[petsc-dev] Small fix associating MatPtAP_seqaijperm_seqmaij_C
    Richard Tran Mills
    rtmills at anl.gov
    Wed Aug 16 17:40:34 CDT 2017
Satish et al.,
I noticed a failure when testing with SeqAIJPERM and have made a small fix
that is on branch rmills/fix-seqaijperm_seqmaij. If such a small fix needs
to be tested in next, then please merge to next for testing. Otherwise,
please merge to master.
Because it is so small, for convenience I have appended the git commit.
--Richard
rmills at Richards-MBP:tests(rmills/fix-seqaijperm_seqmaij=)arch-osx-clang-gfortran7-debug$
git show
commit 1fde5765381347da5003c8b2045311701bd352b4 (HEAD ->
rmills/fix-seqaijperm_seqmaij, origin/rmills/fix-seqaijperm_seqmaij)
Author: Richard Tran Mills <rmills at rmills.org>
Date:   Wed Aug 16 15:32:10 2017 -0700
    Associated function for MatPtAP_seqaijperm_seqmaij_C.
diff --git a/src/mat/impls/maij/maij.c b/src/mat/impls/maij/maij.c
index 83a4c181fe..b2c1711bd5 100644
--- a/src/mat/impls/maij/maij.c
+++ b/src/mat/impls/maij/maij.c
@@ -96,6 +96,7 @@ PetscErrorCode MatDestroy_SeqMAIJ(Mat A)
   ierr = PetscFree(A->data);CHKERRQ(ierr);
   ierr =
PetscObjectComposeFunction((PetscObject)A,"MatConvert_seqmaij_seqaij_C",NULL);CHKERRQ(ierr);
   ierr =
PetscObjectComposeFunction((PetscObject)A,"MatPtAP_seqaij_seqmaij_C",NULL);CHKERRQ(ierr);
+  ierr =
PetscObjectComposeFunction((PetscObject)A,"MatPtAP_seqaijperm_seqmaij_C",NULL);CHKERRQ(ierr);
   PetscFunctionReturn(0);
@@ -3377,6 +3378,7 @@ PetscErrorCode  MatCreateMAIJ(Mat A,PetscInt dof,Mat
*maij)
       ierr =
PetscObjectComposeFunction((PetscObject)B,"MatConvert_seqmaij_seqaij_C",MatConvert_SeqMAIJ_SeqAIJ);CHKERRQ(ierr);
       ierr =
PetscObjectComposeFunction((PetscObject)B,"MatPtAP_seqaij_seqmaij_C",MatPtAP_SeqAIJ_SeqMAIJ);CHKERRQ(ierr);
+      ierr =
PetscObjectComposeFunction((PetscObject)B,"MatPtAP_seqaijperm_seqmaij_C",MatPtAP_SeqAIJ_SeqMAIJ);CHKERRQ(ierr);
     } else {
       Mat_MPIAIJ  *mpiaij = (Mat_MPIAIJ*)A->data;
       Mat_MPIMAIJ *b;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170816/336e308c/attachment.html>
