[petsc-dev] problem in PETSc.pc file
Stefano Zampini stefano.zampini at gmail.com
Sat Aug 26 03:25:54 CDT 2017
I have recently noticed a regression with using Libs.private of PETSc.pc
(used by MFEM configure). For some reason, the mumps and mkl linking lines
are scrambled up. At the bottom of the message you can see the undefined
references I'm getting, coming from having libdmumps before libscalapack,
and libmkl_intel_lp64 before libdmumps and libcholmod. This configuration
(static build with gnu compilers and MKL on a Cray XC40.... yes, I know,
life could be easier....) was working before, but I cannot say when got
broken.
This is the line in PETSc.pc that corresponds to Libs.private and that
makes the executable linking to fail.
-L/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib  -lcmumps  -lscalapack
-lumfpack  -lHYPRE -L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64
-lmkl_intel_lp64  -lmkl_core  -lmkl_sequential  -lparmetis  -lmetis
-lptesmumps
-L/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/
-L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -ldmumps -lsmumps
-lzmumps -lmumps_common -lpord -lklu -lcholmod -lbtf -lccolamd -lcolamd
-lcamd -lamd -lsuitesparseconfig -lptscotch -lptscotcherr -lscotch
-lscotcherr -lrt -lm -lpthread -lz -ldl -lmkl_core -lmkl_sequential
-lmkl_core -lmkl_sequential -lmkl_core -lirc -liomp5 -lsvml -limf -lifcore
-lirng -lifport -lirc -ldl
Instead, this is PETSC_EXTERNAL_LIB_BASIC from petscvariables, that leads
(with the current master) to a successful linking
-Wl,-rpath,/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib
-Wl,-rpath,/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64
-L/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/ -lcmumps -ldmumps
-lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lumfpack -lklu
-lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lHYPRE
-lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lmkl_core -lmkl_sequential
-lmkl_core -lparmetis -lmetis -lptesmumps -lptscotch -lptscotcherr -lscotch
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dana_driver.o):
In function `dmumps_ana_driver_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dana_driver.F:1944:
undefined reference to `numroc_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dana_driver.F:1948:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_driver.o):
In function `dmumps_fac_driver_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_driver.F:1605:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_driver.F:1609:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dend_driver.o):
In function `dmumps_end_driver_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dend_driver.F:44:
undefined reference to `blacs_gridexit_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dana_aux_ELT.o):
In function `dmumps_ana_f_elt_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dana_aux_ELT.F:257:
undefined reference to `metis_setdefaultoptions_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dana_aux.o):
In function `dmumps_ana_f_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dana_aux.F:564:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(darrowheads.o):
In function `dmumps_facto_send_arrowheads_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/darrowheads.F:254:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/darrowheads.F:257:
In function `dmumps_facto_recv_arrowhd2_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/darrowheads.F:688:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/darrowheads.F:691:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_distrib_distentry.o):
In function `dmumps_redistribution_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_distrib_distentry.F:264:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_distrib_distentry.o):/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_distrib_distentry.F:267:
more undefined references to `numroc_' follow
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dsol_root_parallel.o):
In function `dmumps_solve_2d_bcyclic_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dsol_root_parallel.F:76:
undefined reference to `descinit_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dsol_root_parallel.F:84:
undefined reference to `pdgetrs_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dsol_root_parallel.F:87:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dsol_root_parallel.F:91:
undefined reference to `pdpotrs_'
In function `dmumps_root_solve_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dsol_root_parallel.F:33:
undefined reference to `blacs_gridinfo_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dsol_root_parallel.F:34:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dtype3_root.o):
In function `dmumps_root_alloc_static_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dtype3_root.F:1085:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dtype3_root.F:1088:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dtype3_root.F:1091:
In function `dmumps_init_root_ana_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dtype3_root.F:783:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dtype3_root.F:788:
undefined reference to `blacs_gridinit_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dtype3_root.F:792:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_par_m.o):
In function `__dmumps_fac_par_m_MOD_dmumps_fac_par':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_par_m.F:744:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_root_parallel.o):
In function `dmumps_facto_root_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_root_parallel.F:77:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_root_parallel.F:100:
undefined reference to `pdgetrf_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_root_parallel.F:107:
undefined reference to `pdpotrf_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_root_parallel.F:155:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dmumps_iXamax.o):
In function `dmumps_ixamax_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dmumps_iXamax.F:17:
undefined reference to `idamax_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dfac_lr.o):
In function `__dmumps_fac_lr_MOD_dmumps_compress_panel':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dfac_lr.F:873:
undefined reference to `dormqr_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libdmumps.a(dlr_core_subroutine.o):
In function `dmumps_truncated_rrqr_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:69:
undefined reference to `ilaenv_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:78:
undefined reference to `dnrm2_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:83:
undefined reference to `dlamch_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:92:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:121:
undefined reference to `dlarfg_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:123:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/dlr_core_subroutine.F:189:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmumps_common.a(ana_orderings_wrappers_m.o):
In function `__mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto64':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/ana_orderings_wrappers_m.F:225:
undefined reference to `metis_nodend_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/ana_orderings_wrappers_m.F:246:
In function `__mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/ana_orderings_wrappers_m.F:115:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmumps_common.a(mumps_metis.o):
In function `mumps_parmetis_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/mumps_metis.c:43:
undefined reference to `ParMETIS_V3_NodeND'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmumps_common.a(mumps_scotch.o):
In function `mumps_scotch_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/mumps_scotch.c:31:
undefined reference to `esmumps'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libmumps_common.a(mumps_scotch64.o):
In function `mumps_scotch_64_':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/git.mumps/src/mumps_scotch64.c:30:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libcholmod.a(cholmod_super_numeric.o):
In function `c_cholmod_super_numeric':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_numeric.c:692:
undefined reference to `zherk_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_numeric.c:722:
undefined reference to `zgemm_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_numeric.c:872:
undefined reference to `zpotrf_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_numeric.c:1007:
undefined reference to `ztrsm_'
In function `z_cholmod_super_numeric':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/lib/libcholmod.a(cholmod_super_solve.o):
In function `c_cholmod_super_lsolve':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:110:
undefined reference to `ztrsv_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:116:
undefined reference to `zgemv_'
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:189:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:198:
In function `c_cholmod_super_ltsolve':
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:318:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:328:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:393:
/home/zampins/src/petsc/haswell_debug_gnu_mkl/externalpackages/SuiteSparse/CHOLMOD/Lib/../Supernodal/t_cholmod_super_solve.c:404:
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170826/4cb94668/attachment-0001.html>
