEN_VERSION,
> _SC_XOPEN_XCU_VERSION,
> _SC_XOPEN_UNIX,
> _SC_XOPEN_CRYPT,
> _SC_XOPEN_ENH_I18N,
> _SC_XOPEN_SHM,
> _SC_2_CHAR_TERM,
> _SC_2_C_VERSION,
> _SC_2_UPE,
> _SC_XOPEN_XPG2,
> _SC_XOPEN_XPG3,
> _SC_XOPEN_XPG4,
> _SC_CHAR_BIT,
> _SC_CHAR_MAX,
> _SC_CHAR_MIN,
> _SC_INT_MAX,
> _SC_INT_MIN,
> _SC_LONG_BIT,
> _SC_WORD_BIT,
> _SC_MB_LEN_MAX,
> _SC_NZERO,
> _SC_SSIZE_MAX,
> _SC_SCHAR_MAX,
> _SC_SCHAR_MIN,
> _SC_SHRT_MAX,
> _SC_SHRT_MIN,
> _SC_UCHAR_MAX,
> _SC_UINT_MAX,
> _SC_ULONG_MAX,
> _SC_USHRT_MAX,
> _SC_NL_ARGMAX,
> _SC_NL_LANGMAX,
> _SC_NL_MSGMAX,
> _SC_NL_NMAX,
> _SC_NL_SETMAX,
> _SC_NL_TEXTMAX,
> _SC_XBS5_ILP32_OFF32,
> _SC_XBS5_ILP32_OFFBIG,
> _SC_XBS5_LP64_OFF64,
> _SC_XBS5_LPBIG_OFFBIG,
> _SC_XOPEN_LEGACY,
> _SC_XOPEN_REALTIME,
> _SC_XOPEN_REALTIME_THREADS,
> _SC_ADVISORY_INFO,
> _SC_BARRIERS,
> _SC_BASE,
> _SC_C_LANG_SUPPORT,
> _SC_C_LANG_SUPPORT_R,
> _SC_CLOCK_SELECTION,
> _SC_CPUTIME,
> _SC_THREAD_CPUTIME,
> _SC_DEVICE_IO,
> _SC_DEVICE_SPECIFIC,
> _SC_DEVICE_SPECIFIC_R,
> _SC_FD_MGMT,
> _SC_FIFO,
> _SC_PIPE,
> _SC_FILE_ATTRIBUTES,
> _SC_FILE_LOCKING,
> _SC_FILE_SYSTEM,
> _SC_MONOTONIC_CLOCK,
> _SC_MULTI_PROCESS,
> _SC_SINGLE_PROCESS,
> _SC_NETWORKING,
> _SC_READER_WRITER_LOCKS,
> _SC_SPIN_LOCKS,
> _SC_REGEXP,
> _SC_REGEX_VERSION,
> _SC_SHELL,
> _SC_SIGNALS,
> _SC_SPAWN,
> _SC_SPORADIC_SERVER,
> _SC_THREAD_SPORADIC_SERVER,
> _SC_SYSTEM_DATABASE,
> _SC_SYSTEM_DATABASE_R,
> _SC_TIMEOUTS,
> _SC_TYPED_MEMORY_OBJECTS,
> _SC_USER_GROUPS,
> _SC_USER_GROUPS_R,
> _SC_2_PBS,
> _SC_2_PBS_ACCOUNTING,
> _SC_2_PBS_LOCATE,
> _SC_2_PBS_MESSAGE,
> _SC_2_PBS_TRACK,
> _SC_SYMLOOP_MAX,
> _SC_STREAMS,
> _SC_2_PBS_CHECKPOINT,
> _SC_V6_ILP32_OFF32,
> _SC_V6_ILP32_OFFBIG,
> _SC_V6_LP64_OFF64,
> _SC_V6_LPBIG_OFFBIG,
> _SC_HOST_NAME_MAX,
> _SC_TRACE,
> _SC_TRACE_EVENT_FILTER,
> _SC_TRACE_INHERIT,
> _SC_TRACE_LOG,
> _SC_LEVEL1_ICACHE_SIZE,
> _SC_LEVEL1_ICACHE_ASSOC,
> _SC_LEVEL1_ICACHE_LINESIZE,
> _SC_LEVEL1_DCACHE_SIZE,
> _SC_LEVEL1_DCACHE_ASSOC,
> _SC_LEVEL1_DCACHE_LINESIZE,
> _SC_LEVEL2_CACHE_SIZE,
> _SC_LEVEL2_CACHE_ASSOC,
> _SC_LEVEL2_CACHE_LINESIZE,
> _SC_LEVEL3_CACHE_SIZE,
> _SC_LEVEL3_CACHE_ASSOC,
> _SC_LEVEL3_CACHE_LINESIZE,
> _SC_LEVEL4_CACHE_SIZE,
> _SC_LEVEL4_CACHE_ASSOC,
> _SC_LEVEL4_CACHE_LINESIZE,
> _SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
> _SC_RAW_SOCKETS,
> _SC_V7_ILP32_OFF32,
> _SC_V7_ILP32_OFFBIG,
> _SC_V7_LP64_OFF64,
> _SC_V7_LPBIG_OFFBIG,
> _SC_SS_REPL_MAX,
> _SC_TRACE_EVENT_NAME_MAX,
> _SC_TRACE_NAME_MAX,
> _SC_TRACE_SYS_MAX,
> _SC_TRACE_USER_EVENT_MAX,
> _SC_XOPEN_STREAMS,
> _SC_THREAD_ROBUST_PRIO_INHERIT,
> _SC_THREAD_ROBUST_PRIO_PROTECT
> enum
> _CS_PATH,
> _CS_V6_WIDTH_RESTRICTED_ENVS,
> _CS_GNU_LIBC_VERSION,
> _CS_GNU_LIBPTHREAD_VERSION,
> _CS_V5_WIDTH_RESTRICTED_ENVS,
> _CS_V7_WIDTH_RESTRICTED_ENVS,
> _CS_LFS_CFLAGS = 1000,
> _CS_LFS_LDFLAGS,
> _CS_LFS_LIBS,
> _CS_LFS_LINTFLAGS,
> _CS_LFS64_CFLAGS,
> _CS_LFS64_LDFLAGS,
> _CS_LFS64_LIBS,
> _CS_LFS64_LINTFLAGS,
> _CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
> _CS_XBS5_ILP32_OFF32_LDFLAGS,
> _CS_XBS5_ILP32_OFF32_LIBS,
> _CS_XBS5_ILP32_OFF32_LINTFLAGS,
> _CS_XBS5_ILP32_OFFBIG_CFLAGS,
> _CS_XBS5_ILP32_OFFBIG_LDFLAGS,
> _CS_XBS5_ILP32_OFFBIG_LIBS,
> _CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
> _CS_XBS5_LP64_OFF64_CFLAGS,
> _CS_XBS5_LP64_OFF64_LDFLAGS,
> _CS_XBS5_LP64_OFF64_LIBS,
> _CS_XBS5_LP64_OFF64_LINTFLAGS,
> _CS_XBS5_LPBIG_OFFBIG_CFLAGS,
> _CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
> _CS_XBS5_LPBIG_OFFBIG_LIBS,
> _CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
> _CS_POSIX_V6_ILP32_OFF32_CFLAGS,
> _CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
> _CS_POSIX_V6_ILP32_OFF32_LIBS,
> _CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
> _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
> _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
> _CS_POSIX_V6_ILP32_OFFBIG_LIBS,
> _CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
> _CS_POSIX_V6_LP64_OFF64_CFLAGS,
> _CS_POSIX_V6_LP64_OFF64_LDFLAGS,
> _CS_POSIX_V6_LP64_OFF64_LIBS,
> _CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
> _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
> _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
> _CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
> _CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS,
> _CS_POSIX_V7_ILP32_OFF32_CFLAGS,
> _CS_POSIX_V7_ILP32_OFF32_LDFLAGS,
> _CS_POSIX_V7_ILP32_OFF32_LIBS,
> _CS_POSIX_V7_ILP32_OFF32_LINTFLAGS,
> _CS_POSIX_V7_ILP32_OFFBIG_CFLAGS,
> _CS_POSIX_V7_ILP32_OFFBIG_LDFLAGS,
> _CS_POSIX_V7_ILP32_OFFBIG_LIBS,
> _CS_POSIX_V7_ILP32_OFFBIG_LINTFLAGS,
> _CS_POSIX_V7_LP64_OFF64_CFLAGS,
> _CS_POSIX_V7_LP64_OFF64_LDFLAGS,
> _CS_POSIX_V7_LP64_OFF64_LIBS,
> _CS_POSIX_V7_LP64_OFF64_LINTFLAGS,
> _CS_POSIX_V7_LPBIG_OFFBIG_CFLAGS,
> _CS_POSIX_V7_LPBIG_OFFBIG_LDFLAGS,
> _CS_POSIX_V7_LPBIG_OFFBIG_LIBS,
> _CS_POSIX_V7_LPBIG_OFFBIG_LINTFLAGS
> # 605 "/usr/include/unistd.h" 2 3 4
> extern long int pathconf (__const char *__path, int __name)
> extern long int fpathconf (int __fd, int __name) __attribute__ ((__nothrow__));
> extern long int sysconf (int __name) __attribute__ ((__nothrow__));
> extern size_t confstr (int __name, char *__buf, size_t __len) __attribute__ ((__nothrow__));
> extern __pid_t getpid (void) __attribute__ ((__nothrow__));
> extern __pid_t getppid (void) __attribute__ ((__nothrow__));
> extern __pid_t getpgrp (void) __attribute__ ((__nothrow__));
> # 641 "/usr/include/unistd.h" 3 4
> extern __pid_t __getpgid (__pid_t __pid) __attribute__ ((__nothrow__));
> # 650 "/usr/include/unistd.h" 3 4
> extern int setpgid (__pid_t __pid, __pid_t __pgid) __attribute__ ((__nothrow__));
> # 667 "/usr/include/unistd.h" 3 4
> extern int setpgrp (void) __attribute__ ((__nothrow__));
> # 684 "/usr/include/unistd.h" 3 4
> extern __pid_t setsid (void) __attribute__ ((__nothrow__));
> extern __uid_t getuid (void) __attribute__ ((__nothrow__));
> extern __uid_t geteuid (void) __attribute__ ((__nothrow__));
> extern __gid_t getgid (void) __attribute__ ((__nothrow__));
> extern __gid_t getegid (void) __attribute__ ((__nothrow__));
> extern int getgroups (int __size, __gid_t __list[]) __attribute__ ((__nothrow__)) ;
> # 717 "/usr/include/unistd.h" 3 4
> extern int setuid (__uid_t __uid) __attribute__ ((__nothrow__));
> extern int setreuid (__uid_t __ruid, __uid_t __euid) __attribute__ ((__nothrow__));
> extern int seteuid (__uid_t __uid) __attribute__ ((__nothrow__));
> extern int setgid (__gid_t __gid) __attribute__ ((__nothrow__));
> extern int setregid (__gid_t __rgid, __gid_t __egid) __attribute__ ((__nothrow__));
> extern int setegid (__gid_t __gid) __attribute__ ((__nothrow__));
> # 773 "/usr/include/unistd.h" 3 4
> extern __pid_t fork (void) __attribute__ ((__nothrow__));
> extern __pid_t vfork (void) __attribute__ ((__nothrow__));
> extern char *ttyname (int __fd) __attribute__ ((__nothrow__));
> extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
> extern int isatty (int __fd) __attribute__ ((__nothrow__));
> extern int ttyslot (void) __attribute__ ((__nothrow__));
> extern int link (__const char *__from, __const char *__to)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 2))) ;
> extern int linkat (int __fromfd, __const char *__from, int __tofd,
> __const char *__to, int __flags)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 4))) ;
> extern int symlink (__const char *__from, __const char *__to)
> extern ssize_t readlink (__const char *__restrict __path,
> char *__restrict __buf, size_t __len)
> extern int symlinkat (__const char *__from, int __tofd,
> __const char *__to) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1, 3))) ;
> extern ssize_t readlinkat (int __fd, __const char *__restrict __path,
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2, 3))) ;
> extern int unlink (__const char *__name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int unlinkat (int __fd, __const char *__name, int __flag)
> __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> extern int rmdir (__const char *__path) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern __pid_t tcgetpgrp (int __fd) __attribute__ ((__nothrow__));
> extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) __attribute__ ((__nothrow__));
> extern char *getlogin (void);
> extern int getlogin_r (char *__name, size_t __name_len) __attribute__ ((__nonnull__ (1)));
> extern int setlogin (__const char *__name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> # 887 "/usr/include/unistd.h" 3 4
> # 1 "/usr/include/getopt.h" 1 3 4
> # 59 "/usr/include/getopt.h" 3 4
> extern char *optarg;
> # 73 "/usr/include/getopt.h" 3 4
> extern int optind;
> extern int opterr;
> extern int optopt;
> # 152 "/usr/include/getopt.h" 3 4
> extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
> # 888 "/usr/include/unistd.h" 2 3 4
> extern int gethostname (char *__name, size_t __len) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern int sethostname (__const char *__name, size_t __len)
> extern int sethostid (long int __id) __attribute__ ((__nothrow__)) ;
> extern int getdomainname (char *__name, size_t __len)
> extern int setdomainname (__const char *__name, size_t __len)
> extern int vhangup (void) __attribute__ ((__nothrow__));
> extern int revoke (__const char *__file) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern int profil (unsigned short int *__sample_buffer, size_t __size,
> size_t __offset, unsigned int __scale)
> extern int acct (__const char *__name) __attribute__ ((__nothrow__));
> extern char *getusershell (void) __attribute__ ((__nothrow__));
> extern void endusershell (void) __attribute__ ((__nothrow__));
> extern void setusershell (void) __attribute__ ((__nothrow__));
> extern int daemon (int __nochdir, int __noclose) __attribute__ ((__nothrow__)) ;
> extern int chroot (__const char *__path) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1))) ;
> extern char *getpass (__const char *__prompt) __attribute__ ((__nonnull__ (1)));
> # 973 "/usr/include/unistd.h" 3 4
> extern int fsync (int __fd);
> extern long int gethostid (void);
> extern void sync (void) __attribute__ ((__nothrow__));
> extern int getpagesize (void) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern int getdtablesize (void) __attribute__ ((__nothrow__));
> extern int truncate (__const char *__file, __off_t __length)
> # 1020 "/usr/include/unistd.h" 3 4
> extern int ftruncate (int __fd, __off_t __length) __attribute__ ((__nothrow__)) ;
> # 1040 "/usr/include/unistd.h" 3 4
> extern int brk (void *__addr) __attribute__ ((__nothrow__)) ;
> extern void *sbrk (intptr_t __delta) __attribute__ ((__nothrow__));
> # 1061 "/usr/include/unistd.h" 3 4
> extern long int syscall (long int __sysno, ...) __attribute__ ((__nothrow__));
> # 1084 "/usr/include/unistd.h" 3 4
> extern int lockf (int __fd, int __cmd, __off_t __len) ;
> # 1115 "/usr/include/unistd.h" 3 4
> extern int fdatasync (int __fildes);
> # 1153 "/usr/include/unistd.h" 3 4
> Defined "HAVE_UNISTD_H" to "1"
> Checking for header: netinet/in.h
> stdout:
> # 1 "<built-in>"
> # 23 "/usr/include/netinet/in.h" 3 4
> # 24 "/usr/include/netinet/in.h" 2 3 4
> # 1 "/usr/include/sys/types.h" 1 3 4
> # 29 "/usr/include/sys/types.h" 3 4
> # 32 "/usr/include/sys/types.h" 2 3 4
> typedef __u_char u_char;
> typedef __u_short u_short;
> typedef __u_int u_int;
> typedef __u_long u_long;
> typedef __quad_t quad_t;
> typedef __u_quad_t u_quad_t;
> typedef __fsid_t fsid_t;
> typedef __loff_t loff_t;
> typedef __ino_t ino_t;
> # 62 "/usr/include/sys/types.h" 3 4
> typedef __dev_t dev_t;
> typedef __gid_t gid_t;
> typedef __mode_t mode_t;
> typedef __nlink_t nlink_t;
> typedef __uid_t uid_t;
> typedef __off_t off_t;
> # 100 "/usr/include/sys/types.h" 3 4
> typedef __id_t id_t;
> typedef __ssize_t ssize_t;
> typedef __daddr_t daddr_t;
> typedef __caddr_t caddr_t;
> typedef __key_t key_t;
> # 133 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/time.h" 1 3 4
> # 74 "/usr/include/time.h" 3 4
> typedef __time_t time_t;
> # 92 "/usr/include/time.h" 3 4
> typedef __clockid_t clockid_t;
> # 104 "/usr/include/time.h" 3 4
> typedef __timer_t timer_t;
> # 134 "/usr/include/sys/types.h" 2 3 4
> # 147 "/usr/include/sys/types.h" 3 4
> # 148 "/usr/include/sys/types.h" 2 3 4
> typedef unsigned long int ulong;
> typedef unsigned short int ushort;
> typedef unsigned int uint;
> typedef unsigned int u_int8_t __attribute__ ((__mode__ (__QI__)));
> typedef unsigned int u_int16_t __attribute__ ((__mode__ (__HI__)));
> typedef unsigned int u_int32_t __attribute__ ((__mode__ (__SI__)));
> typedef unsigned int u_int64_t __attribute__ ((__mode__ (__DI__)));
> typedef int register_t __attribute__ ((__mode__ (__word__)));
> # 217 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/endian.h" 1 3 4
> # 37 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/endian.h" 1 3 4
> # 38 "/usr/include/endian.h" 2 3 4
> # 61 "/usr/include/endian.h" 3 4
> # 1 "/usr/include/bits/byteswap.h" 1 3 4
> # 28 "/usr/include/bits/byteswap.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 29 "/usr/include/bits/byteswap.h" 2 3 4
> # 62 "/usr/include/endian.h" 2 3 4
> # 218 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/select.h" 1 3 4
> # 31 "/usr/include/sys/select.h" 3 4
> # 1 "/usr/include/bits/select.h" 1 3 4
> # 23 "/usr/include/bits/select.h" 3 4
> # 24 "/usr/include/bits/select.h" 2 3 4
> # 32 "/usr/include/sys/select.h" 2 3 4
> # 1 "/usr/include/bits/sigset.h" 1 3 4
> # 24 "/usr/include/bits/sigset.h" 3 4
> typedef int __sig_atomic_t;
> typedef struct
> unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
> } __sigset_t;
> # 35 "/usr/include/sys/select.h" 2 3 4
> typedef __sigset_t sigset_t;
> # 120 "/usr/include/time.h" 3 4
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> # 45 "/usr/include/sys/select.h" 2 3 4
> # 69 "/usr/include/bits/time.h" 3 4
> struct timeval
> __time_t tv_sec;
> __suseconds_t tv_usec;
> # 47 "/usr/include/sys/select.h" 2 3 4
> typedef __suseconds_t suseconds_t;
> typedef long int __fd_mask;
> # 67 "/usr/include/sys/select.h" 3 4
> typedef struct
> __fd_mask __fds_bits[1024 / (8 * (int) sizeof (__fd_mask))];
> } fd_set;
> typedef __fd_mask fd_mask;
> # 99 "/usr/include/sys/select.h" 3 4
> # 109 "/usr/include/sys/select.h" 3 4
> extern int select (int __nfds, fd_set *__restrict __readfds,
> fd_set *__restrict __writefds,
> fd_set *__restrict __exceptfds,
> struct timeval *__restrict __timeout);
> # 121 "/usr/include/sys/select.h" 3 4
> extern int pselect (int __nfds, fd_set *__restrict __readfds,
> const struct timespec *__restrict __timeout,
> const __sigset_t *__restrict __sigmask);
> # 221 "/usr/include/sys/types.h" 2 3 4
> # 1 "/usr/include/sys/sysmacros.h" 1 3 4
> # 30 "/usr/include/sys/sysmacros.h" 3 4
> __extension__
> extern unsigned int gnu_dev_major (unsigned long long int __dev)
> __extension__
> extern unsigned int gnu_dev_minor (unsigned long long int __dev)
> __extension__
> extern unsigned long long int gnu_dev_makedev (unsigned int __major,
> unsigned int __minor)
> # 224 "/usr/include/sys/types.h" 2 3 4
> # 235 "/usr/include/sys/types.h" 3 4
> typedef __blkcnt_t blkcnt_t;
> typedef __fsblkcnt_t fsblkcnt_t;
> typedef __fsfilcnt_t fsfilcnt_t;
> # 270 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/bits/pthreadtypes.h" 1 3 4
> # 23 "/usr/include/bits/pthreadtypes.h" 3 4
> # 24 "/usr/include/bits/pthreadtypes.h" 2 3 4
> # 50 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef unsigned long int pthread_t;
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> typedef struct __pthread_internal_list
> struct __pthread_internal_list *__prev;
> struct __pthread_internal_list *__next;
> } __pthread_list_t;
> # 76 "/usr/include/bits/pthreadtypes.h" 3 4
> typedef union
> struct __pthread_mutex_s
> int __lock;
> unsigned int __count;
> int __owner;
> unsigned int __nusers;
> int __kind;
> int __spins;
> __pthread_list_t __list;
> # 101 "/usr/include/bits/pthreadtypes.h" 3 4
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_mutexattr_t;
> typedef union
> struct
> int __lock;
> unsigned int __futex;
> __extension__ unsigned long long int __total_seq;
> __extension__ unsigned long long int __wakeup_seq;
> __extension__ unsigned long long int __woken_seq;
> void *__mutex;
> unsigned int __nwaiters;
> unsigned int __broadcast_seq;
> } __data;
> char __size[48];
> __extension__ long long int __align;
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_condattr_t;
> typedef unsigned int pthread_key_t;
> typedef int pthread_once_t;
> typedef union
> struct
> int __lock;
> unsigned int __nr_readers;
> unsigned int __readers_wakeup;
> unsigned int __writer_wakeup;
> unsigned int __nr_readers_queued;
> unsigned int __nr_writers_queued;
> int __writer;
> int __shared;
> unsigned long int __pad1;
> unsigned long int __pad2;
> unsigned int __flags;
> } __data;
> # 187 "/usr/include/bits/pthreadtypes.h" 3 4
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> } pthread_rwlockattr_t;
> typedef volatile int pthread_spinlock_t;
> typedef union
> char __size[32];
> long int __align;
> } pthread_barrier_t;
> typedef union
> char __size[4];
> int __align;
> } pthread_barrierattr_t;
> # 271 "/usr/include/sys/types.h" 2 3 4
> struct iovec
> void *iov_base;
> size_t iov_len;
> __off_t __offset) ;
> __off_t __offset) ;
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> enum __socket_type
> SOCK_STREAM = 1,
> SOCK_DGRAM = 2,
> SOCK_RAW = 3,
> SOCK_RDM = 4,
> SOCK_SEQPACKET = 5,
> SOCK_DCCP = 6,
> SOCK_PACKET = 10,
> struct sockaddr
> char sa_data[14];
> enum
> MSG_OOB = 0x01,
> MSG_PEEK = 0x02,
> MSG_CTRUNC = 0x08,
> MSG_PROXY = 0x10,
> MSG_TRUNC = 0x20,
> MSG_EOR = 0x80,
> MSG_FIN = 0x200,
> MSG_SYN = 0x400,
> MSG_RST = 0x1000,
> MSG_MORE = 0x8000,
> struct msghdr
> void *msg_name;
> size_t msg_iovlen;
> void *msg_control;
> int msg_flags;
> struct cmsghdr
> size_t cmsg_len;
> int cmsg_level;
> int cmsg_type;
> enum
> SCM_RIGHTS = 0x01
> struct linger
> int l_onoff;
> int l_linger;
> struct osockaddr
> enum
> SHUT_RD = 0,
> SHUT_WR,
> SHUT_RDWR
> int __flags);
> enum
> IPPROTO_IP = 0,
> IPPROTO_ICMP = 1,
> IPPROTO_IGMP = 2,
> IPPROTO_IPIP = 4,
> IPPROTO_TCP = 6,
> IPPROTO_EGP = 8,
> IPPROTO_PUP = 12,
> IPPROTO_UDP = 17,
> IPPROTO_IDP = 22,
> IPPROTO_TP = 29,
> IPPROTO_DCCP = 33,
> IPPROTO_IPV6 = 41,
> IPPROTO_RSVP = 46,
> IPPROTO_GRE = 47,
> IPPROTO_ESP = 50,
> IPPROTO_AH = 51,
> IPPROTO_NONE = 59,
> IPPROTO_MTP = 92,
> IPPROTO_ENCAP = 98,
> IPPROTO_PIM = 103,
> IPPROTO_COMP = 108,
> IPPROTO_SCTP = 132,
> IPPROTO_RAW = 255,
> IPPROTO_MAX
> enum
> IPPORT_ECHO = 7,
> IPPORT_DISCARD = 9,
> IPPORT_SYSTAT = 11,
> IPPORT_FTP = 21,
> IPPORT_TELNET = 23,
> IPPORT_SMTP = 25,
> IPPORT_WHOIS = 43,
> IPPORT_MTP = 57,
> IPPORT_TFTP = 69,
> IPPORT_RJE = 77,
> IPPORT_FINGER = 79,
> IPPORT_SUPDUP = 95,
> struct in_addr
> in_addr_t s_addr;
> struct in6_addr
> union
> } __in6_u;
> struct sockaddr_in
> in_port_t sin_port;
> struct sockaddr_in6
> struct ip_mreq
> struct ipv6_mreq
> struct group_req
> struct ip_msfilter
> struct group_filter
> uint32_t gf_fmode;
> uint32_t gf_numsrc;
> struct ip_opts
> char ip_opts[40];
> struct ip_mreqn
> int imr_ifindex;
> struct in_pktinfo
> int ipi_ifindex;
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Defined "HAVE_NETINET_IN_H" to "1"
> TEST checkRecursiveMacros from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:218)
> TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
> Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.headers/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.headers -g -O0 /tmp/petsc-uoFdrH/config.headers/conftest.c
> Successful compile:
> Source:
> void a(int i, int j) {}
> #define a(b) a(b,__LINE__)
> int main() {
> a(0);
> return 0;
> TEST configureCacheDetails from config.utilities.cacheDetails(/home/zampins/src/petsc/config/BuildSystem/config/utilities/cacheDetails.py:78)
> TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
> Try to determine the size and associativity of the cache.
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.utilities.cacheDetails
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.utilities.cacheDetails/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -g -O0 /tmp/petsc-uoFdrH/config.utilities.cacheDetails/conftest.c
> Successful compile:
> Source:
> #include <unistd.h>
> long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
> int main() {
> return 0;
> Popping language C
> Defined "LEVEL1_DCACHE_SIZE" to "32768"
> Defined "LEVEL1_DCACHE_LINESIZE" to "64"
> Defined "LEVEL1_DCACHE_ASSOC" to "8"
> TEST check_siginfo_t from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:46)
> TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
> Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
> Checking for type: siginfo_t
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.types
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.types/conftest.o -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -g -O0 /tmp/petsc-uoFdrH/config.types/conftest.c
> Successful compile:
> Source:
> #include <sys/types.h>
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #include<signal.h>
> #endif
> int main() {
> siginfo_t a;;
> return 0;
> siginfo_t found
> Defined "HAVE_SIGINFO_T" to "1"
> TEST check__int64 from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:52)
> TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
> Checks if __int64 exists. This is primarily for windows.
> Checking for type: __int64
> Possible ERROR while running compiler: exit code 256
> stderr:
> /tmp/petsc-uoFdrH/config.types/conftest.c: In function 'main':
> /tmp/petsc-uoFdrH/config.types/conftest.c:13:1: error: unknown type name '__int64'
> __int64 a;;
> Source:
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #endif
> int main() {
> __int64 a;;
> return 0;
> __int64 found
> TEST checkSizeTypes from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:58)
> TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
> Checks for types associated with sizes, such as size_t.
> Checking for type: size_t
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #endif
> int main() {
> size_t a;;
> return 0;
> size_t found
> TEST checkFileTypes from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:68)
> TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
> Checks for types associated with files, such as mode_t, off_t, etc.
> Checking for type: mode_t
> Successful compile:
> Source:
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #endif
> int main() {
> mode_t a;;
> return 0;
> mode_t found
> Checking for type: off_t
> Successful compile:
> Source:
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #endif
> int main() {
> off_t a;;
> return 0;
> off_t found
> TEST checkIntegerTypes from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:63)
> TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
> Checks for types associated with integers, such as int32_t.
> Checking for type: int32_t
> Successful compile:
> Source:
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #endif
> int main() {
> int32_t a;;
> return 0;
> int32_t found
> TEST checkPID from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:74)
> TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
> Checks for pid_t, and defines it if necessary
> Checking for type: pid_t
> Successful compile:
> Source:
> #if STDC_HEADERS
> #include <stdlib.h>
> #include <stddef.h>
> #endif
> int main() {
> pid_t a;;
> return 0;
> pid_t found
> TEST checkUID from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:78)
> TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
> Checks for uid_t and gid_t, and defines them if necessary
> Source:
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.types/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.types/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.types/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.types/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.types/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.types/conftest.c" 2
> # 27 "/usr/include/sys/types.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 28 "/usr/include/sys/types.h" 2 3 4
> # 31 "/usr/include/bits/types.h" 3 4
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 195 "/usr/include/sys/types.h" 3 4
> typedef int int8_t __attribute__ ((__mode__ (__QI__)));
> typedef int int16_t __attribute__ ((__mode__ (__HI__)));
> typedef int int32_t __attribute__ ((__mode__ (__SI__)));
> typedef int int64_t __attribute__ ((__mode__ (__DI__)));
> typedef struct
> } __sigset_t;
> struct timespec
> __time_t tv_sec;
> long int tv_nsec;
> struct timeval
> __time_t tv_sec;
> typedef struct
> } fd_set;
> __extension__
> __extension__
> __extension__
> typedef union
> char __size[56];
> long int __align;
> } pthread_attr_t;
> } __pthread_list_t;
> typedef union
> int __lock;
> int __owner;
> int __kind;
> int __spins;
> } __data;
> char __size[40];
> long int __align;
> } pthread_mutex_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> void *__mutex;
> } __data;
> char __size[48];
> } pthread_cond_t;
> typedef union
> char __size[4];
> int __align;
> typedef union
> struct
> int __lock;
> int __writer;
> int __shared;
> } __data;
> char __size[56];
> long int __align;
> } pthread_rwlock_t;
> typedef union
> char __size[8];
> long int __align;
> typedef union
> char __size[32];
> long int __align;
> typedef union
> char __size[4];
> int __align;
> TEST checkSignal from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:85)
> TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
> Checks the return type of signal() and defines RETSIGTYPE to that type name
> Successful compile:
> Source:
> #include <signal.h>
> #ifdef signal
> #undef signal
> #endif
> #ifdef __cplusplus
> extern "C" void (*signal (int, void(*)(int)))(int);
> #else
> void (*signal())();
> #endif
> int main() {
> return 0;
> Defined "RETSIGTYPE" to "void"
> TEST checkC99Complex from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:106)
> TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
> Check for complex numbers in in C99 std
> Note that since PETSc source code uses _Complex we test specifically for that, not complex
> Successful compile:
> Source:
> #include <complex.h>
> int main() {
> double _Complex x;
> x = I;
> return 0;
> Successful compile:
> Source:
> int main() {
> double _Complex x;
> x = I;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.types/conftest -g -O0 /tmp/petsc-uoFdrH/config.types/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_C99_COMPLEX" to "1"
> TEST checkCxxComplex from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:117)
> TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
> Check for complex numbers in namespace std
> Pushing language Cxx
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.types/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.types/conftest.cc
> Successful compile:
> Source:
> #include <complex>
> int main() {
> std::complex<double> x;
> return 0;
> Pushing language CXX
> Popping language CXX
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.types/conftest -g -O0 /tmp/petsc-uoFdrH/config.types/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_CXX_COMPLEX" to "1"
> Popping language Cxx
> TEST checkFortranKind from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:138)
> TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
> Checks whether selected_int_kind etc work USE_FORTRANKIND
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.types/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -g -O0 /tmp/petsc-uoFdrH/config.types/conftest.F90
> Successful compile:
> Source:
> program main
> integer(kind=selected_int_kind(10)) i
> real(kind=selected_real_kind(10)) d
> end
> Defined "USE_FORTRANKIND" to "1"
> Popping language FC
> TEST checkConst from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:150)
> TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
> Checks for working const, and if not found defines it to empty string
> Successful compile:
> Source:
> int main() {
> /* Ultrix mips cc rejects this. */
> typedef int charset[2]; const charset x;
> /* SunOS 4.1.1 cc rejects this. */
> char const *const *ccp;
> char **p;
> /* NEC SVR4.0.2 mips cc rejects this. */
> struct point {int x, y;};
> static struct point const zero = {0,0};
> /* AIX XL C 1.02.0.0 rejects this.
> It does not let you subtract one const X* pointer from another in an arm
> of an if-expression whose if-part is not a constant expression */
> const char *g = "string";
> ccp = &g + (g ? g-g : 0);
> /* HPUX 7.0 cc rejects these. */
> ++ccp;
> p = (char**) ccp;
> ccp = (char const *const *) p;
> /* This section avoids unused variable warnings */
> if (zero.x);
> if (x[0]);
> { /* SCO 3.2v4 cc rejects this. */
> char *t;
> char const *s = 0 ? (char *) 0 : (char const *) 0;
> *t++ = 0;
> if (*s);
> { /* Someone thinks the Sun supposedly-ANSI compiler will reject this. */
> int x[] = {25, 17};
> const int *foo = &x[0];
> ++foo;
> { /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
> typedef const int *iptr;
> iptr p = 0;
> ++p;
> { /* AIX XL C 1.02.0.0 rejects this saying
> "k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
> struct s { int j; const int *ap[3]; };
> struct s *b; b->j = 5;
> { /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
> const int foo = 10;
> /* Get rid of unused variable warning */
> if (foo);
> return 0;
> TEST checkEndian from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:206)
> TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
> If the machine is big endian, defines WORDS_BIGENDIAN
> Successful compile:
> Source:
> #ifdef HAVE_SYS_PARAM_H
> #include <sys/param.h>
> #endif
> int main() {
> #if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
> bogus endian macros
> #endif
> return 0;
> stderr:
> /tmp/petsc-uoFdrH/config.types/conftest.c:11:3: error: unknown type name 'not'
> not big endian
> /tmp/petsc-uoFdrH/config.types/conftest.c:11:11: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'endian'
> not big endian
> Source:
> #endif
> int main() {
> #if BYTE_ORDER != BIG_ENDIAN
> not big endian
> #endif
> return 0;
> TEST checkSizeof from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:259)
> TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
> Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
> Checking for size of type: char
> Defined "SIZEOF_CHAR" to "1"
> Checking for size of type: void *
> Defined "SIZEOF_VOID_P" to "8"
> Checking for size of type: short
> Defined "SIZEOF_SHORT" to "2"
> Checking for size of type: int
> Defined "SIZEOF_INT" to "4"
> Checking for size of type: long
> Defined "SIZEOF_LONG" to "8"
> Checking for size of type: long long
> Defined "SIZEOF_LONG_LONG" to "8"
> Checking for size of type: float
> Defined "SIZEOF_FLOAT" to "4"
> Checking for size of type: double
> Defined "SIZEOF_DOUBLE" to "8"
> Checking for size of type: size_t
> Defined "SIZEOF_SIZE_T" to "8"
> TEST checkBitsPerByte from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:310)
> TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
> Determine the nubmer of bits per byte and define BITS_PER_BYTE
> Defined "BITS_PER_BYTE" to "8"
> TEST checkVisibility from config.types(/home/zampins/src/petsc/config/BuildSystem/config/types.py:356)
> TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
> Disabled visibility attributes due to static build================================================================================
> TEST configureMemAlign from PETSc.options.memAlign(/home/zampins/src/petsc/config/PETSc/options/memAlign.py:30)
> TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
> Choose alignment
> Defined "MEMALIGN" to "16"
> Memory alignment is 16
> TEST check from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:159)
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:159)
> Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
> - libDir may be a list of directories
> - libName may be a list of library names
> Checking for functions [socket] in library ['socket', 'nsl'] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> /* Override any gcc2 internal prototype to avoid an error. */
> char socket();
> static void _check_socket() { socket(); }
> int main() {
> _check_socket();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lsocket -lnsl -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Possible ERROR while running linker: exit code 256
> stderr:
> /usr/bin/ld: cannot find -lsocket
> collect2: error: ld returned 1 exit status
> Popping language C
> Checking for functions [handle_sigfpes] in library ['fpe'] []
> Pushing language C
> Successful compile:
> Source:
> char handle_sigfpes();
> static void _check_handle_sigfpes() { handle_sigfpes(); }
> int main() {
> _check_handle_sigfpes();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lfpe -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /usr/bin/ld: cannot find -lfpe
> Popping language C
> Pushing language C
> Successful compile:
> Source:
> char socket();
> int main() {
> _check_socket();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Popping language C
> Pushing language C
> Successful compile:
> Source:
> int main() {
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Popping language C
> TEST checkMath from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:264)
> TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:264)
> Check for sin() in libm, the math library
> Checking for functions [sin floor log10 pow] in library [''] []
> Pushing language C
> Successful compile:
> Source:
> #include <stdio.h>
> double sin(double);
> static void _check_sin() { double x,y; scanf("%lf",&x); y = sin(x); printf("%f",y);
> #include <stdio.h>
> double floor(double);
> static void _check_floor() { double x,y; scanf("%lf",&x); y = floor(x); printf("%f",y);
> #include <stdio.h>
> double log10(double);
> static void _check_log10() { double x,y; scanf("%lf",&x); y = log10(x); printf("%f",y);
> #include <stdio.h>
> double pow(double, double);
> static void _check_pow() { double x,y; scanf("%lf",&x); y = pow(x,x); printf("%f",y);
> int main() {
> _check_sin();
> _check_floor();
> _check_log10();
> _check_pow();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language C
> CheckMath: using math library []
> TEST checkMathErf from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:283)
> TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:283)
> Check for erf() in libm, the math library
> Checking for functions [erf] in library [] []
> Pushing language C
> Successful compile:
> Source:
> #include <math.h>
> static void _check_erf() { double (*checkErf)(double) = erf;double x = 0,y; y = (*checkErf)(x); }
> int main() {
> _check_erf();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> erf() found
> Defined "HAVE_ERF" to "1"
> TEST checkMathTgamma from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:292)
> TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:292)
> Check for tgamma() in libm, the math library
> Checking for functions [tgamma] in library [] []
> Pushing language C
> Successful compile:
> Source:
> #include <math.h>
> static void _check_tgamma() { double (*checkTgamma)(double) = tgamma;double x = 0,y; y = (*checkTgamma)(x); }
> int main() {
> _check_tgamma();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> tgamma() found
> Defined "HAVE_TGAMMA" to "1"
> TEST checkMathFenv from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:301)
> TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:301)
> Checks if <fenv.h> can be used with FE_DFL_ENV
> Checking for functions [fesetenv] in library [] []
> Pushing language C
> Successful compile:
> Source:
> #include <fenv.h>
> static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
> int main() {
> _check_fesetenv();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> Defined "HAVE_FENV_H" to "1"
> TEST checkMathLog2 from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:309)
> TESTING: checkMathLog2 from config.libraries(config/BuildSystem/config/libraries.py:309)
> Check for log2() in libm, the math library
> Checking for functions [log2] in library [] []
> Pushing language C
> Successful compile:
> Source:
> #include <math.h>
> static void _check_log2() { double (*checkLog2)(double) = log2; double x = 2.5, y = (*checkLog2)(x); }
> int main() {
> _check_log2();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> log2() found
> Defined "HAVE_LOG2" to "1"
> TEST checkRealtime from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:318)
> TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:318)
> Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
> Checking for functions [clock_gettime] in library [''] []
> Pushing language C
> Successful compile:
> Source:
> #include <time.h>
> static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
> int main() {
> _check_clock_gettime();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> realtime functions are linked in by default
> TEST checkDynamic from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:334)
> TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:334)
> Check for the header and libraries necessary for dynamic library manipulation
> Checking for functions [dlopen] in library ['dl'] []
> Pushing language C
> Successful compile:
> Source:
> char dlopen();
> static void _check_dlopen() { dlopen(); }
> int main() {
> _check_dlopen();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_dlopen':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Defined "HAVE_LIBDL" to "1"
> Popping language C
> Checking for header: dlfcn.h
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/usr/include/dlfcn.h" 1 3 4
> # 23 "/usr/include/dlfcn.h" 3 4
> # 24 "/usr/include/dlfcn.h" 2 3 4
> # 26 "/usr/include/dlfcn.h" 2 3 4
> # 1 "/usr/include/bits/dlfcn.h" 1 3 4
> # 29 "/usr/include/dlfcn.h" 2 3 4
> # 53 "/usr/include/dlfcn.h" 3 4
> extern void *dlopen (__const char *__file, int __mode) __attribute__ ((__nothrow__));
> extern int dlclose (void *__handle) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (1)));
> extern void *dlsym (void *__restrict __handle,
> __const char *__restrict __name) __attribute__ ((__nothrow__)) __attribute__ ((__nonnull__ (2)));
> # 83 "/usr/include/dlfcn.h" 3 4
> extern char *dlerror (void) __attribute__ ((__nothrow__));
> # 189 "/usr/include/dlfcn.h" 3 4
> Defined "HAVE_DLFCN_H" to "1"
> TEST configureLibraryOptions from PETSc.options.libraryOptions(/home/zampins/src/petsc/config/PETSc/options/libraryOptions.py:37)
> TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:37)
> Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE and PETSC_USE_FORTRAN_KERNELS
> Defined "USE_LOG" to "1"
> Defined "USE_DEBUG" to "1"
> Defined "USE_INFO" to "1"
> Defined "USE_CTABLE" to "1"
> Defined "USE_BACKWARD_LOOP" to "1"
> **********Checking if running on BGL/IBM detected
> Checking for functions [bgl_perfctr_void] in library [''] []
> Pushing language C
> Successful compile:
> Source:
> char bgl_perfctr_void();
> static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
> int main() {
> _check_bgl_perfctr_void();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_bgl_perfctr_void':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `bgl_perfctr_void'
> Popping language C
> Checking for functions [ADIOI_BGL_Open] in library [''] []
> Pushing language C
> Successful compile:
> Source:
> char ADIOI_BGL_Open();
> static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
> int main() {
> _check_ADIOI_BGL_Open();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_ADIOI_BGL_Open':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `ADIOI_BGL_Open'
> Popping language C
> *********BGL/IBM test failure
> Defined "Alignx(a,b)" to " "
> TEST configureISColorValueType from PETSc.options.libraryOptions(/home/zampins/src/petsc/config/PETSc/options/libraryOptions.py:91)
> TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:91)
> Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
> Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
> Defined "IS_COLORING_MAX" to "65535"
> Defined "IS_COLOR_VALUE_TYPE" to "short"
> Defined "IS_COLOR_VALUE_TYPE_F" to "integer2"
> TEST configureCPURelax from config.atomics(/home/zampins/src/petsc/config/BuildSystem/config/atomics.py:17)
> TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
> Definitions for cpu relax assembly instructions
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.atomics
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.atomics/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -g -O0 /tmp/petsc-uoFdrH/config.atomics/conftest.c
> Successful compile:
> Source:
> int main() {
> asm volatile("rep; nop" ::: "memory");;
> return 0;
> Defined "CPU_RELAX()" to "asm volatile("rep; nop" ::: "memory")"
> TEST configureMemoryBarriers from config.atomics(/home/zampins/src/petsc/config/BuildSystem/config/atomics.py:36)
> TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:36)
> Definitions for memory barrier instructions
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.atomics/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -g -O0 /tmp/petsc-uoFdrH/config.atomics/conftest.c
> Successful compile:
> Source:
> int main() {
> asm volatile("mfence":::"memory");
> return 0;
> Defined "MEMORY_BARRIER()" to "asm volatile("mfence":::"memory")"
> Successful compile:
> Source:
> int main() {
> asm volatile("lfence":::"memory");
> return 0;
> Defined "READ_MEMORY_BARRIER()" to "asm volatile("lfence":::"memory")"
> Successful compile:
> Source:
> int main() {
> asm volatile("sfence":::"memory");
> return 0;
> Defined "WRITE_MEMORY_BARRIER()" to "asm volatile("sfence":::"memory")"
> TEST checkMemcmp from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:110)
> TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:110)
> Check for 8-bit clean memcmp
> TEST checkSysinfo from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:135)
> TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:135)
> Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
> Checking for functions [sysinfo]
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.functions
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.functions/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.atomics -g -O0 /tmp/petsc-uoFdrH/config.functions/conftest.c
> Successful compile:
> Source:
> /* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> /* We use char because int might match the return type of a gcc2
> builtin and then its argument prototype would still apply. */
> char sysinfo();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_sysinfo) || defined (__stub___sysinfo)
> sysinfo_will_always_fail_with_ENOSYS();
> #else
> sysinfo();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.functions/conftest -g -O0 /tmp/petsc-uoFdrH/config.functions/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_SYSINFO" to "1"
> Checking for header: linux/kernel.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/linux/kernel.h" 1 3 4
> # 11 "/usr/include/linux/kernel.h" 3 4
> struct sysinfo {
> long uptime;
> unsigned long loads[3];
> unsigned long totalram;
> unsigned long freeram;
> unsigned long sharedram;
> unsigned long bufferram;
> unsigned long totalswap;
> unsigned long freeswap;
> unsigned short procs;
> unsigned short pad;
> unsigned long totalhigh;
> unsigned long freehigh;
> unsigned int mem_unit;
> char _f[20-2*sizeof(long)-sizeof(int)];
> Defined "HAVE_LINUX_KERNEL_H" to "1"
> Checking for header: sys/sysinfo.h
> stdout:
> # 1 "<built-in>"
> # 1 "/usr/include/sys/sysinfo.h" 1 3 4
> # 22 "/usr/include/sys/sysinfo.h" 3 4
> # 23 "/usr/include/sys/sysinfo.h" 2 3 4
> struct sysinfo {
> long uptime;
> unsigned short pad;
> # 26 "/usr/include/sys/sysinfo.h" 2 3 4
> extern int sysinfo (struct sysinfo *__info) __attribute__ ((__nothrow__));
> extern int get_nprocs_conf (void) __attribute__ ((__nothrow__));
> extern int get_nprocs (void) __attribute__ ((__nothrow__));
> extern long int get_phys_pages (void) __attribute__ ((__nothrow__));
> extern long int get_avphys_pages (void) __attribute__ ((__nothrow__));
> Defined "HAVE_SYS_SYSINFO_H" to "1"
> Checking for header: sys/systeminfo.h
> stdout:
> # 1 "<built-in>"
> Possible ERROR while running preprocessor: exit code 256
> stdout:
> # 1 "<built-in>"
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2stderr:
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
> compilation terminated.
> Source:
> #include <sys/systeminfo.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:28: fatal error: sys/systeminfo.h: No such file or directorycompilation terminated.:
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.functions/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.functions -g -O0 /tmp/petsc-uoFdrH/config.functions/conftest.c
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:13:4: error: #error "Cannot check sysinfo without special headers"
> # error "Cannot check sysinfo without special headers"
> /tmp/petsc-uoFdrH/config.functions/conftest.c: In function 'main':
> /tmp/petsc-uoFdrH/config.functions/conftest.c:17:30: warning: implicit declaration of function 'sysinfo' [-Wimplicit-function-declaration]
> char buf[10]; long count=10; sysinfo(1, buf, count);
> Source:
> #ifdef HAVE_LINUX_KERNEL_H
> # include <linux/kernel.h>
> # include <linux/sys.h>
> # ifdef HAVE_SYS_SYSINFO_H
> # include <sys/sysinfo.h>
> # endif
> #elif defined(HAVE_SYS_SYSTEMINFO_H)
> # include <sys/systeminfo.h>
> #else
> #endif
> int main() {
> return 0;
> Compile failed inside link
> TEST checkVPrintf from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:158)
> TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:158)
> Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
> Checking for functions [vprintf]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function 'vprintf'
> char vprintf();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char vprintf();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_vprintf) || defined (__stub___vprintf)
> vprintf_will_always_fail_with_ENOSYS();
> #else
> vprintf();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_VPRINTF" to "1"
> Successful compile:
> Source:
> #include <stdio.h>
> #include <stdarg.h>
> int main() {
> va_list Argp;
> vprintf( "%d", Argp );
> return 0;
> Pushing language C
> Popping language C
> TEST checkVFPrintf from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:165)
> TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:165)
> Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
> Checking for functions [vfprintf]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function 'vfprintf'
> char vfprintf();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char vfprintf();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_vfprintf) || defined (__stub___vfprintf)
> vfprintf_will_always_fail_with_ENOSYS();
> #else
> vfprintf();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_VFPRINTF" to "1"
> Successful compile:
> Source:
> #include <stdio.h>
> #include <stdarg.h>
> int main() {
> va_list Argp;
> vfprintf(stdout, "%d", Argp );
> return 0;
> Pushing language C
> Popping language C
> TEST checkVSNPrintf from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:172)
> TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:172)
> Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:6:1: warning: implicit declaration of function '_vsnprintf' [-Wimplicit-function-declaration]
> _vsnprintf(0,0,0,0);
> Source:
> #include <stdio.h>
> int main() {
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.o: In function `main':
> /tmp/petsc-uoFdrH/config.functions/conftest.c:6: undefined reference to `_vsnprintf'
> Checking for functions [vsnprintf]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function 'vsnprintf'
> char vsnprintf();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char vsnprintf();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
> vsnprintf_will_always_fail_with_ENOSYS();
> #else
> vsnprintf();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_VSNPRINTF" to "1"
> Successful compile:
> Source:
> #include <stdio.h>
> #include <stdarg.h>
> int main() {
> va_list Argp;char str[6];
> vsnprintf(str,5, "%d", Argp );
> return 0;
> Pushing language C
> Popping language C
> TEST checkNanosleep from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:206)
> TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:206)
> Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
> Successful compile:
> Source:
> #include <time.h>
> int main() {
> struct timespec tp;
> tp.tv_sec = 0;
> tp.tv_nsec = (long)(1e9);
> nanosleep(&tp,0);
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_NANOSLEEP" to "1"
> TEST checkSignalHandlerType from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:182)
> TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:182)
> Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.functions/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.functions -g -O0 /tmp/petsc-uoFdrH/config.functions/conftest.cc
> Successful compile:
> Source:
> #include <signal.h>
> static void myhandler(int sig) {}
> int main() {
> signal(SIGFPE,myhandler);
> return 0;
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.functions/conftest -g -O0 /tmp/petsc-uoFdrH/config.functions/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "SIGNAL_CAST" to " "
> TEST checkFreeReturnType from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:192)
> TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:192)
> Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:6:25: error: void value not ignored as it ought to be
> int ierr; void *p; ierr = free(p); return 0;
> Source:
> #include <stdlib.h>
> int main() {
> return 0;
> TEST checkVariableArgumentLists from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:198)
> TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:198)
> Checks whether the variable argument list functionality is working
> Successful compile:
> Source:
> #include <stdarg.h>
> int main() {
> va_list l1, l2;
> va_copy(l1, l2);
> return 0;
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_VA_COPY" to "1"
> TEST checkClassify from config.functions(/home/zampins/src/petsc/config/BuildSystem/config/functions.py:89)
> TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:89)
> Recursive decompose to rapidly classify functions as found or missing
> To confirm that a function is missing, we require a compile/link
> failure with only that function in a compilation unit. In contrast,
> we can confirm that many functions are present by compiling them all
> together in a large compilation unit. We optimistically compile
> everything together, then trim all functions that were named in the
> error message and bisect the result. The trimming is only an
> optimization to increase the likelihood of a big-batch compile
> succeeding; we do not rely on the compiler naming missing functions.
> Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times _mkdir time sysctlbyname stricmp]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:16:6: warning: conflicting types for built-in function 'snprintf'
> char snprintf();
> /tmp/petsc-uoFdrH/config.functions/conftest.c:19:6: warning: conflicting types for built-in function 'bzero'
> char bzero();
> /tmp/petsc-uoFdrH/config.functions/conftest.c:36:6: warning: conflicting types for built-in function 'fork'
> char fork();
> /tmp/petsc-uoFdrH/config.functions/conftest.c:48:6: warning: conflicting types for built-in function 'strcasecmp'
> char strcasecmp();
> /tmp/petsc-uoFdrH/config.functions/conftest.c:52:6: warning: conflicting types for built-in function 'memmove'
> char memmove();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char rand();
> char getdomainname();
> char _sleep();
> char snprintf();
> char realpath();
> char dlsym();
> char bzero();
> char _getcwd();
> char getwd();
> char uname();
> char _lseek();
> char sleep();
> char _access();
> char lseek();
> char usleep();
> char dlclose();
> char gethostname();
> char clock();
> char get_nprocs();
> char access();
> char _snprintf();
> char dlerror();
> char mkstemp();
> char fork();
> char getpagesize();
> char sbreak();
> char memalign();
> char sigset();
> char getcwd();
> char gethostbyname();
> char gettimeofday();
> char readlink();
> char _set_output_format();
> char PXFGETARG();
> char sigaction();
> char strcasecmp();
> char dlopen();
> char drand48();
> char socket();
> char memmove();
> char signal();
> char popen();
> char getrusage();
> char times();
> char _mkdir();
> char time();
> char sysctlbyname();
> char stricmp();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_rand) || defined (__stub___rand)
> rand_will_always_fail_with_ENOSYS();
> #else
> rand();
> #endif
> #if defined (__stub_getdomainname) || defined (__stub___getdomainname)
> getdomainname_will_always_fail_with_ENOSYS();
> #else
> getdomainname();
> #endif
> #if defined (__stub__sleep) || defined (__stub____sleep)
> _sleep_will_always_fail_with_ENOSYS();
> #else
> _sleep();
> #endif
> #if defined (__stub_snprintf) || defined (__stub___snprintf)
> #else
> snprintf();
> #endif
> #if defined (__stub_realpath) || defined (__stub___realpath)
> realpath_will_always_fail_with_ENOSYS();
> #else
> realpath();
> #endif
> #if defined (__stub_dlsym) || defined (__stub___dlsym)
> dlsym_will_always_fail_with_ENOSYS();
> #else
> dlsym();
> #endif
> #if defined (__stub_bzero) || defined (__stub___bzero)
> bzero_will_always_fail_with_ENOSYS();
> #else
> bzero();
> #endif
> #if defined (__stub__getcwd) || defined (__stub____getcwd)
> _getcwd_will_always_fail_with_ENOSYS();
> #else
> _getcwd();
> #endif
> #if defined (__stub_getwd) || defined (__stub___getwd)
> getwd_will_always_fail_with_ENOSYS();
> #else
> getwd();
> #endif
> #if defined (__stub_uname) || defined (__stub___uname)
> uname_will_always_fail_with_ENOSYS();
> #else
> uname();
> #endif
> #if defined (__stub__lseek) || defined (__stub____lseek)
> _lseek_will_always_fail_with_ENOSYS();
> #else
> _lseek();
> #endif
> #if defined (__stub_sleep) || defined (__stub___sleep)
> #else
> sleep();
> #endif
> #if defined (__stub__access) || defined (__stub____access)
> _access_will_always_fail_with_ENOSYS();
> #else
> _access();
> #endif
> #if defined (__stub_lseek) || defined (__stub___lseek)
> #else
> lseek();
> #endif
> #if defined (__stub_usleep) || defined (__stub___usleep)
> usleep_will_always_fail_with_ENOSYS();
> #else
> usleep();
> #endif
> #if defined (__stub_dlclose) || defined (__stub___dlclose)
> dlclose_will_always_fail_with_ENOSYS();
> #else
> dlclose();
> #endif
> #if defined (__stub_gethostname) || defined (__stub___gethostname)
> gethostname_will_always_fail_with_ENOSYS();
> #else
> gethostname();
> #endif
> #if defined (__stub_clock) || defined (__stub___clock)
> clock_will_always_fail_with_ENOSYS();
> #else
> clock();
> #endif
> #if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
> get_nprocs_will_always_fail_with_ENOSYS();
> #else
> get_nprocs();
> #endif
> #if defined (__stub_access) || defined (__stub___access)
> #else
> access();
> #endif
> #if defined (__stub__snprintf) || defined (__stub____snprintf)
> _snprintf_will_always_fail_with_ENOSYS();
> #else
> _snprintf();
> #endif
> #if defined (__stub_dlerror) || defined (__stub___dlerror)
> dlerror_will_always_fail_with_ENOSYS();
> #else
> dlerror();
> #endif
> #if defined (__stub_mkstemp) || defined (__stub___mkstemp)
> mkstemp_will_always_fail_with_ENOSYS();
> #else
> mkstemp();
> #endif
> #if defined (__stub_fork) || defined (__stub___fork)
> fork_will_always_fail_with_ENOSYS();
> #else
> fork();
> #endif
> #if defined (__stub_getpagesize) || defined (__stub___getpagesize)
> getpagesize_will_always_fail_with_ENOSYS();
> #else
> getpagesize();
> #endif
> #if defined (__stub_sbreak) || defined (__stub___sbreak)
> sbreak_will_always_fail_with_ENOSYS();
> #else
> sbreak();
> #endif
> #if defined (__stub_memalign) || defined (__stub___memalign)
> memalign_will_always_fail_with_ENOSYS();
> #else
> memalign();
> #endif
> #if defined (__stub_sigset) || defined (__stub___sigset)
> sigset_will_always_fail_with_ENOSYS();
> #else
> sigset();
> #endif
> #if defined (__stub_getcwd) || defined (__stub___getcwd)
> #else
> getcwd();
> #endif
> #if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
> gethostbyname_will_always_fail_with_ENOSYS();
> #else
> gethostbyname();
> #endif
> #if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
> gettimeofday_will_always_fail_with_ENOSYS();
> #else
> gettimeofday();
> #endif
> #if defined (__stub_readlink) || defined (__stub___readlink)
> readlink_will_always_fail_with_ENOSYS();
> #else
> readlink();
> #endif
> #if defined (__stub__set_output_format) || defined (__stub____set_output_format)
> _set_output_format_will_always_fail_with_ENOSYS();
> #else
> #endif
> #if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
> PXFGETARG_will_always_fail_with_ENOSYS();
> #else
> PXFGETARG();
> #endif
> #if defined (__stub_sigaction) || defined (__stub___sigaction)
> sigaction_will_always_fail_with_ENOSYS();
> #else
> sigaction();
> #endif
> #if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
> strcasecmp_will_always_fail_with_ENOSYS();
> #else
> strcasecmp();
> #endif
> #if defined (__stub_dlopen) || defined (__stub___dlopen)
> dlopen_will_always_fail_with_ENOSYS();
> #else
> dlopen();
> #endif
> #if defined (__stub_drand48) || defined (__stub___drand48)
> drand48_will_always_fail_with_ENOSYS();
> #else
> drand48();
> #endif
> #if defined (__stub_socket) || defined (__stub___socket)
> socket_will_always_fail_with_ENOSYS();
> #else
> socket();
> #endif
> #if defined (__stub_memmove) || defined (__stub___memmove)
> memmove_will_always_fail_with_ENOSYS();
> #else
> memmove();
> #endif
> #if defined (__stub_signal) || defined (__stub___signal)
> signal_will_always_fail_with_ENOSYS();
> #else
> signal();
> #endif
> #if defined (__stub_popen) || defined (__stub___popen)
> popen_will_always_fail_with_ENOSYS();
> #else
> popen();
> #endif
> #if defined (__stub_getrusage) || defined (__stub___getrusage)
> getrusage_will_always_fail_with_ENOSYS();
> #else
> getrusage();
> #endif
> #if defined (__stub_times) || defined (__stub___times)
> times_will_always_fail_with_ENOSYS();
> #else
> times();
> #endif
> #if defined (__stub__mkdir) || defined (__stub____mkdir)
> _mkdir_will_always_fail_with_ENOSYS();
> #else
> _mkdir();
> #endif
> #if defined (__stub_time) || defined (__stub___time)
> time_will_always_fail_with_ENOSYS();
> #else
> time();
> #endif
> #if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
> sysctlbyname_will_always_fail_with_ENOSYS();
> #else
> sysctlbyname();
> #endif
> #if defined (__stub_stricmp) || defined (__stub___stricmp)
> stricmp_will_always_fail_with_ENOSYS();
> #else
> stricmp();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:287: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> /tmp/petsc-uoFdrH/config.functions/conftest.c:119: warning: the `getwd' function is dangerous and should not be used.
> /tmp/petsc-uoFdrH/config.functions/conftest.c:245: warning: Using 'gethostbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> conftest.c:(.text+0x1e): undefined reference to `_sleep'
> conftest.c:(.text+0x50): undefined reference to `_getcwd'
> conftest.c:(.text+0x6e): undefined reference to `_lseek'
> conftest.c:(.text+0x82): undefined reference to `_access'
> conftest.c:(.text+0xd2): undefined reference to `_snprintf'
> conftest.c:(.text+0x104): undefined reference to `sbreak'
> conftest.c:(.text+0x14a): undefined reference to `_set_output_format'
> conftest.c:(.text+0x154): undefined reference to `PXFGETARG'
> conftest.c:(.text+0x1c2): undefined reference to `_mkdir'
> conftest.c:(.text+0x1d6): undefined reference to `sysctlbyname'
> conftest.c:(.text+0x1e0): undefined reference to `stricmp'
> Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:17:6: warning: conflicting types for built-in function 'bzero'
> char bzero();
> /tmp/petsc-uoFdrH/config.functions/conftest.c:26:6: warning: conflicting types for built-in function 'fork'
> char fork();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char rand();
> char realpath();
> char dlsym();
> char bzero();
> char uname();
> char usleep();
> char dlclose();
> char gethostname();
> char clock();
> char get_nprocs();
> char dlerror();
> char mkstemp();
> char fork();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> rand();
> #endif
> #else
> getdomainname();
> #endif
> #else
> realpath();
> #endif
> #else
> dlsym();
> #endif
> #else
> bzero();
> #endif
> #else
> uname();
> #endif
> #else
> usleep();
> #endif
> #else
> dlclose();
> #endif
> #else
> gethostname();
> #endif
> #else
> clock();
> #endif
> #else
> get_nprocs();
> #endif
> #else
> dlerror();
> #endif
> #else
> mkstemp();
> #endif
> #else
> fork();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_RAND" to "1"
> Defined "HAVE_GETDOMAINNAME" to "1"
> Defined "HAVE_REALPATH" to "1"
> Defined "HAVE_DLSYM" to "1"
> Defined "HAVE_BZERO" to "1"
> Defined "HAVE_UNAME" to "1"
> Defined "HAVE_USLEEP" to "1"
> Defined "HAVE_DLCLOSE" to "1"
> Defined "HAVE_GETHOSTNAME" to "1"
> Defined "HAVE_CLOCK" to "1"
> Defined "HAVE_GET_NPROCS" to "1"
> Defined "HAVE_DLERROR" to "1"
> Defined "HAVE_MKSTEMP" to "1"
> Defined "HAVE_FORK" to "1"
> Checking for functions [getpagesize memalign sigset gettimeofday readlink sigaction strcasecmp drand48 socket memmove signal popen getrusage times]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:19:6: warning: conflicting types for built-in function 'strcasecmp'
> char strcasecmp();
> /tmp/petsc-uoFdrH/config.functions/conftest.c:22:6: warning: conflicting types for built-in function 'memmove'
> char memmove();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char getpagesize();
> char memalign();
> char sigset();
> char readlink();
> char sigaction();
> char strcasecmp();
> char drand48();
> char socket();
> char memmove();
> char signal();
> char popen();
> char getrusage();
> char times();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> getpagesize();
> #endif
> #else
> memalign();
> #endif
> #else
> sigset();
> #endif
> #else
> gettimeofday();
> #endif
> #else
> readlink();
> #endif
> #else
> sigaction();
> #endif
> #else
> strcasecmp();
> #endif
> #else
> drand48();
> #endif
> #else
> socket();
> #endif
> #else
> memmove();
> #endif
> #else
> signal();
> #endif
> #else
> popen();
> #endif
> #else
> getrusage();
> #endif
> #else
> times();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_GETPAGESIZE" to "1"
> Defined "HAVE_MEMALIGN" to "1"
> Defined "HAVE_SIGSET" to "1"
> Defined "HAVE_GETTIMEOFDAY" to "1"
> Defined "HAVE_READLINK" to "1"
> Defined "HAVE_SIGACTION" to "1"
> Defined "HAVE_STRCASECMP" to "1"
> Defined "HAVE_DRAND48" to "1"
> Defined "HAVE_SOCKET" to "1"
> Defined "HAVE_MEMMOVE" to "1"
> Defined "HAVE_SIGNAL" to "1"
> Defined "HAVE_POPEN" to "1"
> Defined "HAVE_GETRUSAGE" to "1"
> Defined "HAVE_TIMES" to "1"
> Checking for functions [_sleep]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char _sleep();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> _sleep();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_sleep'
> Checking for functions [snprintf]
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:13:6: warning: conflicting types for built-in function 'snprintf'
> char snprintf();
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char snprintf();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> snprintf();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_SNPRINTF" to "1"
> Checking for functions [_getcwd]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char _getcwd();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> _getcwd();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_getcwd'
> Checking for functions [getwd]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char getwd();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> getwd();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: warning: the `getwd' function is dangerous and should not be used.
> Defined "HAVE_GETWD" to "1"
> Checking for functions [_lseek]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char _lseek();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> _lseek();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_lseek'
> Checking for functions [sleep]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char sleep();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> sleep();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_SLEEP" to "1"
> Checking for functions [_access]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char _access();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> _access();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_access'
> Checking for functions [lseek]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char lseek();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> lseek();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_LSEEK" to "1"
> Checking for functions [access]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char access();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> access();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_ACCESS" to "1"
> Checking for functions [_snprintf]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char _snprintf();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> _snprintf();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_snprintf'
> Checking for functions [sbreak]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char sbreak();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> sbreak();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `sbreak'
> Checking for functions [getcwd]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char getcwd();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> getcwd();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_GETCWD" to "1"
> Checking for functions [gethostbyname]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> gethostbyname();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: warning: Using 'gethostbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Defined "HAVE_GETHOSTBYNAME" to "1"
> Checking for functions [_set_output_format]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_set_output_format'
> Checking for functions [PXFGETARG]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char PXFGETARG();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> PXFGETARG();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `PXFGETARG'
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char dlopen();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> dlopen();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Defined "HAVE_DLOPEN" to "1"
> Checking for functions [_mkdir]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char _mkdir();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> _mkdir();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `_mkdir'
> Checking for functions [time]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char time();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> time();
> #endif
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_TIME" to "1"
> Checking for functions [sysctlbyname]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> sysctlbyname();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `sysctlbyname'
> Checking for functions [stricmp]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char stricmp();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> stricmp();
> #endif
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `stricmp'
> TEST configureMemorySize from config.utilities.getResidentSetSize(/home/zampins/src/petsc/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
> TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
> Try to determine how to measure the memory usage
> TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/home/zampins/src/petsc/config/BuildSystem/config/utilities/featureTestMacros.py:13)
> TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
> Checks if certain feature test macros are support
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.utilities.featureTestMacros
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.utilities.featureTestMacros/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -g -O0 /tmp/petsc-uoFdrH/config.utilities.featureTestMacros/conftest.c
> stderr:
> /tmp/petsc-uoFdrH/config.utilities.featureTestMacros/conftest.c:4:20: fatal error: sysctl.h: No such file or directory
> Source:
> #define _POSIX_C_SOURCE 200112L
> #include <sysctl.h>
> int main() {
> return 0;
> Successful compile:
> Source:
> #define _BSD_SOURCE
> #include<stdlib.h>
> int main() {
> return 0;
> Defined "_BSD_SOURCE" to "1"
> Successful compile:
> Source:
> #define _DEFAULT_SOURCE
> #include<stdlib.h>
> int main() {
> return 0;
> Defined "_DEFAULT_SOURCE" to "1"
> Successful compile:
> Source:
> #define _GNU_SOURCE
> #include <sched.h>
> int main() {
> cpu_set_t mset;
> CPU_ZERO(&mset);;
> return 0;
> Defined "_GNU_SOURCE" to "1"
> TEST configureMissingDefines from config.utilities.missing(/home/zampins/src/petsc/config/BuildSystem/config/utilities/missing.py:57)
> TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
> Checks for limits
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.utilities.missing
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.utilities.missing/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -g -O0 /tmp/petsc-uoFdrH/config.utilities.missing/conftest.c
> Successful compile:
> Source:
> #ifdef PETSC_HAVE_LIMITS_H
> #include <limits.h>
> #endif
> int main() {
> int i=INT_MAX;
> if (i);
> return 0;
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.utilities.missing/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.utilities.missing -g -O0 /tmp/petsc-uoFdrH/config.utilities.missing/conftest.c
> Successful compile:
> Source:
> #ifdef PETSC_HAVE_FLOAT_H
> #include <float.h>
> #endif
> int main() {
> double d=DBL_MAX;
> if (d);
> return 0;
> TEST configureMissingUtypeTypedefs from config.utilities.missing(/home/zampins/src/petsc/config/BuildSystem/config/utilities/missing.py:67)
> TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:67)
> Checks if u_short is undefined
> Successful compile:
> Source:
> #include <sys/types.h>
> int main() {
> u_short foo;
> return 0;
> TEST configureMissingFunctions from config.utilities.missing(/home/zampins/src/petsc/config/BuildSystem/config/utilities/missing.py:73)
> TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:73)
> Checks for SOCKETS
> TEST configureMissingSignals from config.utilities.missing(/home/zampins/src/petsc/config/BuildSystem/config/utilities/missing.py:93)
> TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:93)
> Check for missing signals, and define MISSING_<signal name> if necessary
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> #include <signal.h>
> int main() {
> int i=SIGABRT;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGALRM;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGBUS;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGCHLD;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGCONT;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGFPE;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGHUP;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGILL;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGINT;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGKILL;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGPIPE;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGQUIT;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGSEGV;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGSTOP;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGSYS;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGTERM;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGTRAP;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGTSTP;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGURG;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGUSR1;
> if (i);
> return 0;
> Successful compile:
> Source:
> #include <signal.h>
> int main() {
> int i=SIGUSR2;
> if (i);
> return 0;
> TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/home/zampins/src/petsc/config/BuildSystem/config/utilities/missing.py:110)
> TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:110)
> Successful compile:
> Source:
> #if !defined(_BSD_SOURCE)
> #define _BSD_SOURCE
> #endif
> #if !defined(_DEFAULT_SOURCE)
> #endif
> #if !defined(_GNU_SOURCE)
> #define _GNU_SOURCE
> #endif
> #ifdef PETSC_HAVE_UNISTD_H
> #include <unistd.h>
> #endif
> #ifdef PETSC_HAVE_NETDB_H
> #include <netdb.h>
> #endif
> int main() {
> int (*getdomainname_ptr)(char*,size_t) = getdomainname;
> char test[10];
> if (getdomainname_ptr(test,10)) return 1;
> return 0;
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.utilities.missing/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -g -O0 /tmp/petsc-uoFdrH/config.utilities.missing/conftest.cc
> Successful compile:
> Source:
> #define _BSD_SOURCE
> #endif
> #endif
> #define _GNU_SOURCE
> #endif
> #include <unistd.h>
> #endif
> #include <netdb.h>
> #endif
> int main() {
> char test[10];
> return 0;
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.utilities.missing/conftest -g -O0 /tmp/petsc-uoFdrH/config.utilities.missing/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> TEST configureMissingSrandPrototype from config.utilities.missing(/home/zampins/src/petsc/config/BuildSystem/config/utilities/missing.py:135)
> TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:135)
> Successful compile:
> Source:
> #define _BSD_SOURCE
> #endif
> #endif
> #define _GNU_SOURCE
> #endif
> #ifdef PETSC_HAVE_STDLIB_H
> #include <stdlib.h>
> #endif
> int main() {
> double (*drand48_ptr)(void) = drand48;
> void (*srand48_ptr)(long int) = srand48;
> long int seed=10;
> srand48_ptr(seed);
> if (drand48_ptr() > 0.5) return 1;
> return 0;
> Successful compile:
> Source:
> #define _BSD_SOURCE
> #endif
> #endif
> #define _GNU_SOURCE
> #endif
> #include <stdlib.h>
> #endif
> int main() {
> long int seed=10;
> srand48_ptr(seed);
> return 0;
> TEST configureFPTrap from config.utilities.FPTrap(/home/zampins/src/petsc/config/BuildSystem/config/utilities/FPTrap.py:27)
> TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
> Checking the handling of floating point traps
> Checking for header: sigfpe.h
> stdout:
> # 1 "<built-in>"
> # 1 "<command-line>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
> Source:
> #include <sigfpe.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:20: fatal error: sigfpe.h: No such file or directorycompilation terminated.:
> Checking for header: fpxcp.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
> Source:
> #include <fpxcp.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:19: fatal error: fpxcp.h: No such file or directorycompilation terminated.:
> Checking for header: floatingpoint.h
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
> Source:
> #include <floatingpoint.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:27: fatal error: floatingpoint.h: No such file or directorycompilation terminated.:
> TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/home/zampins/src/petsc/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
> TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
> Check for the mechanism to retrieve command line arguments in Fortran
> Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
> Pushing language FC
> Checking for functions [] in library [''] []
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.F90
> Successful compile:
> Source:
> program main
> integer i
> character*(80) arg
> i = command_argument_count()
> call get_command_argument(i,arg)
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language FC
> Popping language FC
> Pushing language C
> Defined "HAVE_GETARG" to "1"
> Defined "HAVE_BGL_IARGC" to "1"
> Popping language C
> Checking for functions [get_command_argument_] in library [''] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> char get_command_argument_();
> static void _check_get_command_argument_() { get_command_argument_(); }
> int main() {
> _check_get_command_argument_();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_get_command_argument_':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `get_command_argument_'
> Popping language C
> Checking for functions [getarg_] in library [''] []
> Pushing language C
> Successful compile:
> Source:
> char getarg_();
> static void _check_getarg_() { getarg_(); }
> int main() {
> _check_getarg_();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> Pushing language C
> Popping language C
> Pushing language C
> Popping language C
> Pushing language C
> Popping language C
> Pushing language C
> Popping language C
> Checking for functions [ipxfargc_]
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.functions/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.functions/conftest.c
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char ipxfargc_();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
> ipxfargc__will_always_fail_with_ENOSYS();
> #else
> ipxfargc_();
> #endif
> return 0;
> stderr:
> /opt/intel/composer_xe_2015.1.133/compiler/lib/intel64//libifport.a(ipxfargc.o): In function `ipxfargc_':
> /export/users/nbtester/efi2linux_nightly/branch-15_0/20141024_000000/libdev/libifport/posix/ipxfargc.c:(.text+0x5): undefined reference to `for_nargs'
> Checking for functions [f90_unix_MP_iargc]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char f90_unix_MP_iargc();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
> f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
> #else
> #endif
> return 0;
> stderr:
> /tmp/petsc-uoFdrH/config.functions/conftest.c:24: undefined reference to `f90_unix_MP_iargc'
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char PXFGETARG();
> #ifdef __cplusplus
> #endif
> int main() {
> #else
> PXFGETARG();
> #endif
> return 0;
> stderr:
> Checking for functions [iargc_]
> Successful compile:
> Source:
> #include <assert.h>
> #ifdef __cplusplus
> extern "C" {
> #endif
> char iargc_();
> #ifdef __cplusplus
> #endif
> int main() {
> #if defined (__stub_iargc_) || defined (__stub___iargc_)
> iargc__will_always_fail_with_ENOSYS();
> #else
> iargc_();
> #endif
> return 0;
> Defined "HAVE_IARGC_" to "1"
> TEST configureScalarType from PETSc.options.scalarTypes(/home/zampins/src/petsc/config/PETSc/options/scalarTypes.py:37)
> TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:37)
> Choose between real and complex numbers
> Defined "USE_SCALAR_REAL" to "1"
> Scalar type is real
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH/PETSc.options.scalarTypes
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -g -O0 /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.c
> Successful compile:
> Source:
> #include <math.h>
> int main() {
> double b = 2.0; int a = isnormal(b);
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest -g -O0 /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_ISNORMAL" to "1"
> Successful compile:
> Source:
> #include <math.h>
> int main() {
> double b = 2.0; int a = isnan(b);
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_ISNAN" to "1"
> Successful compile:
> Source:
> #include <math.h>
> int main() {
> double b = 2.0; int a = isinf(b);
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_ISINF" to "1"
> Possible ERROR while running compiler:
> stderr:
> /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.c: In function 'main':
> /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.c:6:24: warning: implicit declaration of function '_isnan' [-Wimplicit-function-declaration]
> double b = 2.0;int a = _isnan(b);
> Source:
> #include <float.h>
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Possible ERROR while running linker: exit code 256
> stderr:
> /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.o: In function `main':
> /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_isnan'
> collect2: error: ld returned 1 exit status
> stderr:
> /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.c:6:24: warning: implicit declaration of function '_finite' [-Wimplicit-function-declaration]
> double b = 2.0;int a = _finite(b);
> Source:
> #include <float.h>
> int main() {
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/PETSc.options.scalarTypes/conftest.c:6: undefined reference to `_finite'
> Popping language C
> TEST configurePrecision from PETSc.options.scalarTypes(/home/zampins/src/petsc/config/PETSc/options/scalarTypes.py:77)
> TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:77)
> Set the default real number precision for PETSc objects
> Defined "USE_REAL_DOUBLE" to "1"
> Defined make macro "PETSC_SCALAR_SIZE" to "64"
> Precision is double
> TEST configureMkdir from config.programs(/home/zampins/src/petsc/config/BuildSystem/config/programs.py:23)
> TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:23)
> Make sure we can have mkdir automatically make intermediate directories
> Checking for program /home/zampins/local/fenics-tools/bin/mkdir...not found
> Checking for program /home/zampins/local/bin/mkdir...not found
> Checking for program /home/zampins/local/anaconda/bin/mkdir...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/mkdir...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/mkdir...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/mkdir...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/mkdir...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/mkdir...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/mkdir...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/mkdir...not found
> Checking for program /opt/gcc/5.1.0/bin/mkdir...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/mkdir...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/mkdir...not found
> Checking for program /opt/slurm/default/bin/mkdir...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/mkdir...not found
> Checking for program /opt/cray/craype/2.4.2/bin/mkdir...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/mkdir...not found
> Checking for program /opt/modules/3.2.10.5/bin/mkdir...not found
> Checking for program /home/zampins/bin/mkdir...not found
> Checking for program /usr/local/bin/mkdir...not found
> Checking for program /usr/bin/mkdir...not found
> Checking for program /bin/mkdir...found
> Executing: /bin/mkdir -p .conftest/tmp
> Adding -p flag to /bin/mkdir -p to automatically create directories
> Defined make macro "MKDIR" to "/bin/mkdir -p"
> TEST configureAutoreconf from config.programs(/home/zampins/src/petsc/config/BuildSystem/config/programs.py:45)
> TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:45)
> Check for autoreconf
> Checking for program /home/zampins/local/fenics-tools/bin/autoreconf...not found
> Checking for program /home/zampins/local/bin/autoreconf...not found
> Checking for program /home/zampins/local/anaconda/bin/autoreconf...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/autoreconf...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/autoreconf...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/autoreconf...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/autoreconf...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/autoreconf...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/autoreconf...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/autoreconf...not found
> Checking for program /opt/gcc/5.1.0/bin/autoreconf...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/autoreconf...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/autoreconf...not found
> Checking for program /opt/slurm/default/bin/autoreconf...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/autoreconf...not found
> Checking for program /opt/cray/craype/2.4.2/bin/autoreconf...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/autoreconf...not found
> Checking for program /opt/modules/3.2.10.5/bin/autoreconf...not found
> Checking for program /home/zampins/bin/autoreconf...not found
> Checking for program /usr/local/bin/autoreconf...not found
> Checking for program /usr/bin/autoreconf...found
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.programs
> Executing: cd /tmp/petsc-uoFdrH/config.programs/autoconfdir&&/usr/bin/autoreconf
> autoreconf test successful!
> Checking for program /home/zampins/local/fenics-tools/bin/libtoolize...not found
> Checking for program /home/zampins/local/bin/libtoolize...not found
> Checking for program /home/zampins/local/anaconda/bin/libtoolize...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/libtoolize...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/libtoolize...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/libtoolize...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/libtoolize...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/libtoolize...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/libtoolize...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/libtoolize...not found
> Checking for program /opt/gcc/5.1.0/bin/libtoolize...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/libtoolize...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/libtoolize...not found
> Checking for program /opt/slurm/default/bin/libtoolize...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/libtoolize...not found
> Checking for program /opt/cray/craype/2.4.2/bin/libtoolize...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/libtoolize...not found
> Checking for program /opt/modules/3.2.10.5/bin/libtoolize...not found
> Checking for program /home/zampins/bin/libtoolize...not found
> Checking for program /usr/local/bin/libtoolize...not found
> Checking for program /usr/bin/libtoolize...found
> TEST configurePrograms from config.programs(/home/zampins/src/petsc/config/BuildSystem/config/programs.py:72)
> TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:72)
> Check for the programs needed to build and run PETSc
> Checking for program /home/zampins/local/fenics-tools/bin/sh...not found
> Checking for program /home/zampins/local/bin/sh...not found
> Checking for program /home/zampins/local/anaconda/bin/sh...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/sh...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/sh...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/sh...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/sh...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/sh...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/sh...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/sh...not found
> Checking for program /opt/gcc/5.1.0/bin/sh...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/sh...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/sh...not found
> Checking for program /opt/slurm/default/bin/sh...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/sh...not found
> Checking for program /opt/cray/craype/2.4.2/bin/sh...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/sh...not found
> Checking for program /opt/modules/3.2.10.5/bin/sh...not found
> Checking for program /home/zampins/bin/sh...not found
> Checking for program /usr/local/bin/sh...not found
> Checking for program /usr/bin/sh...found
> Defined make macro "SHELL" to "/usr/bin/sh"
> Checking for program /home/zampins/local/fenics-tools/bin/sed...not found
> Checking for program /home/zampins/local/bin/sed...not found
> Checking for program /home/zampins/local/anaconda/bin/sed...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/sed...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/sed...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/sed...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/sed...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/sed...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/sed...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/sed...not found
> Checking for program /opt/gcc/5.1.0/bin/sed...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/sed...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/sed...not found
> Checking for program /opt/slurm/default/bin/sed...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/sed...not found
> Checking for program /opt/cray/craype/2.4.2/bin/sed...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/sed...not found
> Checking for program /opt/modules/3.2.10.5/bin/sed...not found
> Checking for program /home/zampins/bin/sed...not found
> Checking for program /usr/local/bin/sed...not found
> Checking for program /usr/bin/sed...found
> Defined make macro "SED" to "/usr/bin/sed"
> Executing: /usr/bin/sed -i s/sed/sd/g "/tmp/petsc-uoFdrH/config.programs/sed1"
> Adding SEDINPLACE cmd: /usr/bin/sed -i
> Defined make macro "SEDINPLACE" to "/usr/bin/sed -i"
> Checking for program /home/zampins/local/fenics-tools/bin/mv...not found
> Checking for program /home/zampins/local/bin/mv...not found
> Checking for program /home/zampins/local/anaconda/bin/mv...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/mv...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/mv...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/mv...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/mv...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/mv...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/mv...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/mv...not found
> Checking for program /opt/gcc/5.1.0/bin/mv...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/mv...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/mv...not found
> Checking for program /opt/slurm/default/bin/mv...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/mv...not found
> Checking for program /opt/cray/craype/2.4.2/bin/mv...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/mv...not found
> Checking for program /opt/modules/3.2.10.5/bin/mv...not found
> Checking for program /home/zampins/bin/mv...not found
> Checking for program /usr/local/bin/mv...not found
> Checking for program /usr/bin/mv...not found
> Checking for program /bin/mv...found
> Defined make macro "MV" to "/bin/mv"
> Checking for program /home/zampins/local/fenics-tools/bin/cp...not found
> Checking for program /home/zampins/local/bin/cp...not found
> Checking for program /home/zampins/local/anaconda/bin/cp...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/cp...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/cp...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/cp...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/cp...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/cp...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/cp...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/cp...not found
> Checking for program /opt/gcc/5.1.0/bin/cp...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/cp...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/cp...not found
> Checking for program /opt/slurm/default/bin/cp...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/cp...not found
> Checking for program /opt/cray/craype/2.4.2/bin/cp...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/cp...not found
> Checking for program /opt/modules/3.2.10.5/bin/cp...not found
> Checking for program /home/zampins/bin/cp...not found
> Checking for program /usr/local/bin/cp...not found
> Checking for program /usr/bin/cp...not found
> Checking for program /bin/cp...found
> Defined make macro "CP" to "/bin/cp"
> Checking for program /home/zampins/local/fenics-tools/bin/grep...not found
> Checking for program /home/zampins/local/bin/grep...not found
> Checking for program /home/zampins/local/anaconda/bin/grep...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/grep...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/grep...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/grep...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/grep...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/grep...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/grep...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/grep...not found
> Checking for program /opt/gcc/5.1.0/bin/grep...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/grep...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/grep...not found
> Checking for program /opt/slurm/default/bin/grep...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/grep...not found
> Checking for program /opt/cray/craype/2.4.2/bin/grep...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/grep...not found
> Checking for program /opt/modules/3.2.10.5/bin/grep...not found
> Checking for program /home/zampins/bin/grep...not found
> Checking for program /usr/local/bin/grep...not found
> Checking for program /usr/bin/grep...found
> Defined make macro "GREP" to "/usr/bin/grep"
> Checking for program /home/zampins/local/fenics-tools/bin/rm...not found
> Checking for program /home/zampins/local/bin/rm...not found
> Checking for program /home/zampins/local/anaconda/bin/rm...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/rm...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/rm...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/rm...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/rm...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/rm...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/rm...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/rm...not found
> Checking for program /opt/gcc/5.1.0/bin/rm...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/rm...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/rm...not found
> Checking for program /opt/slurm/default/bin/rm...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/rm...not found
> Checking for program /opt/cray/craype/2.4.2/bin/rm...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/rm...not found
> Checking for program /opt/modules/3.2.10.5/bin/rm...not found
> Checking for program /home/zampins/bin/rm...not found
> Checking for program /usr/local/bin/rm...not found
> Checking for program /usr/bin/rm...not found
> Checking for program /bin/rm...found
> Defined make macro "RM" to "/bin/rm -f"
> Checking for program /home/zampins/local/fenics-tools/bin/diff...not found
> Checking for program /home/zampins/local/bin/diff...not found
> Checking for program /home/zampins/local/anaconda/bin/diff...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/diff...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/diff...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/diff...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/diff...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/diff...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/diff...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/diff...not found
> Checking for program /opt/gcc/5.1.0/bin/diff...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/diff...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/diff...not found
> Checking for program /opt/slurm/default/bin/diff...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/diff...not found
> Checking for program /opt/cray/craype/2.4.2/bin/diff...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/diff...not found
> Checking for program /opt/modules/3.2.10.5/bin/diff...not found
> Checking for program /home/zampins/bin/diff...not found
> Checking for program /usr/local/bin/diff...not found
> Checking for program /usr/bin/diff...found
> Executing: "/usr/bin/diff" -w "/tmp/petsc-uoFdrH/config.programs/diff1" "/tmp/petsc-uoFdrH/config.programs/diff2"
> Defined make macro "DIFF" to "/usr/bin/diff -w"
> Checking for program /usr/ucb/ps...not found
> Checking for program /usr/usb/ps...not found
> Checking for program /home/zampins/ps...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/ps...not found
> Checking for program /home/zampins/local/fenics-tools/bin/gzip...not found
> Checking for program /home/zampins/local/bin/gzip...not found
> Checking for program /home/zampins/local/anaconda/bin/gzip...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/gzip...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/gzip...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/gzip...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/gzip...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/gzip...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/gzip...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/gzip...not found
> Checking for program /opt/gcc/5.1.0/bin/gzip...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/gzip...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/gzip...not found
> Checking for program /opt/slurm/default/bin/gzip...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/gzip...not found
> Checking for program /opt/cray/craype/2.4.2/bin/gzip...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/gzip...not found
> Checking for program /opt/modules/3.2.10.5/bin/gzip...not found
> Checking for program /home/zampins/bin/gzip...not found
> Checking for program /usr/local/bin/gzip...not found
> Checking for program /usr/bin/gzip...found
> Defined make macro "GZIP" to "/usr/bin/gzip"
> Defined "HAVE_GZIP" to "1"
> Defined make macro "PYTHON" to "/home/zampins/local/anaconda/bin/python"
> Checking for program /home/zampins/local/fenics-tools/bin/m4...not found
> Checking for program /home/zampins/local/bin/m4...not found
> Checking for program /home/zampins/local/anaconda/bin/m4...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/m4...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/m4...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/m4...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/m4...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/m4...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/m4...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/m4...not found
> Checking for program /opt/gcc/5.1.0/bin/m4...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/m4...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/m4...not found
> Checking for program /opt/slurm/default/bin/m4...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/m4...not found
> Checking for program /opt/cray/craype/2.4.2/bin/m4...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/m4...not found
> Checking for program /opt/modules/3.2.10.5/bin/m4...not found
> Checking for program /home/zampins/bin/m4...not found
> Checking for program /usr/local/bin/m4...not found
> Checking for program /usr/bin/m4...found
> Defined make macro "M4" to "/usr/bin/m4"
> TEST configureMake from config.packages.make(/home/zampins/src/petsc/config/BuildSystem/config/packages/make.py:82)
> TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:82)
> Check for user specified make - or gmake, make
> Checking for program /home/zampins/local/fenics-tools/bin/gmake...not found
> Checking for program /home/zampins/local/bin/gmake...not found
> Checking for program /home/zampins/local/anaconda/bin/gmake...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/gmake...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/gmake...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/gmake...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/gmake...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/gmake...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/gmake...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/gmake...not found
> Checking for program /opt/gcc/5.1.0/bin/gmake...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/gmake...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/gmake...not found
> Checking for program /opt/slurm/default/bin/gmake...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/gmake...not found
> Checking for program /opt/cray/craype/2.4.2/bin/gmake...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/gmake...not found
> Checking for program /opt/modules/3.2.10.5/bin/gmake...not found
> Checking for program /home/zampins/bin/gmake...not found
> Checking for program /usr/local/bin/gmake...not found
> Checking for program /usr/bin/gmake...found
> Defined make macro "MAKE" to "/usr/bin/gmake"
> Executing: /usr/bin/gmake --version
> stdout:
> GNU Make 3.81
> Copyright (C) 2006 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.
> There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> PARTICULAR PURPOSE.
> This program built for x86_64-unknown-linux-gnu
> TEST configureCheckGNUMake from config.packages.make(/home/zampins/src/petsc/config/BuildSystem/config/packages/make.py:119)
> TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:119)
> Setup other GNU make stuff
> stdout:
> GNU Make 3.81
> PARTICULAR PURPOSE.
> Defined make macro "MAKE_IS_GNUMAKE" to "1"
> Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
> Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
> Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
> Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
> TEST configureMakeNP from config.packages.make(/home/zampins/src/petsc/config/BuildSystem/config/packages/make.py:157)
> TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:157)
> check no of cores on the build machine [perhaps to do make '-j ncores']
> module multiprocessing found 16 cores: using make_np = 13
> Defined make macro "MAKE_NP" to "13"
> Defined make macro "NPMAX" to "16"
> Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/gmake --print-directory"
> Defined make macro "OMAKE" to "/usr/bin/gmake --no-print-directory"
> Defined make macro "MAKE_PAR_OUT_FLG" to ""
> TEST alternateConfigureLibrary from config.packages.OpenMPI(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:796)
> Called if --with-packagename=0; does nothing by default
> Executing: uname -s
> stdout: Linux
> Executing: uname -s
> stdout: Linux
> Executing: /opt/cray/craype/2.4.2/bin/cc -V
> TEST alternateConfigureLibrary from config.packages.MPICH(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:796)
> Pushing language C
> TEST checkDependencies from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.MPI(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:490)
> TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:490)
> Calls the regular package configureLibrary and then does an additional test needed by MPI
> Checking for a functional MPI
> Checking for library in Compiler specific search MPI: []
> TEST check from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:159)
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:159)
> Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
> - libDir may be a list of directories
> - libName may be a list of library names
> Checking for functions [MPI_Init MPI_Comm_create] in library [] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> /* Override any gcc2 internal prototype to avoid an error. */
> char MPI_Init();
> static void _check_MPI_Init() { MPI_Init(); }
> char MPI_Comm_create();
> static void _check_MPI_Comm_create() { MPI_Comm_create(); }
> int main() {
> _check_MPI_Init();
> _check_MPI_Comm_create();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language C
> Checking for headers Compiler specific search MPI: []
> Pushing language C
> TEST checkInclude from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:86)
> TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
> Checks if a particular include file can be found along particular include paths
> Checking for header files ['mpi.h'] in []
> Checking include with compiler flags var CPPFLAGS []
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 1
> # 51 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 1 3 4
> # 9 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 3 4
> # 1 "/usr/include/stdint.h" 1 3 4
> # 26 "/usr/include/stdint.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 27 "/usr/include/stdint.h" 2 3 4
> # 1 "/usr/include/bits/wchar.h" 1 3 4
> # 28 "/usr/include/stdint.h" 2 3 4
> # 29 "/usr/include/stdint.h" 2 3 4
> # 37 "/usr/include/stdint.h" 3 4
> typedef signed char int8_t;
> typedef short int int16_t;
> typedef int int32_t;
> typedef long int int64_t;
> typedef unsigned char uint8_t;
> typedef unsigned short int uint16_t;
> typedef unsigned int uint32_t;
> typedef unsigned long int uint64_t;
> # 66 "/usr/include/stdint.h" 3 4
> typedef signed char int_least8_t;
> typedef short int int_least16_t;
> typedef int int_least32_t;
> typedef long int int_least64_t;
> typedef unsigned char uint_least8_t;
> typedef unsigned short int uint_least16_t;
> typedef unsigned int uint_least32_t;
> typedef unsigned long int uint_least64_t;
> # 91 "/usr/include/stdint.h" 3 4
> typedef signed char int_fast8_t;
> typedef long int int_fast16_t;
> typedef long int int_fast32_t;
> typedef long int int_fast64_t;
> # 104 "/usr/include/stdint.h" 3 4
> typedef unsigned char uint_fast8_t;
> typedef unsigned long int uint_fast16_t;
> typedef unsigned long int uint_fast32_t;
> typedef unsigned long int uint_fast64_t;
> # 120 "/usr/include/stdint.h" 3 4
> typedef long int intptr_t;
> typedef unsigned long int uintptr_t;
> # 135 "/usr/include/stdint.h" 3 4
> typedef long int intmax_t;
> typedef unsigned long int uintmax_t;
> # 10 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 2 3 4
> # 52 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 2
> # 96 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Datatype;
> # 279 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Comm;
> typedef int MPI_Group;
> typedef int MPI_Win;
> typedef struct ADIOI_FileD *MPI_File;
> typedef int MPI_Op;
> # 362 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef enum MPIR_Win_flavor {
> MPI_WIN_FLAVOR_CREATE = 1,
> MPI_WIN_FLAVOR_ALLOCATE = 2,
> MPI_WIN_FLAVOR_DYNAMIC = 3,
> MPI_WIN_FLAVOR_SHARED = 4
> } MPIR_Win_flavor_t;
> typedef enum MPIR_Win_model {
> MPI_WIN_SEPARATE = 1,
> MPI_WIN_UNIFIED = 2
> } MPIR_Win_model_t;
> typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
> extern int * const MPI_UNWEIGHTED;
> extern int * const MPI_WEIGHTS_EMPTY;
> # 394 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
> typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
> void *, int *);
> typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
> typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
> void *, int *);
> typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
> typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
> int *);
> typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
> typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
> typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
> typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
> typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
> typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
> typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
> # 422 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Errhandler;
> # 443 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Request;
> typedef int MPI_Message;
> typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
> typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
> typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
> # 497 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> enum MPIR_Combiner_enum {
> MPI_COMBINER_NAMED = 1,
> MPI_COMBINER_DUP = 2,
> MPI_COMBINER_CONTIGUOUS = 3,
> MPI_COMBINER_VECTOR = 4,
> MPI_COMBINER_HVECTOR_INTEGER = 5,
> MPI_COMBINER_HVECTOR = 6,
> MPI_COMBINER_INDEXED = 7,
> MPI_COMBINER_HINDEXED_INTEGER = 8,
> MPI_COMBINER_HINDEXED = 9,
> MPI_COMBINER_INDEXED_BLOCK = 10,
> MPI_COMBINER_STRUCT_INTEGER = 11,
> MPI_COMBINER_STRUCT = 12,
> MPI_COMBINER_SUBARRAY = 13,
> MPI_COMBINER_DARRAY = 14,
> MPI_COMBINER_F90_REAL = 15,
> MPI_COMBINER_F90_COMPLEX = 16,
> MPI_COMBINER_F90_INTEGER = 17,
> MPI_COMBINER_RESIZED = 18,
> MPI_COMBINER_HINDEXED_BLOCK = 19
> typedef int MPI_Info;
> # 547 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef long MPI_Aint;
> typedef int MPI_Fint;
> typedef long long MPI_Count;
> # 566 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef long long MPI_Offset;
> typedef struct MPI_Status {
> int count_lo;
> int count_hi_and_cancelled;
> int MPI_SOURCE;
> int MPI_TAG;
> int MPI_ERROR;
> } MPI_Status;
> struct MPIR_T_enum_s;
> struct MPIR_T_cvar_handle_s;
> struct MPIR_T_pvar_handle_s;
> struct MPIR_T_pvar_session_s;
> typedef struct MPIR_T_enum_s * MPI_T_enum;
> typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
> typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
> typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
> extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
> # 603 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef enum MPIR_T_verbosity_t {
> MPIX_T_VERBOSITY_INVALID = 0,
> MPI_T_VERBOSITY_USER_BASIC = 221,
> MPI_T_VERBOSITY_USER_DETAIL,
> MPI_T_VERBOSITY_USER_ALL,
> MPI_T_VERBOSITY_TUNER_BASIC,
> MPI_T_VERBOSITY_TUNER_DETAIL,
> MPI_T_VERBOSITY_TUNER_ALL,
> MPI_T_VERBOSITY_MPIDEV_BASIC,
> MPI_T_VERBOSITY_MPIDEV_DETAIL,
> MPI_T_VERBOSITY_MPIDEV_ALL
> } MPIR_T_verbosity_t;
> typedef enum MPIR_T_bind_t {
> MPIX_T_BIND_INVALID = 0,
> MPI_T_BIND_NO_OBJECT = 9700,
> MPI_T_BIND_MPI_COMM,
> MPI_T_BIND_MPI_DATATYPE,
> MPI_T_BIND_MPI_ERRHANDLER,
> MPI_T_BIND_MPI_FILE,
> MPI_T_BIND_MPI_GROUP,
> MPI_T_BIND_MPI_OP,
> MPI_T_BIND_MPI_REQUEST,
> MPI_T_BIND_MPI_WIN,
> MPI_T_BIND_MPI_MESSAGE,
> MPI_T_BIND_MPI_INFO
> } MPIR_T_bind_t;
> typedef enum MPIR_T_scope_t {
> MPIX_T_SCOPE_INVALID = 0,
> MPI_T_SCOPE_CONSTANT = 60438,
> MPI_T_SCOPE_READONLY,
> MPI_T_SCOPE_LOCAL,
> MPI_T_SCOPE_GROUP,
> MPI_T_SCOPE_GROUP_EQ,
> MPI_T_SCOPE_ALL,
> MPI_T_SCOPE_ALL_EQ
> } MPIR_T_scope_t;
> typedef enum MPIR_T_pvar_class_t {
> MPIX_T_PVAR_CLASS_INVALID = 0,
> MPIR_T_PVAR_CLASS_FIRST = 240,
> MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
> MPI_T_PVAR_CLASS_LEVEL,
> MPI_T_PVAR_CLASS_SIZE,
> MPI_T_PVAR_CLASS_PERCENTAGE,
> MPI_T_PVAR_CLASS_HIGHWATERMARK,
> MPI_T_PVAR_CLASS_LOWWATERMARK,
> MPI_T_PVAR_CLASS_COUNTER,
> MPI_T_PVAR_CLASS_AGGREGATE,
> MPI_T_PVAR_CLASS_TIMER,
> MPI_T_PVAR_CLASS_GENERIC,
> MPIR_T_PVAR_CLASS_LAST,
> MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
> } MPIR_T_pvar_class_t;
> # 725 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> extern MPI_Fint * MPI_F_STATUS_IGNORE;
> extern MPI_Fint * MPI_F_STATUSES_IGNORE;
> # 740 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef struct {
> MPI_Fint count_lo;
> MPI_Fint count_hi_and_cancelled;
> MPI_Fint MPI_SOURCE;
> MPI_Fint MPI_TAG;
> MPI_Fint MPI_ERROR;
> } MPI_F08_Status;
> extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
> extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
> extern int MPIR_F08_MPI_IN_PLACE;
> extern int MPIR_F08_MPI_BOTTOM;
> extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
> extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
> # 764 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int (MPI_Grequest_cancel_function)(void *, int);
> typedef int (MPI_Grequest_free_function)(void *);
> typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
> typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
> typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
> # 879 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
> void *, MPI_Offset, void *);
> typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
> void *);
> # 899 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> MPI_Comm comm, MPI_Status *status) ;
> int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Buffer_attach(void *buffer, int size);
> int MPI_Buffer_detach(void *buffer_addr, int *size);
> int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm, MPI_Request *request) ;
> int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int MPI_Wait(MPI_Request *request, MPI_Status *status);
> int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
> int MPI_Request_free(MPI_Request *request);
> int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
> int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
> int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
> int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
> int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int array_of_indices[], MPI_Status array_of_statuses[]);
> int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
> int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
> int MPI_Cancel(MPI_Request *request);
> int MPI_Test_cancelled(const MPI_Status *status, int *flag);
> int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int MPI_Start(MPI_Request *request);
> int MPI_Startall(int count, MPI_Request array_of_requests[]);
> int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
> int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
> int source, int recvtag, MPI_Comm comm, MPI_Status *status)
> int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
> int sendtag, int source, int recvtag, MPI_Comm comm,
> int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
> int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int MPI_Type_indexed(int count, const int *array_of_blocklengths,
> const int *array_of_displacements, MPI_Datatype oldtype,
> int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
> const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
> int MPI_Type_struct(int count, const int *array_of_blocklengths,
> const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
> int MPI_Address(const void *location, MPI_Aint *address);
> int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
> int MPI_Type_size(MPI_Datatype datatype, int *size);
> int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
> int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
> int MPI_Type_commit(MPI_Datatype *datatype);
> int MPI_Type_free(MPI_Datatype *datatype);
> int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
> int outsize, int *position, MPI_Comm comm) ;
> int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
> MPI_Datatype datatype, MPI_Comm comm) ;
> int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
> int MPI_Barrier(MPI_Comm comm);
> int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
> int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
> int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
> MPI_Comm comm)
> int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
> MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
> int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
> MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
> const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
> const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
> int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, MPI_Comm comm)
> int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, int root, MPI_Comm comm)
> int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
> int MPI_Op_free(MPI_Op *op);
> int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
> int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> MPI_Comm comm)
> int MPI_Group_size(MPI_Group group, int *size);
> int MPI_Group_rank(MPI_Group group, int *rank);
> int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
> int ranks2[]);
> int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
> int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
> int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int MPI_Group_free(MPI_Group *group);
> int MPI_Comm_size(MPI_Comm comm, int *size);
> int MPI_Comm_rank(MPI_Comm comm, int *rank);
> int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
> int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
> int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
> int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
> int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
> int MPI_Comm_free(MPI_Comm *comm);
> int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
> int MPI_Comm_remote_size(MPI_Comm comm, int *size);
> int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
> int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
> int remote_leader, int tag, MPI_Comm *newintercomm);
> int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
> int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
> int *keyval, void *extra_state);
> int MPI_Keyval_free(int *keyval);
> int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
> int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
> int MPI_Attr_delete(MPI_Comm comm, int keyval);
> int MPI_Topo_test(MPI_Comm comm, int *status);
> int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
> int reorder, MPI_Comm *comm_cart);
> int MPI_Dims_create(int nnodes, int ndims, int dims[]);
> int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
> int reorder, MPI_Comm *comm_graph);
> int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
> int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
> int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
> int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
> int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
> int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
> int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
> int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
> int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
> int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
> int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
> int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
> int MPI_Get_processor_name(char *name, int *resultlen);
> int MPI_Get_version(int *version, int *subversion);
> int MPI_Get_library_version(char *version, int *resultlen);
> int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
> int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
> int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
> int MPI_Errhandler_free(MPI_Errhandler *errhandler);
> int MPI_Error_string(int errorcode, char *string, int *resultlen);
> int MPI_Error_class(int errorcode, int *errorclass);
> double MPI_Wtime(void);
> double MPI_Wtick(void);
> int MPI_Init(int *argc, char ***argv);
> int MPI_Finalize(void);
> int MPI_Initialized(int *flag);
> int MPI_Abort(MPI_Comm comm, int errorcode);
> int MPI_Pcontrol(const int level, ...);
> int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
> void *attribute_val_out, int *flag);
> int MPI_Close_port(const char *port_name);
> int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int MPI_Comm_disconnect(MPI_Comm *comm);
> int MPI_Comm_get_parent(MPI_Comm *parent);
> int MPI_Comm_join(int fd, MPI_Comm *intercomm);
> int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
> MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
> int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
> const int array_of_maxprocs[], const MPI_Info array_of_info[],
> int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
> int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
> int MPI_Open_port(MPI_Info info, char *port_name);
> int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
> int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
> int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
> int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
> int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int target_rank, MPI_Aint target_disp, int target_count,
> MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
> int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> MPI_Datatype target_datatype, MPI_Win win) ;
> int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int MPI_Win_complete(MPI_Win win);
> int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> MPI_Win *win);
> int MPI_Win_fence(int assert, MPI_Win win);
> int MPI_Win_free(MPI_Win *win);
> int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
> int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
> int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
> int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
> int MPI_Win_test(MPI_Win win, int *flag);
> int MPI_Win_unlock(int rank, MPI_Win win);
> int MPI_Win_wait(MPI_Win win);
> int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
> MPI_Win *win);
> int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> void *baseptr, MPI_Win *win);
> int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
> int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
> int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
> int MPI_Win_detach(MPI_Win win, const void *base);
> int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
> int MPI_Win_set_info(MPI_Win win, MPI_Info info);
> int MPI_Get_accumulate(const void *origin_addr, int origin_count,
> MPI_Datatype origin_datatype, void *result_addr, int result_count,
> MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
> int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
> int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
> MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
> int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
> void *result_addr, MPI_Datatype datatype, int target_rank,
> MPI_Aint target_disp, MPI_Win win)
> int MPI_Rput(const void *origin_addr, int origin_count,
> MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
> int target_count, MPI_Datatype target_datatype, MPI_Win win,
> int MPI_Rget(void *origin_addr, int origin_count,
> int MPI_Raccumulate(const void *origin_addr, int origin_count,
> int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
> int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
> int MPI_Win_lock_all(int assert, MPI_Win win);
> int MPI_Win_unlock_all(MPI_Win win);
> int MPI_Win_flush(int rank, MPI_Win win);
> int MPI_Win_flush_all(MPI_Win win);
> int MPI_Win_flush_local(int rank, MPI_Win win);
> int MPI_Win_flush_local_all(MPI_Win win);
> int MPI_Win_sync(MPI_Win win);
> int MPI_Add_error_class(int *errorclass);
> int MPI_Add_error_code(int errorclass, int *errorcode);
> int MPI_Add_error_string(int errorcode, const char *string);
> int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
> int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
> MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
> void *extra_state);
> int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
> int MPI_Comm_free_keyval(int *comm_keyval);
> int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
> int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
> int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
> int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
> int MPI_File_call_errhandler(MPI_File fh, int errorcode);
> int MPI_Grequest_complete(MPI_Request request);
> int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
> MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
> int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
> int MPI_Is_thread_main(int *flag);
> int MPI_Query_thread(int *provided);
> int MPI_Status_set_cancelled(MPI_Status *status, int flag);
> int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
> int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
> MPI_Type_delete_attr_function *type_delete_attr_fn,
> int *type_keyval, void *extra_state);
> int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
> int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_free_keyval(int *type_keyval);
> int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
> int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
> int max_datatypes, int array_of_integers[],
> MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
> int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
> int *num_datatypes, int *combiner);
> int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
> int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
> int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
> int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
> int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
> int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
> MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
> void *extra_state);
> int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
> int MPI_Win_free_keyval(int *win_keyval);
> int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
> int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
> int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
> int MPI_Win_set_name(MPI_Win win, const char *win_name);
> int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
> int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
> int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
> int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
> int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
> int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
> int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
> int MPI_Finalized(int *flag);
> int MPI_Free_mem(void *base);
> int MPI_Get_address(const void *location, MPI_Aint *address);
> int MPI_Info_create(MPI_Info *info);
> int MPI_Info_delete(MPI_Info info, const char *key);
> int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
> int MPI_Info_free(MPI_Info *info);
> int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
> int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
> int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
> int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
> int MPI_Info_set(MPI_Info info, const char *key, const char *value);
> int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
> MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
> int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
> MPI_Aint *size);
> int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
> int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
> int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
> int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
> const int array_of_distribs[], const int array_of_dargs[],
> const int array_of_psizes[], int order, MPI_Datatype oldtype,
> int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
> const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
> int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
> int MPI_Type_create_hindexed_block(int count, int blocklength,
> int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
> int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
> const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
> int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
> const int array_of_subsizes[], const int array_of_starts[],
> int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
> int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
> int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
> MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
> int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
> int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
> int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
> int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
> int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
> int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
> int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
> MPI_Op op)
> int MPI_Op_commutative(MPI_Op op, int *commute);
> int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
> const int sourceweights[], int outdegree,
> const int destinations[], const int destweights[],
> MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
> int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
> const int destinations[], const int weights[], MPI_Info info,
> int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
> int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
> int maxoutdegree, int destinations[], int destweights[]);
> int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
> int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
> int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
> int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
> int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
> int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
> int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
> int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
> int root, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
> const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
> int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
> int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, MPI_Comm comm, MPI_Request *request)
> int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
> int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, const int recvcounts[], const int displs[],
> int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
> int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
> const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
> void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
> const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
> int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
> const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
> int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
> int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
> int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
> int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
> int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
> int MPIX_Comm_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int MPIX_Comm_remote_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int MPIX_Comm_reenable_anysource(MPI_Comm comm, MPI_Group *failed_group);
> int MPI_T_init_thread(int required, int *provided);
> int MPI_T_finalize(void);
> int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
> int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
> int MPI_T_cvar_get_num(int *num_cvar);
> int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
> MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
> int *binding, int *scope);
> int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
> int *count);
> int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
> int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
> int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
> int MPI_T_pvar_get_num(int *num_pvar);
> int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
> int *binding, int *readonly, int *continuous, int *atomic);
> int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
> int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
> int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
> MPI_T_pvar_handle *handle, int *count);
> int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
> int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
> int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int MPI_T_category_get_num(int *num_cat);
> int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
> int *num_cvars, int *num_pvars, int *num_categories);
> int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
> int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
> int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
> int MPI_T_category_changed(int *stamp);
> int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Buffer_attach(void *buffer, int size);
> int PMPI_Buffer_detach(void *buffer_addr, int *size);
> int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Wait(MPI_Request *request, MPI_Status *status);
> int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
> int PMPI_Request_free(MPI_Request *request);
> int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
> int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
> int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
> int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
> int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
> int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
> int PMPI_Cancel(MPI_Request *request);
> int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
> int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Start(MPI_Request *request);
> int PMPI_Startall(int count, MPI_Request array_of_requests[]);
> int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
> int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
> int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
> int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
> int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
> int PMPI_Type_struct(int count, const int *array_of_blocklengths,
> int PMPI_Address(const void *location, MPI_Aint *address);
> int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
> int PMPI_Type_size(MPI_Datatype datatype, int *size);
> int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
> int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
> int PMPI_Type_commit(MPI_Datatype *datatype);
> int PMPI_Type_free(MPI_Datatype *datatype);
> int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
> int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
> int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
> int PMPI_Barrier(MPI_Comm comm);
> int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
> int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> MPI_Comm comm)
> int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
> int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
> int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
> int PMPI_Op_free(MPI_Op *op);
> int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> MPI_Comm comm)
> int PMPI_Group_size(MPI_Group group, int *size);
> int PMPI_Group_rank(MPI_Group group, int *rank);
> int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
> int ranks2[]);
> int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
> int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
> int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int PMPI_Group_free(MPI_Group *group);
> int PMPI_Comm_size(MPI_Comm comm, int *size);
> int PMPI_Comm_rank(MPI_Comm comm, int *rank);
> int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
> int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
> int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
> int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
> int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
> int PMPI_Comm_free(MPI_Comm *comm);
> int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
> int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
> int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
> int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
> int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
> int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
> int PMPI_Keyval_free(int *keyval);
> int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
> int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
> int PMPI_Attr_delete(MPI_Comm comm, int keyval);
> int PMPI_Topo_test(MPI_Comm comm, int *status);
> int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
> int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
> int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
> int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
> int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
> int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
> int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
> int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
> int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
> int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
> int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
> int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
> int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
> int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
> int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
> int PMPI_Get_processor_name(char *name, int *resultlen);
> int PMPI_Get_version(int *version, int *subversion);
> int PMPI_Get_library_version(char *version, int *resultlen);
> int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
> int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
> int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
> int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
> int PMPI_Error_string(int errorcode, char *string, int *resultlen);
> int PMPI_Error_class(int errorcode, int *errorclass);
> double PMPI_Wtime(void);
> double PMPI_Wtick(void);
> int PMPI_Init(int *argc, char ***argv);
> int PMPI_Finalize(void);
> int PMPI_Initialized(int *flag);
> int PMPI_Abort(MPI_Comm comm, int errorcode);
> int PMPI_Pcontrol(const int level, ...);
> int PMPI_Close_port(const char *port_name);
> int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int PMPI_Comm_disconnect(MPI_Comm *comm);
> int PMPI_Comm_get_parent(MPI_Comm *parent);
> int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
> int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
> int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
> int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
> int PMPI_Open_port(MPI_Info info, char *port_name);
> int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
> int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
> int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
> int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
> int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Win_complete(MPI_Win win);
> int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> MPI_Win *win);
> int PMPI_Win_fence(int assert, MPI_Win win);
> int PMPI_Win_free(MPI_Win *win);
> int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
> int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
> int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
> int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
> int PMPI_Win_test(MPI_Win win, int *flag);
> int PMPI_Win_unlock(int rank, MPI_Win win);
> int PMPI_Win_wait(MPI_Win win);
> int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
> MPI_Win *win);
> int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
> int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
> int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
> int PMPI_Win_detach(MPI_Win win, const void *base);
> int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
> int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
> int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
> int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
> int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
> int PMPI_Rput(const void *origin_addr, int origin_count,
> int PMPI_Rget(void *origin_addr, int origin_count,
> int PMPI_Raccumulate(const void *origin_addr, int origin_count,
> int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
> int PMPI_Win_lock_all(int assert, MPI_Win win);
> int PMPI_Win_unlock_all(MPI_Win win);
> int PMPI_Win_flush(int rank, MPI_Win win);
> int PMPI_Win_flush_all(MPI_Win win);
> int PMPI_Win_flush_local(int rank, MPI_Win win);
> int PMPI_Win_flush_local_all(MPI_Win win);
> int PMPI_Win_sync(MPI_Win win);
> int PMPI_Add_error_class(int *errorclass);
> int PMPI_Add_error_code(int errorclass, int *errorcode);
> int PMPI_Add_error_string(int errorcode, const char *string);
> int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
> int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
> void *extra_state);
> int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
> int PMPI_Comm_free_keyval(int *comm_keyval);
> int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
> int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
> int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
> int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
> int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
> int PMPI_Grequest_complete(MPI_Request request);
> int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
> int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
> int PMPI_Is_thread_main(int *flag);
> int PMPI_Query_thread(int *provided);
> int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
> int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
> int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
> int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
> int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
> int PMPI_Type_free_keyval(int *type_keyval);
> int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
> int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
> int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
> int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
> int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
> int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
> int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
> int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
> int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
> void *extra_state);
> int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
> int PMPI_Win_free_keyval(int *win_keyval);
> int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
> int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
> int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
> int PMPI_Win_set_name(MPI_Win win, const char *win_name);
> int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
> int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
> int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
> int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
> int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
> int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
> int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
> int PMPI_Finalized(int *flag);
> int PMPI_Free_mem(void *base);
> int PMPI_Get_address(const void *location, MPI_Aint *address);
> int PMPI_Info_create(MPI_Info *info);
> int PMPI_Info_delete(MPI_Info info, const char *key);
> int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
> int PMPI_Info_free(MPI_Info *info);
> int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
> int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
> int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
> int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
> int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
> int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
> int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
> MPI_Aint *size);
> int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
> int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
> int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
> int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
> int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
> int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
> int PMPI_Type_create_hindexed_block(int count, int blocklength,
> int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
> int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
> int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
> int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
> int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
> int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
> int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
> int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
> int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
> int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
> int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
> int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
> int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
> MPI_Op op)
> int PMPI_Op_commutative(MPI_Op op, int *commute);
> int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
> int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
> int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
> int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
> int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
> int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
> int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
> int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
> int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
> int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
> int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
> int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
> MPI_Comm comm);
> int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
> int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
> int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
> int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
> int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
> int PMPIX_Comm_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int PMPIX_Comm_remote_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int PMPIX_Comm_reenable_anysource(MPI_Comm comm, MPI_Group *failed_group);
> int PMPI_T_init_thread(int required, int *provided);
> int PMPI_T_finalize(void);
> int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
> int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
> int PMPI_T_cvar_get_num(int *num_cvar);
> int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
> int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
> int *count);
> int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
> int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
> int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
> int PMPI_T_pvar_get_num(int *num_pvar);
> int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
> int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
> int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
> int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
> int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
> int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
> int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int PMPI_T_category_get_num(int *num_cat);
> int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
> int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
> int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
> int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
> int PMPI_T_category_changed(int *stamp);
> # 2178 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h" 1
> # 13 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 1
> # 14 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h" 2
> # 123 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
> int MPI_File_close(MPI_File *fh);
> int MPI_File_delete(const char *filename, MPI_Info info);
> int MPI_File_set_size(MPI_File fh, MPI_Offset size);
> int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
> int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
> int MPI_File_get_group(MPI_File fh, MPI_Group *group);
> int MPI_File_get_amode(MPI_File fh, int *amode);
> int MPI_File_set_info(MPI_File fh, MPI_Info info);
> int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
> int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
> const char *datarep, MPI_Info info);
> int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
> char *datarep);
> int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
> MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
> int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> MPI_Datatype datatype, MPI_Request *request)
> int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
> int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
> int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
> int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
> int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
> int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
> int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
> MPI_Datatype datatype) ;
> int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
> int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
> int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
> int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
> int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
> int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
> MPI_Datarep_conversion_function *write_conversion_fn,
> MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
> int MPI_File_set_atomicity(MPI_File fh, int flag);
> int MPI_File_get_atomicity(MPI_File fh, int *flag);
> int MPI_File_sync(MPI_File fh);
> # 268 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> MPI_File MPI_File_f2c(MPI_Fint file);
> MPI_Fint MPI_File_c2f(MPI_File file);
> # 329 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
> int PMPI_File_close(MPI_File *);
> int PMPI_File_delete(const char *, MPI_Info);
> int PMPI_File_set_size(MPI_File, MPI_Offset);
> int PMPI_File_preallocate(MPI_File, MPI_Offset);
> int PMPI_File_get_size(MPI_File, MPI_Offset *);
> int PMPI_File_get_group(MPI_File, MPI_Group *);
> int PMPI_File_get_amode(MPI_File, int *);
> int PMPI_File_set_info(MPI_File, MPI_Info);
> int PMPI_File_get_info(MPI_File, MPI_Info *);
> int PMPI_File_set_view(MPI_File, MPI_Offset,
> MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
> int PMPI_File_get_view(MPI_File, MPI_Offset *,
> MPI_Datatype *, MPI_Datatype *, char *);
> int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype, MPI_Status *)
> int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
> int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
> int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
> int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype, MPI_Request *)
> int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
> int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
> int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
> int PMPI_File_seek(MPI_File, MPI_Offset, int);
> int PMPI_File_get_position(MPI_File, MPI_Offset *);
> int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
> int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_iread_shared(MPI_File, void *, int,
> int PMPI_File_iwrite_shared(MPI_File, const void *, int,
> int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
> int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
> int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype)
> int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
> int, MPI_Datatype)
> int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
> int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
> int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
> int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
> int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
> int PMPI_Register_datarep(const char *,
> MPI_Datarep_conversion_function *,
> MPI_Datarep_extent_function *,
> void *);
> int PMPI_File_set_atomicity(MPI_File, int);
> int PMPI_File_get_atomicity(MPI_File, int *);
> int PMPI_File_sync(MPI_File);
> # 467 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> MPI_File PMPI_File_f2c(MPI_Fint);
> MPI_Fint PMPI_File_c2f(MPI_File);
> # 2179 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 2
> # 2200 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPIX_Grequest_class;
> int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
> MPIX_Grequest_poll_function *poll_fn,
> MPIX_Grequest_wait_function *wait_fn,
> MPIX_Grequest_class *greq_class);
> int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
> int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
> MPIX_Grequest_wait_function *wait_fn, void *extra_state,
> struct mpixi_mutex_s;
> typedef struct mpixi_mutex_s * MPIX_Mutex;
> int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
> int MPIX_Mutex_free(MPIX_Mutex *hdl);
> int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
> int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
> int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
> int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
> int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
> int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
> int PMPIX_Mutex_free(MPIX_Mutex *hdl);
> int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
> int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Found header files ['mpi.h'] in []
> Popping language C
> TEST configureConversion from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:217)
> TESTING: configureConversion from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:217)
> Check for the functions which convert communicators between C and Fortran
> - Define HAVE_MPI_COMM_F2C and HAVE_MPI_COMM_C2F if they are present
> - Some older MPI 1 implementations are missing these
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.packages.MPI
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.packages.MPI/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -g -O0 /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> #include <mpi.h>
> int main() {
> if (MPI_Comm_f2c((MPI_Fint)0));
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.packages.MPI/conftest -g -O0 /tmp/petsc-uoFdrH/config.packages.MPI/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_MPI_COMM_F2C" to "1"
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.packages.MPI/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.libraries -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -g -O0 /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> if (MPI_Comm_c2f(MPI_COMM_WORLD));
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPI_COMM_C2F" to "1"
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_Fint a;
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPI_FINT" to "1"
> TEST configureMPI2 from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:178)
> TESTING: configureMPI2 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:178)
> Check for functions added to the interface in MPI-2
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> int flag;if (MPI_Finalized(&flag));
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPI_FINALIZED" to "1"
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPI_IN_PLACE" to "1"
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
> if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> if (MPI_Reduce_local(0, 0, 0, MPI_INT, MPI_SUM));;
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPI_REDUCE_LOCAL" to "1"
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> char version[MPI_MAX_LIBRARY_VERSION_STRING];int verlen;if (MPI_Get_library_version(version,&verlen));
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPI_GET_LIBRARY_VERSION" to "1"
> TEST configureTypes from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:237)
> TESTING: configureTypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:237)
> Checking for MPI types
> Checking for size of type: MPI_Comm
> Defined "SIZEOF_MPI_COMM" to "4"
> Checking for size of type: MPI_Fint
> Defined "SIZEOF_MPI_FINT" to "4"
> TEST configureMPITypes from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:249)
> TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:249)
> Checking for MPI Datatype handles
> Successful compile:
> Source:
> #ifdef PETSC_HAVE_STDLIB_H
> #include <stdlib.h>
> #endif
> #include <mpi.h>
> int main() {
> MPI_Aint size;
> int ierr;
> MPI_Init(0,0);
> ierr = MPI_Type_extent(MPI_LONG_DOUBLE, &size);
> if(ierr || (size == 0)) exit(1);
> MPI_Finalize();
> return 0;
> Defined "HAVE_MPI_LONG_DOUBLE" to "1"
> Successful compile:
> Source:
> #include <stdlib.h>
> #endif
> #include <mpi.h>
> int main() {
> MPI_Aint size;
> int ierr;
> MPI_Init(0,0);
> ierr = MPI_Type_extent(MPI_INT64_T, &size);
> MPI_Finalize();
> return 0;
> Defined "HAVE_MPI_INT64_T" to "1"
> Successful compile:
> Source:
> #include <stdlib.h>
> #endif
> #include <mpi.h>
> int main() {
> MPI_Aint size;
> int ierr;
> MPI_Init(0,0);
> ierr = MPI_Type_extent(MPI_C_DOUBLE_COMPLEX, &size);
> MPI_Finalize();
> return 0;
> Defined "HAVE_MPI_C_DOUBLE_COMPLEX" to "1"
> TEST configureMissingPrototypes from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:320)
> TESTING: configureMissingPrototypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:320)
> Checks for missing prototypes, which it adds to petscfix.h
> TEST SGIMPICheck from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:339)
> TESTING: SGIMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:339)
> Returns true if SGI MPI is used
> Checking for functions [MPI_SGI_barrier] in library [] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> /* Override any gcc2 internal prototype to avoid an error. */
> char MPI_SGI_barrier();
> static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
> int main() {
> _check_MPI_SGI_barrier();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Possible ERROR while running linker: exit code 256
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_MPI_SGI_barrier':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `MPI_SGI_barrier'
> collect2: error: ld returned 1 exit status
> Popping language C
> SGI MPI test failure
> TEST CxxMPICheck from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:349)
> TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:349)
> Make sure C++ can compile and link
> Pushing language Cxx
> Checking for header mpi.h
> Executing: /opt/cray/craype/2.4.2/bin/CC -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.cc
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> return 0;
> Checking for C++ MPI_Finalize()
> Checking for functions [MPI_Finalize] in library [] []
> Successful compile:
> Source:
> #include <mpi.h>
> static void _check_MPI_Finalize() { int ierr;
> ierr = MPI_Finalize();; }
> int main() {
> _check_MPI_Finalize();;
> return 0;
> Pushing language CXX
> Popping language CXX
> Executing: /opt/cray/craype/2.4.2/bin/CC -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language Cxx
> TEST FortranMPICheck from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:367)
> TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:367)
> Make sure fortran include [mpif.h] and library symbols are found
> Pushing language FC
> Checking for header mpif.h
> Executing: /opt/cray/craype/2.4.2/bin/ftn -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.F90
> Successful compile:
> Source:
> program main
> #include "mpif.h"
> end
> Checking for fortran mpi_init()
> Checking for functions [] in library [] []
> Pushing language FC
> Successful compile:
> Source:
> program main
> #include "mpif.h"
> integer ierr
> call mpi_init(ierr)
> end
> Pushing language FC
> Popping language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language FC
> Checking for mpi.mod
> Pushing language FC
> Successful compile:
> Source:
> program main
> use mpi
> integer ierr,rank
> call mpi_init(ierr)
> call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
> end
> Pushing language FC
> Popping language FC
> Popping language FC
> Defined "HAVE_MPI_F90MODULE" to "1"
> Popping language FC
> TEST configureIO from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:392)
> TESTING: configureIO from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:392)
> Check for the functions in MPI/IO
> - Define HAVE_MPIIO if they are present
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.packages.MPI/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_Aint lb, extent;
> if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_File fh;
> void *buf;
> MPI_Status status;
> if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_File fh;
> void *buf;
> MPI_Status status;
> if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_File fh;
> MPI_Offset disp;
> MPI_Info info;
> if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_File fh;
> MPI_Info info;
> if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
> return 0;
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> MPI_File fh;
> MPI_Info info;
> if (MPI_File_close(&fh));
> return 0;
> Pushing language C
> Popping language C
> Defined "HAVE_MPIIO" to "1"
> TEST findMPIInc from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:464)
> TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:464)
> Find MPI include paths from "mpicc -show" and use with CUDAC_FLAGS
> TEST checkMPICHorOpenMPI from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:429)
> TESTING: checkMPICHorOpenMPI from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:429)
> Determine if MPICH_NUMVERSION or OMPI_MAJOR_VERSION exist in mpi.h
> Used for consistency checking of MPI installation at compile time
> Possible ERROR while running compiler: exit code 256
> stderr:
> /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c:4:17: error: 'I_MPI_NUMVERSION' undeclared here (not in a function)
> int mpich_ver = I_MPI_NUMVERSION;
> Source:
> #include <mpi.h>
> int main() {
> return 0;
> stderr:
> /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c:4:17: error: 'MVAPICH2_NUMVERSION' undeclared here (not in a function)
> int mpich_ver = MVAPICH2_NUMVERSION;
> Source:
> #include <mpi.h>
> int main() {
> return 0;
> Successful compile:
> Source:
> #include <mpi.h>
> int mpich_ver = MPICH_NUMVERSION;
> int main() {
> return 0;
> Source:
> #include <mpi.h>
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.packages.MPI/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.packages.MPI/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.packages.MPI/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.packages.MPI/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.packages.MPI/conftest.c" 2
> # 51 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 1 3 4
> # 9 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 3 4
> # 1 "/usr/include/stdint.h" 1 3 4
> # 26 "/usr/include/stdint.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 27 "/usr/include/stdint.h" 2 3 4
> # 1 "/usr/include/bits/wchar.h" 1 3 4
> # 28 "/usr/include/stdint.h" 2 3 4
> # 29 "/usr/include/stdint.h" 2 3 4
> # 37 "/usr/include/stdint.h" 3 4
> typedef signed char int8_t;
> typedef short int int16_t;
> typedef int int32_t;
> typedef long int int64_t;
> typedef unsigned char uint8_t;
> typedef unsigned short int uint16_t;
> typedef unsigned int uint32_t;
> typedef unsigned long int uint64_t;
> # 66 "/usr/include/stdint.h" 3 4
> typedef signed char int_least8_t;
> typedef short int int_least16_t;
> typedef int int_least32_t;
> typedef long int int_least64_t;
> typedef unsigned char uint_least8_t;
> typedef unsigned short int uint_least16_t;
> typedef unsigned int uint_least32_t;
> typedef unsigned long int uint_least64_t;
> # 91 "/usr/include/stdint.h" 3 4
> typedef signed char int_fast8_t;
> typedef long int int_fast16_t;
> typedef long int int_fast32_t;
> typedef long int int_fast64_t;
> # 104 "/usr/include/stdint.h" 3 4
> typedef unsigned char uint_fast8_t;
> typedef unsigned long int uint_fast16_t;
> typedef unsigned long int uint_fast32_t;
> typedef unsigned long int uint_fast64_t;
> # 120 "/usr/include/stdint.h" 3 4
> typedef long int intptr_t;
> typedef unsigned long int uintptr_t;
> # 135 "/usr/include/stdint.h" 3 4
> typedef long int intmax_t;
> typedef unsigned long int uintmax_t;
> # 10 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 2 3 4
> # 52 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 2
> # 96 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Datatype;
> # 279 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Comm;
> typedef int MPI_Group;
> typedef int MPI_Win;
> typedef struct ADIOI_FileD *MPI_File;
> typedef int MPI_Op;
> # 362 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef enum MPIR_Win_flavor {
> MPI_WIN_FLAVOR_CREATE = 1,
> MPI_WIN_FLAVOR_ALLOCATE = 2,
> MPI_WIN_FLAVOR_DYNAMIC = 3,
> MPI_WIN_FLAVOR_SHARED = 4
> } MPIR_Win_flavor_t;
> typedef enum MPIR_Win_model {
> MPI_WIN_SEPARATE = 1,
> MPI_WIN_UNIFIED = 2
> } MPIR_Win_model_t;
> typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
> extern int * const MPI_UNWEIGHTED;
> extern int * const MPI_WEIGHTS_EMPTY;
> # 394 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
> typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
> void *, int *);
> typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
> typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
> void *, int *);
> typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
> typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
> int *);
> typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
> typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
> typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
> typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
> typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
> typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
> typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
> # 422 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Errhandler;
> # 443 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Request;
> typedef int MPI_Message;
> typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
> typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
> typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
> # 497 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> enum MPIR_Combiner_enum {
> MPI_COMBINER_NAMED = 1,
> MPI_COMBINER_DUP = 2,
> MPI_COMBINER_CONTIGUOUS = 3,
> MPI_COMBINER_VECTOR = 4,
> MPI_COMBINER_HVECTOR_INTEGER = 5,
> MPI_COMBINER_HVECTOR = 6,
> MPI_COMBINER_INDEXED = 7,
> MPI_COMBINER_HINDEXED_INTEGER = 8,
> MPI_COMBINER_HINDEXED = 9,
> MPI_COMBINER_INDEXED_BLOCK = 10,
> MPI_COMBINER_STRUCT_INTEGER = 11,
> MPI_COMBINER_STRUCT = 12,
> MPI_COMBINER_SUBARRAY = 13,
> MPI_COMBINER_DARRAY = 14,
> MPI_COMBINER_F90_REAL = 15,
> MPI_COMBINER_F90_COMPLEX = 16,
> MPI_COMBINER_F90_INTEGER = 17,
> MPI_COMBINER_RESIZED = 18,
> MPI_COMBINER_HINDEXED_BLOCK = 19
> typedef int MPI_Info;
> # 547 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef long MPI_Aint;
> typedef int MPI_Fint;
> typedef long long MPI_Count;
> # 566 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef long long MPI_Offset;
> typedef struct MPI_Status {
> int count_lo;
> int count_hi_and_cancelled;
> int MPI_SOURCE;
> int MPI_TAG;
> int MPI_ERROR;
> } MPI_Status;
> struct MPIR_T_enum_s;
> struct MPIR_T_cvar_handle_s;
> struct MPIR_T_pvar_handle_s;
> struct MPIR_T_pvar_session_s;
> typedef struct MPIR_T_enum_s * MPI_T_enum;
> typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
> typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
> typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
> extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
> # 603 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef enum MPIR_T_verbosity_t {
> MPIX_T_VERBOSITY_INVALID = 0,
> MPI_T_VERBOSITY_USER_BASIC = 221,
> MPI_T_VERBOSITY_USER_DETAIL,
> MPI_T_VERBOSITY_USER_ALL,
> MPI_T_VERBOSITY_TUNER_BASIC,
> MPI_T_VERBOSITY_TUNER_DETAIL,
> MPI_T_VERBOSITY_TUNER_ALL,
> MPI_T_VERBOSITY_MPIDEV_BASIC,
> MPI_T_VERBOSITY_MPIDEV_DETAIL,
> MPI_T_VERBOSITY_MPIDEV_ALL
> } MPIR_T_verbosity_t;
> typedef enum MPIR_T_bind_t {
> MPIX_T_BIND_INVALID = 0,
> MPI_T_BIND_NO_OBJECT = 9700,
> MPI_T_BIND_MPI_COMM,
> MPI_T_BIND_MPI_DATATYPE,
> MPI_T_BIND_MPI_ERRHANDLER,
> MPI_T_BIND_MPI_FILE,
> MPI_T_BIND_MPI_GROUP,
> MPI_T_BIND_MPI_OP,
> MPI_T_BIND_MPI_REQUEST,
> MPI_T_BIND_MPI_WIN,
> MPI_T_BIND_MPI_MESSAGE,
> MPI_T_BIND_MPI_INFO
> } MPIR_T_bind_t;
> typedef enum MPIR_T_scope_t {
> MPIX_T_SCOPE_INVALID = 0,
> MPI_T_SCOPE_CONSTANT = 60438,
> MPI_T_SCOPE_READONLY,
> MPI_T_SCOPE_LOCAL,
> MPI_T_SCOPE_GROUP,
> MPI_T_SCOPE_GROUP_EQ,
> MPI_T_SCOPE_ALL,
> MPI_T_SCOPE_ALL_EQ
> } MPIR_T_scope_t;
> typedef enum MPIR_T_pvar_class_t {
> MPIX_T_PVAR_CLASS_INVALID = 0,
> MPIR_T_PVAR_CLASS_FIRST = 240,
> MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
> MPI_T_PVAR_CLASS_LEVEL,
> MPI_T_PVAR_CLASS_SIZE,
> MPI_T_PVAR_CLASS_PERCENTAGE,
> MPI_T_PVAR_CLASS_HIGHWATERMARK,
> MPI_T_PVAR_CLASS_LOWWATERMARK,
> MPI_T_PVAR_CLASS_COUNTER,
> MPI_T_PVAR_CLASS_AGGREGATE,
> MPI_T_PVAR_CLASS_TIMER,
> MPI_T_PVAR_CLASS_GENERIC,
> MPIR_T_PVAR_CLASS_LAST,
> MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
> } MPIR_T_pvar_class_t;
> # 725 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> extern MPI_Fint * MPI_F_STATUS_IGNORE;
> extern MPI_Fint * MPI_F_STATUSES_IGNORE;
> # 740 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef struct {
> MPI_Fint count_lo;
> MPI_Fint count_hi_and_cancelled;
> MPI_Fint MPI_SOURCE;
> MPI_Fint MPI_TAG;
> MPI_Fint MPI_ERROR;
> } MPI_F08_Status;
> extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
> extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
> extern int MPIR_F08_MPI_IN_PLACE;
> extern int MPIR_F08_MPI_BOTTOM;
> extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
> extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
> # 764 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int (MPI_Grequest_cancel_function)(void *, int);
> typedef int (MPI_Grequest_free_function)(void *);
> typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
> typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
> typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
> # 879 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
> void *, MPI_Offset, void *);
> typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
> void *);
> # 899 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> MPI_Comm comm, MPI_Status *status) ;
> int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Buffer_attach(void *buffer, int size);
> int MPI_Buffer_detach(void *buffer_addr, int *size);
> int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm, MPI_Request *request) ;
> int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int MPI_Wait(MPI_Request *request, MPI_Status *status);
> int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
> int MPI_Request_free(MPI_Request *request);
> int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
> int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
> int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
> int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
> int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int array_of_indices[], MPI_Status array_of_statuses[]);
> int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
> int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
> int MPI_Cancel(MPI_Request *request);
> int MPI_Test_cancelled(const MPI_Status *status, int *flag);
> int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int MPI_Start(MPI_Request *request);
> int MPI_Startall(int count, MPI_Request array_of_requests[]);
> int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
> int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
> int source, int recvtag, MPI_Comm comm, MPI_Status *status)
> int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
> int sendtag, int source, int recvtag, MPI_Comm comm,
> int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
> int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int MPI_Type_indexed(int count, const int *array_of_blocklengths,
> const int *array_of_displacements, MPI_Datatype oldtype,
> int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
> const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
> int MPI_Type_struct(int count, const int *array_of_blocklengths,
> const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
> int MPI_Address(const void *location, MPI_Aint *address);
> int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
> int MPI_Type_size(MPI_Datatype datatype, int *size);
> int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
> int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
> int MPI_Type_commit(MPI_Datatype *datatype);
> int MPI_Type_free(MPI_Datatype *datatype);
> int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
> int outsize, int *position, MPI_Comm comm) ;
> int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
> MPI_Datatype datatype, MPI_Comm comm) ;
> int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
> int MPI_Barrier(MPI_Comm comm);
> int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
> int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
> int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
> MPI_Comm comm)
> int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
> MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
> int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
> MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
> const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
> const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
> int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, MPI_Comm comm)
> int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, int root, MPI_Comm comm)
> int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
> int MPI_Op_free(MPI_Op *op);
> int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
> int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> MPI_Comm comm)
> int MPI_Group_size(MPI_Group group, int *size);
> int MPI_Group_rank(MPI_Group group, int *rank);
> int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
> int ranks2[]);
> int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
> int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
> int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int MPI_Group_free(MPI_Group *group);
> int MPI_Comm_size(MPI_Comm comm, int *size);
> int MPI_Comm_rank(MPI_Comm comm, int *rank);
> int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
> int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
> int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
> int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
> int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
> int MPI_Comm_free(MPI_Comm *comm);
> int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
> int MPI_Comm_remote_size(MPI_Comm comm, int *size);
> int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
> int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
> int remote_leader, int tag, MPI_Comm *newintercomm);
> int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
> int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
> int *keyval, void *extra_state);
> int MPI_Keyval_free(int *keyval);
> int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
> int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
> int MPI_Attr_delete(MPI_Comm comm, int keyval);
> int MPI_Topo_test(MPI_Comm comm, int *status);
> int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
> int reorder, MPI_Comm *comm_cart);
> int MPI_Dims_create(int nnodes, int ndims, int dims[]);
> int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
> int reorder, MPI_Comm *comm_graph);
> int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
> int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
> int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
> int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
> int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
> int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
> int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
> int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
> int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
> int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
> int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
> int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
> int MPI_Get_processor_name(char *name, int *resultlen);
> int MPI_Get_version(int *version, int *subversion);
> int MPI_Get_library_version(char *version, int *resultlen);
> int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
> int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
> int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
> int MPI_Errhandler_free(MPI_Errhandler *errhandler);
> int MPI_Error_string(int errorcode, char *string, int *resultlen);
> int MPI_Error_class(int errorcode, int *errorclass);
> double MPI_Wtime(void);
> double MPI_Wtick(void);
> int MPI_Init(int *argc, char ***argv);
> int MPI_Finalize(void);
> int MPI_Initialized(int *flag);
> int MPI_Abort(MPI_Comm comm, int errorcode);
> int MPI_Pcontrol(const int level, ...);
> int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
> void *attribute_val_out, int *flag);
> int MPI_Close_port(const char *port_name);
> int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int MPI_Comm_disconnect(MPI_Comm *comm);
> int MPI_Comm_get_parent(MPI_Comm *parent);
> int MPI_Comm_join(int fd, MPI_Comm *intercomm);
> int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
> MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
> int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
> const int array_of_maxprocs[], const MPI_Info array_of_info[],
> int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
> int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
> int MPI_Open_port(MPI_Info info, char *port_name);
> int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
> int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
> int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
> int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
> int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int target_rank, MPI_Aint target_disp, int target_count,
> MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
> int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> MPI_Datatype target_datatype, MPI_Win win) ;
> int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int MPI_Win_complete(MPI_Win win);
> int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> MPI_Win *win);
> int MPI_Win_fence(int assert, MPI_Win win);
> int MPI_Win_free(MPI_Win *win);
> int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
> int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
> int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
> int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
> int MPI_Win_test(MPI_Win win, int *flag);
> int MPI_Win_unlock(int rank, MPI_Win win);
> int MPI_Win_wait(MPI_Win win);
> int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
> MPI_Win *win);
> int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> void *baseptr, MPI_Win *win);
> int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
> int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
> int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
> int MPI_Win_detach(MPI_Win win, const void *base);
> int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
> int MPI_Win_set_info(MPI_Win win, MPI_Info info);
> int MPI_Get_accumulate(const void *origin_addr, int origin_count,
> MPI_Datatype origin_datatype, void *result_addr, int result_count,
> MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
> int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
> int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
> MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
> int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
> void *result_addr, MPI_Datatype datatype, int target_rank,
> MPI_Aint target_disp, MPI_Win win)
> int MPI_Rput(const void *origin_addr, int origin_count,
> MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
> int target_count, MPI_Datatype target_datatype, MPI_Win win,
> int MPI_Rget(void *origin_addr, int origin_count,
> int MPI_Raccumulate(const void *origin_addr, int origin_count,
> int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
> int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
> int MPI_Win_lock_all(int assert, MPI_Win win);
> int MPI_Win_unlock_all(MPI_Win win);
> int MPI_Win_flush(int rank, MPI_Win win);
> int MPI_Win_flush_all(MPI_Win win);
> int MPI_Win_flush_local(int rank, MPI_Win win);
> int MPI_Win_flush_local_all(MPI_Win win);
> int MPI_Win_sync(MPI_Win win);
> int MPI_Add_error_class(int *errorclass);
> int MPI_Add_error_code(int errorclass, int *errorcode);
> int MPI_Add_error_string(int errorcode, const char *string);
> int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
> int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
> MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
> void *extra_state);
> int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
> int MPI_Comm_free_keyval(int *comm_keyval);
> int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
> int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
> int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
> int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
> int MPI_File_call_errhandler(MPI_File fh, int errorcode);
> int MPI_Grequest_complete(MPI_Request request);
> int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
> MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
> int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
> int MPI_Is_thread_main(int *flag);
> int MPI_Query_thread(int *provided);
> int MPI_Status_set_cancelled(MPI_Status *status, int flag);
> int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
> int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
> MPI_Type_delete_attr_function *type_delete_attr_fn,
> int *type_keyval, void *extra_state);
> int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
> int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_free_keyval(int *type_keyval);
> int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
> int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
> int max_datatypes, int array_of_integers[],
> MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
> int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
> int *num_datatypes, int *combiner);
> int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
> int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
> int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
> int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
> int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
> int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
> MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
> void *extra_state);
> int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
> int MPI_Win_free_keyval(int *win_keyval);
> int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
> int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
> int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
> int MPI_Win_set_name(MPI_Win win, const char *win_name);
> int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
> int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
> int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
> int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
> int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
> int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
> int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
> int MPI_Finalized(int *flag);
> int MPI_Free_mem(void *base);
> int MPI_Get_address(const void *location, MPI_Aint *address);
> int MPI_Info_create(MPI_Info *info);
> int MPI_Info_delete(MPI_Info info, const char *key);
> int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
> int MPI_Info_free(MPI_Info *info);
> int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
> int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
> int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
> int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
> int MPI_Info_set(MPI_Info info, const char *key, const char *value);
> int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
> MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
> int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
> MPI_Aint *size);
> int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
> int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
> int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
> int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
> const int array_of_distribs[], const int array_of_dargs[],
> const int array_of_psizes[], int order, MPI_Datatype oldtype,
> int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
> const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
> int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
> int MPI_Type_create_hindexed_block(int count, int blocklength,
> int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
> int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
> const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
> int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
> const int array_of_subsizes[], const int array_of_starts[],
> int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
> int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
> int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
> MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
> int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
> int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
> int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
> int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
> int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
> int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
> int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
> MPI_Op op)
> int MPI_Op_commutative(MPI_Op op, int *commute);
> int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
> const int sourceweights[], int outdegree,
> const int destinations[], const int destweights[],
> MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
> int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
> const int destinations[], const int weights[], MPI_Info info,
> int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
> int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
> int maxoutdegree, int destinations[], int destweights[]);
> int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
> int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
> int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
> int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
> int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
> int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
> int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
> int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
> int root, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
> const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
> int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
> int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, MPI_Comm comm, MPI_Request *request)
> int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
> int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, const int recvcounts[], const int displs[],
> int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
> int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
> const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
> void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
> const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
> int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
> const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
> int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
> int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
> int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
> int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
> int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
> int MPIX_Comm_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int MPIX_Comm_remote_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int MPIX_Comm_reenable_anysource(MPI_Comm comm, MPI_Group *failed_group);
> int MPI_T_init_thread(int required, int *provided);
> int MPI_T_finalize(void);
> int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
> int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
> int MPI_T_cvar_get_num(int *num_cvar);
> int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
> MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
> int *binding, int *scope);
> int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
> int *count);
> int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
> int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
> int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
> int MPI_T_pvar_get_num(int *num_pvar);
> int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
> int *binding, int *readonly, int *continuous, int *atomic);
> int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
> int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
> int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
> MPI_T_pvar_handle *handle, int *count);
> int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
> int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
> int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int MPI_T_category_get_num(int *num_cat);
> int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
> int *num_cvars, int *num_pvars, int *num_categories);
> int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
> int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
> int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
> int MPI_T_category_changed(int *stamp);
> int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Buffer_attach(void *buffer, int size);
> int PMPI_Buffer_detach(void *buffer_addr, int *size);
> int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Wait(MPI_Request *request, MPI_Status *status);
> int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
> int PMPI_Request_free(MPI_Request *request);
> int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
> int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
> int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
> int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
> int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
> int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
> int PMPI_Cancel(MPI_Request *request);
> int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
> int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Start(MPI_Request *request);
> int PMPI_Startall(int count, MPI_Request array_of_requests[]);
> int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
> int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
> int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
> int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
> int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
> int PMPI_Type_struct(int count, const int *array_of_blocklengths,
> int PMPI_Address(const void *location, MPI_Aint *address);
> int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
> int PMPI_Type_size(MPI_Datatype datatype, int *size);
> int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
> int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
> int PMPI_Type_commit(MPI_Datatype *datatype);
> int PMPI_Type_free(MPI_Datatype *datatype);
> int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
> int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
> int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
> int PMPI_Barrier(MPI_Comm comm);
> int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
> int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> MPI_Comm comm)
> int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
> int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
> int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
> int PMPI_Op_free(MPI_Op *op);
> int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> MPI_Comm comm)
> int PMPI_Group_size(MPI_Group group, int *size);
> int PMPI_Group_rank(MPI_Group group, int *rank);
> int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
> int ranks2[]);
> int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
> int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
> int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int PMPI_Group_free(MPI_Group *group);
> int PMPI_Comm_size(MPI_Comm comm, int *size);
> int PMPI_Comm_rank(MPI_Comm comm, int *rank);
> int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
> int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
> int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
> int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
> int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
> int PMPI_Comm_free(MPI_Comm *comm);
> int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
> int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
> int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
> int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
> int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
> int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
> int PMPI_Keyval_free(int *keyval);
> int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
> int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
> int PMPI_Attr_delete(MPI_Comm comm, int keyval);
> int PMPI_Topo_test(MPI_Comm comm, int *status);
> int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
> int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
> int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
> int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
> int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
> int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
> int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
> int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
> int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
> int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
> int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
> int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
> int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
> int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
> int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
> int PMPI_Get_processor_name(char *name, int *resultlen);
> int PMPI_Get_version(int *version, int *subversion);
> int PMPI_Get_library_version(char *version, int *resultlen);
> int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
> int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
> int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
> int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
> int PMPI_Error_string(int errorcode, char *string, int *resultlen);
> int PMPI_Error_class(int errorcode, int *errorclass);
> double PMPI_Wtime(void);
> double PMPI_Wtick(void);
> int PMPI_Init(int *argc, char ***argv);
> int PMPI_Finalize(void);
> int PMPI_Initialized(int *flag);
> int PMPI_Abort(MPI_Comm comm, int errorcode);
> int PMPI_Pcontrol(const int level, ...);
> int PMPI_Close_port(const char *port_name);
> int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int PMPI_Comm_disconnect(MPI_Comm *comm);
> int PMPI_Comm_get_parent(MPI_Comm *parent);
> int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
> int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
> int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
> int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
> int PMPI_Open_port(MPI_Info info, char *port_name);
> int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
> int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
> int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
> int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
> int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Win_complete(MPI_Win win);
> int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> MPI_Win *win);
> int PMPI_Win_fence(int assert, MPI_Win win);
> int PMPI_Win_free(MPI_Win *win);
> int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
> int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
> int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
> int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
> int PMPI_Win_test(MPI_Win win, int *flag);
> int PMPI_Win_unlock(int rank, MPI_Win win);
> int PMPI_Win_wait(MPI_Win win);
> int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
> MPI_Win *win);
> int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
> int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
> int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
> int PMPI_Win_detach(MPI_Win win, const void *base);
> int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
> int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
> int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
> int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
> int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
> int PMPI_Rput(const void *origin_addr, int origin_count,
> int PMPI_Rget(void *origin_addr, int origin_count,
> int PMPI_Raccumulate(const void *origin_addr, int origin_count,
> int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
> int PMPI_Win_lock_all(int assert, MPI_Win win);
> int PMPI_Win_unlock_all(MPI_Win win);
> int PMPI_Win_flush(int rank, MPI_Win win);
> int PMPI_Win_flush_all(MPI_Win win);
> int PMPI_Win_flush_local(int rank, MPI_Win win);
> int PMPI_Win_flush_local_all(MPI_Win win);
> int PMPI_Win_sync(MPI_Win win);
> int PMPI_Add_error_class(int *errorclass);
> int PMPI_Add_error_code(int errorclass, int *errorcode);
> int PMPI_Add_error_string(int errorcode, const char *string);
> int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
> int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
> void *extra_state);
> int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
> int PMPI_Comm_free_keyval(int *comm_keyval);
> int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
> int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
> int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
> int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
> int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
> int PMPI_Grequest_complete(MPI_Request request);
> int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
> int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
> int PMPI_Is_thread_main(int *flag);
> int PMPI_Query_thread(int *provided);
> int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
> int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
> int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
> int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
> int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
> int PMPI_Type_free_keyval(int *type_keyval);
> int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
> int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
> int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
> int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
> int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
> int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
> int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
> int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
> int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
> void *extra_state);
> int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
> int PMPI_Win_free_keyval(int *win_keyval);
> int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
> int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
> int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
> int PMPI_Win_set_name(MPI_Win win, const char *win_name);
> int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
> int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
> int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
> int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
> int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
> int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
> int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
> int PMPI_Finalized(int *flag);
> int PMPI_Free_mem(void *base);
> int PMPI_Get_address(const void *location, MPI_Aint *address);
> int PMPI_Info_create(MPI_Info *info);
> int PMPI_Info_delete(MPI_Info info, const char *key);
> int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
> int PMPI_Info_free(MPI_Info *info);
> int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
> int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
> int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
> int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
> int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
> int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
> int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
> MPI_Aint *size);
> int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
> int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
> int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
> int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
> int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
> int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
> int PMPI_Type_create_hindexed_block(int count, int blocklength,
> int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
> int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
> int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
> int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
> int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
> int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
> int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
> int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
> int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
> int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
> int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
> int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
> int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
> MPI_Op op)
> int PMPI_Op_commutative(MPI_Op op, int *commute);
> int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
> int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
> int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
> int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
> int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
> int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
> int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
> int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
> int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
> int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
> int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
> int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
> MPI_Comm comm);
> int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
> int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
> int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
> int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
> int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
> int PMPIX_Comm_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int PMPIX_Comm_remote_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int PMPIX_Comm_reenable_anysource(MPI_Comm comm, MPI_Group *failed_group);
> int PMPI_T_init_thread(int required, int *provided);
> int PMPI_T_finalize(void);
> int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
> int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
> int PMPI_T_cvar_get_num(int *num_cvar);
> int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
> int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
> int *count);
> int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
> int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
> int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
> int PMPI_T_pvar_get_num(int *num_pvar);
> int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
> int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
> int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
> int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
> int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
> int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
> int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int PMPI_T_category_get_num(int *num_cat);
> int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
> int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
> int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
> int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
> int PMPI_T_category_changed(int *stamp);
> # 2178 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h" 1
> # 13 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 1
> # 14 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h" 2
> # 123 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
> int MPI_File_close(MPI_File *fh);
> int MPI_File_delete(const char *filename, MPI_Info info);
> int MPI_File_set_size(MPI_File fh, MPI_Offset size);
> int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
> int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
> int MPI_File_get_group(MPI_File fh, MPI_Group *group);
> int MPI_File_get_amode(MPI_File fh, int *amode);
> int MPI_File_set_info(MPI_File fh, MPI_Info info);
> int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
> int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
> const char *datarep, MPI_Info info);
> int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
> char *datarep);
> int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
> MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
> int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> MPI_Datatype datatype, MPI_Request *request)
> int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
> int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
> int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
> int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
> int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
> int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
> int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
> MPI_Datatype datatype) ;
> int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
> int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
> int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
> int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
> int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
> int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
> MPI_Datarep_conversion_function *write_conversion_fn,
> MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
> int MPI_File_set_atomicity(MPI_File fh, int flag);
> int MPI_File_get_atomicity(MPI_File fh, int *flag);
> int MPI_File_sync(MPI_File fh);
> # 268 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> MPI_File MPI_File_f2c(MPI_Fint file);
> MPI_Fint MPI_File_c2f(MPI_File file);
> # 329 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
> int PMPI_File_close(MPI_File *);
> int PMPI_File_delete(const char *, MPI_Info);
> int PMPI_File_set_size(MPI_File, MPI_Offset);
> int PMPI_File_preallocate(MPI_File, MPI_Offset);
> int PMPI_File_get_size(MPI_File, MPI_Offset *);
> int PMPI_File_get_group(MPI_File, MPI_Group *);
> int PMPI_File_get_amode(MPI_File, int *);
> int PMPI_File_set_info(MPI_File, MPI_Info);
> int PMPI_File_get_info(MPI_File, MPI_Info *);
> int PMPI_File_set_view(MPI_File, MPI_Offset,
> MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
> int PMPI_File_get_view(MPI_File, MPI_Offset *,
> MPI_Datatype *, MPI_Datatype *, char *);
> int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype, MPI_Status *)
> int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
> int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
> int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
> int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype, MPI_Request *)
> int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
> int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
> int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
> int PMPI_File_seek(MPI_File, MPI_Offset, int);
> int PMPI_File_get_position(MPI_File, MPI_Offset *);
> int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
> int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_iread_shared(MPI_File, void *, int,
> int PMPI_File_iwrite_shared(MPI_File, const void *, int,
> int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
> int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
> int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype)
> int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
> int, MPI_Datatype)
> int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
> int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
> int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
> int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
> int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
> int PMPI_Register_datarep(const char *,
> MPI_Datarep_conversion_function *,
> MPI_Datarep_extent_function *,
> void *);
> int PMPI_File_set_atomicity(MPI_File, int);
> int PMPI_File_get_atomicity(MPI_File, int *);
> int PMPI_File_sync(MPI_File);
> # 467 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> MPI_File PMPI_File_f2c(MPI_Fint);
> MPI_Fint PMPI_File_c2f(MPI_File);
> # 2179 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 2
> # 2200 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPIX_Grequest_class;
> int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
> MPIX_Grequest_poll_function *poll_fn,
> MPIX_Grequest_wait_function *wait_fn,
> MPIX_Grequest_class *greq_class);
> int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
> int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
> MPIX_Grequest_wait_function *wait_fn, void *extra_state,
> struct mpixi_mutex_s;
> typedef struct mpixi_mutex_s * MPIX_Mutex;
> int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
> int MPIX_Mutex_free(MPIX_Mutex *hdl);
> int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
> int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
> int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
> int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
> int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
> int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
> int PMPIX_Mutex_free(MPIX_Mutex *hdl);
> int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
> int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
> # 4 "/tmp/petsc-uoFdrH/config.packages.MPI/conftest.c" 2
> int mpich_ver = 30102300;
> Defined "HAVE_MPICH_NUMVERSION" to "30102300"
> Checking for functions [MPI_Alltoallw] in library [] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> /* Override any gcc2 internal prototype to avoid an error. */
> char MPI_Alltoallw();
> static void _check_MPI_Alltoallw() { MPI_Alltoallw(); }
> int main() {
> _check_MPI_Alltoallw();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Popping language C
> Checking for functions [MPI_Type_create_indexed_block] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPI_Type_create_indexed_block();
> static void _check_MPI_Type_create_indexed_block() { MPI_Type_create_indexed_block(); }
> int main() {
> _check_MPI_Type_create_indexed_block();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> Defined "HAVE_MPI_ALLTOALLW" to "1"
> Checking for functions [MPI_Win_create] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPI_Win_create();
> static void _check_MPI_Win_create() { MPI_Win_create(); }
> int main() {
> _check_MPI_Win_create();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> Defined "HAVE_MPI_WIN_CREATE" to "1"
> Defined "HAVE_MPI_REPLACE" to "1"
> Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan MPI_Reduce_scatter MPI_Reduce_scatter_block] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPI_Comm_spawn();
> static void _check_MPI_Comm_spawn() { MPI_Comm_spawn(); }
> char MPI_Type_get_envelope();
> static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
> char MPI_Type_get_extent();
> static void _check_MPI_Type_get_extent() { MPI_Type_get_extent(); }
> char MPI_Type_dup();
> static void _check_MPI_Type_dup() { MPI_Type_dup(); }
> char MPI_Init_thread();
> static void _check_MPI_Init_thread() { MPI_Init_thread(); }
> char MPI_Iallreduce();
> static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
> char MPI_Ibarrier();
> static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
> char MPI_Finalized();
> static void _check_MPI_Finalized() { MPI_Finalized(); }
> char MPI_Exscan();
> static void _check_MPI_Exscan() { MPI_Exscan(); }
> char MPI_Reduce_scatter();
> static void _check_MPI_Reduce_scatter() { MPI_Reduce_scatter(); }
> char MPI_Reduce_scatter_block();
> static void _check_MPI_Reduce_scatter_block() { MPI_Reduce_scatter_block(); }
> int main() {
> _check_MPI_Comm_spawn();
> _check_MPI_Type_get_envelope();
> _check_MPI_Type_get_extent();
> _check_MPI_Type_dup();
> _check_MPI_Init_thread();
> _check_MPI_Iallreduce();
> _check_MPI_Ibarrier();
> _check_MPI_Finalized();
> _check_MPI_Exscan();
> _check_MPI_Reduce_scatter();
> _check_MPI_Reduce_scatter_block();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> Defined "HAVE_MPI_COMM_SPAWN" to "1"
> Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
> Defined "HAVE_MPI_TYPE_GET_EXTENT" to "1"
> Defined "HAVE_MPI_TYPE_DUP" to "1"
> Defined "HAVE_MPI_INIT_THREAD" to "1"
> Defined "HAVE_MPI_IALLREDUCE" to "1"
> Defined "HAVE_MPI_IBARRIER" to "1"
> Defined "HAVE_MPI_FINALIZED" to "1"
> Defined "HAVE_MPI_EXSCAN" to "1"
> Defined "HAVE_MPI_REDUCE_SCATTER" to "1"
> Defined "HAVE_MPI_REDUCE_SCATTER_BLOCK" to "1"
> Checking for functions [MPIX_Iallreduce] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPIX_Iallreduce();
> static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
> int main() {
> _check_MPIX_Iallreduce();;
> return 0;
> Pushing language C
> Popping language C
> Possible ERROR while running linker: exit code 256
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_MPIX_Iallreduce':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `MPIX_Iallreduce'
> collect2: error: ld returned 1 exit status
> Popping language C
> Checking for functions [MPIX_Ibarrier] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPIX_Ibarrier();
> static void _check_MPIX_Ibarrier() { MPIX_Ibarrier(); }
> int main() {
> _check_MPIX_Ibarrier();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_MPIX_Ibarrier':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `MPIX_Ibarrier'
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.packages.MPI/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.packages.MPI/conftest.c
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> int combiner = MPI_COMBINER_DUP;;
> return 0;
> Defined "HAVE_MPI_COMBINER_DUP" to "1"
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> int combiner = MPI_COMBINER_CONTIGUOUS;;
> return 0;
> Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
> Successful compile:
> Source:
> #include <mpi.h>
> int main() {
> int combiner = MPI_COMBINER_NAMED;;
> return 0;
> Defined "HAVE_MPI_COMBINER_NAMED" to "1"
> Checking for functions [MPIDI_CH3I_sock_set] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPIDI_CH3I_sock_set();
> static void _check_MPIDI_CH3I_sock_set() { MPIDI_CH3I_sock_set(); }
> int main() {
> _check_MPIDI_CH3I_sock_set();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_MPIDI_CH3I_sock_set':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `MPIDI_CH3I_sock_set'
> Popping language C
> Checking for functions [MPIDI_CH3I_sock_fixed_nbc_progress] in library [] []
> Pushing language C
> Successful compile:
> Source:
> char MPIDI_CH3I_sock_fixed_nbc_progress();
> static void _check_MPIDI_CH3I_sock_fixed_nbc_progress() { MPIDI_CH3I_sock_fixed_nbc_progress(); }
> int main() {
> _check_MPIDI_CH3I_sock_fixed_nbc_progress();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_MPIDI_CH3I_sock_fixed_nbc_progress':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `MPIDI_CH3I_sock_fixed_nbc_progress'
> Popping language C
> TEST checkSharedLibrary from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:128)
> TESTING: checkSharedLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:128)
> Sets flag indicating if MPI libraries are shared or not and
> determines if MPI libraries CANNOT be used by shared libraries
> TEST configureMPIEXEC from config.packages.MPI(/home/zampins/src/petsc/config/BuildSystem/config/packages/MPI.py:141)
> TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:141)
> Checking for mpiexec
> Defined make macro "MPIEXEC" to "Not_appropriate_for_batch_systems_You_must_use_your_batch_system_to_submit_MPI_jobs_speak_with_your_local_sys_admin"
> Successful compile:
> Source:
> #include <mpi.h>
> #ifdef __cplusplus
> extern "C"
> #endif
> int init(int argc, char *argv[]) {
> int isInitialized;
> MPI_Init(&argc, &argv);
> MPI_Initialized(&isInitialized);
> return (int) isInitialized;
> Pushing language C
> Popping language C
> Executing: /usr/bin/ar cr /tmp/petsc-uoFdrH/config.packages.MPI/libconftest.a /tmp/petsc-uoFdrH/config.packages.MPI/conftest.o ; /usr/bin/ranlib /tmp/petsc-uoFdrH/config.packages.MPI/libconftest.a
> Successful compile:
> Source:
> #include <mpi.h>
> #ifdef __cplusplus
> extern "C"
> #endif
> int checkInit(void) {
> int isInitialized;
> if (isInitialized) MPI_Finalize();
> Pushing language C
> Popping language C
> Successful compile:
> Source:
> #include <stdio.h>
> #include <stdlib.h>
> #ifdef PETSC_HAVE_DLFCN_H
> #include <dlfcn.h>
> #endif
> int main() {
> int argc = 1;
> char *argv[2] = {(char *) "conftest", NULL};
> void *lib;
> int (*init)(int, char **);
> int (*checkInit)(void);
> lib = dlopen("/tmp/petsc-uoFdrH/config.libraries/lib1.a", RTLD_LAZY);
> if (!lib) {
> fprintf(stderr, "Could not open lib1.so: %s\n", dlerror());
> exit(1);
> init = (int (*)(int, char **)) dlsym(lib, "init");
> if (!init) {
> fprintf(stderr, "Could not find initialization function\n");
> exit(1);
> if (!(*init)(argc, argv)) {
> fprintf(stderr, "Could not initialize library\n");
> exit(1);
> lib = dlopen("/tmp/petsc-uoFdrH/config.libraries/lib2.a", RTLD_LAZY);
> if (!lib) {
> fprintf(stderr, "Could not open lib2.so: %s\n", dlerror());
> exit(1);
> checkInit = (int (*)(void)) dlsym(lib, "checkInit");
> if (!checkInit) {
> fprintf(stderr, "Could not find initialization check function\n");
> exit(1);
> if (!(*checkInit)()) {
> fprintf(stderr, "Did not link with shared library\n");
> exit(2);
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl -ldl
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `main':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:19: warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Testing executable /tmp/petsc-uoFdrH/config.libraries/conftest to see if it can be run
> Library was shared
> Popping language C
> TEST alternateConfigureLibrary from config.packages.memkind(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.memkind(config/BuildSystem/config/package.py:796)
> Called if --with-packagename=0; does nothing by default
> TEST alternateConfigureLibrary from config.packages.yaml(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.yaml(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.revolve(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.revolve(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.libjpeg(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.libjpeg(config/BuildSystem/config/package.py:796)
> TEST locateC2html from config.packages.c2html(/home/zampins/src/petsc/config/BuildSystem/config/packages/c2html.py:32)
> TESTING: locateC2html from config.packages.c2html(config/BuildSystem/config/packages/c2html.py:32)
> Looking for default C2html executable
> Checking for program /home/zampins/local/fenics-tools/bin/c2html...not found
> Checking for program /home/zampins/local/bin/c2html...not found
> Checking for program /home/zampins/local/anaconda/bin/c2html...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/c2html...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/c2html...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/c2html...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/c2html...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/c2html...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/c2html...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/c2html...not found
> Checking for program /opt/gcc/5.1.0/bin/c2html...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/c2html...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/c2html...not found
> Checking for program /opt/slurm/default/bin/c2html...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/c2html...not found
> Checking for program /opt/cray/craype/2.4.2/bin/c2html...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/c2html...not found
> Checking for program /opt/modules/3.2.10.5/bin/c2html...not found
> Checking for program /home/zampins/bin/c2html...not found
> Checking for program /usr/local/bin/c2html...not found
> Checking for program /usr/bin/c2html...not found
> Checking for program /bin/c2html...not found
> Checking for program /usr/bin/X11/c2html...not found
> Checking for program /usr/X11R6/bin/c2html...not found
> Checking for program /usr/games/c2html...not found
> Checking for program /sbin/c2html...not found
> Checking for program /usr/sbin/c2html...not found
> Checking for program /usr/lib/mit/bin/c2html...not found
> Checking for program /usr/lib/mit/sbin/c2html...not found
> Checking for program ./c2html...not found
> Checking for program /usr/lib/qt3/bin/c2html...not found
> Checking for program /opt/cray/bin/c2html...not found
> Checking for program /home/zampins/c2html...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/c2html...not found
> Pushing language C
> TEST configureLibrary from config.packages.valgrind(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.valgrind(config/BuildSystem/config/package.py:744)
> Find an installation and check if it can work with PETSc
> Checking for a functional valgrind
> Not checking for library in Compiler specific search VALGRIND: [] because no functions given to check for
> TEST check from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:159)
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:159)
> Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
> - libDir may be a list of directories
> - libName may be a list of library names
> No functions to check for in library [] []
> Checking for headers Compiler specific search VALGRIND: []
> Pushing language C
> TEST checkInclude from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:86)
> TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
> Checks if a particular include file can be found along particular include paths
> Checking for header files ['valgrind/valgrind.h'] in []
> Checking include with compiler flags var CPPFLAGS []
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> Possible ERROR while running preprocessor: exit code 256
> stdout:
> # 1 "<built-in>"
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2stderr:
> /tmp/petsc-uoFdrH/config.headers/conftest.c:3:31: fatal error: valgrind/valgrind.h: No such file or directory
> compilation terminated.
> Source:
> #include <valgrind/valgrind.h>
> Preprocess stderr before filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:31: fatal error: valgrind/valgrind.h: No such file or directory
> Preprocess stderr after filtering:/tmp/petsc-uoFdrH/config.headers/conftest.c:3:31: fatal error: valgrind/valgrind.h: No such file or directorycompilation terminated.:
> Popping language C
> Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
> Checking for headers Package specific search directory VALGRIND: ['/usr/local/include']
> Pushing language C
> Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include']
> Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers -I/usr/local/include /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> Source:
> Popping language C
> Pushing language C
> stdout:
> # 1 "<built-in>"
> stdout:
> # 1 "<built-in>"
> Source:
> Popping language C
> VALGRIND: SearchDir DirPath not found.. skipping: /opt/local
> Executing: uname -s
> stdout: Linux
> It appears you do not have valgrind installed on your system.
> We HIGHLY recommend you install it from www.valgrind.org
> Or install valgrind-devel or equivalent using your package manager.
> Then rerun ./configure
> Popping language C
> TEST alternateConfigureLibrary from config.packages.ssl(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.ssl(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.sprng(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.sprng(config/BuildSystem/config/package.py:796)
> PETSc clone, checking for Sowing
> Checking for program /home/zampins/local/fenics-tools/bin/pdflatex...not found
> Checking for program /home/zampins/local/bin/pdflatex...not found
> Checking for program /home/zampins/local/anaconda/bin/pdflatex...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/pdflatex...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/pdflatex...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/pdflatex...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/pdflatex...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/pdflatex...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/pdflatex...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/pdflatex...not found
> Checking for program /opt/gcc/5.1.0/bin/pdflatex...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/pdflatex...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/pdflatex...not found
> Checking for program /opt/slurm/default/bin/pdflatex...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/pdflatex...not found
> Checking for program /opt/cray/craype/2.4.2/bin/pdflatex...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/pdflatex...not found
> Checking for program /opt/modules/3.2.10.5/bin/pdflatex...not found
> Checking for program /home/zampins/bin/pdflatex...not found
> Checking for program /usr/local/bin/pdflatex...not found
> Checking for program /usr/bin/pdflatex...found
> Defined make macro "PDFLATEX" to "/usr/bin/pdflatex"
> Checking for program /home/zampins/local/fenics-tools/bin/bfort...not found
> Checking for program /home/zampins/local/bin/bfort...not found
> Checking for program /home/zampins/local/anaconda/bin/bfort...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/bfort...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/bfort...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/bfort...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/bfort...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/bfort...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/bfort...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/bfort...not found
> Checking for program /opt/gcc/5.1.0/bin/bfort...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/bfort...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/bfort...not found
> Checking for program /opt/slurm/default/bin/bfort...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/bfort...not found
> Checking for program /opt/cray/craype/2.4.2/bin/bfort...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/bfort...not found
> Checking for program /opt/modules/3.2.10.5/bin/bfort...not found
> Checking for program /home/zampins/bin/bfort...not found
> Checking for program /usr/local/bin/bfort...not found
> Checking for program /usr/bin/bfort...not found
> Checking for program /bin/bfort...not found
> Checking for program /usr/bin/X11/bfort...not found
> Checking for program /usr/X11R6/bin/bfort...not found
> Checking for program /usr/games/bfort...not found
> Checking for program /sbin/bfort...not found
> Checking for program /usr/sbin/bfort...not found
> Checking for program /usr/lib/mit/bin/bfort...not found
> Checking for program /usr/lib/mit/sbin/bfort...not found
> Checking for program ./bfort...not found
> Checking for program /usr/lib/qt3/bin/bfort...not found
> Checking for program /opt/cray/bin/bfort...not found
> Checking for program /home/zampins/bfort...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/bfort...not found
> Checking for program /home/zampins/local/fenics-tools/bin/doctext...not found
> Checking for program /home/zampins/local/bin/doctext...not found
> Checking for program /home/zampins/local/anaconda/bin/doctext...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/doctext...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/doctext...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/doctext...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/doctext...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/doctext...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/doctext...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/doctext...not found
> Checking for program /opt/gcc/5.1.0/bin/doctext...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/doctext...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/doctext...not found
> Checking for program /opt/slurm/default/bin/doctext...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/doctext...not found
> Checking for program /opt/cray/craype/2.4.2/bin/doctext...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/doctext...not found
> Checking for program /opt/modules/3.2.10.5/bin/doctext...not found
> Checking for program /home/zampins/bin/doctext...not found
> Checking for program /usr/local/bin/doctext...not found
> Checking for program /usr/bin/doctext...not found
> Checking for program /bin/doctext...not found
> Checking for program /usr/bin/X11/doctext...not found
> Checking for program /usr/X11R6/bin/doctext...not found
> Checking for program /usr/games/doctext...not found
> Checking for program /sbin/doctext...not found
> Checking for program /usr/sbin/doctext...not found
> Checking for program /usr/lib/mit/bin/doctext...not found
> Checking for program /usr/lib/mit/sbin/doctext...not found
> Checking for program ./doctext...not found
> Checking for program /usr/lib/qt3/bin/doctext...not found
> Checking for program /opt/cray/bin/doctext...not found
> Checking for program /home/zampins/doctext...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/doctext...not found
> Checking for program /home/zampins/local/fenics-tools/bin/mapnames...not found
> Checking for program /home/zampins/local/bin/mapnames...not found
> Checking for program /home/zampins/local/anaconda/bin/mapnames...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/mapnames...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/mapnames...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/mapnames...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/mapnames...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/mapnames...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/mapnames...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/mapnames...not found
> Checking for program /opt/gcc/5.1.0/bin/mapnames...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/mapnames...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/mapnames...not found
> Checking for program /opt/slurm/default/bin/mapnames...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/mapnames...not found
> Checking for program /opt/cray/craype/2.4.2/bin/mapnames...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/mapnames...not found
> Checking for program /opt/modules/3.2.10.5/bin/mapnames...not found
> Checking for program /home/zampins/bin/mapnames...not found
> Checking for program /usr/local/bin/mapnames...not found
> Checking for program /usr/bin/mapnames...not found
> Checking for program /bin/mapnames...not found
> Checking for program /usr/bin/X11/mapnames...not found
> Checking for program /usr/X11R6/bin/mapnames...not found
> Checking for program /usr/games/mapnames...not found
> Checking for program /sbin/mapnames...not found
> Checking for program /usr/sbin/mapnames...not found
> Checking for program /usr/lib/mit/bin/mapnames...not found
> Checking for program /usr/lib/mit/sbin/mapnames...not found
> Checking for program ./mapnames...not found
> Checking for program /usr/lib/qt3/bin/mapnames...not found
> Checking for program /opt/cray/bin/mapnames...not found
> Checking for program /home/zampins/mapnames...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/mapnames...not found
> Checking for program /home/zampins/local/fenics-tools/bin/bib2html...not found
> Checking for program /home/zampins/local/bin/bib2html...not found
> Checking for program /home/zampins/local/anaconda/bin/bib2html...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/bib2html...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/bib2html...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/bib2html...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/bib2html...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/bib2html...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/bib2html...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/bib2html...not found
> Checking for program /opt/gcc/5.1.0/bin/bib2html...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/bib2html...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/bib2html...not found
> Checking for program /opt/slurm/default/bin/bib2html...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/bib2html...not found
> Checking for program /opt/cray/craype/2.4.2/bin/bib2html...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/bib2html...not found
> Checking for program /opt/modules/3.2.10.5/bin/bib2html...not found
> Checking for program /home/zampins/bin/bib2html...not found
> Checking for program /usr/local/bin/bib2html...not found
> Checking for program /usr/bin/bib2html...not found
> Checking for program /bin/bib2html...not found
> Checking for program /usr/bin/X11/bib2html...not found
> Checking for program /usr/X11R6/bin/bib2html...not found
> Checking for program /usr/games/bib2html...not found
> Checking for program /sbin/bib2html...not found
> Checking for program /usr/sbin/bib2html...not found
> Checking for program /usr/lib/mit/bin/bib2html...not found
> Checking for program /usr/lib/mit/sbin/bib2html...not found
> Checking for program ./bib2html...not found
> Checking for program /usr/lib/qt3/bin/bib2html...not found
> Checking for program /opt/cray/bin/bib2html...not found
> Checking for program /home/zampins/bib2html...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/bib2html...not found
> Bfort not found. Installing sowing for FortranStubs
> Pushing language C
> TEST checkDependencies from config.packages.sowing(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.sowing(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.sowing(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.sowing(config/BuildSystem/config/package.py:744)
> Checking for a functional sowing
> Looking for SOWING at git.sowing, hg.sowing or a directory starting with ['petsc-pkg-sowing']
> Found a copy of SOWING in git.sowing
> Executing: ['git', 'rev-parse', '--git-dir']
> stdout: .git
> Executing: ['git', 'cat-file', '-e', 'v1.1.25-p1^{commit}']
> Executing: ['git', 'fetch']
> Executing: ['git', 'rev-parse', 'v1.1.25-p1']
> stdout: bc33abe1e9818d95968d6897bfbfc35ed0c18b51
> Executing: ['git', 'stash']
> stdout:
> Saved working directory and index state WIP on (no branch): 07d9642 generate configure and include/sowingconfig.h.in
> HEAD is now at 07d9642 generate configure and include/sowingconfig.h.in
> Executing: ['git', 'clean', '-f', '-d', '-x']
> stdout:
> Removing pkg.gitcommit
> Removing sowing.petscconf
> Executing: ['git', 'checkout', '-f', 'bc33abe1e9818d95968d6897bfbfc35ed0c18b51']
> Have to rebuild SOWING, /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/pkg.gitcommit != /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/petsc/conf/pkg.gitcommit.sowing
> Running configure on SOWING; this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing && ./configure --prefix=/home/zampins/src/petsc/haswell_debug_gnu_mkl
> stdout:
> checking for ranlib... ranlib
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether install works... yes
> checking for ar... ar
> checking for gcc... gcc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling... no
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for c++... c++
> checking whether we are using the GNU C++ compiler... yes
> checking whether c++ accepts -g... yes
> checking for virtual path format... VPATH
> checking for latex... /usr/bin/latex
> checking for gs... /usr/bin/gs
> checking for pnmcrop... /usr/bin/pnmcrop
> checking for pbmtoxbm... /usr/bin/pbmtoxbm
> checking for ppmtogif... /usr/bin/ppmtogif
> checking for pnmquant... /usr/bin/pnmquant
> checking for perl... /usr/bin/perl
> checking how to run the C preprocessor... gcc -E
> checking for grep that handles long lines and -e... /usr/bin/grep
> checking for egrep... /usr/bin/grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking fcntl.h usability... yes
> checking fcntl.h presence... yes
> checking for fcntl.h... yes
> checking sys/time.h usability... yes
> checking sys/time.h presence... yes
> checking for sys/time.h... yes
> checking for unistd.h... (cached) yes
> checking pwd.h usability... yes
> checking pwd.h presence... yes
> checking for pwd.h... yes
> checking for stdlib.h... (cached) yes
> checking netdb.h usability... yes
> checking netdb.h presence... yes
> checking for netdb.h... yes
> checking for string.h... (cached) yes
> checking for an ANSI C-conforming const... yes
> checking for C/C++ restrict keyword... __restrict
> checking for uid_t in sys/types.h... yes
> checking for size_t... yes
> checking whether time.h and sys/time.h may both be included... yes
> checking whether struct tm is in sys/time.h or time.h... time.h
> checking size of void *... 8
> checking size of int... 4
> checking size of long... 8
> checking size of long long... 8
> checking for vprintf... yes
> checking for _doprnt... no
> checking for getcwd... yes
> checking for gethostname... yes
> checking for getwd... yes
> checking for mkdir... yes
> checking that mkdir accepts -p... yes
> checking for uname... yes
> checking for gethostbyname... yes
> checking how to run the C++ preprocessor... c++ -E
> checking time.h usability... yes
> checking time.h presence... yes
> checking for time.h... yes
> checking sys/param.h usability... yes
> checking sys/param.h presence... yes
> checking for sys/param.h... yes
> checking for realpath... yes
> checking for readlink... yes
> configure: creating ./config.status
> config.status: creating Makefile
> config.status: creating Makerules
> config.status: creating src/Makefile
> config.status: creating src/sys/Makefile
> config.status: creating src/sys/testing/Makefile
> config.status: creating src/tohtml/Makefile
> config.status: creating src/tohtml/tohtmlpath.h
> config.status: creating src/tohtml/testing/Makefile
> config.status: creating bin/pstoxbm
> config.status: creating bin/pstogif
> config.status: creating bin/bib2html
> config.status: creating src/bfort/Makefile
> config.status: creating src/bfort/testing/Makefile
> config.status: creating src/textfilt/Makefile
> config.status: creating src/doctext/Makefile
> config.status: creating src/doctext/docpath.h
> config.status: creating src/doctext/test/Makefile
> config.status: creating src/mapnames/Makefile
> config.status: creating src/bib2html/Makefile
> config.status: creating docs/Makefile
> config.status: creating docs/bfort/Makefile
> config.status: creating docs/doctext/Makefile
> config.status: creating docs/install/Makefile
> config.status: creating docs/tohtml/Makefile
> config.status: creating include/patchlevel.h
> config.status: creating include/textfilt/textpath.h
> config.status: creating include/sowingconfig.h
> config.status: executing bib2html commands
> Running make on SOWING; this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing && /usr/bin/gmake clean
> stdout:
> gmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing'
> for dir in src docs ; do ( cd $dir && /usr/bin/gmake clean ) ; done
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src'
> for dir in sys bfort tohtml doctext textfilt mapnames bib2html ; do ( cd $dir ; /usr/bin/gmake clean ) ; done
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/sys'
> rm -f *.o *~
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/sys'
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/bfort'
> /bin/rm -f *.o *~ bfort
> /bin/rm -f bfort\ win32/debug/*
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/bfort'
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/tohtml'
> /bin/rm -f *.o *~ tohtml tortf
> /bin/rm -f tohtml\ win32/debug/*
> (cd testing && /usr/bin/gmake clean )
> gmake[4]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/tohtml/testing'
> rm -rf test[1-9] test1[0-9] test2[0-9]
> rm -f test[1-9].html
> rm -f test1[0-9].html test2[0-9].html test7a.html
> rm -f test[0-9].htm test[1-2][0-9].htm
> rm -f inplace subfiles
> rm -f *.ler *.aux *.out
> gmake[4]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/tohtml/testing'
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/tohtml'
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/doctext'
> /bin/rm -f *.o *~ doctext doc2lt
> (cd test ; if [ -s Makefile ] ; then /usr/bin/gmake clean ; fi )
> gmake[4]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/doctext/test'
> rm -f *.o *~ *.3 *.2 *.html *.tex f1.cit
> gmake[4]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/doctext/test'
> /bin/rm -f doctext\ win32/debug/*
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/doctext'
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/textfilt'
> /bin/rm -f *.o *~
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/textfilt'
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/mapnames'
> /bin/rm -f *.o *~ mapnames ccc test1.html test1.tex test1nc.tex test1nc.html test1.pmap
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/mapnames'
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/bib2html'
> rm -f tout.htm tout-bib.htm
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/bib2html'
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src'
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs'
> make[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/bfort'
> rm -f bfort.pdf \
> *.aux *.dvi *.toc *.log *.fn *.hux *.err *.blg *.bbl
> make[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/bfort'
> make[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/doctext'
> rm -f doctext.pdf \
> make[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/doctext'
> make[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/install'
> rm -f install.pdf \
> make[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/install'
> make[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/tohtml'
> rm -f tohtml.pdf \
> make[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs/tohtml'
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/docs'
> /bin/rm -f lib/libsowing.a lib/libtfilter.a
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing'
> stdout:
> (cd src/sys && /usr/bin/gmake )
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/sys'
> gcc -I../../include -I../../include -c arch.c
> gcc -I../../include -I../../include -c txt.c
> gcc -I../../include -I../../include -c daytime.c
> gcc -I../../include -I../../include -c file.c
> gcc -I../../include -I../../include -c tr.c
> gcc -I../../include -I../../include -c getopts.c
> gcc -I../../include -I../../include -c rdconfig.c
> ar cr ../../lib/libsowing.a arch.o txt.o daytime.o file.o tr.o getopts.o rdconfig.o
> ranlib ../../lib/libsowing.a
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/sys'
> (cd src/tohtml && /usr/bin/gmake )
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/tohtml'
> gcc -I../../include -I. -I../../include -c tohtml.c
> gcc -I../../include -I. -I../../include -c tex2html.c
> gcc -I../../include -I. -I../../include -c search.c
> gcc -I../../include -I. -I../../include -c texactio.c
> gcc -I../../include -I. -I../../include -c rdaux.c
> gcc -I../../include -I. -I../../include -c rdindx.c
> gcc -I../../include -I. -I../../include -c label.c
> gcc -I../../include -I. -I../../include -c scan.c
> gcc -I../../include -I. -I../../include -c refmap.c
> gcc -I../../include -I. -I../../include -c style.c
> gcc -I../../include -I. -I../../include -c dimen.c
> gcc -I../../include -I. -I../../include -c userdef.c
> gcc -I../../include -I. -I../../include -c tabular.c
> gcc -I../../include -I. -I../../include -c biblio.c
> gcc -I../../include -I. -I../../include -c environ.c
> gcc -I../../include -I. -I../../include -c math.c
> gcc -I../../include -I. -I../../include -c rddefs.c
> gcc -I../../include -I. -I../../include -c latexinfo.c
> gcc -I../../include -I. -I../../include -c accent.c
> gcc -I../../include -I. -I../../include -c simpleif.c
> gcc -o tohtml tohtml.o tex2html.o search.o texactio.o rdaux.o rdindx.o label.o scan.o refmap.o style.o dimen.o userdef.o tabular.o biblio.o environ.o math.o rddefs.o latexinfo.o accent.o simpleif.o ../../lib/libsowing.a
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/tohtml'
> (cd src/bfort && /usr/bin/gmake )
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/bfort'
> gcc -DBASEDEF='"/home/zampins/src/petsc/haswell_debug_gnu_mkl/share/bfort-base.txt"' -DBASEPATH='"/home/zampins/src/petsc/haswell_debug_gnu_mkl/share"' -I../../include -I../../include -c bfort.c
> gcc -DBASEDEF='"/home/zampins/src/petsc/haswell_debug_gnu_mkl/share/bfort-base.txt"' -DBASEPATH='"/home/zampins/src/petsc/haswell_debug_gnu_mkl/share"' -I../../include -I../../include -c doc.c
> gcc -o bfort bfort.o doc.o ../../lib/libsowing.a
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/bfort'
> (cd src/textfilt && /usr/bin/gmake )
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/textfilt'
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c cmdline.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c file.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c instream.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c outstream.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c search.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c maptok.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c textout.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c texthtml.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c textnroff.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c texttex.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c inutil.cc
> c++ -I../../include/textfilt -I../../include -I../../include -I../../include/textfilt -c errhand.cc
> ar cr ../../lib/libtfilter.a cmdline.o file.o instream.o outstream.o search.o maptok.o textout.o texthtml.o textnroff.o texttex.o inutil.o errhand.o
> ranlib ../../lib/libtfilter.a
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/textfilt'
> (cd src/doctext && /usr/bin/gmake )
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/doctext'
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c doctext.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c docutil.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c keyword.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c dotfmat.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c incfiles.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c quotefmt.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c textb.cc
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c docfields.cc
> c++ -o doctext doctext.o docutil.o keyword.o dotfmat.o \
> incfiles.o quotefmt.o textb.o docfields.o ../../lib/libtfilter.a
> c++ -I../../include/textfilt -I../../include -I. -I../../include -c doc2lt.cc
> c++ -o doc2lt doc2lt.o docutil.o docfields.o ../../lib/libtfilter.a
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/doctext'
> gmake[2]: Nothing to be done for `ALL'.
> (cd src/mapnames && /usr/bin/gmake )
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/mapnames'
> c++ -I../../include/textfilt -I../../include -c mapnames.cc
> c++ -o mapnames mapnames.o ../../lib/libtfilter.a
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing/src/mapnames'
> Running make install on SOWING; this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing && /usr/bin/gmake install
> stdout:
> /usr/bin/install -c bin/bib2html /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bib2html
> /usr/bin/install -c src/doctext/doctext /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/doctext
> /usr/bin/install -c src/doctext/doc2lt /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/doc2lt
> /usr/bin/install -c src/tohtml/tohtml /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/tohtml
> if [ "`cd bin && pwd`" != "`cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin && pwd`" ] ; then \
> /usr/bin/install -c bin/pstoxbm /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/pstoxbm ; \
> /usr/bin/install -c bin/pstogif /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/pstogif ; \
> fi
> /usr/bin/install -c src/bfort/bfort /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bfort
> /usr/bin/install -c src/mapnames/mapnames /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/mapnames
> if [ "`cd ./share && pwd`" != "`cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/share && pwd`" ] ; then \
> /usr/bin/install -c -m 644 ./share/pstoppm.ps /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/pstoppm.ps ;\
> /usr/bin/install -c -m 644 ./share/basedefs.txt /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/basedefs.txt ;\
> /usr/bin/install -c -m 644 ./share/blueball.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/blueball.gif ;\
> /usr/bin/install -c -m 644 ./share/greenball.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/greenball.gif ;\
> /usr/bin/install -c -m 644 ./share/purpleball.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/purpleball.gif ;\
> /usr/bin/install -c -m 644 ./share/redball.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/redball.gif ;\
> /usr/bin/install -c -m 644 ./share/yellowball.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/yellowball.gif ;\
> /usr/bin/install -c -m 644 ./share/next.xbm /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/next.xbm ;\
> /usr/bin/install -c -m 644 ./share/up.xbm /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/up.xbm ;\
> /usr/bin/install -c -m 644 ./share/previous.xbm /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/previous.xbm ;\
> /usr/bin/install -c -m 644 ./share/next.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/next.gif ;\
> /usr/bin/install -c -m 644 ./share/up.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/up.gif ;\
> /usr/bin/install -c -m 644 ./share/previous.gif /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/previous.gif ;\
> /usr/bin/install -c -m 644 ./share/html.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/html.def ;\
> /usr/bin/install -c -m 644 ./share/latex.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/latex.def ;\
> /usr/bin/install -c -m 644 ./share/nroff.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/nroff.def ;\
> /usr/bin/install -c -m 644 ./share/refman.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/refman.def ;\
> /usr/bin/install -c -m 644 ./share/refman.sty /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/refman.sty ;\
> /usr/bin/install -c -m 644 ./share/doctext/html.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/html.def ;\
> /usr/bin/install -c -m 644 ./share/doctext/htmlcolor.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/htmlcolor.def ;\
> /usr/bin/install -c -m 644 ./share/doctext/htmltabl.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/htmltabl.def ;\
> /usr/bin/install -c -m 644 ./share/doctext/htmlargtbl.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/htmlargtbl.def ;\
> /usr/bin/install -c -m 644 ./share/doctext/latex.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/latex.def ;\
> /usr/bin/install -c -m 644 ./share/doctext/latexargtbl.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/latexargtbl.def ;\
> /usr/bin/install -c -m 644 ./share/doctext/nroff.def /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/doctext/nroff.def ;\
> fi
> if [ "`cd ./man/man1 && pwd`" != "`cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/man/man1 && pwd`" ] ; then \
> /usr/bin/install -c -m 644 ./man/man1/tohtml.1 /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/man/man1/tohtml.1 ;\
> /usr/bin/install -c -m 644 ./man/man1/doctext.1 /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/man/man1/doctext.1 ;\
> /usr/bin/install -c -m 644 ./man/man1/bfort.1 /home/zampins/src/petsc/haswell_debug_gnu_mkl/share/man/man1/bfort.1 ;\
> fi
> ********Output of running make on SOWING follows *******
> config.status: executing bib2html commandsgmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing'
> rm -f *.o *~
> /bin/rm -f *.o *~
> rm -f bfort.pdf \
> rm -f doctext.pdf \
> rm -f install.pdf \
> rm -f tohtml.pdf \
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing'gmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing'
> fi
> fi
> fi
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.sowing'********End of Output of running make on SOWING *******
> Not checking for library in Download SOWING: [] because no functions given to check for
> Checking for headers Download SOWING: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> TEST checkSharedLibrary from config.packages.sowing(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.sowing(config/BuildSystem/config/package.py:792)
> By default we don't care about checking if the library is shared
> Popping language C
> Checking for program /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bfort...found
> Defined make macro "BFORT" to "/home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bfort"
> Checking for program /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/doctext...found
> Defined make macro "DOCTEXT" to "/home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/doctext"
> Checking for program /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/mapnames...found
> Defined make macro "MAPNAMES" to "/home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/mapnames"
> Checking for program /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bib2html...found
> Defined make macro "BIB2HTML" to "/home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bib2html"
> Running /home/zampins/src/petsc/haswell_debug_gnu_mkl/bin/bfort to generate fortran stubs
> TEST alternateConfigureLibrary from config.packages.pthread(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.pthread(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.pami(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.pami(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.opengles(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.opengles(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.giflib(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.giflib(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.mpe(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.mpe(config/BuildSystem/config/package.py:796)
> Checking for program /home/zampins/local/fenics-tools/bin/lgrind...not found
> Checking for program /home/zampins/local/bin/lgrind...not found
> Checking for program /home/zampins/local/anaconda/bin/lgrind...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/lgrind...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/lgrind...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/lgrind...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/lgrind...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/lgrind...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/lgrind...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/lgrind...not found
> Checking for program /opt/gcc/5.1.0/bin/lgrind...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/lgrind...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/lgrind...not found
> Checking for program /opt/slurm/default/bin/lgrind...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/lgrind...not found
> Checking for program /opt/cray/craype/2.4.2/bin/lgrind...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/lgrind...not found
> Checking for program /opt/modules/3.2.10.5/bin/lgrind...not found
> Checking for program /home/zampins/bin/lgrind...not found
> Checking for program /usr/local/bin/lgrind...not found
> Checking for program /usr/bin/lgrind...not found
> Checking for program /bin/lgrind...not found
> Checking for program /usr/bin/X11/lgrind...not found
> Checking for program /usr/X11R6/bin/lgrind...not found
> Checking for program /usr/games/lgrind...not found
> Checking for program /sbin/lgrind...not found
> Checking for program /usr/sbin/lgrind...not found
> Checking for program /usr/lib/mit/bin/lgrind...not found
> Checking for program /usr/lib/mit/sbin/lgrind...not found
> Checking for program ./lgrind...not found
> Checking for program /usr/lib/qt3/bin/lgrind...not found
> Checking for program /opt/cray/bin/lgrind...not found
> Checking for program /home/zampins/lgrind...not found
> Checking for program /home/zampins/src/petsc/bin/win32fe/lgrind...not found
> TEST alternateConfigureLibrary from config.packages.gmp(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.gmp(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.mpfr(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.mpfr(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.opengl(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.opengl(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.glut(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.glut(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.ctetgen(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.ctetgen(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.concurrencykit(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.concurrencykit(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.boost(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.boost(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.hwloc(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.PARTY(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.PARTY(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.Numpy(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.Numpy(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.petsc4py(/home/zampins/src/petsc/config/BuildSystem/config/packages/petsc4py.py:121)
> TESTING: alternateConfigureLibrary from config.packages.petsc4py(config/BuildSystem/config/packages/petsc4py.py:121)
> Defined make rule "petsc4py-build" with dependencies "" and code []
> Defined make rule "petsc4py-install" with dependencies "" and code []
> TEST alternateConfigureLibrary from config.packages.mpi4py(/home/zampins/src/petsc/config/BuildSystem/config/packages/mpi4py.py:71)
> TESTING: alternateConfigureLibrary from config.packages.mpi4py(config/BuildSystem/config/packages/mpi4py.py:71)
> Defined make rule "mpi4py-build" with dependencies "" and code []
> Defined make rule "mpi4py-install" with dependencies "" and code []
> TEST alternateConfigureLibrary from config.packages.Matlab(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.Matlab(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.MatlabEngine(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.MatlabEngine(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.Mathematica(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.Mathematica(config/BuildSystem/config/package.py:796)
> Pushing language C
> TEST checkDependencies from config.packages.X(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.X(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.X(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.X(config/BuildSystem/config/package.py:744)
> Checking for a functional X
> Checking for library in Compiler specific search X: []
> Checking for functions [XSetWMName] in library [] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> /* Override any gcc2 internal prototype to avoid an error. */
> char XSetWMName();
> static void _check_XSetWMName() { XSetWMName(); }
> int main() {
> _check_XSetWMName();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_XSetWMName':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `XSetWMName'
> Popping language C
> Checking for library in Compiler specific search X: ['libX11.a']
> Checking for functions [XSetWMName] in library ['libX11.a'] []
> Pushing language C
> Successful compile:
> Source:
> char XSetWMName();
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lX11 -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> /usr/lib/../lib64/libX11.a(xim_trans.o): In function `_XimXTransSocketOpen':
> /usr/include/X11/Xtrans/Xtranssock.c:472: warning: Using 'getaddrinfo' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> /usr/lib/../lib64/libX11.a(xim_trans.o): In function `UnixHostReallyLocal':
> /usr/include/X11/Xtrans/Xtranssock.c:1973: warning: Using 'gethostbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> /usr/lib/../lib64/libX11.a(xim_trans.o): In function `_XimXTransSocketINETConnect':
> /usr/include/X11/Xtrans/Xtranssock.c:1753: warning: Using 'getservbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `wait_or_poll_for_event':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:100: undefined reference to `xcb_wait_for_event'
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `process_responses':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:179: undefined reference to `xcb_connection_has_error'
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `condition_wait':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:74: undefined reference to `xcb_xlib_unlock'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:76: undefined reference to `xcb_xlib_lock'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:155: undefined reference to `xcb_poll_for_reply'
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `_XReply':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:366: undefined reference to `xcb_wait_for_reply'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:363: undefined reference to `xcb_xlib_unlock'
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `_XAllocIDs':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:300: undefined reference to `xcb_generate_id'
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `_XIDHandler':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:266: undefined reference to `xcb_generate_id'
> /usr/lib/../lib64/libX11.a(xcb_io.o): In function `_XSend':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:235: undefined reference to `xcb_flush'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_io.c:104: undefined reference to `xcb_poll_for_event'
> /usr/lib/../lib64/libX11.a(xcb_lock.o): In function `_XPutXCBBuffer':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:181: undefined reference to `xcb_get_request_sent'
> /usr/lib/../lib64/libX11.a(xcb_lock.o): In function `issue_complete_request':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:145: undefined reference to `xcb_get_request_sent'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:148: undefined reference to `xcb_send_request'
> /usr/lib/../lib64/libX11.a(xcb_lock.o): In function `_XGetXCBBuffer':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:68: undefined reference to `xcb_get_request_sent'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:69: undefined reference to `xcb_connection_has_error'
> /usr/lib/../lib64/libX11.a(xcb_lock.o): In function `_XCBUnlockDisplay':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:41: undefined reference to `xcb_xlib_unlock'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:33: undefined reference to `xcb_get_request_sent'
> /usr/lib/../lib64/libX11.a(xcb_lock.o): In function `_XCBLockDisplay':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_lock.c:21: undefined reference to `xcb_xlib_lock'
> /usr/lib/../lib64/libX11.a(ClDisplay.o): In function `XCloseDisplay':
> /usr/src/packages/BUILD/libX11-1.1.5/src/ClDisplay.c:78: undefined reference to `xcb_disconnect'
> /usr/lib/../lib64/libX11.a(OpenDis.o): In function `OutOfMemory':
> /usr/src/packages/BUILD/libX11-1.1.5/src/OpenDis.c:929: undefined reference to `xcb_disconnect'
> /usr/lib/../lib64/libX11.a(OpenDis.o): In function `XOpenDisplay':
> /usr/src/packages/BUILD/libX11-1.1.5/src/OpenDis.c:366: undefined reference to `xcb_get_setup'
> /usr/src/packages/BUILD/libX11-1.1.5/src/OpenDis.c:676: undefined reference to `xcb_get_maximum_request_length'
> /usr/lib/../lib64/libX11.a(xcb_disp.o): In function `_XConnectXCB':
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_disp.c:74: undefined reference to `xcb_parse_display'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_disp.c:85: undefined reference to `xcb_connect_to_display_with_auth_info'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_disp.c:90: undefined reference to `xcb_get_file_descriptor'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_disp.c:94: undefined reference to `xcb_generate_id'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_disp.c:96: undefined reference to `xcb_connection_has_error'
> /usr/src/packages/BUILD/libX11-1.1.5/src/xcb_disp.c:87: undefined reference to `xcb_connect'
> collect2: error: ld returned 1 exit status
> Popping language C
> X: SearchDir DirPath not found.. skipping: /opt/X11
> X: SearchDir DirPath not found.. skipping: /Developer/SDKs/MacOSX10.5.sdk/usr/X11
> X: SearchDir DirPath not found.. skipping: /Developer/SDKs/MacOSX10.4u.sdk/usr/X11R6
> X: SearchDir DirPath not found.. skipping: /usr/X11
> Checking for library in Package specific search directory X: ['/usr/X11R6/lib/libX11.a']
> Contents: ['bin', 'lib64', 'lib']
> Checking for functions [XSetWMName] in library ['/usr/X11R6/lib/libX11.a'] []
> Pushing language C
> Successful compile:
> Source:
> char XSetWMName();
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/usr/X11R6/lib -L/usr/X11R6/lib -lX11 -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Possible ERROR while running linker: exit code 256
> stderr:
> Popping language C
> Checking for library in Package specific search directory X: ['/usr/X11R6/lib64/libX11.a']
> Checking for functions [XSetWMName] in library ['/usr/X11R6/lib64/libX11.a'] []
> Pushing language C
> Successful compile:
> Source:
> char XSetWMName();
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/usr/X11R6/lib64 -L/usr/X11R6/lib64 -lX11 -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Popping language C
> X: SearchDir DirPath not found.. skipping: /usr/X11R5
> X: SearchDir DirPath not found.. skipping: /usr/X11R4
> X: SearchDir DirPath not found.. skipping: /usr/local/X11
> X: SearchDir DirPath not found.. skipping: /usr/local/X11R6
> X: SearchDir DirPath not found.. skipping: /usr/local/X11R5
> X: SearchDir DirPath not found.. skipping: /usr/local/X11R4
> X: SearchDir DirPath not found.. skipping: /usr/X386
> X: SearchDir DirPath not found.. skipping: /usr/x386
> X: SearchDir DirPath not found.. skipping: /usr/XFree86/X11
> Checking for library in Package specific search directory X: ['/usr/local/lib/libX11.a']
> Contents: ['modulefiles', 'man', 'etc', 'src', 'include', 'sbin', 'bin', 'share', 'lib64', 'lib', 'games']
> Checking for functions [XSetWMName] in library ['/usr/local/lib/libX11.a'] []
> Pushing language C
> Successful compile:
> Source:
> char XSetWMName();
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lX11 -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Popping language C
> Checking for library in Package specific search directory X: ['/usr/local/lib64/libX11.a']
> Checking for functions [XSetWMName] in library ['/usr/local/lib64/libX11.a'] []
> Pushing language C
> Successful compile:
> Source:
> char XSetWMName();
> int main() {
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib64 -L/usr/local/lib64 -lX11 -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Popping language C
> X: SearchDir DirPath not found.. skipping: /usr/local/x11r5
> X: SearchDir DirPath not found.. skipping: /usr/lpp/Xamples
> X: SearchDir DirPath not found.. skipping: /usr/openwin
> X: SearchDir DirPath not found.. skipping: /usr/openwin/share
> TEST checkSharedLibrary from config.packages.X(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.X(config/BuildSystem/config/package.py:792)
> Popping language C
> TEST alternateConfigureLibrary from config.packages.szlib(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.szlib(config/BuildSystem/config/package.py:796)
> Called if --with-packagename=0; does nothing by default
> TEST alternateConfigureLibrary from config.packages.zlib(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.zlib(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.openmp(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.openmp(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.opencl(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.opencl(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.cuda(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.cuda(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.viennacl(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.viennacl(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.cusp(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.cusp(config/BuildSystem/config/package.py:796)
> TEST configureVecCUDA from config.utilities.veccuda(/home/zampins/src/petsc/config/BuildSystem/config/utilities/veccuda.py:15)
> TESTING: configureVecCUDA from config.utilities.veccuda(config/BuildSystem/config/utilities/veccuda.py:15)
> Configure VecCUDA as fallback CUDA vector if CUSP and VIENNACL are not present
> TEST locateCMake from config.packages.cmake(/home/zampins/src/petsc/config/BuildSystem/config/packages/cmake.py:36)
> TESTING: locateCMake from config.packages.cmake(config/BuildSystem/config/packages/cmake.py:36)
> Looking for default CMake executable
> Checking for program /home/zampins/local/fenics-tools/bin/cmake...not found
> Checking for program /home/zampins/local/bin/cmake...found
> Defined make macro "CMAKE" to "/home/zampins/local/bin/cmake"
> Looking for default CTest executable
> Checking for program /home/zampins/local/fenics-tools/bin/ctest...not found
> Checking for program /home/zampins/local/bin/ctest...found
> Defined make macro "CTEST" to "/home/zampins/local/bin/ctest"
> TEST alternateConfigureLibrary from config.packages.googletest(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.googletest(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.unittestcpp(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.unittestcpp(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.eigen(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.eigen(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.libpng(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.libpng(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.tetgen(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.tetgen(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.tchem(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.tchem(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.saws(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.saws(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.Triangle(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.Triangle(config/BuildSystem/config/package.py:796)
> Pushing language C
> TEST checkDependencies from config.packages.PTScotch(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.PTScotch(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.PTScotch(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.PTScotch(config/BuildSystem/config/package.py:744)
> Find an installation and check if it can work with PETSc
> Checking for a functional PTScotch
> Looking for PTSCOTCH at git.ptscotch, hg.ptscotch or a directory starting with ['scotch']
> Found a copy of PTSCOTCH in scotch_6.0.3
> Creating PTScotch /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/scotch_6.0.3/src/Makefile.inc
> Checking for program /home/zampins/local/fenics-tools/bin/bison...not found
> Checking for program /home/zampins/local/bin/bison...not found
> Checking for program /home/zampins/local/anaconda/bin/bison...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/bison...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/bison...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/bison...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/bison...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/bison...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/bison...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/bison...not found
> Checking for program /opt/gcc/5.1.0/bin/bison...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/bison...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/bison...not found
> Checking for program /opt/slurm/default/bin/bison...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/bison...not found
> Checking for program /opt/cray/craype/2.4.2/bin/bison...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/bison...not found
> Checking for program /opt/modules/3.2.10.5/bin/bison...not found
> Checking for program /home/zampins/bin/bison...not found
> Checking for program /usr/local/bin/bison...not found
> Checking for program /usr/bin/bison...found
> Defined make macro "BISON" to "/usr/bin/bison"
> Checking for program /home/zampins/local/fenics-tools/bin/flex...not found
> Checking for program /home/zampins/local/bin/flex...not found
> Checking for program /home/zampins/local/anaconda/bin/flex...not found
> Checking for program /opt/cray/rca/1.0.0-2.0502.60530.1.62.ari/bin/flex...not found
> Checking for program /opt/cray/alps/5.2.4-2.0502.9774.31.11.ari/sbin/flex...not found
> Checking for program /opt/cray/dvs/2.5_0.9.0-1.0502.2188.1.116.ari/bin/flex...not found
> Checking for program /opt/cray/xpmem/0.1-2.0502.64982.5.3.ari/bin/flex...not found
> Checking for program /opt/cray/pmi/5.0.10-1.0000.11050.0.0.ari/bin/flex...not found
> Checking for program /opt/cray/ugni/6.0-1.0502.10863.8.29.ari/bin/flex...not found
> Checking for program /opt/cray/udreg/2.3.2-1.0502.10518.2.17.ari/bin/flex...not found
> Checking for program /opt/gcc/5.1.0/bin/flex...not found
> Checking for program /sw/xc40/darshan/2.3.1/cle5.2_gnu4.9.3/bin/flex...not found
> Checking for program /opt/cray/eslogin/eswrap/1.3.3-1.020200.1278.0/bin/flex...not found
> Checking for program /opt/slurm/default/bin/flex...not found
> Checking for program /opt/cray/mpt/7.2.6/gni/bin/flex...not found
> Checking for program /opt/cray/craype/2.4.2/bin/flex...not found
> Checking for program /opt/cray/switch/1.0-1.0502.60522.1.61.ari/bin/flex...not found
> Checking for program /opt/modules/3.2.10.5/bin/flex...not found
> Checking for program /home/zampins/bin/flex...not found
> Checking for program /usr/local/bin/flex...not found
> Checking for program /usr/bin/flex...found
> Defined make macro "FLEX" to "/usr/bin/flex"
> Pushing language C
> Checking for functions [gzwrite] in library ['-lz'] []
> Pushing language C
> Successful compile:
> Source:
> char gzwrite();
> static void _check_gzwrite() { gzwrite(); }
> int main() {
> _check_gzwrite();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBZ" to "1"
> Popping language C
> Adding ['-lz'] to LIBS
> Checking for functions [pthread_barrier_destroy] in library ['-lpthread'] []
> Pushing language C
> Successful compile:
> Source:
> char pthread_barrier_destroy();
> static void _check_pthread_barrier_destroy() { pthread_barrier_destroy(); }
> int main() {
> _check_pthread_barrier_destroy();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBPTHREAD" to "1"
> Popping language C
> Adding ['-lpthread'] to LIBS
> Checking for functions [sin] in library ['-lm'] []
> Pushing language C
> Possible ERROR while running compiler:
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:4:6: warning: conflicting types for built-in function 'sin'
> char sin();
> Source:
> char sin();
> static void _check_sin() { sin(); }
> int main() {
> _check_sin();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBM" to "1"
> Popping language C
> Adding ['-lm'] to LIBS
> Checking for functions [timer_create] in library ['-lrt'] []
> Pushing language C
> Successful compile:
> Source:
> char timer_create();
> static void _check_timer_create() { timer_create(); }
> int main() {
> _check_timer_create();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBRT" to "1"
> Popping language C
> Adding ['-lrt'] to LIBS
> Executing: uname -s
> stdout: Linux
> Popping language C
> Do not need to rebuild PTSCOTCH
> Checking for library in Download PTSCOTCH: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libptesmumps.a', 'libptscotch.a', 'libptscotcherr.a', 'libscotch.a', 'libscotcherr.a']
> Contents: ['include', 'lib', 'bin', 'externalpackages', 'share', 'initial_cache_file.cmake', 'CMakeFiles', 'obj', 'Makefile', 'cmake_install.cmake', 'CMakeCache.txt']
> TEST check from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:159)
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:159)
> Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
> - libDir may be a list of directories
> - libName may be a list of library names
> Checking for functions [SCOTCH_archBuild] in library ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libptesmumps.a', 'libptscotch.a', 'libptscotcherr.a', 'libscotch.a', 'libscotcherr.a'] []
> Pushing language C
> Successful compile:
> Source:
> char SCOTCH_archBuild();
> static void _check_SCOTCH_archBuild() { SCOTCH_archBuild(); }
> int main() {
> _check_SCOTCH_archBuild();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lptesmumps -lptscotch -lptscotcherr -lscotch -lscotcherr -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBPTESMUMPS" to "1"
> Defined "HAVE_LIBPTSCOTCH" to "1"
> Defined "HAVE_LIBPTSCOTCHERR" to "1"
> Defined "HAVE_LIBSCOTCH" to "1"
> Defined "HAVE_LIBSCOTCHERR" to "1"
> Popping language C
> Checking for headers Download PTSCOTCH: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Pushing language C
> TEST checkInclude from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:86)
> TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
> Checks if a particular include file can be found along particular include paths
> Checking for header files ['ptscotch.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Checking include with compiler flags var CPPFLAGS ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/ptscotch.h" 1
> # 69 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/ptscotch.h"
> # 1 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/scotch.h" 1
> # 76 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/scotch.h"
> typedef int32_t SCOTCH_Idx;
> typedef int32_t SCOTCH_Num;
> # 110 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/scotch.h"
> typedef struct {
> double dummy[8];
> } SCOTCH_Arch;
> typedef struct {
> double dummy[2];
> } SCOTCH_Geom;
> typedef struct {
> double dummy[13];
> } SCOTCH_Graph;
> typedef struct {
> double dummy[15];
> } SCOTCH_Mesh;
> typedef struct {
> double dummy[4];
> } SCOTCH_Mapping;
> typedef struct {
> double dummy[12];
> } SCOTCH_Ordering;
> typedef struct {
> double dummy[1];
> } SCOTCH_Strat;
> # 146 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/scotch.h"
> SCOTCH_Arch * SCOTCH_archAlloc (void);
> int SCOTCH_archInit (SCOTCH_Arch * const);
> void SCOTCH_archExit (SCOTCH_Arch * const);
> int SCOTCH_archLoad (SCOTCH_Arch * const, FILE * const);
> int SCOTCH_archSave (const SCOTCH_Arch * const, FILE * const);
> int SCOTCH_archBuild (SCOTCH_Arch * const, const SCOTCH_Graph * const, const SCOTCH_Num, const SCOTCH_Num * const, const SCOTCH_Strat * const);
> char * SCOTCH_archName (const SCOTCH_Arch * const);
> SCOTCH_Num SCOTCH_archSize (const SCOTCH_Arch * const);
> int SCOTCH_archVar (const SCOTCH_Arch * const);
> int SCOTCH_archCmplt (SCOTCH_Arch * const, const SCOTCH_Num);
> int SCOTCH_archCmpltw (SCOTCH_Arch * const, const SCOTCH_Num, const SCOTCH_Num * const);
> int SCOTCH_archHcub (SCOTCH_Arch * const, const SCOTCH_Num);
> int SCOTCH_archMesh2 (SCOTCH_Arch * const, const SCOTCH_Num, const SCOTCH_Num);
> int SCOTCH_archMesh3 (SCOTCH_Arch * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num);
> int SCOTCH_archTleaf (SCOTCH_Arch * const, const SCOTCH_Num, const SCOTCH_Num * const, const SCOTCH_Num * const);
> int SCOTCH_archTorus2 (SCOTCH_Arch * const, const SCOTCH_Num, const SCOTCH_Num);
> int SCOTCH_archTorus3 (SCOTCH_Arch * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num);
> int SCOTCH_archVcmplt (SCOTCH_Arch * const);
> int SCOTCH_archVhcub (SCOTCH_Arch * const);
> void SCOTCH_errorProg (const char * const);
> void SCOTCH_errorPrint (const char * const, ...);
> void SCOTCH_errorPrintW (const char * const, ...);
> SCOTCH_Geom * SCOTCH_geomAlloc (void);
> int SCOTCH_geomInit (SCOTCH_Geom * const);
> void SCOTCH_geomExit (SCOTCH_Geom * const);
> void SCOTCH_geomData (const SCOTCH_Geom * const, SCOTCH_Num * const, double ** const);
> SCOTCH_Graph * SCOTCH_graphAlloc (void);
> int SCOTCH_graphInit (SCOTCH_Graph * const);
> void SCOTCH_graphExit (SCOTCH_Graph * const);
> void SCOTCH_graphFree (SCOTCH_Graph * const);
> int SCOTCH_graphLoad (SCOTCH_Graph * const, FILE * const, const SCOTCH_Num, const SCOTCH_Num);
> int SCOTCH_graphSave (const SCOTCH_Graph * const, FILE * const);
> int SCOTCH_graphBuild (SCOTCH_Graph * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num, const SCOTCH_Num * const, const SCOTCH_Num * const);
> int SCOTCH_graphCoarsen (const SCOTCH_Graph * const, SCOTCH_Graph * const, SCOTCH_Num * const, const SCOTCH_Num, const double);
> int SCOTCH_graphColor (const SCOTCH_Graph * const, SCOTCH_Num * const, SCOTCH_Num * const, const SCOTCH_Num);
> SCOTCH_Num SCOTCH_graphBase (SCOTCH_Graph * const, const SCOTCH_Num baseval);
> int SCOTCH_graphCheck (const SCOTCH_Graph * const);
> void SCOTCH_graphSize (const SCOTCH_Graph * const, SCOTCH_Num * const, SCOTCH_Num * const);
> void SCOTCH_graphData (const SCOTCH_Graph * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num * const, SCOTCH_Num ** const, SCOTCH_Num ** const);
> void SCOTCH_graphStat (const SCOTCH_Graph * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const);
> int SCOTCH_graphGeomLoadChac (SCOTCH_Graph * const, SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphGeomLoadHabo (SCOTCH_Graph * const, SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphGeomLoadMmkt (SCOTCH_Graph * const, SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphGeomLoadScot (SCOTCH_Graph * const, SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphGeomSaveChac (const SCOTCH_Graph * const, const SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphGeomSaveMmkt (const SCOTCH_Graph * const, const SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphGeomSaveScot (const SCOTCH_Graph * const, const SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_graphMapInit (const SCOTCH_Graph * const, SCOTCH_Mapping * const, const SCOTCH_Arch * const, SCOTCH_Num * const);
> void SCOTCH_graphMapExit (const SCOTCH_Graph * const, SCOTCH_Mapping * const);
> int SCOTCH_graphMapLoad (const SCOTCH_Graph * const, const SCOTCH_Mapping * const, FILE * const);
> int SCOTCH_graphTabLoad (const SCOTCH_Graph * const, SCOTCH_Num * const, FILE * const);
> int SCOTCH_graphMapSave (const SCOTCH_Graph * const, const SCOTCH_Mapping * const, FILE * const);
> int SCOTCH_graphMapView (const SCOTCH_Graph * const, const SCOTCH_Mapping * const, FILE * const);
> int SCOTCH_graphRemapView (const SCOTCH_Graph * const, const SCOTCH_Mapping * const, const SCOTCH_Mapping * const, const double, SCOTCH_Num *, FILE * const);
> int SCOTCH_graphRemapViewRaw (const SCOTCH_Graph * const, const SCOTCH_Mapping * const, const SCOTCH_Mapping * const, const double, SCOTCH_Num *, FILE * const);
> int SCOTCH_graphMapCompute (SCOTCH_Graph * const, SCOTCH_Mapping * const, SCOTCH_Strat * const);
> int SCOTCH_graphMapFixedCompute (SCOTCH_Graph * const, SCOTCH_Mapping * const, SCOTCH_Strat * const);
> int SCOTCH_graphRemapCompute (SCOTCH_Graph * const, SCOTCH_Mapping * const, SCOTCH_Mapping * const, const double, const SCOTCH_Num *, SCOTCH_Strat * const);
> int SCOTCH_graphRemapFixedCompute (SCOTCH_Graph * const, SCOTCH_Mapping * const, SCOTCH_Mapping * const, const double, const SCOTCH_Num *, SCOTCH_Strat * const);
> int SCOTCH_graphMap (SCOTCH_Graph * const, const SCOTCH_Arch * const, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphMapFixed (SCOTCH_Graph * const, const SCOTCH_Arch * const, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphRemap (SCOTCH_Graph * const, const SCOTCH_Arch * const, SCOTCH_Num *, const double, const SCOTCH_Num *, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphRemapFixed (SCOTCH_Graph * const, const SCOTCH_Arch * const, SCOTCH_Num *, const double, const SCOTCH_Num *, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphPart (SCOTCH_Graph * const, const SCOTCH_Num, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphPartFixed (SCOTCH_Graph * const, const SCOTCH_Num, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphPartOvl (SCOTCH_Graph * const, const SCOTCH_Num, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphRepart (SCOTCH_Graph * const, const SCOTCH_Num, SCOTCH_Num * const, const double, const SCOTCH_Num *, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphRepartFixed (SCOTCH_Graph * const, const SCOTCH_Num, SCOTCH_Num * const, const double, const SCOTCH_Num *, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_graphOrderInit (const SCOTCH_Graph * const, SCOTCH_Ordering * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> void SCOTCH_graphOrderExit (const SCOTCH_Graph * const, SCOTCH_Ordering * const);
> int SCOTCH_graphOrderLoad (const SCOTCH_Graph * const, SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_graphOrderSave (const SCOTCH_Graph * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_graphOrderSaveMap (const SCOTCH_Graph * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_graphOrderSaveTree (const SCOTCH_Graph * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_graphOrderCompute (SCOTCH_Graph * const, SCOTCH_Ordering * const, SCOTCH_Strat * const);
> int SCOTCH_graphOrderComputeList (SCOTCH_Graph * const, SCOTCH_Ordering * const, const SCOTCH_Num, const SCOTCH_Num * const, SCOTCH_Strat * const);
> int SCOTCH_graphOrderFactor (const SCOTCH_Graph * const, const SCOTCH_Ordering * const, SCOTCH_Graph * const);
> int SCOTCH_graphOrderView (const SCOTCH_Graph * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_graphOrder (SCOTCH_Graph * const, SCOTCH_Strat * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> int SCOTCH_graphOrderList (SCOTCH_Graph * const, const SCOTCH_Num, const SCOTCH_Num * const, SCOTCH_Strat * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> int SCOTCH_graphOrderCheck (const SCOTCH_Graph * const, const SCOTCH_Ordering * const);
> SCOTCH_Mapping * SCOTCH_mapAlloc (void);
> void SCOTCH_memFree (void * const);
> SCOTCH_Idx SCOTCH_memCur (void);
> SCOTCH_Idx SCOTCH_memMax (void);
> int SCOTCH_meshInit (SCOTCH_Mesh * const);
> void SCOTCH_meshExit (SCOTCH_Mesh * const);
> int SCOTCH_meshLoad (SCOTCH_Mesh * const, FILE * const, const SCOTCH_Num);
> int SCOTCH_meshSave (const SCOTCH_Mesh * const, FILE * const);
> int SCOTCH_meshBuild (SCOTCH_Mesh * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num, const SCOTCH_Num * const);
> int SCOTCH_meshCheck (const SCOTCH_Mesh * const);
> void SCOTCH_meshSize (const SCOTCH_Mesh * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> void SCOTCH_meshData (const SCOTCH_Mesh * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num * const, SCOTCH_Num ** const, SCOTCH_Num * const);
> void SCOTCH_meshStat (const SCOTCH_Mesh * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const);
> int SCOTCH_meshGraph (const SCOTCH_Mesh * const, SCOTCH_Graph * const);
> int SCOTCH_meshGeomLoadHabo (SCOTCH_Mesh * const, SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_meshGeomLoadScot (SCOTCH_Mesh * const, SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_meshGeomSaveScot (const SCOTCH_Mesh * const, const SCOTCH_Geom * const, FILE * const, FILE * const, const char * const);
> int SCOTCH_meshOrderInit (const SCOTCH_Mesh * const, SCOTCH_Ordering * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> void SCOTCH_meshOrderExit (const SCOTCH_Mesh * const, SCOTCH_Ordering * const);
> int SCOTCH_meshOrderSave (const SCOTCH_Mesh * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_meshOrderSaveMap (const SCOTCH_Mesh * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_meshOrderSaveTree (const SCOTCH_Mesh * const, const SCOTCH_Ordering * const, FILE * const);
> int SCOTCH_meshOrderCompute (SCOTCH_Mesh * const, SCOTCH_Ordering * const, SCOTCH_Strat * const);
> int SCOTCH_meshOrderComputeList (SCOTCH_Mesh * const, SCOTCH_Ordering * const, const SCOTCH_Num, const SCOTCH_Num * const, SCOTCH_Strat * const);
> int SCOTCH_meshOrder (SCOTCH_Mesh * const, SCOTCH_Strat * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> int SCOTCH_meshOrderList (SCOTCH_Mesh * const, const SCOTCH_Num, const SCOTCH_Num * const, SCOTCH_Strat * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> int SCOTCH_meshOrderCheck (const SCOTCH_Mesh * const, const SCOTCH_Ordering * const);
> int SCOTCH_numSizeof (void);
> SCOTCH_Ordering * SCOTCH_orderAlloc (void);
> void SCOTCH_randomReset (void);
> void SCOTCH_randomSeed (SCOTCH_Num);
> SCOTCH_Strat * SCOTCH_stratAlloc (void);
> int SCOTCH_stratInit (SCOTCH_Strat * const);
> void SCOTCH_stratExit (SCOTCH_Strat * const);
> void SCOTCH_stratFree (SCOTCH_Strat * const);
> int SCOTCH_stratSave (const SCOTCH_Strat * const, FILE * const);
> int SCOTCH_stratGraphBipart (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratGraphMap (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratGraphMapBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const double);
> int SCOTCH_stratGraphClusterBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const double, const double);
> int SCOTCH_stratGraphPartOvl (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratGraphPartOvlBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const double);
> int SCOTCH_stratGraphOrder (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratGraphOrderBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const double);
> int SCOTCH_stratMeshOrder (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratMeshOrderBuild (SCOTCH_Strat * const, const SCOTCH_Num, const double);
> void SCOTCH_version (int * const, int * const, int * const);
> # 70 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/ptscotch.h" 2
> # 87 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/ptscotch.h"
> typedef struct {
> double dummy[29];
> } SCOTCH_Dgraph;
> typedef struct {
> double dummy[1];
> } SCOTCH_DgraphHaloReq;
> typedef struct {
> double dummy[12];
> } SCOTCH_Dmapping;
> typedef struct {
> double dummy[5];
> } SCOTCH_Dordering;
> # 111 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/ptscotch.h"
> SCOTCH_Dgraph * SCOTCH_dgraphAlloc (void);
> int SCOTCH_dgraphInit (SCOTCH_Dgraph * const, MPI_Comm);
> void SCOTCH_dgraphExit (SCOTCH_Dgraph * const);
> void SCOTCH_dgraphFree (SCOTCH_Dgraph * const);
> int SCOTCH_dgraphLoad (SCOTCH_Dgraph * const, FILE * const, const SCOTCH_Num, const SCOTCH_Num);
> int SCOTCH_dgraphSave (SCOTCH_Dgraph * const, FILE * const);
> int SCOTCH_dgraphCheck (const SCOTCH_Dgraph * const);
> int SCOTCH_dgraphBand (SCOTCH_Dgraph * const, const SCOTCH_Num, SCOTCH_Num * const, const SCOTCH_Num, SCOTCH_Dgraph * const);
> int SCOTCH_dgraphBuild (SCOTCH_Dgraph * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, const SCOTCH_Num, const SCOTCH_Num, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> int SCOTCH_dgraphBuildGrid3D (SCOTCH_Dgraph * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const int);
> int SCOTCH_dgraphCoarsen (SCOTCH_Dgraph * const, const SCOTCH_Num, const double, const SCOTCH_Num, SCOTCH_Dgraph * const, SCOTCH_Num * const);
> int SCOTCH_dgraphGather (const SCOTCH_Dgraph * const, SCOTCH_Graph * const);
> int SCOTCH_dgraphGrow (SCOTCH_Dgraph * const, const SCOTCH_Num, SCOTCH_Num * const, const SCOTCH_Num, SCOTCH_Num * const);
> int SCOTCH_dgraphInducePart (SCOTCH_Dgraph * const, const SCOTCH_Num * const, const SCOTCH_Num, const SCOTCH_Num, SCOTCH_Dgraph * const);
> int SCOTCH_dgraphScatter (SCOTCH_Dgraph * const, const SCOTCH_Graph * const);
> int SCOTCH_dgraphRedist (SCOTCH_Dgraph * const, const SCOTCH_Num * const, const SCOTCH_Num * const, const SCOTCH_Num, const SCOTCH_Num, SCOTCH_Dgraph * const);
> void SCOTCH_dgraphSize (const SCOTCH_Dgraph * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> void SCOTCH_dgraphData (const SCOTCH_Dgraph * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num ** const, SCOTCH_Num ** const, SCOTCH_Num ** const, MPI_Comm * const);
> int SCOTCH_dgraphStat (const SCOTCH_Dgraph * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, double * const, double * const);
> int SCOTCH_dgraphGhst (SCOTCH_Dgraph * const);
> int SCOTCH_dgraphHalo (SCOTCH_Dgraph * const, void * const, const MPI_Datatype);
> int SCOTCH_dgraphHaloAsync (SCOTCH_Dgraph * const, void * const, const MPI_Datatype, SCOTCH_DgraphHaloReq * const);
> SCOTCH_DgraphHaloReq * SCOTCH_dgraphHaloReqAlloc (void);
> int SCOTCH_dgraphHaloWait (SCOTCH_DgraphHaloReq * const);
> int SCOTCH_dgraphMapInit (const SCOTCH_Dgraph * const, SCOTCH_Dmapping * const, const SCOTCH_Arch * const, SCOTCH_Num * const);
> void SCOTCH_dgraphMapExit (const SCOTCH_Dgraph * const, SCOTCH_Dmapping * const);
> int SCOTCH_dgraphMapSave (const SCOTCH_Dgraph * const, const SCOTCH_Dmapping * const, FILE * const);
> int SCOTCH_dgraphMapView (SCOTCH_Dgraph * const, const SCOTCH_Dmapping * const, FILE * const);
> int SCOTCH_dgraphMapCompute (SCOTCH_Dgraph * const, SCOTCH_Dmapping * const, SCOTCH_Strat * const);
> int SCOTCH_dgraphMap (SCOTCH_Dgraph * const, const SCOTCH_Arch * const, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_dgraphPart (SCOTCH_Dgraph * const, const SCOTCH_Num, SCOTCH_Strat * const, SCOTCH_Num * const);
> int SCOTCH_dgraphCorderInit (const SCOTCH_Dgraph * const, SCOTCH_Ordering * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const, SCOTCH_Num * const);
> void SCOTCH_dgraphCorderExit (const SCOTCH_Dgraph * const, SCOTCH_Ordering * const);
> int SCOTCH_dgraphOrderInit (const SCOTCH_Dgraph * const, SCOTCH_Dordering * const);
> void SCOTCH_dgraphOrderExit (const SCOTCH_Dgraph * const, SCOTCH_Dordering * const);
> int SCOTCH_dgraphOrderSave (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, FILE * const);
> int SCOTCH_dgraphOrderSaveBlock (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, FILE * const);
> int SCOTCH_dgraphOrderSaveMap (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, FILE * const);
> int SCOTCH_dgraphOrderSaveTree (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, FILE * const);
> int SCOTCH_dgraphOrderPerm (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, SCOTCH_Num * const);
> SCOTCH_Num SCOTCH_dgraphOrderCblkDist (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const);
> int SCOTCH_dgraphOrderTreeDist (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, SCOTCH_Num * const, SCOTCH_Num * const);
> int SCOTCH_dgraphOrderCompute (SCOTCH_Dgraph * const, SCOTCH_Dordering * const, SCOTCH_Strat * const);
> int SCOTCH_dgraphOrderComputeList (SCOTCH_Dgraph * const, SCOTCH_Dordering * const, const SCOTCH_Num, const SCOTCH_Num * const, SCOTCH_Strat * const);
> int SCOTCH_dgraphOrderGather (const SCOTCH_Dgraph * const, const SCOTCH_Dordering * const, SCOTCH_Ordering * const);
> SCOTCH_Dmapping * SCOTCH_dmapAlloc (void);
> SCOTCH_Dordering * SCOTCH_dorderAlloc (void);
> int SCOTCH_stratDgraphMap (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratDgraphMapBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const double);
> int SCOTCH_stratDgraphClusterBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const double, const double);
> int SCOTCH_stratDgraphOrder (SCOTCH_Strat * const, const char * const);
> int SCOTCH_stratDgraphOrderBuild (SCOTCH_Strat * const, const SCOTCH_Num, const SCOTCH_Num, const SCOTCH_Num, const double);
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Found header files ['ptscotch.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Popping language C
> TEST checkSharedLibrary from config.packages.PTScotch(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.PTScotch(config/BuildSystem/config/package.py:792)
> Popping language C
> Pushing language C
> TEST checkDependencies from config.packages.metis(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.metis(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.metis(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.metis(config/BuildSystem/config/package.py:744)
> Checking for a functional metis
> Looking for METIS at git.metis, hg.metis or a directory starting with ['petsc-pkg-metis']
> Could not locate an existing copy of METIS:
> ['git.sowing', 'git.hypre', 'scotch_6.0.3', 'git.mumps', 'SuiteSparse', 'scalapack-2.0.2', 'metis-5.1.0-p2', 'parmetis-4.0.3-p3']
> Downloading metis
> Trying to download git://https://bitbucket.org/petsc/pkg-metis.git for METIS
> Executing: git clone https://bitbucket.org/petsc/pkg-metis.git /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis
> stdout: Cloning into '/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis'...
> Found a copy of METIS in git.metis
> Executing: ['git', 'rev-parse', '--git-dir']
> stdout: .git
> Executing: ['git', 'cat-file', '-e', 'v5.1.0-p4^{commit}']
> Executing: ['git', 'rev-parse', 'v5.1.0-p4']
> stdout: 0adf3ea7785d49ece1ac1ce6f1ddb5e8fa3c6e4d
> Executing: ['git', 'stash']
> stdout: No local changes to save
> Executing: ['git', 'clean', '-f', '-d', '-x']
> Executing: ['git', 'checkout', '-f', '0adf3ea7785d49ece1ac1ce6f1ddb5e8fa3c6e4d']
> Pushing language C
> Popping language C
> Pushing language Cxx
> Popping language Cxx
> Pushing language FC
> Popping language FC
> Have to rebuild METIS, /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/metis.petscconf != /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/petsc/conf/pkg.conf.metis
> Configuring METIS with cmake, this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build && /home/zampins/local/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/zampins/src/petsc/haswell_debug_gnu_mkl -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_C_COMPILER="/opt/cray/craype/2.4.2/bin/cc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-g -O0" -DCMAKE_CXX_COMPILER="/opt/cray/craype/2.4.2/bin/CC" -DCMAKE_CXX_FLAGS:STRING="-g -O0" -DCMAKE_Fortran_COMPILER="/opt/cray/craype/2.4.2/bin/ftn" -DCMAKE_Fortran_FLAGS:STRING="-g -O0" -DBUILD_SHARED_LIBS=off -DGKLIB_PATH=../GKlib -DGKRAND=1 -DDEBUG=1 -DMETIS_USE_DOUBLEPRECISION=1 -DMATH_LIB=""
> stdout:
> -- The C compiler identification is GNU 5.1.0
> -- Check for working C compiler: /opt/cray/craype/2.4.2/bin/cc
> -- Check for working C compiler: /opt/cray/craype/2.4.2/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Looking for execinfo.h
> -- Looking for execinfo.h - found
> -- Looking for getline
> -- Looking for getline - found
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build
> Compiling and installing METIS; this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build && /usr/bin/gmake -j 13 && /usr/bin/gmake install
> stdout:
> gmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -H/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis -B/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build --check-build-system CMakeFiles/Makefile.cmake 0
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles/progress.marks
> /usr/bin/gmake -f CMakeFiles/Makefile2 all
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build && /home/zampins/local/bin/cmake -E cmake_depends "Unix Makefiles" /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
> Scanning dependencies of target metis
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 1
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 2
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 3
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 4
> [ 3%] [ 3%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 5
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 6
> [ 6%] [ 6%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 7
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/blas.c.o
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 8
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o
> [ 9%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/b64.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/b64.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/blas.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/blas.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/csr.c.o
> [ 11%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/error.c.o
> [ 13%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/csr.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/csr.c
> [ 13%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/error.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/error.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 9
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 10
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/evaluate.c.o
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/evaluate.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/fkvkselect.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/getopt.c.o
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 11
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fs.c.o
> [ 16%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/fs.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/fs.c
> [ 16%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/getopt.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/getopt.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 12
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 13
> [ 18%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/gkregex.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/gkregex.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/graph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/graph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/graph.c
> [ 21%] [ 21%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/htable.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/htable.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/htable.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/itemsets.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/itemsets.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/io.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/io.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/io.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 14
> [ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/mcore.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/mcore.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/mcore.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 15
> [ 24%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 16
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/memory.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/memory.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/memory.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 17
> [ 26%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 18
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 19
> [ 27%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 20
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/omp.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/omp.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/omp.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pdb.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/pdb.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pdb.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 21
> [ 32%] [ 34%] [ 34%] [ 34%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 22
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pqueue.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/random.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/random.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/random.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/rw.c.o
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/seq.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/rw.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/rw.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/seq.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/seq.c
> [ 36%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/sort.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/sort.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/sort.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 23
> [ 37%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/string.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/string.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/string.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 24
> [ 39%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 25
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/timers.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/timers.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/timers.c
> [ 40%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 26
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/tokenizer.c
> [ 42%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/util.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/util.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/util.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 27
> [ 44%] Building C object libmetis/CMakeFiles/metis.dir/auxapi.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/auxapi.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/auxapi.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 28
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 29
> [ 47%] [ 47%] Building C object libmetis/CMakeFiles/metis.dir/balance.c.o
> Building C object libmetis/CMakeFiles/metis.dir/bucketsort.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/balance.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/balance.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/bucketsort.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/bucketsort.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 30
> [ 49%] Building C object libmetis/CMakeFiles/metis.dir/checkgraph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/checkgraph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/checkgraph.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 31
> [ 50%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 32
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 33
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 34
> Building C object libmetis/CMakeFiles/metis.dir/coarsen.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/coarsen.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/coarsen.c
> [ 54%] [ 55%] [ 55%] Building C object libmetis/CMakeFiles/metis.dir/compress.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/compress.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/compress.c
> Building C object libmetis/CMakeFiles/metis.dir/contig.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/contig.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c
> Building C object libmetis/CMakeFiles/metis.dir/debug.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/debug.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 35
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 36
> [ 59%] [ 59%] Building C object libmetis/CMakeFiles/metis.dir/fortran.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/fortran.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/fortran.c
> Building C object libmetis/CMakeFiles/metis.dir/fm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/fm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/fm.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 37
> [ 60%] Building C object libmetis/CMakeFiles/metis.dir/frename.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/frename.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/frename.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 38
> [ 62%] Building C object libmetis/CMakeFiles/metis.dir/gklib.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/gklib.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 39
> [ 63%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 40
> Building C object libmetis/CMakeFiles/metis.dir/graph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/graph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/graph.c
> [ 65%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 41
> Building C object libmetis/CMakeFiles/metis.dir/initpart.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/initpart.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c
> [ 67%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 42
> Building C object libmetis/CMakeFiles/metis.dir/kmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/kmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kmetis.c
> [ 68%] Building C object libmetis/CMakeFiles/metis.dir/kwayfm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/kwayfm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 43
> [ 70%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 44
> Building C object libmetis/CMakeFiles/metis.dir/kwayrefine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/kwayrefine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayrefine.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 45
> [ 72%] [ 73%] Building C object libmetis/CMakeFiles/metis.dir/mcutil.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mcutil.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mcutil.c
> Building C object libmetis/CMakeFiles/metis.dir/mesh.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mesh.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mesh.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 46
> [ 75%] Building C object libmetis/CMakeFiles/metis.dir/meshpart.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/meshpart.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/meshpart.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 47
> [ 77%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 48
> Building C object libmetis/CMakeFiles/metis.dir/minconn.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/minconn.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c
> [ 78%] Building C object libmetis/CMakeFiles/metis.dir/mincover.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mincover.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mincover.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 49
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 50
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 51
> [ 83%] [ 83%] [ 83%] Building C object libmetis/CMakeFiles/metis.dir/ometis.c.o
> Building C object libmetis/CMakeFiles/metis.dir/options.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/ometis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/options.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/options.c
> Building C object libmetis/CMakeFiles/metis.dir/mmd.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mmd.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mmd.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 52
> [ 85%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 53
> Building C object libmetis/CMakeFiles/metis.dir/parmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/parmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/parmetis.c
> [ 86%] Building C object libmetis/CMakeFiles/metis.dir/pmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/pmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/pmetis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 54
> [ 88%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 55
> Building C object libmetis/CMakeFiles/metis.dir/refine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/refine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/refine.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 56
> [ 90%] [ 91%] Building C object libmetis/CMakeFiles/metis.dir/separator.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/separator.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/separator.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 57
> Building C object libmetis/CMakeFiles/metis.dir/sfm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/sfm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/sfm.c
> [ 93%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 58
> Building C object libmetis/CMakeFiles/metis.dir/srefine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/srefine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/srefine.c
> [ 95%] Building C object libmetis/CMakeFiles/metis.dir/stat.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/stat.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/stat.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 59
> [ 96%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 60
> [ 98%] Building C object libmetis/CMakeFiles/metis.dir/timing.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/timing.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/timing.c
> Building C object libmetis/CMakeFiles/metis.dir/util.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/util.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/util.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 61
> [100%] Building C object libmetis/CMakeFiles/metis.dir/wspace.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/wspace.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/wspace.c
> Linking C static library libmetis.a
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /home/zampins/local/bin/cmake -P CMakeFiles/metis.dir/cmake_clean_target.cmake
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /home/zampins/local/bin/cmake -E cmake_link_script CMakeFiles/metis.dir/link.txt --verbose=1
> /usr/bin/ar cq libmetis.a CMakeFiles/metis.dir/__/GKlib/b64.c.o CMakeFiles/metis.dir/__/GKlib/blas.c.o CMakeFiles/metis.dir/__/GKlib/csr.c.o CMakeFiles/metis.dir/__/GKlib/error.c.o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o CMakeFiles/metis.dir/__/GKlib/fs.c.o CMakeFiles/metis.dir/__/GKlib/getopt.c.o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o CMakeFiles/metis.dir/__/GKlib/graph.c.o CMakeFiles/metis.dir/__/GKlib/htable.c.o CMakeFiles/metis.dir/__/GKlib/io.c.o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o CMakeFiles/metis.dir/__/GKlib/mcore.c.o CMakeFiles/metis.dir/__/GKlib/memory.c.o CMakeFiles/metis.dir/__/GKlib/omp.c.o CMakeFiles/metis.dir/__/GKlib/pdb.c.o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o CMakeFiles/metis.dir/__/GKlib/random.c.o CMakeFiles/metis.dir/__/GKlib/rw.c.o CMakeFiles/metis.dir/__/GKlib/seq.c.o CMakeFiles/metis.dir/__/GKlib/sort.c.o CMakeFiles/metis.dir/__/GKlib/string.c.o CMakeFiles/metis.dir/__/GKlib/timers.c.o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o CMakeFiles/metis.dir/__/GKlib/util.c.o CMakeFiles/metis.dir/auxapi.c.o CMakeFiles/metis.dir/balance.c.o CMakeFiles/metis.dir/bucketsort.c.o CMakeFiles/metis.dir/checkgraph.c.o CMakeFiles/metis.dir/coarsen.c.o CMakeFiles/metis.dir/compress.c.o CMakeFiles/metis.dir/contig.c.o CMakeFiles/metis.dir/debug.c.o CMakeFiles/metis.dir/fm.c.o CMakeFiles/metis.dir/fortran.c.o CMakeFiles/metis.dir/frename.c.o CMakeFiles/metis.dir/gklib.c.o CMakeFiles/metis.dir/graph.c.o CMakeFiles/metis.dir/initpart.c.o CMakeFiles/metis.dir/kmetis.c.o CMakeFiles/metis.dir/kwayfm.c.o CMakeFiles/metis.dir/kwayrefine.c.o CMakeFiles/metis.dir/mcutil.c.o CMakeFiles/metis.dir/mesh.c.o CMakeFiles/metis.dir/meshpart.c.o CMakeFiles/metis.dir/minconn.c.o CMakeFiles/metis.dir/mincover.c.o CMakeFiles/metis.dir/mmd.c.o CMakeFiles/metis.dir/ometis.c.o CMakeFiles/metis.dir/options.c.o CMakeFiles/metis.dir/parmetis.c.o CMakeFiles/metis.dir/pmetis.c.o CMakeFiles/metis.dir/refine.c.o CMakeFiles/metis.dir/separator.c.o CMakeFiles/metis.dir/sfm.c.o CMakeFiles/metis.dir/srefine.c.o CMakeFiles/metis.dir/stat.c.o CMakeFiles/metis.dir/timing.c.o CMakeFiles/metis.dir/util.c.o CMakeFiles/metis.dir/wspace.c.o
> /usr/bin/ranlib libmetis.a
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
> [100%] Built target metis
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 0
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> gmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -H/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis -B/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build --check-build-system CMakeFiles/Makefile.cmake 0
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles/progress.marks
> /usr/bin/gmake -f CMakeFiles/Makefile2 all
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build && /home/zampins/local/bin/cmake -E cmake_depends "Unix Makefiles" /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
> /usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
> gmake[3]: Nothing to be done for `libmetis/CMakeFiles/metis.dir/build'.
> /usr/bin/gmake -f CMakeFiles/Makefile2 preinstall
> gmake[2]: Nothing to be done for `preinstall'.
> Install the project...
> /home/zampins/local/bin/cmake -P cmake_install.cmake
> -- Install configuration: ""
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/gklib_tls.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmetis.a
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/gklib_defs.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/gklib_rename.h
> ********Output of running make on METIS follows *******
> -- The C compiler identification is GNU 5.1.0
> -- Check for working C compiler: /opt/cray/craype/2.4.2/bin/cc
> -- Check for working C compiler: /opt/cray/craype/2.4.2/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Looking for execinfo.h
> -- Looking for execinfo.h - found
> -- Looking for getline
> -- Looking for getline - found
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/buildCMake Warning:
> Manually-specified variables were not used by the project:
> CMAKE_CXX_COMPILER
> CMAKE_CXX_FLAGS
> CMAKE_Fortran_COMPILER
> CMAKE_Fortran_FLAGS
> Scanning dependencies of target metis
> [ 3%] [ 3%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 5
> [ 6%] [ 6%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 7
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/blas.c.o
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 8
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/b64.c.o
> [ 9%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/b64.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/b64.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/blas.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/blas.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/csr.c.o
> [ 11%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/error.c.o
> [ 13%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/csr.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/csr.c
> [ 13%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/error.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/error.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 9
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 10
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/evaluate.c.o
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/evaluate.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/fkvkselect.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/getopt.c.o
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 11
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/fs.c.o
> [ 16%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/fs.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/fs.c
> [ 16%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/getopt.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/getopt.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 12
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 13
> [ 18%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/gkregex.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/gkregex.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/graph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/graph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/graph.c
> [ 21%] [ 21%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/htable.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/htable.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/htable.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/itemsets.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/itemsets.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/io.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/io.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/io.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 14
> [ 22%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/mcore.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/mcore.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/mcore.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 15
> [ 24%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 16
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/memory.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/memory.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/memory.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 17
> [ 26%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 18
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 19
> [ 27%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 20
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/omp.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/omp.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/omp.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pdb.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/pdb.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pdb.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 21
> [ 32%] [ 34%] [ 34%] [ 34%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 22
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/pqueue.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/random.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/random.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/random.c
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/rw.c.o
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/seq.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/rw.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/rw.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/seq.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/seq.c
> [ 36%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/sort.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/sort.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/sort.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 23
> [ 37%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/string.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/string.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/string.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 24
> [ 39%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 25
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/timers.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/timers.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/timers.c
> [ 40%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 26
> Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/tokenizer.c
> [ 42%] Building C object libmetis/CMakeFiles/metis.dir/__/GKlib/util.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/__/GKlib/util.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/util.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 27
> [ 44%] Building C object libmetis/CMakeFiles/metis.dir/auxapi.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/auxapi.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/auxapi.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 28
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 29
> [ 47%] [ 47%] Building C object libmetis/CMakeFiles/metis.dir/balance.c.o
> Building C object libmetis/CMakeFiles/metis.dir/bucketsort.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/balance.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/balance.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/bucketsort.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/bucketsort.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 30
> [ 49%] Building C object libmetis/CMakeFiles/metis.dir/checkgraph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/checkgraph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/checkgraph.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 31
> [ 50%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 32
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 33
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 34
> Building C object libmetis/CMakeFiles/metis.dir/coarsen.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/coarsen.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/coarsen.c
> [ 54%] [ 55%] [ 55%] Building C object libmetis/CMakeFiles/metis.dir/compress.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/compress.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/compress.c
> Building C object libmetis/CMakeFiles/metis.dir/contig.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/contig.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c
> Building C object libmetis/CMakeFiles/metis.dir/debug.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/debug.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 35
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 36
> [ 59%] [ 59%] Building C object libmetis/CMakeFiles/metis.dir/fortran.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/fortran.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/fortran.c
> Building C object libmetis/CMakeFiles/metis.dir/fm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/fm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/fm.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 37
> [ 60%] Building C object libmetis/CMakeFiles/metis.dir/frename.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/frename.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/frename.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 38
> [ 62%] Building C object libmetis/CMakeFiles/metis.dir/gklib.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/gklib.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 39
> [ 63%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 40
> Building C object libmetis/CMakeFiles/metis.dir/graph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/graph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/graph.c
> [ 65%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 41
> Building C object libmetis/CMakeFiles/metis.dir/initpart.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/initpart.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c
> [ 67%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 42
> Building C object libmetis/CMakeFiles/metis.dir/kmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/kmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kmetis.c
> [ 68%] Building C object libmetis/CMakeFiles/metis.dir/kwayfm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/kwayfm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 43
> [ 70%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 44
> Building C object libmetis/CMakeFiles/metis.dir/kwayrefine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/kwayrefine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayrefine.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 45
> [ 72%] [ 73%] Building C object libmetis/CMakeFiles/metis.dir/mcutil.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mcutil.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mcutil.c
> Building C object libmetis/CMakeFiles/metis.dir/mesh.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mesh.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mesh.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 46
> [ 75%] Building C object libmetis/CMakeFiles/metis.dir/meshpart.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/meshpart.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/meshpart.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 47
> [ 77%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 48
> Building C object libmetis/CMakeFiles/metis.dir/minconn.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/minconn.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c
> [ 78%] Building C object libmetis/CMakeFiles/metis.dir/mincover.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mincover.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mincover.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 49
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 50
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 51
> [ 83%] [ 83%] [ 83%] Building C object libmetis/CMakeFiles/metis.dir/ometis.c.o
> Building C object libmetis/CMakeFiles/metis.dir/options.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/ometis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/options.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/options.c
> Building C object libmetis/CMakeFiles/metis.dir/mmd.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/mmd.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/mmd.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 52
> [ 85%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 53
> Building C object libmetis/CMakeFiles/metis.dir/parmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/parmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/parmetis.c
> [ 86%] Building C object libmetis/CMakeFiles/metis.dir/pmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/pmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/pmetis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 54
> [ 88%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 55
> Building C object libmetis/CMakeFiles/metis.dir/refine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/refine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/refine.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 56
> [ 90%] [ 91%] Building C object libmetis/CMakeFiles/metis.dir/separator.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/separator.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/separator.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 57
> Building C object libmetis/CMakeFiles/metis.dir/sfm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/sfm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/sfm.c
> [ 93%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 58
> Building C object libmetis/CMakeFiles/metis.dir/srefine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/srefine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/srefine.c
> [ 95%] Building C object libmetis/CMakeFiles/metis.dir/stat.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/stat.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/stat.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 59
> [ 96%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 60
> [ 98%] Building C object libmetis/CMakeFiles/metis.dir/timing.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/timing.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/timing.c
> Building C object libmetis/CMakeFiles/metis.dir/util.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/util.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/util.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 61
> [100%] Building C object libmetis/CMakeFiles/metis.dir/wspace.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -DLINUX -D_FILE_OFFSET_BITS=64 -std=c99 -fno-strict-aliasing -fPIC -Wall -pedantic -Wno-unused-variable -Wno-unknown-pragmas -DDEBUG -DNDEBUG -DNDEBUG2 -DUSE_GKRAND -DHAVE_EXECINFO_H -DHAVE_GETLINE -g -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/. -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/include -o CMakeFiles/metis.dir/wspace.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/wspace.c
> Linking C static library libmetis.a
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /home/zampins/local/bin/cmake -P CMakeFiles/metis.dir/cmake_clean_target.cmake
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis && /home/zampins/local/bin/cmake -E cmake_link_script CMakeFiles/metis.dir/link.txt --verbose=1
> /usr/bin/ar cq libmetis.a CMakeFiles/metis.dir/__/GKlib/b64.c.o CMakeFiles/metis.dir/__/GKlib/blas.c.o CMakeFiles/metis.dir/__/GKlib/csr.c.o CMakeFiles/metis.dir/__/GKlib/error.c.o CMakeFiles/metis.dir/__/GKlib/evaluate.c.o CMakeFiles/metis.dir/__/GKlib/fkvkselect.c.o CMakeFiles/metis.dir/__/GKlib/fs.c.o CMakeFiles/metis.dir/__/GKlib/getopt.c.o CMakeFiles/metis.dir/__/GKlib/gkregex.c.o CMakeFiles/metis.dir/__/GKlib/graph.c.o CMakeFiles/metis.dir/__/GKlib/htable.c.o CMakeFiles/metis.dir/__/GKlib/io.c.o CMakeFiles/metis.dir/__/GKlib/itemsets.c.o CMakeFiles/metis.dir/__/GKlib/mcore.c.o CMakeFiles/metis.dir/__/GKlib/memory.c.o CMakeFiles/metis.dir/__/GKlib/omp.c.o CMakeFiles/metis.dir/__/GKlib/pdb.c.o CMakeFiles/metis.dir/__/GKlib/pqueue.c.o CMakeFiles/metis.dir/__/GKlib/random.c.o CMakeFiles/metis.dir/__/GKlib/rw.c.o CMakeFiles/metis.dir/__/GKlib/seq.c.o CMakeFiles/metis.dir/__/GKlib/sort.c.o CMakeFiles/metis.dir/__/GKlib/string.c.o CMakeFiles/metis.dir/__/GKlib/timers.c.o CMakeFiles/metis.dir/__/GKlib/tokenizer.c.o CMakeFiles/metis.dir/__/GKlib/util.c.o CMakeFiles/metis.dir/auxapi.c.o CMakeFiles/metis.dir/balance.c.o CMakeFiles/metis.dir/bucketsort.c.o CMakeFiles/metis.dir/checkgraph.c.o CMakeFiles/metis.dir/coarsen.c.o CMakeFiles/metis.dir/compress.c.o CMakeFiles/metis.dir/contig.c.o CMakeFiles/metis.dir/debug.c.o CMakeFiles/metis.dir/fm.c.o CMakeFiles/metis.dir/fortran.c.o CMakeFiles/metis.dir/frename.c.o CMakeFiles/metis.dir/gklib.c.o CMakeFiles/metis.dir/graph.c.o CMakeFiles/metis.dir/initpart.c.o CMakeFiles/metis.dir/kmetis.c.o CMakeFiles/metis.dir/kwayfm.c.o CMakeFiles/metis.dir/kwayrefine.c.o CMakeFiles/metis.dir/mcutil.c.o CMakeFiles/metis.dir/mesh.c.o CMakeFiles/metis.dir/meshpart.c.o CMakeFiles/metis.dir/minconn.c.o CMakeFiles/metis.dir/mincover.c.o CMakeFiles/metis.dir/mmd.c.o CMakeFiles/metis.dir/ometis.c.o CMakeFiles/metis.dir/options.c.o CMakeFiles/metis.dir/parmetis.c.o CMakeFiles/metis.dir/pmetis.c.o CMakeFiles/metis.dir/refine.c.o CMakeFiles/metis.dir/separator.c.o CMakeFiles/metis.dir/sfm.c.o CMakeFiles/metis.dir/srefine.c.o CMakeFiles/metis.dir/stat.c.o CMakeFiles/metis.dir/timing.c.o CMakeFiles/metis.dir/util.c.o CMakeFiles/metis.dir/wspace.c.o
> /usr/bin/ranlib libmetis.a
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
> [100%] Built target metis
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles 0
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> gmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /home/zampins/local/bin/cmake -H/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis -B/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build --check-build-system CMakeFiles/Makefile.cmake 0
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/CMakeFiles/progress.marks
> /usr/bin/gmake -f CMakeFiles/Makefile2 all
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> /usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/depend
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build && /home/zampins/local/bin/cmake -E cmake_depends "Unix Makefiles" /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build/libmetis/CMakeFiles/metis.dir/DependInfo.cmake --color=
> /usr/bin/gmake -f libmetis/CMakeFiles/metis.dir/build.make libmetis/CMakeFiles/metis.dir/build
> gmake[3]: Nothing to be done for `libmetis/CMakeFiles/metis.dir/build'.
> /usr/bin/gmake -f CMakeFiles/Makefile2 preinstall
> gmake[2]: Nothing to be done for `preinstall'.
> Install the project...
> /home/zampins/local/bin/cmake -P cmake_install.cmake
> -- Install configuration: ""
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/gklib_tls.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmetis.a
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/gklib_defs.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/gklib_rename.h
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/build'/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/error.c: In function 'gk_strerror':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/error.c:183:3: warning: implicit declaration of function 'strerror_r' [-Wimplicit-function-declaration]
> strerror_r(errnum, buf, 1024);
> In file included from /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/GKlib.h:74:0,
> from /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:12:
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c: In function 'gk_ipqCheckHeap':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/gk_mkpqueue.h:386:8: warning: variable 'heap' set but not used [-Wunused-but-set-variable]
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:19:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(gk_ipq, gk_ipq_t, gk_ikv_t, int, gk_idx_t, gk_ikvmalloc, INT_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c: In function 'gk_i32pqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:20:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(gk_i32pq, gk_i32pq_t, gk_i32kv_t, int32_t, gk_idx_t, gk_i32kvmalloc, INT32_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c: In function 'gk_i64pqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:21:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(gk_i64pq, gk_i64pq_t, gk_i64kv_t, int64_t, gk_idx_t, gk_i64kvmalloc, INT64_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c: In function 'gk_fpqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:22:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(gk_fpq, gk_fpq_t, gk_fkv_t, float, gk_idx_t, gk_fkvmalloc, FLT_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c: In function 'gk_dpqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:23:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(gk_dpq, gk_dpq_t, gk_dkv_t, double, gk_idx_t, gk_dkvmalloc, DBL_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c: In function 'gk_idxpqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/GKlib/pqueue.c:24:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(gk_idxpq, gk_idxpq_t, gk_idxkv_t, gk_idx_t, gk_idx_t, gk_idxkvmalloc, GK_IDX_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/coarsen.c: In function 'libmetis__Match_RM':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/coarsen.c:152:33: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *vwgt, *adjncy, *adjwgt, *maxvwgt;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c: In function 'libmetis__CheckBnd':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c: In function 'libmetis__EliminateComponents':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c:345:11: warning: variable 'tpwgts' set but not used [-Wunused-but-set-variable]
> real_t *tpwgts;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:124:43: warning: variable 'bndind' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *adjncy, *where, *bndptr, *bndind;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:124:34: warning: variable 'bndptr' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c: In function 'libmetis__CheckBnd2':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:161:43: warning: variable 'bndind' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:161:34: warning: variable 'bndptr' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c: In function 'libmetis__CheckNodeBnd':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:198:43: warning: variable 'bndind' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:198:34: warning: variable 'bndptr' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:198:17: warning: variable 'adjncy' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:198:10: warning: variable 'xadj' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c: In function 'libmetis__CheckRInfo':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:235:11: warning: variable 'nbrs' set but not used [-Wunused-but-set-variable]
> cnbr_t *nbrs;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c: In function 'libmetis__MoveGroupContigForCut':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c:534:34: warning: variable 'nvtxs' set but not used [-Wunused-but-set-variable]
> idx_t i, ii, iii, j, jj, k, l, nvtxs, nbnd, from, me;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c: In function 'libmetis__CheckNodePartitionParams':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:258:26: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *adjncy, *adjwgt, *vwgt, *where;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c: In function 'libmetis__IsSeparable':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:312:17: warning: variable 'adjncy' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *adjncy, *where;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/debug.c:311:22: warning: variable 'other' set but not used [-Wunused-but-set-variable]
> idx_t i, j, nvtxs, other;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c: In function 'libmetis__MoveGroupContigForVol':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/contig.c:605:34: warning: variable 'nvtxs' set but not used [-Wunused-but-set-variable]
> idx_t i, ii, iii, j, jj, k, l, nvtxs, from, me, other, xgain;
> from /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/metislib.h:17,
> from /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c:12:
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c: In function 'libmetis__ipqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c:33:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(ipq, ipq_t, ikv_t, idx_t, idx_t, ikvmalloc, IDX_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c: In function 'libmetis__rpqCheckHeap':
> KVT *heap;\
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/gklib.c:34:1: note: in expansion of macro 'GK_MKPQUEUE'
> GK_MKPQUEUE(rpq, rpq_t, rkv_t, real_t, idx_t, rkvmalloc, REAL_MAX, key_gt)
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c: In function 'libmetis__RandomBisection':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c:119:33: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *vwgt, *adjncy, *adjwgt, *where;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c:119:24: warning: variable 'adjncy' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c:119:10: warning: variable 'xadj' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c: In function 'libmetis__GrowBisection':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c:195:33: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c: In function 'libmetis__GrowBisectionNode':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/initpart.c:438:33: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *vwgt, *adjncy, *adjwgt, *where, *bndind;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c: In function 'libmetis__Greedy_KWayCutOptimize':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c:69:74: warning: variable 'adwgts' set but not used [-Wunused-but-set-variable]
> idx_t maxndoms, *safetos=NULL, *nads=NULL, *doms=NULL, **adids=NULL, **adwgts=NULL;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayrefine.c: In function 'libmetis__ComputeKWayVolGains':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayrefine.c:565:34: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *vsize, *adjncy, *adjwgt, *where,
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c: In function 'libmetis__Greedy_KWayVolOptimize':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c:379:74: warning: variable 'adwgts' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c:377:33: warning: variable 'bndptr' set but not used [-Wunused-but-set-variable]
> idx_t *where, *pwgts, *perm, *bndptr, *bndind, *minwgt, *maxwgt, *itpwgts;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c: In function 'libmetis__Greedy_McKWayCutOptimize':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c:693:74: warning: variable 'adwgts' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c: In function 'libmetis__Greedy_McKWayVolOptimize':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c:1035:74: warning: variable 'adwgts' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/kwayfm.c:1033:33: warning: variable 'bndptr' set but not used [-Wunused-but-set-variable]
> idx_t *where, *pwgts, *perm, *bndptr, *bndind, *minwgt, *maxwgt;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c: In function 'libmetis__ComputeSubDomainGraph':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c:21:26: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *adjncy, *adjwgt, *where;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c:21:17: warning: variable 'adjncy' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c:21:10: warning: variable 'xadj' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c: In function 'libmetis__MoveGroupMinConnForCut':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c:480:29: warning: variable 'nvtxs' set but not used [-Wunused-but-set-variable]
> idx_t i, ii, j, jj, k, l, nvtxs, nbnd, from, me;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c: In function 'libmetis__MoveGroupMinConnForVol':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/minconn.c:564:29: warning: variable 'nvtxs' set but not used [-Wunused-but-set-variable]
> idx_t i, ii, j, jj, k, l, nvtxs, from, me, other, xgain, ewgt;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c: In function 'libmetis__MlevelNestedDissection':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c:186:15: warning: variable 'nvtxs' set but not used [-Wunused-but-set-variable]
> idx_t i, j, nvtxs, nbnd;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c: In function 'libmetis__SplitGraphOrder':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c:426:33: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> idx_t *xadj, *vwgt, *adjncy, *adjwgt, *label, *where, *bndptr, *bndind;
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c: In function 'libmetis__SplitGraphOrderCC':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/ometis.c:556:33: warning: variable 'adjwgt' set but not used [-Wunused-but-set-variable]
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/separator.c: In function 'libmetis__ConstructMinCoverSeparator':
> /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.metis/libmetis/separator.c:73:27: warning: variable 'bndptr' set but not used [-Wunused-but-set-variable]
> idx_t *where, *bndind, *bndptr, *vmap, *ivmap, *cover;
> ********End of Output of running make on METIS *******
> Checking for library in Download METIS: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmetis.a']
> Contents: ['include', 'lib', 'bin', 'externalpackages', 'share', 'initial_cache_file.cmake', 'CMakeFiles', 'obj', 'Makefile', 'cmake_install.cmake', 'CMakeCache.txt']
> TEST check from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:159)
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:159)
> Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
> - libDir may be a list of directories
> - libName may be a list of library names
> Checking for functions [METIS_PartGraphKway] in library ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmetis.a'] []
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> /* Override any gcc2 internal prototype to avoid an error. */
> char METIS_PartGraphKway();
> static void _check_METIS_PartGraphKway() { METIS_PartGraphKway(); }
> int main() {
> _check_METIS_PartGraphKway();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lmetis -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBMETIS" to "1"
> Popping language C
> Checking for headers Download METIS: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Pushing language C
> TEST checkInclude from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:86)
> TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
> Checks if a particular include file can be found along particular include paths
> Checking for header files ['metis.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Checking include with compiler flags var CPPFLAGS ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h" 1
> # 94 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> # 1 "/usr/include/inttypes.h" 1 3 4
> # 26 "/usr/include/inttypes.h" 3 4
> # 1 "/usr/include/features.h" 1 3 4
> # 347 "/usr/include/features.h" 3 4
> # 1 "/usr/include/sys/cdefs.h" 1 3 4
> # 353 "/usr/include/sys/cdefs.h" 3 4
> # 1 "/usr/include/bits/wordsize.h" 1 3 4
> # 354 "/usr/include/sys/cdefs.h" 2 3 4
> # 348 "/usr/include/features.h" 2 3 4
> # 371 "/usr/include/features.h" 3 4
> # 1 "/usr/include/gnu/stubs.h" 1 3 4
> # 5 "/usr/include/gnu/stubs.h" 2 3 4
> # 1 "/usr/include/gnu/stubs-64.h" 1 3 4
> # 10 "/usr/include/gnu/stubs.h" 2 3 4
> # 372 "/usr/include/features.h" 2 3 4
> # 27 "/usr/include/inttypes.h" 2 3 4
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 1 3 4
> # 9 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 3 4
> # 1 "/usr/include/stdint.h" 1 3 4
> # 27 "/usr/include/stdint.h" 3 4
> # 1 "/usr/include/bits/wchar.h" 1 3 4
> # 28 "/usr/include/stdint.h" 2 3 4
> # 29 "/usr/include/stdint.h" 2 3 4
> # 37 "/usr/include/stdint.h" 3 4
> typedef signed char int8_t;
> typedef short int int16_t;
> typedef int int32_t;
> typedef long int int64_t;
> typedef unsigned char uint8_t;
> typedef unsigned short int uint16_t;
> typedef unsigned int uint32_t;
> typedef unsigned long int uint64_t;
> # 66 "/usr/include/stdint.h" 3 4
> typedef signed char int_least8_t;
> typedef short int int_least16_t;
> typedef int int_least32_t;
> typedef long int int_least64_t;
> typedef unsigned char uint_least8_t;
> typedef unsigned short int uint_least16_t;
> typedef unsigned int uint_least32_t;
> typedef unsigned long int uint_least64_t;
> # 91 "/usr/include/stdint.h" 3 4
> typedef signed char int_fast8_t;
> typedef long int int_fast16_t;
> typedef long int int_fast32_t;
> typedef long int int_fast64_t;
> # 104 "/usr/include/stdint.h" 3 4
> typedef unsigned char uint_fast8_t;
> typedef unsigned long int uint_fast16_t;
> typedef unsigned long int uint_fast32_t;
> typedef unsigned long int uint_fast64_t;
> # 120 "/usr/include/stdint.h" 3 4
> typedef long int intptr_t;
> typedef unsigned long int uintptr_t;
> # 135 "/usr/include/stdint.h" 3 4
> typedef long int intmax_t;
> typedef unsigned long int uintmax_t;
> # 10 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stdint.h" 2 3 4
> # 29 "/usr/include/inttypes.h" 2 3 4
> typedef int __gwchar_t;
> # 274 "/usr/include/inttypes.h" 3 4
> typedef struct
> long int quot;
> long int rem;
> } imaxdiv_t;
> # 298 "/usr/include/inttypes.h" 3 4
> extern intmax_t imaxabs (intmax_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
> extern intmax_t strtoimax (__const char *__restrict __nptr,
> char **__restrict __endptr, int __base) __attribute__ ((__nothrow__));
> extern uintmax_t strtoumax (__const char *__restrict __nptr,
> char ** __restrict __endptr, int __base) __attribute__ ((__nothrow__));
> extern intmax_t wcstoimax (__const __gwchar_t *__restrict __nptr,
> __gwchar_t **__restrict __endptr, int __base)
> extern uintmax_t wcstoumax (__const __gwchar_t *__restrict __nptr,
> __gwchar_t ** __restrict __endptr, int __base)
> # 442 "/usr/include/inttypes.h" 3 4
> # 95 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h" 2
> # 103 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> typedef int32_t idx_t;
> # 151 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> typedef double real_t;
> # 199 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> int METIS_PartGraphRecursive(idx_t *nvtxs, idx_t *ncon, idx_t *xadj,
> idx_t *adjncy, idx_t *vwgt, idx_t *vsize, idx_t *adjwgt,
> idx_t *nparts, real_t *tpwgts, real_t *ubvec, idx_t *options,
> idx_t *edgecut, idx_t *part);
> int METIS_PartGraphKway(idx_t *nvtxs, idx_t *ncon, idx_t *xadj,
> int METIS_MeshToDual(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> idx_t *ncommon, idx_t *numflag, idx_t **r_xadj, idx_t **r_adjncy);
> int METIS_MeshToNodal(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> int METIS_PartMeshNodal(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> idx_t *vwgt, idx_t *vsize, idx_t *nparts, real_t *tpwgts,
> idx_t *options, idx_t *objval, idx_t *epart, idx_t *npart);
> int METIS_PartMeshDual(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> idx_t *vwgt, idx_t *vsize, idx_t *ncommon, idx_t *nparts,
> real_t *tpwgts, idx_t *options, idx_t *objval, idx_t *epart,
> idx_t *npart);
> int METIS_NodeND(idx_t *nvtxs, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
> idx_t *options, idx_t *perm, idx_t *iperm);
> int METIS_Free(void *ptr);
> int METIS_SetDefaultOptions(idx_t *options);
> int METIS_NodeNDP(idx_t nvtxs, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
> idx_t npes, idx_t *options, idx_t *perm, idx_t *iperm,
> idx_t *sizes);
> int METIS_ComputeVertexSeparator(idx_t *nvtxs, idx_t *xadj, idx_t *adjncy,
> idx_t *vwgt, idx_t *options, idx_t *sepsize, idx_t *part);
> int METIS_NodeRefine(idx_t nvtxs, idx_t *xadj, idx_t *vwgt, idx_t *adjncy,
> idx_t *where, idx_t *hmarker, real_t ubfactor);
> # 255 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> typedef enum {
> METIS_OK = 1,
> METIS_ERROR_INPUT = -2,
> METIS_ERROR_MEMORY = -3,
> METIS_ERROR = -4
> } rstatus_et;
> typedef enum {
> METIS_OP_PMETIS,
> METIS_OP_KMETIS,
> METIS_OP_OMETIS
> } moptype_et;
> typedef enum {
> METIS_OPTION_PTYPE,
> METIS_OPTION_OBJTYPE,
> METIS_OPTION_CTYPE,
> METIS_OPTION_IPTYPE,
> METIS_OPTION_RTYPE,
> METIS_OPTION_DBGLVL,
> METIS_OPTION_NITER,
> METIS_OPTION_NCUTS,
> METIS_OPTION_SEED,
> METIS_OPTION_NO2HOP,
> METIS_OPTION_MINCONN,
> METIS_OPTION_CONTIG,
> METIS_OPTION_COMPRESS,
> METIS_OPTION_CCORDER,
> METIS_OPTION_PFACTOR,
> METIS_OPTION_NSEPS,
> METIS_OPTION_UFACTOR,
> METIS_OPTION_NUMBERING,
> METIS_OPTION_HELP,
> METIS_OPTION_TPWGTS,
> METIS_OPTION_NCOMMON,
> METIS_OPTION_NOOUTPUT,
> METIS_OPTION_BALANCE,
> METIS_OPTION_GTYPE,
> METIS_OPTION_UBVEC
> } moptions_et;
> typedef enum {
> METIS_PTYPE_RB,
> METIS_PTYPE_KWAY
> } mptype_et;
> typedef enum {
> METIS_GTYPE_DUAL,
> METIS_GTYPE_NODAL
> } mgtype_et;
> typedef enum {
> METIS_CTYPE_RM,
> METIS_CTYPE_SHEM
> } mctype_et;
> typedef enum {
> METIS_IPTYPE_GROW,
> METIS_IPTYPE_RANDOM,
> METIS_IPTYPE_EDGE,
> METIS_IPTYPE_NODE,
> METIS_IPTYPE_METISRB
> } miptype_et;
> typedef enum {
> METIS_RTYPE_FM,
> METIS_RTYPE_GREEDY,
> METIS_RTYPE_SEP2SIDED,
> METIS_RTYPE_SEP1SIDED
> } mrtype_et;
> typedef enum {
> METIS_DBG_INFO = 1,
> METIS_DBG_TIME = 2,
> METIS_DBG_COARSEN = 4,
> METIS_DBG_REFINE = 8,
> METIS_DBG_IPART = 16,
> METIS_DBG_MOVEINFO = 32,
> METIS_DBG_SEPINFO = 64,
> METIS_DBG_CONNINFO = 128,
> METIS_DBG_CONTIGINFO = 256,
> METIS_DBG_MEMORY = 2048,
> } mdbglvl_et;
> typedef enum {
> METIS_OBJTYPE_CUT,
> METIS_OBJTYPE_VOL,
> METIS_OBJTYPE_NODE
> } mobjtype_et;
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Found header files ['metis.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Popping language C
> TEST checkSharedLibrary from config.packages.metis(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.metis(config/BuildSystem/config/package.py:792)
> By default we don't care about checking if the library is shared
> Popping language C
> TEST alternateConfigureLibrary from config.packages.pragmatic(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.pragmatic(config/BuildSystem/config/package.py:796)
> Called if --with-packagename=0; does nothing by default
> Pushing language C
> TEST checkDependencies from config.packages.parmetis(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.parmetis(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.parmetis(/home/zampins/src/petsc/config/BuildSystem/config/packages/parmetis.py:42)
> TESTING: configureLibrary from config.packages.parmetis(config/BuildSystem/config/packages/parmetis.py:42)
> Checking for a functional parmetis
> Looking for PARMETIS at git.parmetis, hg.parmetis or a directory starting with ['petsc-pkg-parmetis']
> Could not locate an existing copy of PARMETIS:
> ['git.sowing', 'git.hypre', 'scotch_6.0.3', 'git.mumps', 'SuiteSparse', 'scalapack-2.0.2', 'metis-5.1.0-p2', 'parmetis-4.0.3-p3', 'git.metis']
> Downloading parmetis
> Trying to download git://https://bitbucket.org/petsc/pkg-parmetis.git for PARMETIS
> Executing: git clone https://bitbucket.org/petsc/pkg-parmetis.git /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis
> stdout: Cloning into '/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis'...
> Found a copy of PARMETIS in git.parmetis
> Executing: ['git', 'rev-parse', '--git-dir']
> stdout: .git
> Executing: ['git', 'cat-file', '-e', 'v4.0.3-p4^{commit}']
> Executing: ['git', 'rev-parse', 'v4.0.3-p4']
> stdout: 73dab469aa363afcdce33cde3e5575554d7ce78c
> Executing: ['git', 'stash']
> stdout: No local changes to save
> Executing: ['git', 'clean', '-f', '-d', '-x']
> Executing: ['git', 'checkout', '-f', '73dab469aa363afcdce33cde3e5575554d7ce78c']
> Pushing language C
> Popping language C
> Pushing language Cxx
> Popping language Cxx
> Pushing language FC
> Popping language FC
> Have to rebuild PARMETIS, /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/pkg.gitcommit != /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/petsc/conf/pkg.gitcommit.parmetis
> Configuring PARMETIS with cmake, this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build && /home/zampins/local/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/zampins/src/petsc/haswell_debug_gnu_mkl -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_C_COMPILER="/opt/cray/craype/2.4.2/bin/cc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-g -O0" -DCMAKE_CXX_COMPILER="/opt/cray/craype/2.4.2/bin/CC" -DCMAKE_CXX_FLAGS:STRING="-g -O0" -DCMAKE_Fortran_COMPILER="/opt/cray/craype/2.4.2/bin/ftn" -DCMAKE_Fortran_FLAGS:STRING="-g -O0" -DBUILD_SHARED_LIBS=off -DGKLIB_PATH=../headers -DDEBUG=1 -DMETIS_USE_DOUBLEPRECISION=1
> stdout:
> -- The C compiler identification is GNU 5.1.0
> -- Check for working C compiler: /opt/cray/craype/2.4.2/bin/cc
> -- Check for working C compiler: /opt/cray/craype/2.4.2/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build
> Compiling and installing PARMETIS; this may take several minutes
> Executing: cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build && /usr/bin/gmake -j 13 && /usr/bin/gmake install
> stdout:
> gmake[1]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'
> /home/zampins/local/bin/cmake -H/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis -B/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build --check-build-system CMakeFiles/Makefile.cmake 0
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles/progress.marks
> gmake[2]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'
> /usr/bin/gmake -f libparmetis/CMakeFiles/parmetis.dir/build.make libparmetis/CMakeFiles/parmetis.dir/depend
> gmake[3]: Entering directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build && /home/zampins/local/bin/cmake -E cmake_depends "Unix Makefiles" /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis/CMakeFiles/parmetis.dir/DependInfo.cmake --color=
> Scanning dependencies of target parmetis
> gmake[3]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'
> /usr/bin/gmake -f libparmetis/CMakeFiles/parmetis.dir/build.make libparmetis/CMakeFiles/parmetis.dir/build
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 1
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 2
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 3
> [ 5%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 4
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 5
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 6
> [ 10%] [ 10%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 7
> [ 12%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 8
> Building C object libparmetis/CMakeFiles/parmetis.dir/ComputeVertexSeparator.c.o
> [ 15%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/ComputeVertexSeparator.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/ComputeVertexSeparator.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 9
> Building C object libparmetis/CMakeFiles/parmetis.dir/akwayfm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/akwayfm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/akwayfm.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 10
> [ 20%] Building C object libparmetis/CMakeFiles/parmetis.dir/ametis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/ametis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/ametis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 11
> Building C object libparmetis/CMakeFiles/parmetis.dir/balancemylink.c.o
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 12
> Building C object libparmetis/CMakeFiles/parmetis.dir/comm.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/balancemylink.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/balancemylink.c
> [ 22%] [ 22%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/comm.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/comm.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 13
> Building C object libparmetis/CMakeFiles/parmetis.dir/csrmatch.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/csrmatch.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/csrmatch.c
> [ 27%] [ 27%] Building C object libparmetis/CMakeFiles/parmetis.dir/ctrl.c.o
> Building C object libparmetis/CMakeFiles/parmetis.dir/debug.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/ctrl.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/ctrl.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/debug.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/debug.c
> [ 32%] [ 32%] [ 32%] Building C object libparmetis/CMakeFiles/parmetis.dir/diffutil.c.o
> Building C object libparmetis/CMakeFiles/parmetis.dir/frename.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/diffutil.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/diffutil.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/frename.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/frename.c
> Building C object libparmetis/CMakeFiles/parmetis.dir/gkmpi.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/gkmpi.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/gkmpi.c
> Building C object libparmetis/CMakeFiles/parmetis.dir/graph.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/graph.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/graph.c
> Building C object libparmetis/CMakeFiles/parmetis.dir/gkmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/gkmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/gkmetis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 14
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 15
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 16
> [ 37%] [ 37%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 17
> [ 40%] Building C object libparmetis/CMakeFiles/parmetis.dir/initbalance.c.o
> Building C object libparmetis/CMakeFiles/parmetis.dir/initmsection.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/initmsection.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/initmsection.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/initbalance.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/initbalance.c
> [ 42%] Building C object libparmetis/CMakeFiles/parmetis.dir/initpart.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/initpart.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/initpart.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 18
> Building C object libparmetis/CMakeFiles/parmetis.dir/kmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/kmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/kmetis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 19
> [ 45%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 20
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 21
> [ 47%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 22
> Building C object libparmetis/CMakeFiles/parmetis.dir/kwayrefine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/kwayrefine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/kwayrefine.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 23
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 24
> Building C object libparmetis/CMakeFiles/parmetis.dir/match.c.o
> [ 52%] cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/match.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/match.c
> [ 55%] [ 57%] [ 60%] [ 60%] Building C object libparmetis/CMakeFiles/parmetis.dir/mdiffusion.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/mdiffusion.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/mdiffusion.c
> Building C object libparmetis/CMakeFiles/parmetis.dir/mesh.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/mesh.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/mesh.c
> Building C object libparmetis/CMakeFiles/parmetis.dir/mmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/mmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/mmetis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 25
> Building C object libparmetis/CMakeFiles/parmetis.dir/move.c.o
> Building C object libparmetis/CMakeFiles/parmetis.dir/msetup.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/move.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/move.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/msetup.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/msetup.c
> [ 62%] Building C object libparmetis/CMakeFiles/parmetis.dir/node_refine.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/node_refine.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/node_refine.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 26
> [ 65%] Building C object libparmetis/CMakeFiles/parmetis.dir/ometis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/ometis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/ometis.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 27
> [ 67%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 28
> [ 70%] Building C object libparmetis/CMakeFiles/parmetis.dir/pspases.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/pspases.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/pspases.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 29
> Building C object libparmetis/CMakeFiles/parmetis.dir/redomylink.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/redomylink.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/redomylink.c
> [ 72%] Building C object libparmetis/CMakeFiles/parmetis.dir/remap.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/remap.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/remap.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 30
> [ 75%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 31
> [ 77%] Building C object libparmetis/CMakeFiles/parmetis.dir/renumber.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/renumber.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/renumber.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 32
> Building C object libparmetis/CMakeFiles/parmetis.dir/rmetis.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/rmetis.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/rmetis.c
> [ 80%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 33
> Building C object libparmetis/CMakeFiles/parmetis.dir/selectq.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/selectq.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/selectq.c
> [ 82%] Building C object libparmetis/CMakeFiles/parmetis.dir/serial.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/serial.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/serial.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 34
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 35
> [ 85%] [ 87%] Building C object libparmetis/CMakeFiles/parmetis.dir/timer.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/timer.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/timer.c
> Building C object libparmetis/CMakeFiles/parmetis.dir/stat.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/stat.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/stat.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 36
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 37
> [ 92%] [ 92%] /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 38
> Building C object libparmetis/CMakeFiles/parmetis.dir/wave.c.o
> Building C object libparmetis/CMakeFiles/parmetis.dir/util.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/wave.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/wave.c
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/util.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/util.c
> [ 95%] Building C object libparmetis/CMakeFiles/parmetis.dir/weird.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/weird.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/weird.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 39
> [ 97%] Building C object libparmetis/CMakeFiles/parmetis.dir/wspace.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/wspace.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/wspace.c
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 40
> [100%] Building C object libparmetis/CMakeFiles/parmetis.dir/xyzpart.c.o
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /opt/cray/craype/2.4.2/bin/cc -g -O0 -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/metis/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/. -o CMakeFiles/parmetis.dir/xyzpart.c.o -c /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/libparmetis/xyzpart.c
> Linking C static library libparmetis.a
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /home/zampins/local/bin/cmake -P CMakeFiles/parmetis.dir/cmake_clean_target.cmake
> cd /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/libparmetis && /home/zampins/local/bin/cmake -E cmake_link_script CMakeFiles/parmetis.dir/link.txt --verbose=1
> /usr/bin/ar cq libparmetis.a CMakeFiles/parmetis.dir/ComputeVertexSeparator.c.o CMakeFiles/parmetis.dir/akwayfm.c.o CMakeFiles/parmetis.dir/ametis.c.o CMakeFiles/parmetis.dir/balancemylink.c.o CMakeFiles/parmetis.dir/comm.c.o CMakeFiles/parmetis.dir/csrmatch.c.o CMakeFiles/parmetis.dir/ctrl.c.o CMakeFiles/parmetis.dir/debug.c.o CMakeFiles/parmetis.dir/diffutil.c.o CMakeFiles/parmetis.dir/frename.c.o CMakeFiles/parmetis.dir/gkmetis.c.o CMakeFiles/parmetis.dir/gkmpi.c.o CMakeFiles/parmetis.dir/graph.c.o CMakeFiles/parmetis.dir/initbalance.c.o CMakeFiles/parmetis.dir/initmsection.c.o CMakeFiles/parmetis.dir/initpart.c.o CMakeFiles/parmetis.dir/kmetis.c.o CMakeFiles/parmetis.dir/kwayrefine.c.o CMakeFiles/parmetis.dir/match.c.o CMakeFiles/parmetis.dir/mdiffusion.c.o CMakeFiles/parmetis.dir/mesh.c.o CMakeFiles/parmetis.dir/mmetis.c.o CMakeFiles/parmetis.dir/move.c.o CMakeFiles/parmetis.dir/msetup.c.o CMakeFiles/parmetis.dir/node_refine.c.o CMakeFiles/parmetis.dir/ometis.c.o CMakeFiles/parmetis.dir/pspases.c.o CMakeFiles/parmetis.dir/redomylink.c.o CMakeFiles/parmetis.dir/remap.c.o CMakeFiles/parmetis.dir/renumber.c.o CMakeFiles/parmetis.dir/rmetis.c.o CMakeFiles/parmetis.dir/selectq.c.o CMakeFiles/parmetis.dir/serial.c.o CMakeFiles/parmetis.dir/stat.c.o CMakeFiles/parmetis.dir/timer.c.o CMakeFiles/parmetis.dir/util.c.o CMakeFiles/parmetis.dir/wave.c.o CMakeFiles/parmetis.dir/weird.c.o CMakeFiles/parmetis.dir/wspace.c.o CMakeFiles/parmetis.dir/xyzpart.c.o
> /usr/bin/ranlib libparmetis.a
> /home/zampins/local/bin/cmake -E cmake_progress_report /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
> [100%] Built target parmetis
> gmake[2]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'
> /home/zampins/local/bin/cmake -E cmake_progress_start /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build/CMakeFiles 0
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'
> /usr/bin/gmake -f CMakeFiles/Makefile2 all
> gmake[3]: Nothing to be done for `libparmetis/CMakeFiles/parmetis.dir/build'.
> /usr/bin/gmake -f CMakeFiles/Makefile2 preinstall
> gmake[2]: Nothing to be done for `preinstall'.
> Install the project...
> /home/zampins/local/bin/cmake -P cmake_install.cmake
> -- Install configuration: ""
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h
> -- Installing: /home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libparmetis.a
> ********Output of running make on PARMETIS follows *******
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/buildCMake Warning:
> Manually-specified variables were not used by the project:
> CMAKE_CXX_COMPILER
> CMAKE_CXX_FLAGS
> CMAKE_Fortran_FLAGS
> DEBUG
> gmake[1]: Leaving directory `/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.parmetis/build'********End of Output of running make on PARMETIS *******
> Checking for library in Download PARMETIS: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libparmetis.a']
> Checking for functions [ParMETIS_V3_PartKway] in library ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libparmetis.a'] ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmetis.a']
> Pushing language C
> Successful compile:
> Source:
> char ParMETIS_V3_PartKway();
> static void _check_ParMETIS_V3_PartKway() { ParMETIS_V3_PartKway(); }
> int main() {
> _check_ParMETIS_V3_PartKway();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lparmetis -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lmetis -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBPARMETIS" to "1"
> Popping language C
> Checking for headers Download PARMETIS: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Pushing language C
> Checking for header files ['parmetis.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Checking include with compiler flags var CPPFLAGS ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include', '/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "<built-in>"
> # 1 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h" 1
> # 17 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 1
> # 51 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> # 26 "/usr/include/stdint.h" 3 4
> # 27 "/usr/include/stdint.h" 2 3 4
> # 52 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 2
> # 96 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Datatype;
> # 279 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Comm;
> typedef int MPI_Group;
> typedef int MPI_Win;
> typedef struct ADIOI_FileD *MPI_File;
> typedef int MPI_Op;
> # 362 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef enum MPIR_Win_flavor {
> MPI_WIN_FLAVOR_CREATE = 1,
> MPI_WIN_FLAVOR_ALLOCATE = 2,
> MPI_WIN_FLAVOR_DYNAMIC = 3,
> MPI_WIN_FLAVOR_SHARED = 4
> } MPIR_Win_flavor_t;
> typedef enum MPIR_Win_model {
> MPI_WIN_SEPARATE = 1,
> MPI_WIN_UNIFIED = 2
> } MPIR_Win_model_t;
> typedef enum MPIR_Topo_type { MPI_GRAPH=1, MPI_CART=2, MPI_DIST_GRAPH=3 } MPIR_Topo_type;
> extern int * const MPI_UNWEIGHTED;
> extern int * const MPI_WEIGHTS_EMPTY;
> # 394 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef void (MPI_Handler_function) ( MPI_Comm *, int *, ... );
> typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *, void *,
> void *, int *);
> typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
> typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *, void *,
> void *, int *);
> typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int, void *, void *);
> typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *, void *, void *,
> int *);
> typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
> typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
> typedef void (MPI_File_errhandler_function)(MPI_File *, int *, ...);
> typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
> typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn;
> typedef MPI_File_errhandler_function MPI_File_errhandler_fn;
> typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn;
> # 422 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Errhandler;
> # 443 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPI_Request;
> typedef int MPI_Message;
> typedef void (MPI_User_function) ( void *, void *, int *, MPI_Datatype * );
> typedef int (MPI_Copy_function) ( MPI_Comm, int, void *, void *, void *, int * );
> typedef int (MPI_Delete_function) ( MPI_Comm, int, void *, void * );
> # 497 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> enum MPIR_Combiner_enum {
> MPI_COMBINER_NAMED = 1,
> MPI_COMBINER_DUP = 2,
> MPI_COMBINER_CONTIGUOUS = 3,
> MPI_COMBINER_VECTOR = 4,
> MPI_COMBINER_HVECTOR_INTEGER = 5,
> MPI_COMBINER_HVECTOR = 6,
> MPI_COMBINER_INDEXED = 7,
> MPI_COMBINER_HINDEXED_INTEGER = 8,
> MPI_COMBINER_HINDEXED = 9,
> MPI_COMBINER_INDEXED_BLOCK = 10,
> MPI_COMBINER_STRUCT_INTEGER = 11,
> MPI_COMBINER_STRUCT = 12,
> MPI_COMBINER_SUBARRAY = 13,
> MPI_COMBINER_DARRAY = 14,
> MPI_COMBINER_F90_REAL = 15,
> MPI_COMBINER_F90_COMPLEX = 16,
> MPI_COMBINER_F90_INTEGER = 17,
> MPI_COMBINER_RESIZED = 18,
> MPI_COMBINER_HINDEXED_BLOCK = 19
> typedef int MPI_Info;
> # 547 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef long MPI_Aint;
> typedef int MPI_Fint;
> typedef long long MPI_Count;
> # 566 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef long long MPI_Offset;
> typedef struct MPI_Status {
> int count_lo;
> int count_hi_and_cancelled;
> int MPI_SOURCE;
> int MPI_TAG;
> int MPI_ERROR;
> } MPI_Status;
> struct MPIR_T_enum_s;
> struct MPIR_T_cvar_handle_s;
> struct MPIR_T_pvar_handle_s;
> struct MPIR_T_pvar_session_s;
> typedef struct MPIR_T_enum_s * MPI_T_enum;
> typedef struct MPIR_T_cvar_handle_s * MPI_T_cvar_handle;
> typedef struct MPIR_T_pvar_handle_s * MPI_T_pvar_handle;
> typedef struct MPIR_T_pvar_session_s * MPI_T_pvar_session;
> extern struct MPIR_T_pvar_handle_s * const MPI_T_PVAR_ALL_HANDLES;
> # 603 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef enum MPIR_T_verbosity_t {
> MPIX_T_VERBOSITY_INVALID = 0,
> MPI_T_VERBOSITY_USER_BASIC = 221,
> MPI_T_VERBOSITY_USER_DETAIL,
> MPI_T_VERBOSITY_USER_ALL,
> MPI_T_VERBOSITY_TUNER_BASIC,
> MPI_T_VERBOSITY_TUNER_DETAIL,
> MPI_T_VERBOSITY_TUNER_ALL,
> MPI_T_VERBOSITY_MPIDEV_BASIC,
> MPI_T_VERBOSITY_MPIDEV_DETAIL,
> MPI_T_VERBOSITY_MPIDEV_ALL
> } MPIR_T_verbosity_t;
> typedef enum MPIR_T_bind_t {
> MPIX_T_BIND_INVALID = 0,
> MPI_T_BIND_NO_OBJECT = 9700,
> MPI_T_BIND_MPI_COMM,
> MPI_T_BIND_MPI_DATATYPE,
> MPI_T_BIND_MPI_ERRHANDLER,
> MPI_T_BIND_MPI_FILE,
> MPI_T_BIND_MPI_GROUP,
> MPI_T_BIND_MPI_OP,
> MPI_T_BIND_MPI_REQUEST,
> MPI_T_BIND_MPI_WIN,
> MPI_T_BIND_MPI_MESSAGE,
> MPI_T_BIND_MPI_INFO
> } MPIR_T_bind_t;
> typedef enum MPIR_T_scope_t {
> MPIX_T_SCOPE_INVALID = 0,
> MPI_T_SCOPE_CONSTANT = 60438,
> MPI_T_SCOPE_READONLY,
> MPI_T_SCOPE_LOCAL,
> MPI_T_SCOPE_GROUP,
> MPI_T_SCOPE_GROUP_EQ,
> MPI_T_SCOPE_ALL,
> MPI_T_SCOPE_ALL_EQ
> } MPIR_T_scope_t;
> typedef enum MPIR_T_pvar_class_t {
> MPIX_T_PVAR_CLASS_INVALID = 0,
> MPIR_T_PVAR_CLASS_FIRST = 240,
> MPI_T_PVAR_CLASS_STATE = MPIR_T_PVAR_CLASS_FIRST,
> MPI_T_PVAR_CLASS_LEVEL,
> MPI_T_PVAR_CLASS_SIZE,
> MPI_T_PVAR_CLASS_PERCENTAGE,
> MPI_T_PVAR_CLASS_HIGHWATERMARK,
> MPI_T_PVAR_CLASS_LOWWATERMARK,
> MPI_T_PVAR_CLASS_COUNTER,
> MPI_T_PVAR_CLASS_AGGREGATE,
> MPI_T_PVAR_CLASS_TIMER,
> MPI_T_PVAR_CLASS_GENERIC,
> MPIR_T_PVAR_CLASS_LAST,
> MPIR_T_PVAR_CLASS_NUMBER = MPIR_T_PVAR_CLASS_LAST - MPIR_T_PVAR_CLASS_FIRST
> } MPIR_T_pvar_class_t;
> # 725 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> extern MPI_Fint * MPI_F_STATUS_IGNORE;
> extern MPI_Fint * MPI_F_STATUSES_IGNORE;
> # 740 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef struct {
> MPI_Fint count_lo;
> MPI_Fint count_hi_and_cancelled;
> MPI_Fint MPI_SOURCE;
> MPI_Fint MPI_TAG;
> MPI_Fint MPI_ERROR;
> } MPI_F08_Status;
> extern MPI_F08_Status MPIR_F08_MPI_STATUS_IGNORE_OBJ;
> extern MPI_F08_Status MPIR_F08_MPI_STATUSES_IGNORE_OBJ[1];
> extern int MPIR_F08_MPI_IN_PLACE;
> extern int MPIR_F08_MPI_BOTTOM;
> extern MPI_F08_Status *MPI_F08_STATUS_IGNORE;
> extern MPI_F08_Status *MPI_F08_STATUSES_IGNORE;
> # 764 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int (MPI_Grequest_cancel_function)(void *, int);
> typedef int (MPI_Grequest_free_function)(void *);
> typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
> typedef int (MPIX_Grequest_poll_function)(void *, MPI_Status *);
> typedef int (MPIX_Grequest_wait_function)(int, void **, double, MPI_Status *);
> # 879 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype, int,
> void *, MPI_Offset, void *);
> typedef int (MPI_Datarep_extent_function)(MPI_Datatype datatype, MPI_Aint *,
> void *);
> # 899 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> int MPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> MPI_Comm comm, MPI_Status *status) ;
> int MPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int MPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int MPI_Buffer_attach(void *buffer, int size);
> int MPI_Buffer_detach(void *buffer_addr, int *size);
> int MPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm, MPI_Request *request) ;
> int MPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int MPI_Wait(MPI_Request *request, MPI_Status *status);
> int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
> int MPI_Request_free(MPI_Request *request);
> int MPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
> int MPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
> int MPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
> int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
> int MPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int array_of_indices[], MPI_Status array_of_statuses[]);
> int MPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
> int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
> int MPI_Cancel(MPI_Request *request);
> int MPI_Test_cancelled(const MPI_Status *status, int *flag);
> int MPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int MPI_Start(MPI_Request *request);
> int MPI_Startall(int count, MPI_Request array_of_requests[]);
> int MPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
> int sendtag, void *recvbuf, int recvcount, MPI_Datatype recvtype,
> int source, int recvtag, MPI_Comm comm, MPI_Status *status)
> int MPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
> int sendtag, int source, int recvtag, MPI_Comm comm,
> int MPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
> int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int MPI_Type_indexed(int count, const int *array_of_blocklengths,
> const int *array_of_displacements, MPI_Datatype oldtype,
> int MPI_Type_hindexed(int count, const int *array_of_blocklengths,
> const MPI_Aint *array_of_displacements, MPI_Datatype oldtype,
> int MPI_Type_struct(int count, const int *array_of_blocklengths,
> const MPI_Datatype *array_of_types, MPI_Datatype *newtype);
> int MPI_Address(const void *location, MPI_Aint *address);
> int MPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
> int MPI_Type_size(MPI_Datatype datatype, int *size);
> int MPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
> int MPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
> int MPI_Type_commit(MPI_Datatype *datatype);
> int MPI_Type_free(MPI_Datatype *datatype);
> int MPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
> int outsize, int *position, MPI_Comm comm) ;
> int MPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
> MPI_Datatype datatype, MPI_Comm comm) ;
> int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
> int MPI_Barrier(MPI_Comm comm);
> int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
> int MPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm)
> int MPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int *recvcounts, const int *displs, MPI_Datatype recvtype, int root,
> MPI_Comm comm)
> int MPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
> MPI_Datatype sendtype, void *recvbuf, int recvcount, MPI_Datatype recvtype,
> int MPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int *recvcounts, const int *displs, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
> MPI_Datatype sendtype, void *recvbuf, const int *recvcounts,
> const int *rdispls, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const MPI_Datatype sendtypes[], void *recvbuf, const int recvcounts[],
> const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
> int MPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, MPI_Comm comm)
> int MPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, int root, MPI_Comm comm)
> int MPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
> int MPI_Op_free(MPI_Op *op);
> int MPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int MPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> MPI_Datatype datatype, MPI_Op op, MPI_Comm comm)
> int MPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> MPI_Comm comm)
> int MPI_Group_size(MPI_Group group, int *size);
> int MPI_Group_rank(MPI_Group group, int *rank);
> int MPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
> int ranks2[]);
> int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
> int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
> int MPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int MPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int MPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int MPI_Group_free(MPI_Group *group);
> int MPI_Comm_size(MPI_Comm comm, int *size);
> int MPI_Comm_rank(MPI_Comm comm, int *rank);
> int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
> int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
> int MPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
> int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
> int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
> int MPI_Comm_free(MPI_Comm *comm);
> int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
> int MPI_Comm_remote_size(MPI_Comm comm, int *size);
> int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
> int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
> int remote_leader, int tag, MPI_Comm *newintercomm);
> int MPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
> int MPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
> int *keyval, void *extra_state);
> int MPI_Keyval_free(int *keyval);
> int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
> int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
> int MPI_Attr_delete(MPI_Comm comm, int keyval);
> int MPI_Topo_test(MPI_Comm comm, int *status);
> int MPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
> int reorder, MPI_Comm *comm_cart);
> int MPI_Dims_create(int nnodes, int ndims, int dims[]);
> int MPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
> int reorder, MPI_Comm *comm_graph);
> int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
> int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
> int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
> int MPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
> int MPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
> int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
> int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
> int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
> int MPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
> int MPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
> int MPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
> int MPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
> int MPI_Get_processor_name(char *name, int *resultlen);
> int MPI_Get_version(int *version, int *subversion);
> int MPI_Get_library_version(char *version, int *resultlen);
> int MPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
> int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
> int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
> int MPI_Errhandler_free(MPI_Errhandler *errhandler);
> int MPI_Error_string(int errorcode, char *string, int *resultlen);
> int MPI_Error_class(int errorcode, int *errorclass);
> double MPI_Wtime(void);
> double MPI_Wtick(void);
> int MPI_Init(int *argc, char ***argv);
> int MPI_Finalize(void);
> int MPI_Initialized(int *flag);
> int MPI_Abort(MPI_Comm comm, int errorcode);
> int MPI_Pcontrol(const int level, ...);
> int MPIR_Dup_fn(MPI_Comm oldcomm, int keyval, void *extra_state, void *attribute_val_in,
> void *attribute_val_out, int *flag);
> int MPI_Close_port(const char *port_name);
> int MPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int MPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int MPI_Comm_disconnect(MPI_Comm *comm);
> int MPI_Comm_get_parent(MPI_Comm *parent);
> int MPI_Comm_join(int fd, MPI_Comm *intercomm);
> int MPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
> MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
> int MPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
> const int array_of_maxprocs[], const MPI_Info array_of_info[],
> int root, MPI_Comm comm, MPI_Comm *intercomm, int array_of_errcodes[]);
> int MPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
> int MPI_Open_port(MPI_Info info, char *port_name);
> int MPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
> int MPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
> int MPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
> int MPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
> int MPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int target_rank, MPI_Aint target_disp, int target_count,
> MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
> int MPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> MPI_Datatype target_datatype, MPI_Win win) ;
> int MPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int MPI_Win_complete(MPI_Win win);
> int MPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> MPI_Win *win);
> int MPI_Win_fence(int assert, MPI_Win win);
> int MPI_Win_free(MPI_Win *win);
> int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
> int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
> int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
> int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
> int MPI_Win_test(MPI_Win win, int *flag);
> int MPI_Win_unlock(int rank, MPI_Win win);
> int MPI_Win_wait(MPI_Win win);
> int MPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
> MPI_Win *win);
> int MPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> void *baseptr, MPI_Win *win);
> int MPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
> int MPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
> int MPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
> int MPI_Win_detach(MPI_Win win, const void *base);
> int MPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
> int MPI_Win_set_info(MPI_Win win, MPI_Info info);
> int MPI_Get_accumulate(const void *origin_addr, int origin_count,
> MPI_Datatype origin_datatype, void *result_addr, int result_count,
> MPI_Datatype result_datatype, int target_rank, MPI_Aint target_disp,
> int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win)
> int MPI_Fetch_and_op(const void *origin_addr, void *result_addr,
> MPI_Datatype datatype, int target_rank, MPI_Aint target_disp,
> int MPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
> void *result_addr, MPI_Datatype datatype, int target_rank,
> MPI_Aint target_disp, MPI_Win win)
> int MPI_Rput(const void *origin_addr, int origin_count,
> MPI_Datatype origin_datatype, int target_rank, MPI_Aint target_disp,
> int target_count, MPI_Datatype target_datatype, MPI_Win win,
> int MPI_Rget(void *origin_addr, int origin_count,
> int MPI_Raccumulate(const void *origin_addr, int origin_count,
> int target_count, MPI_Datatype target_datatype, MPI_Op op, MPI_Win win,
> int MPI_Rget_accumulate(const void *origin_addr, int origin_count,
> int MPI_Win_lock_all(int assert, MPI_Win win);
> int MPI_Win_unlock_all(MPI_Win win);
> int MPI_Win_flush(int rank, MPI_Win win);
> int MPI_Win_flush_all(MPI_Win win);
> int MPI_Win_flush_local(int rank, MPI_Win win);
> int MPI_Win_flush_local_all(MPI_Win win);
> int MPI_Win_sync(MPI_Win win);
> int MPI_Add_error_class(int *errorclass);
> int MPI_Add_error_code(int errorclass, int *errorcode);
> int MPI_Add_error_string(int errorcode, const char *string);
> int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
> int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
> MPI_Comm_delete_attr_function *comm_delete_attr_fn, int *comm_keyval,
> void *extra_state);
> int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
> int MPI_Comm_free_keyval(int *comm_keyval);
> int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
> int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
> int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
> int MPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
> int MPI_File_call_errhandler(MPI_File fh, int errorcode);
> int MPI_Grequest_complete(MPI_Request request);
> int MPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
> MPI_Grequest_cancel_function *cancel_fn, void *extra_state,
> int MPI_Init_thread(int *argc, char ***argv, int required, int *provided);
> int MPI_Is_thread_main(int *flag);
> int MPI_Query_thread(int *provided);
> int MPI_Status_set_cancelled(MPI_Status *status, int flag);
> int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
> int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
> MPI_Type_delete_attr_function *type_delete_attr_fn,
> int *type_keyval, void *extra_state);
> int MPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
> int MPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_free_keyval(int *type_keyval);
> int MPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
> int MPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
> int max_datatypes, int array_of_integers[],
> MPI_Aint array_of_addresses[], MPI_Datatype array_of_datatypes[]);
> int MPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
> int *num_datatypes, int *combiner);
> int MPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
> int MPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
> int MPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
> int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
> int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
> int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
> MPI_Win_delete_attr_function *win_delete_attr_fn, int *win_keyval,
> void *extra_state);
> int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
> int MPI_Win_free_keyval(int *win_keyval);
> int MPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
> int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
> int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
> int MPI_Win_set_name(MPI_Win win, const char *win_name);
> int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
> int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
> int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
> int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
> int MPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
> int MPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
> int MPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
> int MPI_Finalized(int *flag);
> int MPI_Free_mem(void *base);
> int MPI_Get_address(const void *location, MPI_Aint *address);
> int MPI_Info_create(MPI_Info *info);
> int MPI_Info_delete(MPI_Info info, const char *key);
> int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
> int MPI_Info_free(MPI_Info *info);
> int MPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
> int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
> int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
> int MPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
> int MPI_Info_set(MPI_Info info, const char *key, const char *value);
> int MPI_Pack_external(const char datarep[], const void *inbuf, int incount,
> MPI_Datatype datatype, void *outbuf, MPI_Aint outsize, MPI_Aint *position)
> int MPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
> MPI_Aint *size);
> int MPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
> int MPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
> int MPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
> int MPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
> const int array_of_distribs[], const int array_of_dargs[],
> const int array_of_psizes[], int order, MPI_Datatype oldtype,
> int MPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
> const MPI_Aint array_of_displacements[], MPI_Datatype oldtype,
> int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int MPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
> int MPI_Type_create_hindexed_block(int count, int blocklength,
> int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
> int MPI_Type_create_struct(int count, const int array_of_blocklengths[],
> const MPI_Datatype array_of_types[], MPI_Datatype *newtype);
> int MPI_Type_create_subarray(int ndims, const int array_of_sizes[],
> const int array_of_subsizes[], const int array_of_starts[],
> int order, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int MPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
> int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
> int MPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
> MPI_Aint *position, void *outbuf, int outcount, MPI_Datatype datatype)
> int MPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
> int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
> int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
> int MPI_Type_create_f90_integer(int range, MPI_Datatype *newtype);
> int MPI_Type_create_f90_real(int precision, int range, MPI_Datatype *newtype);
> int MPI_Type_create_f90_complex(int precision, int range, MPI_Datatype *newtype);
> int MPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
> MPI_Op op)
> int MPI_Op_commutative(MPI_Op op, int *commute);
> int MPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
> const int sourceweights[], int outdegree,
> const int destinations[], const int destweights[],
> MPI_Info info, int reorder, MPI_Comm *comm_dist_graph);
> int MPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
> const int destinations[], const int weights[], MPI_Info info,
> int MPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
> int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
> int maxoutdegree, int destinations[], int destweights[]);
> int MPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
> int MPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int MPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
> int MPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int MPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
> int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
> int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
> int MPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, int root, MPI_Comm comm,
> int MPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> const int recvcounts[], const int displs[], MPI_Datatype recvtype, int root,
> int MPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
> int root, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int recvcount, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int MPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> MPI_Datatype sendtype, void *recvbuf, const int recvcounts[],
> const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm,
> int MPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const int rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm,
> int MPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, int root, MPI_Comm comm, MPI_Request *request)
> int MPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> MPI_Op op, MPI_Comm comm, MPI_Request *request)
> int MPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request)
> int MPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int MPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> int MPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int MPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, const int recvcounts[], const int displs[],
> int MPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm,
> int MPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int MPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
> const MPI_Aint sdispls[], const MPI_Datatype sendtypes[],
> void *recvbuf, const int recvcounts[], const MPI_Aint rdispls[],
> const MPI_Datatype recvtypes[], MPI_Comm comm, MPI_Request *request);
> int MPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> void *recvbuf, int recvcount, MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int MPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> const int rdispls[], MPI_Datatype recvtype, MPI_Comm comm)
> int MPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
> const MPI_Aint rdispls[], const MPI_Datatype recvtypes[], MPI_Comm comm);
> int MPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
> int MPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
> int MPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
> int MPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int MPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int MPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
> int MPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
> int MPIX_Comm_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int MPIX_Comm_remote_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int MPIX_Comm_reenable_anysource(MPI_Comm comm, MPI_Group *failed_group);
> int MPI_T_init_thread(int required, int *provided);
> int MPI_T_finalize(void);
> int MPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
> int MPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
> int MPI_T_cvar_get_num(int *num_cvar);
> int MPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
> MPI_Datatype *datatype, MPI_T_enum *enumtype, char *desc, int *desc_len,
> int *binding, int *scope);
> int MPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
> int *count);
> int MPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
> int MPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
> int MPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
> int MPI_T_pvar_get_num(int *num_pvar);
> int MPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
> int *binding, int *readonly, int *continuous, int *atomic);
> int MPI_T_pvar_session_create(MPI_T_pvar_session *session);
> int MPI_T_pvar_session_free(MPI_T_pvar_session *session);
> int MPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
> MPI_T_pvar_handle *handle, int *count);
> int MPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
> int MPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int MPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
> int MPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int MPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int MPI_T_category_get_num(int *num_cat);
> int MPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
> int *num_cvars, int *num_pvars, int *num_categories);
> int MPI_T_category_get_cvars(int cat_index, int len, int indices[]);
> int MPI_T_category_get_pvars(int cat_index, int len, int indices[]);
> int MPI_T_category_get_categories(int cat_index, int len, int indices[]);
> int MPI_T_category_changed(int *stamp);
> int PMPI_Send(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Get_count(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int PMPI_Bsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Ssend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Rsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> MPI_Comm comm) ;
> int PMPI_Buffer_attach(void *buffer, int size);
> int PMPI_Buffer_detach(void *buffer_addr, int *size);
> int PMPI_Isend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Ibsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Issend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Irsend(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Wait(MPI_Request *request, MPI_Status *status);
> int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
> int PMPI_Request_free(MPI_Request *request);
> int PMPI_Waitany(int count, MPI_Request array_of_requests[], int *indx, MPI_Status *status);
> int PMPI_Testany(int count, MPI_Request array_of_requests[], int *indx, int *flag,
> int PMPI_Waitall(int count, MPI_Request array_of_requests[], MPI_Status array_of_statuses[]);
> int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
> int PMPI_Waitsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int PMPI_Testsome(int incount, MPI_Request array_of_requests[], int *outcount,
> int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag, MPI_Status *status);
> int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
> int PMPI_Cancel(MPI_Request *request);
> int PMPI_Test_cancelled(const MPI_Status *status, int *flag);
> int PMPI_Send_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Bsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Ssend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Rsend_init(const void *buf, int count, MPI_Datatype datatype, int dest, int tag,
> int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source, int tag,
> int PMPI_Start(MPI_Request *request);
> int PMPI_Startall(int count, MPI_Request array_of_requests[]);
> int PMPI_Sendrecv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, int dest,
> int PMPI_Sendrecv_replace(void *buf, int count, MPI_Datatype datatype, int dest,
> int PMPI_Type_contiguous(int count, MPI_Datatype oldtype, MPI_Datatype *newtype);
> int PMPI_Type_vector(int count, int blocklength, int stride, MPI_Datatype oldtype,
> int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int PMPI_Type_indexed(int count, const int *array_of_blocklengths,
> int PMPI_Type_hindexed(int count, const int *array_of_blocklengths,
> int PMPI_Type_struct(int count, const int *array_of_blocklengths,
> int PMPI_Address(const void *location, MPI_Aint *address);
> int PMPI_Type_extent(MPI_Datatype datatype, MPI_Aint *extent);
> int PMPI_Type_size(MPI_Datatype datatype, int *size);
> int PMPI_Type_lb(MPI_Datatype datatype, MPI_Aint *displacement);
> int PMPI_Type_ub(MPI_Datatype datatype, MPI_Aint *displacement);
> int PMPI_Type_commit(MPI_Datatype *datatype);
> int PMPI_Type_free(MPI_Datatype *datatype);
> int PMPI_Get_elements(const MPI_Status *status, MPI_Datatype datatype, int *count);
> int PMPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void *outbuf,
> int PMPI_Unpack(const void *inbuf, int insize, int *position, void *outbuf, int outcount,
> int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm, int *size);
> int PMPI_Barrier(MPI_Comm comm);
> int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm)
> int PMPI_Gather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Gatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> MPI_Comm comm)
> int PMPI_Scatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Scatterv(const void *sendbuf, const int *sendcounts, const int *displs,
> int PMPI_Allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Alltoallv(const void *sendbuf, const int *sendcounts, const int *sdispls,
> int PMPI_Alltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Exscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Reduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Op_create(MPI_User_function *user_fn, int commute, MPI_Op *op);
> int PMPI_Op_free(MPI_Op *op);
> int PMPI_Allreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Reduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> int PMPI_Scan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> MPI_Comm comm)
> int PMPI_Group_size(MPI_Group group, int *size);
> int PMPI_Group_rank(MPI_Group group, int *rank);
> int PMPI_Group_translate_ranks(MPI_Group group1, int n, const int ranks1[], MPI_Group group2,
> int ranks2[]);
> int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
> int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
> int PMPI_Group_union(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_difference(MPI_Group group1, MPI_Group group2, MPI_Group *newgroup);
> int PMPI_Group_incl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int PMPI_Group_excl(MPI_Group group, int n, const int ranks[], MPI_Group *newgroup);
> int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3], MPI_Group *newgroup);
> int PMPI_Group_free(MPI_Group *group);
> int PMPI_Comm_size(MPI_Comm comm, int *size);
> int PMPI_Comm_rank(MPI_Comm comm, int *rank);
> int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
> int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
> int PMPI_Comm_dup_with_info(MPI_Comm comm, MPI_Info info, MPI_Comm *newcomm);
> int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
> int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
> int PMPI_Comm_free(MPI_Comm *comm);
> int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
> int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
> int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
> int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader, MPI_Comm peer_comm,
> int PMPI_Intercomm_merge(MPI_Comm intercomm, int high, MPI_Comm *newintracomm);
> int PMPI_Keyval_create(MPI_Copy_function *copy_fn, MPI_Delete_function *delete_fn,
> int PMPI_Keyval_free(int *keyval);
> int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val);
> int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag);
> int PMPI_Attr_delete(MPI_Comm comm, int keyval);
> int PMPI_Topo_test(MPI_Comm comm, int *status);
> int PMPI_Cart_create(MPI_Comm comm_old, int ndims, const int dims[], const int periods[],
> int PMPI_Dims_create(int nnodes, int ndims, int dims[]);
> int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, const int indx[], const int edges[],
> int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
> int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges, int indx[], int edges[]);
> int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
> int PMPI_Cart_get(MPI_Comm comm, int maxdims, int dims[], int periods[], int coords[]);
> int PMPI_Cart_rank(MPI_Comm comm, const int coords[], int *rank);
> int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int coords[]);
> int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
> int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors, int neighbors[]);
> int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp, int *rank_source, int *rank_dest);
> int PMPI_Cart_sub(MPI_Comm comm, const int remain_dims[], MPI_Comm *newcomm);
> int PMPI_Cart_map(MPI_Comm comm, int ndims, const int dims[], const int periods[], int *newrank);
> int PMPI_Graph_map(MPI_Comm comm, int nnodes, const int indx[], const int edges[], int *newrank);
> int PMPI_Get_processor_name(char *name, int *resultlen);
> int PMPI_Get_version(int *version, int *subversion);
> int PMPI_Get_library_version(char *version, int *resultlen);
> int PMPI_Errhandler_create(MPI_Handler_function *function, MPI_Errhandler *errhandler);
> int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler);
> int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler);
> int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
> int PMPI_Error_string(int errorcode, char *string, int *resultlen);
> int PMPI_Error_class(int errorcode, int *errorclass);
> double PMPI_Wtime(void);
> double PMPI_Wtick(void);
> int PMPI_Init(int *argc, char ***argv);
> int PMPI_Finalize(void);
> int PMPI_Initialized(int *flag);
> int PMPI_Abort(MPI_Comm comm, int errorcode);
> int PMPI_Pcontrol(const int level, ...);
> int PMPI_Close_port(const char *port_name);
> int PMPI_Comm_accept(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int PMPI_Comm_connect(const char *port_name, MPI_Info info, int root, MPI_Comm comm,
> MPI_Comm *newcomm);
> int PMPI_Comm_disconnect(MPI_Comm *comm);
> int PMPI_Comm_get_parent(MPI_Comm *parent);
> int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
> int PMPI_Comm_spawn(const char *command, char *argv[], int maxprocs, MPI_Info info, int root,
> int PMPI_Comm_spawn_multiple(int count, char *array_of_commands[], char **array_of_argv[],
> int PMPI_Lookup_name(const char *service_name, MPI_Info info, char *port_name);
> int PMPI_Open_port(MPI_Info info, char *port_name);
> int PMPI_Publish_name(const char *service_name, MPI_Info info, const char *port_name);
> int PMPI_Unpublish_name(const char *service_name, MPI_Info info, const char *port_name);
> int PMPI_Comm_set_info(MPI_Comm comm, MPI_Info info);
> int PMPI_Comm_get_info(MPI_Comm comm, MPI_Info *info);
> int PMPI_Accumulate(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Get(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Put(const void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
> int PMPI_Win_complete(MPI_Win win);
> int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> MPI_Win *win);
> int PMPI_Win_fence(int assert, MPI_Win win);
> int PMPI_Win_free(MPI_Win *win);
> int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
> int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
> int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
> int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
> int PMPI_Win_test(MPI_Win win, int *flag);
> int PMPI_Win_unlock(int rank, MPI_Win win);
> int PMPI_Win_wait(MPI_Win win);
> int PMPI_Win_allocate(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm, void *baseptr,
> MPI_Win *win);
> int PMPI_Win_allocate_shared(MPI_Aint size, int disp_unit, MPI_Info info, MPI_Comm comm,
> int PMPI_Win_shared_query(MPI_Win win, int rank, MPI_Aint *size, int *disp_unit, void *baseptr);
> int PMPI_Win_create_dynamic(MPI_Info info, MPI_Comm comm, MPI_Win *win);
> int PMPI_Win_attach(MPI_Win win, void *base, MPI_Aint size);
> int PMPI_Win_detach(MPI_Win win, const void *base);
> int PMPI_Win_get_info(MPI_Win win, MPI_Info *info_used);
> int PMPI_Win_set_info(MPI_Win win, MPI_Info info);
> int PMPI_Get_accumulate(const void *origin_addr, int origin_count,
> int PMPI_Fetch_and_op(const void *origin_addr, void *result_addr,
> int PMPI_Compare_and_swap(const void *origin_addr, const void *compare_addr,
> int PMPI_Rput(const void *origin_addr, int origin_count,
> int PMPI_Rget(void *origin_addr, int origin_count,
> int PMPI_Raccumulate(const void *origin_addr, int origin_count,
> int PMPI_Rget_accumulate(const void *origin_addr, int origin_count,
> int PMPI_Win_lock_all(int assert, MPI_Win win);
> int PMPI_Win_unlock_all(MPI_Win win);
> int PMPI_Win_flush(int rank, MPI_Win win);
> int PMPI_Win_flush_all(MPI_Win win);
> int PMPI_Win_flush_local(int rank, MPI_Win win);
> int PMPI_Win_flush_local_all(MPI_Win win);
> int PMPI_Win_sync(MPI_Win win);
> int PMPI_Add_error_class(int *errorclass);
> int PMPI_Add_error_code(int errorclass, int *errorcode);
> int PMPI_Add_error_string(int errorcode, const char *string);
> int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
> int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
> void *extra_state);
> int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
> int PMPI_Comm_free_keyval(int *comm_keyval);
> int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval, void *attribute_val, int *flag);
> int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
> int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
> int PMPI_Comm_set_name(MPI_Comm comm, const char *comm_name);
> int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
> int PMPI_Grequest_complete(MPI_Request request);
> int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn, MPI_Grequest_free_function *free_fn,
> int PMPI_Init_thread(int *argc, char ***argv, int required, int *provided);
> int PMPI_Is_thread_main(int *flag);
> int PMPI_Query_thread(int *provided);
> int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
> int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype, int count);
> int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
> int PMPI_Type_delete_attr(MPI_Datatype datatype, int type_keyval);
> int PMPI_Type_dup(MPI_Datatype oldtype, MPI_Datatype *newtype);
> int PMPI_Type_free_keyval(int *type_keyval);
> int PMPI_Type_get_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val, int *flag);
> int PMPI_Type_get_contents(MPI_Datatype datatype, int max_integers, int max_addresses,
> int PMPI_Type_get_envelope(MPI_Datatype datatype, int *num_integers, int *num_addresses,
> int PMPI_Type_get_name(MPI_Datatype datatype, char *type_name, int *resultlen);
> int PMPI_Type_set_attr(MPI_Datatype datatype, int type_keyval, void *attribute_val);
> int PMPI_Type_set_name(MPI_Datatype datatype, const char *type_name);
> int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *datatype);
> int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
> int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
> void *extra_state);
> int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
> int PMPI_Win_free_keyval(int *win_keyval);
> int PMPI_Win_get_attr(MPI_Win win, int win_keyval, void *attribute_val, int *flag);
> int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
> int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
> int PMPI_Win_set_name(MPI_Win win, const char *win_name);
> int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr);
> int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *comm_errhandler_fn,
> int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *errhandler);
> int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
> int PMPI_File_create_errhandler(MPI_File_errhandler_function *file_errhandler_fn,
> int PMPI_File_get_errhandler(MPI_File file, MPI_Errhandler *errhandler);
> int PMPI_File_set_errhandler(MPI_File file, MPI_Errhandler errhandler);
> int PMPI_Finalized(int *flag);
> int PMPI_Free_mem(void *base);
> int PMPI_Get_address(const void *location, MPI_Aint *address);
> int PMPI_Info_create(MPI_Info *info);
> int PMPI_Info_delete(MPI_Info info, const char *key);
> int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
> int PMPI_Info_free(MPI_Info *info);
> int PMPI_Info_get(MPI_Info info, const char *key, int valuelen, char *value, int *flag);
> int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
> int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
> int PMPI_Info_get_valuelen(MPI_Info info, const char *key, int *valuelen, int *flag);
> int PMPI_Info_set(MPI_Info info, const char *key, const char *value);
> int PMPI_Pack_external(const char datarep[], const void *inbuf, int incount,
> int PMPI_Pack_external_size(const char datarep[], int incount, MPI_Datatype datatype,
> MPI_Aint *size);
> int PMPI_Request_get_status(MPI_Request request, int *flag, MPI_Status *status);
> int PMPI_Status_c2f(const MPI_Status *c_status, MPI_Fint *f_status);
> int PMPI_Status_f2c(const MPI_Fint *f_status, MPI_Status *c_status);
> int PMPI_Type_create_darray(int size, int rank, int ndims, const int array_of_gsizes[],
> int PMPI_Type_create_hindexed(int count, const int array_of_blocklengths[],
> int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride, MPI_Datatype oldtype,
> int PMPI_Type_create_indexed_block(int count, int blocklength, const int array_of_displacements[],
> int PMPI_Type_create_hindexed_block(int count, int blocklength,
> int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb, MPI_Aint extent,
> int PMPI_Type_create_struct(int count, const int array_of_blocklengths[],
> int PMPI_Type_create_subarray(int ndims, const int array_of_sizes[],
> int PMPI_Type_get_extent(MPI_Datatype datatype, MPI_Aint *lb, MPI_Aint *extent);
> int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb, MPI_Aint *true_extent);
> int PMPI_Unpack_external(const char datarep[], const void *inbuf, MPI_Aint insize,
> int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *win_errhandler_fn,
> int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
> int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
> int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
> int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
> int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
> int PMPI_Reduce_local(const void *inbuf, void *inoutbuf, int count, MPI_Datatype datatype,
> MPI_Op op)
> int PMPI_Op_commutative(MPI_Op op, int *commute);
> int PMPI_Reduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old, int indegree, const int sources[],
> int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, const int sources[], const int degrees[],
> int PMPI_Dist_graph_neighbors_count(MPI_Comm comm, int *indegree, int *outdegree, int *weighted);
> int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree, int sources[], int sourceweights[],
> int PMPI_Improbe(int source, int tag, MPI_Comm comm, int *flag, MPI_Message *message,
> int PMPI_Imrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int PMPI_Mprobe(int source, int tag, MPI_Comm comm, MPI_Message *message, MPI_Status *status);
> int PMPI_Mrecv(void *buf, int count, MPI_Datatype datatype, MPI_Message *message,
> int PMPI_Comm_idup(MPI_Comm comm, MPI_Comm *newcomm, MPI_Request *request);
> int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
> int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype, int root, MPI_Comm comm,
> int PMPI_Igather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Igatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iscatter(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iscatterv(const void *sendbuf, const int sendcounts[], const int displs[],
> int PMPI_Iallgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Iallgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Ialltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype, void *recvbuf,
> int PMPI_Ialltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ialltoallw(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ireduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Iallreduce(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Ireduce_scatter(const void *sendbuf, void *recvbuf, const int recvcounts[],
> int PMPI_Ireduce_scatter_block(const void *sendbuf, void *recvbuf, int recvcount,
> int PMPI_Iscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype, MPI_Op op,
> int PMPI_Iexscan(const void *sendbuf, void *recvbuf, int count, MPI_Datatype datatype,
> int PMPI_Ineighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Ineighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Ineighbor_alltoallw(const void *sendbuf, const int sendcounts[],
> int PMPI_Neighbor_allgather(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_allgatherv(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_alltoall(const void *sendbuf, int sendcount, MPI_Datatype sendtype,
> int PMPI_Neighbor_alltoallv(const void *sendbuf, const int sendcounts[], const int sdispls[],
> int PMPI_Neighbor_alltoallw(const void *sendbuf, const int sendcounts[], const MPI_Aint sdispls[],
> MPI_Comm comm);
> int PMPI_Comm_split_type(MPI_Comm comm, int split_type, int key, MPI_Info info, MPI_Comm *newcomm);
> int PMPI_Comm_create_group(MPI_Comm comm, MPI_Group group, int tag, MPI_Comm *newcomm);
> int PMPI_Get_elements_x(const MPI_Status *status, MPI_Datatype datatype, MPI_Count *count);
> int PMPI_Status_set_elements_x(MPI_Status *status, MPI_Datatype datatype, MPI_Count count);
> int PMPI_Type_get_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int PMPI_Type_get_true_extent_x(MPI_Datatype datatype, MPI_Count *lb, MPI_Count *extent);
> int PMPI_Type_size_x(MPI_Datatype datatype, MPI_Count *size);
> int PMPIX_Comm_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int PMPIX_Comm_remote_group_failed(MPI_Comm comm, MPI_Group *failed_group);
> int PMPIX_Comm_reenable_anysource(MPI_Comm comm, MPI_Group *failed_group);
> int PMPI_T_init_thread(int required, int *provided);
> int PMPI_T_finalize(void);
> int PMPI_T_enum_get_info(MPI_T_enum enumtype, int *num, char *name, int *name_len);
> int PMPI_T_enum_get_item(MPI_T_enum enumtype, int indx, int *value, char *name, int *name_len);
> int PMPI_T_cvar_get_num(int *num_cvar);
> int PMPI_T_cvar_get_info(int cvar_index, char *name, int *name_len, int *verbosity,
> int PMPI_T_cvar_handle_alloc(int cvar_index, void *obj_handle, MPI_T_cvar_handle *handle,
> int *count);
> int PMPI_T_cvar_handle_free(MPI_T_cvar_handle *handle);
> int PMPI_T_cvar_read(MPI_T_cvar_handle handle, void *buf);
> int PMPI_T_cvar_write(MPI_T_cvar_handle handle, const void *buf);
> int PMPI_T_pvar_get_num(int *num_pvar);
> int PMPI_T_pvar_get_info(int pvar_index, char *name, int *name_len, int *verbosity, int *var_class,
> int PMPI_T_pvar_session_create(MPI_T_pvar_session *session);
> int PMPI_T_pvar_session_free(MPI_T_pvar_session *session);
> int PMPI_T_pvar_handle_alloc(MPI_T_pvar_session session, int pvar_index, void *obj_handle,
> int PMPI_T_pvar_handle_free(MPI_T_pvar_session session, MPI_T_pvar_handle *handle);
> int PMPI_T_pvar_start(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_stop(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_read(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int PMPI_T_pvar_write(MPI_T_pvar_session session, MPI_T_pvar_handle handle, const void *buf);
> int PMPI_T_pvar_reset(MPI_T_pvar_session session, MPI_T_pvar_handle handle);
> int PMPI_T_pvar_readreset(MPI_T_pvar_session session, MPI_T_pvar_handle handle, void *buf);
> int PMPI_T_category_get_num(int *num_cat);
> int PMPI_T_category_get_info(int cat_index, char *name, int *name_len, char *desc, int *desc_len,
> int PMPI_T_category_get_cvars(int cat_index, int len, int indices[]);
> int PMPI_T_category_get_pvars(int cat_index, int len, int indices[]);
> int PMPI_T_category_get_categories(int cat_index, int len, int indices[]);
> int PMPI_T_category_changed(int *stamp);
> # 2178 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h" 1
> # 13 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> # 1 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 1
> # 14 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h" 2
> # 123 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> int MPI_File_open(MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh);
> int MPI_File_close(MPI_File *fh);
> int MPI_File_delete(const char *filename, MPI_Info info);
> int MPI_File_set_size(MPI_File fh, MPI_Offset size);
> int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
> int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
> int MPI_File_get_group(MPI_File fh, MPI_Group *group);
> int MPI_File_get_amode(MPI_File fh, int *amode);
> int MPI_File_set_info(MPI_File fh, MPI_Info info);
> int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
> int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype, MPI_Datatype filetype,
> const char *datarep, MPI_Info info);
> int MPI_File_get_view(MPI_File fh, MPI_Offset *disp, MPI_Datatype *etype, MPI_Datatype *filetype,
> char *datarep);
> int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void * buf, int count,
> MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_write_at(MPI_File fh, MPI_Offset offset, const void * buf, int count,
> int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> MPI_Datatype datatype, MPI_Request *request)
> int MPI_File_read(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_read_all(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Status *status)
> int MPI_File_write(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_all(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iread(MPI_File fh, void *buf, int count, MPI_Datatype datatype, MPI_Request *request)
> int MPI_File_iwrite(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
> int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
> int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset, MPI_Offset *disp);
> int MPI_File_read_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iread_shared(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_iwrite_shared(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_read_ordered(MPI_File fh, void *buf, int count, MPI_Datatype datatype,
> int MPI_File_write_ordered(MPI_File fh, const void *buf, int count, MPI_Datatype datatype,
> int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
> int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
> int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf, int count,
> MPI_Datatype datatype) ;
> int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, const void *buf, int count,
> int MPI_File_write_at_all_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_read_all_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
> int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_all_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
> int MPI_File_write_all_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count, MPI_Datatype datatype)
> int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
> int MPI_File_write_ordered_begin(MPI_File fh, const void *buf, int count, MPI_Datatype datatype)
> int MPI_File_write_ordered_end(MPI_File fh, const void *buf, MPI_Status *status);
> int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype, MPI_Aint *extent);
> int MPI_Register_datarep(const char *datarep, MPI_Datarep_conversion_function *read_conversion_fn,
> MPI_Datarep_conversion_function *write_conversion_fn,
> MPI_Datarep_extent_function *dtype_file_extent_fn, void *extra_state);
> int MPI_File_set_atomicity(MPI_File fh, int flag);
> int MPI_File_get_atomicity(MPI_File fh, int *flag);
> int MPI_File_sync(MPI_File fh);
> # 268 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> MPI_File MPI_File_f2c(MPI_Fint file);
> MPI_Fint MPI_File_c2f(MPI_File file);
> # 329 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> int PMPI_File_open(MPI_Comm, const char *, int, MPI_Info, MPI_File *);
> int PMPI_File_close(MPI_File *);
> int PMPI_File_delete(const char *, MPI_Info);
> int PMPI_File_set_size(MPI_File, MPI_Offset);
> int PMPI_File_preallocate(MPI_File, MPI_Offset);
> int PMPI_File_get_size(MPI_File, MPI_Offset *);
> int PMPI_File_get_group(MPI_File, MPI_Group *);
> int PMPI_File_get_amode(MPI_File, int *);
> int PMPI_File_set_info(MPI_File, MPI_Info);
> int PMPI_File_get_info(MPI_File, MPI_Info *);
> int PMPI_File_set_view(MPI_File, MPI_Offset,
> MPI_Datatype, MPI_Datatype, const char *, MPI_Info);
> int PMPI_File_get_view(MPI_File, MPI_Offset *,
> MPI_Datatype *, MPI_Datatype *, char *);
> int PMPI_File_read_at(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype, MPI_Status *)
> int PMPI_File_read_at_all(MPI_File, MPI_Offset, void *,
> int PMPI_File_write_at(MPI_File, MPI_Offset, const void *,
> int PMPI_File_write_at_all(MPI_File, MPI_Offset, const void *,
> int PMPI_File_iread_at(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype, MPI_Request *)
> int PMPI_File_iwrite_at(MPI_File, MPI_Offset, const void *,
> int PMPI_File_read(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_read_all(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_all(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_iread(MPI_File, void *, int, MPI_Datatype, MPI_Request *)
> int PMPI_File_iwrite(MPI_File, const void *, int, MPI_Datatype, MPI_Request *)
> int PMPI_File_seek(MPI_File, MPI_Offset, int);
> int PMPI_File_get_position(MPI_File, MPI_Offset *);
> int PMPI_File_get_byte_offset(MPI_File, MPI_Offset, MPI_Offset *);
> int PMPI_File_read_shared(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_shared(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_iread_shared(MPI_File, void *, int,
> int PMPI_File_iwrite_shared(MPI_File, const void *, int,
> int PMPI_File_read_ordered(MPI_File, void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_write_ordered(MPI_File, const void *, int, MPI_Datatype, MPI_Status *)
> int PMPI_File_seek_shared(MPI_File, MPI_Offset, int);
> int PMPI_File_get_position_shared(MPI_File, MPI_Offset *);
> int PMPI_File_read_at_all_begin(MPI_File, MPI_Offset, void *,
> int, MPI_Datatype)
> int PMPI_File_read_at_all_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_at_all_begin(MPI_File, MPI_Offset, const void *,
> int, MPI_Datatype)
> int PMPI_File_write_at_all_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_read_all_begin(MPI_File, void *, int, MPI_Datatype)
> int PMPI_File_read_all_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_all_begin(MPI_File, const void *, int, MPI_Datatype)
> int PMPI_File_write_all_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_read_ordered_begin(MPI_File, void *, int, MPI_Datatype)
> int PMPI_File_read_ordered_end(MPI_File, void *, MPI_Status *);
> int PMPI_File_write_ordered_begin(MPI_File, const void *, int, MPI_Datatype)
> int PMPI_File_write_ordered_end(MPI_File, const void *, MPI_Status *);
> int PMPI_File_get_type_extent(MPI_File, MPI_Datatype, MPI_Aint *);
> int PMPI_Register_datarep(const char *,
> MPI_Datarep_conversion_function *,
> MPI_Datarep_extent_function *,
> void *);
> int PMPI_File_set_atomicity(MPI_File, int);
> int PMPI_File_get_atomicity(MPI_File, int *);
> int PMPI_File_sync(MPI_File);
> # 467 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpio.h"
> MPI_File PMPI_File_f2c(MPI_Fint);
> MPI_Fint PMPI_File_c2f(MPI_File);
> # 2179 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h" 2
> # 2200 "/opt/cray/mpt/7.2.6/gni/mpich-gnu/5.1/include/mpi.h"
> typedef int MPIX_Grequest_class;
> int MPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
> MPIX_Grequest_poll_function *poll_fn,
> MPIX_Grequest_wait_function *wait_fn,
> MPIX_Grequest_class *greq_class);
> int MPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
> int MPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
> MPIX_Grequest_wait_function *wait_fn, void *extra_state,
> struct mpixi_mutex_s;
> typedef struct mpixi_mutex_s * MPIX_Mutex;
> int MPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
> int MPIX_Mutex_free(MPIX_Mutex *hdl);
> int MPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
> int MPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
> int PMPIX_Grequest_class_create(MPI_Grequest_query_function *query_fn,
> int PMPIX_Grequest_class_allocate(MPIX_Grequest_class greq_class, void *extra_state,
> int PMPIX_Grequest_start(MPI_Grequest_query_function *query_fn,
> int PMPIX_Mutex_create(int count, MPI_Comm comm, MPIX_Mutex *hdl);
> int PMPIX_Mutex_free(MPIX_Mutex *hdl);
> int PMPIX_Mutex_lock(MPIX_Mutex hdl, int mutex, int proc);
> int PMPIX_Mutex_unlock(MPIX_Mutex hdl, int mutex, int proc);
> # 18 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h" 2
> # 1 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h" 1
> # 94 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> # 1 "/usr/include/inttypes.h" 1 3 4
> # 35 "/usr/include/inttypes.h" 3 4
> typedef int __gwchar_t;
> # 274 "/usr/include/inttypes.h" 3 4
> typedef struct
> long int quot;
> long int rem;
> } imaxdiv_t;
> # 298 "/usr/include/inttypes.h" 3 4
> extern intmax_t imaxabs (intmax_t __n) __attribute__ ((__nothrow__)) __attribute__ ((__const__));
> extern imaxdiv_t imaxdiv (intmax_t __numer, intmax_t __denom)
> extern intmax_t strtoimax (__const char *__restrict __nptr,
> char **__restrict __endptr, int __base) __attribute__ ((__nothrow__));
> extern uintmax_t strtoumax (__const char *__restrict __nptr,
> char ** __restrict __endptr, int __base) __attribute__ ((__nothrow__));
> extern intmax_t wcstoimax (__const __gwchar_t *__restrict __nptr,
> __gwchar_t **__restrict __endptr, int __base)
> extern uintmax_t wcstoumax (__const __gwchar_t *__restrict __nptr,
> __gwchar_t ** __restrict __endptr, int __base)
> # 442 "/usr/include/inttypes.h" 3 4
> # 95 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h" 2
> # 103 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> typedef int32_t idx_t;
> # 151 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> typedef double real_t;
> # 199 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> int METIS_PartGraphRecursive(idx_t *nvtxs, idx_t *ncon, idx_t *xadj,
> idx_t *adjncy, idx_t *vwgt, idx_t *vsize, idx_t *adjwgt,
> idx_t *nparts, real_t *tpwgts, real_t *ubvec, idx_t *options,
> idx_t *edgecut, idx_t *part);
> int METIS_PartGraphKway(idx_t *nvtxs, idx_t *ncon, idx_t *xadj,
> int METIS_MeshToDual(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> idx_t *ncommon, idx_t *numflag, idx_t **r_xadj, idx_t **r_adjncy);
> int METIS_MeshToNodal(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> int METIS_PartMeshNodal(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> idx_t *vwgt, idx_t *vsize, idx_t *nparts, real_t *tpwgts,
> idx_t *options, idx_t *objval, idx_t *epart, idx_t *npart);
> int METIS_PartMeshDual(idx_t *ne, idx_t *nn, idx_t *eptr, idx_t *eind,
> idx_t *vwgt, idx_t *vsize, idx_t *ncommon, idx_t *nparts,
> real_t *tpwgts, idx_t *options, idx_t *objval, idx_t *epart,
> idx_t *npart);
> int METIS_NodeND(idx_t *nvtxs, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
> idx_t *options, idx_t *perm, idx_t *iperm);
> int METIS_Free(void *ptr);
> int METIS_SetDefaultOptions(idx_t *options);
> int METIS_NodeNDP(idx_t nvtxs, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
> idx_t npes, idx_t *options, idx_t *perm, idx_t *iperm,
> idx_t *sizes);
> int METIS_ComputeVertexSeparator(idx_t *nvtxs, idx_t *xadj, idx_t *adjncy,
> idx_t *vwgt, idx_t *options, idx_t *sepsize, idx_t *part);
> int METIS_NodeRefine(idx_t nvtxs, idx_t *xadj, idx_t *vwgt, idx_t *adjncy,
> idx_t *where, idx_t *hmarker, real_t ubfactor);
> # 255 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/metis.h"
> typedef enum {
> METIS_OK = 1,
> METIS_ERROR_INPUT = -2,
> METIS_ERROR_MEMORY = -3,
> METIS_ERROR = -4
> } rstatus_et;
> typedef enum {
> METIS_OP_PMETIS,
> METIS_OP_KMETIS,
> METIS_OP_OMETIS
> } moptype_et;
> typedef enum {
> METIS_OPTION_PTYPE,
> METIS_OPTION_OBJTYPE,
> METIS_OPTION_CTYPE,
> METIS_OPTION_IPTYPE,
> METIS_OPTION_RTYPE,
> METIS_OPTION_DBGLVL,
> METIS_OPTION_NITER,
> METIS_OPTION_NCUTS,
> METIS_OPTION_SEED,
> METIS_OPTION_NO2HOP,
> METIS_OPTION_MINCONN,
> METIS_OPTION_CONTIG,
> METIS_OPTION_COMPRESS,
> METIS_OPTION_CCORDER,
> METIS_OPTION_PFACTOR,
> METIS_OPTION_NSEPS,
> METIS_OPTION_UFACTOR,
> METIS_OPTION_NUMBERING,
> METIS_OPTION_HELP,
> METIS_OPTION_TPWGTS,
> METIS_OPTION_NCOMMON,
> METIS_OPTION_NOOUTPUT,
> METIS_OPTION_BALANCE,
> METIS_OPTION_GTYPE,
> METIS_OPTION_UBVEC
> } moptions_et;
> typedef enum {
> METIS_PTYPE_RB,
> METIS_PTYPE_KWAY
> } mptype_et;
> typedef enum {
> METIS_GTYPE_DUAL,
> METIS_GTYPE_NODAL
> } mgtype_et;
> typedef enum {
> METIS_CTYPE_RM,
> METIS_CTYPE_SHEM
> } mctype_et;
> typedef enum {
> METIS_IPTYPE_GROW,
> METIS_IPTYPE_RANDOM,
> METIS_IPTYPE_EDGE,
> METIS_IPTYPE_NODE,
> METIS_IPTYPE_METISRB
> } miptype_et;
> typedef enum {
> METIS_RTYPE_FM,
> METIS_RTYPE_GREEDY,
> METIS_RTYPE_SEP2SIDED,
> METIS_RTYPE_SEP1SIDED
> } mrtype_et;
> typedef enum {
> METIS_DBG_INFO = 1,
> METIS_DBG_TIME = 2,
> METIS_DBG_COARSEN = 4,
> METIS_DBG_REFINE = 8,
> METIS_DBG_IPART = 16,
> METIS_DBG_MOVEINFO = 32,
> METIS_DBG_SEPINFO = 64,
> METIS_DBG_CONNINFO = 128,
> METIS_DBG_CONTIGINFO = 256,
> METIS_DBG_MEMORY = 2048,
> } mdbglvl_et;
> typedef enum {
> METIS_OBJTYPE_CUT,
> METIS_OBJTYPE_VOL,
> METIS_OBJTYPE_NODE
> } mobjtype_et;
> # 19 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h" 2
> # 67 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h"
> int ParMETIS_V3_PartKway(
> idx_t *vtxdist, idx_t *xadj, idx_t *adjncy, idx_t *vwgt,
> idx_t *adjwgt, idx_t *wgtflag, idx_t *numflag, idx_t *ncon, idx_t *nparts,
> real_t *tpwgts, real_t *ubvec, idx_t *options, idx_t *edgecut, idx_t *part,
> MPI_Comm *comm);
> int ParMETIS_V3_PartGeomKway(
> idx_t *adjwgt, idx_t *wgtflag, idx_t *numflag, idx_t *ndims, real_t *xyz,
> idx_t *ncon, idx_t *nparts, real_t *tpwgts, real_t *ubvec, idx_t *options,
> idx_t *edgecut, idx_t *part, MPI_Comm *comm);
> int ParMETIS_V3_PartGeom(
> idx_t *vtxdist, idx_t *ndims, real_t *xyz, idx_t *part, MPI_Comm *comm);
> int ParMETIS_V3_RefineKway(
> int ParMETIS_V3_AdaptiveRepart(
> idx_t *vsize, idx_t *adjwgt, idx_t *wgtflag, idx_t *numflag, idx_t *ncon,
> idx_t *nparts, real_t *tpwgts, real_t *ubvec, real_t *ipc2redist,
> idx_t *options, idx_t *edgecut, idx_t *part, MPI_Comm *comm);
> int ParMETIS_V3_Mesh2Dual(
> idx_t *elmdist, idx_t *eptr, idx_t *eind, idx_t *numflag,
> idx_t *ncommonnodes, idx_t **xadj, idx_t **adjncy, MPI_Comm *comm);
> int ParMETIS_V3_PartMeshKway(
> idx_t *elmdist, idx_t *eptr, idx_t *eind, idx_t *elmwgt,
> idx_t *wgtflag, idx_t *numflag, idx_t *ncon, idx_t *ncommonnodes, idx_t *nparts,
> MPI_Comm *comm);
> int ParMETIS_V3_NodeND(
> idx_t *vtxdist, idx_t *xadj, idx_t *adjncy, idx_t *numflag,
> idx_t *options, idx_t *order, idx_t *sizes, MPI_Comm *comm);
> int ParMETIS_V32_NodeND(
> idx_t *numflag, idx_t *mtype, idx_t *rtype, idx_t *p_nseps, idx_t *s_nseps,
> real_t *ubfrac, idx_t *seed, idx_t *dbglvl, idx_t *order,
> int ParMETIS_SerialNodeND(
> void ParMETIS_ComputeVertexSeparator(
> real_t *ubfrac, idx_t *idbglvl, idx_t *order, idx_t *sizes,
> MPI_Comm *comm);
> # 133 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/parmetis.h"
> typedef enum {
> PARMETIS_OP_KMETIS,
> PARMETIS_OP_GKMETIS,
> PARMETIS_OP_GMETIS,
> PARMETIS_OP_RMETIS,
> PARMETIS_OP_AMETIS,
> PARMETIS_OP_OMETIS,
> PARMETIS_OP_M2DUAL,
> PARMETIS_OP_MKMETIS
> } pmoptype_et;
> # 3 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> Preprocess stderr before filtering::
> Preprocess stderr after filtering::
> Found header files ['parmetis.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Popping language C
> Checking for functions [ParMETIS_ComputeVertexSeparator] in library ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libparmetis.a'] ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmetis.a']
> Pushing language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -c -o /tmp/petsc-uoFdrH/config.libraries/conftest.o -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.utilities.closure -I/tmp/petsc-uoFdrH/config.compilers -I/tmp/petsc-uoFdrH/config.headers -I/tmp/petsc-uoFdrH/config.utilities.cacheDetails -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.atomics -I/tmp/petsc-uoFdrH/config.utilities.featureTestMacros -I/tmp/petsc-uoFdrH/config.functions -I/tmp/petsc-uoFdrH/config.utilities.missing -I/tmp/petsc-uoFdrH/PETSc.options.scalarTypes -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.libraries -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.c
> Successful compile:
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> /* Override any gcc2 internal prototype to avoid an error. */
> char ParMETIS_ComputeVertexSeparator();
> static void _check_ParMETIS_ComputeVertexSeparator() { ParMETIS_ComputeVertexSeparator(); }
> int main() {
> _check_ParMETIS_ComputeVertexSeparator();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lparmetis -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lmetis -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBPARMETIS" to "1"
> Popping language C
> TEST checkSharedLibrary from config.packages.parmetis(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.parmetis(config/BuildSystem/config/package.py:792)
> By default we don't care about checking if the library is shared
> Popping language C
> TEST alternateConfigureLibrary from config.packages.Zoltan(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.Zoltan(config/BuildSystem/config/package.py:796)
> Called if --with-packagename=0; does nothing by default
> TEST alternateConfigureLibrary from config.packages.hdf5(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.hdf5(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.med(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.med(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.ascem-io(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.ascem-io(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.cgns(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.cgns(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.pflotran(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.pflotran(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.alquimia(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.alquimia(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.netcdf(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.netcdf(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.exodusii(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.exodusii(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.Chaco(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.Chaco(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.openblas(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.openblas(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.fblaslapack(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.fblaslapack(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.f2cblaslapack(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.f2cblaslapack(config/BuildSystem/config/package.py:796)
> Pushing language C
> TEST checkDependencies from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.BlasLapack(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:332)
> TESTING: configureLibrary from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:332)
> Checking for a functional BLAS and LAPACK in User specified BLAS/LAPACK library
> TEST checkLib from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:103)
> TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:103)
> Checking for BLAS and LAPACK symbols
> Checking for functions [ddot_] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char ddot_();
> static void _check_ddot_() { ddot_(); }
> int main() {
> _check_ddot_();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_intel_lp64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Possible ERROR while running linker:
> stderr:
> /opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a(mkl_aa_fw_load_orsl_lite_lib.o): In function `mkl_aa_fw_load_orsl_lite_lib':
> ../../../../serv/offload/framework/core/mkl_aa_fw_load_orsl_lite_lib.c:(.text+0xbe): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Defined "HAVE_LIBMKL_INTEL_LP64" to "1"
> Defined "HAVE_LIBMKL_CORE" to "1"
> Defined "HAVE_LIBMKL_SEQUENTIAL" to "1"
> Popping language C
> Checking for functions [dgetrs_] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char dgetrs_();
> static void _check_dgetrs_() { dgetrs_(); }
> int main() {
> _check_dgetrs_();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Popping language C
> Checking for functions [dgeev_] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char dgeev_();
> static void _check_dgeev_() { dgeev_(); }
> int main() {
> _check_dgeev_();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a(load_library.o): In function `mkl_ueaa_prv_load_backend_lib':
> load_library.c:(.text+0x1d1): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
> Popping language C
> Found Fortran mangling on BLAS/LAPACK which is underscore
> Defined "BLASLAPACK_UNDERSCORE" to "1"
> TEST check64BitBLASIndices from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:495)
> TESTING: check64BitBLASIndices from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:495)
> Check for and use 64bit integer blas
> TEST checkESSL from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:412)
> TESTING: checkESSL from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:412)
> Check for the IBM ESSL library
> Checking for functions [iessl] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char iessl();
> static void _check_iessl() { iessl(); }
> int main() {
> _check_iessl();;
> return 0;
> Pushing language C
> Popping language C
> Possible ERROR while running linker: exit code 256
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_iessl':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `iessl'
> collect2: error: ld returned 1 exit status
> Popping language C
> TEST checkPESSL from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:428)
> TESTING: checkPESSL from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:428)
> Check for the IBM PESSL library - and error out - if used instead of ESSL
> Checking for functions [ipessl] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char ipessl();
> static void _check_ipessl() { ipessl(); }
> int main() {
> _check_ipessl();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> /tmp/petsc-uoFdrH/config.libraries/conftest.o: In function `_check_ipessl':
> /tmp/petsc-uoFdrH/config.libraries/conftest.c:5: undefined reference to `ipessl'
> Popping language C
> TEST checkMKL from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:420)
> TESTING: checkMKL from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:420)
> Check for Intel MKL library
> Checking for functions [mkl_set_num_threads] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char mkl_set_num_threads();
> static void _check_mkl_set_num_threads() { mkl_set_num_threads(); }
> int main() {
> _check_mkl_set_num_threads();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Popping language C
> TEST checkMissing from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:453)
> TESTING: checkMissing from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:453)
> Check for missing LAPACK routines
> Checking for functions [dtrsen_ dgerfs_ dgges_ dtgsen_ dgesvd_ dgetrf_ dgetrs_ dgeev_ dgelss_ dsyev_ dsyevx_ dsygv_ dsygvx_ dpotrf_ dpotrs_ dstebz_ dpttrf_ dpttrs_ dstein_ dorgqr_ dgeqrf_ dgesv_ dhseqr_ dsteqr_] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a']
> Pushing language C
> Successful compile:
> Source:
> char dtrsen_();
> static void _check_dtrsen_() { dtrsen_(); }
> char dgerfs_();
> static void _check_dgerfs_() { dgerfs_(); }
> char dgges_();
> static void _check_dgges_() { dgges_(); }
> char dtgsen_();
> static void _check_dtgsen_() { dtgsen_(); }
> char dgesvd_();
> static void _check_dgesvd_() { dgesvd_(); }
> char dgetrf_();
> static void _check_dgetrf_() { dgetrf_(); }
> char dgetrs_();
> char dgeev_();
> char dgelss_();
> static void _check_dgelss_() { dgelss_(); }
> char dsyev_();
> static void _check_dsyev_() { dsyev_(); }
> char dsyevx_();
> static void _check_dsyevx_() { dsyevx_(); }
> char dsygv_();
> static void _check_dsygv_() { dsygv_(); }
> char dsygvx_();
> static void _check_dsygvx_() { dsygvx_(); }
> char dpotrf_();
> static void _check_dpotrf_() { dpotrf_(); }
> char dpotrs_();
> static void _check_dpotrs_() { dpotrs_(); }
> char dstebz_();
> static void _check_dstebz_() { dstebz_(); }
> char dpttrf_();
> static void _check_dpttrf_() { dpttrf_(); }
> char dpttrs_();
> static void _check_dpttrs_() { dpttrs_(); }
> char dstein_();
> static void _check_dstein_() { dstein_(); }
> char dorgqr_();
> static void _check_dorgqr_() { dorgqr_(); }
> char dgeqrf_();
> static void _check_dgeqrf_() { dgeqrf_(); }
> char dgesv_();
> static void _check_dgesv_() { dgesv_(); }
> char dhseqr_();
> static void _check_dhseqr_() { dhseqr_(); }
> char dsteqr_();
> static void _check_dsteqr_() { dsteqr_(); }
> int main() {
> _check_dtrsen_();
> _check_dgerfs_();
> _check_dgges_();
> _check_dtgsen_();
> _check_dgesvd_();
> _check_dgetrf_();
> _check_dgetrs_();
> _check_dgeev_();
> _check_dgelss_();
> _check_dsyev_();
> _check_dsyevx_();
> _check_dsygv_();
> _check_dsygvx_();
> _check_dpotrf_();
> _check_dpotrs_();
> _check_dstebz_();
> _check_dpttrf_();
> _check_dpttrs_();
> _check_dstein_();
> _check_dorgqr_();
> _check_dgeqrf_();
> _check_dgesv_();
> _check_dhseqr_();
> _check_dsteqr_();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_intel_lp64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_intel_lp64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> stderr:
> Popping language C
> TEST checklsame from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:468)
> TESTING: checklsame from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:468)
> Do the BLAS/LAPACK libraries have a valid lsame() function with correction binding. Lion and xcode 4.2 do not
> Checking for functions [lsame_] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char lsame_();
> static void _check_lsame_() { lsame_(); }
> int main() {
> _check_lsame_();;
> return 0;
> Pushing language C
> Popping language C
> Popping language C
> TEST checksdotreturnsdouble from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/packages/BlasLapack.py:530)
> TESTING: checksdotreturnsdouble from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:530)
> Determines if BLAS sdot routine returns a float or a double
> Checking if sdot() returns a float or a double
> Checking if snrm() returns a float or a double
> TEST checkSharedLibrary from config.packages.BlasLapack(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.BlasLapack(config/BuildSystem/config/package.py:792)
> Popping language C
> TEST alternateConfigureLibrary from config.packages.sundials(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.sundials(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.spai(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.spai(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.pARMS(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.pARMS(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.p4est(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.p4est(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.mkl_cpardiso(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.mkl_cpardiso(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.fftw(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.fftw(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.elemental(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.elemental(config/BuildSystem/config/package.py:796)
> TEST alternateConfigureLibrary from config.packages.ml(/home/zampins/src/petsc/config/BuildSystem/config/package.py:796)
> TESTING: alternateConfigureLibrary from config.packages.ml(config/BuildSystem/config/package.py:796)
> Checking for functions [dgels_] in library ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a'] []
> Pushing language C
> Successful compile:
> Source:
> char dgels_();
> static void _check_dgels_() { dgels_(); }
> int main() {
> _check_dgels_();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Popping language C
> Found dgels() in Lapack library as needed by hypre
> Pushing language C
> TEST checkDependencies from config.packages.hypre(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.hypre(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.hypre(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.hypre(config/BuildSystem/config/package.py:744)
> Find an installation and check if it can work with PETSc
> Checking for a functional hypre
> Looking for HYPRE at git.hypre, hg.hypre or a directory starting with ['hypre']
> Found a copy of HYPRE in git.hypre
> Executing: ['git', 'rev-parse', '--git-dir']
> stdout: .git
> Executing: ['git', 'cat-file', '-e', 'v2.12.0^{commit}']
> Executing: ['git', 'fetch']
> Executing: ['git', 'rev-parse', 'v2.12.0']
> stdout: 1afe41985e85ddb9f0efb2a200103dfdaed9c64b
> Executing: ['git', 'stash']
> stdout:
> Saved working directory and index state WIP on (no branch): 83b1f19 Release v2.11.1-55-g2ea0e43
> HEAD is now at 83b1f19 Release v2.11.1-55-g2ea0e43
> Executing: ['git', 'clean', '-f', '-d', '-x']
> stdout:
> Removing pkg.gitcommit
> Removing src/hypre.petscconf
> Executing: ['git', 'checkout', '-f', '1afe41985e85ddb9f0efb2a200103dfdaed9c64b']
> Pushing language C
> All intermediate test results are stored in /tmp/petsc-uoFdrH/config.packages.hypre
> Popping language C
> Pushing language Cxx
> Popping language Cxx
> Pushing language FC
> Executing: /opt/cray/craype/2.4.2/bin/ftn -v
> Popping language FC
> Do not need to rebuild HYPRE
> Checking for library in Download HYPRE: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libHYPRE.a']
> Contents: ['include', 'lib', 'bin', 'externalpackages', 'share', 'initial_cache_file.cmake', 'CMakeFiles', 'obj', 'Makefile', 'cmake_install.cmake', 'CMakeCache.txt']
> TEST check from config.libraries(/home/zampins/src/petsc/config/BuildSystem/config/libraries.py:159)
> TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:159)
> Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
> - libDir may be a list of directories
> - libName may be a list of library names
> Checking for functions [HYPRE_IJMatrixCreate] in library ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libHYPRE.a'] ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a']
> Pushing language C
> Successful compile:
> Source:
> char HYPRE_IJMatrixCreate();
> static void _check_HYPRE_IJMatrixCreate() { HYPRE_IJMatrixCreate(); }
> int main() {
> _check_HYPRE_IJMatrixCreate();;
> return 0;
> Pushing language C
> Popping language C
> Executing: /opt/cray/craype/2.4.2/bin/cc -o /tmp/petsc-uoFdrH/config.libraries/conftest -g -O0 /tmp/petsc-uoFdrH/config.libraries/conftest.o -Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib -lHYPRE -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_intel_lp64 -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_sequential -Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64 -lmkl_core -lrt -lm -lpthread -lz -ldl -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/ -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lirc -liomp5 -lsvml -limf -lifcore -lirng -lifport -lirc -ldl
> Defined "HAVE_LIBHYPRE" to "1"
> Popping language C
> Checking for headers Download HYPRE: ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Pushing language C
> TEST checkInclude from config.headers(/home/zampins/src/petsc/config/BuildSystem/config/headers.py:86)
> TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
> Checks if a particular include file can be found along particular include paths
> Checking for header files ['HYPRE.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Checking include with compiler flags var CPPFLAGS ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers -I/home/zampins/src/petsc/haswell_debug_gnu_mkl/include /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "/tmp/petsc-uoFdrH/config.headers/conftest.c"
> # 1 "<built-in>"
> # 1 "<command-line>"
> # 1 "/tmp/petsc-uoFdrH/config.headers/confdefs.h" 1
> # 2 "/tmp/petsc-uoFdrH/config.headers/conftest.c" 2
> # 1 "/tmp/petsc-uoFdrH/config.headers/conffix.h" 1
> # 1 "/home/zampins/src/petsc/haswell_debug_gnu_mkl/include/HYPRE.h" 1
> Found header files ['HYPRE.h'] in ['/home/zampins/src/petsc/haswell_debug_gnu_mkl/include']
> Popping language C
> TEST checkSharedLibrary from config.packages.hypre(/home/zampins/src/petsc/config/BuildSystem/config/package.py:792)
> TESTING: checkSharedLibrary from config.packages.hypre(config/BuildSystem/config/package.py:792)
> Popping language C
> Pushing language C
> TEST checkDependencies from config.packages.mkl_pardiso(/home/zampins/src/petsc/config/BuildSystem/config/package.py:719)
> TESTING: checkDependencies from config.packages.mkl_pardiso(config/BuildSystem/config/package.py:719)
> TEST configureLibrary from config.packages.mkl_pardiso(/home/zampins/src/petsc/config/BuildSystem/config/package.py:744)
> TESTING: configureLibrary from config.packages.mkl_pardiso(config/BuildSystem/config/package.py:744)
> Checking for a functional mkl_pardiso
> Checking for library in User specified MKL_PARDISO libraries: []
> Contents: ['interfaces', 'benchmarks', 'examples', 'include', 'bin', 'lib', 'tools', 'tests']
> Checking for functions [pardisoinit] in library [] ['/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_intel_lp64.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_sequential.a', '/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/libmkl_core.a']
> Pushing language C
> Successful compile:
> Source:
> char pardisoinit();
> static void _check_pardisoinit() { pardisoinit(); }
> int main() {
> _check_pardisoinit();;
> return 0;
> Pushing language C
> Popping language C
> stderr:
> Popping language C
> Checking for headers User specified MKL_PARDISO libraries: ['/opt/intel/composer_xe_2015.1.133/mkl/include']
> Pushing language C
> Checking for header files ['mkl.h'] in ['/opt/intel/composer_xe_2015.1.133/mkl/include']
> Checking include with compiler flags var CPPFLAGS ['/opt/intel/composer_xe_2015.1.133/mkl/include']
> Executing: /opt/cray/craype/2.4.2/bin/cc -E -I/tmp/petsc-uoFdrH/config.setCompilers -I/tmp/petsc-uoFdrH/config.types -I/tmp/petsc-uoFdrH/config.packages.MPI -I/tmp/petsc-uoFdrH/config.headers -I/opt/intel/composer_xe_2015.1.133/mkl/include /tmp/petsc-uoFdrH/config.headers/conftest.c
> stdout:
> # 1 "<built-in>"
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h" 1
> # 45 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h"
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_types.h" 1
> # 38 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_types.h"
> typedef
> struct _MKL_Complex8 {
> float real;
> float imag;
> } MKL_Complex8;
> typedef
> struct _MKL_Complex16 {
> double real;
> double imag;
> } MKL_Complex16;
> typedef
> struct {
> int MajorVersion;
> int MinorVersion;
> int UpdateVersion;
> char * ProductStatus;
> char * Build;
> char * Processor;
> char * Platform;
> } MKLVersion;
> # 46 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h" 2
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_blas.h" 1
> # 40 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_blas.h"
> void XERBLA(const char *srname, const int *info, const int lsrname);
> int LSAME(const char *ca, const char *cb, const int lca, const int lcb);
> float SCABS1(const MKL_Complex8 *c);
> float SASUM(const int *n, const float *x, const int *incx);
> void SAXPY(const int *n, const float *alpha, const float *x, const int *incx, float *y, const int *incy);
> void SAXPBY(const int *n, const float *alpha, const float *x, const int *incx, const float *beta, float *y, const int *incy);
> void SAXPYI(const int *nz, const float *a, const float *x, const int *indx,float *y);
> float SCASUM(const int *n, const MKL_Complex8 *x, const int *incx);
> float SCNRM2(const int *n, const MKL_Complex8 *x, const int *incx);
> void SCOPY(const int *n, const float *x, const int *incx, float *y, const int *incy);
> float SDOT(const int *n, const float *x, const int *incx, const float *y, const int *incy);
> float SDSDOT(const int *n, const float *sb, const float *x, const int *incx, const float *y, const int *incy);
> float SDOTI(const int *nz, const float *x, const int *indx, const float *y);
> void SGTHR(const int *nz, const float *y, float *x, const int *indx);
> void SGTHRZ(const int *nz, float *y, float *x, const int *indx);
> float SNRM2(const int *n, const float *x, const int *incx);
> void SROT(const int *n, float *x, const int *incx, float *y, const int *incy, const float *c, const float *s);
> void SROTG(float *a,float *b,float *c,float *s);
> void SROTI(const int *nz, float *x, const int *indx, float *y, const float *c, const float *s);
> void SROTM(const int *n, float *x, const int *incx, float *y, const int *incy, const float *param);
> void SROTMG(float *d1, float *d2, float *x1, const float *y1, float *param);
> void SSCAL(const int *n, const float *a, float *x, const int *incx);
> void SSCTR(const int *nz, const float *x, const int *indx, float *y);
> void SSWAP(const int *n, float *x, const int *incx, float *y, const int *incy);
> int ISAMAX(const int *n, const float *x, const int *incx);
> int ISAMIN(const int *n, const float *x, const int *incx);
> void CAXPY(const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy);
> void CAXPBY(const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *beta, MKL_Complex8 *y, const int *incy);
> void CAXPYI(const int *nz, const MKL_Complex8 *a, const MKL_Complex8 *x, const int *indx, MKL_Complex8 *y);
> void CCOPY(const int *n, const MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy);
> void CDOTC(MKL_Complex8 *pres, const int *n, const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *y, const int *incy);
> void CDOTCI(MKL_Complex8 *pres, const int *nz, const MKL_Complex8 *x, const int *indx, const MKL_Complex8 *y);
> void CDOTU(MKL_Complex8 *pres, const int *n, const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *y, const int *incy);
> void CDOTUI(MKL_Complex8 *pres, const int *nz, const MKL_Complex8 *x, const int *indx, const MKL_Complex8 *y);
> void CGTHR(const int *nz, const MKL_Complex8 *y, MKL_Complex8 *x, const int *indx);
> void CGTHRZ(const int *nz, MKL_Complex8 *y, MKL_Complex8 *x, const int *indx);
> void CROTG(MKL_Complex8 *a, const MKL_Complex8 *b, float *c, MKL_Complex8 *s);
> void CSCAL(const int *n, const MKL_Complex8 *a, MKL_Complex8 *x, const int *incx);
> void CSCTR(const int *nz, const MKL_Complex8 *x, const int *indx, MKL_Complex8 *y);
> void CSROT(const int *n, MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy, const float *c, const float *s);
> void CSSCAL(const int *n, const float *a, MKL_Complex8 *x, const int *incx);
> void CSWAP(const int *n, MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy);
> int ICAMAX(const int *n, const MKL_Complex8 *x, const int *incx);
> int ICAMIN(const int *n, const MKL_Complex8 *x, const int *incx);
> double DCABS1(const MKL_Complex16 *z);
> double DASUM(const int *n, const double *x, const int *incx);
> void DAXPY(const int *n, const double *alpha, const double *x, const int *incx, double *y, const int *incy);
> void DAXPBY(const int *n, const double *alpha, const double *x, const int *incx, const double *beta, double *y, const int *incy);
> void DAXPYI(const int *nz, const double *a, const double *x, const int *indx, double *y);
> void DCOPY(const int *n, const double *x, const int *incx, double *y, const int *incy);
> double DDOT(const int *n, const double *x, const int *incx, const double *y, const int *incy);
> double DSDOT(const int *n, const float *x, const int *incx, const float *y, const int *incy);
> double DDOTI(const int *nz, const double *x, const int *indx, const double *y);
> void DGTHR(const int *nz, const double *y, double *x, const int *indx);
> void DGTHRZ(const int *nz, double *y, double *x, const int *indx);
> double DNRM2(const int *n, const double *x, const int *incx);
> void DROT(const int *n, double *x, const int *incx, double *y, const int *incy, const double *c, const double *s);
> void DROTG(double *a,double *b,double *c,double *s);
> void DROTI(const int *nz, double *x, const int *indx, double *y, const double *c, const double *s);
> void DROTM(const int *n, double *x, const int *incx, double *y, const int *incy, const double *param);
> void DROTMG(double *d1, double *d2, double *x1, const double *y1, double *param);
> void DSCAL(const int *n, const double *a, double *x, const int *incx);
> void DSCTR(const int *nz, const double *x, const int *indx, double *y);
> void DSWAP(const int *n, double *x, const int *incx, double *y, const int *incy);
> double DZASUM(const int *n, const MKL_Complex16 *x, const int *incx);
> double DZNRM2(const int *n, const MKL_Complex16 *x, const int *incx);
> int IDAMAX(const int *n, const double *x, const int *incx);
> int IDAMIN(const int *n, const double *x, const int *incx);
> void ZAXPY(const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy);
> void ZAXPBY(const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *beta, MKL_Complex16 *y, const int *incy);
> void ZAXPYI(const int *nz, const MKL_Complex16 *a, const MKL_Complex16 *x, const int *indx, MKL_Complex16 *y);
> void ZCOPY(const int *n, const MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy);
> void ZDOTC(MKL_Complex16 *pres, const int *n, const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *y, const int *incy);
> void ZDOTCI(MKL_Complex16 *pres,const int *nz, const MKL_Complex16 *x, const int *indx, const MKL_Complex16 *y);
> void ZDOTU(MKL_Complex16 *pres, const int *n, const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *y, const int *incy);
> void ZDOTUI(MKL_Complex16 *pres, const int *nz, const MKL_Complex16 *x, const int *indx, const MKL_Complex16 *y);
> void ZDROT(const int *n, MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy, const double *c, const double *s);
> void ZDSCAL(const int *n, const double *a, MKL_Complex16 *x, const int *incx);
> void ZGTHR(const int *nz, const MKL_Complex16 *y, MKL_Complex16 *x, const int *indx);
> void ZGTHRZ(const int *nz, MKL_Complex16 *y, MKL_Complex16 *x, const int *indx);
> void ZROTG(MKL_Complex16 *a, const MKL_Complex16 *b, double *c, MKL_Complex16 *s);
> void ZSCAL(const int *n, const MKL_Complex16 *a, MKL_Complex16 *x, const int *incx);
> void ZSCTR(const int *nz, const MKL_Complex16 *x, const int *indx, MKL_Complex16 *y);
> void ZSWAP(const int *n, MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy);
> int IZAMAX(const int *n, const MKL_Complex16 *x, const int *incx);
> int IZAMIN(const int *n,const MKL_Complex16 *x, const int *incx);
> void SGBMV(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> const float *alpha, const float *a, const int *lda, const float *x, const int *incx,
> void SGEMV(const char *trans, const int *m, const int *n, const float *alpha,
> void SGER(const int *m, const int *n, const float *alpha, const float *x, const int *incx,
> const float *y, const int *incy, float *a, const int *lda);
> void SSBMV(const char *uplo, const int *n, const int *k,
> void SSPMV(const char *uplo, const int *n, const float *alpha, const float *ap,
> void SSPR(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx, float *ap);
> void SSPR2(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> const float *y, const int *incy, float *ap);
> void SSYMV(const char *uplo, const int *n, const float *alpha, const float *a, const int *lda,
> void SSYR(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> void SSYR2(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> void STBMV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> const float *a, const int *lda, float *x, const int *incx);
> void STBSV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void STPMV(const char *uplo, const char *trans, const char *diag, const int *n,
> const float *ap, float *x, const int *incx);
> void STPSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void STRMV(const char *uplo, const char *transa, const char *diag, const int *n,
> const float *a, const int *lda, float *b, const int *incx);
> void STRSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void SGEM2VU(const int *m, const int *n, const float *alpha, const float *a, const int *lda,
> const float *x1, const int *incx1, const float *x2, const int *incx2,
> const float *beta, float *y1, const int *incy1, float *y2, const int *incy2);
> void CGBMV(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> const MKL_Complex8 *alpha, const MKL_Complex8 *a, const int *lda,
> void CGEMV(const char *trans, const int *m, const int *n, const MKL_Complex8 *alpha,
> const MKL_Complex8 *a, const int *lda, const MKL_Complex8 *x, const int *incx,
> void CGERC(const int *m, const int *n, const MKL_Complex8 *alpha,
> const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *y, const int *incy,
> MKL_Complex8 *a, const int *lda);
> void CGERU(const int *m, const int *n, const MKL_Complex8 *alpha,
> void CHBMV(const char *uplo, const int *n, const int *k, const MKL_Complex8 *alpha,
> void CHEMV(const char *uplo, const int *n, const MKL_Complex8 *alpha,
> void CHER(const char *uplo, const int *n, const float *alpha, const MKL_Complex8 *x, const int *incx,
> void CHER2(const char *uplo, const int *n, const MKL_Complex8 *alpha,
> void CHPMV(const char *uplo, const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *ap,
> void CHPR(const char *uplo, const int *n, const float *alpha, const MKL_Complex8 *x, const int *incx,
> MKL_Complex8 *ap);
> void CHPR2(const char *uplo, const int *n, const MKL_Complex8 *alpha,
> MKL_Complex8 *ap);
> void CTBMV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> const MKL_Complex8 *a, const int *lda, MKL_Complex8 *x, const int *incx);
> void CTBSV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void CTPMV(const char *uplo, const char *trans, const char *diag, const int *n,
> const MKL_Complex8 *ap, MKL_Complex8 *x, const int *incx);
> void CTPSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void CTRMV(const char *uplo, const char *transa, const char *diag, const int *n,
> const MKL_Complex8 *a, const int *lda, MKL_Complex8 *b, const int *incx);
> void CTRSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void CGEM2VC(const int *m, const int *n, const MKL_Complex8 *alpha,
> const MKL_Complex8 *a, const int *lda, const MKL_Complex8 *x1, const int *incx1,
> const MKL_Complex8 *x2, const int *incx2, const MKL_Complex8 *beta,
> MKL_Complex8 *y1, const int *incy1, MKL_Complex8 *y2, const int *incy2);
> void SCGEMV(const char *trans, const int *m, const int *n, const MKL_Complex8 *alpha,
> const float *a, const int *lda, const MKL_Complex8 *x, const int *incx,
> void DGBMV(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> const double *alpha, const double *a, const int *lda, const double *x, const int *incx,
> void DGEMV(const char *trans, const int *m, const int *n, const double *alpha,
> void DGER(const int *m, const int *n, const double *alpha, const double *x, const int *incx,
> const double *y, const int *incy, double *a, const int *lda);
> void DSBMV(const char *uplo, const int *n, const int *k, const double *alpha,
> void DSPMV(const char *uplo, const int *n, const double *alpha, const double *ap,
> void DSPR(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx, double *ap);
> void DSPR2(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> const double *y, const int *incy, double *ap);
> void DSYMV(const char *uplo, const int *n, const double *alpha, const double *a, const int *lda,
> void DSYR(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> void DSYR2(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> void DTBMV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> const double *a, const int *lda, double *x, const int *incx);
> void DTBSV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void DTPMV(const char *uplo, const char *trans, const char *diag, const int *n,
> const double *ap, double *x, const int *incx);
> void DTPSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void DTRMV(const char *uplo, const char *transa, const char *diag, const int *n,
> const double *a, const int *lda, double *b, const int *incx);
> void DTRSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void DGEM2VU(const int *m, const int *n, const double *alpha,
> const double *a, const int *lda, const double *x1, const int *incx1,
> const double *x2, const int *incx2, const double *beta,
> double *y1, const int *incy1, double *y2, const int *incy2);
> void ZGBMV(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> const MKL_Complex16 *alpha, const MKL_Complex16 *a, const int *lda,
> void ZGEMV(const char *trans, const int *m, const int *n, const MKL_Complex16 *alpha,
> const MKL_Complex16 *a, const int *lda, const MKL_Complex16 *x, const int *incx,
> void ZGERC(const int *m, const int *n, const MKL_Complex16 *alpha,
> const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *y, const int *incy,
> MKL_Complex16 *a, const int *lda);
> void ZGERU(const int *m, const int *n, const MKL_Complex16 *alpha,
> void ZHBMV(const char *uplo, const int *n, const int *k, const MKL_Complex16 *alpha,
> void ZHEMV(const char *uplo, const int *n, const MKL_Complex16 *alpha,
> void ZHER(const char *uplo, const int *n, const double *alpha,
> const MKL_Complex16 *x, const int *incx, MKL_Complex16 *a, const int *lda);
> void ZHER2(const char *uplo, const int *n, const MKL_Complex16 *alpha,
> void ZHPMV(const char *uplo, const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *ap,
> void ZHPR(const char *uplo, const int *n, const double *alpha, const MKL_Complex16 *x,
> const int *incx, MKL_Complex16 *ap);
> void ZHPR2(const char *uplo, const int *n, const MKL_Complex16 *alpha,
> MKL_Complex16 *ap);
> void ZTBMV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> const MKL_Complex16 *a, const int *lda, MKL_Complex16 *x, const int *incx);
> void ZTBSV(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void ZTPMV(const char *uplo, const char *trans, const char *diag, const int *n,
> const MKL_Complex16 *ap, MKL_Complex16 *x, const int *incx);
> void ZTPSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void ZTRMV(const char *uplo, const char *transa, const char *diag, const int *n,
> const MKL_Complex16 *a, const int *lda, MKL_Complex16 *b, const int *incx);
> void ZTRSV(const char *uplo, const char *trans, const char *diag, const int *n,
> void ZGEM2VC(const int *m, const int *n, const MKL_Complex16 *alpha,
> const MKL_Complex16 *a, const int *lda, const MKL_Complex16 *x1, const int *incx1,
> const MKL_Complex16 *x2, const int *incx2, const MKL_Complex16 *beta,
> MKL_Complex16 *y1, const int *incy1, MKL_Complex16 *y2, const int *incy2);
> void DZGEMV(const char *trans, const int *m, const int *n, const MKL_Complex16 *alpha,
> const double *a, const int *lda, const MKL_Complex16 *x, const int *incx,
> void SGEMM(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> const float *alpha, const float *a, const int *lda, const float *b, const int *ldb,
> const float *beta, float *c, const int *ldc);
> void SSYMM(const char *side, const char *uplo, const int *m, const int *n,
> void SSYR2K(const char *uplo, const char *trans, const int *n, const int *k,
> void SSYRK(const char *uplo, const char *trans, const int *n, const int *k,
> void STRMM(const char *side, const char *uplo, const char *transa, const char *diag,
> float *b, const int *ldb);
> void STRSM(const char *side, const char *uplo, const char *transa, const char *diag,
> void CGEMM(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta,
> MKL_Complex8 *c, const int *ldc);
> void SCGEMM(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> const MKL_Complex8 *alpha, const float *a, const int *lda,
> void CGEMM3M(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void CHEMM(const char *side, const char *uplo, const int *m, const int *n,
> void CHER2K(const char *uplo, const char *trans, const int *n, const int *k,
> const MKL_Complex8 *b, const int *ldb, const float *beta,
> void CHERK(const char *uplo, const char *trans, const int *n, const int *k,
> const float *alpha, const MKL_Complex8 *a, const int *lda,
> const float *beta, MKL_Complex8 *c, const int *ldc);
> void CSYMM(const char *side, const char *uplo, const int *m, const int *n, const MKL_Complex8 *alpha,
> const MKL_Complex8 *a, const int *lda, const MKL_Complex8 *b, const int *ldb,
> const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void CSYR2K(const char *uplo, const char *trans, const int *n, const int *k,
> void CSYRK(const char *uplo, const char *trans, const int *n, const int *k,
> void CTRMM(const char *side, const char *uplo, const char *transa, const char *diag,
> MKL_Complex8 *b, const int *ldb);
> void CTRSM(const char *side, const char *uplo, const char *transa, const char *diag,
> void DGEMM(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> const double *alpha, const double *a, const int *lda, const double *b, const int *ldb,
> const double *beta, double *c, const int *ldc);
> void DSYMM(const char *side, const char *uplo, const int *m, const int *n,
> void DSYR2K(const char *uplo, const char *trans, const int *n, const int *k,
> void DSYRK(const char *uplo, const char *trans, const int *n, const int *k,
> const double *alpha, const double *a, const int *lda, const double *beta,
> void DTRMM(const char *side, const char *uplo, const char *transa, const char *diag,
> const int *m, const int *n, const double *alpha, const double *a, const int *lda,
> double *b, const int *ldb);
> void DTRSM(const char *side, const char *uplo, const char *transa, const char *diag,
> void ZGEMM(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta,
> MKL_Complex16 *c, const int *ldc);
> void DZGEMM(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> const MKL_Complex16 *alpha, const double *a, const int *lda,
> void ZGEMM3M(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void ZHEMM(const char *side, const char *uplo, const int *m, const int *n,
> void ZHER2K(const char *uplo, const char *trans, const int *n, const int *k,
> const MKL_Complex16 *b, const int *ldb, const double *beta,
> void ZHERK(const char *uplo, const char *trans, const int *n, const int *k,
> const double *alpha, const MKL_Complex16 *a, const int *lda,
> const double *beta, MKL_Complex16 *c, const int *ldc);
> void ZSYMM(const char *side, const char *uplo, const int *m, const int *n,
> void ZSYR2K(const char *uplo, const char *trans, const int *n, const int *k,
> void ZSYRK(const char *uplo, const char *trans, const int *n, const int *k,
> const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void ZTRMM(const char *side, const char *uplo, const char *transa, const char *diag,
> const MKL_Complex16 *a, const int *lda, MKL_Complex16 *b, const int *ldb);
> void ZTRSM(const char *side, const char *uplo, const char *transa, const char *diag,
> void xerbla(const char *srname, const int *info, const int lsrname);
> int lsame(const char *ca, const char *cb, const int lca, const int lcb);
> float scabs1(const MKL_Complex8 *c);
> float sasum(const int *n, const float *x, const int *incx);
> void saxpy(const int *n, const float *alpha, const float *x, const int *incx, float *y, const int *incy);
> void saxpby(const int *n, const float *alpha, const float *x, const int *incx, const float *beta, float *y, const int *incy);
> void saxpyi(const int *nz, const float *a, const float *x, const int *indx, float *y);
> float scasum(const int *n, const MKL_Complex8 *x, const int *incx);
> float scnrm2(const int *n, const MKL_Complex8 *x, const int *incx);
> void scopy(const int *n, const float *x, const int *incx, float *y, const int *incy);
> float sdot(const int *n, const float *x, const int *incx, const float *y, const int *incy);
> float sdoti(const int *nz, const float *x, const int *indx, const float *y);
> float sdsdot(const int *n, const float *sb, const float *x, const int *incx, const float *y, const int *incy);
> void sgthr(const int *nz, const float *y, float *x, const int *indx);
> void sgthrz(const int *nz, float *y, float *x, const int *indx);
> float snrm2(const int *n, const float *x, const int *incx);
> void srot(const int *n, float *x, const int *incx, float *y, const int *incy, const float *c, const float *s);
> void srotg(float *a,float *b,float *c,float *s);
> void sroti(const int *nz, float *x, const int *indx, float *y, const float *c, const float *s);
> void srotm(const int *n, float *x, const int *incx, float *y, const int *incy, const float *param);
> void srotmg(float *d1, float *d2, float *x1, const float *y1, float *param);
> void sscal(const int *n, const float *a, float *x, const int *incx);
> void ssctr(const int *nz, const float *x, const int *indx, float *y);
> void sswap(const int *n, float *x, const int *incx, float *y, const int *incy);
> int isamax(const int *n, const float *x, const int *incx);
> int isamin(const int *n, const float *x, const int *incx);
> void caxpy(const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy);
> void caxpby(const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *beta, MKL_Complex8 *y, const int *incy);
> void caxpyi(const int *nz, const MKL_Complex8 *a, const MKL_Complex8 *x, const int *indx, MKL_Complex8 *y);
> void ccopy(const int *n, const MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy);
> void cdotc(MKL_Complex8 *pres, const int *n, const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *y, const int *incy);
> void cdotci(MKL_Complex8 *pres, const int *nz, const MKL_Complex8 *x, const int *indx, const MKL_Complex8 *y);
> void cdotu(MKL_Complex8 *pres, const int *n, const MKL_Complex8 *x, const int *incx, const MKL_Complex8 *y, const int *incy);
> void cdotui(MKL_Complex8 *pres, const int *nz, const MKL_Complex8 *x, const int *indx, const MKL_Complex8 *y);
> void cgthr(const int *nz, const MKL_Complex8 *y, MKL_Complex8 *x, const int *indx);
> void cgthrz(const int *nz, MKL_Complex8 *y, MKL_Complex8 *x, const int *indx);
> void crotg(MKL_Complex8 *a, const MKL_Complex8 *b, float *c, MKL_Complex8 *s);
> void cscal(const int *n, const MKL_Complex8 *a, MKL_Complex8 *x, const int *incx);
> void csctr(const int *nz, const MKL_Complex8 *x, const int *indx, MKL_Complex8 *y);
> void csrot(const int *n, MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy, const float *c, const float *s);
> void csscal(const int *n, const float *a, MKL_Complex8 *x, const int *incx);
> void cswap(const int *n, MKL_Complex8 *x, const int *incx, MKL_Complex8 *y, const int *incy);
> int icamax(const int *n, const MKL_Complex8 *x, const int *incx);
> int icamin(const int *n, const MKL_Complex8 *x, const int *incx);
> double dcabs1(const MKL_Complex16 *z);
> double dasum(const int *n, const double *x, const int *incx);
> void daxpy(const int *n, const double *alpha, const double *x, const int *incx, double *y, const int *incy);
> void daxpby(const int *n, const double *alpha, const double *x, const int *incx, const double *beta, double *y, const int *incy);
> void daxpyi(const int *nz, const double *a, const double *x, const int *indx, double *y);
> void dcopy(const int *n, const double *x, const int *incx, double *y, const int *incy);
> double ddot(const int *n, const double *x, const int *incx, const double *y, const int *incy);
> double dsdot(const int *n, const float *x, const int *incx, const float *y, const int *incy);
> double ddoti(const int *nz, const double *x, const int *indx, const double *y);
> void dgthr(const int *nz, const double *y, double *x, const int *indx);
> void dgthrz(const int *nz, double *y, double *x, const int *indx);
> double dnrm2(const int *n, const double *x, const int *incx);
> void drot(const int *n, double *x, const int *incx, double *y, const int *incy, const double *c, const double *s);
> void drotg(double *a, double *b, double *c, double *s);
> void droti(const int *nz, double *x, const int *indx, double *y, const double *c, const double *s);
> void drotm(const int *n, double *x, const int *incx, double *y, const int *incy, const double *param);
> void drotmg(double *d1, double *d2, double *x1, const double *y1, double *param);
> void dscal(const int *n, const double *a, double *x, const int *incx);
> void dsctr(const int *nz, const double *x, const int *indx, double *y);
> void dswap(const int *n, double *x, const int *incx, double *y, const int *incy);
> double dzasum(const int *n, const MKL_Complex16 *x, const int *incx);
> double dznrm2(const int *n, const MKL_Complex16 *x, const int *incx);
> int idamax(const int *n, const double *x, const int *incx);
> int idamin(const int *n, const double *x, const int *incx);
> void zaxpy(const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy);
> void zaxpby(const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *beta, MKL_Complex16 *y, const int *incy);
> void zaxpyi(const int *nz, const MKL_Complex16 *a, const MKL_Complex16 *x, const int *indx, MKL_Complex16 *y);
> void zcopy(const int *n, const MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy);
> void zdotc(MKL_Complex16 *pres, const int *n, const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *y, const int *incy);
> void zdotci(MKL_Complex16 *pres, const int *nz, const MKL_Complex16 *x, const int *indx, const MKL_Complex16 *y);
> void zdotu(MKL_Complex16 *pres, const int *n, const MKL_Complex16 *x, const int *incx, const MKL_Complex16 *y, const int *incy);
> void zdotui(MKL_Complex16 *pres, const int *nz, const MKL_Complex16 *x, const int *indx, const MKL_Complex16 *y);
> void zdrot(const int *n, MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy, const double *c, const double *s);
> void zdscal(const int *n, const double *a, MKL_Complex16 *x, const int *incx);
> void zgthr(const int *nz, const MKL_Complex16 *y, MKL_Complex16 *x, const int *indx);
> void zgthrz(const int *nz, MKL_Complex16 *y, MKL_Complex16 *x, const int *indx);
> void zrotg(MKL_Complex16 *a, const MKL_Complex16 *b, double *c, MKL_Complex16 *s);
> void zscal(const int *n, const MKL_Complex16 *a, MKL_Complex16 *x, const int *incx);
> void zsctr(const int *nz, const MKL_Complex16 *x, const int *indx, MKL_Complex16 *y);
> void zswap(const int *n, MKL_Complex16 *x, const int *incx, MKL_Complex16 *y, const int *incy);
> int izamax(const int *n, const MKL_Complex16 *x, const int *incx);
> int izamin(const int *n, const MKL_Complex16 *x, const int *incx);
> void sgbmv(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> void sgemv(const char *trans, const int *m, const int *n, const float *alpha,
> void sger(const int *m, const int *n, const float *alpha, const float *x, const int *incx,
> void ssbmv(const char *uplo, const int *n, const int *k, const float *alpha,
> void sspmv(const char *uplo, const int *n, const float *alpha, const float *ap,
> void sspr(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> float *ap);
> void sspr2(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> void ssymv(const char *uplo, const int *n, const float *alpha, const float *a, const int *lda,
> void ssyr(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> void ssyr2(const char *uplo, const int *n, const float *alpha, const float *x, const int *incx,
> void stbmv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void stbsv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void stpmv(const char *uplo, const char *trans, const char *diag, const int *n, const float *ap,
> void stpsv(const char *uplo, const char *trans, const char *diag, const int *n, const float *ap,
> void strmv(const char *uplo, const char *transa, const char *diag, const int *n, const float *a,
> void strsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void sgem2vu(const int *m, const int *n, const float *alpha, const float *a, const int *lda,
> void cgbmv(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> void cgemv(const char *trans, const int *m, const int *n, const MKL_Complex8 *alpha,
> void cgerc(const int *m, const int *n, const MKL_Complex8 *alpha,
> void cgeru(const int *m, const int *n, const MKL_Complex8 *alpha,
> void chbmv(const char *uplo, const int *n, const int *k, const MKL_Complex8 *alpha,
> void chemv(const char *uplo, const int *n, const MKL_Complex8 *alpha,
> void cher(const char *uplo, const int *n, const float *alpha, const MKL_Complex8 *x, const int *incx,
> void cher2(const char *uplo, const int *n, const MKL_Complex8 *alpha,
> void chpmv(const char *uplo, const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *ap,
> void chpr(const char *uplo, const int *n, const float *alpha, const MKL_Complex8 *x, const int *incx,
> MKL_Complex8 *ap);
> void chpr2(const char *uplo, const int *n, const MKL_Complex8 *alpha, const MKL_Complex8 *x, const int *incx,
> const MKL_Complex8 *y, const int *incy, MKL_Complex8 *ap);
> void ctbmv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void ctbsv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void ctpmv(const char *uplo, const char *trans, const char *diag, const int *n,
> void ctpsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void ctrmv(const char *uplo, const char *transa, const char *diag, const int *n,
> void ctrsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void cgem2vc(const int *m, const int *n, const MKL_Complex8 *alpha,
> void scgemv(const char *trans, const int *m, const int *n, const MKL_Complex8 *alpha,
> void dgbmv(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> void dgemv(const char *trans, const int *m, const int *n, const double *alpha,
> void dger(const int *m, const int *n, const double *alpha, const double *x, const int *incx,
> void dsbmv(const char *uplo, const int *n, const int *k, const double *alpha,
> void dspmv(const char *uplo, const int *n, const double *alpha, const double *ap,
> void dspr(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> double *ap);
> void dspr2(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> void dsymv(const char *uplo, const int *n, const double *alpha, const double *a, const int *lda,
> void dsyr(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> void dsyr2(const char *uplo, const int *n, const double *alpha, const double *x, const int *incx,
> void dtbmv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void dtbsv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void dtpmv(const char *uplo, const char *trans, const char *diag, const int *n,
> void dtpsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void dtrmv(const char *uplo, const char *transa, const char *diag, const int *n,
> void dtrsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void dgem2vu(const int *m, const int *n, const double *alpha,
> void zgbmv(const char *trans, const int *m, const int *n, const int *kl, const int *ku,
> void zgemv(const char *trans, const int *m, const int *n, const MKL_Complex16 *alpha,
> void zgerc(const int *m, const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx,
> const MKL_Complex16 *y, const int *incy, MKL_Complex16 *a, const int *lda);
> void zgeru(const int *m, const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx,
> void zhbmv(const char *uplo, const int *n, const int *k, const MKL_Complex16 *alpha,
> void zhemv(const char *uplo, const int *n, const MKL_Complex16 *alpha,
> void zher(const char *uplo, const int *n, const double *alpha, const MKL_Complex16 *x, const int *incx,
> void zher2(const char *uplo, const int *n, const MKL_Complex16 *alpha,
> void zhpmv(const char *uplo, const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *ap,
> void zhpr(const char *uplo, const int *n, const double *alpha, const MKL_Complex16 *x, const int *incx,
> MKL_Complex16 *ap);
> void zhpr2(const char *uplo, const int *n, const MKL_Complex16 *alpha, const MKL_Complex16 *x, const int *incx,
> const MKL_Complex16 *y, const int *incy, MKL_Complex16 *ap);
> void ztbmv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void ztbsv(const char *uplo, const char *trans, const char *diag, const int *n, const int *k,
> void ztpmv(const char *uplo, const char *trans, const char *diag, const int *n,
> void ztpsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void ztrmv(const char *uplo, const char *transa, const char *diag, const int *n,
> void ztrsv(const char *uplo, const char *trans, const char *diag, const int *n,
> void zgem2vc(const int *m, const int *n, const MKL_Complex16 *alpha,
> void dzgemv(const char *trans, const int *m, const int *n, const MKL_Complex16 *alpha,
> void sgemm(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void ssymm(const char *side, const char *uplo, const int *m, const int *n,
> void ssyr2k(const char *uplo, const char *trans, const int *n, const int *k,
> void ssyrk(const char *uplo, const char *trans, const int *n, const int *k,
> const float *alpha, const float *a, const int *lda, const float *beta,
> void strmm(const char *side, const char *uplo, const char *transa, const char *diag,
> void strsm(const char *side, const char *uplo, const char *transa, const char *diag,
> void cgemm(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void scgemm(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void cgemm3m(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void chemm(const char *side, const char *uplo, const int *m, const int *n,
> void cher2k(const char *uplo, const char *trans, const int *n, const int *k,
> void cherk(const char *uplo, const char *trans, const int *n, const int *k,
> const float *alpha, const MKL_Complex8 *a, const int *lda, const float *beta,
> void csymm(const char *side, const char *uplo, const int *m, const int *n,
> void csyr2k(const char *uplo, const char *trans, const int *n, const int *k,
> void csyrk(const char *uplo, const char *trans, const int *n, const int *k,
> void ctrmm(const char *side, const char *uplo, const char *transa, const char *diag,
> const MKL_Complex8 *a, const int *lda, MKL_Complex8 *b, const int *ldb);
> void ctrsm(const char *side, const char *uplo, const char *transa, const char *diag,
> void dgemm(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void dsymm(const char *side, const char *uplo, const int *m, const int *n,
> void dsyr2k(const char *uplo, const char *trans, const int *n, const int *k,
> void dsyrk(const char *uplo, const char *trans, const int *n, const int *k,
> void dtrmm(const char *side, const char *uplo, const char *transa, const char *diag,
> void dtrsm(const char *side, const char *uplo, const char *transa, const char *diag,
> void zgemm(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void dzgemm(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void zgemm3m(const char *transa, const char *transb, const int *m, const int *n, const int *k,
> void zhemm(const char *side, const char *uplo, const int *m, const int *n,
> void zher2k(const char *uplo, const char *trans, const int *n, const int *k,
> void zherk(const char *uplo, const char *trans, const int *n, const int *k,
> void zsymm(const char *side, const char *uplo, const int *m, const int *n,
> void zsyr2k(const char *uplo, const char *trans, const int *n, const int *k,
> void zsyrk(const char *uplo, const char *trans, const int *n, const int *k,
> void ztrmm(const char *side, const char *uplo, const char *transa, const char *diag,
> void ztrsm(const char *side, const char *uplo, const char *transa, const char *diag,
> # 47 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h" 2
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_trans.h" 1
> # 33 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_trans.h"
> # 1 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 1 3 4
> # 149 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long int ptrdiff_t;
> # 216 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef long unsigned int size_t;
> # 328 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef int wchar_t;
> # 426 "/opt/gcc/5.1.0/snos/lib/gcc/x86_64-suse-linux/5.1.0/include/stddef.h" 3 4
> typedef struct {
> long long __max_align_ll __attribute__((__aligned__(__alignof__(long long))));
> long double __max_align_ld __attribute__((__aligned__(__alignof__(long double))));
> } max_align_t;
> # 34 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_trans.h" 2
> # 44 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_trans.h"
> void MKL_Simatcopy(
> const char ordering, const char trans,
> size_t rows, size_t cols,
> const float alpha,
> float * AB, size_t lda, size_t ldb);
> void MKL_Dimatcopy(
> const double alpha,
> double * AB, size_t lda, size_t ldb);
> void MKL_Cimatcopy(
> const MKL_Complex8 alpha,
> MKL_Complex8 * AB, size_t lda, size_t ldb);
> void MKL_Zimatcopy(
> const MKL_Complex16 alpha,
> MKL_Complex16 * AB, size_t lda, size_t ldb);
> void MKL_Somatcopy(
> char ordering, char trans,
> const float alpha,
> const float * A, size_t lda,
> float * B, size_t ldb);
> void MKL_Domatcopy(
> const double alpha,
> const double * A, size_t lda,
> double * B, size_t ldb);
> void MKL_Comatcopy(
> const MKL_Complex8 * A, size_t lda,
> MKL_Complex8 * B, size_t ldb);
> void MKL_Zomatcopy(
> const MKL_Complex16 * A, size_t lda,
> MKL_Complex16 * B, size_t ldb);
> void MKL_Somatcopy2(
> const float alpha,
> const float * A, size_t lda, size_t stridea,
> float * B, size_t ldb, size_t strideb);
> void MKL_Domatcopy2(
> const double alpha,
> const double * A, size_t lda, size_t stridea,
> double * B, size_t ldb, size_t strideb);
> void MKL_Comatcopy2(
> const MKL_Complex8 * A, size_t lda, size_t stridea,
> MKL_Complex8 * B, size_t ldb, size_t strideb);
> void MKL_Zomatcopy2(
> const MKL_Complex16 * A, size_t lda, size_t stridea,
> MKL_Complex16 * B, size_t ldb, size_t strideb);
> void MKL_Somatadd(
> char ordering, char transa, char transb,
> const float alpha,
> const float beta,
> const float * B, size_t ldb,
> float * C, size_t ldc);
> void MKL_Domatadd(
> const double alpha,
> const double beta,
> const double * B, size_t ldb,
> double * C, size_t ldc);
> void MKL_Comatadd(
> const MKL_Complex8 beta,
> const MKL_Complex8 * B, size_t ldb,
> MKL_Complex8 * C, size_t ldc);
> void MKL_Zomatadd(
> const MKL_Complex16 beta,
> const MKL_Complex16 * B, size_t ldb,
> MKL_Complex16 * C, size_t ldc);
> # 48 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h" 2
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h" 1
> # 31 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h"
> # 32 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h" 2
> # 46 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h"
> typedef enum {CblasRowMajor=101, CblasColMajor=102} CBLAS_LAYOUT;
> typedef enum {CblasNoTrans=111, CblasTrans=112, CblasConjTrans=113} CBLAS_TRANSPOSE;
> typedef enum {CblasUpper=121, CblasLower=122} CBLAS_UPLO;
> typedef enum {CblasNonUnit=131, CblasUnit=132} CBLAS_DIAG;
> typedef enum {CblasLeft=141, CblasRight=142} CBLAS_SIDE;
> typedef CBLAS_LAYOUT CBLAS_ORDER;
> # 61 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h"
> double cblas_dcabs1(const void *z);
> float cblas_scabs1(const void *c);
> float cblas_sdot(const int N, const float *X, const int incX,
> const float *Y, const int incY);
> float cblas_sdoti(const int N, const float *X, const int *indx,
> const float *Y);
> double cblas_ddot(const int N, const double *X, const int incX,
> const double *Y, const int incY);
> double cblas_ddoti(const int N, const double *X, const int *indx,
> const double *Y);
> double cblas_dsdot(const int N, const float *X, const int incX,
> float cblas_sdsdot(const int N, const float sb, const float *X,
> const int incX, const float *Y, const int incY);
> void cblas_cdotu_sub(const int N, const void *X, const int incX,
> const void *Y, const int incY, void *dotu);
> void cblas_cdotui_sub(const int N, const void *X, const int *indx,
> const void *Y, void *dotui);
> void cblas_cdotc_sub(const int N, const void *X, const int incX,
> const void *Y, const int incY, void *dotc);
> void cblas_cdotci_sub(const int N, const void *X, const int *indx,
> void cblas_zdotu_sub(const int N, const void *X, const int incX,
> void cblas_zdotui_sub(const int N, const void *X, const int *indx,
> void cblas_zdotc_sub(const int N, const void *X, const int incX,
> void cblas_zdotci_sub(const int N, const void *X, const int *indx,
> float cblas_snrm2(const int N, const float *X, const int incX);
> float cblas_sasum(const int N, const float *X, const int incX);
> double cblas_dnrm2(const int N, const double *X, const int incX);
> double cblas_dasum(const int N, const double *X, const int incX);
> float cblas_scnrm2(const int N, const void *X, const int incX);
> float cblas_scasum(const int N, const void *X, const int incX);
> double cblas_dznrm2(const int N, const void *X, const int incX);
> double cblas_dzasum(const int N, const void *X, const int incX);
> size_t cblas_isamax(const int N, const float *X, const int incX);
> size_t cblas_idamax(const int N, const double *X, const int incX);
> size_t cblas_icamax(const int N, const void *X, const int incX);
> size_t cblas_izamax(const int N, const void *X, const int incX);
> size_t cblas_isamin(const int N, const float *X, const int incX);
> size_t cblas_idamin(const int N, const double *X, const int incX);
> size_t cblas_icamin(const int N, const void *X, const int incX);
> size_t cblas_izamin(const int N, const void *X, const int incX);
> # 138 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h"
> void cblas_sswap(const int N, float *X, const int incX,
> void cblas_scopy(const int N, const float *X, const int incX,
> void cblas_saxpy(const int N, const float alpha, const float *X,
> const int incX, float *Y, const int incY);
> void cblas_saxpby(const int N, const float alpha, const float *X,
> const int incX, const float beta, float *Y, const int incY);
> void cblas_saxpyi(const int N, const float alpha, const float *X,
> const int *indx, float *Y);
> void cblas_sgthr(const int N, const float *Y, float *X,
> const int *indx);
> void cblas_sgthrz(const int N, float *Y, float *X,
> const int *indx);
> void cblas_ssctr(const int N, const float *X, const int *indx,
> float *Y);
> void cblas_srotg(float *a, float *b, float *c, float *s);
> void cblas_dswap(const int N, double *X, const int incX,
> void cblas_dcopy(const int N, const double *X, const int incX,
> void cblas_daxpy(const int N, const double alpha, const double *X,
> const int incX, double *Y, const int incY);
> void cblas_daxpby(const int N, const double alpha, const double *X,
> const int incX, const double beta, double *Y, const int incY);
> void cblas_daxpyi(const int N, const double alpha, const double *X,
> const int *indx, double *Y);
> void cblas_dgthr(const int N, const double *Y, double *X,
> const int *indx);
> void cblas_dgthrz(const int N, double *Y, double *X,
> const int *indx);
> void cblas_dsctr(const int N, const double *X, const int *indx,
> double *Y);
> void cblas_drotg(double *a, double *b, double *c, double *s);
> void cblas_cswap(const int N, void *X, const int incX,
> void *Y, const int incY);
> void cblas_ccopy(const int N, const void *X, const int incX,
> void cblas_caxpy(const int N, const void *alpha, const void *X,
> const int incX, void *Y, const int incY);
> void cblas_caxpby(const int N, const void *alpha, const void *X,
> const int incX, const void *beta, void *Y, const int incY);
> void cblas_caxpyi(const int N, const void *alpha, const void *X,
> const int *indx, void *Y);
> void cblas_cgthr(const int N, const void *Y, void *X,
> const int *indx);
> void cblas_cgthrz(const int N, void *Y, void *X,
> const int *indx);
> void cblas_csctr(const int N, const void *X, const int *indx,
> void *Y);
> void cblas_crotg(void *a, const void *b, float *c, void *s);
> void cblas_zswap(const int N, void *X, const int incX,
> void cblas_zcopy(const int N, const void *X, const int incX,
> void cblas_zaxpy(const int N, const void *alpha, const void *X,
> void cblas_zaxpby(const int N, const void *alpha, const void *X,
> void cblas_zaxpyi(const int N, const void *alpha, const void *X,
> void cblas_zgthr(const int N, const void *Y, void *X,
> const int *indx);
> void cblas_zgthrz(const int N, void *Y, void *X,
> const int *indx);
> void cblas_zsctr(const int N, const void *X, const int *indx,
> void *Y);
> void cblas_zrotg(void *a, const void *b, double *c, void *s);
> void cblas_srotmg(float *d1, float *d2, float *b1, const float b2, float *P);
> void cblas_srot(const int N, float *X, const int incX,
> float *Y, const int incY, const float c, const float s);
> void cblas_sroti(const int N, float *X, const int *indx,
> float *Y, const float c, const float s);
> void cblas_srotm(const int N, float *X, const int incX,
> float *Y, const int incY, const float *P);
> void cblas_drotmg(double *d1, double *d2, double *b1, const double b2, double *P);
> void cblas_drot(const int N, double *X, const int incX,
> double *Y, const int incY, const double c, const double s);
> void cblas_drotm(const int N, double *X, const int incX,
> double *Y, const int incY, const double *P);
> void cblas_droti(const int N, double *X, const int *indx,
> double *Y, const double c, const double s);
> void cblas_csrot(const int N, void *X, const int incX,
> void *Y, const int incY, const float c, const float s);
> void cblas_zdrot(const int N, void *X, const int incX,
> void *Y, const int incY, const double c, const double s);
> void cblas_sscal(const int N, const float alpha, float *X, const int incX);
> void cblas_dscal(const int N, const double alpha, double *X, const int incX);
> void cblas_cscal(const int N, const void *alpha, void *X, const int incX);
> void cblas_zscal(const int N, const void *alpha, void *X, const int incX);
> void cblas_csscal(const int N, const float alpha, void *X, const int incX);
> void cblas_zdscal(const int N, const double alpha, void *X, const int incX);
> # 256 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h"
> void cblas_sgemv(const CBLAS_LAYOUT Layout,
> const CBLAS_TRANSPOSE TransA, const int M, const int N,
> const float alpha, const float *A, const int lda,
> const float *X, const int incX, const float beta,
> void cblas_sgbmv(const CBLAS_LAYOUT Layout,
> const int KL, const int KU, const float alpha,
> const float *A, const int lda, const float *X,
> void cblas_strmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const CBLAS_TRANSPOSE TransA, const CBLAS_DIAG Diag,
> const int N, const float *A, const int lda,
> void cblas_stbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const int K, const float *A, const int lda,
> void cblas_stpmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const float *Ap, float *X, const int incX);
> void cblas_strsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const float *A, const int lda, float *X,
> const int incX);
> void cblas_stbsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_stpsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_dgemv(const CBLAS_LAYOUT Layout,
> const double alpha, const double *A, const int lda,
> const double *X, const int incX, const double beta,
> void cblas_dgbmv(const CBLAS_LAYOUT Layout,
> const int KL, const int KU, const double alpha,
> const double *A, const int lda, const double *X,
> void cblas_dtrmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const double *A, const int lda,
> void cblas_dtbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const int K, const double *A, const int lda,
> void cblas_dtpmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const double *Ap, double *X, const int incX);
> void cblas_dtrsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const double *A, const int lda, double *X,
> const int incX);
> void cblas_dtbsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_dtpsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_cgemv(const CBLAS_LAYOUT Layout,
> const void *alpha, const void *A, const int lda,
> const void *X, const int incX, const void *beta,
> void cblas_cgbmv(const CBLAS_LAYOUT Layout,
> const int KL, const int KU, const void *alpha,
> const void *A, const int lda, const void *X,
> void cblas_ctrmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const void *A, const int lda,
> void cblas_ctbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const int K, const void *A, const int lda,
> void cblas_ctpmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const void *Ap, void *X, const int incX);
> void cblas_ctrsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const void *A, const int lda, void *X,
> const int incX);
> void cblas_ctbsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ctpsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_zgemv(const CBLAS_LAYOUT Layout,
> void cblas_zgbmv(const CBLAS_LAYOUT Layout,
> void cblas_ztrmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ztbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ztpmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ztrsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX);
> void cblas_ztbsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ztpsv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ssymv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const float alpha, const float *A,
> const int lda, const float *X, const int incX,
> void cblas_ssbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const int K, const float alpha, const float *A,
> void cblas_sspmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const float alpha, const float *Ap,
> void cblas_sger(const CBLAS_LAYOUT Layout, const int M, const int N,
> const float alpha, const float *X, const int incX,
> const float *Y, const int incY, float *A, const int lda);
> void cblas_ssyr(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, float *A, const int lda);
> void cblas_sspr(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, float *Ap);
> void cblas_ssyr2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, const float *Y, const int incY, float *A,
> const int lda);
> void cblas_sspr2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, const float *Y, const int incY, float *A);
> void cblas_dsymv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const double alpha, const double *A,
> const int lda, const double *X, const int incX,
> void cblas_dsbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const int K, const double alpha, const double *A,
> void cblas_dspmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const double alpha, const double *Ap,
> void cblas_dger(const CBLAS_LAYOUT Layout, const int M, const int N,
> const double alpha, const double *X, const int incX,
> const double *Y, const int incY, double *A, const int lda);
> void cblas_dsyr(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, double *A, const int lda);
> void cblas_dspr(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, double *Ap);
> void cblas_dsyr2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, const double *Y, const int incY, double *A,
> const int lda);
> void cblas_dspr2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, const double *Y, const int incY, double *A);
> void cblas_chemv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const void *alpha, const void *A,
> const int lda, const void *X, const int incX,
> void cblas_chbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const int K, const void *alpha, const void *A,
> void cblas_chpmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const void *alpha, const void *Ap,
> void cblas_cgeru(const CBLAS_LAYOUT Layout, const int M, const int N,
> const void *alpha, const void *X, const int incX,
> const void *Y, const int incY, void *A, const int lda);
> void cblas_cgerc(const CBLAS_LAYOUT Layout, const int M, const int N,
> void cblas_cher(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const float alpha, const void *X, const int incX,
> void cblas_chpr(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int incX, void *A);
> void cblas_cher2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo, const int N,
> void cblas_chpr2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo, const int N,
> const void *Y, const int incY, void *Ap);
> void cblas_zhemv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_zhbmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_zhpmv(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_zgeru(const CBLAS_LAYOUT Layout, const int M, const int N,
> void cblas_zgerc(const CBLAS_LAYOUT Layout, const int M, const int N,
> void cblas_zher(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const int N, const double alpha, const void *X, const int incX,
> void cblas_zhpr(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_zher2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo, const int N,
> void cblas_zhpr2(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo, const int N,
> # 524 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_cblas.h"
> void cblas_sgemm(const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE TransA,
> const CBLAS_TRANSPOSE TransB, const int M, const int N,
> const int lda, const float *B, const int ldb,
> const float beta, float *C, const int ldc);
> void cblas_ssymm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> const CBLAS_UPLO Uplo, const int M, const int N,
> const float *B, const int ldb, const float beta,
> void cblas_ssyrk(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const CBLAS_TRANSPOSE Trans, const int N, const int K,
> void cblas_ssyr2k(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_strmm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> const CBLAS_UPLO Uplo, const CBLAS_TRANSPOSE TransA,
> const CBLAS_DIAG Diag, const int M, const int N,
> float *B, const int ldb);
> void cblas_strsm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_dgemm(const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE TransA,
> const int lda, const double *B, const int ldb,
> const double beta, double *C, const int ldc);
> void cblas_dsymm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> const double *B, const int ldb, const double beta,
> void cblas_dsyrk(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_dsyr2k(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_dtrmm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> double *B, const int ldb);
> void cblas_dtrsm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_cgemm(const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE TransA,
> const int lda, const void *B, const int ldb,
> const void *beta, void *C, const int ldc);
> void cblas_cgemm3m(const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE TransA,
> void cblas_csymm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> const void *B, const int ldb, const void *beta,
> void cblas_csyrk(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_csyr2k(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ctrmm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void *B, const int ldb);
> void cblas_ctrsm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_zgemm(const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE TransA,
> void cblas_zgemm3m(const CBLAS_LAYOUT Layout, const CBLAS_TRANSPOSE TransA,
> void cblas_zsymm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_zsyrk(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_zsyr2k(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> void cblas_ztrmm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_ztrsm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_chemm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_cherk(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const float alpha, const void *A, const int lda,
> const float beta, void *C, const int ldc);
> void cblas_cher2k(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const void *B, const int ldb, const float beta,
> void cblas_zhemm(const CBLAS_LAYOUT Layout, const CBLAS_SIDE Side,
> void cblas_zherk(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const double alpha, const void *A, const int lda,
> const double beta, void *C, const int ldc);
> void cblas_zher2k(const CBLAS_LAYOUT Layout, const CBLAS_UPLO Uplo,
> const void *B, const int ldb, const double beta,
> # 49 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h" 2
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_spblas.h" 1
> # 40 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_spblas.h"
> void mkl_scsrmv(const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, const float *beta, float *y);
> void mkl_scsrsv(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, float *y);
> void mkl_scsrgemv(const char *transa, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_cspblas_scsrgemv(const char *transa, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_scsrsymv(const char *uplo, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_cspblas_scsrsymv(const char *uplo, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_scsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_cspblas_scsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_scscmv(const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, const float *beta, float *y);
> void mkl_scscsv(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, float *y);
> void mkl_scoomv(const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, const float *beta, float *y);
> void mkl_scoosv(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_scoogemv(const char *transa, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_cspblas_scoogemv(const char *transa, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_scoosymv(const char *uplo, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_cspblas_scoosymv(const char *uplo, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_scootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_cspblas_scootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void mkl_sdiamv (const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, const float *beta, float *y);
> void mkl_sdiasv (const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void mkl_sdiagemv(const char *transa, const int *m, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void mkl_sdiasymv(const char *uplo, const int *m, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void mkl_sdiatrsv(const char *uplo, const char *transa, const char *diag, const int *m, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void mkl_sskymv (const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *x, const float *beta, float *y);
> void mkl_sskysv(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *x, float *y);
> void mkl_sbsrmv (const char *transa, const int *m, const int *k, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, const float *beta, float *y);
> void mkl_sbsrsv(const char *transa, const int *m, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, float *y);
> void mkl_sbsrgemv(const char *transa, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_cspblas_sbsrgemv(const char *transa, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_sbsrsymv(const char *uplo, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_cspblas_sbsrsymv(const char *uplo, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_sbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_cspblas_sbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void mkl_scsrmm(const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void mkl_scsrsm(const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, float *c, const int *ldc);
> void mkl_scscmm(const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void mkl_scscsm(const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, float *c, const int *ldc);
> void mkl_scoomm(const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void mkl_scoosm(const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *b, const int *ldb, float *c, const int *ldc);
> void mkl_sdiamm (const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void mkl_sdiasm (const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *b, const int *ldb, float *c, const int *ldc);
> void mkl_sskysm (const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *b, const int *ldb, float *c, const int *ldc);
> void mkl_sskymm (const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void mkl_sbsrmm(const char *transa, const int *m, const int *n, const int *k, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void mkl_sbsrsm(const char *transa, const int *m, const int *n, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, float *c, const int *ldc);
> void MKL_SCSRMV (const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, const float *beta, float *y);
> void MKL_SCSRSV(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, float *y);
> void MKL_SCSRGEMV(const char *transa, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_CSPBLAS_SCSRGEMV(const char *transa, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_SCSRSYMV(const char *uplo, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_CSPBLAS_SCSRSYMV(const char *uplo, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_SCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_CSPBLAS_SCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_SCSCMV(const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, const float *beta, float *y);
> void MKL_SCSCSV(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, float *y);
> void MKL_SCOOMV(const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, const float *beta, float *y);
> void MKL_SCOOSV(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_SCOOGEMV(const char *transa, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_CSPBLAS_SCOOGEMV(const char *transa, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_SCOOSYMV(const char *uplo, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_CSPBLAS_SCOOSYMV(const char *uplo, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_SCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_CSPBLAS_SCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const float *val, const int *rowind, const int *colind, const int *nnz, const float *x, float *y);
> void MKL_SDIAMV (const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, const float *beta, float *y);
> void MKL_SDIASV (const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void MKL_SDIAGEMV(const char *transa, const int *m, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void MKL_SDIASYMV(const char *uplo, const int *m, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void MKL_SDIATRSV(const char *uplo, const char *transa, const char *diag, const int *m, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *x, float *y);
> void MKL_SSKYMV (const char *transa, const int *m, const int *k, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *x, const float *beta, float *y);
> void MKL_SSKYSV(const char *transa, const int *m, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *x, float *y);
> void MKL_SBSRMV (const char *transa, const int *m, const int *k, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, const float *beta, float *y);
> void MKL_SBSRSV(const char *transa, const int *m, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *x, float *y);
> void MKL_SBSRGEMV(const char *transa, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_CSPBLAS_SBSRGEMV(const char *transa, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_SBSRSYMV(const char *uplo, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_CSPBLAS_SBSRSYMV(const char *uplo, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_SBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_CSPBLAS_SBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const float *a, const int *ia, const int *ja, const float *x, float *y);
> void MKL_SCSRMM(const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void MKL_SCSRSM(const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, float *c, const int *ldc);
> void MKL_SCSCMM(const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void MKL_SCSCSM(const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, float *c, const int *ldc);
> void MKL_SCOOMM(const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void MKL_SCOOSM(const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *rowind, const int *colind, const int *nnz, const float *b, const int *ldb, float *c, const int *ldc);
> void MKL_SDIAMM (const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void MKL_SDIASM (const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *lval, const int *idiag, const int *ndiag, const float *b, const int *ldb, float *c, const int *ldc);
> void MKL_SSKYSM (const char *transa, const int *m, const int *n, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *b, const int *ldb, float *c, const int *ldc);
> void MKL_SSKYMM (const char *transa, const int *m, const int *n, const int *k, const float *alpha, const char *matdescra, const float *val, const int *pntr, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void MKL_SBSRMM(const char *transa, const int *m, const int *n, const int *k, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, const float *beta, float *c, const int *ldc);
> void MKL_SBSRSM(const char *transa, const int *m, const int *n, const int *lb, const float *alpha, const char *matdescra, const float *val, const int *indx, const int *pntrb, const int *pntre, const float *b, const int *ldb, float *c, const int *ldc);
> void mkl_dcsrmv(const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, const double *beta, double *y);
> void mkl_dcsrsv(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, double *y);
> void mkl_dcsrgemv(const char *transa, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_cspblas_dcsrgemv(const char *transa, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_dcsrsymv(const char *uplo, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_cspblas_dcsrsymv(const char *uplo, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_dcsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_cspblas_dcsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_dcscmv(const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, const double *beta, double *y);
> void mkl_dcscsv(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, double *y);
> void mkl_dcoomv(const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, const double *beta, double *y);
> void mkl_dcoosv(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_dcoogemv(const char *transa, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_cspblas_dcoogemv(const char *transa, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_dcoosymv(const char *uplo, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_cspblas_dcoosymv(const char *uplo, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_dcootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_cspblas_dcootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void mkl_ddiamv (const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, const double *beta, double *y);
> void mkl_ddiasv (const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void mkl_ddiagemv(const char *transa, const int *m, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void mkl_ddiasymv(const char *uplo, const int *m, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void mkl_ddiatrsv(const char *uplo, const char *transa, const char *diag, const int *m, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void mkl_dskymv (const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *x, const double *beta, double *y);
> void mkl_dskysv(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *x, double *y);
> void mkl_dbsrmv (const char *transa, const int *m, const int *k, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, const double *beta, double *y);
> void mkl_dbsrsv(const char *transa, const int *m, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, double *y);
> void mkl_dbsrgemv(const char *transa, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_cspblas_dbsrgemv(const char *transa, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_dbsrsymv(const char *uplo, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_cspblas_dbsrsymv(const char *uplo, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_dbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_cspblas_dbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void mkl_dcsrmm(const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void mkl_dcsrsm(const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, double *c, const int *ldc);
> void mkl_dcscmm(const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void mkl_dcscsm(const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, double *c, const int *ldc);
> void mkl_dcoomm(const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void mkl_dcoosm(const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *b, const int *ldb, double *c, const int *ldc);
> void mkl_ddiamm (const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void mkl_ddiasm (const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *b, const int *ldb, double *c, const int *ldc);
> void mkl_dskysm (const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *b, const int *ldb, double *c, const int *ldc);
> void mkl_dskymm (const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void mkl_dbsrmm(const char *transa, const int *m, const int *n, const int *k, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void mkl_dbsrsm(const char *transa, const int *m, const int *n, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, double *c, const int *ldc);
> void MKL_DCSRMV (const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, const double *beta, double *y);
> void MKL_DCSRSV(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, double *y);
> void MKL_DCSRGEMV(const char *transa, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_CSPBLAS_DCSRGEMV(const char *transa, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_DCSRSYMV(const char *uplo, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_CSPBLAS_DCSRSYMV(const char *uplo, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_DCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_CSPBLAS_DCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_DCSCMV(const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, const double *beta, double *y);
> void MKL_DCSCSV(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, double *y);
> void MKL_DCOOMV(const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, const double *beta, double *y);
> void MKL_DCOOSV(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_DCOOGEMV(const char *transa, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_CSPBLAS_DCOOGEMV(const char *transa, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_DCOOSYMV(const char *uplo, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_CSPBLAS_DCOOSYMV(const char *uplo, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_DCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_CSPBLAS_DCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const double *val, const int *rowind, const int *colind, const int *nnz, const double *x, double *y);
> void MKL_DDIAMV (const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, const double *beta, double *y);
> void MKL_DDIASV (const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void MKL_DDIAGEMV(const char *transa, const int *m, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void MKL_DDIASYMV(const char *uplo, const int *m, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void MKL_DDIATRSV(const char *uplo, const char *transa, const char *diag, const int *m, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *x, double *y);
> void MKL_DSKYMV (const char *transa, const int *m, const int *k, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *x, const double *beta, double *y);
> void MKL_DSKYSV(const char *transa, const int *m, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *x, double *y);
> void MKL_DBSRMV (const char *transa, const int *m, const int *k, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, const double *beta, double *y);
> void MKL_DBSRSV(const char *transa, const int *m, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *x, double *y);
> void MKL_DBSRGEMV(const char *transa, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_CSPBLAS_DBSRGEMV(const char *transa, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_DBSRSYMV(const char *uplo, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_CSPBLAS_DBSRSYMV(const char *uplo, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_DBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_CSPBLAS_DBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const double *a, const int *ia, const int *ja, const double *x, double *y);
> void MKL_DCSRMM(const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void MKL_DCSRSM(const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, double *c, const int *ldc);
> void MKL_DCSCMM(const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void MKL_DCSCSM(const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, double *c, const int *ldc);
> void MKL_DCOOMM(const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void MKL_DCOOSM(const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *rowind, const int *colind, const int *nnz, const double *b, const int *ldb, double *c, const int *ldc);
> void MKL_DDIAMM (const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void MKL_DDIASM (const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *lval, const int *idiag, const int *ndiag, const double *b, const int *ldb, double *c, const int *ldc);
> void MKL_DSKYSM (const char *transa, const int *m, const int *n, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *b, const int *ldb, double *c, const int *ldc);
> void MKL_DSKYMM (const char *transa, const int *m, const int *n, const int *k, const double *alpha, const char *matdescra, const double *val, const int *pntr, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void MKL_DBSRMM(const char *transa, const int *m, const int *n, const int *k, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, const double *beta, double *c, const int *ldc);
> void MKL_DBSRSM(const char *transa, const int *m, const int *n, const int *lb, const double *alpha, const char *matdescra, const double *val, const int *indx, const int *pntrb, const int *pntre, const double *b, const int *ldb, double *c, const int *ldc);
> void mkl_ccsrmv(const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void mkl_ccsrsv(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccsrgemv(const char *transa, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_ccsrgemv(const char *transa, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccsrsymv(const char *uplo, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_ccsrsymv(const char *uplo, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_ccsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccscmv(const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void mkl_ccscsv(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccoomv(const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void mkl_ccoosv(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccoogemv(const char *transa, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_ccoogemv(const char *transa, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccoosymv(const char *uplo, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_ccoosymv(const char *uplo, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_ccootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cdiamv (const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void mkl_cdiasv (const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cdiagemv(const char *transa, const int *m, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cdiasymv(const char *uplo, const int *m, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cdiatrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cskymv (const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void mkl_cskysv(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cbsrmv (const char *transa, const int *m, const int *k, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void mkl_cbsrsv(const char *transa, const int *m, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cbsrgemv(const char *transa, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_cbsrgemv(const char *transa, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cbsrsymv(const char *uplo, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_cbsrsymv(const char *uplo, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_cspblas_cbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void mkl_ccsrmm(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void mkl_ccsrsm(const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void mkl_ccscmm(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void mkl_ccscsm(const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void mkl_ccoomm(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void mkl_ccoosm(const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void mkl_cdiamm (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void mkl_cdiasm (const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void mkl_cskysm (const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void mkl_cskymm (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void mkl_cbsrmm(const char *transa, const int *m, const int *n, const int *k, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void mkl_cbsrsm(const char *transa, const int *m, const int *n, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void MKL_CCSRMV (const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void MKL_CCSRSV(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCSRGEMV(const char *transa, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CCSRGEMV(const char *transa, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCSRSYMV(const char *uplo, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CCSRSYMV(const char *uplo, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCSCMV(const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void MKL_CCSCSV(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCOOMV(const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void MKL_CCOOSV(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCOOGEMV(const char *transa, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CCOOGEMV(const char *transa, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCOOSYMV(const char *uplo, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CCOOSYMV(const char *uplo, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CDIAMV (const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void MKL_CDIASV (const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CDIAGEMV(const char *transa, const int *m, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CDIASYMV(const char *uplo, const int *m, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CDIATRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSKYMV (const char *transa, const int *m, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void MKL_CSKYSV(const char *transa, const int *m, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CBSRMV (const char *transa, const int *m, const int *k, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, const MKL_Complex8 *beta, MKL_Complex8 *y);
> void MKL_CBSRSV(const char *transa, const int *m, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CBSRGEMV(const char *transa, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CBSRGEMV(const char *transa, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CBSRSYMV(const char *uplo, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CBSRSYMV(const char *uplo, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CSPBLAS_CBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex8 *a, const int *ia, const int *ja, const MKL_Complex8 *x, MKL_Complex8 *y);
> void MKL_CCSRMM(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void MKL_CCSRSM(const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void MKL_CCSCMM(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void MKL_CCSCSM(const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void MKL_CCOOMM(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void MKL_CCOOSM(const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void MKL_CDIAMM (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void MKL_CDIASM (const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void MKL_CSKYSM (const char *transa, const int *m, const int *n, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void MKL_CSKYMM (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *pntr, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void MKL_CBSRMM(const char *transa, const int *m, const int *n, const int *k, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, const MKL_Complex8 *beta, MKL_Complex8 *c, const int *ldc);
> void MKL_CBSRSM(const char *transa, const int *m, const int *n, const int *lb, const MKL_Complex8 *alpha, const char *matdescra, const MKL_Complex8 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex8 *b, const int *ldb, MKL_Complex8 *c, const int *ldc);
> void mkl_zcsrmv(const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void mkl_zcsrsv(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcsrgemv(const char *transa, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zcsrgemv(const char *transa, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcsrsymv(const char *uplo, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zcsrsymv(const char *uplo, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zcsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcscmv(const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void mkl_zcscsv(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcoomv(const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void mkl_zcoosv(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcoogemv(const char *transa, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zcoogemv(const char *transa, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcoosymv(const char *uplo, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zcoosymv(const char *uplo, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zcootrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zdiamv (const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void mkl_zdiasv (const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zdiagemv(const char *transa, const int *m, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zdiasymv(const char *uplo, const int *m, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zdiatrsv(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zskymv (const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void mkl_zskysv(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zbsrmv (const char *transa, const int *m, const int *k, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void mkl_zbsrsv(const char *transa, const int *m, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zbsrgemv(const char *transa, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zbsrgemv(const char *transa, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zbsrsymv(const char *uplo, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zbsrsymv(const char *uplo, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_cspblas_zbsrtrsv(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void mkl_zcsrmm(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void mkl_zcsrsm(const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void mkl_zcscmm(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void mkl_zcscsm(const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void mkl_zcoomm(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void mkl_zcoosm(const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void mkl_zdiamm (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void mkl_zdiasm (const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void mkl_zskysm (const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void mkl_zskymm (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void mkl_zbsrmm(const char *transa, const int *m, const int *n, const int *k, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void mkl_zbsrsm(const char *transa, const int *m, const int *n, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void MKL_ZCSRMV (const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void MKL_ZCSRSV(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCSRGEMV(const char *transa, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZCSRGEMV(const char *transa, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCSRSYMV(const char *uplo, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZCSRSYMV(const char *uplo, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZCSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCSCMV(const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void MKL_ZCSCSV(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCOOMV(const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void MKL_ZCOOSV(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCOOGEMV(const char *transa, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZCOOGEMV(const char *transa, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCOOSYMV(const char *uplo, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZCOOSYMV(const char *uplo, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZCOOTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZDIAMV (const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void MKL_ZDIASV (const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZDIAGEMV(const char *transa, const int *m, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZDIASYMV(const char *uplo, const int *m, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZDIATRSV(const char *uplo, const char *transa, const char *diag, const int *m, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZSKYMV (const char *transa, const int *m, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void MKL_ZSKYSV(const char *transa, const int *m, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZBSRMV (const char *transa, const int *m, const int *k, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, const MKL_Complex16 *beta, MKL_Complex16 *y);
> void MKL_ZBSRSV(const char *transa, const int *m, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZBSRGEMV(const char *transa, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZBSRGEMV(const char *transa, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZBSRSYMV(const char *uplo, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZBSRSYMV(const char *uplo, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_CSPBLAS_ZBSRTRSV(const char *uplo, const char *transa, const char *diag, const int *m, const int *lb, const MKL_Complex16 *a, const int *ia, const int *ja, const MKL_Complex16 *x, MKL_Complex16 *y);
> void MKL_ZCSRMM(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void MKL_ZCSRSM(const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void MKL_ZCSCMM(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void MKL_ZCSCSM(const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void MKL_ZCOOMM(const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void MKL_ZCOOSM(const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *rowind, const int *colind, const int *nnz, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void MKL_ZDIAMM (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void MKL_ZDIASM (const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *lval, const int *idiag, const int *ndiag, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void MKL_ZSKYSM (const char *transa, const int *m, const int *n, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void MKL_ZSKYMM (const char *transa, const int *m, const int *n, const int *k, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *pntr, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void MKL_ZBSRMM(const char *transa, const int *m, const int *n, const int *k, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, const MKL_Complex16 *beta, MKL_Complex16 *c, const int *ldc);
> void MKL_ZBSRSM(const char *transa, const int *m, const int *n, const int *lb, const MKL_Complex16 *alpha, const char *matdescra, const MKL_Complex16 *val, const int *indx, const int *pntrb, const int *pntre, const MKL_Complex16 *b, const int *ldb, MKL_Complex16 *c, const int *ldc);
> void mkl_dcsrbsr(const int *job, const int *m, const int *mblk, const int *ldAbsr, double *Acsr, int *AJ, int *AI, double *Absr, int *AJB, int *AIB, int *info);
> void mkl_dcsrcoo(const int *job, const int *n, double *Acsr, int *AJR, int *AIR, int *nnz, double *Acoo, int *ir, int *jc, int *info);
> void mkl_ddnscsr(const int *job, const int *m, const int *n, double *Adns, const int *lda, double *Acsr, int *AJ, int *AI, int *info);
> void mkl_dcsrcsc(const int *job, const int *n, double *Acsr, int *AJ0, int *AI0, double *Acsc, int *AJ1, int *AI1, int *info);
> void mkl_dcsrdia(const int *job, const int *n, double *Acsr, int *AJ0, int *AI0, double *Adia, const int *ndiag, int *distance, int *idiag, double *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void mkl_dcsrsky(const int *job, const int *n, double *Acsr, int *AJ0, int *AI0, double *Asky, int *pointers, int *info);
> void mkl_scsrbsr(const int *job, const int *m, const int *mblk, const int *ldAbsr, float *Acsr, int *AJ, int *AI, float *Absr, int *AJB, int *AIB, int *info);
> void mkl_scsrcoo(const int *job, const int *n, float *Acsr, int *AJR, int *AIR, int *nnz, float *Acoo, int *ir, int *jc, int *info);
> void mkl_sdnscsr(const int *job, const int *m, const int *n, float *Adns, const int *lda, float *Acsr, int *AJ, int *AI, int *info);
> void mkl_scsrcsc(const int *job, const int *n, float *Acsr, int *AJ0, int *AI0, float *Acsc, int *AJ1, int *AI1, int *info);
> void mkl_scsrdia(const int *job, const int *n, float *Acsr, int *AJ0, int *AI0, float *Adia, const int *ndiag, int *distance, int *idiag, float *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void mkl_scsrsky(const int *job, const int *n, float *Acsr, int *AJ0, int *AI0, float *Asky, int *pointers, int *info);
> void mkl_ccsrbsr(const int *job, const int *m, const int *mblk, const int *ldAbsr, MKL_Complex8 *Acsr, int *AJ, int *AI, MKL_Complex8 *Absr, int *AJB, int *AIB, int *info);
> void mkl_ccsrcoo(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJR, int *AIR, int *nnz, MKL_Complex8 *Acoo, int *ir, int *jc, int *info);
> void mkl_cdnscsr(const int *job, const int *m, const int *n, MKL_Complex8 *Adns, const int *lda, MKL_Complex8 *Acsr, int *AJ, int *AI, int *info);
> void mkl_ccsrcsc(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJ0, int *AI0, MKL_Complex8 *Acsc, int *AJ1, int *AI1, int *info);
> void mkl_ccsrdia(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJ0, int *AI0, MKL_Complex8 *Adia, const int *ndiag, int *distance, int *idiag, MKL_Complex8 *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void mkl_ccsrsky(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJ0, int *AI0, MKL_Complex8 *Asky, int *pointers, int *info);
> void mkl_zcsrbsr(const int *job, const int *m, const int *mblk, const int *ldAbsr, MKL_Complex16 *Acsr, int *AJ, int *AI, MKL_Complex16 *Absr, int *AJB, int *AIB, int *info);
> void mkl_zcsrcoo(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJR, int *AIR, int *nnz, MKL_Complex16 *Acoo, int *ir, int *jc, int *info);
> void mkl_zdnscsr(const int *job, const int *m, const int *n, MKL_Complex16 *Adns, const int *lda, MKL_Complex16 *Acsr, int *AJ, int *AI, int *info);
> void mkl_zcsrcsc(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJ0, int *AI0, MKL_Complex16 *Acsc, int *AJ1, int *AI1, int *info);
> void mkl_zcsrdia(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJ0, int *AI0, MKL_Complex16 *Adia, const int *ndiag, int *distance, int *idiag, MKL_Complex16 *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void mkl_zcsrsky(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJ0, int *AI0, MKL_Complex16 *Asky, int *pointers, int *info);
> void MKL_DCSRBSR(const int *job, const int *m, const int *mblk, const int *ldAbsr, double *Acsr, int *AJ, int *AI, double *Absr, int *AJB, int *AIB, int *info);
> void MKL_DCSRCOO(const int *job, const int *n, double *Acsr, int *AJR, int *AIR, int *nnz, double *Acoo, int *ir, int *jc, int *info);
> void MKL_DDNSCSR(const int *job, const int *m, const int *n, double *Adns, const int *lda, double *Acsr, int *AJ, int *AI, int *info);
> void MKL_DCSRCSC(const int *job, const int *n, double *Acsr, int *AJ0, int *AI0, double *Acsc, int *AJ1, int *AI1, int *info);
> void MKL_DCSRDIA(const int *job, const int *n, double *Acsr, int *AJ0, int *AI0, double *Adia, const int *ndiag, int *distance, int *idiag, double *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void MKL_DCSRSKY(const int *job, const int *n, double *Acsr, int *AJ0, int *AI0, double *Asky, int *pointers, int *info);
> void MKL_SCSRBSR(const int *job, const int *m, const int *mblk, const int *ldAbsr, float *Acsr, int *AJ, int *AI, float *Absr, int *AJB, int *AIB, int *info);
> void MKL_SCSRCOO(const int *job, const int *n, float *Acsr, int *AJR, int *AIR, int *nnz, float *Acoo, int *ir, int *jc, int *info);
> void MKL_SDNSCSR(const int *job, const int *m, const int *n, float *Adns, const int *lda, float *Acsr, int *AJ, int *AI, int *info);
> void MKL_SCSRCSC(const int *job, const int *n, float *Acsr, int *AJ0, int *AI0, float *Acsc, int *AJ1, int *AI1, int *info);
> void MKL_SCSRDIA(const int *job, const int *n, float *Acsr, int *AJ0, int *AI0, float *Adia, const int *ndiag, int *distance, int *idiag, float *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void MKL_SCSRSKY(const int *job, const int *n, float *Acsr, int *AJ0, int *AI0, float *Asky, int *pointers, int *info);
> void MKL_CCSRBSR(const int *job, const int *m, const int *mblk, const int *ldAbsr, MKL_Complex8 *Acsr, int *AJ, int *AI, MKL_Complex8 *Absr, int *AJB, int *AIB, int *info);
> void MKL_CCSRCOO(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJR, int *AIR, int *nnz, MKL_Complex8 *Acoo, int *ir, int *jc, int *info);
> void MKL_CDNSCSR(const int *job, const int *m, const int *n, MKL_Complex8 *Adns, const int *lda, MKL_Complex8 *Acsr, int *AJ, int *AI, int *info);
> void MKL_CCSRCSC(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJ0, int *AI0, MKL_Complex8 *Acsc, int *AJ1, int *AI1, int *info);
> void MKL_CCSRDIA(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJ0, int *AI0, MKL_Complex8 *Adia, const int *ndiag, int *distance, int *idiag, MKL_Complex8 *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void MKL_CCSRSKY(const int *job, const int *n, MKL_Complex8 *Acsr, int *AJ0, int *AI0, MKL_Complex8 *Asky, int *pointers, int *info);
> void MKL_ZCSRBSR(const int *job, const int *m, const int *mblk, const int *ldAbsr, MKL_Complex16 *Acsr, int *AJ, int *AI, MKL_Complex16 *Absr, int *AJB, int *AIB, int *info);
> void MKL_ZCSRCOO(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJR, int *AIR, int *nnz, MKL_Complex16 *Acoo, int *ir, int *jc, int *info);
> void MKL_ZDNSCSR(const int *job, const int *m, const int *n, MKL_Complex16 *Adns, const int *lda, MKL_Complex16 *Acsr, int *AJ, int *AI, int *info);
> void MKL_ZCSRCSC(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJ0, int *AI0, MKL_Complex16 *Acsc, int *AJ1, int *AI1, int *info);
> void MKL_ZCSRDIA(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJ0, int *AI0, MKL_Complex16 *Adia, const int *ndiag, int *distance, int *idiag, MKL_Complex16 *Acsr_rem, int *AJ0_rem, int *AI0_rem, int *info);
> void MKL_ZCSRSKY(const int *job, const int *n, MKL_Complex16 *Acsr, int *AJ0, int *AI0, MKL_Complex16 *Asky, int *pointers, int *info);
> void mkl_dcsrmultcsr(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, double *a, int *ja, int *ia, double *b, int *jb, int *ib, double *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_dcsrmultd(const char *transa, const int *m, const int *n, const int *k, double *a, int *ja, int *ia, double *b, int *jb, int *ib, double *c, int *ldc);
> void mkl_dcsradd(const char *transa, const int *job, const int *sort, const int *m, const int *n, double *a, int *ja, int *ia, const double *beta, double *b, int *jb, int *ib, double *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_scsrmultcsr(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, float *a, int *ja, int *ia, float *b, int *jb, int *ib, float *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_scsrmultd(const char *transa, const int *m, const int *n, const int *k, float *a, int *ja, int *ia, float *b, int *jb, int *ib, float *c, int *ldc);
> void mkl_scsradd(const char *transa, const int *job, const int *sort, const int *m, const int *n, float *a, int *ja, int *ia, const float *beta, float *b, int *jb, int *ib, float *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_ccsrmultcsr(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, MKL_Complex8 *a, int *ja, int *ia, MKL_Complex8 *b, int *jb, int *ib, MKL_Complex8 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_ccsrmultd(const char *transa, const int *m, const int *n, const int *k, MKL_Complex8 *a, int *ja, int *ia, MKL_Complex8 *b, int *jb, int *ib, MKL_Complex8 *c, int *ldc);
> void mkl_ccsradd(const char *transa, const int *job, const int *sort, const int *m, const int *n, MKL_Complex8 *a, int *ja, int *ia, const MKL_Complex8 *beta, MKL_Complex8 *b, int *jb, int *ib, MKL_Complex8 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_zcsrmultcsr(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, MKL_Complex16 *a, int *ja, int *ia, MKL_Complex16 *b, int *jb, int *ib, MKL_Complex16 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void mkl_zcsrmultd(const char *transa, const int *m, const int *n, const int *k, MKL_Complex16 *a, int *ja, int *ia, MKL_Complex16 *b, int *jb, int *ib, MKL_Complex16 *c, int *ldc);
> void mkl_zcsradd(const char *transa, const int *job, const int *sort, const int *m, const int *n, MKL_Complex16 *a, int *ja, int *ia, const MKL_Complex16 *beta, MKL_Complex16 *b, int *jb, int *ib, MKL_Complex16 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_DCSRMULTCSR(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, double *a, int *ja, int *ia, double *b, int *jb, int *ib, double *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_DCSRMULTD(const char *transa, const int *m, const int *n, const int *k, double *a, int *ja, int *ia, double *b, int *jb, int *ib, double *c, int *ldc);
> void MKL_DCSRADD(const char *transa, const int *job, const int *sort, const int *m, const int *n, double *a, int *ja, int *ia, const double *beta, double *b, int *jb, int *ib, double *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_SCSRMULTCSR(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, float *a, int *ja, int *ia, float *b, int *jb, int *ib, float *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_SCSRMULTD(const char *transa, const int *m, const int *n, const int *k, float *a, int *ja, int *ia, float *b, int *jb, int *ib, float *c, int *ldc);
> void MKL_SCSRADD(const char *transa, const int *job, const int *sort, const int *m, const int *n, float *a, int *ja, int *ia, const float *beta, float *b, int *jb, int *ib, float *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_CCSRMULTCSR(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, MKL_Complex8 *a, int *ja, int *ia, MKL_Complex8 *b, int *jb, int *ib, MKL_Complex8 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_CCSRMULTD(const char *transa, const int *m, const int *n, const int *k, MKL_Complex8 *a, int *ja, int *ia, MKL_Complex8 *b, int *jb, int *ib, MKL_Complex8 *c, int *ldc);
> void MKL_CCSRADD(const char *transa, const int *job, const int *sort, const int *m, const int *n, MKL_Complex8 *a, int *ja, int *ia, const MKL_Complex8 *beta, MKL_Complex8 *b, int *jb, int *ib, MKL_Complex8 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_ZCSRMULTCSR(const char *transa, const int *job, const int *sort, const int *m, const int *n, const int *k, MKL_Complex16 *a, int *ja, int *ia, MKL_Complex16 *b, int *jb, int *ib, MKL_Complex16 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> void MKL_ZCSRMULTD(const char *transa, const int *m, const int *n, const int *k, MKL_Complex16 *a, int *ja, int *ia, MKL_Complex16 *b, int *jb, int *ib, MKL_Complex16 *c, int *ldc);
> void MKL_ZCSRADD(const char *transa, const int *job, const int *sort, const int *m, const int *n, MKL_Complex16 *a, int *ja, int *ia, const MKL_Complex16 *beta, MKL_Complex16 *b, int *jb, int *ib, MKL_Complex16 *c, int *jc, int *ic, const int *nnzmax, int *ierr);
> # 50 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl.h" 2
> # 1 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_lapack.h" 1
> # 40 "/opt/intel/composer_xe_2015.1.133/mkl/include/mkl_lapack.h"
> typedef int (*MKL_C_SELECT_FUNCTION_1) ( MKL_Complex8* );
> typedef int (*MKL_C_SELECT_FUNCTION_2) ( MKL_Complex8*, MKL_Complex8* );
> typedef int (*MKL_D_SELECT_FUNCTION_2) ( double*, double* );
> typedef int (*MKL_D_SELECT_FUNCTION_3) ( double*, double*, double* );
> typedef int (*MKL_S_SELECT_FUNCTION_2) ( float*, float* );
> typedef int (*MKL_S_SELECT_FUNCTION_3) ( float*, float*, float* );
> typedef int (*MKL_Z_SELECT_FUNCTION_1) ( MKL_Complex16* );
> typedef int (*MKL_Z_SELECT_FUNCTION_2) ( MKL_Complex16*, MKL_Complex16* );
> void CHECON_ROOK( const char* uplo, const int* n, const MKL_Complex8* a,
> const int* lda, const int* ipiv, const float* anorm,
> float* rcond, MKL_Complex8* work, int* info );
> void CHECON_ROOK_( const char* uplo, const int* n, const MKL_Complex8* a,
> void checon_rook( const char* uplo, const int* n, const MKL_Complex8* a,
> void checon_rook_( const char* uplo, const int* n, const MKL_Complex8* a,
> void CHESV_ROOK( const char* uplo, const int* n, const int* nrhs,
> MKL_Complex8* a, const int* lda, int* ipiv,
> MKL_Complex8* b, const int* ldb, MKL_Complex8* work,
> const int* lwork, int* info );
> void CHESV_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void chesv_rook( const char* uplo, const int* n, const int* nrhs,
> void chesv_rook_( const char* uplo, const int* n, const int* nrhs,
> void CHETF2_ROOK( const char* uplo, const int* n, MKL_Complex8* a,
> const int* lda, int* ipiv, int* info );
> void CHETF2_ROOK_( const char* uplo, const int* n, MKL_Complex8* a,
> void chetf2_rook( const char* uplo, const int* n, MKL_Complex8* a,
> void chetf2_rook_( const char* uplo, const int* n, MKL_Complex8* a,
> void CHETRF_ROOK( const char* uplo, const int* n, MKL_Complex8* a,
> const int* lda, int* ipiv, MKL_Complex8* work,
> void CHETRF_ROOK_( const char* uplo, const int* n, MKL_Complex8* a,
> void chetrf_rook( const char* uplo, const int* n, MKL_Complex8* a,
> void chetrf_rook_( const char* uplo, const int* n, MKL_Complex8* a,
> void CHETRI_ROOK( const char* uplo, const int* n, MKL_Complex8* a,
> const int* lda, const int* ipiv, MKL_Complex8* work,
> int* info );
> void CHETRI_ROOK_( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void chetri_rook( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void chetri_rook_( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void CHETRS_ROOK( const char* uplo, const int* n, const int* nrhs,
> const MKL_Complex8* a, const int* lda, const int* ipiv,
> MKL_Complex8* b, const int* ldb, int* info );
> void CHETRS_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void chetrs_rook( const char* uplo, const int* n, const int* nrhs,
> void chetrs_rook_( const char* uplo, const int* n, const int* nrhs,
> void CLAHEF_ROOK( const char* uplo, const int* n, const int* nb,
> int* kb, MKL_Complex8* a, const int* lda, int* ipiv,
> MKL_Complex8* w, const int* ldw, int* info );
> void CLAHEF_ROOK_( const char* uplo, const int* n, const int* nb,
> void clahef_rook( const char* uplo, const int* n, const int* nb,
> void clahef_rook_( const char* uplo, const int* n, const int* nb,
> void CLASYF_ROOK( const char* uplo, const int* n, const int* nb,
> void CLASYF_ROOK_( const char* uplo, const int* n, const int* nb,
> void clasyf_rook( const char* uplo, const int* n, const int* nb,
> void clasyf_rook_( const char* uplo, const int* n, const int* nb,
> void CSYCON_ROOK( const char* uplo, const int* n, const MKL_Complex8* a,
> void CSYCON_ROOK_( const char* uplo, const int* n, const MKL_Complex8* a,
> void csycon_rook( const char* uplo, const int* n, const MKL_Complex8* a,
> void csycon_rook_( const char* uplo, const int* n, const MKL_Complex8* a,
> void CSYSV_ROOK( const char* uplo, const int* n, const int* nrhs,
> void CSYSV_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void csysv_rook( const char* uplo, const int* n, const int* nrhs,
> void csysv_rook_( const char* uplo, const int* n, const int* nrhs,
> void CSYTF2_ROOK( const char* uplo, const int* n, MKL_Complex8* a,
> void CSYTF2_ROOK_( const char* uplo, const int* n, MKL_Complex8* a,
> void csytf2_rook( const char* uplo, const int* n, MKL_Complex8* a,
> void csytf2_rook_( const char* uplo, const int* n, MKL_Complex8* a,
> void CSYTRF_ROOK( const char* uplo, const int* n, MKL_Complex8* a,
> void CSYTRF_ROOK_( const char* uplo, const int* n, MKL_Complex8* a,
> void csytrf_rook( const char* uplo, const int* n, MKL_Complex8* a,
> void csytrf_rook_( const char* uplo, const int* n, MKL_Complex8* a,
> void CSYTRI_ROOK( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void CSYTRI_ROOK_( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void csytri_rook( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void csytri_rook_( const char* uplo, const int* n, MKL_Complex8* a,
> int* info );
> void CSYTRS_ROOK( const char* uplo, const int* n, const int* nrhs,
> void CSYTRS_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void csytrs_rook( const char* uplo, const int* n, const int* nrhs,
> void csytrs_rook_( const char* uplo, const int* n, const int* nrhs,
> void DLASYF_ROOK( const char* uplo, const int* n, const int* nb,
> int* kb, double* a, const int* lda, int* ipiv,
> double* w, const int* ldw, int* info );
> void DLASYF_ROOK_( const char* uplo, const int* n, const int* nb,
> void dlasyf_rook( const char* uplo, const int* n, const int* nb,
> void dlasyf_rook_( const char* uplo, const int* n, const int* nb,
> void DSYCON_ROOK( const char* uplo, const int* n, const double* a,
> const int* lda, const int* ipiv, const double* anorm,
> double* rcond, double* work, int* iwork, int* info );
> void DSYCON_ROOK_( const char* uplo, const int* n, const double* a,
> void dsycon_rook( const char* uplo, const int* n, const double* a,
> void dsycon_rook_( const char* uplo, const int* n, const double* a,
> void DSYSV_ROOK( const char* uplo, const int* n, const int* nrhs, double* a,
> const int* lda, int* ipiv, double* b, const int* ldb,
> double* work, const int* lwork, int* info );
> void DSYSV_ROOK_( const char* uplo, const int* n, const int* nrhs,
> double* a, const int* lda, int* ipiv, double* b,
> const int* ldb, double* work, const int* lwork,
> int* info );
> void dsysv_rook( const char* uplo, const int* n, const int* nrhs, double* a,
> void dsysv_rook_( const char* uplo, const int* n, const int* nrhs,
> int* info );
> void DSYTF2_ROOK( const char* uplo, const int* n, double* a, const int* lda,
> void DSYTF2_ROOK_( const char* uplo, const int* n, double* a,
> void dsytf2_rook( const char* uplo, const int* n, double* a, const int* lda,
> void dsytf2_rook_( const char* uplo, const int* n, double* a,
> void DSYTRF_ROOK( const char* uplo, const int* n, double* a, const int* lda,
> int* ipiv, double* work, const int* lwork,
> int* info );
> void DSYTRF_ROOK_( const char* uplo, const int* n, double* a,
> const int* lda, int* ipiv, double* work,
> void dsytrf_rook( const char* uplo, const int* n, double* a, const int* lda,
> int* info );
> void dsytrf_rook_( const char* uplo, const int* n, double* a,
> void DSYTRI_ROOK( const char* uplo, const int* n, double* a, const int* lda,
> const int* ipiv, double* work, int* info );
> void DSYTRI_ROOK_( const char* uplo, const int* n, double* a,
> const int* lda, const int* ipiv, double* work,
> int* info );
> void dsytri_rook( const char* uplo, const int* n, double* a, const int* lda,
> void dsytri_rook_( const char* uplo, const int* n, double* a,
> int* info );
> void DSYTRS_ROOK( const char* uplo, const int* n, const int* nrhs,
> const double* a, const int* lda, const int* ipiv,
> double* b, const int* ldb, int* info );
> void DSYTRS_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void dsytrs_rook( const char* uplo, const int* n, const int* nrhs,
> void dsytrs_rook_( const char* uplo, const int* n, const int* nrhs,
> void SLASYF_ROOK( const char* uplo, const int* n, const int* nb,
> int* kb, float* a, const int* lda, int* ipiv,
> float* w, const int* ldw, int* info );
> void SLASYF_ROOK_( const char* uplo, const int* n, const int* nb,
> void slasyf_rook( const char* uplo, const int* n, const int* nb,
> void slasyf_rook_( const char* uplo, const int* n, const int* nb,
> void SSYCON_ROOK( const char* uplo, const int* n, const float* a,
> float* rcond, float* work, int* iwork, int* info );
> void SSYCON_ROOK_( const char* uplo, const int* n, const float* a,
> void ssycon_rook( const char* uplo, const int* n, const float* a,
> void ssycon_rook_( const char* uplo, const int* n, const float* a,
> void SSYSV_ROOK( const char* uplo, const int* n, const int* nrhs, float* a,
> const int* lda, int* ipiv, float* b, const int* ldb,
> float* work, const int* lwork, int* info );
> void SSYSV_ROOK_( const char* uplo, const int* n, const int* nrhs, float* a,
> void ssysv_rook( const char* uplo, const int* n, const int* nrhs, float* a,
> void ssysv_rook_( const char* uplo, const int* n, const int* nrhs, float* a,
> void SSYTF2_ROOK( const char* uplo, const int* n, float* a, const int* lda,
> void SSYTF2_ROOK_( const char* uplo, const int* n, float* a, const int* lda,
> void ssytf2_rook( const char* uplo, const int* n, float* a, const int* lda,
> void ssytf2_rook_( const char* uplo, const int* n, float* a, const int* lda,
> void SSYTRF_ROOK( const char* uplo, const int* n, float* a, const int* lda,
> int* ipiv, float* work, const int* lwork, int* info );
> void SSYTRF_ROOK_( const char* uplo, const int* n, float* a, const int* lda,
> int* info );
> void ssytrf_rook( const char* uplo, const int* n, float* a, const int* lda,
> void ssytrf_rook_( const char* uplo, const int* n, float* a, const int* lda,
> int* info );
> void SSYTRI_ROOK( const char* uplo, const int* n, float* a, const int* lda,
> const int* ipiv, float* work, int* info );
> void SSYTRI_ROOK_( const char* uplo, const int* n, float* a, const int* lda,
> void ssytri_rook( const char* uplo, const int* n, float* a, const int* lda,
> void ssytri_rook_( const char* uplo, const int* n, float* a, const int* lda,
> void SSYTRS_ROOK( const char* uplo, const int* n, const int* nrhs,
> const float* a, const int* lda, const int* ipiv, float* b,
> void SSYTRS_ROOK_( const char* uplo, const int* n, const int* nrhs,
> float* b, const int* ldb, int* info );
> void ssytrs_rook( const char* uplo, const int* n, const int* nrhs,
> void ssytrs_rook_( const char* uplo, const int* n, const int* nrhs,
> void ZHECON_ROOK( const char* uplo, const int* n, const MKL_Complex16* a,
> double* rcond, MKL_Complex16* work, int* info );
> void ZHECON_ROOK_( const char* uplo, const int* n, const MKL_Complex16* a,
> void zhecon_rook( const char* uplo, const int* n, const MKL_Complex16* a,
> void zhecon_rook_( const char* uplo, const int* n, const MKL_Complex16* a,
> void ZHESV_ROOK( const char* uplo, const int* n, const int* nrhs,
> MKL_Complex16* a, const int* lda, int* ipiv,
> MKL_Complex16* b, const int* ldb, MKL_Complex16* work,
> void ZHESV_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void zhesv_rook( const char* uplo, const int* n, const int* nrhs,
> void zhesv_rook_( const char* uplo, const int* n, const int* nrhs,
> void ZHETF2_ROOK( const char* uplo, const int* n, MKL_Complex16* a,
> void ZHETF2_ROOK_( const char* uplo, const int* n, MKL_Complex16* a,
> void zhetf2_rook( const char* uplo, const int* n, MKL_Complex16* a,
> void zhetf2_rook_( const char* uplo, const int* n, MKL_Complex16* a,
> void ZHETRF_ROOK( const char* uplo, const int* n, MKL_Complex16* a,
> const int* lda, int* ipiv, MKL_Complex16* work,
> void ZHETRF_ROOK_( const char* uplo, const int* n, MKL_Complex16* a,
> void zhetrf_rook( const char* uplo, const int* n, MKL_Complex16* a,
> void zhetrf_rook_( const char* uplo, const int* n, MKL_Complex16* a,
> void ZHETRI_ROOK( const char* uplo, const int* n, MKL_Complex16* a,
> const int* lda, const int* ipiv, MKL_Complex16* work,
> int* info );
> void ZHETRI_ROOK_( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void zhetri_rook( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void zhetri_rook_( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void ZHETRS_ROOK( const char* uplo, const int* n, const int* nrhs,
> const MKL_Complex16* a, const int* lda, const int* ipiv,
> MKL_Complex16* b, const int* ldb, int* info );
> void ZHETRS_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void zhetrs_rook( const char* uplo, const int* n, const int* nrhs,
> void zhetrs_rook_( const char* uplo, const int* n, const int* nrhs,
> void ZLAHEF_ROOK( const char* uplo, const int* n, const int* nb,
> int* kb, MKL_Complex16* a, const int* lda, int* ipiv,
> MKL_Complex16* w, const int* ldw, int* info );
> void ZLAHEF_ROOK_( const char* uplo, const int* n, const int* nb,
> void zlahef_rook( const char* uplo, const int* n, const int* nb,
> void zlahef_rook_( const char* uplo, const int* n, const int* nb,
> void ZLASYF_ROOK( const char* uplo, const int* n, const int* nb,
> void ZLASYF_ROOK_( const char* uplo, const int* n, const int* nb,
> void zlasyf_rook( const char* uplo, const int* n, const int* nb,
> void zlasyf_rook_( const char* uplo, const int* n, const int* nb,
> void ZSYCON_ROOK( const char* uplo, const int* n, const MKL_Complex16* a,
> void ZSYCON_ROOK_( const char* uplo, const int* n, const MKL_Complex16* a,
> void zsycon_rook( const char* uplo, const int* n, const MKL_Complex16* a,
> void zsycon_rook_( const char* uplo, const int* n, const MKL_Complex16* a,
> void ZSYSV_ROOK( const char* uplo, const int* n, const int* nrhs,
> void ZSYSV_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void zsysv_rook( const char* uplo, const int* n, const int* nrhs,
> void zsysv_rook_( const char* uplo, const int* n, const int* nrhs,
> void ZSYTF2_ROOK( const char* uplo, const int* n, MKL_Complex16* a,
> void ZSYTF2_ROOK_( const char* uplo, const int* n, MKL_Complex16* a,
> void zsytf2_rook( const char* uplo, const int* n, MKL_Complex16* a,
> void zsytf2_rook_( const char* uplo, const int* n, MKL_Complex16* a,
> void ZSYTRF_ROOK( const char* uplo, const int* n, MKL_Complex16* a,
> void ZSYTRF_ROOK_( const char* uplo, const int* n, MKL_Complex16* a,
> void zsytrf_rook( const char* uplo, const int* n, MKL_Complex16* a,
> void zsytrf_rook_( const char* uplo, const int* n, MKL_Complex16* a,
> void ZSYTRI_ROOK( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void ZSYTRI_ROOK_( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void zsytri_rook( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void zsytri_rook_( const char* uplo, const int* n, MKL_Complex16* a,
> int* info );
> void ZSYTRS_ROOK( const char* uplo, const int* n, const int* nrhs,
> void ZSYTRS_ROOK_( const char* uplo, const int* n, const int* nrhs,
> void zsytrs_rook( const char* uplo, const int* n, const int* nrhs,
> void zsytrs_rook_( const char* uplo, const int* n, const int* nrhs,
> void CUNBDB1( const int* m, const int* p, const int* q,
> MKL_Complex8* x11, const int* ldx11, MKL_Complex8* x21,
> const int* ldx21, float* theta, float* phi,
> MKL_Complex8* taup1, MKL_Complex8* taup2, MKL_Complex8* tauq1,
> MKL_Complex8* work, const int* lwork, int* info );
> void CUNBDB1_( const int* m, const int* p, const int* q,
> void cunbdb1( const int* m, const int* p, const int* q,
> void cunbdb1_( const int* m, const int* p, const int* q,
> void CUNBDB2( const int* m, const int* p, const int* q,
> void CUNBDB2_( const int* m, const int* p, const int* q,
> void cunbdb2( const int* m, const int* p, const int* q,
> void cunbdb2_( const int* m, const int* p, const int* q,
> void CUNBDB3( const int* m, const int* p, const int* q,
> void CUNBDB3_( const int* m, const int* p, const int* q,
> void cunbdb3( const int* m, const int* p, const int* q,
> void cunbdb3_( const int* m, const int* p, const int* q,
> void CUNBDB4( const int* m, const int* p, const int* q,
> MKL_Complex8* phantom, MKL_Complex8* work, const int* lwork,
> int* info );
> void CUNBDB4_( const int* m, const int* p, const int* q,
> int* info );
> void cunbdb4( const int* m, const int* p, const int* q,
> int* info );
> void cunbdb4_( const int* m, const int* p, const int* q,
> int* info );
> void CUNBDB5( const int* m1, const int* m2, const int* n,
> MKL_Complex8* x1, const int* incx1, MKL_Complex8* x2,
> const int* incx2, MKL_Complex8* q1, const int* ldq1,
> MKL_Complex8* q2, const int* ldq2, MKL_Complex8* work,
> void CUNBDB5_( const int* m1, const int* m2, const int* n,
> void cunbdb5( const int* m1, const int* m2, const int* n,
> void cunbdb5_( const int* m1, const int* m2, const int* n,
> void CUNBDB6( const int* m1, const int* m2, const int* n,
> void CUNBDB6_( const int* m1, const int* m2, const int* n,
> void cunbdb6( const int* m1, const int* m2, const int* n,
> void cunbdb6_( const int* m1, const int* m2, const int* n,
> void CUNCSD2BY1( const char* jobu1, const char* jobu2, const char* jobv1t,
> const int* ldx21, float* theta, MKL_Complex8* u1,
> const int* ldu1, MKL_Complex8* u2, const int* ldu2,
> MKL_Complex8* v1t, const int* ldv1t, MKL_Complex8* work,
> const int* lwork, float* rwork, const int* lrwork,
> void CUNCSD2BY1_( const char* jobu1, const char* jobu2, const char* jobv1t,
> void cuncsd2by1( const char* jobu1, const char* jobu2, const char* jobv1t,
> void cuncsd2by1_( const char* jobu1, const char* jobu2, const char* jobv1t,
> void DORBDB1( const int* m, const int* p, const int* q,
> double* x11, const int* ldx11, double* x21,
> const int* ldx21, double* theta, double* phi,
> double* taup1, double* taup2, double* tauq1,
> void DORBDB1_( const int* m, const int* p, const int* q,
> void dorbdb1( const int* m, const int* p, const int* q,
> void dorbdb1_( const int* m, const int* p, const int* q,
> void DORBDB2( const int* m, const int* p, const int* q,
> void DORBDB2_( const int* m, const int* p, const int* q,
> void dorbdb2( const int* m, const int* p, const int* q,
> void dorbdb2_( const int* m, const int* p, const int* q,
> void DORBDB3( const int* m, const int* p, const int* q,
> void DORBDB3_( const int* m, const int* p, const int* q,
> void dorbdb3( const int* m, const int* p, const int* q,
> void dorbdb3_( const int* m, const int* p, const int* q,
> void DORBDB4( const int* m, const int* p, const int* q,
> double* phantom, double* work, const int* lwork,
> int* info );
> void DORBDB4_( const int* m, const int* p, const int* q,
> int* info );
> void dorbdb4( const int* m, const int* p, const int* q,
> int* info );
> void dorbdb4_( const int* m, const int* p, const int* q,
> int* info );
> void DORBDB5( const int* m1, const int* m2, const int* n,
> double* x1, const int* incx1, double* x2,
> const int* incx2, double* q1, const int* ldq1,
> double* q2, const int* ldq2, double* work,
> void DORBDB5_( const int* m1, const int* m2, const int* n,
> void dorbdb5( const int* m1, const int* m2, const int* n,
> void dorbdb5_( const int* m1, const int* m2, const int* n,
> void DORBDB6( const int* m1, const int* m2, const int* n,
> void DORBDB6_( const int* m1, const int* m2, const int* n,
> void dorbdb6( const int* m1, const int* m2, const int* n,
> void dorbdb6_( const int* m1, const int* m2, const int* n,
> void DORCSD2BY1( const char* jobu1, const char* jobu2, const char* jobv1t,
> const int* ldx21, double* theta, double* u1,
> const int* ldu1, double* u2, const int* ldu2,
> double* v1t, const int* ldv1t, double* work,
> const int* lwork, int* iwork, int* info );
> void DORCSD2BY1_( const char* jobu1, const char* jobu2, const char* jobv1t,
> void dorcsd2by1( const char* jobu1, const char* jobu2, const char* jobv1t,
> void dorcsd2by1_( const char* jobu1, const char* jobu2, const char* jobv1t,
> void SORBDB1( const int* m, const int* p, const int* q,
> float* x11, const int* ldx11, float* x21,
> float* taup1, float* taup2, float* tauq1,
> void SORBDB1_( const int* m, const int* p, const int* q,
> void sorbdb1( const int* m, const int* p, const int* q,
> void sorbdb1_( const int* m, const int* p, const int* q,
> void SORBDB2( const int* m, const int* p, const int* q,
> void SORBDB2_( const int* m, const int* p, const int* q,
> void sorbdb2( const int* m, const int* p, const int* q,
> void sorbdb2_( const int* m, const int* p, const int* q,
> void SORBDB3( const int* m, const int* p, const int* q,
> void SORBDB3_( const int* m, const int* p, const int* q,
> void sorbdb3( const int* m, const int* p, const int* q,
> void sorbdb3_( const int* m, const int* p, const int* q,
> void SORBDB4( const int* m, const int* p, const int* q,
> float* phantom, float* work, const int* lwork,
> int* info );
> void SORBDB4_( const int* m, const int* p, const int* q,
> int* info );
> void sorbdb4( const int* m, const int* p, const int* q,
> int* info );
> void sorbdb4_( const int* m, const int* p, const int* q,
> int* info );
> void SORBDB5( const int* m1, const int* m2, const int* n,
> float* x1, const int* incx1, float* x2,
> const int* incx2, float* q1, const int* ldq1,
> float* q2, const int* ldq2, float* work,
> void SORBDB5_( const int* m1, const int* m2, const int* n,
> void sorbdb5( const int* m1, const int* m2, const int* n,
> void sorbdb5_( const int* m1, const int* m2, const int* n,
> void SORBDB6( const int* m1, const int* m2, const int* n,
> void SORBDB6_( const int* m1, const int* m2, const int* n,
> void sorbdb6( const int* m1, const int* m2, const int* n,
> void sorbdb6_( const int* m1, const int* m2, const int* n,
> void SORCSD2BY1( const char* jobu1, const char* jobu2, const char* jobv1t,
> const int* ldx21, float* theta, float* u1,
> const int* ldu1, float* u2, const int* ldu2,
> float* v1t, const int* ldv1t, float* work,
> void SORCSD2BY1_( const char* jobu1, const char* jobu2, const char* jobv1t,
> void sorcsd2by1( const char* jobu1, const char* jobu2, const char* jobv1t,
> void sorcsd2by1_( const char* jobu1, const char* jobu2, const char* jobv1t,
> void ZUNBDB1( const int* m, const int* p, const int* q,
> MKL_Complex16* x11, const int* ldx11, MKL_Complex16* x21,
> MKL_Complex16* taup1, MKL_Complex16* taup2, MKL_Complex16* tauq1,
> MKL_Complex16* work, const int* lwork, int* info );
> void ZUNBDB1_( const int* m, const int* p, const int* q,
> void zunbdb1( const int* m, const int* p, const int* q,
> void zunbdb1_( const int* m, const int* p, const int* q,
> void ZUNBDB2( const int* m, const int* p, const int* q,
> void ZUNBDB2_( const int* m, const int* p, const int* q,
> void zunbdb2( const int* m, const int* p, const int* q,
> void zunbdb2_( const int* m, const int* p, const int* q,
> void ZUNBDB3( const int* m, const int* p, const int* q,
> void ZUNBDB3_( const int* m, const int* p, const int* q,
> void zunbdb3( const int* m, const int* p, const int* q,
> void zunbdb3_( const int* m, const int* p, const int* q,
> void ZUNBDB4( const int* m, const int* p, const int* q,
> MKL_Complex16* phantom, MKL_Complex16* work, const int* lwork,
> int* info );
> void ZUNBDB4_( const int* m, const int* p, const int* q,
> int* info );
> void zunbdb4( const int* m, const int* p, const int* q,
> MKL_Com
