[petsc-dev] petsc patch number
Wed Apr 19 10:40:35 CDT 2017
Use --download-superlu_dist=url-to-fixed-superlu_dist-version
[or if using superlu_dist from git]
--download-superlu_dist-commit=commit
Current maint has points to 'v5.1.3' - so you could use:
--download-superlu_dist-commit=v5.1.3
Satish
On Wed, 19 Apr 2017, Kong, Fande wrote:
> Thanks for your email.  Sorry for late reply.
> On Thu, Apr 13, 2017 at 10:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Individual commits are not strictly ordered.  'maint' does not get API
> > changes.  What are you trying to test for?  Presence of a bug fix?
> Yes, I am going to test for the bug fix.
> There is a test system on the moose-side. We usually test all examples
> against one or two versions of PETSc, (PETSc-3.7.5 and/or PETSc-3.6.4,
> right now). The PETSc is precompiled and sits in the test system.  Now,
> there is a bug fix for superlu_dist in the current patched petsc. We want
> to test SOME of examples (not all of them) against the current patched
> petsc (the version number is still the same, 3.7.5). In a test file, we
> have something like "petsc_version= x.x.x " to tell the test system which
> version of petsc we want to use.  But now, I can not distinguish the petsc
> with the broken superlu_dist and the current patched petsc by using the
> petsc version number.
> Any suggestions?
> Fande,
> > "Kong, Fande" <fande.kong at inl.gov> writes:
> > > Thanks,
> > > In the moose side, we want to make some tests against the current maint,
> > > but still have some tests against the old one. The two versions of petsc
> > > may have the same petsc version number, e.g. 3.7.5. I want a patch number
> > > from which I could tell which one is newer. How it is different from the
> > > old one.
> > > Any alternative way to do that? When compiling  PETSc, do we have a macro
> > > variable to define the commit number?
> > > Fande,
> > > On Thu, Apr 13, 2017 at 12:06 PM, Satish Balay <balay at mcs.anl.gov>
> > wrote:
> > >> On Thu, 13 Apr 2017, Kong, Fande wrote:
> > >> > Hi Developers,
> > >> > Do we increase the patch number when pushing a new patch into maint?
> > >> nope
> > >> > If not, how to know if the current maint is different from the one I
> > >> > just got yesterday. I know a commit number is always available.
> > >> git fetch && git log maint..origin/maint
> > >> [and you can look at that and decide to do a 'git pull' on maint]
> > >> Satish
